[U-Boot] [PATCH 1/5] msm7x30: Add support for low speed uart on msm7x30
From: Mohamed Haneef mohamed.haneef@lntinfotech.com
* Support for low speed uart
Signed-off-by: Mohamed Haneef mohamed.haneef@lntinfotech.com --- drivers/serial/Makefile | 1 + drivers/serial/serial_msm_uart.c | 206 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 207 insertions(+), 0 deletions(-) create mode 100644 drivers/serial/serial_msm_uart.c
diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 616b857..2801edc 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -55,6 +55,7 @@ COBJS-$(CONFIG_S3C44B0_SERIAL) += serial_s3c44b0.o COBJS-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o COBJS-$(CONFIG_SANDBOX_SERIAL) += sandbox.o COBJS-$(CONFIG_SCIF_CONSOLE) += serial_sh.o +COBJS-$(CONFIG_MSM_UART) += serial_msm_uart.o
ifndef CONFIG_SPL_BUILD COBJS-$(CONFIG_USB_TTY) += usbtty.o diff --git a/drivers/serial/serial_msm_uart.c b/drivers/serial/serial_msm_uart.c new file mode 100644 index 0000000..8cafa7a --- /dev/null +++ b/drivers/serial/serial_msm_uart.c @@ -0,0 +1,206 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/arch/iomap.h> +#include <asm/io.h> +#include <asm/types.h> + +#define UART_MR1 0x0000 + +#define UART_MR1_AUTO_RFR_LEVEL0(n) (((n) & 0x3f) << 8) +#define UART_MR1_RX_RDY_CTL (1 << 7) +#define UART_MR1_CTS_CTL (1 << 6) +#define UART_MR1_AUTO_RFR_LEVEL1(n) ((n) & 0x3f) + +#define UART_MR2 0x0004 +#define UART_MR2_ERROR_MODE (1 << 6) +#define UART_MR2_BITS_PER_CHAR_5 (0 << 4) +#define UART_MR2_BITS_PER_CHAR_6 (1 << 4) +#define UART_MR2_BITS_PER_CHAR_7 (2 << 4) +#define UART_MR2_BITS_PER_CHAR_8 (3 << 4) +#define UART_MR2_STOP_BIT_LEN_0563 (0 << 2) +#define UART_MR2_STOP_BIT_LEN_1000 (1 << 2) +#define UART_MR2_STOP_BIT_LEN_1563 (2 << 2) +#define UART_MR2_STOP_BIT_LEN_2000 (3 << 2) +#define UART_MR2_PARITY_MODE_NONE (0) +#define UART_MR2_PARITY_MODE_ODD (1) +#define UART_MR2_PARITY_MODE_EVEN (2) +#define UART_MR2_PARITY_MODE_SPACE (3) + +#define UART_CSR 0x0008 +#define UART_CSR_115200 0xFF +#define UART_CSR_57600 0xEE +#define UART_CSR_38400 0xDD +#define UART_CSR_19200 0xBB + +#define UART_TF 0x000C + +#define UART_CR 0x0010 +#define UART_CR_CMD_NULL (0 << 4) +#define UART_CR_CMD_RESET_RX (1 << 4) +#define UART_CR_CMD_RESET_TX (2 << 4) +#define UART_CR_CMD_RESET_ERR (3 << 4) +#define UART_CR_CMD_RESET_BCI (4 << 4) +#define UART_CR_CMD_START_BREAK (5 << 4) +#define UART_CR_CMD_STOP_BREAK (6 << 4) +#define UART_CR_CMD_RESET_CTS_N (7 << 4) +#define UART_CR_CMD_PACKET_MODE (9 << 4) +#define UART_CR_CMD_MODE_RESET (12 << 4) +#define UART_CR_CMD_SET_RFR_N (13 << 4) +#define UART_CR_CMD_RESET_RFR_ND (14 << 4) +#define UART_CR_TX_DISABLE (1 << 3) +#define UART_CR_TX_ENABLE (1 << 3) +#define UART_CR_RX_DISABLE (1 << 3) +#define UART_CR_RX_ENABLE (1 << 3) + +#define UART_IMR 0x0014 +#define UART_IMR_RXLEV (1 << 4) +#define UART_IMR_TXLEV (1 << 0) + +#define UART_IPR 0x0018 +#define UART_TFWR 0x001C +#define UART_RFWR 0x0020 +#define UART_HCR 0x0024 + +#define UART_MREG 0x0028 +#define UART_NREG 0x002C +#define UART_DREG 0x0030 +#define UART_MNDREG 0x0034 +#define UART_IRDA 0x0038 +#define UART_MISR_MODE 0x0040 +#define UART_MISR_RESET 0x0044 +#define UART_MISR_EXPORT 0x0048 +#define UART_MISR_VAL 0x004C +#define UART_TEST_CTRL 0x0050 + +#define UART_SR 0x0008 +#define UART_SR_HUNT_CHAR (1 << 7) +#define UART_SR_RX_BREAK (1 << 6) +#define UART_SR_PAR_FRAME_ERR (1 << 5) +#define UART_SR_OVERRUN (1 << 4) +#define UART_SR_TX_EMPTY (1 << 3) +#define UART_SR_TX_READY (1 << 2) +#define UART_SR_RX_FULL (1 << 1) +#define UART_SR_RX_READY (1 << 0) + +#define UART_RF 0x000C +#define UART_MISR 0x0010 +#define UART_ISR 0x0014 + + +#if PLATFORM_MSM7X30 +static unsigned uart_base = MSM_UART2_BASE; +#elif PLATFORM_MSM7X27A +static unsigned uart_base = MSM_UART1_BASE; +#else +static unsigned uart_base = MSM_UART3_BASE; +#endif + +#define uwr(v, a) writel(v, uart_base + (a)) +#define urd(a) readl(uart_base + (a)) + +void uart_init(void) +{ + uwr(0x0A, UART_CR); /* disable TX and RX */ + uwr(0x30, UART_CR); /* reset error status */ + uwr(0x10, UART_CR); /* reset receiver */ + uwr(0x20, UART_CR); /* reset transmitter */ +#if PLATFORM_QSD8K || PLATFORM_MSM7X30 || PLATFORM_MSM7X27A + /* TCXO */ + uwr(0x06, UART_MREG); + uwr(0xF1, UART_NREG); + uwr(0x0F, UART_DREG); + uwr(0x1A, UART_MNDREG); +#else + /* TCXO/4 */ + uwr(0xC0, UART_MREG); + uwr(0xAF, UART_NREG); + uwr(0x80, UART_DREG); + uwr(0x19, UART_MNDREG); +#endif + uwr(0x10, UART_CR); /* reset RX */ + uwr(0x20, UART_CR); /* reset TX */ + uwr(0x30, UART_CR); /* reset error status */ + uwr(0x40, UART_CR); /* reset RX break */ + uwr(0x70, UART_CR); /* rest? */ + uwr(0xD0, UART_CR); /* reset */ + uwr(0x7BF, UART_IPR); /* stale timeout = 630 * bitrate */ + uwr(0, UART_IMR); + uwr(115, UART_RFWR); /* RX watermark = 58 * 2 - 1 */ + uwr(10, UART_TFWR); /* TX watermark */ + uwr(0, UART_RFWR); + uwr(UART_CSR_115200, UART_CSR); + uwr(0, UART_IRDA); + uwr(0x1E, UART_HCR); + uwr(16, UART_MR1); + uwr(0x34, UART_MR2); /* 8N1 */ + uwr(0x05, UART_CR); /* enable TX & RX */ + +} + +static int _uart_putc(int port, char c) +{ + while (!(urd(UART_SR) & UART_SR_TX_READY)) + ; + uwr(c, UART_TF); + return 0; +} + +int serial_init(void) +{ + uart_init(); + return 0; +} + +void serial_putc(char c) +{ + if (c == '\n') + _uart_putc(0, '\r'); + _uart_putc(0, c); +} + +void serial_putc_raw(const char c) +{ + _uart_putc(0, c); +} + +void serial_puts(const char *s) +{ + while (*s) + serial_putc(*s++); +} + +int serial_getc() +{ + while (!(urd(UART_SR) & UART_SR_RX_READY)) + ; + return urd(UART_RF); +} + +int serial_tstc() +{ + return urd(UART_SR) & UART_SR_RX_READY; +} + +void serial_setbrg() +{ +} + -- 1.7.1
The contents of this e-mail and any attachment(s) may contain confidential or privileged information for the intended recipient(s). Unintended recipients are prohibited from taking action on the basis of information in this e-mail and using or disseminating the information, and must notify the sender and delete it from their system. L&T Infotech will not accept responsibility or liability for the accuracy or completeness of, or the presence of any virus or disabling code in this e-mail"
Hi Mohamed,
Le 16/02/2012 03:59, mohamed.haneef@lntinfotech.com a écrit :
+#define UART_CR_TX_DISABLE (1<< 3) +#define UART_CR_TX_ENABLE (1<< 3)
I doubt the same bit value can mean both enable and disable.
+#define UART_CR_RX_DISABLE (1<< 3) +#define UART_CR_RX_ENABLE (1<< 3)
Ditto.
Besides, neither of these defines are used anyway. What's the point of having them? I suspect many others are unused, too. Unless there is a compelling reason to keep useless defines, remove them.
Please do not post with this footer on the list. It os obnoxious (and quite purposeless on a public list :) )
Amicalement,
Signed-off-by: Mohamed Haneef mohamed.haneef@lntinfotech.com --- Changes for v2: - Removed unused macros
drivers/serial/Makefile | 1 + drivers/serial/serial_msm_uart.c | 156 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 157 insertions(+), 0 deletions(-) create mode 100644 drivers/serial/serial_msm_uart.c
ifndef CONFIG_SPL_BUILD COBJS-$(CONFIG_USB_TTY) += usbtty.o diff --git a/drivers/serial/serial_msm_uart.c b/drivers/serial/serial_msm_uart.c new file mode 100644 index 0000000..8f80561 --- /dev/null +++ b/drivers/serial/serial_msm_uart.c @@ -0,0 +1,156 @@ +/* + * (C) Copyright 2012 + * LARSEN & TOUBRO INFOTECH LTD <www.lntinfotech.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/arch/iomap.h> +#include <asm/io.h> +#include <asm/types.h> + +#define UART_MR1 0x0000 + + +#define UART_MR2 0x0004 + +#define UART_CSR 0x0008 +#define UART_CSR_115200 0xFF + +#define UART_TF 0x000C + +#define UART_CR 0x0010 +#define UART_CR_CMD_MODE_RESET (12 << 4) + +#define UART_IMR 0x0014 + +#define UART_IPR 0x0018 +#define UART_TFWR 0x001C +#define UART_RFWR 0x0020 +#define UART_HCR 0x0024 + +#define UART_MREG 0x0028 +#define UART_NREG 0x002C +#define UART_DREG 0x0030 +#define UART_MNDREG 0x0034 +#define UART_IRDA 0x0038 + +#define UART_SR 0x0008 +#define UART_SR_TX_READY (1 << 2) +#define UART_SR_RX_READY (1 << 0) + +#define UART_RF 0x000C + + +#if PLATFORM_MSM7X30 +static unsigned uart_base = MSM_UART2_BASE; +#elif PLATFORM_MSM7X27A +static unsigned uart_base = MSM_UART1_BASE; +#else +static unsigned uart_base = MSM_UART3_BASE; +#endif + +#define uwr(v, a) writel(v, uart_base + (a)) +#define urd(a) readl(uart_base + (a)) + +void uart_init(void) +{ + uwr(0x0A, UART_CR); /* disable TX and RX */ + uwr(0x30, UART_CR); /* reset error status */ + uwr(0x10, UART_CR); /* reset receiver */ + uwr(0x20, UART_CR); /* reset transmitter */ +#if PLATFORM_QSD8K || PLATFORM_MSM7X30 || PLATFORM_MSM7X27A + /* TCXO */ + uwr(0x06, UART_MREG); + uwr(0xF1, UART_NREG); + uwr(0x0F, UART_DREG); + uwr(0x1A, UART_MNDREG); +#else + /* TCXO/4 */ + uwr(0xC0, UART_MREG); + uwr(0xAF, UART_NREG); + uwr(0x80, UART_DREG); + uwr(0x19, UART_MNDREG); +#endif + uwr(0x10, UART_CR); /* reset RX */ + uwr(0x20, UART_CR); /* reset TX */ + uwr(0x30, UART_CR); /* reset error status */ + uwr(0x40, UART_CR); /* reset RX break */ + uwr(0x70, UART_CR); /* rest? */ + uwr(0xD0, UART_CR); /* reset */ + uwr(0x7BF, UART_IPR); /* stale timeout = 630 * bitrate */ + uwr(0, UART_IMR); + uwr(115, UART_RFWR); /* RX watermark = 58 * 2 - 1 */ + uwr(10, UART_TFWR); /* TX watermark */ + uwr(0, UART_RFWR); + uwr(UART_CSR_115200, UART_CSR); + uwr(0, UART_IRDA); + uwr(0x1E, UART_HCR); + uwr(16, UART_MR1); + uwr(0x34, UART_MR2); /* 8N1 */ + uwr(0x05, UART_CR); /* enable TX & RX */ + +} + +static int _uart_putc(int port, char c) +{ + while (!(urd(UART_SR) & UART_SR_TX_READY)) + ; + uwr(c, UART_TF); + return 0; +} + +int serial_init(void) +{ + uart_init(); + return 0; +} + +void serial_putc(char c) +{ + if (c == '\n') + _uart_putc(0, '\r'); + _uart_putc(0, c); +} + +void serial_putc_raw(const char c) +{ + _uart_putc(0, c); +} + +void serial_puts(const char *s) +{ + while (*s) + serial_putc(*s++); +} + +int serial_getc() +{ + while (!(urd(UART_SR) & UART_SR_RX_READY)) + ; + return urd(UART_RF); +} + +int serial_tstc() +{ + return urd(UART_SR) & UART_SR_RX_READY; +} + +void serial_setbrg() +{ +} + -- 1.7.1
This is a humbel reminder for review of patch series for msm7630 board after making the changes proposed by u-boot community. The Patches contain the following support * low speed uart for msm7630 * interprocessor communication * qc_mmc microcontroller * msm7630 soc * msm7630 surf board
The patch for msm7630 was released to the u-boot community on 16-feb-2-2012 can this be mainlined in v2012.07 release.The Patches contain the following support * low speed uart for msm7630 * interprocessor communication * qc_mmc microcontroller * msm7630 soc * msm7630 surf board
Thanks and regards, Mohamed Haneef M.A
Dear mohamed.haneef@lntinfotech.com,
It'd be great, CCing albert to review it as we don't have MSM maintainer.
The contents of this e-mail and any attachment(s) may contain confidential or privileged information for the intended recipient(s). Unintended recipients are prohibited from taking action on the basis of information in this e-mail and using or disseminating the information, and must notify the sender and delete it from their system. L&T Infotech will not accept responsibility or liability for the accuracy or completeness of, or the presence of any virus or disabling code in this e-mail" _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Best regards, Marek Vasut
Albert ARIBAUD
Mohamed Haneef
