[PATCH] env: Kconfig: Adding default values for Microblaze
This patch will add default values for ENV_OFFSET and ENV_SECT_SIZE for Microblaze.
Signed-off-by: Varalaxmi Bingi varalaxmi.bingi@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
env/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/env/Kconfig b/env/Kconfig index 0d6f559b39d3..2d972a5d4f34 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -500,6 +500,7 @@ config ENV_OFFSET default 0 if ARC default 0x140000 if ARCH_AT91 default 0x260000 if ARCH_OMAP2PLUS + default 0x1080000 if MICROBLAZE && ENV_IS_IN_SPI_FLASH help Offset from the start of the device (or partition)
@@ -529,6 +530,7 @@ config ENV_SECT_SIZE default 0x2000 if ARCH_ROCKCHIP default 0x40000 if ARCH_ZYNQMP || ARCH_VERSAL default 0x20000 if ARCH_ZYNQ || ARCH_OMAP2PLUS || ARCH_AT91 + default 0x20000 if MICROBLAZE && ENV_IS_IN_SPI_FLASH help Size of the sector containing the environment.
Ășt 18. 2. 2020 v 13:51 odesĂlatel Michal Simek michal.simek@xilinx.com napsal:
-- 2.25.0
Applied. M
Michal Simek
Michal Simek
