[U-Boot] [PATCH] ARC: Import entire libgcc from GCC 8.1.0
Some background on private libgcc on ARC first.
The whole point of having private libgcc in U-Boot is to be toolchain agnostic. I.e. have an ability to use any more or less up-to-date ARC GNU tools for building U-Boot for any platform with ARC core.
As of today we have at least 6 (sic!) flavors of GNU toolchains for ARC. 1. Little-endian multilib Elf32 2. Big-endian multilib Elf32 3. Little-endian uClibc for ARC700 (ARCompact or ARCv1 ISA) 4. Big-endian uClibc for ARC700 5. Little-endian uClibc for ARC HS (ARCv2 ISA) 6. Big-endian uClibc for ARC HS
In foreseeable future we'll have multilib Linux toolchain so we'll cut number of tools down to 4. Anyways...
In general we don't need Linux toolchain for building U-Boot and since Elf32 GNU tools have libs for most of "standard" ARC core templates [1] it might be a good toolchain for U-Boot. But: 1. Still big-/little-endian platforms require different tools 2. Developers need to have Linux toolchain for user-space stuff because of C-library 3. People tend to build more Linux tools, like Linux kernel crootools
So it looks like multilib Linux toolchain might be a bit more convenient option, at least it addresses (2) and (3) from above, i.e. we'll only need to deal with big-/little-endian story and that should be fine as not that many developers in the world play simultaneously with platforms of both types.
But no! Linux multilib toolchain will only be built for very limited list of mcpu's [2]. Basically only "arc700" and "archs" (with few flavors for HS38 templates). That's because only those cores are capable of running Linux and uClibc/glibc couldn't be built for others. I.e. all the simpler cores where U-Boot could be perfectly used [and in fact is used more and more] won't have libgcc pre-built as the part of the toolchain.
And really ultimate solution is to build libgcc as a part of U-Boot and have no external dependencies. That's something that we used to do for quite some time [3] with limited amount of functions really required by existing platforms. But with addition of more platforms like those with missing multiplier (MPY and friends) we need to have more libgcc functions and to make things simple and at the same time very optimal we're importing entire libgcc for ARC from latest stable GCC (8.1.0 as of today).
[1] https://github.com/gcc-mirror/gcc/blob/master/gcc/config/arc/t-multilib#L24 [2] https://github.com/gcc-mirror/gcc/blob/master/gcc/config/arc/t-multilib-linu... [3] http://git.denx.de/?p=u-boot.git;a=commit;h=a67ef280f46803e319639f5380ff8da6...
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com ---
Since that's an import from GCC I intentionally didn't do any changes to imported files. And that means checkpatch.pl is pretty unhappy. In particular because: 1. SPDX license header is missing 2. Some identation made with spaces 3. Spaces are missing in code or there're more than needed 4. A couple of "#if 0" etc etc.
And that poses a question: what is mandatory to be fixed and what not?
1. I guess SPDX license header MUST be inserted, right? 2. All the rest I'd really like to keep as it is now to simplify subsequent updates of newer libgcc versions.
Any thoughts?
arch/arc/lib/Makefile | 14 +- arch/arc/lib/_millicodethunk.S | 225 --- arch/arc/lib/asm.h | 29 + arch/arc/lib/dp-hack.h | 103 ++ arch/arc/lib/fp-hack.h | 87 ++ arch/arc/lib/ieee-754/adddf3.S | 524 +++++++ arch/arc/lib/ieee-754/addsf3.S | 344 +++++ arch/arc/lib/ieee-754/arc-ieee-754.h | 63 + arch/arc/lib/ieee-754/arc600-dsp/divdf3.S | 421 ++++++ arch/arc/lib/ieee-754/arc600-dsp/divsf3.S | 274 ++++ arch/arc/lib/ieee-754/arc600-dsp/muldf3.S | 231 +++ arch/arc/lib/ieee-754/arc600-dsp/mulsf3.S | 176 +++ arch/arc/lib/ieee-754/arc600-mul64/divdf3.S | 410 ++++++ arch/arc/lib/ieee-754/arc600-mul64/divsf3.S | 274 ++++ arch/arc/lib/ieee-754/arc600-mul64/muldf3.S | 234 +++ arch/arc/lib/ieee-754/arc600-mul64/mulsf3.S | 180 +++ arch/arc/lib/ieee-754/arc600/divsf3.S | 227 +++ arch/arc/lib/ieee-754/arc600/mulsf3.S | 179 +++ arch/arc/lib/ieee-754/divdf3.S | 435 ++++++ arch/arc/lib/ieee-754/divsf3-stdmul.S | 281 ++++ arch/arc/lib/ieee-754/divsf3.S | 221 +++ arch/arc/lib/ieee-754/divtab-arc-df.c | 161 +++ arch/arc/lib/ieee-754/divtab-arc-sf.c | 127 ++ arch/arc/lib/ieee-754/eqdf2.S | 81 ++ arch/arc/lib/ieee-754/eqsf2.S | 69 + arch/arc/lib/ieee-754/extendsfdf2.S | 122 ++ arch/arc/lib/ieee-754/fixdfsi.S | 85 ++ arch/arc/lib/ieee-754/fixsfsi.S | 71 + arch/arc/lib/ieee-754/fixunsdfsi.S | 80 ++ arch/arc/lib/ieee-754/floatsidf.S | 77 + arch/arc/lib/ieee-754/floatsisf.S | 99 ++ arch/arc/lib/ieee-754/floatunsidf.S | 75 + arch/arc/lib/ieee-754/gedf2.S | 86 ++ arch/arc/lib/ieee-754/gesf2.S | 75 + arch/arc/lib/ieee-754/gtdf2.S | 86 ++ arch/arc/lib/ieee-754/gtsf2.S | 75 + arch/arc/lib/ieee-754/muldf3.S | 235 +++ arch/arc/lib/ieee-754/mulsf3.S | 180 +++ arch/arc/lib/ieee-754/orddf2.S | 63 + arch/arc/lib/ieee-754/ordsf2.S | 63 + arch/arc/lib/ieee-754/truncdfsf2.S | 134 ++ arch/arc/lib/ieee-754/uneqdf2.S | 73 + arch/arc/lib/ieee-754/uneqsf2.S | 69 + arch/arc/lib/lib1funcs.S | 1430 +++++++++++++++++++ arch/arc/lib/libgcc2.c | 84 -- 45 files changed, 8321 insertions(+), 311 deletions(-) delete mode 100644 arch/arc/lib/_millicodethunk.S create mode 100644 arch/arc/lib/asm.h create mode 100644 arch/arc/lib/dp-hack.h create mode 100644 arch/arc/lib/fp-hack.h create mode 100644 arch/arc/lib/ieee-754/adddf3.S create mode 100644 arch/arc/lib/ieee-754/addsf3.S create mode 100644 arch/arc/lib/ieee-754/arc-ieee-754.h create mode 100644 arch/arc/lib/ieee-754/arc600-dsp/divdf3.S create mode 100644 arch/arc/lib/ieee-754/arc600-dsp/divsf3.S create mode 100644 arch/arc/lib/ieee-754/arc600-dsp/muldf3.S create mode 100644 arch/arc/lib/ieee-754/arc600-dsp/mulsf3.S create mode 100644 arch/arc/lib/ieee-754/arc600-mul64/divdf3.S create mode 100644 arch/arc/lib/ieee-754/arc600-mul64/divsf3.S create mode 100644 arch/arc/lib/ieee-754/arc600-mul64/muldf3.S create mode 100644 arch/arc/lib/ieee-754/arc600-mul64/mulsf3.S create mode 100644 arch/arc/lib/ieee-754/arc600/divsf3.S create mode 100644 arch/arc/lib/ieee-754/arc600/mulsf3.S create mode 100644 arch/arc/lib/ieee-754/divdf3.S create mode 100644 arch/arc/lib/ieee-754/divsf3-stdmul.S create mode 100644 arch/arc/lib/ieee-754/divsf3.S create mode 100644 arch/arc/lib/ieee-754/divtab-arc-df.c create mode 100644 arch/arc/lib/ieee-754/divtab-arc-sf.c create mode 100644 arch/arc/lib/ieee-754/eqdf2.S create mode 100644 arch/arc/lib/ieee-754/eqsf2.S create mode 100644 arch/arc/lib/ieee-754/extendsfdf2.S create mode 100644 arch/arc/lib/ieee-754/fixdfsi.S create mode 100644 arch/arc/lib/ieee-754/fixsfsi.S create mode 100644 arch/arc/lib/ieee-754/fixunsdfsi.S create mode 100644 arch/arc/lib/ieee-754/floatsidf.S create mode 100644 arch/arc/lib/ieee-754/floatsisf.S create mode 100644 arch/arc/lib/ieee-754/floatunsidf.S create mode 100644 arch/arc/lib/ieee-754/gedf2.S create mode 100644 arch/arc/lib/ieee-754/gesf2.S create mode 100644 arch/arc/lib/ieee-754/gtdf2.S create mode 100644 arch/arc/lib/ieee-754/gtsf2.S create mode 100644 arch/arc/lib/ieee-754/muldf3.S create mode 100644 arch/arc/lib/ieee-754/mulsf3.S create mode 100644 arch/arc/lib/ieee-754/orddf2.S create mode 100644 arch/arc/lib/ieee-754/ordsf2.S create mode 100644 arch/arc/lib/ieee-754/truncdfsf2.S create mode 100644 arch/arc/lib/ieee-754/uneqdf2.S create mode 100644 arch/arc/lib/ieee-754/uneqsf2.S create mode 100644 arch/arc/lib/lib1funcs.S
diff --git a/arch/arc/lib/Makefile b/arch/arc/lib/Makefile index 0eb44bcf33d0..7fd194d528f5 100644 --- a/arch/arc/lib/Makefile +++ b/arch/arc/lib/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+ # -# Copyright (C) 2013-2014 Synopsys, Inc. All rights reserved. +# Copyright (C) 2013-2014, 2018 Synopsys, Inc. All rights reserved.
extra-y = start.o head-y := start.o @@ -14,4 +14,14 @@ obj-y += init_helpers.o
obj-$(CONFIG_CMD_BOOTM) += bootm.o
-lib-$(CONFIG_USE_PRIVATE_LIBGCC) += _millicodethunk.o libgcc2.o +LIB1ASMFUNCS = _mulsi3 _umulsidi3 _umulsi3_highpart \ + _udivsi3 _divsi3 _umodsi3 _modsi3 \ + _divmod_tools _clzsi2 \ + _millicodethunk_st _millicodethunk_ld _millicodethunk_ret \ + _adddf3 _muldf3 _addsf3 _mulsf3 _divsf3 _divdf3 _truncdfsf2 _extendsfdf2 \ + _eqdf2 _eqsf2 _gedf2 _gesf2 _gtdf2 _gtsf2 _uneqdf2 _uneqsf2 _ordsf2 _orddf2 \ + _fixdfsi _fixsfsi _floatsidf _floatsisf _fixunsdfsi _floatunsidf + +AFLAGS_lib1funcs.o += $(addprefix -DL, $(LIB1ASMFUNCS)) + +lib-$(CONFIG_USE_PRIVATE_LIBGCC) += lib1funcs.o libgcc2.o diff --git a/arch/arc/lib/_millicodethunk.S b/arch/arc/lib/_millicodethunk.S deleted file mode 100644 index 4ad16ae3b688..000000000000 --- a/arch/arc/lib/_millicodethunk.S +++ /dev/null @@ -1,225 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 1995, 1997, 2007-2013 Free Software Foundation, Inc. - */ - - /* ANSI concatenation macros. */ - - #define CONCAT1(a, b) CONCAT2(a, b) - #define CONCAT2(a, b) a ## b - - /* Use the right prefix for global labels. */ - - #define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x) - -#ifndef WORKING_ASSEMBLER -#define abs_l abs -#define asl_l asl -#define mov_l mov -#endif - -#define FUNC(X) .type SYM(X),@function -#define HIDDEN_FUNC(X) FUNC(X)` .hidden X -#define ENDFUNC0(X) .Lfe_##X: .size X,.Lfe_##X-X -#define ENDFUNC(X) ENDFUNC0(X) - - .section .text - .align 4 - .global SYM(__st_r13_to_r15) - .global SYM(__st_r13_to_r16) - .global SYM(__st_r13_to_r17) - .global SYM(__st_r13_to_r18) - .global SYM(__st_r13_to_r19) - .global SYM(__st_r13_to_r20) - .global SYM(__st_r13_to_r21) - .global SYM(__st_r13_to_r22) - .global SYM(__st_r13_to_r23) - .global SYM(__st_r13_to_r24) - .global SYM(__st_r13_to_r25) - HIDDEN_FUNC(__st_r13_to_r15) - HIDDEN_FUNC(__st_r13_to_r16) - HIDDEN_FUNC(__st_r13_to_r17) - HIDDEN_FUNC(__st_r13_to_r18) - HIDDEN_FUNC(__st_r13_to_r19) - HIDDEN_FUNC(__st_r13_to_r20) - HIDDEN_FUNC(__st_r13_to_r21) - HIDDEN_FUNC(__st_r13_to_r22) - HIDDEN_FUNC(__st_r13_to_r23) - HIDDEN_FUNC(__st_r13_to_r24) - HIDDEN_FUNC(__st_r13_to_r25) - .align 4 -SYM(__st_r13_to_r25): - st r25, [sp,48] -SYM(__st_r13_to_r24): - st r24, [sp,44] -SYM(__st_r13_to_r23): - st r23, [sp,40] -SYM(__st_r13_to_r22): - st r22, [sp,36] -SYM(__st_r13_to_r21): - st r21, [sp,32] -SYM(__st_r13_to_r20): - st r20, [sp,28] -SYM(__st_r13_to_r19): - st r19, [sp,24] -SYM(__st_r13_to_r18): - st r18, [sp,20] -SYM(__st_r13_to_r17): - st r17, [sp,16] -SYM(__st_r13_to_r16): - st r16, [sp,12] -SYM(__st_r13_to_r15): -#ifdef __ARC700__ - st r15, [sp,8] ; minimum function size to avoid stall: 6 bytes. -#else - st_s r15, [sp,8] -#endif - st_s r14, [sp,4] - j_s.d [%blink] - st_s r13, [sp,0] - ENDFUNC(__st_r13_to_r15) - ENDFUNC(__st_r13_to_r16) - ENDFUNC(__st_r13_to_r17) - ENDFUNC(__st_r13_to_r18) - ENDFUNC(__st_r13_to_r19) - ENDFUNC(__st_r13_to_r20) - ENDFUNC(__st_r13_to_r21) - ENDFUNC(__st_r13_to_r22) - ENDFUNC(__st_r13_to_r23) - ENDFUNC(__st_r13_to_r24) - ENDFUNC(__st_r13_to_r25) - - .section .text - .align 4 -; ================================== -; the loads - - .global SYM(__ld_r13_to_r15) - .global SYM(__ld_r13_to_r16) - .global SYM(__ld_r13_to_r17) - .global SYM(__ld_r13_to_r18) - .global SYM(__ld_r13_to_r19) - .global SYM(__ld_r13_to_r20) - .global SYM(__ld_r13_to_r21) - .global SYM(__ld_r13_to_r22) - .global SYM(__ld_r13_to_r23) - .global SYM(__ld_r13_to_r24) - .global SYM(__ld_r13_to_r25) - HIDDEN_FUNC(__ld_r13_to_r15) - HIDDEN_FUNC(__ld_r13_to_r16) - HIDDEN_FUNC(__ld_r13_to_r17) - HIDDEN_FUNC(__ld_r13_to_r18) - HIDDEN_FUNC(__ld_r13_to_r19) - HIDDEN_FUNC(__ld_r13_to_r20) - HIDDEN_FUNC(__ld_r13_to_r21) - HIDDEN_FUNC(__ld_r13_to_r22) - HIDDEN_FUNC(__ld_r13_to_r23) - HIDDEN_FUNC(__ld_r13_to_r24) - HIDDEN_FUNC(__ld_r13_to_r25) -SYM(__ld_r13_to_r25): - ld r25, [sp,48] -SYM(__ld_r13_to_r24): - ld r24, [sp,44] -SYM(__ld_r13_to_r23): - ld r23, [sp,40] -SYM(__ld_r13_to_r22): - ld r22, [sp,36] -SYM(__ld_r13_to_r21): - ld r21, [sp,32] -SYM(__ld_r13_to_r20): - ld r20, [sp,28] -SYM(__ld_r13_to_r19): - ld r19, [sp,24] -SYM(__ld_r13_to_r18): - ld r18, [sp,20] -SYM(__ld_r13_to_r17): - ld r17, [sp,16] -SYM(__ld_r13_to_r16): - ld r16, [sp,12] -SYM(__ld_r13_to_r15): -#ifdef __ARC700__ - ld r15, [sp,8] ; minimum function size to avoid stall: 6 bytes. -#else - ld_s r15, [sp,8] -#endif - ld_s r14, [sp,4] - j_s.d [%blink] - ld_s r13, [sp,0] - ENDFUNC(__ld_r13_to_r15) - ENDFUNC(__ld_r13_to_r16) - ENDFUNC(__ld_r13_to_r17) - ENDFUNC(__ld_r13_to_r18) - ENDFUNC(__ld_r13_to_r19) - ENDFUNC(__ld_r13_to_r20) - ENDFUNC(__ld_r13_to_r21) - ENDFUNC(__ld_r13_to_r22) - ENDFUNC(__ld_r13_to_r23) - ENDFUNC(__ld_r13_to_r24) - ENDFUNC(__ld_r13_to_r25) - - .global SYM(__ld_r13_to_r14_ret) - .global SYM(__ld_r13_to_r15_ret) - .global SYM(__ld_r13_to_r16_ret) - .global SYM(__ld_r13_to_r17_ret) - .global SYM(__ld_r13_to_r18_ret) - .global SYM(__ld_r13_to_r19_ret) - .global SYM(__ld_r13_to_r20_ret) - .global SYM(__ld_r13_to_r21_ret) - .global SYM(__ld_r13_to_r22_ret) - .global SYM(__ld_r13_to_r23_ret) - .global SYM(__ld_r13_to_r24_ret) - .global SYM(__ld_r13_to_r25_ret) - HIDDEN_FUNC(__ld_r13_to_r14_ret) - HIDDEN_FUNC(__ld_r13_to_r15_ret) - HIDDEN_FUNC(__ld_r13_to_r16_ret) - HIDDEN_FUNC(__ld_r13_to_r17_ret) - HIDDEN_FUNC(__ld_r13_to_r18_ret) - HIDDEN_FUNC(__ld_r13_to_r19_ret) - HIDDEN_FUNC(__ld_r13_to_r20_ret) - HIDDEN_FUNC(__ld_r13_to_r21_ret) - HIDDEN_FUNC(__ld_r13_to_r22_ret) - HIDDEN_FUNC(__ld_r13_to_r23_ret) - HIDDEN_FUNC(__ld_r13_to_r24_ret) - HIDDEN_FUNC(__ld_r13_to_r25_ret) - .section .text - .align 4 -SYM(__ld_r13_to_r25_ret): - ld r25, [sp,48] -SYM(__ld_r13_to_r24_ret): - ld r24, [sp,44] -SYM(__ld_r13_to_r23_ret): - ld r23, [sp,40] -SYM(__ld_r13_to_r22_ret): - ld r22, [sp,36] -SYM(__ld_r13_to_r21_ret): - ld r21, [sp,32] -SYM(__ld_r13_to_r20_ret): - ld r20, [sp,28] -SYM(__ld_r13_to_r19_ret): - ld r19, [sp,24] -SYM(__ld_r13_to_r18_ret): - ld r18, [sp,20] -SYM(__ld_r13_to_r17_ret): - ld r17, [sp,16] -SYM(__ld_r13_to_r16_ret): - ld r16, [sp,12] -SYM(__ld_r13_to_r15_ret): - ld r15, [sp,8] -SYM(__ld_r13_to_r14_ret): - ld blink,[sp,r12] - ld_s r14, [sp,4] - ld.ab r13, [sp,r12] - j_s.d [%blink] - add_s sp,sp,4 - ENDFUNC(__ld_r13_to_r14_ret) - ENDFUNC(__ld_r13_to_r15_ret) - ENDFUNC(__ld_r13_to_r16_ret) - ENDFUNC(__ld_r13_to_r17_ret) - ENDFUNC(__ld_r13_to_r18_ret) - ENDFUNC(__ld_r13_to_r19_ret) - ENDFUNC(__ld_r13_to_r20_ret) - ENDFUNC(__ld_r13_to_r21_ret) - ENDFUNC(__ld_r13_to_r22_ret) - ENDFUNC(__ld_r13_to_r23_ret) - ENDFUNC(__ld_r13_to_r24_ret) - ENDFUNC(__ld_r13_to_r25_ret) diff --git a/arch/arc/lib/asm.h b/arch/arc/lib/asm.h new file mode 100644 index 000000000000..4f22786959e1 --- /dev/null +++ b/arch/arc/lib/asm.h @@ -0,0 +1,29 @@ +/* Assembler macros for the Synopsys DesignWare ARC CPU. + + Copyright (C) 1994-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#define FUNC(X) .type X,@function +#define ENDFUNC(X) .size X, .-X diff --git a/arch/arc/lib/dp-hack.h b/arch/arc/lib/dp-hack.h new file mode 100644 index 000000000000..d1a697574ce6 --- /dev/null +++ b/arch/arc/lib/dp-hack.h @@ -0,0 +1,103 @@ +/* Copyright (C) 2007-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* This file selects the double-precision parts of fp-bit.c that are + still needed for some ARC hardware variants; it also renames functions + that duplicate asm-coded functionality so that their results can be + used to compare with the optimized versions for debugging. */ + +#define FINE_GRAINED_LIBRARIES +#define ARC_DP_DEBUG 1 +#define ARC_OPTFPE (defined (__ARC700__) || defined (__ARC_FPX_QUARK__)) + +#if !ARC_OPTFPE || ARC_DP_DEBUG +#define L_pack_df +#define L_unpack_df +#define L_make_df +#define L_thenan_df +#define L_sf_to_df +#endif +#if !ARC_OPTFPE +#define L_addsub_df +#elif ARC_DP_DEBUG +#define L_addsub_df +#define __adddf3 __adddf3_c +#define __subdf3 __subdf3_c +#endif +#if !ARC_OPTFPE +#define L_mul_df +#define L_div_df +#elif (!defined (__ARC700__) && !defined (__ARC_MUL64__) \ + && !defined (__ARC_MUL32BY16__) && !defined (__HS__)) +#define L_mul_df +#define L_div_df +#undef QUIET_NAN +#define QUIET_NAN 0xfffffffffffffLL +#elif ARC_DP_DEBUG +#define L_mul_df +#define __muldf3 __muldf3_c +#define L_div_df +#define __divdf3 __divdf3_c +#endif +#if !ARC_OPTFPE +#define L_df_to_sf +#define L_si_to_df +#define L_df_to_si +#define L_tf_to_usi /* need to defined this instead of df_to_usi */ +#define L_usi_to_df +#elif ARC_DP_DEBUG +#define L_df_to_sf +#define __truncdfsf2 __truncdfsf2_c +#define L_si_to_df +#define __floatsidf __floatsidf_c +#define L_df_to_si +#define __fixdfsi __fixdfsi_c +#define L_tf_to_usi +#define __fixunsdfsi __fixunsdfsi_c +#define L_usi_to_df +#define __floatunsidf __floatunsidf_c +#endif +#if !ARC_OPTFPE +#define L_fpcmp_parts_df +#define L_compare_df +#define L_eq_df +#define L_ne_df +#define L_gt_df +#define L_ge_df +#define L_lt_df +#define L_le_df +#define L_unord_df +#define L_negate_df +#elif ARC_DP_DEBUG +#define L_fpcmp_parts_df +#define L_eq_df +#define __eqdf2 __eqdf2_c +#define L_gt_df +#define __gtdf2 __gtdf2_c +#define L_ge_df +#define __gedf2 __gedf2_c +#define L_unord_df +#define __unorddf2 __unorddf2_c +#endif diff --git a/arch/arc/lib/fp-hack.h b/arch/arc/lib/fp-hack.h new file mode 100644 index 000000000000..8b3ee322aea5 --- /dev/null +++ b/arch/arc/lib/fp-hack.h @@ -0,0 +1,87 @@ +/* Copyright (C) 2007-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* This file selects the single-precision parts of fp-bit.c that are + still needed for some ARC hardware variants; it also renames functions + that duplicate asm-coded functionality so that their results can be + used to compare with the optimized versions for debugging. */ + +#define ARC_FP_DEBUG 1 +#define FINE_GRAINED_LIBRARIES +#define ARC_OPTFPE (defined (__ARC700__) || defined (__ARC_FPX_QUARK__)) + +#if !ARC_OPTFPE || ARC_FP_DEBUG +#define L_pack_sf +#define L_unpack_sf +#define L_make_sf +#define L_thenan_sf +#endif +#if !ARC_OPTFPE +#define L_addsub_sf +#define L_mul_sf +#define L_div_sf +#define L_sf_to_df +#define L_si_to_sf +#define L_sf_to_si +#define L_usi_to_sf +#elif ARC_FP_DEBUG +#define L_addsub_sf +#define __addsf3 __addsf3_c +#define __subsf3 __subsf3_c +#define L_mul_sf +#define __mulsf3 __mulsf3_c +#define L_div_sf +#define __divsf3 __divsf3_c +#define L_sf_to_df +#define __extendsfdf2 __extendsfdf2_c +#define L_si_to_sf +#define __floatsisf __floatsisf_c +#define L_sf_to_si +#define __fixsfsi __fixsfsi_c +#define L_usi_to_sf +#define __floatunsisf __floatunsisf_c +#endif +#if !ARC_OPTFPE +#define L_fpcmp_parts_sf +#define L_compare_sf +#define L_eq_sf +#define L_ne_sf +#define L_gt_sf +#define L_ge_sf +#define L_lt_sf +#define L_le_sf +#define L_unord_sf +#define L_negate_sf +#elif ARC_FP_DEBUG +#define L_fpcmp_parts_sf +#define L_eq_sf +#define __eqsf2 __eqsf2_c +#define L_gt_sf +#define __gtsf2 __gtsf2_c +#define L_ge_sf +#define __gesf2 __gesf2_c +#define L_unord_sf +#define __unordsf2 __unordsf2_c +#endif diff --git a/arch/arc/lib/ieee-754/adddf3.S b/arch/arc/lib/ieee-754/adddf3.S new file mode 100644 index 000000000000..54b99d4251a7 --- /dev/null +++ b/arch/arc/lib/ieee-754/adddf3.S @@ -0,0 +1,524 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +#if 0 /* DEBUG */ + .global __adddf3 + .balign 4 +__adddf3: + push_s blink + push_s r2 + push_s r3 + push_s r0 + bl.d __adddf3_c + push_s r1 + ld_s r2,[sp,12] + ld_s r3,[sp,8] + st_s r0,[sp,12] + st_s r1,[sp,8] + pop_s r1 + bl.d __adddf3_asm + pop_s r0 + pop_s r3 + pop_s r2 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + bl abort + .global __subdf3 + .balign 4 +__subdf3: + push_s blink + push_s r2 + push_s r3 + push_s r0 + bl.d __subdf3_c + push_s r1 + ld_s r2,[sp,12] + ld_s r3,[sp,8] + st_s r0,[sp,12] + st_s r1,[sp,8] + pop_s r1 + bl.d __subdf3_asm + pop_s r0 + pop_s r3 + pop_s r2 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + bl abort +#define __adddf3 __adddf3_asm +#define __subdf3 __subdf3_asm +#endif /* DEBUG */ +/* N.B. This is optimized for ARC700. + ARC600 has very different scheduling / instruction selection criteria. */ + +/* inputs: DBL0, DBL1 (r0-r3) + output: DBL0 (r0, r1) + clobber: r2-r10, r12, flags + All NaN highword bits must be 1. NaN low word is random. */ + + .balign 4 + .global __adddf3 + .global __subdf3 + .long 0x7ff00000 ; exponent mask + FUNC(__adddf3) + FUNC(__subdf3) +__subdf3: + bxor_l DBL1H,DBL1H,31 +__adddf3: + ld r9,[pcl,-8] + bmsk r4,DBL0H,30 + xor r10,DBL0H,DBL1H + and r6,DBL1H,r9 + sub.f r12,r4,r6 + asr_s r12,r12,20 + blo .Ldbl1_gt + brhs r4,r9,.Linf_nan + brhs r12,32,.Large_shift + brne r12,0,.Lsmall_shift + brge r10,0,.Ladd_same_exp ; r12 == 0 + +/* After subtracting, we need to normalize; when shifting to place the + leading 1 into position for the implicit 1 and adding that to DBL0H, + we increment the exponent. Thus, we have to subtract one more than + the shift count from the exponent beforehand. Iff the exponent drops thus + below zero (before adding in the fraction with the leading one), we have + generated a denormal number. Denormal handling is basicallly reducing the + shift count so that we produce a zero exponent instead; however, this way + the shift count can become zero (if we started out with exponent 1). + Therefore, a simple min operation is not good enough, since we don't + want to handle a zero normalizing shift in the main path. + On the plus side, we don't need to check for denorm input, the result + of subtracing these looks just the same as denormals generated during + subtraction. */ + bmsk r7,DBL1H,30 + cmp r4,r7 + cmp.eq DBL0L,DBL1L + blo .L_rsub_same_exp + sub.f DBL0L,DBL0L,DBL1L + bmsk r12,DBL0H,19 + bic DBL1H,DBL0H,r12 + sbc.f r4,r4,r7 + beq_l .Large_cancel + norm DBL1L,r4 + b.d .Lsub_done_same_exp + sub r12,DBL1L,9 + + .balign 4 +.Linf_nan: + ; If both inputs are inf, but with different signs, the result is NaN. + asr r12,r10,31 + or_s DBL1H,DBL1H,r12 + j_s.d [blink] + or.eq DBL0H,DBL0H,DBL1H + + .balign 4 +.L_rsub_same_exp: + rsub.f DBL0L,DBL0L,DBL1L + bmsk r12,DBL1H,19 + bic_s DBL1H,DBL1H,r12 + sbc.f r4,r7,r4 + beq_l .Large_cancel + norm DBL1L,r4 + + sub r12,DBL1L,9 +.Lsub_done_same_exp: + asl_s r12,r12,20 + sub_s DBL1L,DBL1L,10 + sub DBL0H,DBL1H,r12 + xor.f 0,DBL0H,DBL1H + bmi .Ldenorm +.Lpast_denorm: + neg_s r12,DBL1L + lsr r7,DBL0L,r12 + asl r12,r4,DBL1L + asl_s DBL0L,DBL0L,DBL1L + add_s r12,r12,r7 + j_s.d [blink] + add_l DBL0H,DBL0H,r12 + .balign 4 +.Ladd_same_exp: + /* This is a special case because we can't test for need to shift + down by checking if bit 20 of DBL0H changes. OTOH, here we know + that we always need to shift down. */ + ; The implicit 1 of DBL0 is not shifted together with the + ; fraction, thus effectively doubled, compensating for not setting + ; implicit1 for DBL1 + add_s r12,DBL0L,DBL1L + lsr.f 0,r12,2 ; round to even + breq r6,0,.Ldenorm_add + adc.f DBL0L,DBL0L,DBL1L + sub r7,DBL1H,DBL0H + sub1 r7,r7,r9 ; boost exponent by 2/2 + rrc DBL0L,DBL0L + asr.f r7,r7 ; DBL1.fraction/2 - DBL0.fraction/2 ; exp++ + add.cs.f DBL0L,DBL0L,0x80000000 + add_l DBL0H,DBL0H,r7 ; DBL0.implicit1 not shifted for DBL1.implicit1 + add.cs DBL0H,DBL0H,1 + bic.f 0,r9,DBL0H ; check for overflow -> infinity. + jne_l [blink] + and DBL0H,DBL0H,0xfff00000 + j_s.d [blink] + mov_s DBL0L,0 + .balign 4 +.Large_shift: + brhs r12,55,.Lret_dbl0 + bmsk_s DBL1H,DBL1H,19 + brne r6,0,.Lno_denorm_large_shift + brhi.d r12,33,.Lfixed_denorm_large_shift + sub_s r12,r12,1 + breq r12,31, .Lfixed_denorm_small_shift +.Lshift32: + mov_s r12,DBL1L + mov_s DBL1L,DBL1H + brlt.d r10,0,.Lsub + mov_s DBL1H,0 + b_s .Ladd +.Ldenorm_add: + cmp_s r12,DBL1L + mov_s DBL0L,r12 + j_s.d [blink] + adc DBL0H,r4,DBL1H + +.Lret_dbl0: + j_s [blink] + .balign 4 +.Lsmall_shift: + breq.d r6,0,.Ldenorm_small_shift + bmsk_s DBL1H,DBL1H,19 + bset_s DBL1H,DBL1H,20 +.Lfixed_denorm_small_shift: + neg r8,r12 + asl r4,DBL1H,r8 + lsr_l DBL1H,DBL1H,r12 + lsr r5,DBL1L,r12 + asl r12,DBL1L,r8 + brge.d r10,0,.Ladd + or DBL1L,r4,r5 +/* subtract, abs(DBL0) > abs(DBL1) */ +/* DBL0H, DBL0L: original values + DBL1H, DBL1L: fraction with explicit leading 1, shifted into place + r4: orig. DBL0H & 0x7fffffff + r6: orig. DBL1H & 0x7ff00000 + r9: 0x7ff00000 + r10: orig. DBL0H ^ DBL1H + r12: guard bits */ + .balign 4 +.Lsub: + neg.f r12,r12 + mov_s r7,DBL1H + bmsk r5,DBL0H,19 + sbc.f DBL0L,DBL0L,DBL1L + bic DBL1H,DBL0H,r5 + bset r5,r5,20 + sbc.f r4,r5,r7 + beq_l .Large_cancel_sub + norm DBL1L,r4 + bmsk r6,DBL1H,30 +.Lsub_done: + sub_s DBL1L,DBL1L,9 + breq DBL1L,1,.Lsub_done_noshift + asl r5,DBL1L,20 + sub_s DBL1L,DBL1L,1 + brlo r6,r5,.Ldenorm_sub + sub DBL0H,DBL1H,r5 +.Lpast_denorm_sub: + neg_s DBL1H,DBL1L + lsr r6,r12,DBL1H + asl_s r12,r12,DBL1L + and r8,r6,1 + add1.f 0,r8,r12 + add.ne.f r12,r12,r12 + asl r8,DBL0L,DBL1L + lsr r12,DBL0L,DBL1H + adc.f DBL0L,r8,r6 + asl r5,r4,DBL1L + add_s DBL0H,DBL0H,r12 + j_s.d [blink] + adc DBL0H,DBL0H,r5 + + .balign 4 +.Lno_denorm_large_shift: + breq.d r12,32,.Lshift32 + bset_l DBL1H,DBL1H,20 +.Lfixed_denorm_large_shift: + neg r8,r12 + asl r4,DBL1H,r8 + lsr r5,DBL1L,r12 + asl.f 0,DBL1L,r8 + lsr DBL1L,DBL1H,r12 + or r12,r4,r5 + tst.eq r12,1 + or.ne r12,r12,2 + brlt.d r10,0,.Lsub + mov_s DBL1H,0 + b_l .Ladd + + ; If a denorm is produced without shifting, we have an exact result - + ; no need for rounding. + .balign 4 +.Ldenorm_sub: + lsr DBL1L,r6,20 + xor DBL0H,r6,DBL1H + brne.d DBL1L,1,.Lpast_denorm_sub + sub_s DBL1L,DBL1L,1 +.Lsub_done_noshift: + add.f 0,r12,r12 + btst.eq DBL0L,0 + cmp.eq r12,r12 + add.cs.f DBL0L,DBL0L,1 + bclr r4,r4,20 + j_s.d [blink] + adc DBL0H,DBL1H,r4 + + .balign 4 +.Ldenorm_small_shift: + brne.d r12,1,.Lfixed_denorm_small_shift + sub_l r12,r12,1 + brlt r10,0,.Lsub +.Ladd: ; bit 20 of DBL1H is clear and bit 0 of r12 does not matter + add.f DBL0L,DBL0L,DBL1L + add_s DBL1H,DBL1H,DBL0H + add.cs DBL1H,DBL1H,1 + xor_l DBL0H,DBL0H,DBL1H + bbit0 DBL0H,20,.Lno_shiftdown + lsr.f DBL0H,DBL1H + and r4,DBL0L,2 + bmsk DBL0H,DBL0H,18 + sbc DBL0H,DBL1H,DBL0H + rrc.f DBL0L,DBL0L + or.f r12,r12,r4 + cmp.eq r12,r12 + add.cs.f DBL0L,DBL0L,1 + bic.f 0,r9,DBL0H ; check for generating infinity with possible ... + jne.d [blink] ; ... non-zero fraction + add.cs DBL0H,DBL0H,1 + mov_s DBL0L,0 + bmsk DBL1H,DBL0H,19 + j_s.d [blink] + bic_s DBL0H,DBL0H,DBL1H +.Lno_shiftdown: + mov_s DBL0H,DBL1H + add.f 0,r12,r12 + btst.eq DBL0L,0 + cmp.eq r12,r12 + add.cs.f DBL0L,DBL0L,1 + j_s.d [blink] + add.cs DBL0H,DBL0H,1 + .balign 4 +.Ldenorm: + bmsk DBL0H,DBL1H,30 + lsr r12,DBL0H,20 + xor_s DBL0H,DBL0H,DBL1H + sub_l DBL1L,r12,1 + bgt .Lpast_denorm + j_s.d [blink] + add_l DBL0H,DBL0H,r4 + + .balign 4 +.Large_cancel: + ;DBL0L: mantissa DBL1H: sign & exponent + norm.f DBL1L,DBL0L + bmsk DBL0H,DBL1H,30 + add_s DBL1L,DBL1L,22 + mov.mi DBL1L,21 + add_s r12,DBL1L,1 + asl_s r12,r12,20 + beq_s .Lret0 + brhs.d DBL0H,r12,.Lpast_denorm_large_cancel + sub DBL0H,DBL1H,r12 + bmsk DBL0H,DBL1H,30 + lsr r12,DBL0H,20 + xor_s DBL0H,DBL0H,DBL1H + sub.f DBL1L,r12,1 + jle [blink] +.Lpast_denorm_large_cancel: + rsub.f r7,DBL1L,32 + lsr r7,DBL0L,r7 + asl_s DBL0L,DBL0L,DBL1L + mov.ls r7,DBL0L + add_s DBL0H,DBL0H,r7 + j_s.d [blink] + mov.ls DBL0L,0 +.Lret0: + j_s.d [blink] + mov_l DBL0H,0 + +/* r4:DBL0L:r12 : unnormalized result fraction + DBL1H: result sign and exponent */ +/* When seeing large cancellation, only the topmost guard bit might be set. */ + .balign 4 +.Large_cancel_sub: + norm.f DBL1L,DBL0L + bpnz.d 0f + bmsk DBL0H,DBL1H,30 + mov r5,22<<20 + bne.d 1f + mov_s DBL1L,21 + bset r5,r5,5+20 + add_s DBL1L,DBL1L,32 + brne r12,0,1f + j_s.d [blink] + mov_l DBL0H,0 + .balign 4 +0: add r5,DBL1L,23 + asl r5,r5,20 + add_s DBL1L,DBL1L,22 +1: brlo DBL0H,r5,.Ldenorm_large_cancel_sub + sub DBL0H,DBL1H,r5 +.Lpast_denorm_large_cancel_sub: + rsub.f r7,DBL1L,32 + lsr r12,r12,r7 + lsr r7,DBL0L,r7 + asl_s DBL0L,DBL0L,DBL1L + add.ge DBL0H,DBL0H,r7 + add_s DBL0L,DBL0L,r12 + add.lt DBL0H,DBL0H,DBL0L + mov.eq DBL0L,r12 + j_s.d [blink] + mov.lt DBL0L,0 + .balign 4 +.Ldenorm_large_cancel_sub: + lsr r5,DBL0H,20 + xor_s DBL0H,DBL0H,DBL1H + brgt.d r5,1,.Lpast_denorm_large_cancel_sub + sub DBL1L,r5,1 + j_l [blink] ; denorm, no shift -> no rounding needed. + +/* r4: DBL0H & 0x7fffffff + r6: DBL1H & 0x7ff00000 + r9: 0x7ff00000 + r10: sign difference + r12: shift count (negative) */ + .balign 4 +.Ldbl1_gt: + brhs r6,r9,.Lret_dbl1 ; inf or NaN + neg r8,r12 + brhs r8,32,.Large_shift_dbl0 +.Lsmall_shift_dbl0: + breq.d r6,0,.Ldenorm_small_shift_dbl0 + bmsk_s DBL0H,DBL0H,19 + bset_s DBL0H,DBL0H,20 +.Lfixed_denorm_small_shift_dbl0: + asl r4,DBL0H,r12 + lsr DBL0H,DBL0H,r8 + lsr r5,DBL0L,r8 + asl r12,DBL0L,r12 + brge.d r10,0,.Ladd_dbl1_gt + or DBL0L,r4,r5 +/* subtract, abs(DBL0) < abs(DBL1) */ +/* DBL0H, DBL0L: fraction with explicit leading 1, shifted into place + DBL1H, DBL1L: original values + r6: orig. DBL1H & 0x7ff00000 + r9: 0x7ff00000 + r12: guard bits */ + .balign 4 +.Lrsub: + neg.f r12,r12 + bmsk r7,DBL1H,19 + mov_s r5,DBL0H + sbc.f DBL0L,DBL1L,DBL0L + bic DBL1H,DBL1H,r7 + bset r7,r7,20 + sbc.f r4,r7,r5 + beq_l .Large_cancel_sub + norm DBL1L,r4 + b_l .Lsub_done ; note: r6 is already set up. + +.Lret_dbl1: + mov_s DBL0H,DBL1H + j_s.d [blink] + mov_l DBL0L,DBL1L + .balign 4 +.Ldenorm_small_shift_dbl0: + sub.f r8,r8,1 + bne.d .Lfixed_denorm_small_shift_dbl0 + add_s r12,r12,1 + brlt r10,0,.Lrsub +.Ladd_dbl1_gt: ; bit 20 of DBL0H is clear and bit 0 of r12 does not matter + add.f DBL0L,DBL0L,DBL1L + add_s DBL0H,DBL0H,DBL1H + add.cs DBL0H,DBL0H,1 + xor DBL1H,DBL0H,DBL1H + bbit0 DBL1H,20,.Lno_shiftdown_dbl1_gt + lsr.f DBL1H,DBL0H + and r4,DBL0L,2 + bmsk DBL1H,DBL1H,18 + sbc DBL0H,DBL0H,DBL1H + rrc.f DBL0L,DBL0L + or.f r12,r12,r4 + cmp.eq r12,r12 + add.cs.f DBL0L,DBL0L,1 + bic.f 0,r9,DBL0H ; check for generating infinity with possible ... + jne.d [blink] ; ... non-zero fraction + add.cs DBL0H,DBL0H,1 + mov_s DBL0L,0 + bmsk DBL1H,DBL0H,19 + j_s.d [blink] + bic_s DBL0H,DBL0H,DBL1H +.Lno_shiftdown_dbl1_gt: + add.f 0,r12,r12 + btst.eq DBL0L,0 + cmp.eq r12,r12 + add.cs.f DBL0L,DBL0L,1 + j_s.d [blink] + add.cs DBL0H,DBL0H,1 + + .balign 4 +.Large_shift_dbl0: + brhs r8,55,.Lret_dbl1 + bmsk_s DBL0H,DBL0H,19 + brne r6,0,.Lno_denorm_large_shift_dbl0 + add_s r12,r12,1 + brne.d r8,33,.Lfixed_denorm_large_shift_dbl0 + sub r8,r8,1 + bset_s DBL0H,DBL0H,20 +.Lshift32_dbl0: + mov_s r12,DBL0L + mov_s DBL0L,DBL0H + brlt.d r10,0,.Lrsub + mov_s DBL0H,0 + b_s .Ladd_dbl1_gt + + .balign 4 +.Lno_denorm_large_shift_dbl0: + breq.d r8,32,.Lshift32_dbl0 + bset_l DBL0H,DBL0H,20 +.Lfixed_denorm_large_shift_dbl0: + asl r4,DBL0H,r12 + lsr r5,DBL0L,r8 + asl.f 0,DBL0L,r12 + lsr DBL0L,DBL0H,r8 + or r12,r4,r5 + tst.eq r12,1 + or.ne r12,r12,2 + brlt.d r10,0,.Lrsub + mov_s DBL0H,0 + b_l .Ladd_dbl1_gt + ENDFUNC(__adddf3) + ENDFUNC(__subdf3) diff --git a/arch/arc/lib/ieee-754/addsf3.S b/arch/arc/lib/ieee-754/addsf3.S new file mode 100644 index 000000000000..b33a95f4b524 --- /dev/null +++ b/arch/arc/lib/ieee-754/addsf3.S @@ -0,0 +1,344 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +#if 0 /* DEBUG */ + .global __addsf3 + FUNC(__addsf3) + .balign 4 +__addsf3: + push_s blink + push_s r1 + bl.d __addsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __addsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + bl abort + ENDFUNC(__addsf3) + .global __subsf3 + FUNC(__subsf3) + .balign 4 +__subsf3: + push_s blink + push_s r1 + bl.d __subsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __subsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + bl abort + ENDFUNC(__subsf3) +#define __addsf3 __addsf3_asm +#define __subsf3 __subsf3_asm +#endif /* DEBUG */ +/* N.B. This is optimized for ARC700. + ARC600 has very different scheduling / instruction selection criteria. */ + +/* inputs: r0, r1 + output: r0 + clobber: r1-r10, r12, flags */ + + .balign 4 + .global __addsf3 + .global __subsf3 + FUNC(__addsf3) + FUNC(__subsf3) + .long 0x7f800000 ; exponent mask +__subsf3: + bxor_l r1,r1,31 +__addsf3: + ld r9,[pcl,-8] + bmsk r4,r0,30 + xor r10,r0,r1 + and r6,r1,r9 + sub.f r12,r4,r6 + asr_s r12,r12,23 + blo .Ldbl1_gt + brhs r4,r9,.Linf_nan + brne r12,0,.Lsmall_shift + brge r10,0,.Ladd_same_exp ; r12 == 0 +/* After subtracting, we need to normalize; when shifting to place the + leading 1 into position for the implicit 1 and adding that to DBL0, + we increment the exponent. Thus, we have to subtract one more than + the shift count from the exponent beforehand. Iff the exponent drops thus + below zero (before adding in the fraction with the leading one), we have + generated a denormal number. Denormal handling is basicallly reducing the + shift count so that we produce a zero exponent instead; FWIW, this way + the shift count can become zero (if we started out with exponent 1). + On the plus side, we don't need to check for denorm input, the result + of subtracing these looks just the same as denormals generated during + subtraction. */ + bmsk r7,r1,30 + breq r4,r7,.Lret0 + sub.f r5,r4,r7 + lsr r12,r4,23 + neg.cs r5,r5 + norm r3,r5 + bmsk r2,r0,22 + sub_s r3,r3,6 + min r12,r12,r3 + bic r1,r0,r2 + sub_s r3,r12,1 + asl_s r12,r12,23 + asl r2,r5,r3 + sub_s r1,r1,r12 + add_s r0,r1,r2 + j_s.d [blink] + bxor.cs r0,r0,31 + .balign 4 +.Linf_nan: + ; If both inputs are inf, but with different signs, the result is NaN. + asr r12,r10,31 + or_s r1,r1,r12 + j_s.d [blink] + or.eq r0,r0,r1 + .balign 4 +.Ladd_same_exp: + /* This is a special case because we can't test for need to shift + down by checking if bit 23 of DBL0 changes. OTOH, here we know + that we always need to shift down. */ + ; adding the two floating point numbers together makes the sign + ; cancel out and apear as carry; the exponent is doubled, and the + ; fraction also in need of shifting left by one. The two implicit + ; ones of the sources make an implicit 1 of the result, again + ; non-existent in a place shifted by one. + add.f r0,r0,r1 + btst_s r0,1 + breq r6,0,.Ldenorm_add + add.ne r0,r0,1 ; round to even. + rrc r0,r0 + bmsk r1,r9,23 + add r0,r0,r1 ; increment exponent + bic.f 0,r9,r0; check for overflow -> infinity. + jne_l [blink] + mov_s r0,r9 + j_s.d [blink] + bset.cs r0,r0,31 + +.Ldenorm_add: + j_s.d [blink] + add r0,r4,r1 + +.Lret_dbl0: + j_s [blink] + + .balign 4 +.Lsmall_shift: + brhi r12,25,.Lret_dbl0 + breq.d r6,0,.Ldenorm_small_shift + bmsk_s r1,r1,22 + bset_s r1,r1,23 +.Lfixed_denorm_small_shift: + neg r8,r12 + asl r5,r1,r8 + brge.d r10,0,.Ladd + lsr_l r1,r1,r12 +/* subtract, abs(DBL0) > abs(DBL1) */ +/* DBL0: original values + DBL1: fraction with explicit leading 1, shifted into place + r4: orig. DBL0 & 0x7fffffff + r6: orig. DBL1 & 0x7f800000 + r9: 0x7f800000 + r10: orig. DBL0H ^ DBL1H + r5 : guard bits */ + .balign 4 +.Lsub: + neg.f r12,r5 + bmsk r3,r0,22 + bset r5,r3,23 + sbc.f r4,r5,r1 + beq.d .Large_cancel_sub + bic r7,r0,r3 + norm r3,r4 + bmsk r6,r7,30 +.Lsub_done: + sub_s r3,r3,6 + breq r3,1,.Lsub_done_noshift + asl r5,r3,23 + sub_l r3,r3,1 + brlo r6,r5,.Ldenorm_sub + sub r0,r7,r5 + neg_s r1,r3 + lsr.f r2,r12,r1 + asl_s r12,r12,r3 + btst_s r2,0 + bmsk.eq.f r12,r12,30 + asl r5,r4,r3 + add_s r0,r0,r2 + adc.ne r0,r0,0 + j_s.d [blink] + add_l r0,r0,r5 + +.Lret0: + j_s.d [blink] + mov_l r0,0 + + .balign 4 +.Ldenorm_small_shift: + brne.d r12,1,.Lfixed_denorm_small_shift + sub_s r12,r12,1 + brlt.d r10,0,.Lsub + mov_s r5,r12 ; zero r5, and align following code +.Ladd: ; Both bit 23 of DBL1 and bit 0 of r5 are clear. + bmsk r2,r0,22 + add_s r2,r2,r1 + bbit0.d r2,23,.Lno_shiftdown + add_s r0,r0,r1 + bic.f 0,r9,r0; check for overflow -> infinity; eq : infinity + bmsk r1,r2,22 + lsr.ne.f r2,r2,2; cc: even ; hi: might round down + lsr.ne r1,r1,1 + rcmp.hi r5,1; hi : round down + bclr.hi r0,r0,0 + j_l.d [blink] + sub_s r0,r0,r1 + +/* r4: DBL0H & 0x7fffffff + r6: DBL1H & 0x7f800000 + r9: 0x7f800000 + r10: sign difference + r12: shift count (negative) */ + .balign 4 +.Ldbl1_gt: + brhs r6,r9,.Lret_dbl1 ; inf or NaN + neg r8,r12 + brhi r8,25,.Lret_dbl1 +.Lsmall_shift_dbl0: + breq.d r6,0,.Ldenorm_small_shift_dbl0 + bmsk_s r0,r0,22 + bset_s r0,r0,23 +.Lfixed_denorm_small_shift_dbl0: + asl r5,r0,r12 + brge.d r10,0,.Ladd_dbl1_gt + lsr r0,r0,r8 +/* subtract, abs(DBL0) < abs(DBL1) */ +/* DBL0: fraction with explicit leading 1, shifted into place + DBL1: original value + r6: orig. DBL1 & 0x7f800000 + r9: 0x7f800000 + r5: guard bits */ + .balign 4 +.Lrsub: + neg.f r12,r5 + bmsk r5,r1,22 + bic r7,r1,r5 + bset r5,r5,23 + sbc.f r4,r5,r0 + bne.d .Lsub_done ; note: r6 is already set up. + norm r3,r4 + /* Fall through */ + +/* r4:r12 : unnormalized result fraction + r7: result sign and exponent */ +/* When seeing large cancellation, only the topmost guard bit might be set. */ + .balign 4 +.Large_cancel_sub: + breq_s r12,0,.Lret0 + sub r0,r7,24<<23 + xor.f 0,r0,r7 ; test if exponent is negative + tst.pl r9,r0 ; test if exponent is zero + jpnz [blink] ; return if non-denormal result + bmsk r6,r7,30 + lsr r3,r6,23 + xor r0,r6,r7 + sub_s r3,r3,24-22 + j_s.d [blink] + bset r0,r0,r3 + + ; If a denorm is produced, we have an exact result - + ; no need for rounding. + .balign 4 +.Ldenorm_sub: + sub r3,r6,1 + lsr.f r3,r3,23 + xor r0,r6,r7 + neg_s r1,r3 + asl.ne r4,r4,r3 + lsr_s r12,r12,r1 + add_s r0,r0,r4 + j_s.d [blink] + add.ne r0,r0,r12 + + .balign 4 +.Lsub_done_noshift: + add.f 0,r12,r12 + btst.eq r4,0 + bclr r4,r4,23 + add r0,r7,r4 + j_s.d [blink] + adc.ne r0,r0,0 + + .balign 4 +.Lno_shiftdown: + add.f 0,r5,r5 + btst.eq r0,0 + cmp.eq r5,r5 + j_s.d [blink] + add.cs r0,r0,1 + +.Lret_dbl1: + j_s.d [blink] + mov_l r0,r1 + .balign 4 +.Ldenorm_small_shift_dbl0: + sub.f r8,r8,1 + bne.d .Lfixed_denorm_small_shift_dbl0 + add_s r12,r12,1 + brlt.d r10,0,.Lrsub + mov r5,0 +.Ladd_dbl1_gt: ; both bit 23 of DBL0 and bit 0 of r5 are clear. + bmsk r2,r1,22 + add_s r2,r2,r0 + bbit0.d r2,23,.Lno_shiftdown_dbl1_gt + add_s r0,r1,r0 + bic.f 0,r9,r0; check for overflow -> infinity; eq : infinity + bmsk r1,r2,22 + lsr.ne.f r2,r2,2; cc: even ; hi: might round down + lsr.ne r1,r1,1 + rcmp.hi r5,1; hi : round down + bclr.hi r0,r0,0 + j_l.d [blink] + sub_s r0,r0,r1 + + .balign 4 +.Lno_shiftdown_dbl1_gt: + add.f 0,r5,r5 + btst.eq r0,0 + cmp.eq r5,r5 + j_s.d [blink] + add.cs r0,r0,1 + ENDFUNC(__addsf3) + ENDFUNC(__subsf3) diff --git a/arch/arc/lib/ieee-754/arc-ieee-754.h b/arch/arc/lib/ieee-754/arc-ieee-754.h new file mode 100644 index 000000000000..d8df22cfd723 --- /dev/null +++ b/arch/arc/lib/ieee-754/arc-ieee-754.h @@ -0,0 +1,63 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#ifdef __LITTLE_ENDIAN__ +#define DBL0L r0 +#define DBL0H r1 +#define DBL1L r2 +#define DBL1H r3 +#else +#define DBL0L r1 +#define DBL0H r0 +#define DBL1L r3 +#define DBL1H r2 +#endif +#define add_l add +#define asr_l asr +#define j_l j +#define jne_l jne +#define jeq_l jeq +#define or_l or +#define mov_l mov +#define b_l b +#define beq_l beq +#define bne_l bne +#define brne_l brne +#define bset_l bset +#define sub_l sub +#define sub1_l sub1 +#define lsr_l lsr +#define xor_l xor +#define bic_l bic +#define bmsk_l bmsk +#define bxor_l bxor +#define bcs_s blo_s +#if defined (__HS__) || defined (__EM__) +#define MPYHU mpymu +#define MPYH mpym +#else +#define MPYHU mpyhu +#define MPYH mpyh +#endif diff --git a/arch/arc/lib/ieee-754/arc600-dsp/divdf3.S b/arch/arc/lib/ieee-754/arc600-dsp/divdf3.S new file mode 100644 index 000000000000..20b06715c4fb --- /dev/null +++ b/arch/arc/lib/ieee-754/arc600-dsp/divdf3.S @@ -0,0 +1,421 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* + to calculate a := b/x as b*y, with y := 1/x: + - x is in the range [1..2) + - calculate 15..18 bit inverse y0 using a table of approximating polynoms. + Precision is higher for polynoms used to evaluate input with larger + value. + - Do one newton-raphson iteration step to double the precision, + then multiply this with the divisor + -> more time to decide if dividend is subnormal + - the worst error propagation is on the side of the value range + with the least initial defect, thus giving us about 30 bits precision. + The truncation error for the either is less than 1 + x/2 ulp. + A 31 bit inverse can be simply calculated by using x with implicit 1 + and chaining the multiplies. For a 32 bit inverse, we multiply y0^2 + with the bare fraction part of x, then add in y0^2 for the implicit + 1 of x. + - If calculating a 31 bit inverse, the systematic error is less than + -1 ulp; likewise, for 32 bit, it is less than -2 ulp. + - If we calculate our seed with a 32 bit fraction, we can archive a + tentative result strictly better than -2 / +2.5 (1) ulp/128, i.e. we + only need to take the step to calculate the 2nd stage rest and + rounding adjust 1/32th of the time. However, if we use a 20 bit + fraction for the seed, the negative error can exceed -2 ulp/128, (2) + thus for a simple add / tst check, we need to do the 2nd stage + rest calculation/ rounding adjust 1/16th of the time. + (1): The inexactness of the 32 bit inverse contributes an error in the + range of (-1 .. +(1+x/2) ) ulp/128. Leaving out the low word of the + rest contributes an error < +1/x ulp/128 . In the interval [1,2), + x/2 + 1/x <= 1.5 . + (2): Unless proven otherwise. I have not actually looked for an + example where -2 ulp/128 is exceeded, and my calculations indicate + that the excess, if existent, is less than -1/512 ulp. + ??? The algorithm is still based on the ARC700 optimized code. + Maybe we could make better use of 32x16 bit multiply, or 64 bit multiply + results. + */ +#include "../arc-ieee-754.h" +#define mlo acc2 +#define mhi acc1 +#define mul64(b,c) mullw 0,b,c` machlw 0,b,c +#define mulu64(b,c) mululw 0,b,c` machulw 0,b,c + +/* N.B. fp-bit.c does double rounding on denormal numbers. */ +#if 0 /* DEBUG */ + .global __divdf3 + FUNC(__divdf3) + .balign 4 +__divdf3: + push_s blink + push_s r2 + push_s r3 + push_s r0 + bl.d __divdf3_c + push_s r1 + ld_s r2,[sp,12] + ld_s r3,[sp,8] + st_s r0,[sp,12] + st_s r1,[sp,8] + pop_s r1 + bl.d __divdf3_asm + pop_s r0 + pop_s r3 + pop_s r2 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + and r12,DBL0H,DBL1H + bic.f 0,0x7ff80000,r12 ; both NaN -> OK + jeq_s [blink] + bl abort + ENDFUNC(__divdf3) +#define __divdf3 __divdf3_asm +#endif /* DEBUG */ + + FUNC(__divdf3) + .balign 4 +.L7ff00000: + .long 0x7ff00000 +.Ldivtab: + .long 0xfc0fffe1 + .long 0xf46ffdfb + .long 0xed1ffa54 + .long 0xe61ff515 + .long 0xdf7fee75 + .long 0xd91fe680 + .long 0xd2ffdd52 + .long 0xcd1fd30c + .long 0xc77fc7cd + .long 0xc21fbbb6 + .long 0xbcefaec0 + .long 0xb7efa100 + .long 0xb32f92bf + .long 0xae8f83b7 + .long 0xaa2f7467 + .long 0xa5ef6479 + .long 0xa1cf53fa + .long 0x9ddf433e + .long 0x9a0f3216 + .long 0x965f2091 + .long 0x92df0f11 + .long 0x8f6efd05 + .long 0x8c1eeacc + .long 0x88eed876 + .long 0x85dec615 + .long 0x82eeb3b9 + .long 0x800ea10b + .long 0x7d3e8e0f + .long 0x7a8e7b3f + .long 0x77ee6836 + .long 0x756e5576 + .long 0x72fe4293 + .long 0x709e2f93 + .long 0x6e4e1c7f + .long 0x6c0e095e + .long 0x69edf6c5 + .long 0x67cde3a5 + .long 0x65cdd125 + .long 0x63cdbe25 + .long 0x61ddab3f + .long 0x600d991f + .long 0x5e3d868c + .long 0x5c6d7384 + .long 0x5abd615f + .long 0x590d4ecd + .long 0x576d3c83 + .long 0x55dd2a89 + .long 0x545d18e9 + .long 0x52dd06e9 + .long 0x516cf54e + .long 0x4ffce356 + .long 0x4e9cd1ce + .long 0x4d3cbfec + .long 0x4becae86 + .long 0x4aac9da4 + .long 0x496c8c73 + .long 0x483c7bd3 + .long 0x470c6ae8 + .long 0x45dc59af + .long 0x44bc4915 + .long 0x43ac3924 + .long 0x428c27fb + .long 0x418c187a + .long 0x407c07bd + +__divdf3_support: /* This label makes debugger output saner. */ + .balign 4 +.Ldenorm_dbl1: + brge r6, \ + 0x43500000,.Linf_NaN ; large number / denorm -> Inf + bmsk.f r12,DBL1H,19 + mov.eq r12,DBL1L + mov.eq DBL1L,0 + sub.eq r7,r7,32 + norm.f r11,r12 ; flag for x/0 -> Inf check + beq_s .Linf_NaN + mov.mi r11,0 + add.pl r11,r11,1 + add_s r12,r12,r12 + asl r8,r12,r11 + rsub r12,r11,31 + lsr r12,DBL1L,r12 + tst_s DBL1H,DBL1H + or r8,r8,r12 + lsr r4,r8,26 + lsr DBL1H,r8,12 + ld.as r4,[r10,r4] + bxor.mi DBL1H,DBL1H,31 + sub r11,r11,11 + asl DBL1L,DBL1L,r11 + sub r11,r11,1 + mulu64 (r4,r8) + sub r7,r7,r11 + b.d .Lpast_denorm_dbl1 + asl r7,r7,20 + +.Linf_NaN: + tst_s DBL0L,DBL0L ; 0/0 -> NaN + xor_s DBL1H,DBL1H,DBL0H + bclr.eq.f DBL0H,DBL0H,31 + bmsk DBL0H,DBL1H,30 + xor_s DBL0H,DBL0H,DBL1H + sub.eq DBL0H,DBL0H,1 + mov_s DBL0L,0 + j_s.d [blink] + or DBL0H,DBL0H,r9 + .balign 4 +.Lret0_2: + xor_s DBL1H,DBL1H,DBL0H + mov_s DBL0L,0 + bmsk DBL0H,DBL1H,30 + j_s.d [blink] + xor_s DBL0H,DBL0H,DBL1H + .balign 4 + .global __divdf3 +/* N.B. the spacing between divtab and the sub3 to get its address must + be a multiple of 8. */ +__divdf3: + asl r8,DBL1H,12 + lsr r4,r8,26 + sub3 r10,pcl,51;(.-.Ldivtab) >> 3 + ld.as r9,[pcl,-104]; [pcl,(-((.-.L7ff00000) >> 2))] ; 0x7ff00000 + ld.as r4,[r10,r4] + lsr r12,DBL1L,20 + and.f r7,DBL1H,r9 + or r8,r8,r12 + mulu64 (r4,r8) + beq.d .Ldenorm_dbl1 +.Lpast_denorm_dbl1: + and.f r6,DBL0H,r9 + breq.d r7,r9,.Linf_nan_dbl1 + asl r4,r4,12 + sub r4,r4,mhi + mululw 0,r4,r4 + machulw r5,r4,r4 + bne.d .Lnormal_dbl0 + lsr r8,r8,1 + + .balign 4 +.Ldenorm_dbl0: + bmsk.f r12,DBL0H,19 + ; wb stall + mov.eq r12,DBL0L + sub.eq r6,r6,32 + norm.f r11,r12 ; flag for 0/x -> 0 check + brge r7, \ + 0x43500000, .Lret0_2 ; denorm/large number -> 0 + beq_s .Lret0_2 + mov.mi r11,0 + add.pl r11,r11,1 + asl r12,r12,r11 + sub r6,r6,r11 + add.f 0,r6,31 + lsr r10,DBL0L,r6 + mov.mi r10,0 + add r6,r6,11+32 + neg.f r11,r6 + asl DBL0L,DBL0L,r11 + mov.pl DBL0L,0 + sub r6,r6,32-1 + b.d .Lpast_denorm_dbl0 + asl r6,r6,20 + + .balign 4 +.Linf_nan_dbl1: ; 0/Inf -> NaN Inf/Inf -> NaN x/Inf-> 0 x/NaN -> NaN + or.f 0,r6,DBL0L + cmp.ne r6,r9 + not_s DBL0L,DBL1H + sub_s.ne DBL0L,DBL0L,DBL0L + tst_s DBL0H,DBL0H + add_s DBL0H,DBL1H,DBL0L + j_s.d [blink] + bxor.mi DBL0H,DBL0H,31 + + .balign 4 +.Lnormal_dbl0: + breq.d r6,r9,.Linf_nan_dbl0 + asl r12,DBL0H,11 + lsr r10,DBL0L,21 +.Lpast_denorm_dbl0: + bset r8,r8,31 + mulu64 (r5,r8) + add_s r12,r12,r10 + bset r5,r12,31 + cmp r5,r8 + cmp.eq DBL0L,DBL1L + lsr.cc r5,r5,1 + sub r4,r4,mhi ; u1.31 inverse, about 30 bit + mululw 0,r5,r4 + machulw r11,r5,r4 ; result fraction highpart + lsr r8,r8,2 ; u3.29 + add r5,r6, /* wait for immediate */ \ + 0x3fe00000 + mulu64 (r11,r8) ; u-28.31 + asl_s DBL1L,DBL1L,9 ; u-29.23:9 + sbc r6,r5,r7 + mov r12,mlo ; u-28.31 + mulu64 (r11,DBL1L) ; mhi: u-28.23:9 + add.cs DBL0L,DBL0L,DBL0L + asl_s DBL0L,DBL0L,6 ; u-26.25:7 + asl r10,r11,23 + sub_l DBL0L,DBL0L,r12 + lsr r7,r11,9 + sub r5,DBL0L,mhi ; rest msw ; u-26.31:0 + mul64 (r5,r4) ; mhi: result fraction lowpart + xor.f 0,DBL0H,DBL1H + and DBL0H,r6,r9 + add_s DBL0H,DBL0H,r7 + bclr r12,r9,20 ; 0x7fe00000 + brhs.d r6,r12,.Linf_denorm + bxor.mi DBL0H,DBL0H,31 + add.f r12,mhi,0x11 + asr r9,r12,5 + sub.mi DBL0H,DBL0H,1 + add.f DBL0L,r9,r10 + tst r12,0x1c + jne.d [blink] + add.cs DBL0H,DBL0H,1 + /* work out exact rounding if we fall through here. */ + /* We know that the exact result cannot be represented in double + precision. Find the mid-point between the two nearest + representable values, multiply with the divisor, and check if + the result is larger than the dividend. Since we want to know + only the sign bit, it is sufficient to calculate only the + highpart of the lower 64 bits. */ + mulu64 (r11,DBL1L) ; rest before considering r12 in r5 : -mlo + sub.f DBL0L,DBL0L,1 + asl r12,r9,2 ; u-22.30:2 + sub.cs DBL0H,DBL0H,1 + sub.f r12,r12,2 + mov r10,mlo ; rest before considering r12 in r5 : -r10 + mululw 0,r12,DBL1L + machulw r7,r12,DBL1L ; mhi: u-51.32 + asl r5,r5,25 ; s-51.7:25 + lsr r10,r10,7 ; u-51.30:2 + mulu64 (r12,r8) ; mlo: u-51.31:1 + sub r5,r5,r10 + add.mi r5,r5,DBL1L ; signed multiply adjust for r12*DBL1L + bset r7,r7,0 ; make sure that the result is not zero, and that + sub r5,r5,r7 ; a highpart zero appears negative + sub.f r5,r5,mlo ; rest msw + add.pl.f DBL0L,DBL0L,1 + j_s.d [blink] + add.eq DBL0H,DBL0H,1 + +.Linf_nan_dbl0: + tst_s DBL1H,DBL1H + j_s.d [blink] + bxor.mi DBL0H,DBL0H,31 + .balign 4 +.Linf_denorm: + lsr r12,r6,28 + brlo.d r12,0xc,.Linf +.Ldenorm: + asr r6,r6,20 + neg r9,r6 + mov_s DBL0H,0 + brhs.d r9,54,.Lret0 + bxor.mi DBL0H,DBL0H,31 + add r12,mhi,1 + and r12,r12,-4 + rsub r7,r6,5 + asr r10,r12,28 + bmsk r4,r12,27 + min r7,r7,31 + asr DBL0L,r4,r7 + add DBL1H,r11,r10 + abs.f r10,r4 + sub.mi r10,r10,1 + add.f r7,r6,32-5 + asl r4,r4,r7 + mov.mi r4,r10 + add.f r10,r6,23 + rsub r7,r6,9 + lsr r7,DBL1H,r7 + asl r10,DBL1H,r10 + or.pnz DBL0H,DBL0H,r7 + or.mi r4,r4,r10 + mov.mi r10,r7 + add.f DBL0L,r10,DBL0L + add.cs.f DBL0H,DBL0H,1 ; carry clear after this point + bxor.f 0,r4,31 + add.pnz.f DBL0L,DBL0L,1 + add.cs.f DBL0H,DBL0H,1 + jne_s [blink] + /* Calculation so far was not conclusive; calculate further rest. */ + mulu64 (r11,DBL1L) ; rest before considering r12 in r5 : -mlo + asr.f r12,r12,3 + asl r5,r5,25 ; s-51.7:25 + mov r11,mlo ; rest before considering r12 in r5 : -r11 + mulu64 (r12,r8) ; u-51.31:1 + and r9,DBL0L,1 ; tie-breaker: round to even + lsr r11,r11,7 ; u-51.30:2 + mov DBL1H,mlo ; u-51.31:1 + mulu64 (r12,DBL1L) ; u-51.62:2 + sub.mi r11,r11,DBL1L ; signed multiply adjust for r12*DBL1L + add_s DBL1H,DBL1H,r11 + sub DBL1H,DBL1H,r5 ; -rest msw + add_s DBL1H,DBL1H,mhi ; -rest msw + add.f 0,DBL1H,DBL1H ; can't ror.f by 32 :-( + tst_s DBL1H,DBL1H + cmp.eq mlo,r9 + add.cs.f DBL0L,DBL0L,1 + j_s.d [blink] + add.cs DBL0H,DBL0H,1 + +.Lret0: + /* return +- 0 */ + j_s.d [blink] + mov_s DBL0L,0 +.Linf: + mov_s DBL0H,r9 + mov_s DBL0L,0 + j_s.d [blink] + bxor.mi DBL0H,DBL0H,31 + ENDFUNC(__divdf3) diff --git a/arch/arc/lib/ieee-754/arc600-dsp/divsf3.S b/arch/arc/lib/ieee-754/arc600-dsp/divsf3.S new file mode 100644 index 000000000000..07ae4af9ec0b --- /dev/null +++ b/arch/arc/lib/ieee-754/arc600-dsp/divsf3.S @@ -0,0 +1,274 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* + - calculate 15..18 bit inverse using a table of approximating polynoms. + precision is higher for polynoms used to evaluate input with larger + value. + - do one newton-raphson iteration step to double the precision, + then multiply this with the divisor + -> more time to decide if dividend is subnormal + - the worst error propagation is on the side of the value range + with the least initial defect, thus giving us about 30 bits precision. + */ +#include "../arc-ieee-754.h" +#define mlo acc2 +#define mhi acc1 +#define mul64(b,c) mullw 0,b,c` machlw 0,b,c +#define mulu64(b,c) mululw 0,b,c` machulw 0,b,c + +#if 0 /* DEBUG */ + .global __divsf3 + FUNC(__divsf3) + .balign 4 +__divsf3: + push_s blink + push_s r1 + bl.d __divsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __divsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 +#if 1 + bne abort + jeq_s [blink] + b abort +#else + bne abort + j_s [blink] +#endif + ENDFUNC(__divsf3) +#define __divsf3 __divsf3_asm +#endif /* DEBUG */ + + FUNC(__divsf3) + .balign 4 +.Ldivtab: + .long 0xfc0ffff0 + .long 0xf46ffefd + .long 0xed1ffd2a + .long 0xe627fa8e + .long 0xdf7ff73b + .long 0xd917f33b + .long 0xd2f7eea3 + .long 0xcd1fe986 + .long 0xc77fe3e7 + .long 0xc21fdddb + .long 0xbcefd760 + .long 0xb7f7d08c + .long 0xb32fc960 + .long 0xae97c1ea + .long 0xaa27ba26 + .long 0xa5e7b22e + .long 0xa1cfa9fe + .long 0x9ddfa1a0 + .long 0x9a0f990c + .long 0x9667905d + .long 0x92df878a + .long 0x8f6f7e84 + .long 0x8c27757e + .long 0x88f76c54 + .long 0x85df630c + .long 0x82e759c5 + .long 0x8007506d + .long 0x7d3f470a + .long 0x7a8f3da2 + .long 0x77ef341e + .long 0x756f2abe + .long 0x72f7212d + .long 0x709717ad + .long 0x6e4f0e44 + .long 0x6c1704d6 + .long 0x69e6fb44 + .long 0x67cef1d7 + .long 0x65c6e872 + .long 0x63cedf18 + .long 0x61e6d5cd + .long 0x6006cc6d + .long 0x5e36c323 + .long 0x5c76b9f3 + .long 0x5abeb0b7 + .long 0x5916a79b + .long 0x57769e77 + .long 0x55de954d + .long 0x54568c4e + .long 0x52d6834d + .long 0x51667a7f + .long 0x4ffe71b5 + .long 0x4e9e68f1 + .long 0x4d466035 + .long 0x4bf65784 + .long 0x4aae4ede + .long 0x496e4646 + .long 0x48363dbd + .long 0x47063547 + .long 0x45de2ce5 + .long 0x44be2498 + .long 0x43a61c64 + .long 0x4296144a + .long 0x41860c0e + .long 0x407e03ee +.L7f800000: + .long 0x7f800000 + .balign 4 + .global __divsf3_support +__divsf3_support: +.Linf_NaN: + bclr.f 0,r0,31 ; 0/0 -> NaN + xor_s r0,r0,r1 + bmsk r1,r0,30 + bic_s r0,r0,r1 + sub.eq r0,r0,1 + j_s.d [blink] + or r0,r0,r9 +.Lret0: + xor_s r0,r0,r1 + bmsk r1,r0,30 + j_s.d [blink] + bic_s r0,r0,r1 +/* N.B. the spacing between divtab and the sub3 to get its address must + be a multiple of 8. */ +__divsf3: + ld.as r9,[pcl,-9]; [pcl,(-((.-.L7f800000) >> 2))] ; 0x7f800000 + sub3 r3,pcl,37;(.-.Ldivtab) >> 3 + lsr r2,r1,17 + and.f r11,r1,r9 + bmsk r5,r2,5 + beq.d .Ldenorm_fp1 + asl r6,r1,8 + and.f r2,r0,r9 + ld.as r5,[r3,r5] + asl r4,r1,9 + bset r6,r6,31 + breq.d r11,r9,.Linf_nan_fp1 +.Lpast_denorm_fp1: + mululw 0,r5,r4 + machulw r8,r5,r4 + breq.d r2,r9,.Linf_nan_fp0 + asl r5,r5,13 + sub r7,r5,r8 + mululw 0,r7,r6 + machulw r8,r7,r6 + beq.d .Ldenorm_fp0 + asl r12,r0,8 + mulu64 (r8,r7) + bset r3,r12,31 +.Lpast_denorm_fp0: + cmp_s r3,r6 + lsr.cc r3,r3,1 + add_s r2,r2, /* wait for immediate */ \ + 0x3f000000 + sub r7,r7,mhi ; u1.31 inverse, about 30 bit + mulu64 (r3,r7) + sbc r2,r2,r11 + xor.f 0,r0,r1 + and r0,r2,r9 + bclr r3,r9,23 ; 0x7f000000 + brhs.d r2,r3,.Linf_denorm + bxor.mi r0,r0,31 +.Lpast_denorm: + add r3,mhi,0x22 ; round to nearest or higher + tst r3,0x3c ; check if rounding was unsafe + lsr r3,r3,6 + jne.d [blink] ; return if rounding was safe. + add_s r0,r0,r3 + /* work out exact rounding if we fall through here. */ + /* We know that the exact result cannot be represented in single + precision. Find the mid-point between the two nearest + representable values, multiply with the divisor, and check if + the result is larger than the dividend. */ + add_s r3,r3,r3 + sub_s r3,r3,1 + mulu64 (r3,r6) + asr.f 0,r0,1 ; for round-to-even in case this is a denorm + rsub r2,r9,25 + asl_s r12,r12,r2 + sub.f 0,r12,mlo + j_s.d [blink] + sub.mi r0,r0,1 +.Linf_nan_fp1: + lsr_s r0,r0,31 + bmsk.f 0,r1,22 + asl_s r0,r0,31 + bne_s 0f ; inf/inf -> nan + brne r2,r9,.Lsigned0 ; x/inf -> 0, but x/nan -> nan +0: j_s.d [blink] + mov r0,-1 +.Lsigned0: +.Linf_nan_fp0: + tst_s r1,r1 + j_s.d [blink] + bxor.mi r0,r0,31 + .balign 4 + .global __divsf3 +/* For denormal results, it is possible that an exact result needs + rounding, and thus the round-to-even rule has to come into play. */ +.Linf_denorm: + brlo r2,0xc0000000,.Linf +.Ldenorm: + asr_s r2,r2,23 + bic r0,r0,r9 + neg r9,r2 + brlo.d r9,25,.Lpast_denorm + lsr r3,mlo,r9 + /* Fall through: return +- 0 */ + j_s [blink] +.Linf: + j_s.d [blink] + or r0,r0,r9 + .balign 4 +.Ldenorm_fp1: + norm.f r12,r6 ; flag for x/0 -> Inf check + add r6,r6,r6 + rsub r5,r12,16 + ror r5,r1,r5 + bmsk r5,r5,5 + bic.ne.f 0, \ + 0x60000000,r0 ; large number / denorm -> Inf + ld.as r5,[r3,r5] + asl r6,r6,r12 + beq.d .Linf_NaN + and.f r2,r0,r9 + add r4,r6,r6 + asl_s r12,r12,23 + bne.d .Lpast_denorm_fp1 + add_s r2,r2,r12 +.Ldenorm_fp0: + mulu64 (r8,r7) + bclr r12,r12,31 + norm.f r3,r12 ; flag for 0/x -> 0 check + bic.ne.f 0,0x60000000,r1 ; denorm/large number -> 0 + beq_s .Lret0 + asl_s r12,r12,r3 + asl_s r3,r3,23 + add_s r12,r12,r12 + add r11,r11,r3 + b.d .Lpast_denorm_fp0 + mov_s r3,r12 + ENDFUNC(__divsf3) diff --git a/arch/arc/lib/ieee-754/arc600-dsp/muldf3.S b/arch/arc/lib/ieee-754/arc600-dsp/muldf3.S new file mode 100644 index 000000000000..22c01de61b43 --- /dev/null +++ b/arch/arc/lib/ieee-754/arc600-dsp/muldf3.S @@ -0,0 +1,231 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "../arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __muldf3 + .balign 4 +__muldf3: + push_s blink + push_s r2 + push_s r3 + push_s r0 + bl.d __muldf3_c + push_s r1 + ld_s r2,[sp,12] + ld_s r3,[sp,8] + st_s r0,[sp,12] + st_s r1,[sp,8] + pop_s r1 + bl.d __muldf3_asm + pop_s r0 + pop_s r3 + pop_s r2 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + b abort +#define __muldf3 __muldf3_asm +#endif /* DEBUG */ + +__muldf3_support: /* This label makes debugger output saner. */ + .balign 4 + FUNC(__muldf3) +.Ldenorm_2: + breq.d DBL1L,0,.Lret0_2 ; 0 input -> 0 output + norm.f r12,DBL1L + mov.mi r12,21 + add.pl r12,r12,22 + neg r11,r12 + asl_s r12,r12,20 + lsr.f DBL1H,DBL1L,r11 + ror DBL1L,DBL1L,r11 + sub_s DBL0H,DBL0H,r12 + mov.eq DBL1H,DBL1L + sub_l DBL1L,DBL1L,DBL1H + /* Fall through. */ + .global __muldf3 + .balign 4 +__muldf3: + mululw 0,DBL0L,DBL1L + machulw r4,DBL0L,DBL1L + ld.as r9,[pcl,0x67] ; ((.L7ff00000-.+2)/4)] + bmsk r6,DBL0H,19 + bset r6,r6,20 + mov r8,acc2 + mululw 0,r4,1 + and r11,DBL0H,r9 + breq.d r11,0,.Ldenorm_dbl0 + and r12,DBL1H,r9 + breq.d r12,0,.Ldenorm_dbl1 + maclw 0,r6,DBL1L + machulw 0,r6,DBL1L + breq.d r11,r9,.Linf_nan + bmsk r10,DBL1H,19 + breq.d r12,r9,.Linf_nan + bset r10,r10,20 + maclw 0,r10,DBL0L + machulw r5,r10,DBL0L + add_s r12,r12,r11 ; add exponents + mov r4,acc2 + mululw 0,r5,1 + maclw 0,r6,r10 + machulw r7,r6,r10 ; fraction product in r7:acc2:r4:r8 + tst r8,r8 + bclr r8,r9,30 ; 0x3ff00000 + bset.ne r4,r4,0 ; put least significant word into sticky bit + bclr r6,r9,20 ; 0x7fe00000 + lsr.f r10,r7,9 + rsub.eq r8,r8,r9 ; 0x40000000 + sub r12,r12,r8 ; subtract bias + implicit 1 + brhs.d r12,r6,.Linf_denorm + rsub r10,r10,12 +.Lshift_frac: + neg r8,r10 + asl r6,r4,r10 + lsr DBL0L,r4,r8 + add.f 0,r6,r6 + btst.eq DBL0L,0 + cmp.eq r4,r4 ; round to nearest / round to even + asl r4,acc2,r10 + lsr r5,acc2,r8 + adc.f DBL0L,DBL0L,r4 + xor.f 0,DBL0H,DBL1H + asl r7,r7,r10 + add_s r12,r12,r5 + adc DBL0H,r12,r7 + j_s.d [blink] + bset.mi DBL0H,DBL0H,31 + +/* N.B. This is optimized for ARC700. + ARC600 has very different scheduling / instruction selection criteria. */ + +/* If one number is denormal, subtract some from the exponent of the other + one (if the other exponent is too small, return 0), and normalize the + denormal. Then re-run the computation. */ +.Lret0_2: + lsr_s DBL0H,DBL0H,31 + asl_s DBL0H,DBL0H,31 + j_s.d [blink] + mov_s DBL0L,0 + .balign 4 +.Ldenorm_dbl0: + mov_s r12,DBL0L + mov_s DBL0L,DBL1L + mov_s DBL1L,r12 + mov_s r12,DBL0H + mov_s DBL0H,DBL1H + mov_s DBL1H,r12 + and r11,DBL0H,r9 +.Ldenorm_dbl1: + brhs r11,r9,.Linf_nan + brhs 0x3ca00001,r11,.Lret0 + sub_s DBL0H,DBL0H,DBL1H + bmsk.f DBL1H,DBL1H,30 + add_s DBL0H,DBL0H,DBL1H + beq.d .Ldenorm_2 + norm r12,DBL1H + sub_s r12,r12,10 + asl r5,r12,20 + asl_s DBL1H,DBL1H,r12 + sub DBL0H,DBL0H,r5 + neg r5,r12 + lsr r6,DBL1L,r5 + asl_s DBL1L,DBL1L,r12 + b.d __muldf3 + add_s DBL1H,DBL1H,r6 + +.Lret0: xor_s DBL0H,DBL0H,DBL1H + bclr DBL1H,DBL0H,31 + xor_s DBL0H,DBL0H,DBL1H + j_s.d [blink] + mov_s DBL0L,0 + + .balign 4 +.Linf_nan: + bclr r12,DBL1H,31 + xor_s DBL1H,DBL1H,DBL0H + bclr_s DBL0H,DBL0H,31 + max r8,DBL0H,r12 ; either NaN -> NaN ; otherwise inf + or.f 0,DBL0H,DBL0L + mov_s DBL0L,0 + or.ne.f DBL1L,DBL1L,r12 + not_s DBL0H,DBL0L ; inf * 0 -> NaN + mov.ne DBL0H,r8 + tst_s DBL1H,DBL1H + j_s.d [blink] + bset.mi DBL0H,DBL0H,31 + +/* We have checked for infinity / NaN input before, and transformed + denormalized inputs into normalized inputs. Thus, the worst case + exponent overflows are: + 1 + 1 - 0x400 == 0xc02 : maximum underflow + 0x7fe + 0x7fe - 0x3ff == 0xbfd ; maximum overflow + N.B. 0x7e and 0x7f are also values for overflow. + + If (r12 <= -54), we have an underflow to zero. */ + .balign 4 +.Linf_denorm: + lsr r6,r12,28 + brlo.d r6,0xc,.Linf + asr r6,r12,20 + add.f r10,r10,r6 + brgt.d r10,0,.Lshift_frac + mov_s r12,0 + beq.d .Lround_frac + add r10,r10,32 +.Lshift32_frac: + tst r4,r4 + mov r4,acc2 + bset.ne r4,r4,1 + mululw 0,r7,1 + brge.d r10,1,.Lshift_frac + mov r7,0 + breq.d r10,0,.Lround_frac + add r10,r10,32 + brgt r10,21,.Lshift32_frac + b_s .Lret0 + +.Lround_frac: + add.f 0,r4,r4 + btst.eq acc2,0 + mov_s DBL0L,acc2 + mov_s DBL0H,r7 + adc.eq.f DBL0L,DBL0L,0 + j_s.d [blink] + adc.eq DBL0H,DBL0H,0 + +.Linf: mov_s DBL0L,0 + xor.f DBL1H,DBL1H,DBL0H + mov_s DBL0H,r9 + j_s.d [blink] + bset.mi DBL0H,DBL0H,31 + ENDFUNC(__muldf3) + + .balign 4 +.L7ff00000: + .long 0x7ff00000 diff --git a/arch/arc/lib/ieee-754/arc600-dsp/mulsf3.S b/arch/arc/lib/ieee-754/arc600-dsp/mulsf3.S new file mode 100644 index 000000000000..7c2204f047f9 --- /dev/null +++ b/arch/arc/lib/ieee-754/arc600-dsp/mulsf3.S @@ -0,0 +1,176 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "../arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __mulsf3 + FUNC(__mulsf3) + .balign 4 +__mulsf3: + push_s blink + push_s r1 + bl.d __mulsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __mulsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + and r12,r0,r1 + bic.f 0,0x7f800000,r12 + bne 0f + bmsk.f 0,r0,22 + bmsk.ne.f r1,r1,22 + jne_s [blink] ; both NaN -> OK +0: bl abort + ENDFUNC(__mulsf3) +#define __mulsf3 __mulsf3_asm +#endif /* DEBUG */ + + .balign 4 + .global __mulsf3 + FUNC(__mulsf3) +__mulsf3: + ld.as r9,[pcl,80]; [pcl,((.L7f800000-.+2)/4)] + bmsk r4,r1,22 + bset r2,r0,23 + asl_s r2,r2,8 + bset r3,r4,23 + and r11,r0,r9 + breq.d r11,0,.Ldenorm_dbl0 + and r12,r1,r9 + breq.d r12,0,.Ldenorm_dbl1 + xor_s r0,r0,r1 + mululw 0,r2,r3 + machulw r6,r2,r3 + breq.d r11,r9,.Linf_nan_dbl0 + ld.as r4,[pcl,69]; [pcl,((.L7fffffff-.+2)/4)] + breq.d r12,r9,.Linf_nan_dbl1 +.Lpast_denorm: + asl.f 0,r6,8 + mov r7,acc2 + add.pl r6,r6,r6 + bclr.pl r6,r6,23 + add.pl.f r7,r7,r7 + add.cs r6,r6,1 + lsr.f 0,r6,1 + add_s r12,r12,r11 + adc.f 0,r7,r4 + add_s r12,r12, \ + -0x3f800000 + adc.f r8,r6,r12 + tst.pl r8,r9 + bic r0,r0,r4 + min r3,r8,r9 + jpnz.d [blink] + add.pnz r0,r0,r3 +; infinity or denormal number + add.ne.f r3,r3,r3 + asr_s r3,r3,23+1 + bset r6,r6,23 + bpnz.d .Linfinity + sub_s r3,r3,1 + neg_s r2,r3 + brhi.d r2,24,.Lret_r0 ; right shift shift > 24 -> return +-0 + lsr r2,r6,r2 + asl r9,r6,r3 + lsr.f 0,r2,1 + tst r7,r7 + add_s r0,r0,r2 + bset.ne r9,r9,0 + adc.f 0,r9,r4 + j_s.d [blink] + add.cs r0,r0,1 +.Linfinity: + j_s.d [blink] + add_s r0,r0,r9 + +.Lret_r0: j_s [blink] + + .balign 4 +.Ldenorm_dbl0: + bclr_s r2,r2,31 + norm.f r4,r2 + add_s r2,r2,r2 + asl r2,r2,r4 + breq.d r12,r9,.Ldenorm_dbl0_inf_nan_dbl1 + asl r4,r4,23 + mululw 0,r2,r3 + machulw r6,r2,r3 + sub.ne.f r12,r12,r4 + ld.as r4,[pcl,28]; [pcl,((.L7fffffff-.+2)/4)] + bhi.d .Lpast_denorm + xor_s r0,r0,r1 + bmsk r1,r0,30 + j_s.d [blink] + bic_s r0,r0,r1 + + .balign 4 +.Ldenorm_dbl0_inf_nan_dbl1: + bmsk.f 0,r0,30 + mov.eq r1,-1 +.Linf_nan_dbl1: + xor_s r1,r1,r0 +.Linf_nan_dbl0: + bclr_s r1,r1,31 + j_s.d [blink] + xor_s r0,r0,r1 + + .balign 4 +.Ldenorm_dbl1: + breq.d r11,r9,.Linf_nan_dbl0_2 + norm.f r3,r4 + sub_s r3,r3,7 + asl r4,r4,r3 + mululw 0,r2,r4 + machulw r6,r2,r4 + sub_s r3,r3,1 + asl_s r3,r3,23 + sub.ne.f r11,r11,r3 + ld.as r4,[pcl,11]; [pcl,((.L7fffffff-.+2)/4)] + bhi.d .Lpast_denorm + bmsk r8,r0,30 + j_s.d [blink] + bic r0,r0,r8 + + .balign 4 +.Linf_nan_dbl0_2: + bclr_s r1,r1,31 + xor_s r0,r0,r1 + sub.eq r1,r1,1 ; inf/nan * 0 -> nan + bic.f 0,r9,r1 + j_s.d [blink] + or.eq r0,r0,r1 ; r1 nan -> result nan + + .balign 4 +.L7f800000: + .long 0x7f800000 +.L7fffffff: + .long 0x7fffffff + ENDFUNC(__mulsf3) diff --git a/arch/arc/lib/ieee-754/arc600-mul64/divdf3.S b/arch/arc/lib/ieee-754/arc600-mul64/divdf3.S new file mode 100644 index 000000000000..67f0af985026 --- /dev/null +++ b/arch/arc/lib/ieee-754/arc600-mul64/divdf3.S @@ -0,0 +1,410 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* + to calculate a := b/x as b*y, with y := 1/x: + - x is in the range [1..2) + - calculate 15..18 bit inverse y0 using a table of approximating polynoms. + Precision is higher for polynoms used to evaluate input with larger + value. + - Do one newton-raphson iteration step to double the precision, + then multiply this with the divisor + -> more time to decide if dividend is subnormal + - the worst error propagation is on the side of the value range + with the least initial defect, thus giving us about 30 bits precision. + The truncation error for the either is less than 1 + x/2 ulp. + A 31 bit inverse can be simply calculated by using x with implicit 1 + and chaining the multiplies. For a 32 bit inverse, we multiply y0^2 + with the bare fraction part of x, then add in y0^2 for the implicit + 1 of x. + - If calculating a 31 bit inverse, the systematic error is less than + -1 ulp; likewise, for 32 bit, it is less than -2 ulp. + - If we calculate our seed with a 32 bit fraction, we can archive a + tentative result strictly better than -2 / +2.5 (1) ulp/128, i.e. we + only need to take the step to calculate the 2nd stage rest and + rounding adjust 1/32th of the time. However, if we use a 20 bit + fraction for the seed, the negative error can exceed -2 ulp/128, (2) + thus for a simple add / tst check, we need to do the 2nd stage + rest calculation/ rounding adjust 1/16th of the time. + (1): The inexactness of the 32 bit inverse contributes an error in the + range of (-1 .. +(1+x/2) ) ulp/128. Leaving out the low word of the + rest contributes an error < +1/x ulp/128 . In the interval [1,2), + x/2 + 1/x <= 1.5 . + (2): Unless proven otherwise. I have not actually looked for an + example where -2 ulp/128 is exceeded, and my calculations indicate + that the excess, if existent, is less than -1/512 ulp. + ??? The algorithm is still based on the ARC700 optimized code. + Maybe we could make better use of 64 bit multiply results and/or mmed . + */ +#include "../arc-ieee-754.h" + +/* N.B. fp-bit.c does double rounding on denormal numbers. */ +#if 0 /* DEBUG */ + .global __divdf3 + FUNC(__divdf3) + .balign 4 +__divdf3: + push_s blink + push_s r2 + push_s r3 + push_s r0 + bl.d __divdf3_c + push_s r1 + ld_s r2,[sp,12] + ld_s r3,[sp,8] + st_s r0,[sp,12] + st_s r1,[sp,8] + pop_s r1 + bl.d __divdf3_asm + pop_s r0 + pop_s r3 + pop_s r2 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + and r12,DBL0H,DBL1H + bic.f 0,0x7ff80000,r12 ; both NaN -> OK + jeq_s [blink] + bl abort + ENDFUNC(__divdf3) +#define __divdf3 __divdf3_asm +#endif /* DEBUG */ + + FUNC(__divdf3) + .balign 4 +.L7ff00000: + .long 0x7ff00000 +.Ldivtab: + .long 0xfc0fffe1 + .long 0xf46ffdfb + .long 0xed1ffa54 + .long 0xe61ff515 + .long 0xdf7fee75 + .long 0xd91fe680 + .long 0xd2ffdd52 + .long 0xcd1fd30c + .long 0xc77fc7cd + .long 0xc21fbbb6 + .long 0xbcefaec0 + .long 0xb7efa100 + .long 0xb32f92bf + .long 0xae8f83b7 + .long 0xaa2f7467 + .long 0xa5ef6479 + .long 0xa1cf53fa + .long 0x9ddf433e + .long 0x9a0f3216 + .long 0x965f2091 + .long 0x92df0f11 + .long 0x8f6efd05 + .long 0x8c1eeacc + .long 0x88eed876 + .long 0x85dec615 + .long 0x82eeb3b9 + .long 0x800ea10b + .long 0x7d3e8e0f + .long 0x7a8e7b3f + .long 0x77ee6836 + .long 0x756e5576 + .long 0x72fe4293 + .long 0x709e2f93 + .long 0x6e4e1c7f + .long 0x6c0e095e + .long 0x69edf6c5 + .long 0x67cde3a5 + .long 0x65cdd125 + .long 0x63cdbe25 + .long 0x61ddab3f + .long 0x600d991f + .long 0x5e3d868c + .long 0x5c6d7384 + .long 0x5abd615f + .long 0x590d4ecd + .long 0x576d3c83 + .long 0x55dd2a89 + .long 0x545d18e9 + .long 0x52dd06e9 + .long 0x516cf54e + .long 0x4ffce356 + .long 0x4e9cd1ce + .long 0x4d3cbfec + .long 0x4becae86 + .long 0x4aac9da4 + .long 0x496c8c73 + .long 0x483c7bd3 + .long 0x470c6ae8 + .long 0x45dc59af + .long 0x44bc4915 + .long 0x43ac3924 + .long 0x428c27fb + .long 0x418c187a + .long 0x407c07bd + +__divdf3_support: /* This label makes debugger output saner. */ + .balign 4 +.Ldenorm_dbl1: + brge r6, \ + 0x43500000,.Linf_NaN ; large number / denorm -> Inf + bmsk.f r12,DBL1H,19 + mov.eq r12,DBL1L + mov.eq DBL1L,0 + sub.eq r7,r7,32 + norm.f r11,r12 ; flag for x/0 -> Inf check + beq_s .Linf_NaN + mov.mi r11,0 + add.pl r11,r11,1 + add_s r12,r12,r12 + asl r8,r12,r11 + rsub r12,r11,31 + lsr r12,DBL1L,r12 + tst_s DBL1H,DBL1H + or r8,r8,r12 + lsr r4,r8,26 + lsr DBL1H,r8,12 + ld.as r4,[r10,r4] + bxor.mi DBL1H,DBL1H,31 + sub r11,r11,11 + asl DBL1L,DBL1L,r11 + sub r11,r11,1 + mulu64 r4,r8 + sub r7,r7,r11 + b.d .Lpast_denorm_dbl1 + asl r7,r7,20 + + .balign 4 +.Ldenorm_dbl0: + bmsk.f r12,DBL0H,19 + ; wb stall + mov.eq r12,DBL0L + sub.eq r6,r6,32 + norm.f r11,r12 ; flag for 0/x -> 0 check + brge r7, \ + 0x43500000, .Lret0_2 ; denorm/large number -> 0 + beq_s .Lret0_2 + mov.mi r11,0 + add.pl r11,r11,1 + asl r12,r12,r11 + sub r6,r6,r11 + add.f 0,r6,31 + lsr r10,DBL0L,r6 + mov.mi r10,0 + add r6,r6,11+32 + neg.f r11,r6 + asl DBL0L,DBL0L,r11 + mov.pl DBL0L,0 + sub r6,r6,32-1 + b.d .Lpast_denorm_dbl0 + asl r6,r6,20 + +.Linf_NaN: + tst_s DBL0L,DBL0L ; 0/0 -> NaN + xor_s DBL1H,DBL1H,DBL0H + bclr.eq.f DBL0H,DBL0H,31 + bmsk DBL0H,DBL1H,30 + xor_s DBL0H,DBL0H,DBL1H + sub.eq DBL0H,DBL0H,1 + mov_s DBL0L,0 + j_s.d [blink] + or DBL0H,DBL0H,r9 + .balign 4 +.Lret0_2: + xor_s DBL1H,DBL1H,DBL0H + mov_s DBL0L,0 + bmsk DBL0H,DBL1H,30 + j_s.d [blink] + xor_s DBL0H,DBL0H,DBL1H + .balign 4 + .global __divdf3 +/* N.B. the spacing between divtab and the sub3 to get its address must + be a multiple of 8. */ +__divdf3: + asl r8,DBL1H,12 + lsr r4,r8,26 + sub3 r10,pcl,61; (.-.Ldivtab) >> 3 + ld.as r9,[pcl,-124]; [pcl,(-((.-.L7ff00000) >> 2))] ; 0x7ff00000 + ld.as r4,[r10,r4] + lsr r12,DBL1L,20 + and.f r7,DBL1H,r9 + or r8,r8,r12 + mulu64 r4,r8 + beq.d .Ldenorm_dbl1 +.Lpast_denorm_dbl1: + and.f r6,DBL0H,r9 + breq.d r7,r9,.Linf_nan_dbl1 + asl r4,r4,12 + sub r4,r4,mhi + mulu64 r4,r4 + beq.d .Ldenorm_dbl0 + lsr r8,r8,1 + breq.d r6,r9,.Linf_nan_dbl0 + asl r12,DBL0H,11 + lsr r10,DBL0L,21 +.Lpast_denorm_dbl0: + bset r8,r8,31 + mulu64 mhi,r8 + add_s r12,r12,r10 + bset r5,r12,31 + cmp r5,r8 + cmp.eq DBL0L,DBL1L + lsr.cc r5,r5,1 + sub r4,r4,mhi ; u1.31 inverse, about 30 bit + mulu64 r5,r4 ; result fraction highpart + lsr r8,r8,2 ; u3.29 + add r5,r6, /* wait for immediate */ \ + 0x3fe00000 + mov r11,mhi ; result fraction highpart + mulu64 r11,r8 ; u-28.31 + asl_s DBL1L,DBL1L,9 ; u-29.23:9 + sbc r6,r5,r7 + mov r12,mlo ; u-28.31 + mulu64 r11,DBL1L ; mhi: u-28.23:9 + add.cs DBL0L,DBL0L,DBL0L + asl_s DBL0L,DBL0L,6 ; u-26.25:7 + asl r10,r11,23 + sub_l DBL0L,DBL0L,r12 + lsr r7,r11,9 + sub r5,DBL0L,mhi ; rest msw ; u-26.31:0 + mul64 r5,r4 ; mhi: result fraction lowpart + xor.f 0,DBL0H,DBL1H + and DBL0H,r6,r9 + add_s DBL0H,DBL0H,r7 + bclr r12,r9,20 ; 0x7fe00000 + brhs.d r6,r12,.Linf_denorm + bxor.mi DBL0H,DBL0H,31 + add.f r12,mhi,0x11 + asr r9,r12,5 + sub.mi DBL0H,DBL0H,1 + add.f DBL0L,r9,r10 + tst r12,0x1c + jne.d [blink] + add.cs DBL0H,DBL0H,1 + /* work out exact rounding if we fall through here. */ + /* We know that the exact result cannot be represented in double + precision. Find the mid-point between the two nearest + representable values, multiply with the divisor, and check if + the result is larger than the dividend. Since we want to know + only the sign bit, it is sufficient to calculate only the + highpart of the lower 64 bits. */ + mulu64 r11,DBL1L ; rest before considering r12 in r5 : -mlo + sub.f DBL0L,DBL0L,1 + asl r12,r9,2 ; u-22.30:2 + sub.cs DBL0H,DBL0H,1 + sub.f r12,r12,2 + mov r10,mlo ; rest before considering r12 in r5 : -r10 + mulu64 r12,DBL1L ; mhi: u-51.32 + asl r5,r5,25 ; s-51.7:25 + lsr r10,r10,7 ; u-51.30:2 + mov r7,mhi ; u-51.32 + mulu64 r12,r8 ; mlo: u-51.31:1 + sub r5,r5,r10 + add.mi r5,r5,DBL1L ; signed multiply adjust for r12*DBL1L + bset r7,r7,0 ; make sure that the result is not zero, and that + sub r5,r5,r7 ; a highpart zero appears negative + sub.f r5,r5,mlo ; rest msw + add.pl.f DBL0L,DBL0L,1 + j_s.d [blink] + add.eq DBL0H,DBL0H,1 + +.Linf_nan_dbl1: ; 0/Inf -> NaN Inf/Inf -> NaN x/Inf-> 0 x/NaN -> NaN + or.f 0,r6,DBL0L + cmp.ne r6,r9 + not_s DBL0L,DBL1H + sub_s.ne DBL0L,DBL0L,DBL0L + tst_s DBL0H,DBL0H + add_s DBL0H,DBL1H,DBL0L + j_s.d [blink] + bxor.mi DBL0H,DBL0H,31 +.Linf_nan_dbl0: + tst_s DBL1H,DBL1H + j_s.d [blink] + bxor.mi DBL0H,DBL0H,31 + .balign 4 +.Linf_denorm: + lsr r12,r6,28 + brlo.d r12,0xc,.Linf +.Ldenorm: + asr r6,r6,20 + neg r9,r6 + mov_s DBL0H,0 + brhs.d r9,54,.Lret0 + bxor.mi DBL0H,DBL0H,31 + add r12,mhi,1 + and r12,r12,-4 + rsub r7,r6,5 + asr r10,r12,28 + bmsk r4,r12,27 + min r7,r7,31 + asr DBL0L,r4,r7 + add DBL1H,r11,r10 + abs.f r10,r4 + sub.mi r10,r10,1 + add.f r7,r6,32-5 + asl r4,r4,r7 + mov.mi r4,r10 + add.f r10,r6,23 + rsub r7,r6,9 + lsr r7,DBL1H,r7 + asl r10,DBL1H,r10 + or.pnz DBL0H,DBL0H,r7 + or.mi r4,r4,r10 + mov.mi r10,r7 + add.f DBL0L,r10,DBL0L + add.cs.f DBL0H,DBL0H,1 ; carry clear after this point + bxor.f 0,r4,31 + add.pnz.f DBL0L,DBL0L,1 + add.cs.f DBL0H,DBL0H,1 + jne_s [blink] + /* Calculation so far was not conclusive; calculate further rest. */ + mulu64 r11,DBL1L ; rest before considering r12 in r5 : -mlo + asr.f r12,r12,3 + asl r5,r5,25 ; s-51.7:25 + mov r11,mlo ; rest before considering r12 in r5 : -r11 + mulu64 r12,r8 ; u-51.31:1 + and r9,DBL0L,1 ; tie-breaker: round to even + lsr r11,r11,7 ; u-51.30:2 + mov DBL1H,mlo ; u-51.31:1 + mulu64 r12,DBL1L ; u-51.62:2 + sub.mi r11,r11,DBL1L ; signed multiply adjust for r12*DBL1L + add_s DBL1H,DBL1H,r11 + sub DBL1H,DBL1H,r5 ; -rest msw + add_s DBL1H,DBL1H,mhi ; -rest msw + add.f 0,DBL1H,DBL1H ; can't ror.f by 32 :-( + tst_s DBL1H,DBL1H + cmp.eq mlo,r9 + add.cs.f DBL0L,DBL0L,1 + j_s.d [blink] + add.cs DBL0H,DBL0H,1 + +.Lret0: + /* return +- 0 */ + j_s.d [blink] + mov_s DBL0L,0 +.Linf: + mov_s DBL0H,r9 + mov_s DBL0L,0 + j_s.d [blink] + bxor.mi DBL0H,DBL0H,31 + ENDFUNC(__divdf3) diff --git a/arch/arc/lib/ieee-754/arc600-mul64/divsf3.S b/arch/arc/lib/ieee-754/arc600-mul64/divsf3.S new file mode 100644 index 000000000000..73e3e9e027b1 --- /dev/null +++ b/arch/arc/lib/ieee-754/arc600-mul64/divsf3.S @@ -0,0 +1,274 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* + - calculate 15..18 bit inverse using a table of approximating polynoms. + precision is higher for polynoms used to evaluate input with larger + value. + - do one newton-raphson iteration step to double the precision, + then multiply this with the divisor + -> more time to decide if dividend is subnormal + - the worst error propagation is on the side of the value range + with the least initial defect, thus giving us about 30 bits precision. + */ +#include "../arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __divsf3 + FUNC(__divsf3) + .balign 4 +__divsf3: + push_s blink + push_s r1 + bl.d __divsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __divsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 +#if 1 + bne abort + jeq_s [blink] + b abort +#else + bne abort + j_s [blink] +#endif + ENDFUNC(__divsf3) +#define __divsf3 __divsf3_asm +#endif /* DEBUG */ + + FUNC(__divsf3) + .balign 4 +.Ldivtab: + .long 0xfc0ffff0 + .long 0xf46ffefd + .long 0xed1ffd2a + .long 0xe627fa8e + .long 0xdf7ff73b + .long 0xd917f33b + .long 0xd2f7eea3 + .long 0xcd1fe986 + .long 0xc77fe3e7 + .long 0xc21fdddb + .long 0xbcefd760 + .long 0xb7f7d08c + .long 0xb32fc960 + .long 0xae97c1ea + .long 0xaa27ba26 + .long 0xa5e7b22e + .long 0xa1cfa9fe + .long 0x9ddfa1a0 + .long 0x9a0f990c + .long 0x9667905d + .long 0x92df878a + .long 0x8f6f7e84 + .long 0x8c27757e + .long 0x88f76c54 + .long 0x85df630c + .long 0x82e759c5 + .long 0x8007506d + .long 0x7d3f470a + .long 0x7a8f3da2 + .long 0x77ef341e + .long 0x756f2abe + .long 0x72f7212d + .long 0x709717ad + .long 0x6e4f0e44 + .long 0x6c1704d6 + .long 0x69e6fb44 + .long 0x67cef1d7 + .long 0x65c6e872 + .long 0x63cedf18 + .long 0x61e6d5cd + .long 0x6006cc6d + .long 0x5e36c323 + .long 0x5c76b9f3 + .long 0x5abeb0b7 + .long 0x5916a79b + .long 0x57769e77 + .long 0x55de954d + .long 0x54568c4e + .long 0x52d6834d + .long 0x51667a7f + .long 0x4ffe71b5 + .long 0x4e9e68f1 + .long 0x4d466035 + .long 0x4bf65784 + .long 0x4aae4ede + .long 0x496e4646 + .long 0x48363dbd + .long 0x47063547 + .long 0x45de2ce5 + .long 0x44be2498 + .long 0x43a61c64 + .long 0x4296144a + .long 0x41860c0e + .long 0x407e03ee +.L7f800000: + .long 0x7f800000 + .balign 4 + .global __divsf3_support +__divsf3_support: +.Linf_NaN: + bclr.f 0,r0,31 ; 0/0 -> NaN + xor_s r0,r0,r1 + bmsk r1,r0,30 + bic_s r0,r0,r1 + sub.eq r0,r0,1 + j_s.d [blink] + or r0,r0,r9 +.Lret0: + xor_s r0,r0,r1 + bmsk r1,r0,30 + j_s.d [blink] + bic_s r0,r0,r1 +/* N.B. the spacing between divtab and the sub3 to get its address must + be a multiple of 8. */ +__divsf3: + lsr r2,r1,17 + sub3 r3,pcl,37 ; (.-.Ldivtab) >> 3 + bmsk_s r2,r2,5 + ld.as r5,[r3,r2] + asl r4,r1,9 + ld.as r9,[pcl,-13]; [pcl,(-((.-.L7f800000) >> 2))] ; 0x7f800000 + mulu64 r5,r4 + and.f r11,r1,r9 + asl r6,r1,8 + bset r6,r6,31 + beq.d .Ldenorm_fp1 + asl r5,r5,13 + breq.d r11,r9,.Linf_nan_fp1 + and.f r2,r0,r9 + sub r7,r5,mhi + mulu64 r7,r6 + beq.d .Ldenorm_fp0 + asl r12,r0,8 + breq.d r2,r9,.Linf_nan_fp0 + mulu64 mhi,r7 +.Lpast_denorm_fp1: + bset r3,r12,31 +.Lpast_denorm_fp0: + cmp_s r3,r6 + lsr.cc r3,r3,1 + add_s r2,r2, /* wait for immediate */ \ + 0x3f000000 + sub r7,r7,mhi ; u1.31 inverse, about 30 bit + mulu64 r3,r7 + sbc r2,r2,r11 + xor.f 0,r0,r1 + and r0,r2,r9 + bclr r3,r9,23 ; 0x7f000000 + brhs.d r2,r3,.Linf_denorm + bxor.mi r0,r0,31 +.Lpast_denorm: + add r3,mhi,0x22 ; round to nearest or higher + tst r3,0x3c ; check if rounding was unsafe + lsr r3,r3,6 + jne.d [blink] ; return if rounding was safe. + add_s r0,r0,r3 + /* work out exact rounding if we fall through here. */ + /* We know that the exact result cannot be represented in single + precision. Find the mid-point between the two nearest + representable values, multiply with the divisor, and check if + the result is larger than the dividend. */ + add_s r3,r3,r3 + sub_s r3,r3,1 + mulu64 r3,r6 + asr.f 0,r0,1 ; for round-to-even in case this is a denorm + rsub r2,r9,25 + asl_s r12,r12,r2 + sub.f 0,r12,mlo + j_s.d [blink] + sub.mi r0,r0,1 +.Linf_nan_fp1: + lsr_s r0,r0,31 + bmsk.f 0,r1,22 + asl_s r0,r0,31 + bne_s 0f ; inf/inf -> nan + brne r2,r9,.Lsigned0 ; x/inf -> 0, but x/nan -> nan +0: j_s.d [blink] + mov r0,-1 +.Lsigned0: +.Linf_nan_fp0: + tst_s r1,r1 + j_s.d [blink] + bxor.mi r0,r0,31 + .balign 4 + .global __divsf3 +/* For denormal results, it is possible that an exact result needs + rounding, and thus the round-to-even rule has to come into play. */ +.Linf_denorm: + brlo r2,0xc0000000,.Linf +.Ldenorm: + asr_s r2,r2,23 + bic r0,r0,r9 + neg r9,r2 + brlo.d r9,25,.Lpast_denorm + lsr r3,mlo,r9 + /* Fall through: return +- 0 */ + j_s [blink] +.Linf: + j_s.d [blink] + or r0,r0,r9 + .balign 4 +.Ldenorm_fp1: + bclr r6,r6,31 + norm.f r12,r6 ; flag for x/0 -> Inf check + add r6,r6,r6 + rsub r5,r12,16 + ror r5,r1,r5 + asl r6,r6,r12 + bmsk r5,r5,5 + ld.as r5,[r3,r5] + add r4,r6,r6 + ; load latency + mulu64 r5,r4 + bic.ne.f 0, \ + 0x60000000,r0 ; large number / denorm -> Inf + asl r5,r5,13 + sub r7,r5,mhi + beq.d .Linf_NaN + mulu64 r7,r6 + asl_s r12,r12,23 + and.f r2,r0,r9 + add_s r2,r2,r12 + asl r12,r0,8 + bne.d .Lpast_denorm_fp1 +.Ldenorm_fp0: mulu64 mhi,r7 + bclr r12,r12,31 + norm.f r3,r12 ; flag for 0/x -> 0 check + bic.ne.f 0,0x60000000,r1 ; denorm/large number -> 0 + beq_s .Lret0 + asl_s r12,r12,r3 + asl_s r3,r3,23 + add_s r12,r12,r12 + add r11,r11,r3 + b.d .Lpast_denorm_fp0 + mov_s r3,r12 + ENDFUNC(__divsf3) diff --git a/arch/arc/lib/ieee-754/arc600-mul64/muldf3.S b/arch/arc/lib/ieee-754/arc600-mul64/muldf3.S new file mode 100644 index 000000000000..f7eb664764ef --- /dev/null +++ b/arch/arc/lib/ieee-754/arc600-mul64/muldf3.S @@ -0,0 +1,234 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "../arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __muldf3 + .balign 4 +__muldf3: + push_s blink + push_s r2 + push_s r3 + push_s r0 + bl.d __muldf3_c + push_s r1 + ld_s r2,[sp,12] + ld_s r3,[sp,8] + st_s r0,[sp,12] + st_s r1,[sp,8] + pop_s r1 + bl.d __muldf3_asm + pop_s r0 + pop_s r3 + pop_s r2 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + and r12,DBL0H,DBL1H + bic.f 0,0x7ff80000,r12 ; both NaN -> OK + jeq_s [blink] + b abort +#define __muldf3 __muldf3_asm +#endif /* DEBUG */ + +__muldf3_support: /* This label makes debugger output saner. */ + .balign 4 + FUNC(__muldf3) +.Ldenorm_2: + breq.d DBL1L,0,.Lret0_2 ; 0 input -> 0 output + norm.f r12,DBL1L + mov.mi r12,21 + add.pl r12,r12,22 + neg r11,r12 + asl_s r12,r12,20 + lsr.f DBL1H,DBL1L,r11 + ror DBL1L,DBL1L,r11 + sub_s DBL0H,DBL0H,r12 + mov.eq DBL1H,DBL1L + sub_l DBL1L,DBL1L,DBL1H + /* Fall through. */ + .global __muldf3 + .balign 4 +__muldf3: + mulu64 DBL0L,DBL1L + ld.as r9,[pcl,0x68] ; ((.L7ff00000-.+2)/4)] + bmsk r6,DBL0H,19 + bset r6,r6,20 + and r11,DBL0H,r9 + breq.d r11,0,.Ldenorm_dbl0 + and r12,DBL1H,r9 + breq.d r12,0,.Ldenorm_dbl1 + mov r8,mlo + mov r4,mhi + mulu64 r6,DBL1L + breq.d r11,r9,.Linf_nan + bmsk r10,DBL1H,19 + breq.d r12,r9,.Linf_nan + bset r10,r10,20 + add.f r4,r4,mlo + adc r5,mhi,0 + mulu64 r10,DBL0L + add_s r12,r12,r11 ; add exponents + add.f r4,r4,mlo + adc r5,r5,mhi + mulu64 r6,r10 + tst r8,r8 + bclr r8,r9,30 ; 0x3ff00000 + bset.ne r4,r4,0 ; put least significant word into sticky bit + bclr r6,r9,20 ; 0x7fe00000 + add.f r5,r5,mlo + adc r7,mhi,0 ; fraction product in r7:r5:r4 + lsr.f r10,r7,9 + rsub.eq r8,r8,r9 ; 0x40000000 + sub r12,r12,r8 ; subtract bias + implicit 1 + brhs.d r12,r6,.Linf_denorm + rsub r10,r10,12 +.Lshift_frac: + neg r8,r10 + asl r6,r4,r10 + lsr DBL0L,r4,r8 + add.f 0,r6,r6 + btst.eq DBL0L,0 + cmp.eq r4,r4 ; round to nearest / round to even + asl r4,r5,r10 + lsr r5,r5,r8 + adc.f DBL0L,DBL0L,r4 + xor.f 0,DBL0H,DBL1H + asl r7,r7,r10 + add_s r12,r12,r5 + adc DBL0H,r12,r7 + j_s.d [blink] + bset.mi DBL0H,DBL0H,31 + +/* N.B. This is optimized for ARC700. + ARC600 has very different scheduling / instruction selection criteria. */ + +/* If one number is denormal, subtract some from the exponent of the other + one (if the other exponent is too small, return 0), and normalize the + denormal. Then re-run the computation. */ +.Lret0_2: + lsr_s DBL0H,DBL0H,31 + asl_s DBL0H,DBL0H,31 + j_s.d [blink] + mov_s DBL0L,0 + .balign 4 +.Ldenorm_dbl0: + mov_s r12,DBL0L + mov_s DBL0L,DBL1L + mov_s DBL1L,r12 + mov_s r12,DBL0H + mov_s DBL0H,DBL1H + mov_s DBL1H,r12 + and r11,DBL0H,r9 +.Ldenorm_dbl1: + brhs r11,r9,.Linf_nan + brhs 0x3ca00001,r11,.Lret0 + sub_s DBL0H,DBL0H,DBL1H + bmsk.f DBL1H,DBL1H,30 + add_s DBL0H,DBL0H,DBL1H + beq.d .Ldenorm_2 + norm r12,DBL1H + sub_s r12,r12,10 + asl r5,r12,20 + asl_s DBL1H,DBL1H,r12 + sub DBL0H,DBL0H,r5 + neg r5,r12 + lsr r6,DBL1L,r5 + asl_s DBL1L,DBL1L,r12 + b.d __muldf3 + add_s DBL1H,DBL1H,r6 + +.Lret0: xor_s DBL0H,DBL0H,DBL1H + bclr DBL1H,DBL0H,31 + xor_s DBL0H,DBL0H,DBL1H + j_s.d [blink] + mov_s DBL0L,0 + + .balign 4 +.Linf_nan: + bclr r12,DBL1H,31 + xor_s DBL1H,DBL1H,DBL0H + bclr_s DBL0H,DBL0H,31 + max r8,DBL0H,r12 ; either NaN -> NaN ; otherwise inf + or.f 0,DBL0H,DBL0L + mov_s DBL0L,0 + or.ne.f DBL1L,DBL1L,r12 + not_s DBL0H,DBL0L ; inf * 0 -> NaN + mov.ne DBL0H,r8 + tst_s DBL1H,DBL1H + j_s.d [blink] + bset.mi DBL0H,DBL0H,31 + +/* We have checked for infinity / NaN input before, and transformed + denormalized inputs into normalized inputs. Thus, the worst case + exponent overflows are: + 1 + 1 - 0x400 == 0xc02 : maximum underflow + 0x7fe + 0x7fe - 0x3ff == 0xbfd ; maximum overflow + N.B. 0x7e and 0x7f are also values for overflow. + + If (r12 <= -54), we have an underflow to zero. */ + .balign 4 +.Linf_denorm: + lsr r6,r12,28 + brlo.d r6,0xc,.Linf + asr r6,r12,20 + add.f r10,r10,r6 + brgt.d r10,0,.Lshift_frac + mov_s r12,0 + beq.d .Lround_frac + add r10,r10,32 +.Lshift32_frac: + tst r4,r4 + mov r4,r5 + bset.ne r4,r4,1 + mov r5,r7 + brge.d r10,1,.Lshift_frac + mov r7,0 + breq.d r10,0,.Lround_frac + add r10,r10,32 + brgt r10,21,.Lshift32_frac + b_s .Lret0 + +.Lround_frac: + add.f 0,r4,r4 + btst.eq r5,0 + mov_s DBL0L,r5 + mov_s DBL0H,r7 + adc.eq.f DBL0L,DBL0L,0 + j_s.d [blink] + adc.eq DBL0H,DBL0H,0 + +.Linf: mov_s DBL0L,0 + xor.f DBL1H,DBL1H,DBL0H + mov_s DBL0H,r9 + j_s.d [blink] + bset.mi DBL0H,DBL0H,31 + ENDFUNC(__muldf3) + + .balign 4 +.L7ff00000: + .long 0x7ff00000 diff --git a/arch/arc/lib/ieee-754/arc600-mul64/mulsf3.S b/arch/arc/lib/ieee-754/arc600-mul64/mulsf3.S new file mode 100644 index 000000000000..a9a9fa70fead --- /dev/null +++ b/arch/arc/lib/ieee-754/arc600-mul64/mulsf3.S @@ -0,0 +1,180 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "../arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __mulsf3 + FUNC(__mulsf3) + .balign 4 +__mulsf3: + push_s blink + push_s r1 + bl.d __mulsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __mulsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + and r12,r0,r1 + bic.f 0,0x7f800000,r12 + bne 0f + bmsk.f 0,r0,22 + bmsk.ne.f r1,r1,22 + jne_s [blink] ; both NaN -> OK +0: bl abort + ENDFUNC(__mulsf3) +#define __mulsf3 __mulsf3_asm +#endif /* DEBUG */ + + .balign 4 + .global __mulsf3 + FUNC(__mulsf3) +__mulsf3: + ld.as r9,[pcl,80]; [pcl,((.L7f800000-.+2)/4)] + bmsk r4,r1,22 + bset r2,r0,23 + asl_s r2,r2,8 + bset r3,r4,23 + mulu64 r2,r3 + and r11,r0,r9 + breq.d r11,0,.Ldenorm_dbl0 + and r12,r1,r9 + breq.d r12,0,.Ldenorm_dbl1 + xor_s r0,r0,r1 + breq.d r11,r9,.Linf_nan_dbl0 + ld.as r4,[pcl,70]; [pcl,((.L7fffffff-.+2)/4)] + breq.d r12,r9,.Linf_nan_dbl1 +.Lpast_denorm: + asl.f 0,mhi,8 + mov r6,mhi + mov r7,mlo + add.pl r6,r6,r6 + bclr.pl r6,r6,23 + add.pl.f r7,r7,r7 + add.cs r6,r6,1 + lsr.f 0,r6,1 + add_s r12,r12,r11 + adc.f 0,r7,r4 + add_s r12,r12, \ + -0x3f800000 + adc.f r8,r6,r12 + tst.pl r8,r9 + bic r0,r0,r4 + min r3,r8,r9 + jpnz.d [blink] + add.pnz r0,r0,r3 +; infinity or denormal number + add.ne.f r3,r3,r3 + asr_s r3,r3,23+1 + bset r6,r6,23 + bpnz.d .Linfinity + sub_s r3,r3,1 + neg_s r2,r3 + brhi.d r2,24,.Lret_r0 ; right shift shift > 24 -> return +-0 + lsr r2,r6,r2 + asl r9,r6,r3 + lsr.f 0,r2,1 + tst r7,r7 + add_s r0,r0,r2 + bset.ne r9,r9,0 + adc.f 0,r9,r4 + j_s.d [blink] + add.cs r0,r0,1 +.Linfinity: + j_s.d [blink] + add_s r0,r0,r9 + +.Lret_r0: j_s [blink] + + .balign 4 +.Ldenorm_dbl0: + bclr_s r2,r2,31 + norm.f r4,r2 + add_s r2,r2,r2 + asl r2,r2,r4 + mulu64 r2,r3 + breq.d r12,r9,.Ldenorm_dbl0_inf_nan_dbl1 + asl r4,r4,23 + sub.ne.f r12,r12,r4 + ld.as r4,[pcl,29]; [pcl,((.L7fffffff-.+2)/4)] + bhi.d .Lpast_denorm + xor_s r0,r0,r1 + bmsk r1,r0,30 + j_s.d [blink] + bic_s r0,r0,r1 + + .balign 4 +.Ldenorm_dbl0_inf_nan_dbl1: + bmsk.f 0,r0,30 + beq_s .Lretnan + xor_s r0,r0,r1 +.Linf_nan_dbl1: + xor_s r1,r1,r0 +.Linf_nan_dbl0: + bclr_s r1,r1,31 + cmp_s r1,r9 + jls.d [blink] + xor_s r0,r0,r1 +; r1 NaN -> result NaN +.Lretnan: + j_s.d [blink] + mov r0,-1 + + .balign 4 +.Ldenorm_dbl1: + breq.d r11,r9,.Linf_nan_dbl0_2 + norm.f r3,r4 + sub_s r3,r3,7 + asl r4,r4,r3 + mulu64 r2,r4 + sub_s r3,r3,1 + asl_s r3,r3,23 + sub.ne.f r11,r11,r3 + ld.as r4,[pcl,11]; [pcl,((.L7fffffff-.+2)/4)] + bhi.d .Lpast_denorm + bmsk r8,r0,30 + j_s.d [blink] + bic r0,r0,r8 + + .balign 4 +.Linf_nan_dbl0_2: + bclr_s r1,r1,31 + xor_s r0,r0,r1 + sub.eq r1,r1,1 ; inf/nan * 0 -> nan + bic.f 0,r9,r1 + j_s.d [blink] + or.eq r0,r0,r1 ; r1 nan -> result nan + + .balign 4 +.L7f800000: + .long 0x7f800000 +.L7fffffff: + .long 0x7fffffff + ENDFUNC(__mulsf3) diff --git a/arch/arc/lib/ieee-754/arc600/divsf3.S b/arch/arc/lib/ieee-754/arc600/divsf3.S new file mode 100644 index 000000000000..8a868af883ef --- /dev/null +++ b/arch/arc/lib/ieee-754/arc600/divsf3.S @@ -0,0 +1,227 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "../arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __divsf3 + FUNC(__divsf3) + .balign 4 +__divsf3: + push_s blink + push_s r1 + bl.d __divsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __divsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + and r12,r0,r1 + bic.f 0,0x7f800000,r12 ; both NaN -> OK + jeq_s [blink] + bl abort + ENDFUNC(__divsf3) +#define __divsf3 __divsf3_asm +#endif /* DEBUG */ + + .balign 4 +__divdf3_support: /* This label makes debugger output saner. */ + FUNC(__divsf3) +.Ldenorm_fp0: + norm.f r12,r2 ; flag for 0/x -> 0 check + bic.ne.f 0,0x60000000,r1 ; denorm/large number -> 0 + beq_s .Lret0_NaN + tst r1,r9 + add_s r2,r2,r2 + sub_s r12,r12,8 + asl_s r2,r2,r12 + asl_l r12,r12,23 + bne.d .Lpast_denorm_fp0 + add r5,r5,r12 +/* r0 is subnormal, r1 is subnormal or 0. */ + + .balign 4 +.Ldenorm_fp1: + norm.f r12,r3 ; flag for x/0 -> Inf check + bic.ne.f 0,0x60000000,r0 ; large number/denorm -> Inf + beq_s .Linf + add_s r3,r3,r3 + sub_s r12,r12,8 + asl_s r3,r3,r12 + asl_s r12,r12,23 + b.d .Lpast_denorm_fp1 + add r4,r4,r12 + +.Lret0_NaN: + bclr.f 0,r1,31 ; 0/0 -> NaN + bic r0,r10,r9 + j_s.d [blink] + sub.eq r0,r0,1 + + .balign 4 +.Linf_nan_fp0: + bic.f 0,r9,r1 ; fp1 Inf -> result NaN + bic r1,r5,r9 ; fp1 sign + sub.eq r1,r1,1 + j_s.d [blink] + xor_s r0,r0,r1 +.Linf_nan_fp1: + bic r0,r4,r9 ; fp0 sign + bmsk.f 0,r1,22 ; x/inf -> 0, x/nan -> nan + xor.eq r1,r1,r9 + j_s.d [blink] + xor_s r0,r0,r1 + + .global __divsf3 + .balign 4 + .long 0x7f800000 ; exponent mask +__divsf3: + ld r9,[pcl,-4] + bmsk r2,r0,22 + xor r4,r0,r2 + bmsk r3,r1,22 + xor r5,r1,r3 + and r11,r0,r9 + breq.d r11,0,.Ldenorm_fp0 + xor r10,r4,r5 + breq r11,r9,.Linf_nan_fp0 + bset_s r2,r2,23 + and r11,r1,r9 + breq r11,0,.Ldenorm_fp1 + breq r11,r9,.Linf_nan_fp1 +.Lpast_denorm_fp0: + bset_s r3,r3,23 +.Lpast_denorm_fp1: + cmp r2,r3 + asl_s r2,r2,6+1 + asl_s r3,r3,7 + add.lo r2,r2,r2 + bclr r8,r9,30 ; exponent bias + bclr.lo r8,r8,23 ; reduce exp by one if fraction is shifted + sub r4,r4,r5 + add r4,r4,r8 + xor.f 0,r10,r4 + bmi .Linf_denorm + and.f r12,r4,r9 + beq .Ldenorm + sub_s r2,r2,r3 ; discard implicit 1 + rsub r3,r3,1 ; prime r3 for two-insn divide-step use +.Ldiv_23bit: + .rep 6 + add1.f r2,r3,r2 + sub.cc r2,r2,r3 + .endr + breq r12,r9,.Linf + bmsk r0,r2,6 + xor_s r2,r2,r0 +.Ldiv_17bit: + .rep 7 + add1.f r2,r3,r2 + sub.cc r2,r2,r3 + .endr + asl_s r0,r0,7 + bmsk r1,r2,6 + xor_s r2,r2,r1 + or_s r0,r0,r1 +.Ldiv_10bit: + .rep 7 + add1.f r2,r3,r2 + sub.cc r2,r2,r3 + .endr + asl_s r0,r0,7 + bmsk r1,r2,6 + xor_s r2,r2,r1 + or_s r0,r0,r1 +.Ldiv_3bit: + .rep 3 + add1.f r2,r3,r2 + sub.cc r2,r2,r3 + .endr + asl_s r0,r0,3 +.Ldiv_0bit: + add1.f r1,r3,r2 + sub.cc r1,r1,r3 + bmsk_s r2,r2,2 + tst r1,-0x7e ; 0xffffff82, test for rest or odd + bmsk_s r1,r1,0 + add_s r0,r0,r2 ; assemble fraction + add_s r0,r0,r4 ; add in sign & exponent + j_s.d [blink] + add.ne r0,r0,r1 ; round to nearest / even + + .balign 4 +.Linf: + j_s.d [blink] + or r0,r10,r9 + +.Lret_r4: + j_s.d [blink] + mov_s r0,r4 + .balign 4 +.Linf_denorm: + add.f r12,r4,r4 + asr_l r12,r12,24 + bpl .Linf + max r12,r12,-24 +.Ldenorm: + rsub r3,r3,1 + add r1,pcl,68; .Ldenorm_tab-. + ldw.as r12,[r1,r12] + mov_s r0,0 + lsr_s r2,r2 + sub_s r1,r1,r12 + j_s.d [r1] + bic r4,r10,r9 + .short .Ldenorm_tab-.Lret_r4 + .short .Ldenorm_tab-.Ldiv_0bit + .short .Ldenorm_tab-.Ldiv_3bit-2*8 + .short .Ldenorm_tab-.Ldiv_3bit-1*8 + .short .Ldenorm_tab-.Ldiv_3bit + .short .Ldenorm_tab-.Ldiv_10bit-6*8 + .short .Ldenorm_tab-.Ldiv_10bit-5*8 + .short .Ldenorm_tab-.Ldiv_10bit-3*8 + .short .Ldenorm_tab-.Ldiv_10bit-3*8 + .short .Ldenorm_tab-.Ldiv_10bit-2*8 + .short .Ldenorm_tab-.Ldiv_10bit-1*8 + .short .Ldenorm_tab-.Ldiv_10bit + .short .Ldenorm_tab-.Ldiv_17bit-6*8 + .short .Ldenorm_tab-.Ldiv_17bit-5*8 + .short .Ldenorm_tab-.Ldiv_17bit-4*8 + .short .Ldenorm_tab-.Ldiv_17bit-3*8 + .short .Ldenorm_tab-.Ldiv_17bit-2*8 + .short .Ldenorm_tab-.Ldiv_17bit-1*8 + .short .Ldenorm_tab-.Ldiv_17bit + .short .Ldenorm_tab-.Ldiv_23bit-5*8 + .short .Ldenorm_tab-.Ldiv_23bit-4*8 + .short .Ldenorm_tab-.Ldiv_23bit-3*8 + .short .Ldenorm_tab-.Ldiv_23bit-2*8 + .short .Ldenorm_tab-.Ldiv_23bit-1*8 +.Ldenorm_tab: + .short .Ldenorm_tab-.Ldiv_23bit + ENDFUNC(__divsf3) diff --git a/arch/arc/lib/ieee-754/arc600/mulsf3.S b/arch/arc/lib/ieee-754/arc600/mulsf3.S new file mode 100644 index 000000000000..344f489298da --- /dev/null +++ b/arch/arc/lib/ieee-754/arc600/mulsf3.S @@ -0,0 +1,179 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "../arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __mulsf3 + FUNC(__mulsf3) + .balign 4 +__mulsf3: + push_s blink + push_s r1 + bl.d __mulsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __mulsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + and r12,r0,r1 + bic.f 0,0x7f800000,r12 + bne 0f + bmsk.f 0,r0,22 + bmsk.ne.f r1,r1,22 + jne_s [blink] ; both NaN -> OK +0: bl abort + ENDFUNC(__mulsf3) +#define __mulsf3 __mulsf3_asm +#endif /* DEBUG */ + + .balign 4 + .global __mulsf3 + FUNC(__mulsf3) +__mulsf3: + ld.as r9,[pcl,76]; [pcl,((.L7f800000-.+2)/4)] + bmsk r4,r1,22 + bset r3,r4,23 + bmsk r2,r0,22 + and r11,r0,r9 + breq.d r11,0,.Ldenorm_dbl0 + and r12,r1,r9 + xor_s r0,r0,r1 + breq.d r11,r9,.Linf_nan_dbl0 + bset_s r2,r2,23 + breq r12,0,.Ldenorm_dbl1 + breq r12,r9,.Linf_nan_dbl1 +.Lpast_denorm: + mov r6,0 + lsr.f r7,r2 +; We could so this a bit faster here with a 32 bit shift register and +; inserting the r2 factor / retrieving the low result a byte at a time, +; but that'd increase code size. + mov lp_count,24 + .balign 4 + lp 0f + add.cs r6,r6,r3 + lsr.f r6,r6 + rrc.f r7,r7 +0: + ld.as r4,[pcl,59]; [pcl,((.L7fffffff-.+2)/4)] + asl.f 0,r6,8 + add.pl r6,r6,r6 + bclr.pl r6,r6,23 + add.pl.f r7,r7,r7 + add.cs r6,r6,1 + lsr.f 0,r6,1 + add_s r12,r12,r11 + adc.f 0,r7,r4 + add_s r12,r12, \ + -0x3f800000 + adc.f r8,r6,r12 + tst.pl r8,r9 + bic r0,r0,r4 + min r3,r8,r9 + jpnz.d [blink] + add.pnz r0,r0,r3 +; infinity or denormal number + add.ne.f r3,r3,r3 + asr_s r3,r3,23+1 + bset r6,r6,23 + bpnz.d .Linfinity + sub_s r3,r3,1 + neg_s r2,r3 + brhi.d r2,24,.Lret_r0 ; right shift shift > 24 -> return +-0 + lsr r2,r6,r2 + asl r9,r6,r3 + lsr.f 0,r2,1 + tst r7,r7 + add_s r0,r0,r2 + bset.ne r9,r9,0 + adc.f 0,r9,r4 + j_s.d [blink] + add.cs r0,r0,1 +.Linfinity: + j_s.d [blink] + add_s r0,r0,r9 + +.Lret_r0: j_s [blink] + + .balign 4 +.Ldenorm_dbl0: + asl_s r2,r2,8 + norm.f r4,r2 + lsr_s r2,r2,7 + asl r2,r2,r4 + breq.d r12,r9,.Ldenorm_dbl0_inf_nan_dbl1 + asl r4,r4,23 + sub.ne.f r12,r12,r4 + bhi.d .Lpast_denorm + xor_s r0,r0,r1 + bmsk r1,r0,30 + j_s.d [blink] + bic_s r0,r0,r1 + + .balign 4 +.Ldenorm_dbl0_inf_nan_dbl1: + bmsk.f 0,r0,30 + beq_s .Lretnan + xor_s r0,r0,r1 +.Linf_nan_dbl1: + xor_s r1,r1,r0 + bclr_s r1,r1,31 + j_s.d [blink] + xor_s r0,r0,r1 +.Linf_nan_dbl0: + sub_s r2,r1,1 ; inf/nan * 0 -> nan; inf * nan -> nan (use |r2| >= inf) + bic.f 0,r9,r2 + xor_s r0,r0,r1 + bclr_s r1,r1,31 + xor_s r0,r0,r1 + jne_s [blink] +.Lretnan: + j_s.d [blink] + mov r0,-1 + .balign 4 +.Ldenorm_dbl1: + norm.f r3,r4 + sub_s r3,r3,7 + asl r4,r4,r3 + sub_s r3,r3,1 + asl_s r3,r3,23 + sub.ne.f r11,r11,r3 + bhi.d .Lpast_denorm + mov_s r3,r4 + bmsk r3,r0,30 + j_s.d [blink] + bic_s r0,r0,r3 + + .balign 4 +.L7f800000: + .long 0x7f800000 +.L7fffffff: + .long 0x7fffffff + ENDFUNC(__mulsf3) diff --git a/arch/arc/lib/ieee-754/divdf3.S b/arch/arc/lib/ieee-754/divdf3.S new file mode 100644 index 000000000000..c2f2252d9f4f --- /dev/null +++ b/arch/arc/lib/ieee-754/divdf3.S @@ -0,0 +1,435 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* + to calculate a := b/x as b*y, with y := 1/x: + - x is in the range [1..2) + - calculate 15..18 bit inverse y0 using a table of approximating polynoms. + Precision is higher for polynoms used to evaluate input with larger + value. + - Do one newton-raphson iteration step to double the precision, + then multiply this with the divisor + -> more time to decide if dividend is subnormal + - the worst error propagation is on the side of the value range + with the least initial defect, thus giving us about 30 bits precision. + The truncation error for the either is less than 1 + x/2 ulp. + A 31 bit inverse can be simply calculated by using x with implicit 1 + and chaining the multiplies. For a 32 bit inverse, we multiply y0^2 + with the bare fraction part of x, then add in y0^2 for the implicit + 1 of x. + - If calculating a 31 bit inverse, the systematic error is less than + -1 ulp; likewise, for 32 bit, it is less than -2 ulp. + - If we calculate our seed with a 32 bit fraction, we can archive a + tentative result strictly better than -2 / +2.5 (1) ulp/128, i.e. we + only need to take the step to calculate the 2nd stage rest and + rounding adjust 1/32th of the time. However, if we use a 20 bit + fraction for the seed, the negative error can exceed -2 ulp/128, (2) + thus for a simple add / tst check, we need to do the 2nd stage + rest calculation/ rounding adjust 1/16th of the time. + (1): The inexactness of the 32 bit inverse contributes an error in the + range of (-1 .. +(1+x/2) ) ulp/128. Leaving out the low word of the + rest contributes an error < +1/x ulp/128 . In the interval [1,2), + x/2 + 1/x <= 1.5 . + (2): Unless proven otherwise. I have not actually looked for an + example where -2 ulp/128 is exceeded, and my calculations indicate + that the excess, if existent, is less than -1/512 ulp. + */ +#include "arc-ieee-754.h" + +/* N.B. fp-bit.c does double rounding on denormal numbers. */ +#if 0 /* DEBUG */ + .global __divdf3 + FUNC(__divdf3) + .balign 4 +__divdf3: + push_s blink + push_s r2 + push_s r3 + push_s r0 + bl.d __divdf3_c + push_s r1 + ld_s r2,[sp,12] + ld_s r3,[sp,8] + st_s r0,[sp,12] + st_s r1,[sp,8] + pop_s r1 + bl.d __divdf3_asm + pop_s r0 + pop_s r3 + pop_s r2 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + and r12,DBL0H,DBL1H + bic.f 0,0x7ff80000,r12 ; both NaN -> OK + jeq_s [blink] + bl abort + ENDFUNC(__divdf3) +#define __divdf3 __divdf3_asm +#endif /* DEBUG */ + + FUNC(__divdf3) +__divdf3_support: /* This label makes debugger output saner. */ + .balign 4 +.Ldenorm_dbl1: + brge r6, \ + 0x43500000,.Linf_NaN ; large number / denorm -> Inf + bmsk.f r12,DBL1H,19 + mov.eq r12,DBL1L + mov.eq DBL1L,0 + sub.eq r7,r7,32 + norm.f r11,r12 ; flag for x/0 -> Inf check + beq_s .Linf_NaN + mov.mi r11,0 + add.pl r11,r11,1 + add_s r12,r12,r12 + asl r8,r12,r11 + rsub r12,r11,31 + lsr r12,DBL1L,r12 + tst_s DBL1H,DBL1H + or r8,r8,r12 + lsr r4,r8,26 + lsr DBL1H,r8,12 + ld.as r4,[r10,r4] + bxor.mi DBL1H,DBL1H,31 + sub r11,r11,11 + asl DBL1L,DBL1L,r11 + sub r11,r11,1 + MPYHU r5,r4,r8 + sub r7,r7,r11 + asl r4,r4,12 + b.d .Lpast_denorm_dbl1 + asl r7,r7,20 + ; wb stall + + .balign 4 +.Ldenorm_dbl0: + bmsk.f r12,DBL0H,19 + ; wb stall + mov.eq r12,DBL0L + sub.eq r6,r6,32 + norm.f r11,r12 ; flag for 0/x -> 0 check + brge r7, \ + 0x43500000, .Lret0_NaN ; denorm/large number -> 0 + beq_s .Lret0_NaN + mov.mi r11,0 + add.pl r11,r11,1 + asl r12,r12,r11 + sub r6,r6,r11 + add.f 0,r6,31 + lsr r10,DBL0L,r6 + mov.mi r10,0 + add r6,r6,11+32 + neg.f r11,r6 + asl DBL0L,DBL0L,r11 + mov.pl DBL0L,0 + sub r6,r6,32-1 + b.d .Lpast_denorm_dbl0 + asl r6,r6,20 + +.Linf_NaN: + tst_s DBL0L,DBL0L ; 0/0 -> NaN + xor_s DBL1H,DBL1H,DBL0H + bclr.eq.f DBL0H,DBL0H,31 + bmsk DBL0H,DBL1H,30 + xor_s DBL0H,DBL0H,DBL1H + sub.eq DBL0H,DBL0H,1 + mov_s DBL0L,0 + j_s.d [blink] + or DBL0H,DBL0H,r9 + .balign 4 +.Lret0_NaN: + xor_s DBL1H,DBL1H,DBL0H + cmp_s r12,r9 + mov_s DBL0L,0 + bmsk DBL0H,DBL1H,30 + xor_s DBL0H,DBL0H,DBL1H + j_s.d [blink] + sub.hi DBL0H,DBL0H,1 +.Linf_nan_dbl1: ; Inf/Inf -> NaN x/Inf-> 0 x/NaN -> NaN + not_s DBL0L,DBL1H + cmp r6,r9 + sub_s.ne DBL0L,DBL0L,DBL0L + tst_s DBL0H,DBL0H + add_s DBL0H,DBL1H,DBL0L + j_s.d [blink] + bxor.mi DBL0H,DBL0H,31 +.Linf_nan_dbl0: + tst_s DBL1H,DBL1H + j_s.d [blink] + bxor.mi DBL0H,DBL0H,31 + .balign 4 + .global __divdf3 +/* N.B. the spacing between divtab and the add3 to get its address must + be a multiple of 8. */ +__divdf3: + asl r8,DBL1H,12 + lsr r12,DBL1L,20 + lsr r4,r8,26 +#if defined (__ARCHS__) || defined (__ARCEM__) + add3 r10,pcl,60 ; (.Ldivtab-.) >> 3 +#else + add3 r10,pcl,59 ; (.Ldivtab-.) >> 3 +#endif + ld.as r4,[r10,r4] +#if defined (__ARCHS__) || defined (__ARCEM__) + ld.as r9,[pcl,182]; [pcl,(-((.-.L7ff00000) >> 2))] ; 0x7ff00000 +#else + ld.as r9,[pcl,180]; [pcl,(-((.-.L7ff00000) >> 2))] ; 0x7ff00000 +#endif + or r8,r8,r12 + MPYHU r5,r4,r8 + and.f r7,DBL1H,r9 + asl r4,r4,12 ; having the asl here is a concession to the XMAC pipeline. + beq.d .Ldenorm_dbl1 + and r6,DBL0H,r9 +.Lpast_denorm_dbl1: ; wb stall + sub r4,r4,r5 + MPYHU r5,r4,r4 + breq.d r6,0,.Ldenorm_dbl0 + lsr r8,r8,1 + asl r12,DBL0H,11 + lsr r10,DBL0L,21 +.Lpast_denorm_dbl0: ; wb stall + bset r8,r8,31 + MPYHU r11,r5,r8 + add_s r12,r12,r10 + bset r5,r12,31 + cmp r5,r8 + cmp.eq DBL0L,DBL1L + ; wb stall + lsr.cc r5,r5,1 + sub r4,r4,r11 ; u1.31 inverse, about 30 bit + MPYHU r11,r5,r4 ; result fraction highpart + breq r7,r9,.Linf_nan_dbl1 + lsr r8,r8,2 ; u3.29 + add r5,r6, /* wait for immediate / XMAC wb stall */ \ + 0x3fe00000 + ; wb stall (not for XMAC) + breq r6,r9,.Linf_nan_dbl0 + mpyu r12,r11,r8 ; u-28.31 + asl_s DBL1L,DBL1L,9 ; u-29.23:9 + sbc r6,r5,r7 + ; resource conflict (not for XMAC) + MPYHU r5,r11,DBL1L ; u-28.23:9 + add.cs DBL0L,DBL0L,DBL0L + asl_s DBL0L,DBL0L,6 ; u-26.25:7 + asl r10,r11,23 + sub_l DBL0L,DBL0L,r12 + ; wb stall (before 'and' for XMAC) + lsr r7,r11,9 + sub r5,DBL0L,r5 ; rest msw ; u-26.31:0 + MPYH r12,r5,r4 ; result fraction lowpart + xor.f 0,DBL0H,DBL1H + and DBL0H,r6,r9 + add_s DBL0H,DBL0H,r7 ; (XMAC wb stall) + bxor.mi DBL0H,DBL0H,31 + brhs r6, /* wb stall / wait for immediate */ \ + 0x7fe00000,.Linf_denorm + add.f r12,r12,0x11 + asr r9,r12,5 + sub.mi DBL0H,DBL0H,1 + add.f DBL0L,r9,r10 + tst r12,0x1c + jne.d [blink] + add.cs DBL0H,DBL0H,1 + /* work out exact rounding if we fall through here. */ + /* We know that the exact result cannot be represented in double + precision. Find the mid-point between the two nearest + representable values, multiply with the divisor, and check if + the result is larger than the dividend. Since we want to know + only the sign bit, it is sufficient to calculate only the + highpart of the lower 64 bits. */ + sub.f DBL0L,DBL0L,1 + asl r12,r9,2 ; u-22.30:2 + mpyu r10,r11,DBL1L ; rest before considering r12 in r5 : -r10 + sub.cs DBL0H,DBL0H,1 + sub.f r12,r12,2 + ; resource conflict (not for XMAC) + MPYHU r7,r12,DBL1L ; u-51.32 + asl r5,r5,25 ; s-51.7:25 + lsr r10,r10,7 ; u-51.30:2 + ; resource conflict (not for XMAC) + ; resource conflict (not for XMAC) + mpyu r9,r12,r8 ; u-51.31:1 + sub r5,r5,r10 + add.mi r5,r5,DBL1L ; signed multiply adjust for r12*DBL1L + bset r7,r7,0 ; make sure that the result is not zero, and that + ; wb stall (one earlier for XMAC) + sub r5,r5,r7 ; a highpart zero appears negative + sub.f r5,r5,r9 ; rest msw + add.pl.f DBL0L,DBL0L,1 + j_s.d [blink] + add.eq DBL0H,DBL0H,1 + + .balign 4 +.Linf_denorm: + brlo r6,0xc0000000,.Linf +.Ldenorm: + asr r6,r6,20 + neg r9,r6 + mov_s DBL0H,0 + brhs.d r9,54,.Lret0 + bxor.mi DBL0H,DBL0H,31 + add_l r12,r12,1 + and r12,r12,-4 + rsub r7,r6,5 + asr r10,r12,28 + bmsk r4,r12,27 +#if defined (__ARCHS__) || defined (__ARCEM__) + min r7, r7, 31 + asr DBL0L, r4, r7 +#else + asrs DBL0L,r4,r7 +#endif + add DBL1H,r11,r10 +#if defined (__ARCHS__) || defined (__ARCEM__) + abs.f r10, r4 + sub.mi r10, r10, 1 +#endif + add.f r7,r6,32-5 +#ifdef __ARC700__ + abss r10,r4 +#endif + asl r4,r4,r7 + mov.mi r4,r10 + add.f r10,r6,23 + rsub r7,r6,9 + lsr r7,DBL1H,r7 + asl r10,DBL1H,r10 + or.pnz DBL0H,DBL0H,r7 + or.mi r4,r4,r10 + mov.mi r10,r7 + add.f DBL0L,r10,DBL0L + add.cs.f DBL0H,DBL0H,1 ; carry clear after this point + bxor.f 0,r4,31 + add.pnz.f DBL0L,DBL0L,1 + add.cs.f DBL0H,DBL0H,1 + jne_l [blink] + /* Calculation so far was not conclusive; calculate further rest. */ + mpyu r11,r11,DBL1L ; rest before considering r12 in r5 : -r11 + asr.f r12,r12,3 + asl r5,r5,25 ; s-51.7:25 + ; resource conflict (not for XMAC) + mpyu DBL1H,r12,r8 ; u-51.31:1 + and r9,DBL0L,1 ; tie-breaker: round to even + lsr r11,r11,7 ; u-51.30:2 + ; resource conflict (not for XMAC) + MPYHU r8,r12,DBL1L ; u-51.32 + sub.mi r11,r11,DBL1L ; signed multiply adjust for r12*DBL1L + add_s DBL1H,DBL1H,r11 + ; resource conflict (not for XMAC) + ; resource conflict (not for XMAC) + mpyu r12,r12,DBL1L ; u-83.30:2 + sub DBL1H,DBL1H,r5 ; -rest msw + add_s DBL1H,DBL1H,r8 ; -rest msw + add.f 0,DBL1H,DBL1H ; can't ror.f by 32 :-( + ; wb stall (XMAC: Before add.f) + tst_s DBL1H,DBL1H + cmp.eq r12,r9 + add.cs.f DBL0L,DBL0L,1 + j_s.d [blink] + add.cs DBL0H,DBL0H,1 + +.Lret0: + /* return +- 0 */ + j_s.d [blink] + mov_s DBL0L,0 +.Linf: + mov_s DBL0H,r9 + mov_s DBL0L,0 + j_s.d [blink] + bxor.mi DBL0H,DBL0H,31 + + .balign 4 +.Ldivtab: + .long 0xfc0fffe1 + .long 0xf46ffdfb + .long 0xed1ffa54 + .long 0xe61ff515 + .long 0xdf7fee75 + .long 0xd91fe680 + .long 0xd2ffdd52 + .long 0xcd1fd30c + .long 0xc77fc7cd + .long 0xc21fbbb6 + .long 0xbcefaec0 + .long 0xb7efa100 + .long 0xb32f92bf + .long 0xae8f83b7 + .long 0xaa2f7467 + .long 0xa5ef6479 + .long 0xa1cf53fa + .long 0x9ddf433e + .long 0x9a0f3216 + .long 0x965f2091 + .long 0x92df0f11 + .long 0x8f6efd05 + .long 0x8c1eeacc + .long 0x88eed876 + .long 0x85dec615 + .long 0x82eeb3b9 + .long 0x800ea10b + .long 0x7d3e8e0f + .long 0x7a8e7b3f + .long 0x77ee6836 + .long 0x756e5576 + .long 0x72fe4293 + .long 0x709e2f93 + .long 0x6e4e1c7f + .long 0x6c0e095e + .long 0x69edf6c5 + .long 0x67cde3a5 + .long 0x65cdd125 + .long 0x63cdbe25 + .long 0x61ddab3f + .long 0x600d991f + .long 0x5e3d868c + .long 0x5c6d7384 + .long 0x5abd615f + .long 0x590d4ecd + .long 0x576d3c83 + .long 0x55dd2a89 + .long 0x545d18e9 + .long 0x52dd06e9 + .long 0x516cf54e + .long 0x4ffce356 + .long 0x4e9cd1ce + .long 0x4d3cbfec + .long 0x4becae86 + .long 0x4aac9da4 + .long 0x496c8c73 + .long 0x483c7bd3 + .long 0x470c6ae8 + .long 0x45dc59af + .long 0x44bc4915 + .long 0x43ac3924 + .long 0x428c27fb + .long 0x418c187a + .long 0x407c07bd +.L7ff00000: + .long 0x7ff00000 + ENDFUNC(__divdf3) diff --git a/arch/arc/lib/ieee-754/divsf3-stdmul.S b/arch/arc/lib/ieee-754/divsf3-stdmul.S new file mode 100644 index 000000000000..b6d0b4db10c5 --- /dev/null +++ b/arch/arc/lib/ieee-754/divsf3-stdmul.S @@ -0,0 +1,281 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* + - calculate 15..18 bit inverse using a table of approximating polynoms. + precision is higher for polynoms used to evaluate input with larger + value. + - do one newton-raphson iteration step to double the precision, + then multiply this with the divisor + -> more time to decide if dividend is subnormal + - the worst error propagation is on the side of the value range + with the least initial defect, thus giving us about 30 bits precision. + */ +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __divsf3 + FUNC(__divsf3) + .balign 4 +__divsf3: + push_s blink + push_s r1 + bl.d __divsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __divsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 +#if 1 + bne abort + jeq_s [blink] + b abort +#else + bne abort + j_s [blink] +#endif + ENDFUNC(__divsf3) +#define __divsf3 __divsf3_asm +#endif /* DEBUG */ + + FUNC(__divsf3) + .balign 4 +.L7f800000: + .long 0x7f800000 +.Ldivtab: + .long 0xfc0ffff0 + .long 0xf46ffefd + .long 0xed1ffd2a + .long 0xe627fa8e + .long 0xdf7ff73b + .long 0xd917f33b + .long 0xd2f7eea3 + .long 0xcd1fe986 + .long 0xc77fe3e7 + .long 0xc21fdddb + .long 0xbcefd760 + .long 0xb7f7d08c + .long 0xb32fc960 + .long 0xae97c1ea + .long 0xaa27ba26 + .long 0xa5e7b22e + .long 0xa1cfa9fe + .long 0x9ddfa1a0 + .long 0x9a0f990c + .long 0x9667905d + .long 0x92df878a + .long 0x8f6f7e84 + .long 0x8c27757e + .long 0x88f76c54 + .long 0x85df630c + .long 0x82e759c5 + .long 0x8007506d + .long 0x7d3f470a + .long 0x7a8f3da2 + .long 0x77ef341e + .long 0x756f2abe + .long 0x72f7212d + .long 0x709717ad + .long 0x6e4f0e44 + .long 0x6c1704d6 + .long 0x69e6fb44 + .long 0x67cef1d7 + .long 0x65c6e872 + .long 0x63cedf18 + .long 0x61e6d5cd + .long 0x6006cc6d + .long 0x5e36c323 + .long 0x5c76b9f3 + .long 0x5abeb0b7 + .long 0x5916a79b + .long 0x57769e77 + .long 0x55de954d + .long 0x54568c4e + .long 0x52d6834d + .long 0x51667a7f + .long 0x4ffe71b5 + .long 0x4e9e68f1 + .long 0x4d466035 + .long 0x4bf65784 + .long 0x4aae4ede + .long 0x496e4646 + .long 0x48363dbd + .long 0x47063547 + .long 0x45de2ce5 + .long 0x44be2498 + .long 0x43a61c64 + .long 0x4296144a + .long 0x41860c0e + .long 0x407e03ee +__divsf3_support: /* This label makes debugger output saner. */ +.Ldenorm_fp1: + bclr r6,r6,31 + norm.f r12,r6 ; flag for x/0 -> Inf check + add r6,r6,r6 + rsub r5,r12,16 + ror r5,r1,r5 + asl r6,r6,r12 + bmsk r5,r5,5 + ld.as r5,[r3,r5] + add r4,r6,r6 + ; load latency + MPYHU r7,r5,r4 + bic.ne.f 0, \ + 0x60000000,r0 ; large number / denorm -> Inf + beq_s .Linf_NaN + asl r5,r5,13 + ; wb stall + ; slow track + sub r7,r5,r7 + MPYHU r8,r7,r6 + asl_s r12,r12,23 + and.f r2,r0,r9 + add r2,r2,r12 + asl r12,r0,8 + ; wb stall + bne.d .Lpast_denorm_fp1 +.Ldenorm_fp0: + MPYHU r8,r8,r7 + bclr r12,r12,31 + norm.f r3,r12 ; flag for 0/x -> 0 check + bic.ne.f 0,0x60000000,r1 ; denorm/large number -> 0 + beq_s .Lret0 + asl_s r12,r12,r3 + asl_s r3,r3,23 + add_s r12,r12,r12 + add r11,r11,r3 + b.d .Lpast_denorm_fp0 + mov_s r3,r12 + .balign 4 +.Linf_NaN: + bclr.f 0,r0,31 ; 0/0 -> NaN + xor_s r0,r0,r1 + bmsk r1,r0,30 + bic_s r0,r0,r1 + sub.eq r0,r0,1 + j_s.d [blink] + or r0,r0,r9 +.Lret0: + xor_s r0,r0,r1 + bmsk r1,r0,30 + j_s.d [blink] + bic_s r0,r0,r1 +.Linf_nan_fp1: + lsr_s r0,r0,31 + bmsk.f 0,r1,22 + asl_s r0,r0,31 + bne_s 0f ; inf/inf -> nan + brne r2,r9,.Lsigned0 ; x/inf -> 0, but x/nan -> nan +0: j_s.d [blink] + mov r0,-1 +.Lsigned0: +.Linf_nan_fp0: + tst_s r1,r1 + j_s.d [blink] + bxor.mi r0,r0,31 + .balign 4 + .global __divsf3 +/* N.B. the spacing between divtab and the sub3 to get its address must + be a multiple of 8. */ +__divsf3: + lsr r2,r1,17 + sub3 r3,pcl,55;(.-.Ldivtab) >> 3 + bmsk_s r2,r2,5 + ld.as r5,[r3,r2] + asl r4,r1,9 + ld.as r9,[pcl,-114]; [pcl,(-((.-.L7f800000) >> 2))] ; 0x7f800000 + MPYHU r7,r5,r4 + asl r6,r1,8 + and.f r11,r1,r9 + bset r6,r6,31 + asl r5,r5,13 + ; wb stall + beq .Ldenorm_fp1 + sub r7,r5,r7 + MPYHU r8,r7,r6 + breq.d r11,r9,.Linf_nan_fp1 + and.f r2,r0,r9 + beq.d .Ldenorm_fp0 + asl r12,r0,8 + ; wb stall + breq r2,r9,.Linf_nan_fp0 + MPYHU r8,r8,r7 +.Lpast_denorm_fp1: + bset r3,r12,31 +.Lpast_denorm_fp0: + cmp_s r3,r6 + lsr.cc r3,r3,1 + add_s r2,r2, /* wait for immediate */ \ + /* wb stall */ \ + 0x3f000000 + sub r7,r7,r8 ; u1.31 inverse, about 30 bit + MPYHU r3,r3,r7 + sbc r2,r2,r11 + xor.f 0,r0,r1 + and r0,r2,r9 + bxor.mi r0,r0,31 + brhs r2, /* wb stall / wait for immediate */ \ + 0x7f000000,.Linf_denorm +.Lpast_denorm: + add_s r3,r3,0x22 ; round to nearest or higher + tst r3,0x3c ; check if rounding was unsafe + lsr r3,r3,6 + jne.d [blink] ; return if rounding was safe. + add_s r0,r0,r3 + /* work out exact rounding if we fall through here. */ + /* We know that the exact result cannot be represented in single + precision. Find the mid-point between the two nearest + representable values, multiply with the divisor, and check if + the result is larger than the dividend. */ + add_s r3,r3,r3 + sub_s r3,r3,1 + mpyu r3,r3,r6 + asr.f 0,r0,1 ; for round-to-even in case this is a denorm + rsub r2,r9,25 + asl_s r12,r12,r2 + ; wb stall + ; slow track + sub.f 0,r12,r3 + j_s.d [blink] + sub.mi r0,r0,1 +/* For denormal results, it is possible that an exact result needs + rounding, and thus the round-to-even rule has to come into play. */ +.Linf_denorm: + brlo r2,0xc0000000,.Linf +.Ldenorm: + asr_s r2,r2,23 + bic r0,r0,r9 + neg r9,r2 + brlo.d r9,25,.Lpast_denorm + lsr r3,r3,r9 + /* Fall through: return +- 0 */ + j_s [blink] +.Linf: + j_s.d [blink] + or r0,r0,r9 + ENDFUNC(__divsf3) diff --git a/arch/arc/lib/ieee-754/divsf3.S b/arch/arc/lib/ieee-754/divsf3.S new file mode 100644 index 000000000000..76d002d3773d --- /dev/null +++ b/arch/arc/lib/ieee-754/divsf3.S @@ -0,0 +1,221 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __divsf3 + FUNC(__divsf3) + .balign 4 +__divsf3: + push_s blink + push_s r1 + bl.d __divsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __divsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 +#if 1 + bne abort + jeq_s [blink] + b abort +#else + bne abort + j_s [blink] +#endif + ENDFUNC(__divsf3) +#define __divsf3 __divsf3_asm +#endif /* DEBUG */ + + .balign 4 +__divdf3_support: /* This label makes debugger output saner. */ + FUNC(__divsf3) +.Ldenorm_fp0: + norm.f r12,r2 ; flag for 0/x -> 0 check + bic.ne.f 0,0x60000000,r1 ; denorm/large number -> 0 + beq_s .Lret0_NaN + tst r1,r9 + add_s r2,r2,r2 + sub_s r12,r12,8 + asl_s r2,r2,r12 + asl_l r12,r12,23 + bne.d .Lpast_denorm_fp0 + add r5,r5,r12 +/* r0 is subnormal, r1 is subnormal or 0. */ + + .balign 4 +.Ldenorm_fp1: + norm.f r12,r3 ; flag for x/0 -> Inf check + bic.ne.f 0,0x60000000,r0 ; large number/denorm -> Inf + beq_s .Linf + add_s r3,r3,r3 + sub_s r12,r12,8 + asl_s r3,r3,r12 + asl_s r12,r12,23 + b.d .Lpast_denorm_fp1 + add r4,r4,r12 + +.Lret0_NaN: + bclr.f 0,r1,31 ; 0/0 -> NaN + bic r0,r10,r9 + j_s.d [blink] + sub.eq r0,r0,1 + + .global __divsf3 + .balign 4 + .long 0x7f800000 ; exponent mask +__divsf3: + ld r9,[pcl,-4] + bmsk r2,r0,22 + xor r4,r0,r2 + bmsk r3,r1,22 + xor r5,r1,r3 + and r11,r0,r9 + breq.d r11,0,.Ldenorm_fp0 + xor r10,r4,r5 + breq r11,r9,.Linf_nan_fp0 + bset_s r2,r2,23 + and r11,r1,r9 + breq r11,0,.Ldenorm_fp1 + breq r11,r9,.Linf_nan_fp1 +.Lpast_denorm_fp0: + bset_s r3,r3,23 +.Lpast_denorm_fp1: + cmp r2,r3 + asl_s r2,r2,6+1 + asl_s r3,r3,7 + add.lo r2,r2,r2 + bclr r8,r9,30 ; exponent bias + bclr.lo r8,r8,23 ; reduce exp by one if fraction is shifted + sub r4,r4,r5 + add r4,r4,r8 + xor.f 0,r10,r4 + bmi .Linf_denorm + and r12,r4,r9 + breq r12,0,.Ldenorm + sub_s r2,r2,r3 ; discard implicit 1 +.Ldiv_23bit: + .rep 6 + divaw r2,r2,r3 + .endr + breq r12,r9,.Linf + bmsk r0,r2,6 + xor_s r2,r2,r0 +.Ldiv_17bit: + .rep 7 + divaw r2,r2,r3 + .endr + asl_s r0,r0,7 + bmsk r1,r2,6 + xor_s r2,r2,r1 + or_s r0,r0,r1 +.Ldiv_10bit: + .rep 7 + divaw r2,r2,r3 + .endr + asl_s r0,r0,7 + bmsk r1,r2,6 + xor_s r2,r2,r1 + or_s r0,r0,r1 +.Ldiv_3bit: + .rep 3 + divaw r2,r2,r3 + .endr + asl_s r0,r0,3 +.Ldiv_0bit: + divaw r1,r2,r3 + bmsk_s r2,r2,2 + tst r1,-0x7e ; 0xffffff82, test for rest or odd + bmsk_s r1,r1,0 + add_s r0,r0,r2 ; assemble fraction + add_s r0,r0,r4 ; add in sign & exponent + j_s.d [blink] + add.ne r0,r0,r1 ; round to nearest / even + + .balign 4 +.Linf_nan_fp0: + bic.f 0,r9,r1 ; fp1 Inf -> result NaN + bic r1,r5,r9 ; fp1 sign + sub.eq r1,r1,1 + j_s.d [blink] + xor_s r0,r0,r1 +.Linf_nan_fp1: + bic r0,r4,r9 ; fp0 sign + bmsk.f 0,r1,22 ; x/inf -> 0, x/nan -> nan + xor.eq r1,r1,r9 + j_s.d [blink] + xor_s r0,r0,r1 +.Linf: + j_s.d [blink] + or r0,r10,r9 + +.Lret_r4: + j_s.d [blink] + mov_s r0,r4 + .balign 4 +.Linf_denorm: + add.f r12,r4,r4 + asr_l r12,r12,24 + bpl .Linf + max r12,r12,-24 +.Ldenorm: + add r1,pcl,42; .Ldenorm_tab-. + ldb_s r12,[r12,r1] + mov_s r0,0 + lsr_s r2,r2 + sub_s r1,r1,r12 + j_s.d [r1] + bic r4,r10,r9 + .byte .Ldenorm_tab-.Lret_r4 + .byte .Ldenorm_tab-.Ldiv_0bit + .byte .Ldenorm_tab-.Ldiv_3bit-8 + .byte .Ldenorm_tab-.Ldiv_3bit-4 + .byte .Ldenorm_tab-.Ldiv_3bit + .byte .Ldenorm_tab-.Ldiv_10bit-24 + .byte .Ldenorm_tab-.Ldiv_10bit-20 + .byte .Ldenorm_tab-.Ldiv_10bit-16 + .byte .Ldenorm_tab-.Ldiv_10bit-12 + .byte .Ldenorm_tab-.Ldiv_10bit-8 + .byte .Ldenorm_tab-.Ldiv_10bit-4 + .byte .Ldenorm_tab-.Ldiv_10bit + .byte .Ldenorm_tab-.Ldiv_17bit-24 + .byte .Ldenorm_tab-.Ldiv_17bit-20 + .byte .Ldenorm_tab-.Ldiv_17bit-16 + .byte .Ldenorm_tab-.Ldiv_17bit-12 + .byte .Ldenorm_tab-.Ldiv_17bit-8 + .byte .Ldenorm_tab-.Ldiv_17bit-4 + .byte .Ldenorm_tab-.Ldiv_17bit + .byte .Ldenorm_tab-.Ldiv_23bit-20 + .byte .Ldenorm_tab-.Ldiv_23bit-16 + .byte .Ldenorm_tab-.Ldiv_23bit-12 + .byte .Ldenorm_tab-.Ldiv_23bit-8 + .byte .Ldenorm_tab-.Ldiv_23bit-4 +.Ldenorm_tab: + .byte .Ldenorm_tab-.Ldiv_23bit + ENDFUNC(__divsf3) diff --git a/arch/arc/lib/ieee-754/divtab-arc-df.c b/arch/arc/lib/ieee-754/divtab-arc-df.c new file mode 100644 index 000000000000..c62deef4858b --- /dev/null +++ b/arch/arc/lib/ieee-754/divtab-arc-df.c @@ -0,0 +1,161 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* We use a polynom similar to a Tchebycheff polynom to get an initial + seed, and then use a newton-raphson iteration step to get an + approximate result + If this result can't be rounded to the exact result with confidence, we + round to the value between the two closest representable values, and + test if the correctly rounded value is above or below this value. + + Because of the Newton-raphson iteration step, an error in the seed at X + is amplified by X. Therefore, we don't want a Tchebycheff polynom + or a polynom that is close to optimal according to the maximum norm + on the errro of the seed value; we want one that is close to optimal + according to the maximum norm on the error of the result, i.e. we + want the maxima of the polynom to increase linearily. + Given an interval [X0,X2) over which to approximate, + with X1 := (X0+X2)/2, D := X1-X0, F := 1/D, and S := D/X1 we have, + like for Tchebycheff polynoms: + P(0) := 1 + but then we have: + P(1) := X + S*D + P(2) := 2 * X^2 + S*D * X - D^2 + Then again: + P(n+1) := 2 * X * P(n) - D^2 * P (n-1) + */ + +static long double merr = 42.; + +double +err (long double a0, long double a1, long double x) +{ + long double y0 = a0 + (x-1)*a1; + + long double approx = 2. * y0 - y0 * x * y0; + long double true = 1./x; + long double err = approx - true; + + if (err <= -1./65536./16384.) + printf ("ERROR EXCEEDS 1 ULP %.15f %.15f %.15f\n", + (double)x, (double)approx, (double)true); + if (merr > err) + merr = err; + return err; +} + +int +main (void) +{ + long double T[5]; /* Taylor polynom */ + long double P[5][5]; + int i, j; + long double X0, X1, X2, S; + long double inc = 1./64; + long double D = inc*0.5; + long i0, i1, i2, io; + + memset (P, 0, sizeof (P)); + P[0][0] = 1.; + for (i = 1; i < 5; i++) + P[i][i] = 1 << i-1; + P[2][0] = -D*D; + for (X0 = 1.; X0 < 2.; X0 += inc) + { + X1 = X0 + inc * 0.5; + X2 = X0 + inc; + S = D / X1; + T[0] = 1./X1; + for (i = 1; i < 5; i++) + T[i] = T[i-1] * -T[0]; +#if 0 + printf ("T %1.8f %f %f %f %f\n", (double)T[0], (double)T[1], (double)T[2], +(double)T[3], (double)T[4]); +#endif + P[1][0] = S*D; + P[2][1] = S*D; + for (i = 3; i < 5; i++) + { + P[i][0] = -D*D*P[i-2][0]; + for (j = 1; j < i; j++) + P[i][j] = 2*P[i-1][j-1]-D*D*P[i-2][j]; + } +#if 0 + printf ("P3 %1.8f %f %f %f %f\n", (double)P[3][0], (double)P[3][1], (double)P[3][2], +(double)P[3][3], (double)P[3][4]); + printf ("P4 %1.8f %f %f %f %f\n", (double)P[4][0], (double)P[4][1], (double)P[4][2], +(double)P[4][3], (double)P[4][4]); +#endif + for (i = 4; i > 1; i--) + { + long double a = T[i]/P[i][i]; + + for (j = 0; j < i; j++) + T[j] -= a * P[i][j]; + } +#if 0 + printf ("A %1.8f %f %f\n", (double)T[0], (double)T[1], (double)T[2]); +#endif +#if 0 + i2 = T[2]*1024; + long double a = (T[2]-i/1024.)/P[2][2]; + for (j = 0; j < 2; j++) + T[j] -= a * P[2][j]; +#else + i2 = 0; +#endif + long double T0, Ti1; + for (i = 0, i0 = 0; i < 4; i++) + { + + i1 = T[1]*4096. + i0 / (long double)(1 << 20) - 0.5; + i1 = - (-i1 & 0x0fff); + Ti1 = ((unsigned)(-i1 << 20) | i0) /-(long double)(1LL<<32LL); + T0 = T[0] - (T[1]-Ti1)/P[1][1] * P[1][0] - (X1 - 1) * Ti1; + i0 = T0 * 1024 * 1024 + 0.5; + i0 &= 0xfffff; + } +#if 0 + printf ("A %1.8f %f %f\n", (double)T[0], (double)T[1], (double)T[2]); +#endif + io = (unsigned)(-i1 << 20) | i0; + long double A1 = (unsigned)io/-65536./65536.; + long double A0 = (unsigned)(io << 12)/65536./65536.; + long double Xm0 = 1./sqrt (-A1); + long double Xm1 = 0.5+0.5*-A0/A1; +#if 0 + printf ("%f %f %f %f\n", (double)A0, (double)A1, (double) Ti1, (double)X0); + printf ("%.12f %.12f %.12f\n", + err (A0, A1, X0), err (A0, A1, X1), err (A0, A1, X2)); + printf ("%.12f %.12f\n", (double)Xm0, (double)Xm1); + printf ("%.12f %.12f\n", err (A0, A1, Xm0), err (A0, A1, Xm1)); +#endif + printf ("\t.long 0x%x\n", io); + } +#if 0 + printf ("maximum error: %.15f %x %f\n", (double)merr, (unsigned)(long long)(-merr * 65536 * 65536), (double)log(-merr)/log(2)); +#endif + return 0; +} diff --git a/arch/arc/lib/ieee-754/divtab-arc-sf.c b/arch/arc/lib/ieee-754/divtab-arc-sf.c new file mode 100644 index 000000000000..5a347f59753f --- /dev/null +++ b/arch/arc/lib/ieee-754/divtab-arc-sf.c @@ -0,0 +1,127 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* We use a polynom similar to a Tchebycheff polynom to get an initial + seed, and then use a newton-raphson iteration step to get an + approximate result + If this result can't be rounded to the exact result with confidence, we + round to the value between the two closest representable values, and + test if the correctly rounded value is above or below this value. + + Because of the Newton-raphson iteration step, an error in the seed at X + is amplified by X. Therefore, we don't want a Tchebycheff polynom + or a polynom that is close to optimal according to the maximum norm + on the errro of the seed value; we want one that is close to optimal + according to the maximum norm on the error of the result, i.e. we + want the maxima of the polynom to increase linearily. + Given an interval [X0,X2) over which to approximate, + with X1 := (X0+X2)/2, D := X1-X0, F := 1/D, and S := D/X1 we have, + like for Tchebycheff polynoms: + P(0) := 1 + but then we have: + P(1) := X + S*D + P(2) := 2 * X^2 + S*D * X - D^2 + Then again: + P(n+1) := 2 * X * P(n) - D^2 * P (n-1) + */ + +int +main (void) +{ + long double T[5]; /* Taylor polynom */ + long double P[5][5]; + int i, j; + long double X0, X1, X2, S; + long double inc = 1./64; + long double D = inc*0.5; + long i0, i1, i2; + + memset (P, 0, sizeof (P)); + P[0][0] = 1.; + for (i = 1; i < 5; i++) + P[i][i] = 1 << i-1; + P[2][0] = -D*D; + for (X0 = 1.; X0 < 2.; X0 += inc) + { + X1 = X0 + inc * 0.5; + X2 = X1 + inc; + S = D / X1; + T[0] = 1./X1; + for (i = 1; i < 5; i++) + T[i] = T[i-1] * -T[0]; +#if 0 + printf ("T %1.8f %f %f %f %f\n", (double)T[0], (double)T[1], (double)T[2], +(double)T[3], (double)T[4]); +#endif + P[1][0] = S*D; + P[2][1] = S*D; + for (i = 3; i < 5; i++) + { + P[i][0] = -D*D*P[i-2][0]; + for (j = 1; j < i; j++) + P[i][j] = 2*P[i-1][j-1]-D*D*P[i-2][j]; + } +#if 0 + printf ("P3 %1.8f %f %f %f %f\n", (double)P[3][0], (double)P[3][1], (double)P[3][2], +(double)P[3][3], (double)P[3][4]); + printf ("P4 %1.8f %f %f %f %f\n", (double)P[4][0], (double)P[4][1], (double)P[4][2], +(double)P[4][3], (double)P[4][4]); +#endif + for (i = 4; i > 1; i--) + { + long double a = T[i]/P[i][i]; + + for (j = 0; j < i; j++) + T[j] -= a * P[i][j]; + } +#if 0 + printf ("A %1.8f %f %f\n", (double)T[0], (double)T[1], (double)T[2]); +#endif +#if 0 + i2 = T[2]*512; + long double a = (T[2]-i/512.)/P[2][2]; + for (j = 0; j < 2; j++) + T[j] -= a * P[2][j]; +#else + i2 = 0; +#endif + for (i = 0, i0 = 0; i < 4; i++) + { + long double T0, Ti1; + + i1 = T[1]*8192. + i0 / (long double)(1 << 19) - 0.5; + i1 = - (-i1 & 0x1fff); + Ti1 = ((unsigned)(-i1 << 19) | i0) /-(long double)(1LL<<32LL); + T0 = T[0] - (T[1]-Ti1)/P[1][1] * P[1][0] - (X1 - 1) * Ti1; + i0 = T0 * 512 * 1024 + 0.5; + i0 &= 0x7ffff; + } +#if 0 + printf ("A %1.8f %f %f\n", (double)T[0], (double)T[1], (double)T[2]); +#endif + printf ("\t.long 0x%x\n", (-i1 << 19) | i0); + } + return 0; +} diff --git a/arch/arc/lib/ieee-754/eqdf2.S b/arch/arc/lib/ieee-754/eqdf2.S new file mode 100644 index 000000000000..f8c752b17c14 --- /dev/null +++ b/arch/arc/lib/ieee-754/eqdf2.S @@ -0,0 +1,81 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +/* inputs: DBL0, DBL1 + output: z flag + clobber: r12, flags + For NaNs, bit 19.. bit 30 of the high word must be set. */ +#if 0 /* DEBUG */ + .global __eqdf2 + .balign 4 + FUNC(__eqdf2) +__eqdf2: + st.a r11,[sp,-4]` push_s blink` st.a r10,[sp,-4]` st.a r9,[sp,-4] + st.a r8,[sp,-4]` st.a r7,[sp,-4]` st.a r6,[sp,-4]` st.a r5,[sp,-4] + st.a r4,[sp,-4]` push_s r3` push_s r2` push_s r1` + bl.d __eqdf2_c` push_s r0 + mov r11,r0` pop_s r0` pop_s r1` pop_s r2` pop_s r3 + ld.ab r4,[sp,4]` ld.ab r5,[sp,4]` ld.ab r6,[sp,4]` + ld.ab r7,[sp,4]` ld.ab r8,[sp,4]` ld.ab r9,[sp,4] + bl.d __eqdf2_asm` ld.ab r10,[sp,4] + pop_s blink + breq.d r11,0,0f + ld.ab r11,[sp,4] + jne_s [blink] + bl abort +0: jeq_s [blink] + bl abort + ENDFUNC(__eqdf2) +#define __eqdf2 __eqdf2_asm +#endif /* DEBUG */ + .global __eqdf2 + .balign 4 + HIDDEN_FUNC(__eqdf2) + /* Good performance as long as the difference in high word is + well predictable (as seen from the branch predictor). */ +__eqdf2: + brne.d DBL0H,DBL1H,.Lhighdiff +#ifndef __HS__ + /* The next two instructions are required to recognize the FPX + NaN, which has a pattern like this: 0x7ff0_0000_8000_0000, as + oposite to 0x7ff8_0000_0000_0000. */ + or.f 0,DBL0L,DBL1L + mov_s r12,0x00200000 + bset.ne r12,r12,0 +#else + bmsk r12,DBL0H,20 +#endif /* __HS__ */ + add1.f r12,r12,DBL0H /* set c iff NaN; also, clear z if NaN. */ + j_s.d [blink] + cmp.cc DBL0L,DBL1L + .balign 4 +.Lhighdiff: + or r12,DBL0H,DBL1H + or.f 0,DBL0L,DBL1L + j_s.d [blink] + bmsk.eq.f r12,r12,30 + ENDFUNC(__eqdf2) +/* ??? could we do better by speeding up some 'common' case of inequality? */ diff --git a/arch/arc/lib/ieee-754/eqsf2.S b/arch/arc/lib/ieee-754/eqsf2.S new file mode 100644 index 000000000000..345a584c7139 --- /dev/null +++ b/arch/arc/lib/ieee-754/eqsf2.S @@ -0,0 +1,69 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +/* inputs: r0, r1 + output: z flag + clobber: r12, flags + For NaNs, bit 22 .. bit 30 must be set. */ +#if 0 /* DEBUG */ + .global __eqsf2 + .balign 4 + FUNC(__eqsf2) +__eqsf2: + st.a r11,[sp,-4]` push_s blink` st.a r10,[sp,-4]` st.a r9,[sp,-4] + st.a r8,[sp,-4]` st.a r7,[sp,-4]` st.a r6,[sp,-4]` st.a r5,[sp,-4] + st.a r4,[sp,-4]` push_s r3` push_s r2` push_s r1` + bl.d __eqsf2_c` push_s r0 + mov r11,r0` pop_s r0` pop_s r1` pop_s r2` pop_s r3 + ld.ab r4,[sp,4]` ld.ab r5,[sp,4]` ld.ab r6,[sp,4]` + ld.ab r7,[sp,4]` ld.ab r8,[sp,4]` ld.ab r9,[sp,4] + bl.d __eqsf2_asm` ld.ab r10,[sp,4] + pop_s blink + breq.d r11,0,0f + ld.ab r11,[sp,4] + jne_s [blink] + bl abort +0: jeq_s [blink] + bl abort + ENDFUNC(__eqsf2) +#define __eqsf2 __eqsf2_asm +#endif /* DEBUG */ + /* Good performance as long as the binary difference is + well predictable (as seen from the branch predictor). */ + .global __eqsf2 + .balign 4 + HIDDEN_FUNC(__eqsf2) +__eqsf2: + breq r0, r1,.Lno_bdiff + or r12,r0,r1 + j_s.d [blink] + bmsk.f 0,r12,30 +.Lno_bdiff: + bmsk r12,r0,23 + add1.f r12,r12,r0 /* set c iff NaN; also, clear z if NaN. */ + j_s.d [blink] + cmp.cc r0,r1 + ENDFUNC(__eqsf2) diff --git a/arch/arc/lib/ieee-754/extendsfdf2.S b/arch/arc/lib/ieee-754/extendsfdf2.S new file mode 100644 index 000000000000..4cb072f814f7 --- /dev/null +++ b/arch/arc/lib/ieee-754/extendsfdf2.S @@ -0,0 +1,122 @@ +/* Copyright (C) 2006-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __extendsfdf2 + .balign 4 + FUNC(__extendsfdf2) +__extendsfdf2: + push_s blink + bl.d __extendsfdf2_c + push_s r0 + ld_s r2,[sp] + st_s r1,[sp] + push_s r0 + bl.d __extendsfdf2_asm + mov_s r0,r2 + pop_s r2 + pop_s r3 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + bl abort + ENDFUNC(__extendsfdf2) +#define __extendsfdf2 __extendsfdf2_asm +#endif /* DEBUG */ +#if 0 /* ARC600 */ +__extendsfdf2: + lsr r2,r0,23 + tst r2,0xff + bic.ne.f r2,0xff + beq_s .Linf_nan_denorm_0 +.. +.Linf_nan_denorm: + bbit1 r0,30,.Linf_nan +#endif + .global __extendsfdf2 + .balign 4 + FUNC(__extendsfdf2) +__extendsfdf2: + add.f r1,r0,r0 + norm r3,r1 +#ifdef __LITTLE_ENDIAN__ + lsr_s DBL0H,r1,4 + brhs r3,7,.Linf_nan_denorm_0 + asl_s DBL0L,r0,29 + add_s DBL0H,DBL0H, \ + 0x38000000 +#else + lsr r2,r1,4 + brhs r3,7,.Linf_nan_denorm_0 + asl_s DBL0L,r1,28 + add DBL0H,r2, \ + 0x38000000 +#endif + j_s.d [blink] + bxor.cs DBL0H,DBL0H,31 + .balign 4 +.Linf_nan_denorm_0: +#ifdef __LITTLE_ENDIAN__ + mov_s DBL0H,r0 + jeq.d [blink] + mov.eq DBL0L,0 +#else + jeq_s [blink] +#endif + bmi .Linf_nan + asl_s r0,r0,r3 + rsub r3,r3,0x380+6 +#ifdef __LITTLE_ENDIAN__ + asl_s r3,r3,20 + lsr DBL0H,r0,9 + asl_s DBL0L,r0,23 + add_s DBL0H,DBL0H,r3 + j_s.d [blink] + bxor.cs DBL0H,DBL0H,31 +#else + asl DBL0L,r0,23 + lsr_s DBL0H,r0,9 + asl_s r3,r3,20 + bxor.cs DBL0H,DBL0H,31 + j_s.d [blink] + add_l DBL0H,DBL0H,r3 +#endif +.Linf_nan: +#ifdef __LITTLE_ENDIAN__ + lsr DBL0H,r0,3 + + or_s DBL0H,DBL0H,r0 + j_s.d [blink] + mov_l DBL0L,0 +#else + lsr r3,r0,3 + mov_s DBL0L,0 + j_s.d [blink] + or_l DBL0H,r0,r3 +#endif + ENDFUNC(__extendsfdf2) diff --git a/arch/arc/lib/ieee-754/fixdfsi.S b/arch/arc/lib/ieee-754/fixdfsi.S new file mode 100644 index 000000000000..5f0e60cc951f --- /dev/null +++ b/arch/arc/lib/ieee-754/fixdfsi.S @@ -0,0 +1,85 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + FUNC(__fixdfsi) + .global __fixdfsi + .balign 4 +__fixdfsi: + push_s blink + push_s r0 + bl.d __fixdfsi_c + push_s r1 + mov_s r2,r0 + pop_s r1 + ld r0,[sp] + bl.d __fixdfsi_asm + st r2,[sp] + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + bl abort + ENDFUNC(__fixdfsi) +#define __fixdfsi __fixdfsi_asm +#endif /* DEBUG */ + +/* If the fraction has to be shifted left by a positive non-zero amount, + we have to combine bits from DBL0L and DBL0H. If we shift right, + or shift by zero, we only want to have the bits from DBL0H in r0. */ + + .global __fixdfsi + FUNC(__fixdfsi) + .balign 4 +__fixdfsi: + bbit0 DBL0H,30,.Lret0or1 + asr r2,DBL0H,20 + bmsk_s DBL0H,DBL0H,19 + sub_s r2,r2,19; 0x3ff+20-0x400 + neg_s r3,r2 + asr.f 0,r3,11 + bset_s DBL0H,DBL0H,20 +#ifdef __LITTLE_ENDIAN__ + mov.cs DBL0L,DBL0H + asl DBL0H,DBL0H,r2 +#else + asl.cc DBL0H,DBL0H,r2 + lsr.cs DBL0H,DBL0H,r3 +#endif + lsr_s DBL0L,DBL0L,r3 + + add.cc r0,r0,r1 + j_s.d [blink] + neg.pl r0,r0 +.Lret0or1: + add.f r0,DBL0H,0x100000 + lsr_s r0,r0,30 + + bmsk_s r0,r0,0 + j_s.d [blink] + neg.mi r0,r0 + ENDFUNC(__fixdfsi) diff --git a/arch/arc/lib/ieee-754/fixsfsi.S b/arch/arc/lib/ieee-754/fixsfsi.S new file mode 100644 index 000000000000..d1862d8678a0 --- /dev/null +++ b/arch/arc/lib/ieee-754/fixsfsi.S @@ -0,0 +1,71 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __fixsfsi + FUNC(__fixsfsi) + .balign 4 +__fixsfsi: + push_s blink + bl.d __fixsfsi_c + push_s r0 + ld_s r1,[sp] + st_s r0,[sp] + bl.d __fixsfsi_asm + mov_s r0,r1 + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + bl abort + ENDFUNC(__fixsfsi) +#define __fixsfsi __fixsfsi_asm +#endif /* DEBUG */ + + .global __fixsfsi + FUNC(__fixsfsi) + .balign 4 +__fixsfsi: + bbit0 r0,30,.Lret0or1 + lsr r2,r0,23 + bmsk_s r0,r0,22 + bset_s r0,r0,23 + sub_s r2,r2,22;0x7f+23-0x80 + asl.f 0,r2,24 + neg r3,r2 + asl.mi r0,r0,r2 + lsr.pl r0,r0,r3 + j_s.d [blink] + neg.cs r0,r0 +.Lret0or1: + add.f r0,r0,0x800000 + lsr_s r0,r0,30 + + bmsk_s r0,r0,0 + j_s.d [blink] + neg.mi r0,r0 + ENDFUNC(__fixsfsi) diff --git a/arch/arc/lib/ieee-754/fixunsdfsi.S b/arch/arc/lib/ieee-754/fixunsdfsi.S new file mode 100644 index 000000000000..6340dc253ce6 --- /dev/null +++ b/arch/arc/lib/ieee-754/fixunsdfsi.S @@ -0,0 +1,80 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + FUNC(__fixunsdfsi) + .global __fixunsdfsi + .balign 4 +__fixunsdfsi: + push_s blink + push_s r0 + bl.d __fixunsdfsi_c + push_s r1 + mov_s r2,r0 + pop_s r1 + ld r0,[sp] + bl.d __fixunsdfsi_asm + st r2,[sp] + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + bl abort + ENDFUNC(__fixunsdfsi) +#define __fixunsdfsi __fixunsdfsi_asm +#endif /* DEBUG */ + + .global __fixunsdfsi + FUNC(__fixunsdfsi) + .balign 4 +__fixunsdfsi: + bbit0 DBL0H,30,.Lret0or1 + lsr r2,DBL0H,20 + bmsk_s DBL0H,DBL0H,19 + sub_s r2,r2,19; 0x3ff+20-0x400 + neg_s r3,r2 + btst_s r3,10 + bset_s DBL0H,DBL0H,20 +#ifdef __LITTLE_ENDIAN__ + mov.ne DBL0L,DBL0H + asl DBL0H,DBL0H,r2 +#else + asl.eq DBL0H,DBL0H,r2 + lsr.ne DBL0H,DBL0H,r3 +#endif + lsr DBL0L,DBL0L,r3 + j_s.d [blink] + add.eq r0,r0,r1 +.Lret0: + j_s.d [blink] + mov_l r0,0 +.Lret0or1: + add_s DBL0H,DBL0H,0x100000 + lsr_s DBL0H,DBL0H,30 + j_s.d [blink] + bmsk_l r0,DBL0H,0 + ENDFUNC(__fixunsdfsi) diff --git a/arch/arc/lib/ieee-754/floatsidf.S b/arch/arc/lib/ieee-754/floatsidf.S new file mode 100644 index 000000000000..41632996e32a --- /dev/null +++ b/arch/arc/lib/ieee-754/floatsidf.S @@ -0,0 +1,77 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __floatsidf + .balign 4 + FUNC(__floatsidf) +__floatsidf: + push_s blink + bl.d __floatsidf_c + push_s r0 + ld_s r2,[sp] + st_s r1,[sp] + push_s r0 + bl.d __floatsidf_asm + mov_s r0,r2 + pop_s r2 + pop_s r3 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + bl abort + ENDFUNC(__floatsidf) +#define __floatsidf __floatsidf_asm +#endif /* DEBUG */ + + .global __floatsidf + .balign 4 + FUNC(__floatsidf) +__floatsidf: + abs.f r1,r0 + jeq_s [blink] + lsr r2,r1 + mov r12,-0x41d ; -(0x3ff+31-1) + norm r2,r2 + bclr.cs r12,r12,11 + rsub.f r3,r2,11 + add_s r12,r2,r12 + add_s r2,r2,21 +#ifdef __LITTLE_ENDIAN__ + asl DBL0L,r1,r2 + lsr_s DBL0H,r1,r3 +#else + lsr DBL0H,r1,r3 + asl_s DBL0L,r1,r2 +#endif + asl_s r12,r12,20 + mov.lo DBL0H,DBL0L + sub_s DBL0H,DBL0H,r12 + j_s.d [blink] + mov.ls DBL0L,0 + ENDFUNC(__floatsidf) diff --git a/arch/arc/lib/ieee-754/floatsisf.S b/arch/arc/lib/ieee-754/floatsisf.S new file mode 100644 index 000000000000..bbb667b9dbfa --- /dev/null +++ b/arch/arc/lib/ieee-754/floatsisf.S @@ -0,0 +1,99 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __floatsisf + FUNC(__floatsisf) + .balign 4 +__floatsisf: + push_s blink + bl.d __floatsisf_c + push_s r0 + ld_s r1,[sp] + st_s r0,[sp] + bl.d __floatsisf_asm + mov_s r0,r1 + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + bl abort + ENDFUNC(__floatsisf) + .global __floatunsisf + FUNC(__floatunsisf) + .balign 4 +__floatunsisf: + push_s blink + bl.d __floatunsisf_c + push_s r0 + ld_s r1,[sp] + st_s r0,[sp] + bl.d __floatunsisf_asm + mov_s r0,r1 + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + bl abort + ENDFUNC(__floatunsisf) +#define __floatsisf __floatsisf_asm +#define __floatunsisf __floatunsisf_asm +#endif /* DEBUG */ + + .global __floatunsisf + .global __floatsisf + FUNC(__floatsisf) + FUNC(__floatunsisf) + .balign 4 +__floatunsisf: + lsr_s r2,r0 + mov_l r12,0x9d ; 0x7f + 31 - 1 + norm r2,r2 + brne_l r0,0,0f + j_s [blink] + .balign 4 +__floatsisf: + abs.f r0,r0 + jeq_s [blink] + lsr_s r2,r0 + mov_s r12,0x9d ; 0x7f + 31 - 1 + norm r2,r2 + bset.cs r12,r12,8 +0: rsub.f r3,r2,8 + bmsk r1,r0,r3 + ror r1,r1,r3 + lsr.pl r0,r0,r3 + neg_s r3,r3 + asl.mi r0,r0,r3 + sub_s r12,r12,r2 + asl_s r12,r12,23 + bxor.pl.f r1,r1,31 + add_s r0,r0,r12 + j_s.d [blink] + add.pnz r0,r0,1 + ENDFUNC(__floatunsisf) + ENDFUNC(__floatsisf) diff --git a/arch/arc/lib/ieee-754/floatunsidf.S b/arch/arc/lib/ieee-754/floatunsidf.S new file mode 100644 index 000000000000..c0313fc9f6cb --- /dev/null +++ b/arch/arc/lib/ieee-754/floatunsidf.S @@ -0,0 +1,75 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __floatunsidf + .balign 4 + FUNC(__floatunsidf) +__floatunsidf: + push_s blink + bl.d __floatunsidf_c + push_s r0 + ld_s r2,[sp] + st_s r1,[sp] + push_s r0 + bl.d __floatunsidf_asm + mov_s r0,r2 + pop_s r2 + pop_s r3 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + bl abort + ENDFUNC(__floatunsidf) +#define __floatunsidf __floatunsidf_asm +#endif /* DEBUG */ + + .global __floatunsidf + .balign 4 + FUNC(__floatunsidf) +__floatunsidf: + lsr_s r1,r0 + breq_s r0,0,.Lret0 + norm r2,r1 + mov r12,-0x41d ; -(0x3ff+31-1) + rsub.f r3,r2,11 + add_s r12,r2,r12 + add_s r2,r2,21 +#ifdef __LITTLE_ENDIAN__ + lsr DBL0H,r0,r3 + asl_s DBL0L,r0,r2 +#else + asl DBL0L,r0,r2 + lsr_s DBL0H,r0,r3 +#endif + asl_s r12,r12,20 + mov.lo DBL0H,DBL0L + sub_s DBL0H,DBL0H,r12 +.Lret0: j_s.d [blink] + mov.ls DBL0L,0 + ENDFUNC(__floatunsidf) diff --git a/arch/arc/lib/ieee-754/gedf2.S b/arch/arc/lib/ieee-754/gedf2.S new file mode 100644 index 000000000000..b8f3b37fbb50 --- /dev/null +++ b/arch/arc/lib/ieee-754/gedf2.S @@ -0,0 +1,86 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +/* inputs: DBL0, DBL1 + output: c flags to be used for 'hs' condition + clobber: r12, flags */ +/* For NaNs, bit 19.. bit 30 of the high word must be set. */ +#if 0 /* DEBUG */ + .global __gedf2 + .balign 4 + FUNC(__gedf2) +__gedf2: + st.a r11,[sp,-4]` push_s blink` st.a r10,[sp,-4]` st.a r9,[sp,-4] + st.a r8,[sp,-4]` st.a r7,[sp,-4]` st.a r6,[sp,-4]` st.a r5,[sp,-4] + st.a r4,[sp,-4]` push_s r3` push_s r2` push_s r1` + bl.d __gedf2_c` push_s r0 + mov r11,r0` pop_s r0` pop_s r1` pop_s r2` pop_s r3 + ld.ab r4,[sp,4]` ld.ab r5,[sp,4]` ld.ab r6,[sp,4]` + ld.ab r7,[sp,4]` ld.ab r8,[sp,4]` ld.ab r9,[sp,4] + bl.d __gedf2_asm` ld.ab r10,[sp,4] + pop_s blink + brge.d r11,0,0f + ld.ab r11,[sp,4] + jlo [blink] + bl abort +0: jhs [blink] + bl abort + ENDFUNC(__gedf2) +#define __gedf2 __gedf2_asm +#endif /* DEBUG */ + .global __gedf2 + .balign 4 + HIDDEN_FUNC(__gedf2) +__gedf2: + or.f r12,DBL0H,DBL1H + bmi.d .Lneg + bmsk_s r12,r12,20 + add1.f 0,r12,DBL0H ; clear z; set c iff NaN + add1.cc.f r12,r12,DBL1H ; clear z; set c iff NaN + bbit1 DBL0H,31,.Lneg + cmp.cc DBL0H,DBL1H + j_s.d [blink] + cmp.eq DBL0L,DBL1L + .balign 4 +.Lneg: breq.d DBL1H,0,.L0 + add1.f 0,r12,DBL0H + add1.cc.f r12,r12,DBL1H + cmp.cc DBL1H,DBL0H + j_s.d [blink] + cmp.eq DBL1L,DBL0L + .balign 4 +.L0: + bxor.f 0,DBL0H,31 ; check for high word of -0. + beq_s .Lcheck_0 + cmp.cc DBL1H,DBL0H + j_s.d [blink] + cmp.eq DBL1L,DBL0L +.Lcheck_0: + ; high words suggest DBL0 may be -0, DBL1 +0; check low words. + cmp_s DBL1H,DBL0L + j_s.d [blink] + cmp.cc DBL1H,DBL1L + ENDFUNC(__gedf2) diff --git a/arch/arc/lib/ieee-754/gesf2.S b/arch/arc/lib/ieee-754/gesf2.S new file mode 100644 index 000000000000..cc3d3a2a0d65 --- /dev/null +++ b/arch/arc/lib/ieee-754/gesf2.S @@ -0,0 +1,75 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +/* inputs: r0, r1 + output: c flag to be used for 'hs' condition + clobber: r12,flags */ +/* For NaNs, bit 22.. bit 30 must be set. */ +#if 0 /* DEBUG */ + .global __gesf2 + .balign 4 + FUNC(__gesf2) +__gesf2: + st.a r11,[sp,-4]` push_s blink` st.a r10,[sp,-4]` st.a r9,[sp,-4] + st.a r8,[sp,-4]` st.a r7,[sp,-4]` st.a r6,[sp,-4]` st.a r5,[sp,-4] + st.a r4,[sp,-4]` push_s r3` push_s r2` push_s r1` + bl.d __gesf2_c` push_s r0 + mov r11,r0` pop_s r0` pop_s r1` pop_s r2` pop_s r3 + ld.ab r4,[sp,4]` ld.ab r5,[sp,4]` ld.ab r6,[sp,4]` + ld.ab r7,[sp,4]` ld.ab r8,[sp,4]` ld.ab r9,[sp,4] + bl.d __gesf2_asm` ld.ab r10,[sp,4] + pop_s blink + brge.d r11,0,0f + ld.ab r11,[sp,4] + jlo [blink] + bl abort +0: jhs [blink] + bl abort + ENDFUNC(__gesf2) +#define __gesf2 __gesf2_asm +#endif /* DEBUG */ + .global __gesf2 + .balign 4 + HIDDEN_FUNC(__gesf2) +__gesf2: + or.f r12,r0,r1 + bmi.d .Lneg + bmsk_s r12,r12,23 + add1.f 0,r12,r0 ; check for NaN + add1.cc.f r12,r12,r1 + j_s.d [blink] + cmp.cc r0,r1 + .balign 4 +.Lneg: breq.d r1,0,.L0 + add1.f 0,r12,r0 ; check for NaN + add1.cc.f r12,r12,r1 + j_s.d [blink] + cmp.cc r1,r0 + .balign 4 +.L0: bxor.f 0,r0,31 ; check for -0 + j_s.d [blink] + cmp.hi r1,r0 + ENDFUNC(__gesf2) diff --git a/arch/arc/lib/ieee-754/gtdf2.S b/arch/arc/lib/ieee-754/gtdf2.S new file mode 100644 index 000000000000..0d490b2e2c5a --- /dev/null +++ b/arch/arc/lib/ieee-754/gtdf2.S @@ -0,0 +1,86 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +/* inputs: DBL0, DBL1 + output: c,z flags to be used for 'hi' condition + clobber: r12, flags */ +/* For NaNs, bit 19.. bit 30 of the high word must be set. */ +#if 0 /* DEBUG */ + .global __gtdf2 + .balign 4 + FUNC(__gtdf2) +__gtdf2: + st.a r11,[sp,-4]` push_s blink` st.a r10,[sp,-4]` st.a r9,[sp,-4] + st.a r8,[sp,-4]` st.a r7,[sp,-4]` st.a r6,[sp,-4]` st.a r5,[sp,-4] + st.a r4,[sp,-4]` push_s r3` push_s r2` push_s r1` + bl.d __gtdf2_c` push_s r0 + mov r11,r0` pop_s r0` pop_s r1` pop_s r2` pop_s r3 + ld.ab r4,[sp,4]` ld.ab r5,[sp,4]` ld.ab r6,[sp,4]` + ld.ab r7,[sp,4]` ld.ab r8,[sp,4]` ld.ab r9,[sp,4] + bl.d __gtdf2_asm` ld.ab r10,[sp,4] + pop_s blink + brgt.d r11,0,0f + ld.ab r11,[sp,4] + jls [blink] + bl abort +0: jhi [blink] + bl abort + ENDFUNC(__gtdf2) +#define __gtdf2 __gtdf2_asm +#endif /* DEBUG */ + .global __gtdf2 + .balign 4 + HIDDEN_FUNC(__gtdf2) +__gtdf2: + or.f r12,DBL0H,DBL1H + bmi.d .Lneg + bmsk_s r12,r12,20 + add1.f 0,r12,DBL0H ; clear z; set c iff NaN + add1.cc.f r12,r12,DBL1H ; clear z; set c iff NaN + ; don't care: z may or may not be cleared if there is no NaN event + cmp.cc DBL0H,DBL1H + j_s.d [blink] + cmp.eq DBL0L,DBL1L + .balign 4 +.Lneg: breq.d DBL0H,0,.L0 + add1.f 0,r12,DBL1H + add1.cc.f r12,r12,DBL0H + cmp.cc DBL1H,DBL0H + j_s.d [blink] + cmp.eq DBL1L,DBL0L + .balign 4 +.L0: + bxor.f 0,DBL1H,31 + beq_s .Lcheck_0 + cmp.cc DBL1H,DBL0H + j_s.d [blink] + cmp.eq DBL1L,DBL0L + .balign 4 +.Lcheck_0: + ; high words suggest DBL0 may be +0, DBL1 -0; check low words. + j_s.d [blink] + or.f 0,DBL0L,DBL1L + ENDFUNC(__gtdf2) diff --git a/arch/arc/lib/ieee-754/gtsf2.S b/arch/arc/lib/ieee-754/gtsf2.S new file mode 100644 index 000000000000..7da8c02df449 --- /dev/null +++ b/arch/arc/lib/ieee-754/gtsf2.S @@ -0,0 +1,75 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +/* inputs: r0, r1 + output: c, z flags to be used for 'hi' condition + clobber: r12,flags */ +/* For NaNs, bit 22.. bit 30 must be set. */ +#if 0 /* DEBUG */ + .global __gtsf2 + .balign 4 + FUNC(__gtsf2) +__gtsf2: + st.a r11,[sp,-4]` push_s blink` st.a r10,[sp,-4]` st.a r9,[sp,-4] + st.a r8,[sp,-4]` st.a r7,[sp,-4]` st.a r6,[sp,-4]` st.a r5,[sp,-4] + st.a r4,[sp,-4]` push_s r3` push_s r2` push_s r1` + bl.d __gtsf2_c` push_s r0 + mov r11,r0` pop_s r0` pop_s r1` pop_s r2` pop_s r3 + ld.ab r4,[sp,4]` ld.ab r5,[sp,4]` ld.ab r6,[sp,4]` + ld.ab r7,[sp,4]` ld.ab r8,[sp,4]` ld.ab r9,[sp,4] + bl.d __gtsf2_asm` ld.ab r10,[sp,4] + pop_s blink + brgt.d r11,0,0f + ld.ab r11,[sp,4] + jls [blink] + bl abort +0: jhi [blink] + bl abort + ENDFUNC(__gtsf2) +#define __gtsf2 __gtsf2_asm +#endif /* DEBUG */ + .global __gtsf2 + .balign 4 + HIDDEN_FUNC(__gtsf2) +__gtsf2: + or.f r12,r0,r1 + bmi.d .Lneg + bmsk_s r12,r12,23 + add1.f 0,r12,r0 ; check for NaN + add1.cc.f r12,r12,r1 + j_s.d [blink] + cmp.cc r0,r1 + .balign 4 +.Lneg: breq.d r0,0,.L0 + add1.f 0,r12,r0 ; check for NaN + add1.cc.f r12,r12,r1 + j_s.d [blink] + cmp.cc r1,r0 + .balign 4 +.L0: bxor.f 0,r1,31 ; check for -0 + j_s.d [blink] + cmp.hi r1,r0 + ENDFUNC(__gtsf2) diff --git a/arch/arc/lib/ieee-754/muldf3.S b/arch/arc/lib/ieee-754/muldf3.S new file mode 100644 index 000000000000..31c13af8ec26 --- /dev/null +++ b/arch/arc/lib/ieee-754/muldf3.S @@ -0,0 +1,235 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* XMAC schedule: directly back-to-back multiplies stall; the third + instruction after a multiply stalls unless it is also a multiply. */ +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __muldf3 + .balign 4 +__muldf3: + push_s blink + push_s r2 + push_s r3 + push_s r0 + bl.d __muldf3_c + push_s r1 + ld_s r2,[sp,12] + ld_s r3,[sp,8] + st_s r0,[sp,12] + st_s r1,[sp,8] + pop_s r1 + bl.d __muldf3_asm + pop_s r0 + pop_s r3 + pop_s r2 + pop_s blink + cmp r0,r2 + cmp.eq r1,r3 + jeq_s [blink] + b abort +#define __muldf3 __muldf3_asm +#endif /* DEBUG */ +/* N.B. This is optimized for ARC700. + ARC600 has very different scheduling / instruction selection criteria. */ +/* For the standard multiplier, instead of mpyu rx,DBL0L,DBL1L; tst rx,rx , + we can do: + sub rx,DBL0L,1; bic rx,DBL0L,rx; lsr rx,rx; norm rx,rx; asl.f 0,DBL1L,rx */ + +__muldf3_support: /* This label makes debugger output saner. */ +/* If one number is denormal, subtract some from the exponent of the other + one (if the other exponent is too small, return 0), and normalize the + denormal. Then re-run the computation. */ + .balign 4 + FUNC(__muldf3) +.Ldenorm_dbl0: + mov_s r12,DBL0L + mov_s DBL0L,DBL1L + mov_s DBL1L,r12 + mov_s r12,DBL0H + mov_s DBL0H,DBL1H + mov_s DBL1H,r12 + and r11,DBL0H,r9 +.Ldenorm_dbl1: + brhs r11,r9,.Linf_nan + brhs 0x3ca00001,r11,.Lret0 + sub_s DBL0H,DBL0H,DBL1H + bmsk_s DBL1H,DBL1H,30 + add_s DBL0H,DBL0H,DBL1H + breq_s DBL1H,0,.Ldenorm_2 + norm r12,DBL1H + + sub_s r12,r12,10 + asl r5,r12,20 + asl_s DBL1H,DBL1H,r12 + sub DBL0H,DBL0H,r5 + neg r5,r12 + lsr r6,DBL1L,r5 + asl_s DBL1L,DBL1L,r12 + b.d __muldf3 + add_s DBL1H,DBL1H,r6 + + .balign 4 +.Linf_nan: + bclr r12,DBL1H,31 + xor_s DBL1H,DBL1H,DBL0H + bclr_s DBL0H,DBL0H,31 + max r8,DBL0H,r12 ; either NaN -> NaN ; otherwise inf + or.f 0,DBL0H,DBL0L + mov_s DBL0L,0 + or.ne.f DBL1L,DBL1L,r12 + not_s DBL0H,DBL0L ; inf * 0 -> NaN + mov.ne DBL0H,r8 + tst_s DBL1H,DBL1H + j_s.d [blink] + bset.mi DBL0H,DBL0H,31 + +.Lret0: xor_s DBL0H,DBL0H,DBL1H + bclr DBL1H,DBL0H,31 + xor_s DBL0H,DBL0H,DBL1H + j_s.d [blink] + mov_l DBL0L,0 + + .balign 4 +.Ldenorm_2: + breq_s DBL1L,0,.Lret0 ; 0 input -> 0 output + norm.f r12,DBL1L + + mov.mi r12,21 + add.pl r12,r12,22 + neg r11,r12 + asl_s r12,r12,20 + lsr.f DBL1H,DBL1L,r11 + ror DBL1L,DBL1L,r11 + sub_s DBL0H,DBL0H,r12 + mov.eq DBL1H,DBL1L + sub_s DBL1L,DBL1L,DBL1H + /* Fall through. */ + .global __muldf3 + .balign 4 +__muldf3: + ld.as r9,[pcl,0x4b] ; ((.L7ff00000-.+2)/4)] + MPYHU r4,DBL0L,DBL1L + bmsk r6,DBL0H,19 + bset r6,r6,20 + mpyu r7,r6,DBL1L + and r11,DBL0H,r9 + breq r11,0,.Ldenorm_dbl0 + MPYHU r8,r6,DBL1L + bmsk r10,DBL1H,19 + bset r10,r10,20 + MPYHU r5,r10,DBL0L + add.f r4,r4,r7 + and r12,DBL1H,r9 + MPYHU r7,r6,r10 + breq r12,0,.Ldenorm_dbl1 + adc.f r5,r5,r8 + mpyu r8,r10,DBL0L + breq r11,r9,.Linf_nan + breq r12,r9,.Linf_nan + mpyu r6,r6,r10 + add.cs r7,r7,1 + add.f r4,r4,r8 + mpyu r10,DBL1L,DBL0L + bclr r8,r9,30 ; 0x3ff00000 + adc.f r5,r5,r6 + ; XMAC write-back stall / std. mult stall is one cycle later + bclr r6,r9,20 ; 0x7fe00000 + add.cs r7,r7,1 ; fraction product in r7:r5:r4 + tst r10,r10 + bset.ne r4,r4,0 ; put least significant word into sticky bit + lsr.f r10,r7,9 + add_l r12,r12,r11 ; add exponents + rsub.eq r8,r8,r9 ; 0x40000000 + sub r12,r12,r8 ; subtract bias + implicit 1 + brhs.d r12,r6,.Linf_denorm + rsub r10,r10,12 +.Lshift_frac: + neg r8,r10 + asl r6,r4,r10 + lsr DBL0L,r4,r8 + add.f 0,r6,r6 + btst.eq DBL0L,0 + cmp.eq r4,r4 ; round to nearest / round to even + asl r4,r5,r10 + lsr r5,r5,r8 + adc.f DBL0L,DBL0L,r4 + xor.f 0,DBL0H,DBL1H + asl r7,r7,r10 + add_s r12,r12,r5 + adc DBL0H,r12,r7 + j_s.d [blink] + bset.mi DBL0H,DBL0H,31 + +/* We have checked for infinity / NaN input before, and transformed + denormalized inputs into normalized inputs. Thus, the worst case + exponent overflows are: + 1 + 1 - 0x400 == 0xc02 : maximum underflow + 0x7fe + 0x7fe - 0x3ff == 0xbfd ; maximum overflow + N.B. 0x7e and 0x7f are also values for overflow. + + If (r12 <= -54), we have an underflow to zero. */ + .balign 4 +.Linf_denorm: + brlo r12,0xc0000000,.Linf + asr r6,r12,20 + mov_s r12,0 + add.f r10,r10,r6 + brgt r10,0,.Lshift_frac + beq_s .Lround_frac + add.f r10,r10,32 +.Lshift32_frac: + tst r4,r4 + mov r4,r5 + bset.ne r4,r4,1 + mov r5,r7 + mov r7,0 + brge r10,1,.Lshift_frac + breq r10,0,.Lround_frac + add.f r10,r10,32 + brgt r10,21,.Lshift32_frac + b_s .Lret0 + +.Lround_frac: + add.f 0,r4,r4 + btst.eq r5,0 + mov_s DBL0L,r5 + mov_s DBL0H,r7 + adc.eq.f DBL0L,DBL0L,0 + j_s.d [blink] + + adc.eq DBL0H,DBL0H,0 + +.Linf: xor.f DBL1H,DBL1H,DBL0H + mov_s DBL0L,0 + mov_s DBL0H,r9 + j_s.d [blink] + bset.mi DBL0H,DBL0H,31 + ENDFUNC(__muldf3) + + .balign 4 +.L7ff00000: + .long 0x7ff00000 diff --git a/arch/arc/lib/ieee-754/mulsf3.S b/arch/arc/lib/ieee-754/mulsf3.S new file mode 100644 index 000000000000..23235ae9c4a5 --- /dev/null +++ b/arch/arc/lib/ieee-754/mulsf3.S @@ -0,0 +1,180 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* XMAC schedule: directly back-to-back multiplies stall; the third + instruction after a multiply stalls unless it is also a multiply. */ +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + .global __mulsf3 + FUNC(__mulsf3) + .balign 4 +__mulsf3: + push_s blink + push_s r1 + bl.d __mulsf3_c + push_s r0 + ld_s r1,[sp,4] + st_s r0,[sp,4] + bl.d __mulsf3_asm + pop_s r0 + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + and r12,r0,r1 + bic.f 0,0x7f800000,r12 + bne 0f + bmsk.f 0,r0,22 + bmsk.ne.f r1,r1,22 + jne_s [blink] ; both NaN -> OK +0: bl abort + ENDFUNC(__mulsf3) +#define __mulsf3 __mulsf3_asm +#endif /* DEBUG */ + + .balign 4 + .global __mulsf3 + FUNC(__mulsf3) +__mulsf3: + ld.as r9,[pcl,79]; [pcl,((.L7f800000-.+2)/4)] + bmsk r4,r1,22 + bset r2,r0,23 + asl_s r2,r2,8 + bset r3,r4,23 + MPYHU r6,r2,r3 + and r11,r0,r9 + breq r11,0,.Ldenorm_dbl0 + mpyu r7,r2,r3 + breq r11,r9,.Linf_nan_dbl0 + and r12,r1,r9 + asl.f 0,r6,8 + breq r12,0,.Ldenorm_dbl1 +.Lpast_denorm: + xor_s r0,r0,r1 +.Lpast_denorm_dbl1: + add.pl r6,r6,r6 + bclr.pl r6,r6,23 + add.pl.f r7,r7,r7 + ld.as r4,[pcl,64]; [pcl,((.L7fffffff-.+2)/4)] + add.cs r6,r6,1 + lsr.f 0,r6,1 + breq r12,r9,.Linf_nan_dbl1 + add_s r12,r12,r11 + adc.f 0,r7,r4 + add_s r12,r12, \ + -0x3f800000 + adc.f r8,r6,r12 + bic r0,r0,r4 + tst.pl r8,r9 + min r3,r8,r9 + jpnz.d [blink] + add.pnz r0,r0,r3 +; infinity or denormal number + add.ne.f r3,r3,r3 + bpnz .Linfinity + asr_s r3,r3,23+1 + bset r6,r6,23 + sub_s r3,r3,1 + neg_s r2,r3 + brhi r2,24,.Lret_r0 ; right shift shift > 24 -> return +-0 + lsr r2,r6,r2 + asl r9,r6,r3 + lsr.f 0,r2,1 + tst r7,r7 + add_s r0,r0,r2 + bset.ne r9,r9,0 + adc.f 0,r9,r4 + j_s.d [blink] + add.cs r0,r0,1 +.Linfinity: + j_s.d [blink] + add_s r0,r0,r9 + +.Lret_r0: j_s [blink] + + .balign 4 +.Linf_nan_dbl0: + sub_s r2,r1,1 ; inf/nan * 0 -> nan; inf * nan -> nan (use |r2| >= inf) + bic.f 0,r9,r2 + xor_s r0,r0,r1 + bclr_s r1,r1,31 + xor_s r0,r0,r1 + jne_s [blink] +.Lretnan: + j_s.d [blink] + mov r0,-1 +.Ldenorm_dbl0_inf_nan_dbl1: + bmsk.f 0,r0,30 + beq_s .Lretnan + xor_s r0,r0,r1 +.Linf_nan_dbl1: + xor_s r1,r1,r0 + bclr_s r1,r1,31 + j_s.d [blink] + xor_s r0,r0,r1 + + .balign 4 +.Ldenorm_dbl0: + bclr_s r2,r2,31 + norm.f r4,r2 + and r12,r1,r9 + add_s r2,r2,r2 + asl r2,r2,r4 + asl r4,r4,23 + MPYHU r6,r2,r3 + breq r12,r9,.Ldenorm_dbl0_inf_nan_dbl1 + sub.ne.f r12,r12,r4 + mpyu r7,r2,r3 + bhi.d .Lpast_denorm + asl.f 0,r6,8 + xor_s r0,r0,r1 + bmsk r1,r0,30 + j_s.d [blink] + bic_l r0,r0,r1 + + .balign 4 +.Ldenorm_dbl1: + norm.f r3,r4 + xor_s r0,r0,r1 + sub_s r3,r3,7 + asl r4,r4,r3 + sub_s r3,r3,1 + asl_s r3,r3,23 + MPYHU r6,r2,r4 + sub.ne.f r11,r11,r3 + bmsk r8,r0,30 + mpyu r7,r2,r4 + bhi.d .Lpast_denorm_dbl1 + asl.f 0,r6,8 + j_s.d [blink] + bic r0,r0,r8 + + .balign 4 +.L7f800000: + .long 0x7f800000 +.L7fffffff: + .long 0x7fffffff + ENDFUNC(__mulsf3) diff --git a/arch/arc/lib/ieee-754/orddf2.S b/arch/arc/lib/ieee-754/orddf2.S new file mode 100644 index 000000000000..98fe9d987839 --- /dev/null +++ b/arch/arc/lib/ieee-754/orddf2.S @@ -0,0 +1,63 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +/* inputs: r0, r1 + output: c flag + clobber: r12, flags + For NaNs, bit 19 .. bit 30 must be set. */ +#if 0 /* DEBUG */ + .global __orddf2 + .balign 4 + FUNC(__orddf2) +__orddf2: + st.a r11,[sp,-4]` push_s blink` st.a r10,[sp,-4]` st.a r9,[sp,-4] + st.a r8,[sp,-4]` st.a r7,[sp,-4]` st.a r6,[sp,-4]` st.a r5,[sp,-4] + st.a r4,[sp,-4]` push_s r3` push_s r2` push_s r1` + bl.d __unorddf2_c` push_s r0 + mov r11,r0` pop_s r0` pop_s r1` pop_s r2` pop_s r3 + ld.ab r4,[sp,4]` ld.ab r5,[sp,4]` ld.ab r6,[sp,4]` + ld.ab r7,[sp,4]` ld.ab r8,[sp,4]` ld.ab r9,[sp,4] + bl.d __orddf2_asm` ld.ab r10,[sp,4] + pop_s blink + brne.d r11,0,0f + ld.ab r11,[sp,4] + jcc [blink] + bl abort +0: jcs [blink] + bl abort + ENDFUNC(__orddf2) +#define __orddf2 __orddf2_asm +#endif /* DEBUG */ + .global __orddf2 + .balign 4 + HIDDEN_FUNC(__orddf2) +__orddf2: + bmsk r12,DBL0H,20 + add1.f r12,r12,DBL0H /* clear z; set c if NaN. */ + bmsk r12,DBL1H,20 + j_s.d [blink] + add1.cc.f r12,r12,DBL1H /* clear z; set c if NaN. */ + ENDFUNC(__orddf2) diff --git a/arch/arc/lib/ieee-754/ordsf2.S b/arch/arc/lib/ieee-754/ordsf2.S new file mode 100644 index 000000000000..e913230fcf43 --- /dev/null +++ b/arch/arc/lib/ieee-754/ordsf2.S @@ -0,0 +1,63 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +/* inputs: r0, r1 + output: c flag + clobber: r12, flags + For NaNs, bit 22 .. bit 30 must be set. */ +#if 0 /* DEBUG */ + .global __ordsf2 + .balign 4 + FUNC(__ordsf2) +__ordsf2: + st.a r11,[sp,-4]` push_s blink` st.a r10,[sp,-4]` st.a r9,[sp,-4] + st.a r8,[sp,-4]` st.a r7,[sp,-4]` st.a r6,[sp,-4]` st.a r5,[sp,-4] + st.a r4,[sp,-4]` push_s r3` push_s r2` push_s r1` + bl.d __unordsf2_c` push_s r0 + mov r11,r0` pop_s r0` pop_s r1` pop_s r2` pop_s r3 + ld.ab r4,[sp,4]` ld.ab r5,[sp,4]` ld.ab r6,[sp,4]` + ld.ab r7,[sp,4]` ld.ab r8,[sp,4]` ld.ab r9,[sp,4] + bl.d __ordsf2_asm` ld.ab r10,[sp,4] + pop_s blink + brne.d r11,0,0f + ld.ab r11,[sp,4] + jcc [blink] + bl abort +0: jcs [blink] + bl abort + ENDFUNC(__ordsf2) +#define __ordsf2 __ordsf2_asm +#endif /* DEBUG */ + .global __ordsf2 + .balign 4 + HIDDEN_FUNC(__ordsf2) +__ordsf2: + bmsk r12,r0,23 + add1.f r12,r12,r0 /* clear z; set c if NaN. */ + bmsk r12,r1,23 + j_s.d [blink] + add1.cc.f r12,r12,r1 /* clear z; set c if NaN. */ + ENDFUNC(__ordsf2) diff --git a/arch/arc/lib/ieee-754/truncdfsf2.S b/arch/arc/lib/ieee-754/truncdfsf2.S new file mode 100644 index 000000000000..d4acc3f1c40c --- /dev/null +++ b/arch/arc/lib/ieee-754/truncdfsf2.S @@ -0,0 +1,134 @@ +/* Copyright (C) 2006-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" + +#if 0 /* DEBUG */ + FUNC(__truncdfsf2) + .global __truncdfsf2 + .balign 4 +__truncdfsf2: + push_s blink + push_s r0 + bl.d __truncdfsf2_c + push_s r1 + mov_s r2,r0 + pop_s r1 + ld r0,[sp] + bl.d __truncdfsf2_asm + st r2,[sp] + pop_s r1 + pop_s blink + cmp r0,r1 + jeq_s [blink] + and r12,r0,r1 + bic.f 0,0x7f800000,r12 + bne 0f + bmsk.f 0,r0,22 + bmsk.ne.f r1,r1,22 + jne_s [blink] ; both NaN -> OK +0: bl abort + ENDFUNC(__truncdfsf2) +#define __truncdfsf2 __truncdfsf2_asm +#endif /* DEBUG */ + + .global __truncdfsf2 + .balign 4 + FUNC(__truncdfsf2) +__truncdfsf2: + lsr r2,DBL0H,20 + asl_s DBL0H,DBL0H,12 + sub r12,r2,0x380 + bclr.f r3,r12,11 + brhs r3,0xff,.Lill_exp + beq_l .Ldenorm0 + asl_s r12,r12,23 + tst DBL0L, \ + 0x2fffffff /* Check if msb guard bit wants rounding up. */ + lsr_s DBL0L,DBL0L,28 + lsr_s DBL0H,DBL0H,8 + add.ne DBL0L,DBL0L,1 + add_s DBL0H,DBL0H,DBL0L + lsr_s DBL0H,DBL0H + btst_s r2,11 + add_s r0,DBL0H,r12 + j_s.d [blink] + bxor.ne r0,r0,31 + .balign 4 +.Lill_exp: + bbit1 r2,10,.Linf_nan + bmsk_s r12,r12,9 + rsub.f r12,r12,8+0x400-32 ; Go from 9 to 1 guard bit in MSW. */ + bhs_s .Lzero + lsr r3,DBL0L,21 + rrc DBL0H,DBL0H ; insert leading 1 + asl.f 0,DBL0L,8 ; check lower 24 guard bits + add_s r3,DBL0H,r3 + add.pnz r3,r3,1 ; assemble fraction with compressed guard bits. + lsr r0,r3,r12 + neg_s r12,r12 + btst_s r0,1 + asl.eq.f r3,r3,r12 + add.ne r0,r0,1 + btst_s r2,11 + lsr_s r0,r0 + j_s.d [blink] + bxor.ne r0,r0,31 +.Lzero: + lsr_s r2,r2,11 + j_s.d [blink] + asl r0,r2,31 +.Ldenorm0: + asl_s r12,r12,20 + tst DBL0L, \ + 0x5fffffff /* Check if msb guard bit wants rounding up. */ + lsr_s DBL0L,DBL0L,29 + lsr_s DBL0H,DBL0H,9 + add.ne DBL0L,DBL0L,1 + bset_s DBL0H,DBL0H,23 + add_s DBL0H,DBL0H,DBL0L + lsr_s DBL0H,DBL0H + j_s.d [blink] + add_l r0,DBL0H,r12 + +/* We would generally say that NaNs must have a non-zero high fraction part, + but to allow hardware double precision floating point to interoperate + with single precision software floating point, we make an exception here. + The cost is to replace a tst_s DBL0H with an or.f DBL0L,DBL0L,DBL0H . + As we start out unaligned, and there is an odd number of other short insns, + we have a choice of letting this cost us a misalign penalty or + 4 more bytes (if we align the code). We choose the former here because + infinity / NaN is not expected to be prevalent in time-critical code. */ +.Linf_nan: + or.f DBL0L,DBL0L,DBL0H + mov_s r0,1 + add.ne r2,r2,1 + tst r2,0x7ff + asl.ne r0,r0,23 + btst_s r12,11 + neg r0,r0 + j_s.d [blink] + bxor.eq r0,r0,31 + ENDFUNC(__truncdfsf2) diff --git a/arch/arc/lib/ieee-754/uneqdf2.S b/arch/arc/lib/ieee-754/uneqdf2.S new file mode 100644 index 000000000000..de6ba46ce168 --- /dev/null +++ b/arch/arc/lib/ieee-754/uneqdf2.S @@ -0,0 +1,73 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +/* inputs: DBL0, DBL1 + output: z flag + clobber: r12, flags + For NaNs, bit 19.. bit 30 of the high word must be set. */ +#if 0 /* DEBUG */ + .global __uneqdf2 + .balign 4 + FUNC(__uneqdf2) +__uneqdf2: + st.a r11,[sp,-4]` push_s blink` st.a r10,[sp,-4]` st.a r9,[sp,-4] + st.a r8,[sp,-4]` st.a r7,[sp,-4]` st.a r6,[sp,-4]` st.a r5,[sp,-4] + st.a r4,[sp,-4]` push_s r3` push_s r2` push_s r1` + bl.d __eqdf2_c` push_s r0 + push_s r0` ld_s r0, [sp,4]` ld_s r1, [sp,8]` ld_s r2,[sp,12] + bl.d __unorddf2_c` ld_s r3,[sp,16] + ld.ab r11,[sp,4]` tst r0,r0` mov.ne r11,0 + pop_s r0` pop_s r1` pop_s r2` pop_s r3 + ld.ab r4,[sp,4]` ld.ab r5,[sp,4]` ld.ab r6,[sp,4]` + ld.ab r7,[sp,4]` ld.ab r8,[sp,4]` ld.ab r9,[sp,4] + bl.d __uneqdf2_asm` ld.ab r10,[sp,4] + pop_s blink + breq.d r11,0,0f + ld.ab r11,[sp,4] + jne_s [blink] + bl abort +0: jeq_s [blink] + bl abort + ENDFUNC(__uneqdf2) +#define __uneqdf2 __uneqdf2_asm +#endif /* DEBUG */ + .global __uneqdf2 + .balign 4 + HIDDEN_FUNC(__uneqdf2) +__uneqdf2: + cmp_s DBL0H,DBL1H + cmp.eq DBL0L,DBL1L + jeq_s [blink] + or r12,DBL0H,DBL1H + or.f 0,DBL0L,DBL1L + bclr.eq.f r12,r12,31 + jeq_s [blink] + mov_s r12, \ + 0x7ff80000 + bic.f 0,r12,DBL0H + j_s.d [blink] + bic.ne.f r12,r12,DBL1H + ENDFUNC(__uneqdf2) diff --git a/arch/arc/lib/ieee-754/uneqsf2.S b/arch/arc/lib/ieee-754/uneqsf2.S new file mode 100644 index 000000000000..d528785d18f9 --- /dev/null +++ b/arch/arc/lib/ieee-754/uneqsf2.S @@ -0,0 +1,69 @@ +/* Copyright (C) 2008-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +#include "arc-ieee-754.h" +/* inputs: r0, r1 + output: z flag + clobber: r12, flags + For NaNs, bit 22 .. bit 30 must be set. */ +#if 0 /* DEBUG */ + .global __uneqsf2 + .balign 4 + FUNC(__uneqsf2) +__uneqsf2: + st.a r11,[sp,-4]` push_s blink` st.a r10,[sp,-4]` st.a r9,[sp,-4] + st.a r8,[sp,-4]` st.a r7,[sp,-4]` st.a r6,[sp,-4]` st.a r5,[sp,-4] + st.a r4,[sp,-4]` push_s r3` push_s r2` push_s r1` + bl.d __eqsf2_c` push_s r0 + push_s r0` ld_s r0, [sp,4] + bl.d __unordsf2_c` ld_s r1,[sp,8] + ld.ab r11,[sp,4]` tst r0,r0` mov.ne r11,0 + pop_s r0` pop_s r1` pop_s r2` pop_s r3 + ld.ab r4,[sp,4]` ld.ab r5,[sp,4]` ld.ab r6,[sp,4]` + ld.ab r7,[sp,4]` ld.ab r8,[sp,4]` ld.ab r9,[sp,4] + bl.d __uneqsf2_asm` ld.ab r10,[sp,4] + pop_s blink + breq.d r11,0,0f + ld.ab r11,[sp,4] + jne_s [blink] + bl abort +0: jeq_s [blink] + bl abort + ENDFUNC(__uneqsf2) +#define __uneqsf2 __uneqsf2_asm +#endif /* DEBUG */ + .global __uneqsf2 + .balign 4 + HIDDEN_FUNC(__uneqsf2) +__uneqsf2: + mov_s r12, \ + 0x7fc00000 + bic.f 0,r12,r0 + bic.ne.f r12,r12,r1 + or r12,r0,r1 + bmsk.ne.f r12,r12,30 + j_s.d [blink] + cmp.ne r0,r1 + ENDFUNC(__uneqsf2) diff --git a/arch/arc/lib/lib1funcs.S b/arch/arc/lib/lib1funcs.S new file mode 100644 index 000000000000..9a6260226120 --- /dev/null +++ b/arch/arc/lib/lib1funcs.S @@ -0,0 +1,1430 @@ +; libgcc1 routines for Synopsys DesignWare ARC cpu. + +/* Copyright (C) 1995-2018 Free Software Foundation, Inc. + Contributor: Joern Rennecke joern.rennecke@embecosm.com + on behalf of Synopsys Inc. + +This file is part of GCC. + +GCC is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free +Software Foundation; either version 3, or (at your option) any later +version. + +GCC is distributed in the hope that it will be useful, but WITHOUT ANY +WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +Under Section 7 of GPL version 3, you are granted additional +permissions described in the GCC Runtime Library Exception, version +3.1, as published by the Free Software Foundation. + +You should have received a copy of the GNU General Public License and +a copy of the GCC Runtime Library Exception along with this program; +see the files COPYING3 and COPYING.RUNTIME respectively. If not, see +http://www.gnu.org/licenses/. */ + +/* As a special exception, if you link this library with other files, + some of which are compiled with GCC, to produce an executable, + this library does not by itself cause the resulting executable + to be covered by the GNU General Public License. + This exception does not however invalidate any other reasons why + the executable file might be covered by the GNU General Public License. */ + + + /* ANSI concatenation macros. */ + + #define CONCAT1(a, b) CONCAT2(a, b) + #define CONCAT2(a, b) a ## b + + /* Use the right prefix for global labels. */ + + #define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x) + +#ifndef WORKING_ASSEMBLER +#define abs_l abs +#define asl_l asl +#define mov_l mov +#endif + +#define FUNC(X) .type SYM(X),@function +#define HIDDEN_FUNC(X) FUNC(X)` .hidden X +#define ENDFUNC0(X) .Lfe_##X: .size X,.Lfe_##X-X +#define ENDFUNC(X) ENDFUNC0(X) + + + +#ifdef L_mulsi3 + .section .text + .align 4 + + .global SYM(__mulsi3) +SYM(__mulsi3): + +/* This the simple version. + + while (a) + { + if (a & 1) + r += b; + a >>= 1; + b <<= 1; + } +*/ + +#if defined (__ARC_MUL64__) + FUNC(__mulsi3) + mulu64 r0,r1 + j_s.d [blink] + mov_s r0,mlo + ENDFUNC(__mulsi3) +#elif defined (__ARC_MPY__) + HIDDEN_FUNC(__mulsi3) + mpyu r0,r0,r1 + nop_s + j_s [blink] + ENDFUNC(__mulsi3) +#elif defined (__ARC_NORM__) + FUNC(__mulsi3) + norm.f r2,r0 + rsub lp_count,r2,31 + mov.mi lp_count,32 + mov_s r2,r0 + mov_s r0,0 + lpnz @.Lend ; loop is aligned + lsr.f r2,r2 + add.cs r0,r0,r1 + add_s r1,r1,r1 +.Lend: j_s [blink] + ENDFUNC(__mulsi3) +#elif !defined (__OPTIMIZE_SIZE__) && defined (__ARC_BARREL_SHIFTER__) + /* Up to 3.5 times faster than the simpler code below, but larger. */ + FUNC(__mulsi3) + ror.f r2,r0,4 + mov_s r0,0 + add3.mi r0,r0,r1 + asl.f r2,r2,2 + add2.cs r0,r0,r1 + jeq_s [blink] +.Loop: + add1.mi r0,r0,r1 + asl.f r2,r2,2 + add.cs r0,r0,r1 + asl_s r1,r1,4 + ror.f r2,r2,8 + add3.mi r0,r0,r1 + asl.f r2,r2,2 + bne.d .Loop + add2.cs r0,r0,r1 + j_s [blink] + ENDFUNC(__mulsi3) +#elif !defined (__OPTIMIZE_SIZE__) /* __ARC601__ */ + FUNC(__mulsi3) + lsr.f r2,r0 + mov_s r0,0 + mov_s r3,0 + add.cs r0,r0,r1 +.Loop: + lsr.f r2,r2 + add1.cs r0,r0,r1 + lsr.f r2,r2 + add2.cs r0,r0,r1 + lsr.f r2,r2 + add3.cs r0,r0,r1 + bne.d .Loop + add3 r1,r3,r1 + j_s [blink] + ENDFUNC(__mulsi3) +#else +/********************************************************/ + FUNC(__mulsi3) + mov_s r2,0 ; Accumulate result here. +.Lloop: + bbit0 r0,0,@.Ly + add_s r2,r2,r1 ; r += b +.Ly: + lsr_s r0,r0 ; a >>= 1 + asl_s r1,r1 ; b <<= 1 + brne_s r0,0,@.Lloop +.Ldone: + j_s.d [blink] + mov_s r0,r2 + ENDFUNC(__mulsi3) +/********************************************************/ +#endif + +#endif /* L_mulsi3 */ + +#ifdef L_umulsidi3 + .section .text + .align 4 + + .global SYM(__umulsidi3) +SYM(__umulsidi3): + HIDDEN_FUNC(__umulsidi3) +/* We need ARC700 /ARC_MUL64 definitions of __umulsidi3 / __umulsi3_highpart + in case some code has been compiled without multiply support enabled, + but linked with the multiply-support enabled libraries. + For ARC601 (i.e. without a barrel shifter), we also use umuldisi3 as our + umulsi3_highpart implementation; the use of the latter label doesn't + actually benefit ARC601 platforms, but is useful when ARC601 code is linked + against other libraries. */ +#if defined (__ARC_MPY__) || defined (__ARC_MUL64__) \ + || !defined (__ARC_BARREL_SHIFTER__) + .global SYM(__umulsi3_highpart) +SYM(__umulsi3_highpart): + HIDDEN_FUNC(__umulsi3_highpart) +#endif + +/* This the simple version. + + while (a) + { + if (a & 1) + r += b; + a >>= 1; + b <<= 1; + } +*/ +#include "ieee-754/arc-ieee-754.h" + +#ifdef __ARC_MPY__ + mov_s r12,DBL0L + mpyu DBL0L,r12,DBL0H + j_s.d [blink] + MPYHU DBL0H,r12,DBL0H +#elif defined (__ARC_MUL64__) +/* Likewise for __ARC_MUL64__ */ + mulu64 r0,r1 + mov_s DBL0L,mlo + j_s.d [blink] + mov_s DBL0H,mhi +#else /* !__ARC_MPY__ && !__ARC_MUL64__ */ +/* Although it might look tempting to extend this to handle muldi3, + using mulsi3 twice with 2.25 cycles per 32 bit add is faster + than one loop with 3 or four cycles per 32 bit add. */ + asl.f r12,0 ; Top part of b. + mov_s r2,0 ; Accumulate result here. + bbit1.d r0,0,@.Ladd + mov_s r3,0 +.Llooptst: + rlc r12,r12 + breq r0,0,@.Ldone ; while (a) +.Lloop: + asl.f r1,r1 ; b <<= 1 + bbit0.d r0,1,@.Llooptst + lsr r0,r0 ; a >>= 1 + rlc r12,r12 +.Ladd: + add.f r3,r3,r1 ; r += b + brne.d r0,0,@.Lloop ; while (a); + adc r2,r2,r12 +.Ldone: + mov_s DBL0L,r3 + j_s.d [blink] + mov DBL0H,r2 +#endif /* !__ARC_MPY__*/ + ENDFUNC(__umulsidi3) +#if defined (__ARC_MPY__) || defined (__ARC_MUL64__) \ + || !defined (__ARC_BARREL_SHIFTER__) + ENDFUNC(__umulsi3_highpart) +#endif +#endif /* L_umulsidi3 */ + +#ifdef L_umulsi3_highpart +#include "ieee-754/arc-ieee-754.h" +/* For use without a barrel shifter, and for ARC700 / ARC_MUL64, the + mulsidi3 algorithms above look better, so for these, there is an + extra label up there. */ +#if !defined (__ARC_MPY__) && !defined (__ARC_MUL64__) \ + && defined (__ARC_BARREL_SHIFTER__) + .global SYM(__umulsi3_highpart) +SYM(__umulsi3_highpart): + HIDDEN_FUNC(__umulsi3_highpart) + mov_s r2,0 + mov_s r3,32 +.Loop: + lsr.f r0,r0 + add.cs.f r2,r2,r1 + sub_s r3,r3,1 + brne.d r0,0,.Loop + rrc r2,r2 + j_s.d [blink] +/* Make the result register peephole-compatible with mulsidi3. */ + lsr DBL0H,r2,r3 + ENDFUNC(__umulsi3_highpart) +#endif /* !__ARC_MPY__ && __ARC_BARREL_SHIFTER__ */ +#endif /* L_umulsi3_highpart */ + +#ifdef L_divmod_tools + +; Utilities used by all routines. + + .section .text + +/* +unsigned long +udivmodsi4(int modwanted, unsigned long num, unsigned long den) +{ + unsigned long bit = 1; + unsigned long res = 0; + + while (den < num && bit && !(den & (1L<<31))) + { + den <<=1; + bit <<=1; + } + while (bit) + { + if (num >= den) + { + num -= den; + res |= bit; + } + bit >>=1; + den >>=1; + } + if (modwanted) return num; + return res; +} +*/ + +; inputs: r0 = numerator, r1 = denominator +; outputs: r0 = quotient, r1 = remainder, r2/r3 trashed + + .balign 4 + .global SYM(__udivmodsi4) + FUNC(__udivmodsi4) +SYM(__udivmodsi4): + +#if defined (__ARC_EA__) +/* Normalize divisor and divident, and then use the appropriate number of + divaw (the number of result bits, or one more) to produce the result. + There are some special conditions that need to be tested: + - We can only directly normalize unsigned numbers that fit in 31 bit. For + the divisor, we test early on that it is not 'negative'. + - divaw can't corrrectly process a divident that is larger than the divisor. + We handle this be checking that the divident prior to normalization is + not larger than the normalized divisor. As we then already know then + that the divisor fits 31 bit, this check also makes sure that the + divident fits. + - ordinary normalization of the divident could make it larger than the + normalized divisor, which again would be unsuitable for divaw. + Thus, we want to shift left the divident by one less, except that we + want to leave it alone if it is already 31 bit. To this end, we + double the input to norm with adds. + - If the divident has less bits than the divisor, that would leave us + with a negative number of divaw to execute. Although we could use a + conditional loop to avoid excess divaw, and then the quotient could + be extracted correctly as there'd be more than enough zero bits, the + remainder would be shifted left too far, requiring a conditional shift + right. The cost of that shift and the possible mispredict on the + conditional loop cost as much as putting in an early check for a zero + result. */ + bmsk r3,r0,29 + brne.d r3,r0,.Large_dividend + norm.f r2,r1 + brlo r0,r1,.Lret0 + norm r3,r0 + asl_s r1,r1,r2 + sub_s r3,r3,1 + asl_l r0,r0,r3 ; not short to keep loop aligned + sub lp_count,r2,r3 + lp .Ldiv_end + divaw r0,r0,r1 +.Ldiv_end:sub_s r3,r2,1 + lsr r1,r0,r2 + j_s.d [blink] + bmsk r0,r0,r3 + + .balign 4 +.Large_dividend: + bmi .Ltrivial + asl_s r1,r1,r2 + mov_s r3,0 + sub1.f r4,r0,r1 + mov.lo r4,r0 + mov.hs r3,2 + cmp r4,r1 + sub.hs r4,r4,r1 + add.hs r3,r3,1 + mov.f lp_count,r2 + lpne .Ldiv_end2 + divaw r4,r4,r1 +.Ldiv_end2:asl r0,r3,r2 + lsr r1,r4,r2 + sub_s r2,r2,1 + bmsk r4,r4,r2 + j_s.d [blink] + or.ne r0,r0,r4 + +.Lret0: + mov_s r1,r0 + j_s.d [blink] + mov_l r0,0 + .balign 4 +.Ltrivial: + sub.f r1,r0,r1 + mov.c r1,r0 + mov_s r0,1 + j_s.d [blink] + mov.c r0,0 +#elif !defined (__OPTIMIZE_SIZE__) && !defined (__ARC_RF16__) +#if defined (__ARC_NORM__) && defined (__ARC_BARREL_SHIFTER__) + lsr_s r2,r0 + brhs.d r1,r2,.Lret0_3 + norm r2,r2 + norm r3,r1 + sub_s r3,r3,r2 + asl_s r1,r1,r3 + sub1.f 0,r0,r1 + lsr.cs r1,r1,1 + sbc r2,r3,0 + sub1 r0,r0,r1 + cmp_s r0,r1 + mov.f lp_count,r2 +#else /* ! __ARC_NORM__ */ + lsr_s r2,r0 + brhs.d r1,r2,.Lret0_3 + mov lp_count,32 +.Lloop1: + asl_s r1,r1 ; den <<= 1 + brls.d r1,r2,@.Lloop1 + sub lp_count,lp_count,1 + sub_s r0,r0,r1 + lsr_s r1,r1 + cmp_s r0,r1 + xor.f r2,lp_count,31 +#if !defined (__ARCEM__) && !defined (__ARCHS__) + mov_s lp_count,r2 +#else + mov lp_count,r2 + nop_s +#endif /* !__ARCEM__ && !__ARCHS__ */ +#endif /* !__ARC_NORM__ */ + sub.cc r0,r0,r1 + mov_s r3,3 + sbc r3,r3,0 +#if defined (__ARC_BARREL_SHIFTER__) + asl_s r3,r3,r2 + rsub r1,r1,1 + lpne @.Lloop2_end + add1.f r0,r1,r0 + sub.cc r0,r0,r1 +.Lloop2_end: + lsr r1,r0,r2 +#else + rsub r1,r1,1 + lpne @.Lloop2_end + asl_s r3,r3 + add1.f r0,r1,r0 + sub.cc r0,r0,r1 +.Lloop2_end: + lsr_s r1,r0 + lsr.f lp_count,r2 + mov.cc r1,r0 + lpnz 1f + lsr_s r1,r1 + lsr_s r1,r1 +1: +#endif + bmsk r0,r0,r2 + bclr r0,r0,r2 + j_s.d [blink] + or_s r0,r0,r3 +.Lret0_3: +#if 0 /* Slightly shorter, but slower. */ + lp .Loop3_end + brhi.d r1,r0,.Loop3_end + sub_s r0,r0,r1 +.Loop3_end + add_s r1,r1,r0 + j_s.d [blink] + rsub r0,lp_count,32-1 +#else + mov_s r4,r1 + sub.f r1,r0,r1 + sbc r0,r0,r0 + sub.cc.f r1,r1,r4 + sbc r0,r0,0 + sub.cc.f r1,r1,r4 + sbc r0,r0,-3 + j_s.d [blink] + add.cs r1,r1,r4 +#endif +#else /* Arctangent-A5 */ + breq_s r1,0,@.Ldivmodend + mov_s r2,1 ; bit = 1 + mov_s r3,0 ; res = 0 +.Lloop1: + brhs r1,r0,@.Lloop2 + bbit1 r1,31,@.Lloop2 + asl_s r1,r1 ; den <<= 1 + b.d @.Lloop1 + asl_s r2,r2 ; bit <<= 1 +.Lloop2: + brlo r0,r1,@.Lshiftdown + sub_s r0,r0,r1 ; num -= den + or_s r3,r3,r2 ; res |= bit +.Lshiftdown: + lsr_s r2,r2 ; bit >>= 1 + lsr_s r1,r1 ; den >>= 1 + brne_s r2,0,@.Lloop2 +.Ldivmodend: + mov_s r1,r0 ; r1 = mod + j.d [blink] + mov_s r0,r3 ; r0 = res +/******************************************************/ +#endif + ENDFUNC(__udivmodsi4) + +#endif + +#ifdef L_udivsi3 + .section .text + .align 4 + + .global SYM(__udivsi3) + FUNC(__udivsi3) +SYM(__udivsi3): + b @SYM(__udivmodsi4) + ENDFUNC(__udivsi3) +#if 0 /* interferes with linux loader */ + .section .__arc_profile_forward, "a" + .long SYM(__udivsi3) + .long SYM(__udivmodsi4) + .long 65536 +#endif + +#endif /* L_udivsi3 */ + +#ifdef L_divsi3 + .section .text + .align 4 + + .global SYM(__divsi3) + FUNC(__divsi3) + +#ifndef __ARC_EA__ +SYM(__divsi3): + /* A5 / ARC60? */ + mov r12,blink + xor r11,r0,r1 + abs_s r0,r0 + bl.d @SYM(__udivmodsi4) + abs_s r1,r1 + tst r11,r11 + j.d [r12] + neg.mi r0,r0 +#else /* !ifndef __ARC_EA__ */ + ;; We can use the abs, norm, divaw and mpy instructions for ARC700 +#define MULDIV +#ifdef MULDIV +/* This table has been generated by divtab-arc700.c. */ +/* 1/512 .. 1/256, normalized. There is a leading 1 in bit 31. + For powers of two, we list unnormalized numbers instead. The values + for powers of 2 are loaded, but not used. The value for 1 is actually + the first instruction after .Lmuldiv. */ + .balign 4 +.Ldivtab: + + .long 0x1000000 + .long 0x80808081 + .long 0x81020409 + .long 0x81848DA9 + .long 0x82082083 + .long 0x828CBFBF + .long 0x83126E98 + .long 0x83993053 + .long 0x84210843 + .long 0x84A9F9C9 + .long 0x85340854 + .long 0x85BF3762 + .long 0x864B8A7E + .long 0x86D90545 + .long 0x8767AB60 + .long 0x87F78088 + .long 0x88888889 + .long 0x891AC73B + .long 0x89AE408A + .long 0x8A42F871 + .long 0x8AD8F2FC + .long 0x8B70344B + .long 0x8C08C08D + .long 0x8CA29C05 + .long 0x8D3DCB09 + .long 0x8DDA5203 + .long 0x8E78356E + .long 0x8F1779DA + .long 0x8FB823EF + .long 0x905A3864 + .long 0x90FDBC0A + .long 0x91A2B3C5 + .long 0x92492493 + .long 0x92F11385 + .long 0x939A85C5 + .long 0x94458095 + .long 0x94F20950 + .long 0x95A02569 + .long 0x964FDA6D + .long 0x97012E03 + .long 0x97B425EE + .long 0x9868C80A + .long 0x991F1A52 + .long 0x99D722DB + .long 0x9A90E7DA + .long 0x9B4C6F9F + .long 0x9C09C09D + .long 0x9CC8E161 + .long 0x9D89D89E + .long 0x9E4CAD24 + .long 0x9F1165E8 + .long 0x9FD809FE + .long 0xA0A0A0A1 + .long 0xA16B312F + .long 0xA237C32C + .long 0xA3065E40 + .long 0xA3D70A3E + .long 0xA4A9CF1E + .long 0xA57EB503 + .long 0xA655C43A + .long 0xA72F053A + .long 0xA80A80A9 + .long 0xA8E83F58 + .long 0xA9C84A48 + .long 0xAAAAAAAB + .long 0xAB8F69E3 + .long 0xAC769185 + .long 0xAD602B59 + .long 0xAE4C415D + .long 0xAF3ADDC7 + .long 0xB02C0B03 + .long 0xB11FD3B9 + .long 0xB21642C9 + .long 0xB30F6353 + .long 0xB40B40B5 + .long 0xB509E68B + .long 0xB60B60B7 + .long 0xB70FBB5B + .long 0xB81702E1 + .long 0xB92143FB + .long 0xBA2E8BA3 + .long 0xBB3EE722 + .long 0xBC52640C + .long 0xBD691048 + .long 0xBE82FA0C + .long 0xBFA02FE9 + .long 0xC0C0C0C1 + .long 0xC1E4BBD6 + .long 0xC30C30C4 + .long 0xC4372F86 + .long 0xC565C87C + .long 0xC6980C6A + .long 0xC7CE0C7D + .long 0xC907DA4F + .long 0xCA4587E7 + .long 0xCB8727C1 + .long 0xCCCCCCCD + .long 0xCE168A78 + .long 0xCF6474A9 + .long 0xD0B69FCC + .long 0xD20D20D3 + .long 0xD3680D37 + .long 0xD4C77B04 + .long 0xD62B80D7 + .long 0xD79435E6 + .long 0xD901B204 + .long 0xDA740DA8 + .long 0xDBEB61EF + .long 0xDD67C8A7 + .long 0xDEE95C4D + .long 0xE070381D + .long 0xE1FC780F + .long 0xE38E38E4 + .long 0xE525982B + .long 0xE6C2B449 + .long 0xE865AC7C + .long 0xEA0EA0EB + .long 0xEBBDB2A6 + .long 0xED7303B6 + .long 0xEF2EB720 + .long 0xF0F0F0F1 + .long 0xF2B9D649 + .long 0xF4898D60 + .long 0xF6603D99 + .long 0xF83E0F84 + .long 0xFA232CF3 + .long 0xFC0FC0FD + .long 0xFE03F810 + .long 0x2000000 + .long 0x81020409 + .long 0x82082083 + .long 0x83126E98 + .long 0x84210843 + .long 0x85340854 + .long 0x864B8A7E + .long 0x8767AB60 + .long 0x88888889 + .long 0x89AE408A + .long 0x8AD8F2FC + .long 0x8C08C08D + .long 0x8D3DCB09 + .long 0x8E78356E + .long 0x8FB823EF + .long 0x90FDBC0A + .long 0x92492493 + .long 0x939A85C5 + .long 0x94F20950 + .long 0x964FDA6D + .long 0x97B425EE + .long 0x991F1A52 + .long 0x9A90E7DA + .long 0x9C09C09D + .long 0x9D89D89E + .long 0x9F1165E8 + .long 0xA0A0A0A1 + .long 0xA237C32C + .long 0xA3D70A3E + .long 0xA57EB503 + .long 0xA72F053A + .long 0xA8E83F58 + .long 0xAAAAAAAB + .long 0xAC769185 + .long 0xAE4C415D + .long 0xB02C0B03 + .long 0xB21642C9 + .long 0xB40B40B5 + .long 0xB60B60B7 + .long 0xB81702E1 + .long 0xBA2E8BA3 + .long 0xBC52640C + .long 0xBE82FA0C + .long 0xC0C0C0C1 + .long 0xC30C30C4 + .long 0xC565C87C + .long 0xC7CE0C7D + .long 0xCA4587E7 + .long 0xCCCCCCCD + .long 0xCF6474A9 + .long 0xD20D20D3 + .long 0xD4C77B04 + .long 0xD79435E6 + .long 0xDA740DA8 + .long 0xDD67C8A7 + .long 0xE070381D + .long 0xE38E38E4 + .long 0xE6C2B449 + .long 0xEA0EA0EB + .long 0xED7303B6 + .long 0xF0F0F0F1 + .long 0xF4898D60 + .long 0xF83E0F84 + .long 0xFC0FC0FD + .long 0x4000000 + .long 0x82082083 + .long 0x84210843 + .long 0x864B8A7E + .long 0x88888889 + .long 0x8AD8F2FC + .long 0x8D3DCB09 + .long 0x8FB823EF + .long 0x92492493 + .long 0x94F20950 + .long 0x97B425EE + .long 0x9A90E7DA + .long 0x9D89D89E + .long 0xA0A0A0A1 + .long 0xA3D70A3E + .long 0xA72F053A + .long 0xAAAAAAAB + .long 0xAE4C415D + .long 0xB21642C9 + .long 0xB60B60B7 + .long 0xBA2E8BA3 + .long 0xBE82FA0C + .long 0xC30C30C4 + .long 0xC7CE0C7D + .long 0xCCCCCCCD + .long 0xD20D20D3 + .long 0xD79435E6 + .long 0xDD67C8A7 + .long 0xE38E38E4 + .long 0xEA0EA0EB + .long 0xF0F0F0F1 + .long 0xF83E0F84 + .long 0x8000000 + .long 0x84210843 + .long 0x88888889 + .long 0x8D3DCB09 + .long 0x92492493 + .long 0x97B425EE + .long 0x9D89D89E + .long 0xA3D70A3E + .long 0xAAAAAAAB + .long 0xB21642C9 + .long 0xBA2E8BA3 + .long 0xC30C30C4 + .long 0xCCCCCCCD + .long 0xD79435E6 + .long 0xE38E38E4 + .long 0xF0F0F0F1 + .long 0x10000000 + .long 0x88888889 + .long 0x92492493 + .long 0x9D89D89E + .long 0xAAAAAAAB + .long 0xBA2E8BA3 + .long 0xCCCCCCCD + .long 0xE38E38E4 + .long 0x20000000 + .long 0x92492493 + .long 0xAAAAAAAB + .long 0xCCCCCCCD + .long 0x40000000 + .long 0xAAAAAAAB + .long 0x80000000 +__muldiv: + neg r4,r2 + ld.as r5,[pcl,r4] + abs_s r12,r0 + bic.f 0,r2,r4 + mpyhu.ne r12,r12,r5 + norm r3,r2 + xor.f 0,r0,r1 + ; write port allocation stall + rsub r3,r3,30 + lsr r0,r12,r3 + j_s.d [blink] + neg.mi r0,r0 + + .balign 4 +SYM(__divsi3): + norm r3,r1 + abs_s r2,r1 + brhs r3,23,__muldiv + norm r4,r0 + abs_l r12,r0 + brhs r4,r3,.Lonebit + asl_s r2,r2,r3 + asl r12,r12,r4 + sub lp_count,r3,r4 + sub.f r12,r12,r2 + brge.d r12,r2,.Lsbit + sub r4,r3,r4 + add.lo r12,r12,r2 + lp .Ldivend +.Ldivstart:divaw r12,r12,r2 +.Ldivend:xor_s r1,r1,r0 + sub r0,r4,1 + bmsk r0,r12,r0 + bset.hs r0,r0,r4 + tst_s r1,r1 + j_s.d [blink] + neg.mi r0,r0 +.Lonebit: + xor_s r1,r1,r0 + asr_s r1,r1,31 + sub1.f 0,r12,r2 ; special case: -2**(n+1) / 2**n + or r0,r1,1 + add.eq r0,r0,r0 + cmp_s r12,r2 + j_s.d [blink] + mov.lo r0,0 +.Lsbit: + ; Need to handle special cases involving negative powers of two: + ; r12,r2 are normalized dividend / divisor; + ; divide anything by 0x80000000, or divide 0x80000000 by 0x40000000 + add_s r12,r12,r2 + xor_s r1,r1,r0 + rsub r4,r4,-1 + ror r0,r12,r4 + tst_s r2,r2 + bmsk r0,r0,r3 + add.pl r0,r0,r0 + tst_s r1,r1 + j_s.d [blink] + neg.mi r0,r0 +#else /* !MULDIV */ +/* This version requires that divaw works with a divisor of 0x80000000U */ + abs_s r2,r1 + norm r4,r0 + neg_s r3,r2 + norm r3,r3 + abs_s r12,r0 + brhs r4,r3,.Lonebit + asl_s r2,r2,r3 + asl r12,r12,r4 + sub lp_count,r3,r4 + cmp_s r12,r2 + sub.hs r12,r12,r2 + lp .Ldivend +.Ldivstart:divaw r12,r12,r2 +.Ldivend:xor_s r1,r1,r0 + sub_s r0,r3,1 + bmsk r0,r12,r0 + bset.hs r0,r0,r3 + tst_s r1,r1 + j_s.d [blink] + negmi r0,r0 +.Lonebit: + xor_s r1,r1,r0 + asr_s r1,r1,31 + cmp_s r12,r2 + mov_s r0,0 + j_s.d [blink] + orhs r0,r1,1 +#endif /* MULDIV */ + +#endif /* ifndef __ARC700__ */ + ENDFUNC(__divsi3) + + +#endif /* L_divsi3 */ + +#ifdef L_umodsi3 + .section .text + .align 4 + + .global SYM(__umodsi3) + FUNC(__umodsi3) +SYM(__umodsi3): + mov r7,blink + bl.nd @SYM(__udivmodsi4) + j.d [r7] + mov r0,r1 + ENDFUNC(__umodsi3) +#if 0 /* interferes with linux loader */ + .section .__arc_profile_forward, "a" + .long SYM(__umodsi3) + .long SYM(__udivmodsi4) + .long 65536 +#endif + +#endif /* L_umodsi3 */ + +#ifdef L_modsi3 + .section .text + .align 4 + + .global SYM (__modsi3) + FUNC(__modsi3) +SYM(__modsi3): +#ifndef __ARC_EA__ + /* A5 / ARC60? */ + mov_s r12,blink + mov_s r11,r0 + abs_s r0,r0 + bl.d @SYM(__udivmodsi4) + abs_s r1,r1 + tst r11,r11 + neg_s r0,r1 + j_s.d [r12] + mov.pl r0,r1 +#else /* __ARC_EA__ */ + abs_s r2,r1 + norm.f r4,r0 + neg r5,r2 + norm r3,r5 + abs_l r12,r0 + brhs r4,r3,.Lonebit + asl_s r2,r2,r3 + asl r12,r12,r4 + sub lp_count,r3,r4 + cmp_s r12,r2 + sub.hs r12,r12,r2 + tst_s r0,r0 + lp .Ldivend +.Ldivstart:divaw r12,r12,r2 +.Ldivend: + lsr r0,r12,r3 + j_s.d [blink] + neg.mi r0,r0 + .balign 4 +.Lonebit:neg.pl r5,r5 + cmp_s r12,r2 + j_s.d [blink] + sub.hs r0,r0,r5 +#endif /* !__ARC_EA__ */ + ENDFUNC(__modsi3) + +#endif /* L_modsi3 */ + +#ifdef L_clzsi2 + .section .text + .align 4 + .global SYM (__clzsi2) +SYM(__clzsi2): +#ifdef __ARC_NORM__ + HIDDEN_FUNC(__clzsi2) + norm.f r0,r0 + mov.n r0,0 + j_s.d [blink] + add.pl r0,r0,1 + ENDFUNC(__clzsi2) +#elif !defined (__ARC_BARREL_SHIFTER__) + FUNC(__clzsi2) + mov lp_count,10 + mov_l r1,0 + bset r2,r1,29 + lp .Loop_end + brhs r0,r2,.Loop_end + add3 r0,r1,r0 +.Loop_end: + asl.f 0,r0 + sub2 r0,lp_count,lp_count + sub.cs.f r0,r0,1 + add r0,r0,31 + j_s.d [blink] + add.pl r0,r0,1 + ENDFUNC(__clzsi2) +#else + FUNC(__clzsi2) + asl.f 0,r0,2 + mov r1,-1 +.Lcheck: + bbit1.d r0,31,.Ldone + asl.pl r0,r0,3 + bcs.d .Ldone_1 + add_s r1,r1,3 + bpnz.d .Lcheck + asl.f 0,r0,2 + mov_s r0,32 + j_s.d [blink] + mov.ne r0,r1 +.Ldone: + j_s.d [blink] + add_s r0,r1,1 +.Ldone_1: + j_s.d [blink] + sub_s r0,r1,1 + ENDFUNC(__clzsi2) +#endif +#endif /* L_clzsi2 */ + .section .text + + +;;; MILLICODE THUNK LIB ;*************** + +;;; .macro push_regs from, to, offset +;;; st_s "\from", [sp, \offset] +;;; .if \to-\from +;;; push_regs "(\from+1)", \to, "(\offset+4)" +;;; .endif +;;; .endm +;;; push_regs 13, 18, 0 +;;; + +;;;; .macro sum from, to, three +;;;; .long \from +;;;; .long \three +;;;; .local regno +;;;; .set regno, \from+1 +;;;; .set shift, 32 +;;;; .set shift, shift - 1 +;;;; # st_s %shift @3 lsl #shift +;;;; .if \to-\from +;;;; sum "(\from+1)", \to, "(\three)" +;;;; .endif +;;;; .endm +;;;; +;;;; SUM 0,5, 9 +;;;; +; .altmacro +;; .macro push_regs from=0, to=3, offset +;; st_s r\from, [sp, \offset] +;; .if \to-\from +;; push_regs "\from+1 ",\to,"(\offset+4)" +;; .endif +;; .endm +;; +;; .macro expand_to_push from=13, to +;; ; .section .text +;; ; .align 4 +;; ; .global st_ +;; ; .type foo, +;; st_13_to_25: +;; ; push_regs \from, \to, 0 +;; push_regs 0,3 ; +;; .endm +;; +;; expand_to_push 13,18 +;; +;#endif + +#ifdef L_millicodethunk_st + .section .text + .align 4 + .global SYM(__st_r13_to_r15) + .global SYM(__st_r13_to_r16) + .global SYM(__st_r13_to_r17) + .global SYM(__st_r13_to_r18) + .global SYM(__st_r13_to_r19) + .global SYM(__st_r13_to_r20) + .global SYM(__st_r13_to_r21) + .global SYM(__st_r13_to_r22) + .global SYM(__st_r13_to_r23) + .global SYM(__st_r13_to_r24) + .global SYM(__st_r13_to_r25) + HIDDEN_FUNC(__st_r13_to_r15) + HIDDEN_FUNC(__st_r13_to_r16) + HIDDEN_FUNC(__st_r13_to_r17) + HIDDEN_FUNC(__st_r13_to_r18) + HIDDEN_FUNC(__st_r13_to_r19) + HIDDEN_FUNC(__st_r13_to_r20) + HIDDEN_FUNC(__st_r13_to_r21) + HIDDEN_FUNC(__st_r13_to_r22) + HIDDEN_FUNC(__st_r13_to_r23) + HIDDEN_FUNC(__st_r13_to_r24) + HIDDEN_FUNC(__st_r13_to_r25) + .align 4 +SYM(__st_r13_to_r25): + st r25, [sp,48] +SYM(__st_r13_to_r24): + st r24, [sp,44] +SYM(__st_r13_to_r23): + st r23, [sp,40] +SYM(__st_r13_to_r22): + st r22, [sp,36] +SYM(__st_r13_to_r21): + st r21, [sp,32] +SYM(__st_r13_to_r20): + st r20, [sp,28] +SYM(__st_r13_to_r19): + st r19, [sp,24] +SYM(__st_r13_to_r18): + st r18, [sp,20] +SYM(__st_r13_to_r17): + st r17, [sp,16] +SYM(__st_r13_to_r16): + st r16, [sp,12] +SYM(__st_r13_to_r15): +#ifdef __ARC700__ + st r15, [sp,8] ; minimum function size to avoid stall: 6 bytes. +#else + st_s r15, [sp,8] +#endif + st_s r14, [sp,4] + j_s.d [%blink] + st_s r13, [sp,0] + ENDFUNC(__st_r13_to_r15) + ENDFUNC(__st_r13_to_r16) + ENDFUNC(__st_r13_to_r17) + ENDFUNC(__st_r13_to_r18) + ENDFUNC(__st_r13_to_r19) + ENDFUNC(__st_r13_to_r20) + ENDFUNC(__st_r13_to_r21) + ENDFUNC(__st_r13_to_r22) + ENDFUNC(__st_r13_to_r23) + ENDFUNC(__st_r13_to_r24) + ENDFUNC(__st_r13_to_r25) +#endif /* L_millicodethunk_st */ + + +#ifdef L_millicodethunk_ld + .section .text + .align 4 +; ================================== +; the loads + + .global SYM(__ld_r13_to_r15) + .global SYM(__ld_r13_to_r16) + .global SYM(__ld_r13_to_r17) + .global SYM(__ld_r13_to_r18) + .global SYM(__ld_r13_to_r19) + .global SYM(__ld_r13_to_r20) + .global SYM(__ld_r13_to_r21) + .global SYM(__ld_r13_to_r22) + .global SYM(__ld_r13_to_r23) + .global SYM(__ld_r13_to_r24) + .global SYM(__ld_r13_to_r25) + HIDDEN_FUNC(__ld_r13_to_r15) + HIDDEN_FUNC(__ld_r13_to_r16) + HIDDEN_FUNC(__ld_r13_to_r17) + HIDDEN_FUNC(__ld_r13_to_r18) + HIDDEN_FUNC(__ld_r13_to_r19) + HIDDEN_FUNC(__ld_r13_to_r20) + HIDDEN_FUNC(__ld_r13_to_r21) + HIDDEN_FUNC(__ld_r13_to_r22) + HIDDEN_FUNC(__ld_r13_to_r23) + HIDDEN_FUNC(__ld_r13_to_r24) + HIDDEN_FUNC(__ld_r13_to_r25) +SYM(__ld_r13_to_r25): + ld r25, [sp,48] +SYM(__ld_r13_to_r24): + ld r24, [sp,44] +SYM(__ld_r13_to_r23): + ld r23, [sp,40] +SYM(__ld_r13_to_r22): + ld r22, [sp,36] +SYM(__ld_r13_to_r21): + ld r21, [sp,32] +SYM(__ld_r13_to_r20): + ld r20, [sp,28] +SYM(__ld_r13_to_r19): + ld r19, [sp,24] +SYM(__ld_r13_to_r18): + ld r18, [sp,20] +SYM(__ld_r13_to_r17): + ld r17, [sp,16] +SYM(__ld_r13_to_r16): + ld r16, [sp,12] +SYM(__ld_r13_to_r15): +#ifdef __ARC700__ + ld r15, [sp,8] ; minimum function size to avoid stall: 6 bytes. +#else + ld_s r15, [sp,8] +#endif + ld_s r14, [sp,4] + j_s.d [%blink] + ld_s r13, [sp,0] + ENDFUNC(__ld_r13_to_r15) + ENDFUNC(__ld_r13_to_r16) + ENDFUNC(__ld_r13_to_r17) + ENDFUNC(__ld_r13_to_r18) + ENDFUNC(__ld_r13_to_r19) + ENDFUNC(__ld_r13_to_r20) + ENDFUNC(__ld_r13_to_r21) + ENDFUNC(__ld_r13_to_r22) + ENDFUNC(__ld_r13_to_r23) + ENDFUNC(__ld_r13_to_r24) + ENDFUNC(__ld_r13_to_r25) + +#endif /* L_millicodethunk_ld */ +#ifdef L_millicodethunk_ret + .global SYM(__ld_r13_to_r14_ret) + .global SYM(__ld_r13_to_r15_ret) + .global SYM(__ld_r13_to_r16_ret) + .global SYM(__ld_r13_to_r17_ret) + .global SYM(__ld_r13_to_r18_ret) + .global SYM(__ld_r13_to_r19_ret) + .global SYM(__ld_r13_to_r20_ret) + .global SYM(__ld_r13_to_r21_ret) + .global SYM(__ld_r13_to_r22_ret) + .global SYM(__ld_r13_to_r23_ret) + .global SYM(__ld_r13_to_r24_ret) + .global SYM(__ld_r13_to_r25_ret) + HIDDEN_FUNC(__ld_r13_to_r14_ret) + HIDDEN_FUNC(__ld_r13_to_r15_ret) + HIDDEN_FUNC(__ld_r13_to_r16_ret) + HIDDEN_FUNC(__ld_r13_to_r17_ret) + HIDDEN_FUNC(__ld_r13_to_r18_ret) + HIDDEN_FUNC(__ld_r13_to_r19_ret) + HIDDEN_FUNC(__ld_r13_to_r20_ret) + HIDDEN_FUNC(__ld_r13_to_r21_ret) + HIDDEN_FUNC(__ld_r13_to_r22_ret) + HIDDEN_FUNC(__ld_r13_to_r23_ret) + HIDDEN_FUNC(__ld_r13_to_r24_ret) + HIDDEN_FUNC(__ld_r13_to_r25_ret) + .section .text + .align 4 +SYM(__ld_r13_to_r25_ret): + ld r25, [sp,48] +SYM(__ld_r13_to_r24_ret): + ld r24, [sp,44] +SYM(__ld_r13_to_r23_ret): + ld r23, [sp,40] +SYM(__ld_r13_to_r22_ret): + ld r22, [sp,36] +SYM(__ld_r13_to_r21_ret): + ld r21, [sp,32] +SYM(__ld_r13_to_r20_ret): + ld r20, [sp,28] +SYM(__ld_r13_to_r19_ret): + ld r19, [sp,24] +SYM(__ld_r13_to_r18_ret): + ld r18, [sp,20] +SYM(__ld_r13_to_r17_ret): + ld r17, [sp,16] +SYM(__ld_r13_to_r16_ret): + ld r16, [sp,12] +SYM(__ld_r13_to_r15_ret): + ld r15, [sp,8] +SYM(__ld_r13_to_r14_ret): + ld blink,[sp,r12] + ld_s r14, [sp,4] + ld.ab r13, [sp,r12] + j_s.d [%blink] + add_s sp,sp,4 + ENDFUNC(__ld_r13_to_r14_ret) + ENDFUNC(__ld_r13_to_r15_ret) + ENDFUNC(__ld_r13_to_r16_ret) + ENDFUNC(__ld_r13_to_r17_ret) + ENDFUNC(__ld_r13_to_r18_ret) + ENDFUNC(__ld_r13_to_r19_ret) + ENDFUNC(__ld_r13_to_r20_ret) + ENDFUNC(__ld_r13_to_r21_ret) + ENDFUNC(__ld_r13_to_r22_ret) + ENDFUNC(__ld_r13_to_r23_ret) + ENDFUNC(__ld_r13_to_r24_ret) + ENDFUNC(__ld_r13_to_r25_ret) + +#endif /* L_millicodethunk_ret */ + +#define ARC_OPTFPE (defined (__ARC700__) || defined (__ARC_FPX_QUARK__)) + +#if ARC_OPTFPE +#ifdef L_adddf3 +#ifdef __ARC_NORM__ +#include "ieee-754/adddf3.S" +#endif +#endif + +#ifdef L_muldf3 +#ifdef __ARC_MPY__ +#include "ieee-754/muldf3.S" +#elif defined (__ARC_NORM__) && defined(__ARC_MUL64__) +#include "ieee-754/arc600-mul64/muldf3.S" +#elif defined (__ARC_NORM__) && defined(__ARC_MUL32BY16__) +#include "ieee-754/arc600-dsp/muldf3.S" +#endif +#endif + +#ifdef L_addsf3 +#ifdef __ARC_NORM__ +#include "ieee-754/addsf3.S" +#endif +#endif + +#ifdef L_mulsf3 +#ifdef __ARC_MPY__ +#include "ieee-754/mulsf3.S" +#elif defined (__ARC_NORM__) && defined(__ARC_MUL64__) +#include "ieee-754/arc600-mul64/mulsf3.S" +#elif defined (__ARC_NORM__) && defined(__ARC_MUL32BY16__) +#include "ieee-754/arc600-dsp/mulsf3.S" +#elif defined (__ARC_NORM__) +#include "ieee-754/arc600/mulsf3.S" +#endif +#endif + +#ifdef L_divdf3 +#ifdef __ARC_MPY__ +#include "ieee-754/divdf3.S" +#elif defined (__ARC_NORM__) && defined(__ARC_MUL64__) +#include "ieee-754/arc600-mul64/divdf3.S" +#elif defined (__ARC_NORM__) && defined(__ARC_MUL32BY16__) +#include "ieee-754/arc600-dsp/divdf3.S" +#endif +#endif + +#ifdef L_divsf3 +#ifdef __ARC_MPY__ +#include "ieee-754/divsf3-stdmul.S" +#elif defined (__ARC_NORM__) && defined(__ARC_MUL64__) +#include "ieee-754/arc600-mul64/divsf3.S" +#elif defined (__ARC_NORM__) && defined(__ARC_MUL32BY16__) +#include "ieee-754/arc600-dsp/divsf3.S" +#elif defined (__ARC_NORM__) +#include "ieee-754/arc600/divsf3.S" +#endif +#endif + +#ifdef L_extendsfdf2 +#ifdef __ARC_NORM__ +#include "ieee-754/extendsfdf2.S" +#endif +#endif + +#ifdef L_truncdfsf2 +#ifdef __ARC_NORM__ +#include "ieee-754/truncdfsf2.S" +#endif +#endif + +#ifdef L_floatsidf +#ifdef __ARC_NORM__ +#include "ieee-754/floatsidf.S" +#endif +#endif + +#ifdef L_floatsisf +#ifdef __ARC_NORM__ +#include "ieee-754/floatsisf.S" +#endif +#endif + +#ifdef L_floatunsidf +#ifdef __ARC_NORM__ +#include "ieee-754/floatunsidf.S" +#endif +#endif + +#ifdef L_fixdfsi +#ifdef __ARC_NORM__ +#include "ieee-754/fixdfsi.S" +#endif +#endif + +#ifdef L_fixsfsi +#ifdef __ARC_NORM__ +#include "ieee-754/fixsfsi.S" +#endif +#endif + +#ifdef L_fixunsdfsi +#ifdef __ARC_NORM__ +#include "ieee-754/fixunsdfsi.S" +#endif +#endif + +#ifdef L_eqdf2 +#ifdef __ARC_NORM__ +#include "ieee-754/eqdf2.S" +#endif +#endif + +#ifdef L_eqsf2 +#ifdef __ARC_NORM__ +#include "ieee-754/eqsf2.S" +#endif +#endif + +#ifdef L_gtdf2 +#ifdef __ARC_NORM__ +#include "ieee-754/gtdf2.S" +#endif +#endif + +#ifdef L_gtsf2 +#ifdef __ARC_NORM__ +#include "ieee-754/gtsf2.S" +#endif +#endif + +#ifdef L_gedf2 +#ifdef __ARC_NORM__ +#include "ieee-754/gedf2.S" +#endif +#endif + +#ifdef L_gesf2 +#ifdef __ARC_NORM__ +#include "ieee-754/gesf2.S" +#endif +#endif + +#ifdef L_uneqdf2 +#ifdef __ARC_NORM__ +#include "ieee-754/uneqdf2.S" +#endif +#endif + +#ifdef L_uneqsf2 +#ifdef __ARC_NORM__ +#include "ieee-754/uneqsf2.S" +#endif +#endif + +#ifdef L_orddf2 +#ifdef __ARC_NORM__ +#include "ieee-754/orddf2.S" +#endif +#endif + +#ifdef L_ordsf2 +#ifdef __ARC_NORM__ +#include "ieee-754/ordsf2.S" +#endif +#endif +#endif /* ARC_OPTFPE */ diff --git a/arch/arc/lib/libgcc2.c b/arch/arc/lib/libgcc2.c index b92a841a374b..eac8faf4f740 100644 --- a/arch/arc/lib/libgcc2.c +++ b/arch/arc/lib/libgcc2.c @@ -74,87 +74,3 @@ __lshrdi3(DWtype u, shift_count_type b)
return w.ll; } - -unsigned long -udivmodsi4(unsigned long num, unsigned long den, int modwanted) -{ - unsigned long bit = 1; - unsigned long res = 0; - - while (den < num && bit && !(den & (1L<<31))) { - den <<= 1; - bit <<= 1; - } - - while (bit) { - if (num >= den) { - num -= den; - res |= bit; - } - bit >>= 1; - den >>= 1; - } - - if (modwanted) - return num; - - return res; -} - -long -__divsi3(long a, long b) -{ - int neg = 0; - long res; - - if (a < 0) { - a = -a; - neg = !neg; - } - - if (b < 0) { - b = -b; - neg = !neg; - } - - res = udivmodsi4(a, b, 0); - - if (neg) - res = -res; - - return res; -} - -long -__modsi3(long a, long b) -{ - int neg = 0; - long res; - - if (a < 0) { - a = -a; - neg = 1; - } - - if (b < 0) - b = -b; - - res = udivmodsi4(a, b, 1); - - if (neg) - res = -res; - - return res; -} - -long -__udivsi3(long a, long b) -{ - return udivmodsi4(a, b, 0); -} - -long -__umodsi3(long a, long b) -{ - return udivmodsi4(a, b, 1); -}
On Thu, Jun 07, 2018 at 08:31:49PM +0300, Alexey Brodkin wrote:
Some background on private libgcc on ARC first.
The whole point of having private libgcc in U-Boot is to be toolchain agnostic. I.e. have an ability to use any more or less up-to-date ARC GNU tools for building U-Boot for any platform with ARC core.
As of today we have at least 6 (sic!) flavors of GNU toolchains for ARC.
- Little-endian multilib Elf32
- Big-endian multilib Elf32
- Little-endian uClibc for ARC700 (ARCompact or ARCv1 ISA)
- Big-endian uClibc for ARC700
- Little-endian uClibc for ARC HS (ARCv2 ISA)
- Big-endian uClibc for ARC HS
In foreseeable future we'll have multilib Linux toolchain so we'll cut number of tools down to 4. Anyways...
In general we don't need Linux toolchain for building U-Boot and since Elf32 GNU tools have libs for most of "standard" ARC core templates [1] it might be a good toolchain for U-Boot. But:
- Still big-/little-endian platforms require different tools
- Developers need to have Linux toolchain for user-space stuff because of C-library
- People tend to build more Linux tools, like Linux kernel crootools
So it looks like multilib Linux toolchain might be a bit more convenient option, at least it addresses (2) and (3) from above, i.e. we'll only need to deal with big-/little-endian story and that should be fine as not that many developers in the world play simultaneously with platforms of both types.
But no! Linux multilib toolchain will only be built for very limited list of mcpu's [2]. Basically only "arc700" and "archs" (with few flavors for HS38 templates). That's because only those cores are capable of running Linux and uClibc/glibc couldn't be built for others. I.e. all the simpler cores where U-Boot could be perfectly used [and in fact is used more and more] won't have libgcc pre-built as the part of the toolchain.
And really ultimate solution is to build libgcc as a part of U-Boot and have no external dependencies. That's something that we used to do for quite some time [3] with limited amount of functions really required by existing platforms. But with addition of more platforms like those with missing multiplier (MPY and friends) we need to have more libgcc functions and to make things simple and at the same time very optimal we're importing entire libgcc for ARC from latest stable GCC (8.1.0 as of today).
[1] https://github.com/gcc-mirror/gcc/blob/master/gcc/config/arc/t-multilib#L24 [2] https://github.com/gcc-mirror/gcc/blob/master/gcc/config/arc/t-multilib-linu... [3] http://git.denx.de/?p=u-boot.git;a=commit;h=a67ef280f46803e319639f5380ff8da6...
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com
Since that's an import from GCC I intentionally didn't do any changes to imported files. And that means checkpatch.pl is pretty unhappy. In particular because:
- SPDX license header is missing
- Some identation made with spaces
- Spaces are missing in code or there're more than needed
- A couple of "#if 0"
etc etc.
And that poses a question: what is mandatory to be fixed and what not?
- I guess SPDX license header MUST be inserted, right?
Yes. And this is what we've done for other GCC imports as well btw.
- All the rest I'd really like to keep as it is now to simplify subsequent updates of newer libgcc versions.
Yes, leaving the style otherwise non-matching is OK.
Alexey Brodkin
