[PATCH] efi_loader: capsule: detect possible ESP device path
When using CapsuleApp to execute on-disk update, it will choose the first boot option as BootNext entry to perform the capsule update after a reboot. But auto-generate boot option will ignore the logical partition which might be an ESP, thus it could not find the capsule file.
Align with the EDK II, detect the possible ESP device path by expanding the media path.
Fixes: f86fba8adbf3 ("efi_loader: auto-generate boot option for each blkio device") Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- include/efi_loader.h | 6 ++ lib/efi_loader/efi_boottime.c | 15 ++--- lib/efi_loader/efi_capsule.c | 110 +++++++++++++++++++++++++++++++++- 3 files changed, 118 insertions(+), 13 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index 9600941aa327..9d78fa936701 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -683,6 +683,12 @@ efi_status_t efi_protocol_open(struct efi_handler *handler, void **protocol_interface, void *agent_handle, void *controller_handle, uint32_t attributes);
+/* Connect drivers to controller */ +efi_status_t EFIAPI efi_connect_controller(efi_handle_t controller_handle, + efi_handle_t *driver_image_handle, + struct efi_device_path *remain_device_path, + bool recursive); + /* Install multiple protocol interfaces */ efi_status_t EFIAPI efi_install_multiple_protocol_interfaces(efi_handle_t *handle, ...); diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 1951291747cd..2c86d78208b2 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -103,12 +103,6 @@ static efi_status_t EFIAPI efi_disconnect_controller( efi_handle_t driver_image_handle, efi_handle_t child_handle);
-static -efi_status_t EFIAPI efi_connect_controller(efi_handle_t controller_handle, - efi_handle_t *driver_image_handle, - struct efi_device_path *remain_device_path, - bool recursive); - /* Called on every callback entry */ int __efi_entry_check(void) { @@ -3670,11 +3664,10 @@ static efi_status_t efi_connect_single_controller( * * Return: status code */ -static efi_status_t EFIAPI efi_connect_controller( - efi_handle_t controller_handle, - efi_handle_t *driver_image_handle, - struct efi_device_path *remain_device_path, - bool recursive) +efi_status_t EFIAPI efi_connect_controller(efi_handle_t controller_handle, + efi_handle_t *driver_image_handle, + struct efi_device_path *remain_device_path, + bool recursive) { efi_status_t r; efi_status_t ret = EFI_NOT_FOUND; diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index de0d49ebebda..919e3cba071b 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -922,6 +922,105 @@ static bool device_is_present_and_system_part(struct efi_device_path *dp) return true; }
+/** + * get_esp_from_boot_option_file_path - get the expand device path + * + * Get a possible efi system partition by expanding a boot option + * file path. + * + * @boot_dev The device path pointing to a boot option + * Return: The full ESP device path or NULL if fail + */ +static struct efi_device_path *get_esp_from_boot_option_file_path(struct efi_device_path *boot_dev) +{ + efi_status_t ret = EFI_SUCCESS; + efi_handle_t handle; + struct efi_device_path *dp = boot_dev; + struct efi_device_path *full_path = NULL; + + ret = EFI_CALL(efi_locate_device_path(&efi_simple_file_system_protocol_guid, + &dp, + &handle)); + if (ret != EFI_SUCCESS) + ret = EFI_CALL(efi_locate_device_path(&efi_block_io_guid, &dp, &handle)); + + /* Expand Media Device Path */ + if (ret == EFI_SUCCESS && EFI_DP_TYPE(dp, END, END)) { + struct efi_device_path *temp_dp; + struct efi_block_io *block_io; + void *buffer; + efi_handle_t *simple_file_system_handle; + efi_uintn_t number_handles, index; + u32 size; + u32 temp_size; + + temp_dp = boot_dev; + ret = EFI_CALL(efi_locate_device_path(&efi_simple_file_system_protocol_guid, + &temp_dp, + &handle)); + /* + * For device path pointing to simple file system, it only expands to one + * full path + */ + if (ret == EFI_SUCCESS && EFI_DP_TYPE(temp_dp, END, END)) { + if (device_is_present_and_system_part(temp_dp)) + return temp_dp; + } + + /* + * For device path only pointing to the removable device handle, try to + * search all its children handles + */ + ret = EFI_CALL(efi_locate_device_path(&efi_block_io_guid, &temp_dp, &handle)); + EFI_CALL(efi_connect_controller(handle, NULL, NULL, true)); + + /* Align with edk2, issue a dummy read to the device to check the device change */ + ret = EFI_CALL(efi_handle_protocol(handle, &efi_block_io_guid, (void **)&block_io)); + if (ret == EFI_SUCCESS) { + buffer = memalign(block_io->media->io_align, block_io->media->block_size); + if (buffer) { + ret = EFI_CALL(block_io->read_blocks(block_io, + block_io->media->media_id, + 0, + block_io->media->block_size, + buffer)); + free(buffer); + } else { + return full_path; + } + } else { + return full_path; + } + + /* detect the default boot file from removable media */ + size = efi_dp_size(boot_dev) - sizeof(struct efi_device_path); + EFI_CALL(efi_locate_handle_buffer(BY_PROTOCOL, + &efi_simple_file_system_protocol_guid, + NULL, + &number_handles, + &simple_file_system_handle)); + for (index = 0; index < number_handles; index++) { + EFI_CALL(efi_handle_protocol(simple_file_system_handle[index], + &efi_guid_device_path, + (void **)&temp_dp)); + + log_debug("Search ESP %pD\n", temp_dp); + temp_size = efi_dp_size(temp_dp) - sizeof(struct efi_device_path); + if (size <= temp_size && !memcmp(temp_dp, boot_dev, size)) { + if (device_is_present_and_system_part(temp_dp)) { + efi_free_pool(simple_file_system_handle); + return temp_dp; + } + } + } + + if (simple_file_system_handle) + efi_free_pool(simple_file_system_handle); + } + + return full_path; +} + /** * find_boot_device - identify the boot device * @@ -938,6 +1037,7 @@ static efi_status_t find_boot_device(void) int i, num; struct efi_simple_file_system_protocol *volume; struct efi_device_path *boot_dev = NULL; + struct efi_device_path *full_path = NULL; efi_status_t ret;
/* find active boot device in BootNext */ @@ -961,8 +1061,14 @@ static efi_status_t find_boot_device(void) if (device_is_present_and_system_part(boot_dev)) { goto found; } else { - efi_free_pool(boot_dev); - boot_dev = NULL; + full_path = get_esp_from_boot_option_file_path(boot_dev); + if (full_path) { + boot_dev = full_path; + goto found; + } else { + efi_free_pool(boot_dev); + boot_dev = NULL; + } } } }
Hello Wheizhoa,
From the description I would not know how to reproduce the problem you face.
Could you, please, provide an example (including disk image and capsule) for QEMU and describe expected and observed behavior.
We should add a CI test case covering the observed bug.
bool recursive);
- /* Install multiple protocol interfaces */ efi_status_t EFIAPI efi_install_multiple_protocol_interfaces(efi_handle_t *handle, ...);
bool recursive);
- Return: status code
bool recursive)
{ efi_status_t r; efi_status_t ret = EFI_NOT_FOUND;bool recursive)
- get_esp_from_boot_option_file_path - get the expand device path
- Get a possible efi system partition by expanding a boot option
- file path.
- @boot_dev The device path pointing to a boot option
- Return: The full ESP device path or NULL if fail
- efi_status_t ret = EFI_SUCCESS;
- efi_handle_t handle;
- struct efi_device_path *dp = boot_dev;
- struct efi_device_path *full_path = NULL;
- ret = EFI_CALL(efi_locate_device_path(&efi_simple_file_system_protocol_guid,
&dp,
&handle));
- if (ret != EFI_SUCCESS)
- /* Expand Media Device Path */
- if (ret == EFI_SUCCESS && EFI_DP_TYPE(dp, END, END)) {
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
return temp_dp;
Which driver do you expect to connect here?
if (buffer) {
0,
buffer));
free(buffer);
} else {
return full_path;
} else {
return full_path;
If you are looking for an ESP shouldn't you use the ESP GUID to find it? It is installed on the ESP in efi_status_t efi_disk_add_dev().
Best regards
Heinrich
NULL,
&number_handles,
return temp_dp;
- return full_path;
- find_boot_device - identify the boot device
boot_dev = NULL;
if (full_path) {
goto found;
} else {
boot_dev = NULL;
Hello Wheizhoa,
Hi Heinrich,
Here is a brief description, I'll add a testcase in the next patch.
background: - there is an ESP in an mmc logical partition - in the edk2 shell payload, running "CapsuleApp.efi -OD" to perform the capsule on-disk update
workflow: - currently, u-boot will auto-generate boot option and install with eliminating logical partitions. So we will have a boot variable Boot0000 that its file_path seems like: "/VenHw/eMMC(0)/eMMC(0)" - then we run the efi app in the edk shell payload. The CapsuleApp will find this boot entry, and it will detect that there is an ESP in this mmc device. According to the on-disk update flow, it will copy the capsule to the ESP, and add the Boot0000 to the BootNext. - After CapsuleApp.efi reset the device, u-boot will check OsIndications and perform the on-disk update flow. Then it will search for the capsule file from the boot entry indicated by the BootNext. Unfortunately, its file_path is "/VenHw/eMMC(0)/eMMC(0)", so the search will fail. - Using this patch, u-boot will expand the Boot0000 file path to detect its ESP, so the capsule file will be found in the expanded device path, eg: "/VenHw/eMMC(0)/eMMC(0)/HD(2)".
BR, Weizhao
bool recursive);
bool recursive);
bool recursive)
- file path.
&dp,
&handle));
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
return temp_dp;
if (buffer) {
0,
buffer));
free(buffer);
} else {
return full_path;
} else {
return full_path;
Best regards
Heinrich
NULL,
&number_handles,
return temp_dp;
return full_path;
struct efi_device_path *full_path = NULL; efi_status_t ret; /* find active boot device in BootNext */
boot_dev = NULL;
if (full_path) {
goto found;
} else {
boot_dev = NULL;
Hello Wheizhoa,
Hi Heinrich,
background:
workflow:
Why do you need an EFI app? Shouldn't the operating system place the capsule file?
What makes you expect that there is any ESP on whatever Boot0000 points to? You should evaluate BootCurrent if you want to know from which boot entry the current application was started from.
U-Boot does not check OsIndications.
Best regards
Heirnich
BR, Weizhao
bool recursive);
bool recursive);
bool recursive)
- file path.
&dp,
&handle));
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
return temp_dp;
if (buffer) {
0,
buffer));
free(buffer);
} else {
return full_path;
} else {
return full_path;
Best regards
Heinrich
NULL,
&number_handles,
return temp_dp;
return full_path;
boot_dev = NULL;
if (full_path) {
goto found;
} else {
boot_dev = NULL;
Hello Wheizhoa,
Hi Heinrich,
background:
workflow:
CapsuleApp[1] is a shell application that can manually trigger capsule update process. As one of its flow, it will install the capsule to the ESP and update the BootNext. The purpose of this patch is to fix the broken update process and align with edk2.
I mean the check_run_capsules().
[1] https://github.com/tianocore/edk2/tree/master/MdeModulePkg/Application/Capsu...
BR, Weizhao
Best regards
Heirnich
BR, Weizhao
bool recursive);
bool recursive);
bool recursive)
- file path.
&dp,
&handle));
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
return temp_dp;
if (buffer) {
0,
buffer));
free(buffer);
} else {
return full_path;
} else {
return full_path;
Best regards
Heinrich
NULL,
&number_handles,
return temp_dp;
return full_path;
boot_dev = NULL;
if (full_path) {
goto found;
} else {
boot_dev = NULL;
- file path.
&dp,
&handle));
Flip this around. Always do failure handling. Never do success handling. full_path is always NULL. Just return that. Delete the variable.
if (ret != EFI_SUCCESS || !EFI_DP_TYPE(dp, END, END)) return NULL;
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
"Always" was hyperbole. This success handling is fine.
return temp_dp;
ret is not used. Delete.
if (ret != EFI_SUCCESS) return NULL;
if (buffer) {
if (!buffer) return NULL;
0,
buffer));
Delete the unused "ret = " assignment.
free(buffer);
} else {
return full_path;
} else {
return full_path;
NULL,
&number_handles,
You could combine these conditions:
if (size <= temp_size && memcmp(temp_dp, boot_dev, size) == 0 && device_is_present_and_system_part(temp_dp)) { efi_free_pool(simple_file_system_handle); return temp_dp; }
return temp_dp;
- return full_path;
No need to initialize this to NULL, it disables static checker warnings for uninitialized variables so it can lead to bugs.
efi_status_t ret;
boot_dev = NULL;
if (full_path) {
Later, we free full_path but do we ever free the original boot_dev?
goto found;
} else {
boot_dev = NULL;
Better to delete indenting where you can:
full_path = get_esp_from_boot_option_file_path(boot_dev); if (full_path) { boot_dev = full_path; goto found; } efi_free_pool(boot_dev); boot_dev = NULL;
regards, dan carpenter
- file path.
&dp,
&handle));
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
return temp_dp;
Errors should be handled and not ignored.
if (buffer) {
0,
buffer));
ditto
Best regards
Heinrich
free(buffer);
} else {
return full_path;
} else {
return full_path;
NULL,
&number_handles,
return temp_dp;
- return full_path;
efi_status_t ret;
boot_dev = NULL;
if (full_path) {
goto found;
} else {
boot_dev = NULL;
Hi Dan,
Thanks for the suggestion, I'll fix them in the next patch.
BR, Weizhao
- file path.
&dp,
&handle));
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
return temp_dp;
if (buffer) {
0,
buffer));
free(buffer);
} else {
return full_path;
} else {
return full_path;
NULL,
&number_handles,
return temp_dp;
return full_path;
boot_dev = NULL;
if (full_path) {
goto found;
} else {
boot_dev = NULL;
Hi Weizhao,
This is not entirely accurate. The capsule update on-disk mechanism will look in the ESP pointed to by BootNext or the highest priority BootOrder. But the problem you are describing isn't tied only to capsules. IIUC if you have a logical partition with bootXXX.efi the current code will ignore it as well and the automatic selection of the boot option won't work. Can you adjust the commit message on v2 and mention the scanning as an issue with the capsule on disk being the obvious side-effect?
bool recursive);
bool recursive);
bool recursive)
bool recursive)
expanded
- file path.
&dp,
&handle));
I don't see where the device path is expanded in this patch. We already have try_load_from_media() which tries to do something similar. Is anything missing from there?
Can you invert the logic here and return immediately? (if ret != EFI_SUCCESS ...etc ) return full_path;
The indentation will go away.
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
Why do we have multiple calls to efi_locate_device_path()? Aren't the arguments identical? Which part of edk2 did you read? Is it BmExpandMediaDevicePath()?
return temp_dp;
if (buffer) {
0,
buffer));
free(buffer);
} else {
return full_path;
} else {
return full_path;
NULL,
&number_handles,
return temp_dp;
return full_path;
boot_dev = NULL;
if (full_path) {
goto found;
} else {
boot_dev = NULL;
-- 2.40.1
Thanks /Ilias
- file path.
&dp,
&handle));
Looking a bit closer, we do lack calling ConnectController there, but all this should be added to try_load_from_media() not in a different path. Also I don't think we need the Fixes tag
Thanks /Ilias
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
return temp_dp;
if (buffer) {
0,
buffer));
free(buffer);
} else {
return full_path;
} else {
return full_path;
NULL,
&number_handles,
return temp_dp;
return full_path;
boot_dev = NULL;
if (full_path) {
goto found;
} else {
boot_dev = NULL;
-- 2.40.1
Thanks /Ilias
On Wed, May 8, 2024 at 9:56 PM Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
- file path.
&dp,
&handle));
Yeah, I'll summarize them to the try_load_from_media().
Okay.
BR, Weizhao
Thanks /Ilias
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
return temp_dp;
if (buffer) {
0,
buffer));
free(buffer);
} else {
return full_path;
} else {
return full_path;
NULL,
&number_handles,
return temp_dp;
return full_path;
boot_dev = NULL;
if (full_path) {
goto found;
} else {
boot_dev = NULL;
-- 2.40.1
Thanks /Ilias
Hi Ilias,
On Wed, May 8, 2024 at 9:47 PM Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Weizhao,
I'll do.
bool recursive);
bool recursive);
bool recursive)
bool recursive)
expanded
Okay.
- file path.
&dp,
&handle));
Yes we have the try_load_from_media(), but it doesn't cover all cases. Maybe we need to expand it.
Okay.
void *buffer;
u32 size;
u32 temp_size;
temp_dp = boot_dev;
&temp_dp,
&handle));
* full path
Yes it is BmExpandMediaDevicePath(). The device_is_present_and_system_part() check can be removed.
return temp_dp;
if (buffer) {
0,
buffer));
free(buffer);
} else {
return full_path;
} else {
return full_path;
NULL,
&number_handles,
return temp_dp;
return full_path;
boot_dev = NULL;
if (full_path) {
goto found;
} else {
boot_dev = NULL;
-- 2.40.1
Thanks /Ilias
Dan Carpenter
Ilias Apalodimas
Weizhao Ouyang
