[U-Boot-Users] Re: [PATCH] 4/4: some general patches
In message 20030614163658.GE26793@pengutronix.de you wrote:
405gp_enet.c:
The code shall only be compiled when the user has chosen to use the 4xx onchip ethernet device. This is not necessarily true on _all_ 4xx boards
- CONFIG_MII defines the behaviour.
This is not correct. CONFIG_MII is not used in any 4xx related code except to enable the MII utils. It has nothing to do with calling or not calling ppc_4xx_eth_initialize().
Rejected.
cmd_boot.c:
This code has been in u-boot forever. It was removed by one of my cleanup patches some time ago while moving a piece of code to another location. It hasn't found it's way back into the code since then.
Added.
common.h:
Add a generic debugX macro, without changing the existing printk macros, as suggested by WD some time ago.
Added.
eth.c:
Compile code only if 4xx CPU _and_ MII was selected.
See above.
Rejected.
mach-types.h:
Update to latest arm.linux.org.uk master list.
Added.
README:
Add hint for minicom users :-)
Added.
tag.h:
Put ARM tag handling into separate file. Patch by Holger Schurig.
If this is ARM specific code, I don't want to see it in include/
Please put it in include/asm-arm/ or include/asm-arm/arch/
Rejected.
