[U-Boot-Users] Looking for Info on Marvell Libertas 88w8510 WLAN/88E606 switch chipset, AP32/52 SDK or reference design
Hello U-boot forum:
I am searching for some more concrete information on the Marvell Libertas 88w8510 wireless lan and 88E6060 switch. In particular something that describes the internal registers for memory mapping, interrupts, switch registers, etc. Better still would be the documentation and the SDK from the Marvell AP52/32 reference designs. I am writing because I have seen post in the past from groups with access to the Marvell's SDK. Marvell supplies a SDK for eCOS or uClinux.
I have been trying to reverse engineer the Netgear WGR614v4 wireless access based upon the 88W8510 and its associated switch chip. This is almost identical in design to the AP52 reference design. I have however been hampered by the lack of documentation.
Here is what I have been able to do on my own:
1. I have built a JTAG interface and can run C code on the ARM 946 processor and communicate via the serial interface (see 2 below).
2. I currently have source for the firmware boot loader code which was a port of U-boot done by Marvell around 2003. The code was available through ASUS GPL code for the WL530g but has been pulled. (now only listed on http://files.wl500g.info/asus/wl530g/gpl/) The memory model between the Netgear and ASUS product are different.
3. I have not been able to get the U-boot Ethernet code to work. This could be due to:
a. Improper setup of the memory controller on the 88W8510,
b. Improper setup of interrupt controller,
c. Improper setup of the WLAN and switch.
4. I have disassembled the existing Netgear code and can load and run this from ram, but I have not had the time to understand how and what registers the commercial code is initializing for the Ethernet controller and how this is different from Marvell's port of the U-boot code. My suspicion is that the U-boot code does not know about the switch and I am not setting it up correctly so the Arp packets I send are never actually written to the physical layer.
5. Netgear supplies only limited header files and just object code for its GPL release (no source) so I am still missing details.
Could anyone shed any more details?
Thanks in advance for the help.
Regards,
--Jeff Strickrott
Jeff,
If anyone provided you with details on this chip they, or the source of their information, would be in violation of a Marvell NDA. Companies like Marvell and Broadcom that keep their specs private are very selective in who they sell to, and go to great pains to ensure that this stuff is legally protected. In short, asking for this information on a public forum is probably not going to work for you. Maybe I'll be pleasantly surprised, though...
regards, Ben
Ben Warren
Jeff Strickrott
