[PATCH 1/2] board: ti: am335x: Enable spi0 bus on SanCloud BBE Lite
The SanCloud BBE Lite has a Micron Authenta flash device connected to the spi0 bus.
Signed-off-by: Paul Barker paul.barker@sancloud.com --- board/ti/am335x/mux.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index fed737fa099a..7d31adec1421 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -401,8 +401,13 @@ void enable_board_pin_mux(void) configure_module_pin_mux(mmc0_pin_mux_sk_evm); } else if (board_is_bone_lt()) { if (board_is_bben()) { + char subtype_id = board_ti_get_config()[1]; + /* SanCloud Beaglebone LT Enhanced pinmux */ configure_module_pin_mux(rgmii1_pin_mux); + + if (subtype_id == 'L') + configure_module_pin_mux(spi0_pin_mux); } else { /* Beaglebone LT pinmux */ configure_module_pin_mux(mii1_pin_mux);
base-commit: 0cc846dafcf6f6270c6587d6fe79011834d6e49a
We have different dtbs for the Lite and Extended WiFi variants of the SanCloud BBE.
Signed-off-by: Paul Barker paul.barker@sancloud.com --- board/ti/am335x/board.c | 18 ++++++++++++++---- configs/am335x_evm_defconfig | 2 +- 2 files changed, 15 insertions(+), 5 deletions(-)
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 2cb5b1cb3fc7..b97fedddd5e2 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -966,10 +966,20 @@ int board_fit_config_name_match(const char *name) return 0; else if (board_is_icev2() && !strcmp(name, "am335x-icev2")) return 0; - else if (board_is_bben() && !strcmp(name, "am335x-sancloud-bbe")) - return 0; - else - return -1; + else if (board_is_bben()) { + char subtype_id = board_ti_get_config()[1]; + + if (subtype_id == 'L') { + if (!strcmp(name, "am335x-sancloud-bbe-lite")) + return 0; + } else if (subtype_id == 'I') { + if (!strcmp(name, "am335x-sancloud-bbe-extended-wifi")) + return 0; + } else if (!strcmp(name, "am335x-sancloud-bbe")) { + return 0; + } + } + return -1; } #endif
diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 30577a6fce42..3f677a2326c2 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -45,7 +45,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),1m(NAND.u-boot),128k(NAND.u-boot-env),128k(NAND.u-boot-env.backup1),8m(NAND.kernel),-(NAND.file-system)" # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="am335x-evm am335x-bone am335x-sancloud-bbe am335x-boneblack am335x-evmsk am335x-bonegreen am335x-icev2 am335x-pocketbeagle" +CONFIG_OF_LIST="am335x-evm am335x-bone am335x-sancloud-bbe am335x-sancloud-bbe-lite am335x-sancloud-bbe-extended-wifi am335x-boneblack am335x-evmsk am335x-bonegreen am335x-icev2 am335x-pocketbeagle" CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y
Signed-off-by: Paul Barker paul.barker@sancloud.com Reviewed-by: Tom Rini trini@konsulko.com
Paul Barker
