Re: [PATCH v3 2/3] kconfig: Add support for conditional values
+U-Boot Mailing List to update patchwork so 'patman status' works
On Fri, 14 Jan 2022 at 21:52, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
(Sorry for formatting, on phone)
At present if an optional Kconfig value needs to be used it must be bracketed by #ifdef. For example, with this Kconfig setup:
config WIBBLE bool "Support wibbles, the world needs more wibbles"
config WIBBLE_ADDR hex "Address of the wibble" depends on WIBBLE
then the following code must be used:
#ifdef CONFIG_WIBBLE static void handle_wibble(void) { int val = CONFIG_WIBBLE_ADDR;
} #endif
static void init_machine() { ... #ifdef CONFIG_WIBBLE handle_wibble(); #endif }
Add a new IF_ENABLED_INT() to help with this. So now it is possible to write, without #ifdefs:
static void handle_wibble(void) { int val = IF_ENABLED_INT(CONFIG_WIBBLE, CONFIG_WIBBLE_ADDR);
static void init_machine() { ... if (IS_ENABLED(CONFIG_WIBBLE)) handle_wibble(); }
The value will be 0 if CONFIG_WIBBLE is not defined, and CONFIG_WIBBLE_ADDR if it is.
This is stale, please update.
This allows us +/* Evaluates to 0 if option is not defined, int_option if it is defined */
Stale.
+#define IF_ENABLED_INT(option, int_option) \
config_opt_enabled(option, int_option, invalid_use_of_IF_ENABLED_INT())
Should we add a three-arg form of IS_ENABLED so this can also be a trivial wrapper?
- Count number of arguments to a variadic macro. Currently only need
- it for 1, 2 or 3 arguments.
@@ -113,5 +133,17 @@ #define CONFIG_IS_ENABLED(option, ...) \ __concat(__CONFIG_IS_ENABLED_, __count_args(option, ##__VA_ARGS__)) (option, ##__VA_ARGS__)
+#ifndef __ASSEMBLY__
Why prevent use from asm? Sure, if it expands to the function call that gives a syntax error and not a link error, but it will still serve its purpose. Of course the declaration of the function must be guarded, but not the macro definition.
Rasmus
