[U-Boot] [PATCH v2 1/4] ftahbc020s: Faraday FTAHBC020s AHB Bus Controller
ftahbc020s.h provides basic definitions of this controller to help a SoC which use this AHB Controller could do scalable software settings in lowlevel_init.S.
Signed-off-by: Macpaul Lin macpaul@andestech.com --- Changes for v2: - Add __ASSEMBLY__ protecton to register offset for supporting lowlevel_init
include/faraday/ftahbc020s.h | 94 ++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 94 insertions(+), 0 deletions(-) create mode 100644 include/faraday/ftahbc020s.h
diff --git a/include/faraday/ftahbc020s.h b/include/faraday/ftahbc020s.h new file mode 100644 index 0000000..da85582 --- /dev/null +++ b/include/faraday/ftahbc020s.h @@ -0,0 +1,94 @@ +/* + * Copyright (C) 2011 Andes Technology Corporation + * Macpaul Lin, Andes Technology Corporation macpaul@andestech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* FTAHBC020S - AHB Controller (Arbiter/Decoder) definitions */ +#ifndef __FTAHBC020S_H +#define __FTAHBC202S_H + +/* Registers Offsets */ + +/* + * AHB Slave BSR, n * 4, n=0~31 + */ +#ifdef __ASSEMBLY__ +/* this section is used by lowlevel_init.S */ +#define FTAHBC020S_SLAVE_BSR_0 0x00 /* Slave n Base/Size Reg */ +#define FTAHBC020S_SLAVE_BSR_1 0x04 +#define FTAHBC020S_SLAVE_BSR_2 0x08 +#define FTAHBC020S_SLAVE_BSR_3 0x0C +#define FTAHBC020S_SLAVE_BSR_4 0x10 +#define FTAHBC020S_SLAVE_BSR_5 0x14 +#define FTAHBC020S_SLAVE_BSR_6 0x18 +#define FTAHBC020S_SLAVE_BSR_7 0x1C +#define FTAHBC020S_SLAVE_BSR_8 0x20 +#define FTAHBC020S_SLAVE_BSR_9 0x24 +#define FTAHBC020S_SLAVE_BSR_10 0x28 + +#define FTAHBC020S_PCR 0x80 /* Priority Ctrl Reg */ +#define FTAHBC020S_TCRG 0x84 /* Transfer Ctrl Reg */ +#define FTAHBC020S_CR 0x88 /* Ctrl Reg */ +#endif /* __ASSEMBLY__ */ + +/* + * FTAHBC020S_SLAVE_BSR - Slave n Base / Size Register + */ +#define FTAHBC020S_SLAVE_BSR_BASE(x) (((x) & 0xFFF) << 20) +#define FTAHBC020S_SLAVE_BSR_SIZE(x) (((x) & 0xF) << 16) + +#define FTAHBC020S_SLAVE_BSR_SIZE_1M 0x0 +#define FTAHBC020S_SLAVE_BSR_SIZE_2M 0x1 +#define FTAHBC020S_SLAVE_BSR_SIZE_4M 0x2 +#define FTAHBC020S_SLAVE_BSR_SIZE_8M 0x3 +#define FTAHBC020S_SLAVE_BSR_SIZE_16M 0x4 +#define FTAHBC020S_SLAVE_BSR_SIZE_32M 0x5 +#define FTAHBC020S_SLAVE_BSR_SIZE_64M 0x6 +#define FTAHBC020S_SLAVE_BSR_SIZE_128M 0x7 +#define FTAHBC020S_SLAVE_BSR_SIZE_256M 0x8 +#define FTAHBC020S_SLAVE_BSR_SIZE_512M 0x9 +#define FTAHBC020S_SLAVE_BSR_SIZE_1G 0xA +#define FTAHBC020S_SLAVE_BSR_SIZE_2G 0xB + +/* + * FTAHBC020S_PCR - Priority Control Register + */ +#define FTAHBC020S_PCR_PLEVEL_15 (1 << 15) +#define FTAHBC020S_PCR_PLEVEL_14 (1 << 14) +#define FTAHBC020S_PCR_PLEVEL_13 (1 << 13) +#define FTAHBC020S_PCR_PLEVEL_12 (1 << 12) +#define FTAHBC020S_PCR_PLEVEL_11 (1 << 11) +#define FTAHBC020S_PCR_PLEVEL_10 (1 << 10) +#define FTAHBC020S_PCR_PLEVEL_09 (1 << 9) +#define FTAHBC020S_PCR_PLEVEL_08 (1 << 8) +#define FTAHBC020S_PCR_PLEVEL_07 (1 << 7) +#define FTAHBC020S_PCR_PLEVEL_06 (1 << 6) +#define FTAHBC020S_PCR_PLEVEL_05 (1 << 5) +#define FTAHBC020S_PCR_PLEVEL_04 (1 << 4) +#define FTAHBC020S_PCR_PLEVEL_03 (1 << 3) +#define FTAHBC020S_PCR_PLEVEL_02 (1 << 2) +#define FTAHBC020S_PCR_PLEVEL_01 (1 << 1) + +/* + * FTAHBC020S_CR - Interrupt Control Register + */ +#define FTAHBC020S_CR_INTSTS (1 << 24) +#define FTAHBC020S_CR_RESP(x) (((x) & 0x3) << 20) +#define FTAHBC020S_CR_INTSMASK (1 << 16) +#define FTAHBC020S_CR_REMAP (1 << 0) + +#endif /* __FTAHBC020S_H */
Support registers definitions of ftsdmc021 SDRAM controller.
include/faraday/ftsdmc021.h | 154 +++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 154 insertions(+), 0 deletions(-) create mode 100644 include/faraday/ftsdmc021.h
diff --git a/include/faraday/ftsdmc021.h b/include/faraday/ftsdmc021.h new file mode 100644 index 0000000..3ed535a --- /dev/null +++ b/include/faraday/ftsdmc021.h @@ -0,0 +1,154 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * (C) Copyright 2011 Andes Technology Corp + * Macpaul Lin macpaul@andestech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * FTSDMC021 - SDRAM Controller + */ +#ifndef __FTSDMC021_H +#define __FTSDMC021_H + +#ifdef __ASSEMBLY__ +#define FTSDMC021_OFFSET_TP1 0x00 /* SDRAM Timing Parameter 1 */ +#define FTSDMC021_OFFSET_TP2 0x04 /* SDRAM Timing Parameter 2 */ +#define FTSDMC021_OFFSET_CR1 0x08 /* SDRAM Configuration Reg 1 */ +#define FTSDMC021_OFFSET_CR2 0x0C /* SDRAM Configuration Reg 2 */ +#define FTSDMC021_OFFSET_BANK0_BSR 0x10 /* External Bank Base/Size Reg 0 */ +#define FTSDMC021_OFFSET_BANK1_BSR 0x14 /* External Bank Base/Size Reg 1 */ +#define FTSDMC021_OFFSET_BANK2_BSR 0x18 /* External Bank Base/Size Reg 2 */ +#define FTSDMC021_OFFSET_BANK3_BSR 0x1C /* External Bank Base/Size Reg 3 */ +#define FTSDMC021_OFFSET_BANK4_BSR 0x20 /* External Bank Base/Size Reg 4 */ +#define FTSDMC021_OFFSET_BANK5_BSR 0x24 /* External Bank Base/Size Reg 5 */ +#define FTSDMC021_OFFSET_BANK6_BSR 0x28 /* External Bank Base/Size Reg 6 */ +#define FTSDMC021_OFFSET_BANK7_BSR 0x2C /* External Bank Base/Size Reg 7 */ +#define FTSDMC021_OFFSET_RAGR 0x30 /* Read Arbitration Group Reg */ +#define FTSDMC021_OFFSET_FRR 0x34 /* Flush Request Register */ +#define FTSDMC021_OFFSET_EBISR 0x38 /* EBI Support Register */ +#define FTSDMC021_OFFSET_CRR 0x100 /* Controller Revision Reg */ +#define FTSDMC021_OFFSET_CFR 0x104 /* Controller Feature Reg */ +#endif /* __ASSEMBLY__ */ + +/* + * Timing Parameter 1 Register + */ +#define FTSDMC021_TP1_TCL(x) ((x) & 0x3) +#define FTSDMC021_TP1_TWR(x) (((x) & 0x3) << 4) +#define FTSDMC021_TP1_TRF(x) (((x) & 0xf) << 8) +#define FTSDMC021_TP1_TRCD(x) (((x) & 0x7) << 12) +#define FTSDMC021_TP1_TRP(x) (((x) & 0xf) << 16) +#define FTSDMC021_TP1_TRAS(x) (((x) & 0xf) << 20) + +/* + * Timing Parameter 2 Register + */ +#define FTSDMC021_TP2_REF_INTV(x) ((x) & 0xffff) +#define FTSDMC021_TP2_INI_REFT(x) (((x) & 0xf) << 16) +#define FTSDMC021_TP2_INI_PREC(x) (((x) & 0xf) << 20) + +/* + * Configuration Register 1 + */ +#define FTSDMC021_CR1_BNKSIZEF(x) ((x) & 0xf) +#define FTSDMC021_CR1_MBW(x) (((x) & 0x3) << 4) +#define FTSDMC021_CR1_DSZ(x) (((x) & 0x7) << 8) +#define FTSDMC021_CR1_DDW(x) (((x) & 0x3) << 12) +#define FTSDMC021_CR1_MA2T(x) (1 << 16) /* Double Memory Address Cycle Enable */ + +/* + * Configuration Register 2 + */ +#define FTSDMC021_CR2_SREF (1 << 0) +#define FTSDMC021_CR2_PWDN (1 << 1) +#define FTSDMC021_CR2_ISMR (1 << 2) +#define FTSDMC021_CR2_IREF (1 << 3) +#define FTSDMC021_CR2_IPREC (1 << 4) +#define FTSDMC021_CR2_REFTYPE (1 << 5) + +/* + * SDRAM External Bank Base/Size Register + */ +#define FTSDMC021_BANK_ENABLE (1 << 12) + +/* 12-bit base address of external bank. + * Default value is 0x800. + * The 12-bit equals to the haddr[31:20] of AHB address bus. */ +#define FTSDMC021_BANK_BASE(x) ((x) & 0xfff) + +#define FTSDMC021_BANK_SIZE_1M 0x0 +#define FTSDMC021_BANK_SIZE_2M 0x1 +#define FTSDMC021_BANK_SIZE_4M 0x2 +#define FTSDMC021_BANK_SIZE_8M 0x3 +#define FTSDMC021_BANK_SIZE_16M 0x4 +#define FTSDMC021_BANK_SIZE_32M 0x5 +#define FTSDMC021_BANK_SIZE_64M 0x6 +#define FTSDMC021_BANK_SIZE_128M 0x7 +#define FTSDMC021_BANK_SIZE_256M 0x8 +#define FTSDMC021_BANK_SIZE_512M 0x9 + +/* + * Read Arbitration Grant Window Register + */ +#define FTSDMC021_RAGR_CH1GW(x) (((x) & 0xff) << 0) +#define FTSDMC021_RAGR_CH2GW(x) (((x) & 0xff) << 4) +#define FTSDMC021_RAGR_CH3GW(x) (((x) & 0xff) << 8) +#define FTSDMC021_RAGR_CH4GW(x) (((x) & 0xff) << 12) +#define FTSDMC021_RAGR_CH5GW(x) (((x) & 0xff) << 16) +#define FTSDMC021_RAGR_CH6GW(x) (((x) & 0xff) << 20) +#define FTSDMC021_RAGR_CH7GW(x) (((x) & 0xff) << 24) +#define FTSDMC021_RAGR_CH8GW(x) (((x) & 0xff) << 28) + +/* + * Flush Request Register + */ +#define FTSDMC021_FRR_FLUSHCHN(x) (((x) & 0x7) << 0) +#define FTSDMC021_FRR_FLUSHCMPLT (1 << 3) + +/* + * External Bus Interface Support Register (EBISR) + */ +#define FTSDMC021_EBISR_MR(x) ((x) & 0xfff) +#define FTSDMC021_EBISR_PRSMR (1 << 12) +#define FTSDMC021_EBISR_POPREC (1 << 13) +#define FTSDMC021_EBISR_POSMR (1 << 14) + +/* + * Controller Revision Register (CRR, Read Only) + */ +#define FTSDMC021_CRR_REV_VER (((x) >> 0) & 0xff) +#define FTSDMC021_CRR_MINOR_VER (((x) >> 8) & 0xff) +#define FTSDMC021_CRR_MAJOR_VER (((x) >> 16) & 0xff) + +/* + * Controller Feature Register (CFR, Read Only) + */ +#define FTSDMC021_CFR_EBNK (((x) >> 0) & 0xf) +#define FTSDMC021_CFR_CHN (((x) >> 8) & 0xf) +#define FTSDMC021_CFR_EBI (((x) >> 16) & 0x1) +#define FTSDMC021_CFR_CH1_FDEPTH (((x) >> 24) & 0x1) +#define FTSDMC021_CFR_CH2_FDEPTH (((x) >> 25) & 0x1) +#define FTSDMC021_CFR_CH3_FDEPTH (((x) >> 26) & 0x1) +#define FTSDMC021_CFR_CH4_FDEPTH (((x) >> 27) & 0x1) +#define FTSDMC021_CFR_CH5_FDEPTH (((x) >> 28) & 0x1) +#define FTSDMC021_CFR_CH6_FDEPTH (((x) >> 29) & 0x1) +#define FTSDMC021_CFR_CH7_FDEPTH (((x) >> 30) & 0x1) +#define FTSDMC021_CFR_CH8_FDEPTH (((x) >> 31) & 0x1) + +#endif /* __FTSDMC021_H */
Dear "Macpaul Lin",
Changes for v2:
lowlevel_init
Corrupted patch (line wrapped). Please resubmit after fixing your mailer (or better use git sendmail).
Hi Wolfgang,
2011/4/26 Wolfgang Denk wd@denx.de:
I did use git sent-email to send this patch. However it seems still some problem. I will change a mail server to resend this.
Please help on check the latest patch if the corruption still occurs.
Sorry for the bothering.
Changes for v2: - Add __ASSEMBLY__ protecton to register offset for supporting lowlevel_init --- include/faraday/ftahbc020s.h | 94 ++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 94 insertions(+), 0 deletions(-) create mode 100644 include/faraday/ftahbc020s.h
Changes for v2: - Add __ASSEMBLY__ protecton to register offset for supporting lowlevel_init --- include/faraday/ftsdmc021.h | 154 +++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 154 insertions(+), 0 deletions(-) create mode 100644 include/faraday/ftsdmc021.h
Signed-off-by: Macpaul Lin macpaul@andestech.com --- Changes for v2: - Add __ASSEMBLY__ protecton to register offset for supporting lowlevel_init Changes for v3: - Patch: no change. Changed a mail server to resend this.
Dear Macpaul Lin,
In message 1303797876-28548-1-git-send-email-macpaul@andestech.com you wrote:
Changes for v2:
Changes for v3:
See previous comment: I think this should be done using asm-offsets instead.
I recommend to use a generic macro here, as recommended for the other patch.
- FTAHBC020S_PCR - Priority Control Register
Ditto here. Why flooding the code with tons of (mostly) unused defines?
Use:
#define FTAHBC020S_PCR_PLEVEL(x) (1 << (x))
Dear Macpaul Lin,
In message 1303797876-28548-2-git-send-email-macpaul@andestech.com you wrote:
Changes for v2:
Changes for v3:
Lines too long. Please fix globally.
I think it is generally wrong to manually define these offsets here. You should use a C struct instead, and auto-generate the offsets if needed using the asm-offsets approach (see top level Makefile for details).
- Default value is 0x800.
- The 12-bit equals to the haddr[31:20] of AHB address bus. */
Why don't you use a generic macro here, like
#define FTSDMC021_BANK_SIZE(sz) (ffs(x) - 21)
Hi Wolfgang,
Dear Macpaul Lin,
Since this is a patch send before in old times, I will fix it soon and send the next patch.
Thanks for your suggestion.
Signed-off-by: Macpaul Lin macpaul@andestech.com --- Changes for v2: - Add __ASSEMBLY__ protecton to register offset for supporting lowlevel_init Changes for v3: - Patch: no change. Changed a mail server to resend this patch Changes for v4: - Fix BSR according to datasheet. - Replace offset define into structure. - Replace the constant of power of 2 define into (ffs(x) - 1) - Replace redundant define of PCR into simple version.
include/faraday/ftahbc020s.h | 59 ++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 59 insertions(+), 0 deletions(-) create mode 100644 include/faraday/ftahbc020s.h
diff --git a/include/faraday/ftahbc020s.h b/include/faraday/ftahbc020s.h new file mode 100644 index 0000000..c6b0c16 --- /dev/null +++ b/include/faraday/ftahbc020s.h @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2011 Andes Technology Corporation + * Macpaul Lin, Andes Technology Corporation macpaul@andestech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* FTAHBC020S - AHB Controller (Arbiter/Decoder) definitions */ +#ifndef __FTAHBC020S_H +#define __FTAHBC202S_H + +/* Registers Offsets */ + +/* + * AHB Slave BSR, offset: n * 4, n=0~31 + */ +#ifndef __ASSEMBLY__ +struct ftahbc02s { + unsigned int s_bsr[32]; /* 0x00-0x7c - Slave n Base/Size Reg */ + unsigned int pcr; /* 0x80 - Priority Ctrl Reg */ + unsigned int tcrg; /* 0x84 - Transfer Ctrl Reg */ + unsigned int cr; /* 0x88 - Ctrl Reg */ +}; +#endif /* __ASSEMBLY__ */ + +/* + * FTAHBC020S_SLAVE_BSR - Slave n Base / Size Register + */ +#define FTAHBC020S_SLAVE_BSR_BASE(x) (((x) & 0xfff) << 20) +#define FTAHBC020S_SLAVE_BSR_SIZE(x) (((x) & 0xf) << 16) +/* The value of b(16:19)SLAVE_BSR_SIZE: 1M-2048M, must be power of 2 */ +#define FTAHBC020S_BSR_SIZE(x) (ffs(x) - 1) /* size of Addr Space */ + +/* + * FTAHBC020S_PCR - Priority Control Register + */ +#define FTAHBC020S_PCR_PLEVEL_(x) (1 << (x)) /* x: 1-15 */ + +/* + * FTAHBC020S_CR - Interrupt Control Register + */ +#define FTAHBC020S_CR_INTSTS (1 << 24) +#define FTAHBC020S_CR_RESP(x) (((x) & 0x3) << 20) +#define FTAHBC020S_CR_INTSMASK (1 << 16) +#define FTAHBC020S_CR_REMAP (1 << 0) + +#endif /* __FTAHBC020S_H */
Signed-off-by: Macpaul Lin macpaul@andestech.com --- Changes for v2: - Add __ASSEMBLY__ protecton to register offset for supporting lowlevel_init Changes for v3: - Patch: no change. Changed a mail server to resend this patch Changes for v4: - Cleanup. - Replace lines over 80 chararters with proper statement. - Add some bit-field description about important registers. - Replace the define of constant which is power of 2 to (ffs(x - 1))
include/faraday/ftsdmc021.h | 151 +++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 151 insertions(+), 0 deletions(-) create mode 100644 include/faraday/ftsdmc021.h
diff --git a/include/faraday/ftsdmc021.h b/include/faraday/ftsdmc021.h new file mode 100644 index 0000000..483d991 --- /dev/null +++ b/include/faraday/ftsdmc021.h @@ -0,0 +1,151 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * (C) Copyright 2011 Andes Technology Corp + * Macpaul Lin macpaul@andestech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * FTSDMC021 - SDRAM Controller + */ +#ifndef __FTSDMC021_H +#define __FTSDMC021_H + +#ifndef __ASSEMBLY__ +struct ftsdmc021 { + unsigned int tp1; /* 0x00 - SDRAM Timing Parameter 1 */ + unsigned int tp2; /* 0x04 - SDRAM Timing Parameter 2 */ + unsigned int cr1; /* 0x08 - SDRAM Configuration Reg 1 */ + unsigned int cr2; /* 0x0c - SDRAM Configuration Reg 2 */ + unsigned int bank0_bsr; /* 0x10 - Ext. Bank Base/Size Reg 0 */ + unsigned int bank1_bsr; /* 0x14 - Ext. Bank Base/Size Reg 1 */ + unsigned int bank2_bsr; /* 0x18 - Ext. Bank Base/Size Reg 2 */ + unsigned int bank3_bsr; /* 0x1c - Ext. Bank Base/Size Reg 3 */ + unsigned int bank4_bsr; /* 0x20 - Ext. Bank Base/Size Reg 4 */ + unsigned int bank5_bsr; /* 0x24 - Ext. Bank Base/Size Reg 5 */ + unsigned int bank6_bsr; /* 0x28 - Ext. Bank Base/Size Reg 6 */ + unsigned int bank7_bsr; /* 0x2c - Ext. Bank Base/Size Reg 7 */ + unsigned int ragr; /* 0x30 - Read Arbitration Group Reg */ + unsigned int frr; /* 0x34 - Flush Request Register */ + unsigned int ebisr; /* 0x38 - EBI Support Register */ + unsigned int RSVED[25]; /* 0x3c-0x9c - Reserved */ + unsigned int crr; /* 0x100 - Controller Revision Reg */ + unsigned int cfr; /* 0x104 - Controller Feature Reg */ +}; +#endif /* __ASSEMBLY__ */ + +/* + * Timing Parameter 1 Register + */ +#define FTSDMC021_TP1_TCL(x) ((x) & 0x3) /* CAS Latency */ +#define FTSDMC021_TP1_TWR(x) (((x) & 0x3) << 4) /* W-Recovery Time */ +#define FTSDMC021_TP1_TRF(x) (((x) & 0xf) << 8) /* Auto-Refresh Cycle */ +#define FTSDMC021_TP1_TRCD(x) (((x) & 0x7) << 12) /* RAS-to-CAS Delay */ +#define FTSDMC021_TP1_TRP(x) (((x) & 0xf) << 16) /* Precharge Cycle */ +#define FTSDMC021_TP1_TRAS(x) (((x) & 0xf) << 20) + +/* + * Timing Parameter 2 Register + */ +#define FTSDMC021_TP2_REF_INTV(x) ((x) & 0xffff) /* Refresh interval */ +/* b(16:19) - Initial Refresh Times */ +#define FTSDMC021_TP2_INI_REFT(x) (((x) & 0xf) << 16) +/* b(20:23) - Initial Pre-Charge Times */ +#define FTSDMC021_TP2_INI_PREC(x) (((x) & 0xf) << 20) + +/* + * SDRAM Configuration Register 1 + */ +#define FTSDMC021_CR1_BNKSIZE(x) ((x) & 0xf) /* Bank Size */ +#define FTSDMC021_CR1_MBW(x) (((x) & 0x3) << 4) /* Bus Width */ +#define FTSDMC021_CR1_DSZ(x) (((x) & 0x7) << 8) /* SDRAM Size */ +#define FTSDMC021_CR1_DDW(x) (((x) & 0x3) << 12) /* Data Width */ +/* b(16) MA2T: Double Memory Address Cycle Enable */ +#define FTSDMC021_CR1_MA2T(x) (1 << 16) +/* The value of b(0:3)CR1: 1M-512M, must be power of 2 */ +#define FTSDMC021_BANK_SIZE(x) (ffs(x) - 1) + +/* + * Configuration Register 2 + */ +#define FTSDMC021_CR2_SREF (1 << 0) /* Self-Refresh Mode */ +#define FTSDMC021_CR2_PWDN (1 << 1) /* Power Down Operation Mode */ +#define FTSDMC021_CR2_ISMR (1 << 2) /* Start Set-Mode-Register */ +#define FTSDMC021_CR2_IREF (1 << 3) /* Init Refresh Start Flag */ +#define FTSDMC021_CR2_IPREC (1 << 4) /* Init Pre-Charge Start Flag */ +#define FTSDMC021_CR2_REFTYPE (1 << 5) + +/* + * SDRAM External Bank Base/Size Register + */ +#define FTSDMC021_BANK_ENABLE (1 << 12) + +/* 12-bit base address of external bank. + * Default value is 0x800. + * The 12-bit equals to the haddr[31:20] of AHB address bus. */ +#define FTSDMC021_BANK_BASE(x) ((x) & 0xfff) + +/* + * Read Arbitration Grant Window Register + */ +#define FTSDMC021_RAGR_CH1GW(x) (((x) & 0xff) << 0) +#define FTSDMC021_RAGR_CH2GW(x) (((x) & 0xff) << 4) +#define FTSDMC021_RAGR_CH3GW(x) (((x) & 0xff) << 8) +#define FTSDMC021_RAGR_CH4GW(x) (((x) & 0xff) << 12) +#define FTSDMC021_RAGR_CH5GW(x) (((x) & 0xff) << 16) +#define FTSDMC021_RAGR_CH6GW(x) (((x) & 0xff) << 20) +#define FTSDMC021_RAGR_CH7GW(x) (((x) & 0xff) << 24) +#define FTSDMC021_RAGR_CH8GW(x) (((x) & 0xff) << 28) + +/* + * Flush Request Register + */ +#define FTSDMC021_FRR_FLUSHCHN(x) (((x) & 0x7) << 0) +#define FTSDMC021_FRR_FLUSHCMPLT (1 << 3) /* Flush Req Flag */ + +/* + * External Bus Interface Support Register (EBISR) + */ +#define FTSDMC021_EBISR_MR(x) ((x) & 0xfff) /* Far-end mode */ +#define FTSDMC021_EBISR_PRSMR (1 << 12) /* Pre-SMR */ +#define FTSDMC021_EBISR_POPREC (1 << 13) +#define FTSDMC021_EBISR_POSMR (1 << 14) /* Post-SMR */ + +/* + * Controller Revision Register (CRR, Read Only) + */ +#define FTSDMC021_CRR_REV_VER (((x) >> 0) & 0xff) +#define FTSDMC021_CRR_MINOR_VER (((x) >> 8) & 0xff) +#define FTSDMC021_CRR_MAJOR_VER (((x) >> 16) & 0xff) + +/* + * Controller Feature Register (CFR, Read Only) + */ +#define FTSDMC021_CFR_EBNK (((x) >> 0) & 0xf) +#define FTSDMC021_CFR_CHN (((x) >> 8) & 0xf) +#define FTSDMC021_CFR_EBI (((x) >> 16) & 0x1) +#define FTSDMC021_CFR_CH1_FDEPTH (((x) >> 24) & 0x1) +#define FTSDMC021_CFR_CH2_FDEPTH (((x) >> 25) & 0x1) +#define FTSDMC021_CFR_CH3_FDEPTH (((x) >> 26) & 0x1) +#define FTSDMC021_CFR_CH4_FDEPTH (((x) >> 27) & 0x1) +#define FTSDMC021_CFR_CH5_FDEPTH (((x) >> 28) & 0x1) +#define FTSDMC021_CFR_CH6_FDEPTH (((x) >> 29) & 0x1) +#define FTSDMC021_CFR_CH7_FDEPTH (((x) >> 30) & 0x1) +#define FTSDMC021_CFR_CH8_FDEPTH (((x) >> 31) & 0x1) + +#endif /* __FTSDMC021_H */
Dear Macpaul Lin,
In message 1303813524-28948-2-git-send-email-macpaul@andestech.com you wrote:
Changes for v2:
Changes for v3:
Changes for v4:
- Cleanup.
- (C) Copyright 2009 Faraday Technology
- Po-Yu Chuang ratbert@faraday-tech.com
- (C) Copyright 2011 Andes Technology Corp
- Macpaul Lin macpaul@andestech.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
- FTSDMC021 - SDRAM Controller
- unsigned int tp1; /* 0x00 - SDRAM Timing Parameter 1 */
- unsigned int tp2; /* 0x04 - SDRAM Timing Parameter 2 */
- unsigned int cr1; /* 0x08 - SDRAM Configuration Reg 1 */
- unsigned int cr2; /* 0x0c - SDRAM Configuration Reg 2 */
- unsigned int bank0_bsr; /* 0x10 - Ext. Bank Base/Size Reg 0 */
- unsigned int bank1_bsr; /* 0x14 - Ext. Bank Base/Size Reg 1 */
- unsigned int bank2_bsr; /* 0x18 - Ext. Bank Base/Size Reg 2 */
- unsigned int bank3_bsr; /* 0x1c - Ext. Bank Base/Size Reg 3 */
- unsigned int bank4_bsr; /* 0x20 - Ext. Bank Base/Size Reg 4 */
- unsigned int bank5_bsr; /* 0x24 - Ext. Bank Base/Size Reg 5 */
- unsigned int bank6_bsr; /* 0x28 - Ext. Bank Base/Size Reg 6 */
- unsigned int bank7_bsr; /* 0x2c - Ext. Bank Base/Size Reg 7 */
- unsigned int ragr; /* 0x30 - Read Arbitration Group Reg */
- unsigned int frr; /* 0x34 - Flush Request Register */
- unsigned int ebisr; /* 0x38 - EBI Support Register */
- unsigned int RSVED[25]; /* 0x3c-0x9c - Reserved */
Sorry, but only macro definitions use ALL CAPS names. Variables names are all lower case.
Hi Wolfgang,
Dear Macpaul Lin,
I was think of no used variable will be CAPS names to avoid typo with variable that will be used.
Will send the fix soon.
Thanks.
Move the header file "ftsdmc020.h" (SDRAM Controller) to "include/faraday" folder.
This change will let other SoC which also use ftsdmc020 could share the same header file.
Signed-off-by: Macpaul Lin macpaul@andestech.com --- Changes for v2: - Fix the include path of ftsdmc020 for a320evb. - v1 of this patch /patch/71953/ in patchworks has been marked as superseded.
arch/arm/include/asm/arch-a320/ftsdmc020.h | 103 ---------------------------- board/faraday/a320evb/lowlevel_init.S | 2 +- include/faraday/ftsdmc020.h | 103 ++++++++++++++++++++++++++++ 3 files changed, 104 insertions(+), 104 deletions(-) delete mode 100644 arch/arm/include/asm/arch-a320/ftsdmc020.h create mode 100644 include/faraday/ftsdmc020.h
diff --git a/arch/arm/include/asm/arch-a320/ftsdmc020.h b/arch/arm/include/asm/arch-a320/ftsdmc020.h deleted file mode 100644 index 0699772..0000000 --- a/arch/arm/include/asm/arch-a320/ftsdmc020.h +++ /dev/null @@ -1,103 +0,0 @@ -/* - * (C) Copyright 2009 Faraday Technology - * Po-Yu Chuang ratbert@faraday-tech.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. - */ - -/* - * SDRAM Controller - */ -#ifndef __FTSDMC020_H -#define __FTSDMC020_H - -#define FTSDMC020_OFFSET_TP0 0x00 -#define FTSDMC020_OFFSET_TP1 0x04 -#define FTSDMC020_OFFSET_CR 0x08 -#define FTSDMC020_OFFSET_BANK0_BSR 0x0C -#define FTSDMC020_OFFSET_BANK1_BSR 0x10 -#define FTSDMC020_OFFSET_BANK2_BSR 0x14 -#define FTSDMC020_OFFSET_BANK3_BSR 0x18 -#define FTSDMC020_OFFSET_BANK4_BSR 0x1C -#define FTSDMC020_OFFSET_BANK5_BSR 0x20 -#define FTSDMC020_OFFSET_BANK6_BSR 0x24 -#define FTSDMC020_OFFSET_BANK7_BSR 0x28 -#define FTSDMC020_OFFSET_ACR 0x34 - -/* - * Timing Parametet 0 Register - */ -#define FTSDMC020_TP0_TCL(x) ((x) & 0x3) -#define FTSDMC020_TP0_TWR(x) (((x) & 0x3) << 4) -#define FTSDMC020_TP0_TRF(x) (((x) & 0xf) << 8) -#define FTSDMC020_TP0_TRCD(x) (((x) & 0x7) << 12) -#define FTSDMC020_TP0_TRP(x) (((x) & 0xf) << 16) -#define FTSDMC020_TP0_TRAS(x) (((x) & 0xf) << 20) - -/* - * Timing Parametet 1 Register - */ -#define FTSDMC020_TP1_REF_INTV(x) ((x) & 0xffff) -#define FTSDMC020_TP1_INI_REFT(x) (((x) & 0xf) << 16) -#define FTSDMC020_TP1_INI_PREC(x) (((x) & 0xf) << 20) - -/* - * Configuration Register - */ -#define FTSDMC020_CR_SREF (1 << 0) -#define FTSDMC020_CR_PWDN (1 << 1) -#define FTSDMC020_CR_ISMR (1 << 2) -#define FTSDMC020_CR_IREF (1 << 3) -#define FTSDMC020_CR_IPREC (1 << 4) -#define FTSDMC020_CR_REFTYPE (1 << 5) - -/* - * SDRAM External Bank Base/Size Register - */ -#define FTSDMC020_BANK_ENABLE (1 << 28) - -#define FTSDMC020_BANK_BASE(addr) (((addr) >> 20) << 16) - -#define FTSDMC020_BANK_DDW_X4 (0 << 12) -#define FTSDMC020_BANK_DDW_X8 (1 << 12) -#define FTSDMC020_BANK_DDW_X16 (2 << 12) -#define FTSDMC020_BANK_DDW_X32 (3 << 12) - -#define FTSDMC020_BANK_DSZ_16M (0 << 8) -#define FTSDMC020_BANK_DSZ_64M (1 << 8) -#define FTSDMC020_BANK_DSZ_128M (2 << 8) -#define FTSDMC020_BANK_DSZ_256M (3 << 8) - -#define FTSDMC020_BANK_MBW_8 (0 << 4) -#define FTSDMC020_BANK_MBW_16 (1 << 4) -#define FTSDMC020_BANK_MBW_32 (2 << 4) - -#define FTSDMC020_BANK_SIZE_1M 0x0 -#define FTSDMC020_BANK_SIZE_2M 0x1 -#define FTSDMC020_BANK_SIZE_4M 0x2 -#define FTSDMC020_BANK_SIZE_8M 0x3 -#define FTSDMC020_BANK_SIZE_16M 0x4 -#define FTSDMC020_BANK_SIZE_32M 0x5 -#define FTSDMC020_BANK_SIZE_64M 0x6 -#define FTSDMC020_BANK_SIZE_128M 0x7 -#define FTSDMC020_BANK_SIZE_256M 0x8 - -/* - * Arbiter Control Register - */ -#define FTSDMC020_ACR_TOC(x) ((x) & 0x1f) -#define FTSDMC020_ACR_TOE (1 << 8) - -#endif /* __FTSDMC020_H */ diff --git a/board/faraday/a320evb/lowlevel_init.S b/board/faraday/a320evb/lowlevel_init.S index 97718c0..4262c11 100644 --- a/board/faraday/a320evb/lowlevel_init.S +++ b/board/faraday/a320evb/lowlevel_init.S @@ -21,7 +21,7 @@ #include <version.h>
#include <asm/macro.h> -#include <asm/arch/ftsdmc020.h> +#include <faraday/ftsdmc020.h>
/* * parameters for the SDRAM controller diff --git a/include/faraday/ftsdmc020.h b/include/faraday/ftsdmc020.h new file mode 100644 index 0000000..0699772 --- /dev/null +++ b/include/faraday/ftsdmc020.h @@ -0,0 +1,103 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * SDRAM Controller + */ +#ifndef __FTSDMC020_H +#define __FTSDMC020_H + +#define FTSDMC020_OFFSET_TP0 0x00 +#define FTSDMC020_OFFSET_TP1 0x04 +#define FTSDMC020_OFFSET_CR 0x08 +#define FTSDMC020_OFFSET_BANK0_BSR 0x0C +#define FTSDMC020_OFFSET_BANK1_BSR 0x10 +#define FTSDMC020_OFFSET_BANK2_BSR 0x14 +#define FTSDMC020_OFFSET_BANK3_BSR 0x18 +#define FTSDMC020_OFFSET_BANK4_BSR 0x1C +#define FTSDMC020_OFFSET_BANK5_BSR 0x20 +#define FTSDMC020_OFFSET_BANK6_BSR 0x24 +#define FTSDMC020_OFFSET_BANK7_BSR 0x28 +#define FTSDMC020_OFFSET_ACR 0x34 + +/* + * Timing Parametet 0 Register + */ +#define FTSDMC020_TP0_TCL(x) ((x) & 0x3) +#define FTSDMC020_TP0_TWR(x) (((x) & 0x3) << 4) +#define FTSDMC020_TP0_TRF(x) (((x) & 0xf) << 8) +#define FTSDMC020_TP0_TRCD(x) (((x) & 0x7) << 12) +#define FTSDMC020_TP0_TRP(x) (((x) & 0xf) << 16) +#define FTSDMC020_TP0_TRAS(x) (((x) & 0xf) << 20) + +/* + * Timing Parametet 1 Register + */ +#define FTSDMC020_TP1_REF_INTV(x) ((x) & 0xffff) +#define FTSDMC020_TP1_INI_REFT(x) (((x) & 0xf) << 16) +#define FTSDMC020_TP1_INI_PREC(x) (((x) & 0xf) << 20) + +/* + * Configuration Register + */ +#define FTSDMC020_CR_SREF (1 << 0) +#define FTSDMC020_CR_PWDN (1 << 1) +#define FTSDMC020_CR_ISMR (1 << 2) +#define FTSDMC020_CR_IREF (1 << 3) +#define FTSDMC020_CR_IPREC (1 << 4) +#define FTSDMC020_CR_REFTYPE (1 << 5) + +/* + * SDRAM External Bank Base/Size Register + */ +#define FTSDMC020_BANK_ENABLE (1 << 28) + +#define FTSDMC020_BANK_BASE(addr) (((addr) >> 20) << 16) + +#define FTSDMC020_BANK_DDW_X4 (0 << 12) +#define FTSDMC020_BANK_DDW_X8 (1 << 12) +#define FTSDMC020_BANK_DDW_X16 (2 << 12) +#define FTSDMC020_BANK_DDW_X32 (3 << 12) + +#define FTSDMC020_BANK_DSZ_16M (0 << 8) +#define FTSDMC020_BANK_DSZ_64M (1 << 8) +#define FTSDMC020_BANK_DSZ_128M (2 << 8) +#define FTSDMC020_BANK_DSZ_256M (3 << 8) + +#define FTSDMC020_BANK_MBW_8 (0 << 4) +#define FTSDMC020_BANK_MBW_16 (1 << 4) +#define FTSDMC020_BANK_MBW_32 (2 << 4) + +#define FTSDMC020_BANK_SIZE_1M 0x0 +#define FTSDMC020_BANK_SIZE_2M 0x1 +#define FTSDMC020_BANK_SIZE_4M 0x2 +#define FTSDMC020_BANK_SIZE_8M 0x3 +#define FTSDMC020_BANK_SIZE_16M 0x4 +#define FTSDMC020_BANK_SIZE_32M 0x5 +#define FTSDMC020_BANK_SIZE_64M 0x6 +#define FTSDMC020_BANK_SIZE_128M 0x7 +#define FTSDMC020_BANK_SIZE_256M 0x8 + +/* + * Arbiter Control Register + */ +#define FTSDMC020_ACR_TOC(x) ((x) & 0x1f) +#define FTSDMC020_ACR_TOE (1 << 8) + +#endif /* __FTSDMC020_H */
Hi MacPaul Lin,
Signed-off-by: Macpaul Linmacpaul@andestech.com
Changes for v2:
superseded.
Please use git format-patch -M or -C to get the move actually shown in the patch as a rename rather than as a delete+create.
Amicalement,
Hi Albert,
2011/4/16 Albert ARIBAUD albert.u.boot@aribaud.net:
Hi MacPaul Lin,
Thanks for your tip of -M or -C options. Should I resend these two patches? Or you have already applied them into arm's master?
Hi Macpaul Lin,
Le 16/04/2011 08:43, Macpaul Lin a écrit :
Hi Albert,
2011/4/16 Albert ARIBAUDalbert.u.boot@aribaud.net:
Hi MacPaul Lin,
Please resend a V3 patch set of the four patches, even if two of them are unchanged. Make sure all patches have their history updated, even the unchanged patches ('V3: no change'). I'll apply the whole set in one go.
Amicalement,
HI Albert,
Amicalement,
Albert.
Patch v3 of this set of patches has been send on 2011-04-16
Please refer to http://patchwork.ozlabs.org/patch/91478/ http://patchwork.ozlabs.org/patch/91479/ http://patchwork.ozlabs.org/patch/91476/ http://patchwork.ozlabs.org/patch/91477/
Thanks.
Hi MacPaul,
Le 21/04/2011 04:57, Macpaul Lin a écrit :
HI Albert,
Amicalement,
Albert.
91476 and 91477 are ok, I'll apply them.
91478 and 91479, though, I don't see their point: they are adding a file that obviously no one used before it was added, but that no one uses now. These header files are dead code, and should only be added in a patch where other code changes actually make them required.
Amicalement,
Hi Albert,
2011/4/21 Albert ARIBAUD albert.u.boot@aribaud.net:
Amicalement,
Albert.
Roger that. I'll resend this later with the SoC which used it is under reviewing. Thanks.
Move the header file and definitions of ftsmc020 static memory control unit from a320 SoC folder to "drivers/mtd" folder.
This change will let other SoC which also use ftsmc020 could share the same header file.
Signed-off-by: Macpaul Lin macpaul@andestech.com --- Changes for v2: - Move the header file of ftsmc020.h to include/faraday. - Fix the include path of ftsmc020 for a320evb. - v1 of this patch /patch/71957/ in patchworks has been marked as superseded.
arch/arm/cpu/arm920t/a320/Makefile | 1 - arch/arm/cpu/arm920t/a320/ftsmc020.c | 51 ------------------ arch/arm/include/asm/arch-a320/ftsmc020.h | 79 ----------------------------- board/faraday/a320evb/a320evb.c | 2 +- drivers/mtd/Makefile | 1 + drivers/mtd/ftsmc020.c | 51 ++++++++++++++++++ include/configs/a320evb.h | 4 +- include/faraday/ftsmc020.h | 79 +++++++++++++++++++++++++++++ 8 files changed, 135 insertions(+), 133 deletions(-) delete mode 100644 arch/arm/cpu/arm920t/a320/ftsmc020.c delete mode 100644 arch/arm/include/asm/arch-a320/ftsmc020.h create mode 100644 drivers/mtd/ftsmc020.c create mode 100644 include/faraday/ftsmc020.h
diff --git a/arch/arm/cpu/arm920t/a320/Makefile b/arch/arm/cpu/arm920t/a320/Makefile index 31da706..50eb265 100644 --- a/arch/arm/cpu/arm920t/a320/Makefile +++ b/arch/arm/cpu/arm920t/a320/Makefile @@ -27,7 +27,6 @@ LIB = $(obj)lib$(SOC).o
SOBJS += reset.o COBJS += timer.o -COBJS += ftsmc020.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/arm920t/a320/ftsmc020.c b/arch/arm/cpu/arm920t/a320/ftsmc020.c deleted file mode 100644 index 7646537..0000000 --- a/arch/arm/cpu/arm920t/a320/ftsmc020.c +++ /dev/null @@ -1,51 +0,0 @@ -/* - * (C) Copyright 2009 Faraday Technology - * Po-Yu Chuang ratbert@faraday-tech.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. - */ - -#include <config.h> -#include <common.h> -#include <asm/io.h> -#include <asm/arch/ftsmc020.h> - -struct ftsmc020_config { - unsigned int config; - unsigned int timing; -}; - -static struct ftsmc020_config config[] = CONFIG_SYS_FTSMC020_CONFIGS; - -static struct ftsmc020 *smc = (struct ftsmc020 *)CONFIG_FTSMC020_BASE; - -static void ftsmc020_setup_bank(unsigned int bank, struct ftsmc020_config *cfg) -{ - if (bank > 3) { - printf("bank # %u invalid\n", bank); - return; - } - - writel(cfg->config, &smc->bank[bank].cr); - writel(cfg->timing, &smc->bank[bank].tpr); -} - -void ftsmc020_init(void) -{ - int i; - - for (i = 0; i < ARRAY_SIZE(config); i++) - ftsmc020_setup_bank(i, &config[i]); -} diff --git a/arch/arm/include/asm/arch-a320/ftsmc020.h b/arch/arm/include/asm/arch-a320/ftsmc020.h deleted file mode 100644 index 95d9500..0000000 --- a/arch/arm/include/asm/arch-a320/ftsmc020.h +++ /dev/null @@ -1,79 +0,0 @@ -/* - * (C) Copyright 2009 Faraday Technology - * Po-Yu Chuang ratbert@faraday-tech.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. - */ - -/* - * Static Memory Controller - */ -#ifndef __FTSMC020_H -#define __FTSMC020_H - -#ifndef __ASSEMBLY__ - -struct ftsmc020 { - struct { - unsigned int cr; /* 0x00, 0x08, 0x10, 0x18 */ - unsigned int tpr; /* 0x04, 0x0c, 0x14, 0x1c */ - } bank[4]; - unsigned int pad[8]; /* 0x20 - 0x3c */ - unsigned int ssr; /* 0x40 */ -}; - -void ftsmc020_init(void); - -#endif /* __ASSEMBLY__ */ - -/* - * Memory Bank Configuration Register - */ -#define FTSMC020_BANK_ENABLE (1 << 28) -#define FTSMC020_BANK_BASE(x) ((x) & 0x0fff1000) - -#define FTSMC020_BANK_WPROT (1 << 11) - -#define FTSMC020_BANK_SIZE_32K (0xb << 4) -#define FTSMC020_BANK_SIZE_64K (0xc << 4) -#define FTSMC020_BANK_SIZE_128K (0xd << 4) -#define FTSMC020_BANK_SIZE_256K (0xe << 4) -#define FTSMC020_BANK_SIZE_512K (0xf << 4) -#define FTSMC020_BANK_SIZE_1M (0x0 << 4) -#define FTSMC020_BANK_SIZE_2M (0x1 << 4) -#define FTSMC020_BANK_SIZE_4M (0x2 << 4) -#define FTSMC020_BANK_SIZE_8M (0x3 << 4) -#define FTSMC020_BANK_SIZE_16M (0x4 << 4) -#define FTSMC020_BANK_SIZE_32M (0x5 << 4) - -#define FTSMC020_BANK_MBW_8 (0x0 << 0) -#define FTSMC020_BANK_MBW_16 (0x1 << 0) -#define FTSMC020_BANK_MBW_32 (0x2 << 0) - -/* - * Memory Bank Timing Parameter Register - */ -#define FTSMC020_TPR_ETRNA(x) (((x) & 0xf) << 28) -#define FTSMC020_TPR_EATI(x) (((x) & 0xf) << 24) -#define FTSMC020_TPR_RBE (1 << 20) -#define FTSMC020_TPR_AST(x) (((x) & 0x3) << 18) -#define FTSMC020_TPR_CTW(x) (((x) & 0x3) << 16) -#define FTSMC020_TPR_ATI(x) (((x) & 0xf) << 12) -#define FTSMC020_TPR_AT2(x) (((x) & 0x3) << 8) -#define FTSMC020_TPR_WTC(x) (((x) & 0x3) << 6) -#define FTSMC020_TPR_AHT(x) (((x) & 0x3) << 4) -#define FTSMC020_TPR_TRNA(x) (((x) & 0xf) << 0) - -#endif /* __FTSMC020_H */ diff --git a/board/faraday/a320evb/a320evb.c b/board/faraday/a320evb/a320evb.c index b9343e4..2578be4 100644 --- a/board/faraday/a320evb/a320evb.c +++ b/board/faraday/a320evb/a320evb.c @@ -21,7 +21,7 @@ #include <netdev.h> #include <asm/io.h>
-#include <asm/arch/ftsmc020.h> +#include <faraday/ftsmc020.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index 999431c..5a5ecdf 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -32,6 +32,7 @@ COBJS-$(CONFIG_HAS_DATAFLASH) += at45.o COBJS-$(CONFIG_FLASH_CFI_DRIVER) += cfi_flash.o COBJS-$(CONFIG_FLASH_CFI_MTD) += cfi_mtd.o COBJS-$(CONFIG_HAS_DATAFLASH) += dataflash.o +COBJS-$(CONFIG_FTSMC020) += ftsmc020.o COBJS-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o COBJS-$(CONFIG_MW_EEPROM) += mw_eeprom.o COBJS-$(CONFIG_SPEARSMI) += spr_smi.o diff --git a/drivers/mtd/ftsmc020.c b/drivers/mtd/ftsmc020.c new file mode 100644 index 0000000..b027685 --- /dev/null +++ b/drivers/mtd/ftsmc020.c @@ -0,0 +1,51 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <faraday/ftsmc020.h> + +struct ftsmc020_config { + unsigned int config; + unsigned int timing; +}; + +static struct ftsmc020_config config[] = CONFIG_SYS_FTSMC020_CONFIGS; + +static struct ftsmc020 *smc = (struct ftsmc020 *)CONFIG_FTSMC020_BASE; + +static void ftsmc020_setup_bank(unsigned int bank, struct ftsmc020_config *cfg) +{ + if (bank > 3) { + printf("bank # %u invalid\n", bank); + return; + } + + writel(cfg->config, &smc->bank[bank].cr); + writel(cfg->timing, &smc->bank[bank].tpr); +} + +void ftsmc020_init(void) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(config); i++) + ftsmc020_setup_bank(i, &config[i]); +} diff --git a/include/configs/a320evb.h b/include/configs/a320evb.h index 5373bcb..4b297f0 100644 --- a/include/configs/a320evb.h +++ b/include/configs/a320evb.h @@ -163,7 +163,8 @@ * Static memory controller configuration */
-#include <asm/arch/ftsmc020.h> +#define CONFIG_FTSMC020 +#include <faraday/ftsmc020.h>
#define FTSMC020_BANK0_CONFIG (FTSMC020_BANK_ENABLE | \ FTSMC020_BANK_BASE(PHYS_FLASH_1) | \ @@ -196,6 +197,7 @@ { FTSMC020_BANK0_CONFIG, FTSMC020_BANK0_TIMING, }, \ { FTSMC020_BANK1_CONFIG, FTSMC020_BANK1_TIMING, }, \ } +#endif /* CONFIG_FTSMC020 */
/*----------------------------------------------------------------------- * FLASH and environment organization diff --git a/include/faraday/ftsmc020.h b/include/faraday/ftsmc020.h new file mode 100644 index 0000000..95d9500 --- /dev/null +++ b/include/faraday/ftsmc020.h @@ -0,0 +1,79 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * Static Memory Controller + */ +#ifndef __FTSMC020_H +#define __FTSMC020_H + +#ifndef __ASSEMBLY__ + +struct ftsmc020 { + struct { + unsigned int cr; /* 0x00, 0x08, 0x10, 0x18 */ + unsigned int tpr; /* 0x04, 0x0c, 0x14, 0x1c */ + } bank[4]; + unsigned int pad[8]; /* 0x20 - 0x3c */ + unsigned int ssr; /* 0x40 */ +}; + +void ftsmc020_init(void); + +#endif /* __ASSEMBLY__ */ + +/* + * Memory Bank Configuration Register + */ +#define FTSMC020_BANK_ENABLE (1 << 28) +#define FTSMC020_BANK_BASE(x) ((x) & 0x0fff1000) + +#define FTSMC020_BANK_WPROT (1 << 11) + +#define FTSMC020_BANK_SIZE_32K (0xb << 4) +#define FTSMC020_BANK_SIZE_64K (0xc << 4) +#define FTSMC020_BANK_SIZE_128K (0xd << 4) +#define FTSMC020_BANK_SIZE_256K (0xe << 4) +#define FTSMC020_BANK_SIZE_512K (0xf << 4) +#define FTSMC020_BANK_SIZE_1M (0x0 << 4) +#define FTSMC020_BANK_SIZE_2M (0x1 << 4) +#define FTSMC020_BANK_SIZE_4M (0x2 << 4) +#define FTSMC020_BANK_SIZE_8M (0x3 << 4) +#define FTSMC020_BANK_SIZE_16M (0x4 << 4) +#define FTSMC020_BANK_SIZE_32M (0x5 << 4) + +#define FTSMC020_BANK_MBW_8 (0x0 << 0) +#define FTSMC020_BANK_MBW_16 (0x1 << 0) +#define FTSMC020_BANK_MBW_32 (0x2 << 0) + +/* + * Memory Bank Timing Parameter Register + */ +#define FTSMC020_TPR_ETRNA(x) (((x) & 0xf) << 28) +#define FTSMC020_TPR_EATI(x) (((x) & 0xf) << 24) +#define FTSMC020_TPR_RBE (1 << 20) +#define FTSMC020_TPR_AST(x) (((x) & 0x3) << 18) +#define FTSMC020_TPR_CTW(x) (((x) & 0x3) << 16) +#define FTSMC020_TPR_ATI(x) (((x) & 0xf) << 12) +#define FTSMC020_TPR_AT2(x) (((x) & 0x3) << 8) +#define FTSMC020_TPR_WTC(x) (((x) & 0x3) << 6) +#define FTSMC020_TPR_AHT(x) (((x) & 0x3) << 4) +#define FTSMC020_TPR_TRNA(x) (((x) & 0xf) << 0) + +#endif /* __FTSMC020_H */
Hi MacMaul Lin,
Changes for v2:
superseded.
Please regenerate with git format-patch -C or -M to get moves to show as rename, not delete+create.
Amicalement,
Signed-off-by: Macpaul Lin macpaul@andestech.com --- Changes for v2: - Add __ASSEMBLY__ protecton to register offset for supporting lowlevel_init Changes for v3: - Patch: no change. Changed a mail server to resend this patch Changes for v4: - Fix BSR according to datasheet. - Replace offset define into structure. - Replace the constant of power of 2 define into (ffs(x) - 1) - Replace redundant define of PCR into simple version. Changes for v5: - No Change
Dear Macpaul Lin,
Changes for v2:
Changes for v3:
Changes for v4:
Changes for v5:
- No Change
Applied, thanks.
Signed-off-by: Macpaul Lin macpaul@andestech.com --- Changes for v2: - Add __ASSEMBLY__ protecton to register offset for supporting lowlevel_init Changes for v3: - Patch: no change. Changed a mail server to resend this patch Changes for v4: - Cleanup. - Replace lines over 80 chararters with proper statement. - Add some bit-field description about important registers. - Replace the define of constant which is power of 2 to (ffs(x - 1)) Changes for v5: - Replace all CAPS variable into lower case.
diff --git a/include/faraday/ftsdmc021.h b/include/faraday/ftsdmc021.h new file mode 100644 index 0000000..fa12e1a --- /dev/null +++ b/include/faraday/ftsdmc021.h @@ -0,0 +1,151 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * (C) Copyright 2011 Andes Technology Corp + * Macpaul Lin macpaul@andestech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * FTSDMC021 - SDRAM Controller + */ +#ifndef __FTSDMC021_H +#define __FTSDMC021_H + +#ifndef __ASSEMBLY__ +struct ftsdmc021 { + unsigned int tp1; /* 0x00 - SDRAM Timing Parameter 1 */ + unsigned int tp2; /* 0x04 - SDRAM Timing Parameter 2 */ + unsigned int cr1; /* 0x08 - SDRAM Configuration Reg 1 */ + unsigned int cr2; /* 0x0c - SDRAM Configuration Reg 2 */ + unsigned int bank0_bsr; /* 0x10 - Ext. Bank Base/Size Reg 0 */ + unsigned int bank1_bsr; /* 0x14 - Ext. Bank Base/Size Reg 1 */ + unsigned int bank2_bsr; /* 0x18 - Ext. Bank Base/Size Reg 2 */ + unsigned int bank3_bsr; /* 0x1c - Ext. Bank Base/Size Reg 3 */ + unsigned int bank4_bsr; /* 0x20 - Ext. Bank Base/Size Reg 4 */ + unsigned int bank5_bsr; /* 0x24 - Ext. Bank Base/Size Reg 5 */ + unsigned int bank6_bsr; /* 0x28 - Ext. Bank Base/Size Reg 6 */ + unsigned int bank7_bsr; /* 0x2c - Ext. Bank Base/Size Reg 7 */ + unsigned int ragr; /* 0x30 - Read Arbitration Group Reg */ + unsigned int frr; /* 0x34 - Flush Request Register */ + unsigned int ebisr; /* 0x38 - EBI Support Register */ + unsigned int rsved[25]; /* 0x3c-0x9c - Reserved */ + unsigned int crr; /* 0x100 - Controller Revision Reg */ + unsigned int cfr; /* 0x104 - Controller Feature Reg */ +}; +#endif /* __ASSEMBLY__ */ + +/* + * Timing Parameter 1 Register + */ +#define FTSDMC021_TP1_TCL(x) ((x) & 0x3) /* CAS Latency */ +#define FTSDMC021_TP1_TWR(x) (((x) & 0x3) << 4) /* W-Recovery Time */ +#define FTSDMC021_TP1_TRF(x) (((x) & 0xf) << 8) /* Auto-Refresh Cycle */ +#define FTSDMC021_TP1_TRCD(x) (((x) & 0x7) << 12) /* RAS-to-CAS Delay */ +#define FTSDMC021_TP1_TRP(x) (((x) & 0xf) << 16) /* Precharge Cycle */ +#define FTSDMC021_TP1_TRAS(x) (((x) & 0xf) << 20) + +/* + * Timing Parameter 2 Register + */ +#define FTSDMC021_TP2_REF_INTV(x) ((x) & 0xffff) /* Refresh interval */ +/* b(16:19) - Initial Refresh Times */ +#define FTSDMC021_TP2_INI_REFT(x) (((x) & 0xf) << 16) +/* b(20:23) - Initial Pre-Charge Times */ +#define FTSDMC021_TP2_INI_PREC(x) (((x) & 0xf) << 20) + +/* + * SDRAM Configuration Register 1 + */ +#define FTSDMC021_CR1_BNKSIZE(x) ((x) & 0xf) /* Bank Size */ +#define FTSDMC021_CR1_MBW(x) (((x) & 0x3) << 4) /* Bus Width */ +#define FTSDMC021_CR1_DSZ(x) (((x) & 0x7) << 8) /* SDRAM Size */ +#define FTSDMC021_CR1_DDW(x) (((x) & 0x3) << 12) /* Data Width */ +/* b(16) MA2T: Double Memory Address Cycle Enable */ +#define FTSDMC021_CR1_MA2T(x) (1 << 16) +/* The value of b(0:3)CR1: 1M-512M, must be power of 2 */ +#define FTSDMC021_BANK_SIZE(x) (ffs(x) - 1) + +/* + * Configuration Register 2 + */ +#define FTSDMC021_CR2_SREF (1 << 0) /* Self-Refresh Mode */ +#define FTSDMC021_CR2_PWDN (1 << 1) /* Power Down Operation Mode */ +#define FTSDMC021_CR2_ISMR (1 << 2) /* Start Set-Mode-Register */ +#define FTSDMC021_CR2_IREF (1 << 3) /* Init Refresh Start Flag */ +#define FTSDMC021_CR2_IPREC (1 << 4) /* Init Pre-Charge Start Flag */ +#define FTSDMC021_CR2_REFTYPE (1 << 5) + +/* + * SDRAM External Bank Base/Size Register + */ +#define FTSDMC021_BANK_ENABLE (1 << 12) + +/* 12-bit base address of external bank. + * Default value is 0x800. + * The 12-bit equals to the haddr[31:20] of AHB address bus. */ +#define FTSDMC021_BANK_BASE(x) ((x) & 0xfff) + +/* + * Read Arbitration Grant Window Register + */ +#define FTSDMC021_RAGR_CH1GW(x) (((x) & 0xff) << 0) +#define FTSDMC021_RAGR_CH2GW(x) (((x) & 0xff) << 4) +#define FTSDMC021_RAGR_CH3GW(x) (((x) & 0xff) << 8) +#define FTSDMC021_RAGR_CH4GW(x) (((x) & 0xff) << 12) +#define FTSDMC021_RAGR_CH5GW(x) (((x) & 0xff) << 16) +#define FTSDMC021_RAGR_CH6GW(x) (((x) & 0xff) << 20) +#define FTSDMC021_RAGR_CH7GW(x) (((x) & 0xff) << 24) +#define FTSDMC021_RAGR_CH8GW(x) (((x) & 0xff) << 28) + +/* + * Flush Request Register + */ +#define FTSDMC021_FRR_FLUSHCHN(x) (((x) & 0x7) << 0) +#define FTSDMC021_FRR_FLUSHCMPLT (1 << 3) /* Flush Req Flag */ + +/* + * External Bus Interface Support Register (EBISR) + */ +#define FTSDMC021_EBISR_MR(x) ((x) & 0xfff) /* Far-end mode */ +#define FTSDMC021_EBISR_PRSMR (1 << 12) /* Pre-SMR */ +#define FTSDMC021_EBISR_POPREC (1 << 13) +#define FTSDMC021_EBISR_POSMR (1 << 14) /* Post-SMR */ + +/* + * Controller Revision Register (CRR, Read Only) + */ +#define FTSDMC021_CRR_REV_VER (((x) >> 0) & 0xff) +#define FTSDMC021_CRR_MINOR_VER (((x) >> 8) & 0xff) +#define FTSDMC021_CRR_MAJOR_VER (((x) >> 16) & 0xff) + +/* + * Controller Feature Register (CFR, Read Only) + */ +#define FTSDMC021_CFR_EBNK (((x) >> 0) & 0xf) +#define FTSDMC021_CFR_CHN (((x) >> 8) & 0xf) +#define FTSDMC021_CFR_EBI (((x) >> 16) & 0x1) +#define FTSDMC021_CFR_CH1_FDEPTH (((x) >> 24) & 0x1) +#define FTSDMC021_CFR_CH2_FDEPTH (((x) >> 25) & 0x1) +#define FTSDMC021_CFR_CH3_FDEPTH (((x) >> 26) & 0x1) +#define FTSDMC021_CFR_CH4_FDEPTH (((x) >> 27) & 0x1) +#define FTSDMC021_CFR_CH5_FDEPTH (((x) >> 28) & 0x1) +#define FTSDMC021_CFR_CH6_FDEPTH (((x) >> 29) & 0x1) +#define FTSDMC021_CFR_CH7_FDEPTH (((x) >> 30) & 0x1) +#define FTSDMC021_CFR_CH8_FDEPTH (((x) >> 31) & 0x1) + +#endif /* __FTSDMC021_H */
Dear Macpaul Lin,
Changes for v2:
Changes for v3:
Changes for v4:
- Cleanup.
Changes for v5:
Applied, thanks.
Albert ARIBAUD
Macpaul Lin
Macpaul Lin
