[PATCH v2 0/3] Add spi flash lock option
Disabling the flash lock option for versal and versal-net mini ospi and qspi defconfigs.
Changes in v2: - Updated the commit message. - Added SPI_FLASH_LOCK in cmd/sf.c, so when disabling this option "sf protect" commands wont appear to users.
Venkatesh Yadav Abbarapu (3): mtd: spi-nor: Add spi flash lock config option arm64: versal: Disable the lock option for mini ospi and qspi arm64: versal_net: Disable the lock option for mini ospi and qspi
cmd/sf.c | 4 +++- configs/xilinx_versal_mini_ospi_defconfig | 3 ++- configs/xilinx_versal_mini_qspi_defconfig | 3 ++- configs/xilinx_versal_net_mini_ospi_defconfig | 3 ++- configs/xilinx_versal_net_mini_qspi_defconfig | 3 ++- drivers/mtd/spi/Kconfig | 7 +++++++ drivers/mtd/spi/spi-nor-core.c | 8 +++++++- 7 files changed, 25 insertions(+), 6 deletions(-)
Provide an explicit configuration option to disable default "lock" of any flash chip which supports locking. By disabling the lock config will save some amount of memory and also don't expose the lock functionality to the users i.e., via sf protect command.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- cmd/sf.c | 4 +++- drivers/mtd/spi/Kconfig | 7 +++++++ drivers/mtd/spi/spi-nor-core.c | 8 +++++++- 3 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/cmd/sf.c b/cmd/sf.c index 55bef2f769..fa0be4248c 100644 --- a/cmd/sf.c +++ b/cmd/sf.c @@ -604,7 +604,7 @@ static int do_spi_flash(struct cmd_tbl *cmdtp, int flag, int argc, ret = do_spi_flash_read_write(argc, argv); else if (strcmp(cmd, "erase") == 0) ret = do_spi_flash_erase(argc, argv); - else if (strcmp(cmd, "protect") == 0) + else if (IS_ENABLED(CONFIG_SPI_FLASH_LOCK) && strcmp(cmd, "protect") == 0) ret = do_spi_protect(argc, argv); else if (IS_ENABLED(CONFIG_CMD_SF_TEST) && !strcmp(cmd, "test")) ret = do_spi_flash_test(argc, argv); @@ -630,8 +630,10 @@ static const char long_help[] = "sf update addr offset|partition len - erase and write `len' bytes from memory\n" " at `addr' to flash at `offset'\n" " or to start of mtd `partition'\n" +#ifdef CONFIG_SPI_FLASH_LOCK "sf protect lock/unlock sector len - protect/unprotect 'len' bytes starting\n" " at address 'sector'" +#endif #ifdef CONFIG_CMD_SF_TEST "\nsf test offset len - run a very basic destructive test" #endif diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index a9617c6c58..476d848321 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -134,6 +134,13 @@ config SPI_FLASH_BAR Bank/Extended address registers are used to access the flash which has size > 16MiB in 3-byte addressing.
+config SPI_FLASH_LOCK + bool "Enable the Locking feature" + default y + help + Enable the SPI flash lock support. By default this is set to y. + If you intend not to use the lock support you should say n here. + config SPI_FLASH_UNLOCK_ALL bool "Unlock the entire SPI flash on u-boot startup" default y diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 6093277f17..9c51f2b1b0 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -1099,6 +1099,7 @@ static int spansion_erase_non_uniform(struct spi_nor *nor, u32 addr, } #endif
+#if defined(CONFIG_SPI_FLASH_LOCK) #if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) /* Write status register and ensure bits in mask match written values */ static int write_sr_and_check(struct spi_nor *nor, u8 status_new, u8 mask) @@ -1386,6 +1387,7 @@ static int stm_is_unlocked(struct spi_nor *nor, loff_t ofs, uint64_t len) return stm_is_unlocked_sr(nor, ofs, len, status); } #endif /* CONFIG_SPI_FLASH_STMICRO */ +#endif
static const struct flash_info *spi_nor_read_id(struct spi_nor *nor) { @@ -1461,6 +1463,7 @@ read_err: return ret; }
+#if defined(CONFIG_SPI_FLASH_LOCK) #ifdef CONFIG_SPI_FLASH_SST /* * sst26 flash series has its own block protection implementation: @@ -1729,6 +1732,8 @@ sst_write_err: return ret; } #endif +#endif + /* * Write an address range to the nor chip. Data must be written in * FLASH_PAGESIZE chunks. The address range may be any size provided @@ -4103,6 +4108,7 @@ int spi_nor_scan(struct spi_nor *nor) mtd->_read = spi_nor_read; mtd->_write = spi_nor_write;
+#if defined(CONFIG_SPI_FLASH_LOCK) #if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) /* NOR protection support for STmicro/Micron chips and similar */ if (JEDEC_MFR(info) == SNOR_MFR_ST || @@ -4126,7 +4132,7 @@ int spi_nor_scan(struct spi_nor *nor) nor->flash_is_unlocked = sst26_is_unlocked; } #endif - +#endif if (info->flags & USE_FSR) nor->flags |= SNOR_F_USE_FSR; if (info->flags & SPI_NOR_HAS_TB)
As mini configs are required only for flashing the images, so disabling the lock config which will save nearly 6KB of memory.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- configs/xilinx_versal_mini_ospi_defconfig | 3 ++- configs/xilinx_versal_mini_qspi_defconfig | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/configs/xilinx_versal_mini_ospi_defconfig b/configs/xilinx_versal_mini_ospi_defconfig index 27b59f899a..539ce2d3c0 100644 --- a/configs/xilinx_versal_mini_ospi_defconfig +++ b/configs/xilinx_versal_mini_ospi_defconfig @@ -12,7 +12,6 @@ CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x80 # CONFIG_DM_GPIO is not set CONFIG_DEFAULT_DEVICE_TREE="versal-mini-ospi-single" -CONFIG_SYS_PROMPT="Versal> " CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_VERSAL_NO_DDR=y # CONFIG_PSCI_RESET is not set @@ -27,6 +26,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set +CONFIG_SYS_PROMPT="Versal> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set @@ -57,6 +57,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SOFT_RESET=y CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y +# CONFIG_SPI_FLASH_LOCK is not set CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/xilinx_versal_mini_qspi_defconfig b/configs/xilinx_versal_mini_qspi_defconfig index 4b0793411c..93365e7d30 100644 --- a/configs/xilinx_versal_mini_qspi_defconfig +++ b/configs/xilinx_versal_mini_qspi_defconfig @@ -10,7 +10,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xFFFE0000 CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x80 CONFIG_DEFAULT_DEVICE_TREE="versal-mini-qspi-single" -CONFIG_SYS_PROMPT="Versal> " CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_VERSAL_NO_DDR=y # CONFIG_PSCI_RESET is not set @@ -27,6 +26,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set +CONFIG_SYS_PROMPT="Versal> " # CONFIG_SYS_XTRACE is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set @@ -61,6 +61,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_SMART_HWCAPS is not set +# CONFIG_SPI_FLASH_LOCK is not set # CONFIG_SPI_FLASH_UNLOCK_ALL is not set CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_ISSI=y
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- configs/xilinx_versal_net_mini_ospi_defconfig | 3 ++- configs/xilinx_versal_net_mini_qspi_defconfig | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/configs/xilinx_versal_net_mini_ospi_defconfig b/configs/xilinx_versal_net_mini_ospi_defconfig index d11e180780..db3e7c80b2 100644 --- a/configs/xilinx_versal_net_mini_ospi_defconfig +++ b/configs/xilinx_versal_net_mini_ospi_defconfig @@ -12,7 +12,6 @@ CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x80 # CONFIG_DM_GPIO is not set CONFIG_DEFAULT_DEVICE_TREE="versal-net-mini-ospi-single" -CONFIG_SYS_PROMPT="Versal NET> " CONFIG_SYS_MEM_RSVD_FOR_MMU=y # CONFIG_PSCI_RESET is not set CONFIG_SYS_LOAD_ADDR=0xBBF80000 @@ -26,6 +25,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set +CONFIG_SYS_PROMPT="Versal NET> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set @@ -56,6 +56,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SOFT_RESET=y CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y +# CONFIG_SPI_FLASH_LOCK is not set CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/xilinx_versal_net_mini_qspi_defconfig b/configs/xilinx_versal_net_mini_qspi_defconfig index a7ebc38cda..c0ff42aa91 100644 --- a/configs/xilinx_versal_net_mini_qspi_defconfig +++ b/configs/xilinx_versal_net_mini_qspi_defconfig @@ -10,7 +10,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xBBF20000 CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x80 CONFIG_DEFAULT_DEVICE_TREE="versal-net-mini-qspi-single" -CONFIG_SYS_PROMPT="Versal NET> " CONFIG_SYS_MEM_RSVD_FOR_MMU=y # CONFIG_PSCI_RESET is not set CONFIG_SYS_LOAD_ADDR=0xBBF80000 @@ -26,6 +25,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set +CONFIG_SYS_PROMPT="Versal NET> " # CONFIG_SYS_XTRACE is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set @@ -60,6 +60,7 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_SMART_HWCAPS is not set +# CONFIG_SPI_FLASH_LOCK is not set # CONFIG_SPI_FLASH_UNLOCK_ALL is not set CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y
Changes in v2:
Applied. M
Michal Simek
