[U-Boot] [PATCH 1/2] Add env vars describing U-Boot target board
This can be useful for generic scripts. For example, rather than hard- coding a script to ext2load tegra-harmony.dtb, it could load ${board_soc}-${board_name}.dtb and hence not need adjustments to run on multiple boards.
Signed-off-by: Stephen Warren swarren@nvidia.com --- Wolfgang, does this seem like a reasonable feature? If so, can we merge it through the Tegra tree, since the next patch enables this for Tegra. Thanks!
common/Makefile | 9 +++++++++ common/env_common.c | 15 +++++++++++++++ common/env_embedded.c | 15 +++++++++++++++ 3 files changed, 39 insertions(+), 0 deletions(-)
diff --git a/common/Makefile b/common/Makefile index 6e23baa..e9fcd6a 100644 --- a/common/Makefile +++ b/common/Makefile @@ -44,6 +44,15 @@ COBJS-y += cmd_nvedit.o COBJS-y += cmd_version.o
# environment +board_config_vars := \ + '-DBOARD_ARCH="$(ARCH)"' \ + '-DBOARD_CPU="$(CPU)"' \ + '-DBOARD_NAME="$(BOARD)"' \ + '-DBOARD_VENDOR="$(VENDOR)"' \ + '-DBOARD_SOC="$(SOC)"' +CFLAGS_common/env_common.o += $(board_config_vars) +CFLAGS_common/env_embedded.o += $(board_config_vars) + COBJS-y += env_common.o COBJS-$(CONFIG_ENV_IS_IN_DATAFLASH) += env_dataflash.o COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += env_eeprom.o diff --git a/common/env_common.c b/common/env_common.c index c33d22d..4020ab9 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -116,6 +116,21 @@ const uchar default_environment[] = { #if defined(CONFIG_PCI_BOOTDELAY) && (CONFIG_PCI_BOOTDELAY > 0) "pcidelay=" MK_STR(CONFIG_PCI_BOOTDELAY) "\0" #endif +#ifdef CONFIG_ENV_VAR_BOARD_ARCH + "board_arch=" BOARD_ARCH "\0" +#endif +#ifdef CONFIG_ENV_VAR_BOARD_CPU + "board_cpu=" BOARD_CPU "\0" +#endif +#ifdef CONFIG_ENV_VAR_BOARD_NAME + "board_name=" BOARD_NAME "\0" +#endif +#ifdef CONFIG_ENV_VAR_BOARD_VENDOR + "board_vendor=" BOARD_VENDOR "\0" +#endif +#ifdef CONFIG_ENV_VAR_BOARD_SOC + "board_soc=" BOARD_SOC "\0" +#endif #ifdef CONFIG_EXTRA_ENV_SETTINGS CONFIG_EXTRA_ENV_SETTINGS #endif diff --git a/common/env_embedded.c b/common/env_embedded.c index 80fb29d..9ce2fc6 100644 --- a/common/env_embedded.c +++ b/common/env_embedded.c @@ -179,6 +179,21 @@ env_t environment __PPCENV__ = { #if defined(CONFIG_PCI_BOOTDELAY) && (CONFIG_PCI_BOOTDELAY > 0) "pcidelay=" MK_STR(CONFIG_PCI_BOOTDELAY) "\0" #endif +#ifdef CONFIG_ENV_VAR_BOARD_ARCH + "board_arch=" BOARD_ARCH "\0" +#endif +#ifdef CONFIG_ENV_VAR_BOARD_CPU + "board_cpu=" BOARD_CPU "\0" +#endif +#ifdef CONFIG_ENV_VAR_BOARD_NAME + "board_name=" BOARD_NAME "\0" +#endif +#ifdef CONFIG_ENV_VAR_BOARD_VENDOR + "board_vendor=" BOARD_VENDOR "\0" +#endif +#ifdef CONFIG_ENV_VAR_BOARD_SOC + "board_soc=" BOARD_SOC "\0" +#endif #ifdef CONFIG_EXTRA_ENV_SETTINGS CONFIG_EXTRA_ENV_SETTINGS #endif
So that all Tegra boards define environment variables that describe themselves.
Signed-off-by: Stephen Warren swarren@nvidia.com --- include/configs/tegra2-common.h | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/include/configs/tegra2-common.h b/include/configs/tegra2-common.h index 1931179..de9c39c 100644 --- a/include/configs/tegra2-common.h +++ b/include/configs/tegra2-common.h @@ -68,6 +68,9 @@ #endif
/* Environment */ +#define CONFIG_ENV_VAR_BOARD_NAME +#define CONFIG_ENV_VAR_BOARD_VENDOR +#define CONFIG_ENV_VAR_BOARD_SOC #define CONFIG_ENV_SIZE 0x2000 /* Total Size Environment */
I do like the idea; this moves to the right direction for generic scripts :)
Dear Stephen Warren,
In message 1337189793-25367-1-git-send-email-swarren@wwwdotorg.org you wrote:
Please make this optional - I don't want to have this enforced on all boards, whether they want it or not.
Wolfgang,
Thanks for taking a look. The variables are already optional; you need to set CONFIG_ENV_VAR_* in order for common/env_*.c to add those variables to the default environment. Is that OK?
Ah, now I see what you mean. But this is awkward. Why do we need both CONFIG_ENV_VAR_<foo> and <foo> ? Also note that these BOARD_* names are kind of polluting the name space. I don't like that.
Just use a single variable with an appropriate value for each of these settings. And don't pass these on the command line (which is already unreadable enough), but add it to the auto-generated config file.
And make the whole feature user selectable - I think it makes no sense if you have to individually enable all the 5 settings.
Hm... thinking about this, I also don't like the "board_*" prefix. What you actually have are names, i. e. it should probably read "soc_name" instead of "board_soc", etc.
Otavio Salvador
Stephen Warren
