[U-Boot] [PATCH] ARM: Add support for edb93xx boards
Add support for the Cirrus EP93xx platform and EDB93xx boards
Signed-off-by: Matthias Kaehlcke matthias@kaehlcke.net
This work is based on the patch from Dominic Rath for the Olimex CS-E9301 board (http://article.gmane.org/gmane.linux.ports.arm.cirrus/722) and some input from a patch for EDB93xx boards from Herbert Valerio Riedel (http://stud3.tuwien.ac.at/~e9725348/Projects/ep93xx/u-boot-1.2.0-edb93xx_sup...)
For now it has been tested on boards based on the EDB9301 and EDB9307A design.
Makefile | 36 ++ board/edb93xx/Makefile | 51 ++ board/edb93xx/config.mk | 1 + board/edb93xx/edb93xx.c | 120 +++++ board/edb93xx/flash_cfg.S | 42 ++ board/edb93xx/pll_cfg.S | 93 ++++ board/edb93xx/sdram_cfg.S | 217 +++++++++ board/edb93xx/u-boot.lds | 59 +++ cpu/arm920t/ep93xx/Makefile | 55 +++ cpu/arm920t/ep93xx/cpu.c | 125 +++++ cpu/arm920t/ep93xx/eth.c | 876 ++++++++++++++++++++++++++++++++++ cpu/arm920t/ep93xx/lowlevel_init.S | 74 +++ cpu/arm920t/ep93xx/speed.c | 120 +++++ cpu/arm920t/ep93xx/timer.c | 163 +++++++ include/asm-arm/arch-ep93xx/ep93xx.h | 868 +++++++++++++++++++++++++++++++++ include/common.h | 6 + include/configs/edb93xx.h | 235 +++++++++ 17 files changed, 3141 insertions(+), 0 deletions(-)
diff --git a/Makefile b/Makefile index bcb3fe9..8ddd19d 100644 --- a/Makefile +++ b/Makefile @@ -2429,6 +2429,42 @@ TQM834x_config: unconfig vme8349_config: unconfig @$(MKCONFIG) $(@:_config=) ppc mpc83xx vme8349 esd
+edb93xx_config \ +edb9301_config \ +edb9302_config \ +edb9302a_config \ +edb9307_config \ +edb9307a_config \ +edb9315a_config: unconfig + @if [ "$(findstring 01_,$@)" ] ; then \ + echo "#define CONFIG_EDB9301" >> $(obj)include/config.h ; \ + elif [ "$(findstring 02_,$@)" ] ; then \ + echo "#define CONFIG_EDB9302" >> $(obj)include/config.h ; \ + elif [ "$(findstring 02a_,$@)" ] ; then \ + echo "#define CONFIG_EDB9302A" >> $(obj)include/config.h ; \ + elif [ "$(findstring 07_,$@)" ] ; then \ + echo "#define CONFIG_EDB9307" >> $(obj)include/config.h ; \ + elif [ "$(findstring 07a_,$@)" ] ; then \ + echo "#define CONFIG_EDB9307A" >> $(obj)include/config.h ; \ + elif [ "$(findstring 12_,$@)" ] ; then \ + echo "#define CONFIG_EDB9312" >> $(obj)include/config.h ; \ + elif [ "$(findstring 15_,$@)" ] ; then \ + echo "#define CONFIG_EDB9315" >> $(obj)include/config.h ; \ + elif [ "$(findstring 15a_,$@)" ] ; then \ + echo "#define CONFIG_EDB9315A" >> $(obj)include/config.h ; \ + fi ; + + @$(MKCONFIG) -a edb93xx arm arm920t edb93xx NULL ep93xx + @if [ "$(findstring 01_,$@)" ] || [ "$(findstring 02_,$@)" ]; then \ + echo "TEXT_BASE = 0x05400000" >> $(obj)include/config.mk ; \ + elif [ "$(findstring 02a_,$@)" ]; then \ + echo "TEXT_BASE = 0xc5400000" >> $(obj)include/config.mk ; \ + elif [ "$(findstring 07_,$@)" ] || [ "$(findstring 12_,$@)" ] || [ "$(findstring 15_,$@)" ]; then \ + echo "TEXT_BASE = 0x01f00000" >> $(obj)include/config.mk ; \ + elif [ "$(findstring 07a_,$@)" ] || [ "$(findstring 15a_,$@)" ]; then \ + echo "TEXT_BASE = 0xc1f00000" >> $(obj)include/config.mk ; \ + fi ; + ######################################################################### ## MPC85xx Systems ######################################################################### diff --git a/board/edb93xx/Makefile b/board/edb93xx/Makefile new file mode 100644 index 0000000..57c109d --- /dev/null +++ b/board/edb93xx/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2003-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := edb93xx.o +SOBJS := flash_cfg.o pll_cfg.o sdram_cfg.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/edb93xx/config.mk b/board/edb93xx/config.mk new file mode 100644 index 0000000..dffa83e --- /dev/null +++ b/board/edb93xx/config.mk @@ -0,0 +1 @@ +LDSCRIPT := $(SRCTREE)/board/$(BOARDDIR)/u-boot.lds \ No newline at end of file diff --git a/board/edb93xx/edb93xx.c b/board/edb93xx/edb93xx.c new file mode 100644 index 0000000..fdbb956 --- /dev/null +++ b/board/edb93xx/edb93xx.c @@ -0,0 +1,120 @@ +/* + * vim: set ts=4 sw=4 noet: + */ +/* + * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net + * + * (C) Copyright 2002 2003 + * Network Audio Technologies, Inc. <www.netaudiotech.com> + * Adam Bezanson bezanson@netaudiotech.com + * + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/ep93xx.h> +#include <asm/io.h> + +int board_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + icache_enable(); + +#ifdef USE_920T_MMU + dcache_enable(); +#endif + + /* set UARTBAUD bit to drive UARTs with 14.7456MHz instead of + * 14.7456/2 MHz + */ + uint32_t value = readl(SYSCON_PWRCNT); + value |= SYSCON_PWRCNT_UART_BAUD; + writel(value, SYSCON_PWRCNT); + + /* Machine number, as defined in linux/arch/arm/tools/mach-types + */ +#ifdef CONFIG_EDB9301 + gd->bd->bi_arch_number = 462; +#elif defined(CONFIG_EDB9302) + gd->bd->bi_arch_number = 538; +#elif defined(CONFIG_EDB9302A) + gd->bd->bi_arch_number = 1127; +#elif (defined CONFIG_EDB9307) + gd->bd->bi_arch_number = 607; +#elif (defined CONFIG_EDB9307A) + gd->bd->bi_arch_number = 1128; +#elif defined(CONFIG_EDB9312) + gd->bd->bi_arch_number = 451; +#elif defined(CONFIG_EDB9315) + gd->bd->bi_arch_number = 463; +#elif defined(CONFIG_EDB9315A) + gd->bd->bi_arch_number = 772; +#endif + + /* adress of boot parameters + */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + /* We have a console + */ + gd->have_console = 1; + + return 0; +} + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + unsigned int *src, *dst; + int i; + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE_1; + +#ifdef PHYS_SDRAM_2 + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_SIZE_2; +#endif + +#ifdef PHYS_SDRAM_3 + gd->bd->bi_dram[2].start = PHYS_SDRAM_3; + gd->bd->bi_dram[2].size = PHYS_SDRAM_SIZE_3; +#endif + +#ifdef PHYS_SDRAM_4 + gd->bd->bi_dram[3].start = PHYS_SDRAM_4; + gd->bd->bi_dram[3].size = PHYS_SDRAM_SIZE_4; +#endif + +#ifdef CONFIG_EDB93XX_SDCS3 + dst = (unsigned int *)0x00000000; +#else + dst = (unsigned int *)0xc0000000; +#endif + + /* copy exception vectors */ + src = (unsigned int *)_armboot_start; + + for (i = 0; i < 16; i++) + *dst++ = *src++; + + return 0; +} diff --git a/board/edb93xx/flash_cfg.S b/board/edb93xx/flash_cfg.S new file mode 100644 index 0000000..aa61a3c --- /dev/null +++ b/board/edb93xx/flash_cfg.S @@ -0,0 +1,42 @@ +/* + * Flash setup for Olimex CS-E9302 board + * + * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net + * + * Copyright (C) 2006 Dominic Rath Dominic.Rath@gmx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <asm/arch/ep93xx.h> + +.globl flash_cfg +flash_cfg: + /* configure smc bank 6 (Intel TE28F128J3D75 Strata Flash) + * ebibrkdis: 0, mw: 0x1 (16 bit), pme: 0, wp: 0, wst2: 2(+1), + * wst1: 5(+1), rble: 1, idcy: 2(+1) + * TODO: we don't enable page mode for now + */ + ldr r0, =SMC_BCR6 + + ldr r1, =(2 << SMC_BCR_IDCY_SHIFT | 5 << SMC_BCR_WST1_SHIFT | \ + SMC_BCR_BLE | 2 << SMC_BCR_WST2_SHIFT | 1 << SMC_BCR_MW_SHIFT) + + str r1, [r0] + + mov pc, lr diff --git a/board/edb93xx/pll_cfg.S b/board/edb93xx/pll_cfg.S new file mode 100644 index 0000000..ae69a7d --- /dev/null +++ b/board/edb93xx/pll_cfg.S @@ -0,0 +1,93 @@ +/* + * PLL setup for Cirrus EDB93xx boards + * + * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net + * + * Copyright (C) 2006 Dominic Rath Dominic.Rath@gmx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/ep93xx.h> + +.globl pll_cfg +pll_cfg: + /* configure PLL1 */ + ldr r0, =SYSCON_CLKSET1 +#if defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) || \ + defined(CONFIG_EDB9302A) + /* fclk_div: 2, nbyp1: 1, hclk_div: 5, pclk_div: 2 + * pll1_x1: 294912000.000000, pll1_x2ip: 36864000.000000, + * pll1_x2: 331776000.000000, pll1_out: 331776000.000000 + */ + ldr r1, =(7 << SYSCON_CLKSET_PLL_X2IPD_SHIFT | \ + 8 << SYSCON_CLKSET_PLL_X2FBD2_SHIFT | \ + 19 << SYSCON_CLKSET_PLL_X1FBD1_SHIFT | \ + 1 << SYSCON_CLKSET1_PCLK_DIV_SHIFT | \ + 3 << SYSCON_CLKSET1_HCLK_DIV_SHIFT | \ + SYSCON_CLKSET1_NBYP1 | \ + 1 << SYSCON_CLKSET1_FCLK_DIV_SHIFT) +#elif defined(CONFIG_EDB9307) || defined(CONFIG_EDB9307A) ||\ + defined CONFIG_EDB9312 || defined(CONFIG_EDB9315) ||\ + defined(CONFIG_EDB9315A) + /* fclk_div: 2, nbyp1: 1, hclk_div: 4, pclk_div: 2 + * pll1_x1: 3096576000.000000, pll1_x2ip: 129024000.000000, + * pll1_x2: 3999744000.000000, pll1_out: 1999872000.000000 + */ + ldr r1, =(23 << SYSCON_CLKSET_PLL_X2IPD_SHIFT | \ + 30 << SYSCON_CLKSET_PLL_X2FBD2_SHIFT | \ + 20 << SYSCON_CLKSET_PLL_X1FBD1_SHIFT | \ + 1 << SYSCON_CLKSET1_PCLK_DIV_SHIFT | \ + 2 << SYSCON_CLKSET1_HCLK_DIV_SHIFT | \ + SYSCON_CLKSET1_NBYP1 | \ + 1 << SYSCON_CLKSET1_FCLK_DIV_SHIFT) +#endif + str r1, [r0] + + /* flush the pipeline + * writing to CLKSET1 causes the EP9302 to enter standby for between + * 8 ms to 16 ms, until PLL1 stabilizes + */ + nop + nop + nop + nop + nop + + /* configure PLL2 + * usb_div: 4, nbyp2: 1, pll2_en: 1 + * pll2_x1: 368640000.000000, pll2_x2ip: 15360000.000000, + * pll2_x2: 384000000.000000, pll2_out: 192000000.000000 + */ + ldr r0, =SYSCON_CLKSET2 + ldr r1, =(23 << SYSCON_CLKSET_PLL_X2IPD_SHIFT | \ + 24 << SYSCON_CLKSET_PLL_X2FBD2_SHIFT | \ + 24 << SYSCON_CLKSET_PLL_X1FBD1_SHIFT | \ + 1 << SYSCON_CLKSET_PLL_PS_SHIFT | \ + SYSCON_CLKSET2_PLL2_EN | \ + SYSCON_CLKSET2_NBYP2 | \ + 3 << SYSCON_CLKSET2_USB_DIV_SHIFT) + str r1, [r0] + + /* the user's guide recommends to wait at least 1 ms for PLL2 to + * stabilize, but Cirrus' Redboot doesn't do that, either + */ + + mov pc, lr diff --git a/board/edb93xx/sdram_cfg.S b/board/edb93xx/sdram_cfg.S new file mode 100644 index 0000000..752bb72 --- /dev/null +++ b/board/edb93xx/sdram_cfg.S @@ -0,0 +1,217 @@ +/* + * SDRAM setup for edb93xx boards + * + * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net + * + * Copyright (C) 2006 Dominic Rath Dominic.Rath@gmx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/ep93xx.h> + +/* delay for 200us + * loop takes 4 cycles at 5.0ns (worst case, running at 200MHz) + * per cycle = 20ns, 0x3000 (12288) gives us 246us to be safe + */ +.macro delay200 + ldr r0, =0x3000 +200: + subs r0, r0, #1 + bne 200b +.endm + +.globl sdram_cfg +sdram_cfg: + +#ifdef CONFIG_EDB93XX_SDCS0 + ldr r1, =SDRAM_DEVCFG0 +#elif defined(CONFIG_EDB93XX_SDCS3) + ldr r1, =SDRAM_DEVCFG3 +#else +#error "SDRAM bank configuration" +#endif + +#if defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) ||\ + defined(CONFIG_EDB9302A) + /* 1x Samsung K4S561632C-TC/L75 4M x 16bit x 4 banks SDRAM + * + * CLK cycle time min: + * @ CAS latency = 3: 7.5ns + * @ CAS latency = 2: 10ns + * We're running at 66MHz (15ns cycle time) external bus speed (HCLK), + * so it's safe to use CAS latency = 2 + * + * RAS-to-CAS delay min: + * 20ns + * At 15ns cycle time, we use RAS-to-CAS delay = 2 + * + * SROMLL = 1: Swap BA[1:0] with A[13:12], making the SDRAM appear + * as four blocks of 8MB size, instead of eight blocks of 4MB size: + * + * EDB9301/EDB9302: + * + * 0x00000000 - 0x007fffff + * 0x01000000 - 0x017fffff + * 0x04000000 - 0x047fffff + * 0x05000000 - 0x057fffff + * + * + * EDB9302a: + * + * 0xc0000000 - 0xc07fffff + * 0xc1000000 - 0xc17fffff + * 0xc4000000 - 0xc47fffff + * 0xc5000000 - 0xc57fffff + * + * BANKCOUNT = 1: This is a device with four banks + */ + + ldr r0, =(SDRAM_DEVCFG_BANKCOUNT | SDRAM_DEVCFG_SROMLL |\ + SDRAM_DEVCFG_CASLAT_2 | SDRAM_DEVCFG_RASTOCAS_2 |\ + SDRAM_DEVCFG_EXTBUSWIDTH) +#elif defined(CONFIG_EDB9307) || defined(CONFIG_EDB9307A) ||\ + defined CONFIG_EDB9312 || defined(CONFIG_EDB9315) ||\ + defined(CONFIG_EDB9315A) + /* 2x Samsung K4S561632C-TC/L75 4M x 16bit x 4 banks SDRAM + * + * CLK cycle time min: + * @ CAS latency = 3: 7.5ns + * @ CAS latency = 2: 10ns + * We're running at 100MHz (10ns cycle time) external bus speed (HCLK), + * so it's safe to use CAS latency = 2 + * + * RAS-to-CAS delay min: + * 20ns + * At 10ns cycle time, we use RAS-to-CAS delay = 2 + * + * EDB9307, EDB9312, EDB9315: + * + * 0x00000000 - 0x01ffffff + * 0x04000000 - 0x05ffffff + * + * + * EDB9307a, EDB9315a: + * + * 0xc0000000 - 0xc1ffffff + * 0xc4000000 - 0xc5ffffff + * + */ + ldr r0, =(SDRAM_DEVCFG_BANKCOUNT | SDRAM_DEVCFG_SROMLL |\ + SDRAM_DEVCFG_CASLAT_2 | SDRAM_DEVCFG_RASTOCAS_2) +#endif + str r0, [r1] + + /* Issue continous NOP commands */ + ldr r1, =SDRAM_GLCONFIG + ldr r0, =(GLCONFIG_INIT | GLCONFIG_MRS | GLCONFIG_CKE) + str r0, [r1] + + delay200 + +#if defined(CONFIG_EP9301) || defined(CONFIG_EP9302) + /* Errata for EP9301/2 rev. E0 says that PRECHARGE ALL isn't always + * issued. + * Do a read from each bank to make sure they're precharged + * Logical address bits A[22:21] map to BA[1:0] (SROMLL is set) + * The errata further says that this isn't going to be fixed, + * therefor do it for all revisions + */ + ldr r0, =(GLCONFIG_CKE) + str r0, [r1] /* SDRAM_GLCONFIG */ + + ldr r0, =0x00000000 /* A[22:21] = b00 */ + str r0, [r0] + ldr r0, =0x00200000 /* A[22:21] = b01 */ + str r0, [r0] + ldr r0, =0x00400000 /* A[22:21] = b10 */ + str r0, [r0] + ldr r0, =0x00600000 /* A[22:21] = b11 */ + str r0, [r0] +#endif + + /* Load refresh timer with 10 to issue refresh every 10 cycles */ + ldr r1, =SDRAM_REFRSHTIMR + ldr r0, =0x0a + str r0, [r1] + + /* Wait at least 80 clock cycles to provide 8 refresh cycles + to all SDRAMs */ + delay200 /* we wait 200us, which is a lot more than necessary */ + + /* Program refresh timer with normal value + * We need 8192 refresh cycles every 64ms + * at 15ns (HCLK >= 66MHz) per cycle: + * 64ms / 8192 = 7.8125us + * 7.8125us / 15ns = 520 (0x208) + */ + /* TODO: redboot uses 0x1e0 for the slowest possible device + but i don't understand how this value is calculated */ + ldr r0, =0x208 + str r0, [r1] + + + /* Select mode register update mode */ + ldr r1, =SDRAM_GLCONFIG + ldr r0, =(GLCONFIG_CKE | GLCONFIG_MRS) + str r0, [r1] + +#if defined(CONFIG_EP9301) || defined(CONFIG_EP9302) + /* Program mode register + * A[22:09] is output as SYA[13:0] on a 16 bit ext. bus + * CAS latency: 2 + * Burst type: sequential + * Burst length: 8 (required for 16 bit ext. bus) + * SYA[13:0] = 0x0023 + */ + ldr r0, =0x00004600 + ldr r0, [r0] +#elif defined(CONFIG_EDB93XX_SDCS3) + ldr r0, =0x00008800 + ldr r0, [r0] + + ldr r0, =0x00400000 + ldr r0, [r0] + + ldr r0, =0x00808800 + ldr r0, [r0] + + ldr r0, =0x00c08800 + ldr r0, [r0] +#else + ldr r0, =0x00008800 + ldr r0, [r0] + + ldr r0, =0xc0400000 + ldr r0, [r0] + + ldr r0, =0xc0808800 + ldr r0, [r0] + + ldr r0, =0xc0c08800 + ldr r0, [r0] +#endif + + /* Select normal operation mode */ + ldr r1, =SDRAM_GLCONFIG + ldr r0, =(GLCONFIG_CKE) + str r0, [r1] + + mov pc, lr diff --git a/board/edb93xx/u-boot.lds b/board/edb93xx/u-boot.lds new file mode 100644 index 0000000..76caef3 --- /dev/null +++ b/board/edb93xx/u-boot.lds @@ -0,0 +1,59 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +/*OUTPUT_FORMAT("elf32-arm", "elf32-arm", "elf32-arm")*/ +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm920t/start.o (.text) + . = 0x1000; + LONG(0x53555243) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/cpu/arm920t/ep93xx/Makefile b/cpu/arm920t/ep93xx/Makefile new file mode 100644 index 0000000..9763e15 --- /dev/null +++ b/cpu/arm920t/ep93xx/Makefile @@ -0,0 +1,55 @@ +# vim: set ts=8 sw=8 noet: +# +# Cirrus Logic EP93xx CPU-specific Makefile +# +# Copyright (C) 2004, 2005 +# Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com +# +# Copyright (C) 2006 +# Dominic Rath Dominic.Rath@gmx.de +# +# Based on an original Makefile, which is +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this project. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, but +# WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY +# or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +# for more details. +# +# You should have received a copy of the GNU General Public License along +# with this program; if not, write to the Free Software Foundation, Inc., +# 675 Mass Ave, Cambridge, MA 02139, USA. +# +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS = cpu.o eth.o timer.o speed.o +SOBJS = lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### + diff --git a/cpu/arm920t/ep93xx/cpu.c b/cpu/arm920t/ep93xx/cpu.c new file mode 100644 index 0000000..3989ee8 --- /dev/null +++ b/cpu/arm920t/ep93xx/cpu.c @@ -0,0 +1,125 @@ +/* vim: set ts=8 sw=8 noet: + * + * Cirrus Logic EP93xx CPU-specific support. + * + * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net + * + * Copyright (C) 2004, 2005 + * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com + * + * See file CREDITS for list of people who contributed to this project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY + * or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License + * for more details. + * + * You should have received a copy of the GNU General Public License along + * with this program; if not, write to the Free Software Foundation, Inc., + * 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#include <common.h> + +#if defined(CONFIG_EP93XX) +#include <asm/arch/ep93xx.h> +#include <asm/io.h> + + +/* The errata for silicon revision E1 states that the PartID of the + * ExtensionID register is not programmed, and that this feature has been + * removed from the chip. + * + * Note also that the chip revision indication found in the CHIP_ID register + * (0x80930094) has proven reliable for determining a particular core's + * silicon version. + */ +extern int checkcpu(void) +{ + const uint32_t chip_id = readl(SYSCON_CHIPID); + + printf("CPU: Cirrus Logic EP93xx"); + printf(" - Rev. "); + switch (chip_id & SYSCON_CHIPID_REV_MASK) { + case 0x00000000: + printf("A"); + break; + + case 0x10000000: + printf("B"); + break; + + case 0x20000000: + printf("C"); + break; + + case 0x30000000: + printf("D0"); + break; + + case 0x40000000: + printf("D1"); + break; + + case 0x50000000: + printf("E0"); + break; + + default: + printf("?"); + break; + } + + return 0; +} + + +/* All EP93xx variants have 16 KiB I-cache. */ +extern int checkicache(void) +{ + return 16 << 10; +} + + +/* All EP93xx variants have 16 KiB D-cache. */ +extern int checkdcache(void) +{ + return 16 << 10; +} + + +/* This is a nop on ARM, and is included here for completeness only. */ +extern void upmconfig(unsigned int upm, unsigned int *table, unsigned int size) +{ + /* nop */ +} + + +/* We reset the CPU by generating a 1-->0 transition on DeviceCfg bit 31. */ +extern void reset_cpu(ulong addr) +{ + uint32_t value; + + /* Unlock DeviceCfg and set SWRST */ + writel(0xAA, SYSCON_SYSSWLOCK); + value = readl(SYSCON_DEVICECFG); + value |= SYSCON_DEVICECFG_SWRST; + writel(value, SYSCON_DEVICECFG); + + /* Unlock DeviceCfg and clear SWRST */ + writel(0xAA, SYSCON_SYSSWLOCK); + value = readl(SYSCON_DEVICECFG); + value &= ~SYSCON_DEVICECFG_SWRST; + writel(value, SYSCON_DEVICECFG); + + /* Dying... */ + while (1) + ; /* nop */ +} + + +#endif /* defined(CONFIG_EP93XX) */ diff --git a/cpu/arm920t/ep93xx/eth.c b/cpu/arm920t/ep93xx/eth.c new file mode 100644 index 0000000..513c221 --- /dev/null +++ b/cpu/arm920t/ep93xx/eth.c @@ -0,0 +1,876 @@ +/* vim: set ts=8 sw=8 noet: + * + * Cirrus Logic EP93xx ethernet MAC / MII driver. + * + * Copyright (C) 2004, 2005 + * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com + * + * Based on the original eth.[ch] Cirrus Logic EP93xx Rev D. Ethernet Driver, + * which is + * + * (C) Copyright 2002 2003 + * Adam Bezanson, Network Audio Technologies, Inc. + * bezanson@netaudiotech.com + * + * See file CREDITS for list of people who contributed to this project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY + * or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License + * for more details. + * + * You should have received a copy of the GNU General Public License along + * with this program; if not, write to the Free Software Foundation, Inc., + * 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#include <command.h> +#include <common.h> +#include <asm/arch/ep93xx.h> +#include <asm/io.h> +#include <malloc.h> +#include <miiphy.h> +#include <net.h> +#include <linux/types.h> + + +/** + * Send an error message to the terminal. + */ +#define ERROR(x) \ + do { \ + char *__foo = strrchr(__FILE__, '/'); \ + \ + printf("%s: %d: %s(): ", \ + (__foo == NULL ? __FILE__ : (__foo + 1)), \ + __LINE__, __func__); \ + printf x; printf("\n"); \ + } while (0); + + +/** + * Send a trace message to the terminal. + */ +#if 0 +#define TRACE(x) \ + do { \ + char *__foo = strrchr(__FILE__, '/'); \ + \ + printf("%s: %d: %s(): ", \ + (__foo == NULL ? __FILE__ : (__foo + 1)), \ + __LINE__, __func__); \ + printf x; printf("\n"); \ + } while (0); + +#else +#define TRACE(x) +#endif + + +/* ----------------------------------------------------------------------------- + * EP93xx ethernet MAC functionality + */ +#if defined(CONFIG_DRIVER_EP93XX_MAC) + +/** + * #define this to dump device status and queue info during initialization and + * following errors. + */ +#undef EP93XX_MAC_DEBUG + +/** + * Number of descriptor and status entries in our RX queues. + * It must be power of 2 ! + */ +#define NUMRXDESC PKTBUFSRX + +/** + * Number of descriptor and status entries in our TX queues. + */ +#define NUMTXDESC 1 + +/** + * 944 = (1024 - 64) - 16, Fifo size - Minframesize - 16 (Chip FACT) + */ +#define TXSTARTMAX 944 + + +/** + * Ethernet MAC interface return values for public functions. + */ +enum eth_status { + ETH_STATUS_SUCCESS = 0, + ETH_STATUS_FAILURE = 1, +}; + + +/** + * Receive descriptor queue entry + */ +struct rx_descriptor { + union { + uint32_t word1; + + struct { + unsigned buffer_address:32; + }; + }; + + union { + uint32_t word2; + + struct { + unsigned buffer_length:16; + unsigned buffer_index:15; + unsigned not_sof:1; + }; + }; +} __attribute__((packed)); + + +/** + * Receive status queue entry + */ +struct rx_status { + union { + uint32_t word1; + + struct { + unsigned:8; + unsigned hti:6; + unsigned:1; + unsigned crci:1; + unsigned crce:1; + unsigned edata:1; + unsigned runt:1; + unsigned fe:1; + unsigned oe:1; + unsigned rx_err:1; + unsigned am:2; + unsigned:4; + unsigned eob:1; + unsigned eof:1; + unsigned rwe:1; + unsigned rfp:1; + }; + }; + + union { + uint32_t word2; + + struct { + unsigned frame_length:16; + unsigned buffer_index:15; + unsigned rfp:1; + }; + }; +} __attribute__((packed)); + + +/** + * Transmit descriptor queue entry + */ +struct tx_descriptor { + union { + uint32_t word1; + + struct { + unsigned buffer_address:32; + }; + }; + + union { + uint32_t word2; + + struct { + unsigned buffer_length:12; + unsigned:3; + unsigned abort_frame:1; + unsigned buffer_index:15; + unsigned eof:1; + }; + }; +} __attribute__((packed)); + + +/** + * Transmit status queue entry + */ +struct tx_status { + union { + uint32_t word1; + + struct { + unsigned tbi:15; + unsigned:1; + unsigned ncoll:5; + unsigned:3; + unsigned ecoll:1; + unsigned txu:1; + unsigned ow:1; + unsigned:1; + unsigned lcrs:1; + unsigned fa:1; + unsigned txwe:1; + unsigned txfp:1; + }; + }; +} __attribute__((packed)); + + +/** + * Transmit descriptor queue + */ +struct tx_descriptor_queue { + struct tx_descriptor *base; + struct tx_descriptor *current; + struct tx_descriptor *end; +}; + + +/** + * Transmit status queue + */ +struct tx_status_queue { + struct tx_status *base; + struct tx_status *current; + struct tx_status *end; +}; + + +/** + * Receive descriptor queue + */ +struct rx_descriptor_queue { + struct rx_descriptor *base; + struct rx_descriptor *current; + struct rx_descriptor *end; +}; + + +/** + * Receive status queue + */ +struct rx_status_queue { + struct rx_status *base; + struct rx_status *current; + struct rx_status *end; +}; + + +/** + * EP93xx MAC private data structure + */ +struct ep93xx_mac { + int is_initialized; + + struct rx_descriptor_queue rx_dq; + struct rx_status_queue rx_sq; + void *rx_buffer[NUMRXDESC]; + + struct tx_descriptor_queue tx_dq; + struct tx_status_queue tx_sq; +}; + + +/* ep93xx_miiphy ops forward declarations */ +static int ep93xx_miiphy_read(char * const dev, unsigned char const addr, + unsigned char const reg, unsigned short * const value); +static int ep93xx_miiphy_write(char * const dev, unsigned char const addr, + unsigned char const reg, unsigned short const value); + + +/* Reserve memory for the MAC's private data */ +static struct ep93xx_mac dev = { 0 }; + + +/** + * Dump ep93xx_mac values to the terminal. + */ +inline void dump_dev(void) +{ +#if defined(EP93XX_MAC_DEBUG) + int i; + + printf("\ndump_dev()\n"); + printf(" is_initialized %02X\n", dev.is_initialized); + printf(" rx_dq.base %08X\n", dev.rx_dq.base); + printf(" rx_dq.current %08X\n", dev.rx_dq.current); + printf(" rx_dq.end %08X\n", dev.rx_dq.end); + printf(" rx_sq.base %08X\n", dev.rx_sq.base); + printf(" rx_sq.current %08X\n", dev.rx_sq.current); + printf(" rx_sq.end %08X\n", dev.rx_sq.end); + + for (i = 0; i < NUMRXDESC; i++) + printf(" rx_buffer[%2.d] %08X\n", i, NetRxPackets[i]); + + printf(" tx_dq.base %08X\n", dev.tx_dq.base); + printf(" tx_dq.current %08X\n", dev.tx_dq.current); + printf(" tx_dq.end %08X\n", dev.tx_dq.end); + printf(" tx_sq.base %08X\n", dev.tx_sq.base); + printf(" tx_sq.current %08X\n", dev.tx_sq.current); + printf(" tx_sq.end %08X\n", dev.tx_sq.end); +#endif /* defined(EP93XX_MAC_DEBUG) */ +} + + +/** + * Dump all RX descriptor queue entries to the terminal. + */ +inline void dump_rx_descriptor_queue(void) +{ +#if defined(EP93XX_MAC_DEBUG) + int i; + + printf("\ndump_rx_descriptor_queue()\n"); + printf(" descriptor address word1 word2\n"); + for (i = 0; i < NUMRXDESC; i++) { + printf(" [ %08X ] %08X %08X\n", + (dev.rx_dq.base + i), + (dev.rx_dq.base + i)->word1, + (dev.rx_dq.base + i)->word2); + } +#endif /* defined(EP93XX_MAC_DEBUG) */ +} + + +/** + * Dump all RX status queue entries to the terminal. + */ +inline void dump_rx_status_queue(void) +{ +#if defined(EP93XX_MAC_DEBUG) + int i; + + printf("\ndump_rx_status_queue()\n"); + printf(" descriptor address word1 word2\n"); + for (i = 0; i < NUMRXDESC; i++) { + printf(" [ %08X ] %08X %08X\n", + (dev.rx_sq.base + i), + (dev.rx_sq.base + i)->word1, + (dev.rx_sq.base + i)->word2); + } +#endif /* defined(EP93XX_MAC_DEBUG) */ +} + + +/** + * Dump all TX descriptor queue entries to the terminal. + */ +inline void dump_tx_descriptor_queue(void) +{ +#if defined(EP93XX_MAC_DEBUG) + int i; + + printf("\ndump_tx_descriptor_queue()\n"); + printf(" descriptor address word1 word2\n"); + for (i = 0; i < NUMTXDESC; i++) { + printf(" [ %08X ] %08X %08X\n", + (dev.tx_dq.base + i), + (dev.tx_dq.base + i)->word1, + (dev.tx_dq.base + i)->word2); + } +#endif /* defined(EP93XX_MAC_DEBUG) */ +} + + +/** + * Dump all TX status queue entries to the terminal. + */ +inline void dump_tx_status_queue(void) +{ +#if defined(EP93XX_MAC_DEBUG) + int i; + + printf("\ndump_tx_status_queue()\n"); + printf(" descriptor address word1\n"); + for (i = 0; i < NUMTXDESC; i++) { + printf(" [ %08X ] %08X\n", + (dev.rx_sq.base + i), + (dev.rx_sq.base + i)->word1); + } +#endif /* defined(EP93XX_MAC_DEBUG) */ +} + + +/** + * Reset the EP93xx MAC by twiddling the soft reset bit and spinning until + * it's cleared. + */ +static void ep93xx_mac_reset(void) +{ + TRACE(("+ep93xx_mac_reset")); + + uint32_t value = readl(MAC_SELFCTL); + value |= SELFCTL_RESET; + writel(value, MAC_SELFCTL); + + while (readl(MAC_SELFCTL) & SELFCTL_RESET) + ; /* nop */ + + TRACE(("-ep93xx_mac_reset")); +} + + +/** + * Halt EP93xx MAC transmit and receive by clearing the TxCTL and RxCTL + * registers. + */ +extern void eth_halt(void) +{ + TRACE(("+eth_halt")); + + writel(0x00000000, MAC_RXCTL); + writel(0x00000000, MAC_TXCTL); + + TRACE(("-eth_halt")); +} + +#if defined(CONFIG_MII) +int ep93xx_miiphy_initialize(bd_t * const bd) +{ + miiphy_register("ep93xx_eth0", ep93xx_miiphy_read, ep93xx_miiphy_write); + return 0; +} +#endif + +/** + * Initialize the EP93xx MAC. The MAC hardware is reset. Buffers are + * allocated, if necessary, for the TX and RX descriptor and status queues, + * as well as for received packets. The EP93XX MAC hardware is initialized. + * Transmit and receive operations are enabled. + */ +extern int eth_init(bd_t * const bd) +{ + int ret = ETH_STATUS_FAILURE; + int i; + uchar enetaddr[6]; + + TRACE(("+eth_init")); + + /* Parameter check */ + if (bd == NULL) { + ERROR(("NULL bd")); + goto eth_init_failed_0; + } + + /* Reset the MAC */ + ep93xx_mac_reset(); + + /* Allocate space for the queues and RX packet buffers if we're not + * already initialized */ + if (!dev.is_initialized) { + dev.tx_dq.base = calloc(NUMTXDESC, + sizeof(struct tx_descriptor)); + if (dev.tx_dq.base == NULL) { + ERROR(("calloc() failed")); + goto eth_init_failed_0; + } + + dev.tx_sq.base = calloc(NUMTXDESC, + sizeof(struct tx_status)); + if (dev.tx_sq.base == NULL) { + ERROR(("calloc() failed")); + goto eth_init_failed_1; + } + + dev.rx_dq.base = calloc(NUMRXDESC, + sizeof(struct rx_descriptor)); + if (dev.rx_dq.base == NULL) { + ERROR(("calloc() failed")); + goto eth_init_failed_2; + } + + dev.rx_sq.base = calloc(NUMRXDESC, + sizeof(struct rx_status)); + if (dev.rx_sq.base == NULL) { + ERROR(("calloc() failed")); + goto eth_init_failed_3; + } + + /* Set is_initialized flag so we don't go through allocation + * portion of init again. */ + dev.is_initialized = 1; + } + + /* Reset the descriptor queues' current and end address values */ + dev.tx_dq.current = dev.tx_dq.base; + dev.tx_dq.end = (dev.tx_dq.base + NUMTXDESC); + + dev.tx_sq.current = dev.tx_sq.base; + dev.tx_sq.end = (dev.tx_sq.base + NUMTXDESC); + + dev.rx_dq.current = dev.rx_dq.base; + dev.rx_dq.end = (dev.rx_dq.base + NUMRXDESC); + + dev.rx_sq.current = dev.rx_sq.base; + dev.rx_sq.end = (dev.rx_sq.base + NUMRXDESC); + + /* Set the transmit descriptor and status queues' base address, + * current address, and length registers. Set the maximum frame + * length and threshold. Enable the transmit descriptor processor. */ + writel((uint32_t)dev.tx_dq.base, MAC_TXDQBADD); + writel((uint32_t)dev.tx_dq.base, MAC_TXDQCURADD); + writel(sizeof(struct tx_descriptor) * NUMTXDESC, MAC_TXDQBLEN); + + writel((uint32_t)dev.tx_sq.base, MAC_TXSTSQBADD); + writel((uint32_t)dev.tx_sq.base, MAC_TXSTSQCURADD); + writel(sizeof(struct tx_status) * NUMTXDESC, MAC_TXSTSQBLEN); + + writel(0x00040000, MAC_TXDTHRSHLD); + + writel(0x00040000, MAC_TXSTSTHRSHLD); + + writel((TXSTARTMAX << 0) | (PKTSIZE_ALIGN << 16), MAC_MAXFRMLEN); + writel(BMCTL_TXEN, MAC_BMCTL); + + /* Set the receive descriptor and status queues' base address, + * current address, and length registers. Enable the receive + * descriptor processor. */ + writel((uint32_t)dev.rx_dq.base, MAC_RXDQBADD); + writel((uint32_t)dev.rx_dq.base, MAC_RXDQCURADD); + writel(sizeof(struct rx_descriptor) * NUMRXDESC, MAC_RXDQBLEN); + + writel((uint32_t)dev.rx_sq.base, MAC_RXSTSQBADD); + writel((uint32_t)dev.rx_sq.base, MAC_RXSTSQCURADD); + writel(sizeof(struct rx_status) * NUMRXDESC, MAC_RXSTSQBLEN); + + writel(0x00040000, MAC_RXDTHRSHLD); + + writel(BMCTL_RXEN, MAC_BMCTL); + + writel(0x00040000, MAC_RXSTSTHRSHLD); + + /* Wait until the receive descriptor processor is active */ + while (!(readl(MAC_BMSTS) & BMSTS_RXACT)) + ; /* nop */ + + /* Initialize the RX descriptor queue. Clear the TX descriptor queue. + * Clear the RX and TX status queues. Enqueue the RX descriptor and + * status entries to the MAC. */ + for (i = 0; i < NUMRXDESC; i++) { + (dev.rx_dq.base + i)->buffer_address = + (uint32_t)NetRxPackets[i]; + (dev.rx_dq.base + i)->buffer_length = PKTSIZE_ALIGN; + (dev.rx_dq.base + i)->buffer_index = 0; + } + + memset(dev.tx_dq.base, 0, (sizeof(struct tx_descriptor) * NUMTXDESC)); + memset(dev.rx_sq.base, 0, (sizeof(struct rx_status) * NUMRXDESC)); + memset(dev.tx_sq.base, 0, (sizeof(struct tx_status) * NUMTXDESC)); + + writel(NUMRXDESC, MAC_RXDENQ); + writel(NUMRXDESC, MAC_RXSTSENQ); + + /* Set the primary MAC address */ + writel(AFP_IAPRIMARY, MAC_AFP); + eth_getenv_enetaddr("ethaddr", enetaddr); + writel(enetaddr[0] | (enetaddr[1] << 8) | + (enetaddr[2] << 16) | (enetaddr[3] << 24), + MAC_INDAD); + writel(enetaddr[4] | (enetaddr[5] << 8), MAC_INDAD_UPPER); + + /* Turn on RX and TX */ + writel(RXCTL_IA0 | RXCTL_BA | RXCTL_SRXON | + RXCTL_RCRCA | RXCTL_MA, MAC_RXCTL); + writel(TXCTL_STXON, MAC_TXCTL); + + /* Dump data structures if we're debugging */ + dump_dev(); + dump_rx_descriptor_queue(); + dump_rx_status_queue(); + dump_tx_descriptor_queue(); + dump_tx_status_queue(); + + /* Done! */ + ret = ETH_STATUS_SUCCESS; + goto eth_init_done; + + free(dev.rx_sq.base); + /* Fall through */ + +eth_init_failed_3: + free(dev.rx_dq.base); + /* Fall through */ + +eth_init_failed_2: + free(dev.tx_sq.base); + /* Fall through */ + +eth_init_failed_1: + free(dev.tx_dq.base); + /* Fall through */ + +eth_init_failed_0: +eth_init_done: + TRACE(("-eth_init %d", ret)); + return ret; +} + + +/** + * Copy a frame of data from the MAC into the protocol layer for further + * processing. + * + * TODO: Enhance this to deal with as many packets as are available at + * the MAC at one time? */ +extern int eth_rx(void) +{ + int ret = ETH_STATUS_FAILURE; + + TRACE(("+eth_rx")); + + if (dev.rx_sq.current->rfp) { + if (dev.rx_sq.current->rwe) { + /* We have a good frame. Extract the frame's length + * from the current rx_status_queue entry, and copy + * the frame's data into NetRxPackets[] of the + * protocol stack. We track the total number of + * bytes in the frame (nbytes_frame) which will be + * used when we pass the data off to the protocol + * layer via NetReceive(). */ + NetReceive((uchar *)dev.rx_dq.current->buffer_address, + dev.rx_sq.current->frame_length); + TRACE(("reporting %d bytes...\n", + dev.rx_sq.current->frame_length)); + + ret = ETH_STATUS_SUCCESS; + + } else { + /* Do we have an erroneous packet? */ + ERROR(("packet rx error, status %08X %08X", + dev.rx_sq.current->word1, + dev.rx_sq.current->word2)); + dump_rx_descriptor_queue(); + dump_rx_status_queue(); + } + + /* Clear the associated status queue entry, and + * increment our current pointers to the next RX + * descriptor and status queue entries (making sure + * we wrap properly). */ + memset(dev.rx_sq.current, 0, sizeof(struct rx_status)); + + dev.rx_sq.current++; + if (dev.rx_sq.current >= dev.rx_sq.end) + dev.rx_sq.current = dev.rx_sq.base; + + dev.rx_dq.current++; + if (dev.rx_dq.current >= dev.rx_dq.end) + dev.rx_dq.current = dev.rx_dq.base; + + /* Finally, return the RX descriptor and status entries + * back to the MAC engine, and loop again, checking for + * more descriptors to process. */ + writel(1, MAC_RXDENQ); + writel(1, MAC_RXSTSENQ); + } else { + ret = ETH_STATUS_SUCCESS; + } + + TRACE(("-eth_rx %d", ret)); + return ret; +} + + +/** + * Send a block of data via ethernet. + * + * TODO: Enhance this to deal with as much data as are available at one time? */ +extern int eth_send(volatile void * const packet, int const length) +{ + int ret = ETH_STATUS_FAILURE; + + TRACE(("+eth_send")); + + /* Parameter check */ + if (packet == NULL) { + ERROR(("NULL packet")); + goto eth_send_failed_0; + } + + /* Initialize the TX descriptor queue with the new packet's info. + * Clear the associated status queue entry. Enqueue the packet + * to the MAC for transmission. */ + dev.tx_dq.current->buffer_address = (uint32_t)packet; + dev.tx_dq.current->buffer_length = length; + dev.tx_dq.current->buffer_index = 0; + dev.tx_dq.current->eof = 1; + + dev.tx_sq.current->word1 = 0; + + writel(1, MAC_TXDENQ); + + /* Wait for TX to complete, and check status entry for errors. */ + while (!(readl(MAC_INTSTSC) & INTSTS_TXSQ)) + ; /* nop */ + + if (!dev.tx_sq.current->txfp || !dev.tx_sq.current->txwe) { + ERROR(("packet tx error, status %08X", + dev.tx_sq.current->word1)); + dump_tx_descriptor_queue(); + dump_tx_status_queue(); + + /* TODO: Add better error handling? */ + goto eth_send_failed_0; + } + + ret = ETH_STATUS_SUCCESS; + /* Fall through */ + +eth_send_failed_0: + TRACE(("-eth_send %d", ret)); + return ret; +} +#endif /* defined(CONFIG_DRIVER_EP93XX_MAC) */ + + +/* ----------------------------------------------------------------------------- + * EP93xx ethernet MII functionality. + */ +#if defined(CONFIG_MII) + +/** + * Maximum MII address we support + */ +#define MII_ADDRESS_MAX (31) + +/** + * Maximum MII register address we support + */ +#define MII_REGISTER_MAX (31) + + +/** + * Ethernet MII interface return values for public functions. + */ +enum mii_status { + MII_STATUS_SUCCESS = 0, + MII_STATUS_FAILURE = 1, +}; + + +/** + * Read a 16-bit value from an MII register. + */ +static int ep93xx_miiphy_read(char * const dev, unsigned char const addr, + unsigned char const reg, unsigned short * const value) +{ + int ret = MII_STATUS_FAILURE; + uint32_t self_ctl; + + TRACE(("+ep93xx_miiphy_read")); + + /* Parameter checks */ + if (dev == NULL) { + ERROR(("NULL dev")); + goto ep93xx_miiphy_read_failed_0; + } + + if (addr > MII_ADDRESS_MAX) { + ERROR(("invalid addr, 0x%02X", addr)); + goto ep93xx_miiphy_read_failed_0; + } + + if (reg > MII_REGISTER_MAX) { + ERROR(("invalid reg, 0x%02X", reg)); + goto ep93xx_miiphy_read_failed_0; + } + + if (value == NULL) { + ERROR(("NULL value")); + goto ep93xx_miiphy_read_failed_0; + } + + /* Save the current SelfCTL register value. Set MAC to suppress + * preamble bits. Wait for any previous MII command to complete + * before issuing the new command. */ + self_ctl = MAC_SELFCTL; +#if defined(CONFIG_MII_SUPPRESS_PREAMBLE) + writel(self_ctl & ~(1 << 8), MAC_SELFCTL); +#endif /* defined(CONFIG_MII_SUPPRESS_PREAMBLE) */ + + while (readl(MAC_MIISTS) & MIISTS_BUSY) + ; /* nop */ + + /* Issue the MII 'read' command. Wait for the command to complete. + * Read the MII data value. */ + writel(MIICMD_OPCODE_READ | ((uint32_t)addr << 5) | (uint32_t)reg, + MAC_MIICMD); + while (readl(MAC_MIISTS) & MIISTS_BUSY) + ; /* nop */ + + *value = (unsigned short)readl(MAC_MIIDATA); + + /* Restore the saved SelfCTL value and return. */ + writel(self_ctl, MAC_SELFCTL); + + ret = MII_STATUS_SUCCESS; + /* Fall through */ + +ep93xx_miiphy_read_failed_0: + TRACE(("-ep93xx_miiphy_read")); + return ret; +} + + +/** + * Write a 16-bit value to an MII register. + */ +static int ep93xx_miiphy_write(char * const dev, unsigned char const addr, + unsigned char const reg, unsigned short const value) +{ + int ret = MII_STATUS_FAILURE; + uint32_t self_ctl; + + TRACE(("+ep93xx_miiphy_write")); + + /* Parameter checks */ + if (dev == NULL) { + ERROR(("NULL dev")); + goto ep93xx_miiphy_write_failed_0; + } + + if (addr > MII_ADDRESS_MAX) { + ERROR(("invalid addr, 0x%02X", addr)); + goto ep93xx_miiphy_write_failed_0; + } + + if (reg > MII_REGISTER_MAX) { + ERROR(("invalid reg, 0x%02X", reg)); + goto ep93xx_miiphy_write_failed_0; + } + + /* Save the current SelfCTL register value. Set MAC to suppress + * preamble bits. Wait for any previous MII command to complete + * before issuing the new command. */ + self_ctl = readl(MAC_SELFCTL); +#if defined(CONFIG_MII_SUPPRESS_PREAMBLE) + writel(self_ctl & ~(1 << 8), MAC_SELFCTL); +#endif /* defined(CONFIG_MII_SUPPRESS_PREAMBLE) */ + + while (readl(MAC_MIISTS) & MIISTS_BUSY) + ; /* nop */ + + /* Issue the MII 'write' command. Wait for the command to complete. */ + writel((uint32_t)value, MAC_MIIDATA); + writel(MIICMD_OPCODE_WRITE | ((uint32_t)addr << 5) | (uint32_t)reg, + MAC_MIICMD); + while (readl(MAC_MIISTS) & MIISTS_BUSY) + ; /* nop */ + + /* Restore the saved SelfCTL value and return. */ + writel(self_ctl, MAC_SELFCTL); + + ret = MII_STATUS_SUCCESS; + /* Fall through */ + +ep93xx_miiphy_write_failed_0: + TRACE(("-ep93xx_miiphy_write")); + return ret; +} +#endif /* defined(CONFIG_MII) */ diff --git a/cpu/arm920t/ep93xx/lowlevel_init.S b/cpu/arm920t/ep93xx/lowlevel_init.S new file mode 100644 index 0000000..34a2100 --- /dev/null +++ b/cpu/arm920t/ep93xx/lowlevel_init.S @@ -0,0 +1,74 @@ +/* + * Low-level initialization for EP93xx + * + * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net + * + * Copyright (C) 2006 Dominic Rath Dominic.Rath@gmx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <version.h> +#include <asm/arch/ep93xx.h> + +.globl lowlevel_init +lowlevel_init: + + /* Turn on both LEDs */ + ldr r1, =GPIO_PEDR + ldr r0, [r1] + orr r0, r0, #(0x1 | 0x2) + str r0, [r1] + + /* backup return address */ + ldr r1, =SYSCON_SCRATCH0 + str lr, [r1] + + /* Configure flash wait states before we switch to the PLL */ + bl flash_cfg + + /* Set up PLL */ + bl pll_cfg + + /* Turn off the Green LED and leave the Red LED on */ + ldr r1, =GPIO_PEDR + ldr r0, [r1] + bic r0, r0, #(0x1) + str r0, [r1] + + /* Setup SDRAM */ + bl sdram_cfg + + /* Turn on Green LED, Turn off the Red LED */ + ldr r1, =GPIO_PEDR + ldr r0, [r1] + bic r0, r0, #(0x2) + orr r0, r0, #(0x1) + str r0, [r1] + + /* FIXME: we use async mode for now */ + mrc p15, 0, r0, c1, c0, 0 + orr r0, r0, #0xc0000000 + mcr p15, 0, r0, c1, c0, 0 + + /* restore return address */ + ldr r1, =SYSCON_SCRATCH0 + ldr lr, [r1] + + mov pc, lr diff --git a/cpu/arm920t/ep93xx/speed.c b/cpu/arm920t/ep93xx/speed.c new file mode 100644 index 0000000..cc32ec7 --- /dev/null +++ b/cpu/arm920t/ep93xx/speed.c @@ -0,0 +1,120 @@ +/* vim: set ts=8 sw=8 noet: + * + * Cirrus Logic EP93xx PLL support. + * + * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net + * + * Copyright (C) 2004, 2005 + * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com + * + * Based on the S3C24x0 speed.c, which is + * + * (C) Copyright 2001-2002 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de + * + * (C) Copyright 2002 + * David Mueller, ELSOFT AG, d.mueller@elsoft.ch + * + * See file CREDITS for list of people who contributed to this project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY + * or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License + * for more details. + * + * You should have received a copy of the GNU General Public License along + * with this program; if not, write to the Free Software Foundation, Inc., + * 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#include <common.h> +#include <asm/arch/ep93xx.h> +#include <asm/io.h> +#include <div64.h> + +/* ------------------------------------------------------------------------- */ +/* NOTE: This describes the proper use of this file. + * + * CONFIG_SYS_CLK_FREQ should be defined as the input frequency of the PLL. + * + * get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of + * the specified bus in HZ. + */ +/* ------------------------------------------------------------------------- */ + +static char fclk_divisors[] = { 1, 2, 4, 8, 16, 1, 1, 1 }; +static char hclk_divisors[] = { 1, 2, 4, 5, 6, 8, 16, 32 }; +static char pclk_divisors[] = { 1, 2, 4, 8 }; + + +/* return the PLL output frequency */ +/* PLL rate = CONFIG_SYS_CLK_FREQ * (X1FBD + 1) * (X2FBD + 1) + * / (X2IPD + 1) / 2^PS + */ +static ulong get_PLLCLK(int pllreg) +{ + uint8_t i; + const uint32_t clkset = readl(pllreg); + uint64_t rate = CONFIG_SYS_CLK_FREQ; + rate *= ((clkset >> SYSCON_CLKSET_PLL_X1FBD1_SHIFT) & 0x1f) + 1; + rate *= ((clkset >> SYSCON_CLKSET_PLL_X2FBD2_SHIFT) & 0x3f) + 1; + do_div(rate, (clkset & 0x1f) + 1); /* X2IPD */ + for (i = 0; i < ((clkset >> SYSCON_CLKSET_PLL_PS_SHIFT) & 3); i++) + rate >>= 1; + + return rate; +} + +/* return FCLK frequency */ +ulong get_FCLK() +{ + const uint32_t clkset1 = readl(SYSCON_CLKSET1); + const uint8_t fclk_div = + fclk_divisors[(clkset1 >> SYSCON_CLKSET1_FCLK_DIV_SHIFT) & 0x7]; + const ulong fclk_rate = get_PLLCLK(SYSCON_CLKSET1) / fclk_div; + + return fclk_rate; +} + + +/* return HCLK frequency */ +ulong get_HCLK(void) +{ + const uint32_t clkset1 = readl(SYSCON_CLKSET1); + const uint8_t hclk_div = + hclk_divisors[(clkset1 >> SYSCON_CLKSET1_HCLK_DIV_SHIFT) & 0x7]; + const ulong hclk_rate = get_PLLCLK(SYSCON_CLKSET1) / hclk_div; + + return hclk_rate; +} + + +/* return PCLK frequency */ +ulong get_PCLK(void) +{ + const uint32_t clkset1 = readl(SYSCON_CLKSET1); + const uint8_t pclk_div = + pclk_divisors[(clkset1 >> SYSCON_CLKSET1_PCLK_DIV_SHIFT) & 0x3]; + const ulong pclk_rate = get_HCLK() / pclk_div; + + return pclk_rate; +} + + +/* return UCLK frequency */ +ulong get_UCLK(void) +{ + ulong uclk_rate; + + const uint32_t value = readl(SYSCON_PWRCNT); + if (value & SYSCON_PWRCNT_UART_BAUD) + uclk_rate = CONFIG_SYS_CLK_FREQ; + else + uclk_rate = CONFIG_SYS_CLK_FREQ / 2; + + return uclk_rate; +} diff --git a/cpu/arm920t/ep93xx/timer.c b/cpu/arm920t/ep93xx/timer.c new file mode 100644 index 0000000..28660d0 --- /dev/null +++ b/cpu/arm920t/ep93xx/timer.c @@ -0,0 +1,163 @@ +/* vim: set ts=8 sw=8 noet: + * + * Cirrus Logic EP93xx interrupt support. + * + * Copyright (C) 2004, 2005 + * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com + * + * Based on the original intr.c Cirrus Logic EP93xx Rev D. interrupt support, + * author unknown. + * + * See file CREDITS for list of people who contributed to this project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY + * or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License + * for more details. + * + * You should have received a copy of the GNU General Public License along + * with this program; if not, write to the Free Software Foundation, Inc., + * 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#include <common.h> + +#if defined(CONFIG_EP93XX) +#include <linux/types.h> +#include <asm/arch/ep93xx.h> +#include <asm/io.h> + + +static int timer_load_val; + +/* macro to read the 16 bit timer */ +static inline ulong READ_TIMER(void) +{ + return readl(TIMER1_VALUE) & 0xffff; +} + +static ulong timestamp; +static ulong lastdec; + + +int timer_init(void) +{ + /* use timer 1 with 2KHz and free running */ + writel(0x00, TIMER1_CONTROL); + if (timer_load_val == 0) { + /* + * for 10 ms clock period @ PCLK with 4 bit divider = 1/2 + * (default) and prescaler = 16. Should be 10390 + * @33.25MHz and 15625 @ 50 MHz + */ + + /* set to constant just now, until I resolve clocking issues */ + timer_load_val = 21; + } + /* auto load, manual update of Timer 1 */ + lastdec = timer_load_val; + writel(timer_load_val, TIMER1_LOAD); + + /* Enable the timer and periodic mode */ + writel(0xC0, TIMER1_CONTROL); + + return 0; +} + +/* + * timer without interrupts + */ + +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void set_timer(ulong t) +{ + timestamp = t; +} + +void udelay(unsigned long usec) +{ + ulong tmo; + + tmo = usec / 1000; + tmo *= (timer_load_val * 100); + tmo /= 1000; + + tmo += get_timer(0); + + while (get_timer_masked() < tmo) + /*NOP*/; +} + +void reset_timer_masked(void) +{ + /* reset time */ + lastdec = READ_TIMER(); + timestamp = 0; +} + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER(); + + if (lastdec >= now) { + /* normal mode */ + timestamp += lastdec - now; + } else { + /* we have an overflow ... */ + timestamp += lastdec + timer_load_val - now; + } + lastdec = now; + + return timestamp; +} + +void udelay_masked(unsigned long usec) +{ + ulong tmo; + + tmo = usec / 1000; + tmo *= (timer_load_val * 100); + tmo /= 1000; + + reset_timer_masked(); + + while (get_timer_masked() < tmo) + /*NOP*/; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + ulong tbclk; + + tbclk = timer_load_val * 100; + return tbclk; +} + + +#endif /* defined(CONFIG_EP93XX) */ diff --git a/include/asm-arm/arch-ep93xx/ep93xx.h b/include/asm-arm/arch-ep93xx/ep93xx.h new file mode 100644 index 0000000..47e2a21 --- /dev/null +++ b/include/asm-arm/arch-ep93xx/ep93xx.h @@ -0,0 +1,868 @@ +/* ----------------------------------------------------------------------------- + * Cirrus Logic EP93xx register definitions. + * + * Copyright (C) 2009 + * Matthias Kaehlcke matthias@kaehlcke.net + * + * Copyright (C) 2006 + * Dominic Rath Dominic.Rath@gmx.de + * + * Copyright (C) 2004, 2005 + * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com + * + * Based in large part on linux/include/asm-arm/arch-ep93xx/regmap.h, which is + * + * Copyright (C) 2004 Ray Lehtiniemi + * Copyright (C) 2003 Cirrus Logic, Inc + * Copyright (C) 1999 ARM Limited. + * + * See file CREDITS for list of people who contributed to this project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY + * or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License + * for more details. + * + * You should have received a copy of the GNU General Public License along + * with this program; if not, write to the Free Software Foundation, Inc., + * 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#define EP93XX_AHB_BASE 0x80000000 +#define EP93XX_APB_BASE 0x80800000 + +/* ----------------------------------------------------------------------------- + * 0x80000000 - 0x8000FFFF: DMA + */ +#define DMA_OFFSET 0x000000 +#define DMA_BASE (EP93XX_AHB_BASE | DMA_OFFSET) + +#define DMAMP_TX_0_CONTROL (DMA_BASE + 0x0000) +#define DMAMP_TX_0_INTERRUPT (DMA_BASE + 0x0004) +#define DMAMP_TX_0_PPALLOC (DMA_BASE + 0x0008) +#define DMAMP_TX_0_STATUS (DMA_BASE + 0x000C) +#define DMAMP_TX_0_REMAIN (DMA_BASE + 0x0014) +#define DMAMP_TX_0_MAXCNT0 (DMA_BASE + 0x0020) +#define DMAMP_TX_0_BASE0 (DMA_BASE + 0x0024) +#define DMAMP_TX_0_CURRENT0 (DMA_BASE + 0x0028) +#define DMAMP_TX_0_MAXCNT1 (DMA_BASE + 0x0030) +#define DMAMP_TX_0_BASE1 (DMA_BASE + 0x0034) +#define DMAMP_TX_0_CURRENT1 (DMA_BASE + 0x0038) + +#define DMAMP_RX_1_CONTROL (DMA_BASE + 0x0040) +#define DMAMP_RX_1_INTERRUPT (DMA_BASE + 0x0044) +#define DMAMP_RX_1_PPALLOC (DMA_BASE + 0x0048) +#define DMAMP_RX_1_STATUS (DMA_BASE + 0x004C) +#define DMAMP_RX_1_REMAIN (DMA_BASE + 0x0054) +#define DMAMP_RX_1_MAXCNT0 (DMA_BASE + 0x0060) +#define DMAMP_RX_1_BASE0 (DMA_BASE + 0x0064) +#define DMAMP_RX_1_CURRENT0 (DMA_BASE + 0x0068) +#define DMAMP_RX_1_MAXCNT1 (DMA_BASE + 0x0070) +#define DMAMP_RX_1_BASE1 (DMA_BASE + 0x0074) +#define DMAMP_RX_1_CURRENT1 (DMA_BASE + 0x0078) + +#define DMAMP_TX_2_CONTROL (DMA_BASE + 0x0080) +#define DMAMP_TX_2_INTERRUPT (DMA_BASE + 0x0084) +#define DMAMP_TX_2_PPALLOC (DMA_BASE + 0x0088) +#define DMAMP_TX_2_STATUS (DMA_BASE + 0x008C) +#define DMAMP_TX_2_REMAIN (DMA_BASE + 0x0094) +#define DMAMP_TX_2_MAXCNT0 (DMA_BASE + 0x00A0) +#define DMAMP_TX_2_BASE0 (DMA_BASE + 0x00A4) +#define DMAMP_TX_2_CURRENT0 (DMA_BASE + 0x00A8) +#define DMAMP_TX_2_MAXCNT1 (DMA_BASE + 0x00B0) +#define DMAMP_TX_2_BASE1 (DMA_BASE + 0x00B4) +#define DMAMP_TX_2_CURRENT1 (DMA_BASE + 0x00B8) + +#define DMAMP_RX_3_CONTROL (DMA_BASE + 0x00C0) +#define DMAMP_RX_3_INTERRUPT (DMA_BASE + 0x00C4) +#define DMAMP_RX_3_PPALLOC (DMA_BASE + 0x00C8) +#define DMAMP_RX_3_STATUS (DMA_BASE + 0x00CC) +#define DMAMP_RX_3_REMAIN (DMA_BASE + 0x00D4) +#define DMAMP_RX_3_MAXCNT0 (DMA_BASE + 0x00E0) +#define DMAMP_RX_3_BASE0 (DMA_BASE + 0x00E4) +#define DMAMP_RX_3_CURRENT0 (DMA_BASE + 0x00E8) +#define DMAMP_RX_3_MAXCNT1 (DMA_BASE + 0x00F0) +#define DMAMP_RX_3_BASE1 (DMA_BASE + 0x00F4) +#define DMAMP_RX_3_CURRENT1 (DMA_BASE + 0x00F8) + +#define DMAMM_0_CONTROL (DMA_BASE + 0x0100) +#define DMAMM_0_INTERRUPT (DMA_BASE + 0x0104) +#define DMAMM_0_STATUS (DMA_BASE + 0x010C) +#define DMAMM_0_BCR0 (DMA_BASE + 0x0110) +#define DMAMM_0_BCR1 (DMA_BASE + 0x0114) +#define DMAMM_0_SAR_BASE0 (DMA_BASE + 0x0118) +#define DMAMM_0_SAR_BASE1 (DMA_BASE + 0x011C) +#define DMAMM_0_SAR_CURRENT0 (DMA_BASE + 0x0124) +#define DMAMM_0_SAR_CURRENT1 (DMA_BASE + 0x0128) +#define DMAMM_0_DAR_BASE0 (DMA_BASE + 0x012C) +#define DMAMM_0_DAR_BASE1 (DMA_BASE + 0x0130) +#define DMAMM_0_DAR_CURRENT0 (DMA_BASE + 0x0134) +#define DMAMM_0_DAR_CURRENT1 (DMA_BASE + 0x013C) + +#define DMAMM_1_CONTROL (DMA_BASE + 0x0140) +#define DMAMM_1_INTERRUPT (DMA_BASE + 0x0144) +#define DMAMM_1_STATUS (DMA_BASE + 0x014C) +#define DMAMM_1_BCR0 (DMA_BASE + 0x0150) +#define DMAMM_1_BCR1 (DMA_BASE + 0x0154) +#define DMAMM_1_SAR_BASE0 (DMA_BASE + 0x0158) +#define DMAMM_1_SAR_BASE1 (DMA_BASE + 0x015C) +#define DMAMM_1_SAR_CURRENT0 (DMA_BASE + 0x0164) +#define DMAMM_1_SAR_CURRENT1 (DMA_BASE + 0x0168) +#define DMAMM_1_DAR_BASE0 (DMA_BASE + 0x016C) +#define DMAMM_1_DAR_BASE1 (DMA_BASE + 0x0170) +#define DMAMM_1_DAR_CURRENT0 (DMA_BASE + 0x0174) +#define DMAMM_1_DAR_CURRENT1 (DMA_BASE + 0x017C) + +#define DMAMP_RX_5_CONTROL (DMA_BASE + 0x0200) +#define DMAMP_RX_5_INTERRUPT (DMA_BASE + 0x0204) +#define DMAMP_RX_5_PPALLOC (DMA_BASE + 0x0208) +#define DMAMP_RX_5_STATUS (DMA_BASE + 0x020C) +#define DMAMP_RX_5_REMAIN (DMA_BASE + 0x0214) +#define DMAMP_RX_5_MAXCNT0 (DMA_BASE + 0x0220) +#define DMAMP_RX_5_BASE0 (DMA_BASE + 0x0224) +#define DMAMP_RX_5_CURRENT0 (DMA_BASE + 0x0228) +#define DMAMP_RX_5_MAXCNT1 (DMA_BASE + 0x0230) +#define DMAMP_RX_5_BASE1 (DMA_BASE + 0x0234) +#define DMAMP_RX_5_CURRENT1 (DMA_BASE + 0x0238) + +#define DMAMP_TX_4_CONTROL (DMA_BASE + 0x0240) +#define DMAMP_TX_4_INTERRUPT (DMA_BASE + 0x0244) +#define DMAMP_TX_4_PPALLOC (DMA_BASE + 0x0248) +#define DMAMP_TX_4_STATUS (DMA_BASE + 0x024C) +#define DMAMP_TX_4_REMAIN (DMA_BASE + 0x0254) +#define DMAMP_TX_4_MAXCNT0 (DMA_BASE + 0x0260) +#define DMAMP_TX_4_BASE0 (DMA_BASE + 0x0264) +#define DMAMP_TX_4_CURRENT0 (DMA_BASE + 0x0268) +#define DMAMP_TX_4_MAXCNT1 (DMA_BASE + 0x0270) +#define DMAMP_TX_4_BASE1 (DMA_BASE + 0x0274) +#define DMAMP_TX_4_CURRENT1 (DMA_BASE + 0x0278) + +#define DMAMP_RX_7_CONTROL (DMA_BASE + 0x0280) +#define DMAMP_RX_7_INTERRUPT (DMA_BASE + 0x0284) +#define DMAMP_RX_7_PPALLOC (DMA_BASE + 0x0288) +#define DMAMP_RX_7_STATUS (DMA_BASE + 0x028C) +#define DMAMP_RX_7_REMAIN (DMA_BASE + 0x0294) +#define DMAMP_RX_7_MAXCNT0 (DMA_BASE + 0x02A0) +#define DMAMP_RX_7_BASE0 (DMA_BASE + 0x02A4) +#define DMAMP_RX_7_CURRENT0 (DMA_BASE + 0x02A8) +#define DMAMP_RX_7_MAXCNT1 (DMA_BASE + 0x02B0) +#define DMAMP_RX_7_BASE1 (DMA_BASE + 0x02B4) +#define DMAMP_RX_7_CURRENT1 (DMA_BASE + 0x02B8) + +#define DMAMP_TX_6_CONTROL (DMA_BASE + 0x02C0) +#define DMAMP_TX_6_INTERRUPT (DMA_BASE + 0x02C4) +#define DMAMP_TX_6_PPALLOC (DMA_BASE + 0x02C8) +#define DMAMP_TX_6_STATUS (DMA_BASE + 0x02CC) +#define DMAMP_TX_6_REMAIN (DMA_BASE + 0x02D4) +#define DMAMP_TX_6_MAXCNT0 (DMA_BASE + 0x02E0) +#define DMAMP_TX_6_BASE0 (DMA_BASE + 0x02E4) +#define DMAMP_TX_6_CURRENT0 (DMA_BASE + 0x02E8) +#define DMAMP_TX_6_MAXCNT1 (DMA_BASE + 0x02F0) +#define DMAMP_TX_6_BASE1 (DMA_BASE + 0x02F4) +#define DMAMP_TX_6_CURRENT1 (DMA_BASE + 0x02F8) + +#define DMAMP_RX_9_CONTROL (DMA_BASE + 0x0300) +#define DMAMP_RX_9_INTERRUPT (DMA_BASE + 0x0304) +#define DMAMP_RX_9_PPALLOC (DMA_BASE + 0x0308) +#define DMAMP_RX_9_STATUS (DMA_BASE + 0x030C) +#define DMAMP_RX_9_REMAIN (DMA_BASE + 0x0314) +#define DMAMP_RX_9_MAXCNT0 (DMA_BASE + 0x0320) +#define DMAMP_RX_9_BASE0 (DMA_BASE + 0x0324) +#define DMAMP_RX_9_CURRENT0 (DMA_BASE + 0x0328) +#define DMAMP_RX_9_MAXCNT1 (DMA_BASE + 0x0330) +#define DMAMP_RX_9_BASE1 (DMA_BASE + 0x0334) +#define DMAMP_RX_9_CURRENT1 (DMA_BASE + 0x0338) + +#define DMAMP_TX_8_CONTROL (DMA_BASE + 0x0340) +#define DMAMP_TX_8_INTERRUPT (DMA_BASE + 0x0344) +#define DMAMP_TX_8_PPALLOC (DMA_BASE + 0x0348) +#define DMAMP_TX_8_STATUS (DMA_BASE + 0x034C) +#define DMAMP_TX_8_REMAIN (DMA_BASE + 0x0354) +#define DMAMP_TX_8_MAXCNT0 (DMA_BASE + 0x0360) +#define DMAMP_TX_8_BASE0 (DMA_BASE + 0x0364) +#define DMAMP_TX_8_CURRENT0 (DMA_BASE + 0x0368) +#define DMAMP_TX_8_MAXCNT1 (DMA_BASE + 0x0370) +#define DMAMP_TX_8_BASE1 (DMA_BASE + 0x0374) +#define DMAMP_TX_8_CURRENT1 (DMA_BASE + 0x0378) + +#define DMA_ARBITRATION (DMA_BASE + 0x0380) +#define DMA_INTERRUPT (DMA_BASE + 0x03C0) + + +/* ----------------------------------------------------------------------------- + * 0x80010000 - 0x8001FFFF: Ethernet MAC + */ +#define MAC_OFFSET 0x010000 +#define MAC_BASE (EP93XX_AHB_BASE | MAC_OFFSET) + +#define MAC_RXCTL (MAC_BASE + 0x0000) +#define MAC_TXCTL (MAC_BASE + 0x0004) +#define MAC_TESTCTL (MAC_BASE + 0x0008) +#define MAC_MIICMD (MAC_BASE + 0x0010) +#define MAC_MIIDATA (MAC_BASE + 0x0014) +#define MAC_MIISTS (MAC_BASE + 0x0018) +#define MAC_SELFCTL (MAC_BASE + 0x0020) +#define MAC_INTEN (MAC_BASE + 0x0024) +#define MAC_INTSTSP (MAC_BASE + 0x0028) +#define MAC_INTSTSC (MAC_BASE + 0x002C) +#define MAC_DIAGAD (MAC_BASE + 0x0038) +#define MAC_DIAGDATA (MAC_BASE + 0x003C) +#define MAC_GT (MAC_BASE + 0x0040) +#define MAC_FCT (MAC_BASE + 0x0044) +#define MAC_FCF (MAC_BASE + 0x0048) +#define MAC_AFP (MAC_BASE + 0x004C) +#define MAC_HASHTBL (MAC_BASE + 0x0050) +#define MAC_INDAD (MAC_BASE + 0x0050) +#define MAC_INDAD_UPPER (MAC_BASE + 0x0054) +#define MAC_GIINTSTS (MAC_BASE + 0x0060) +#define MAC_GIINTMSK (MAC_BASE + 0x0064) +#define MAC_GIINTROSTS (MAC_BASE + 0x0068) +#define MAC_GIINTFRC (MAC_BASE + 0x006C) +#define MAC_TXCOLLCNT (MAC_BASE + 0x0070) +#define MAC_RXMISSCNT (MAC_BASE + 0x0074) +#define MAC_RXRUNTCNT (MAC_BASE + 0x0078) +#define MAC_BMCTL (MAC_BASE + 0x0080) +#define MAC_BMSTS (MAC_BASE + 0x0084) +#define MAC_RXBCA (MAC_BASE + 0x0088) +#define MAC_RXDQBADD (MAC_BASE + 0x0090) +#define MAC_RXDQBLEN (MAC_BASE + 0x0094) +#define MAC_RXDQCURLEN (MAC_BASE + 0x0096) +#define MAC_RXDQCURADD (MAC_BASE + 0x0098) +#define MAC_RXDENQ (MAC_BASE + 0x009C) +#define MAC_RXSTSQBADD (MAC_BASE + 0x00A0) +#define MAC_RXSTSQBLEN (MAC_BASE + 0x00A4) +#define MAC_RXSTSQCURLEN (MAC_BASE + 0x00A6) +#define MAC_RXSTSQCURADD (MAC_BASE + 0x00A8) +#define MAC_RXSTSENQ (MAC_BASE + 0x00AC) +#define MAC_TXDQBADD (MAC_BASE + 0x00B0) +#define MAC_TXDQBLEN (MAC_BASE + 0x00B4) +#define MAC_TXDQCURLEN (MAC_BASE + 0x00B6) +#define MAC_TXDQCURADD (MAC_BASE + 0x00B8) +#define MAC_TXDENQ (MAC_BASE + 0x00BC) +#define MAC_TXSTSQBADD (MAC_BASE + 0x00C0) +#define MAC_TXSTSQBLEN (MAC_BASE + 0x00C4) +#define MAC_TXSTSQCURLEN (MAC_BASE + 0x00C6) +#define MAC_TXSTSQCURADD (MAC_BASE + 0x00C8) +#define MAC_RXBUFTHRSHLD (MAC_BASE + 0x00D0) +#define MAC_TXBUFTHRSHLD (MAC_BASE + 0x00D4) +#define MAC_RXSTSTHRSHLD (MAC_BASE + 0x00D8) +#define MAC_TXSTSTHRSHLD (MAC_BASE + 0x00DC) +#define MAC_RXDTHRSHLD (MAC_BASE + 0x00E0) +#define MAC_TXDTHRSHLD (MAC_BASE + 0x00E4) +#define MAC_MAXFRMLEN (MAC_BASE + 0x00E8) +#define MAC_RXHDRLEN (MAC_BASE + 0x00EC) + +#define SELFCTL_RWP (1 << 7) +#define SELFCTL_GPO0 (1 << 5) +#define SELFCTL_PUWE (1 << 4) +#define SELFCTL_PDWE (1 << 3) +#define SELFCTL_MIIL (1 << 2) +#define SELFCTL_RESET (1 << 0) + +#define INTSTS_RWI (1 << 30) +#define INTSTS_RXMI (1 << 29) +#define INTSTS_RXBI (1 << 28) +#define INTSTS_RXSQI (1 << 27) +#define INTSTS_TXLEI (1 << 26) +#define INTSTS_ECIE (1 << 25) +#define INTSTS_TXUHI (1 << 24) +#define INTSTS_MOI (1 << 18) +#define INTSTS_TXCOI (1 << 17) +#define INTSTS_RXROI (1 << 16) +#define INTSTS_MIII (1 << 12) +#define INTSTS_PHYI (1 << 11) +#define INTSTS_TI (1 << 10) +#define INTSTS_AHBE (1 << 8) +#define INTSTS_OTHER (1 << 4) +#define INTSTS_TXSQ (1 << 3) +#define INTSTS_RXSQ (1 << 2) + +#define BMCTL_MT (1 << 13) +#define BMCTL_TT (1 << 12) +#define BMCTL_UNH (1 << 11) +#define BMCTL_TXCHR (1 << 10) +#define BMCTL_TXDIS (1 << 9) +#define BMCTL_TXEN (1 << 8) +#define BMCTL_EH2 (1 << 6) +#define BMCTL_EH1 (1 << 5) +#define BMCTL_EEOB (1 << 4) +#define BMCTL_RXCHR (1 << 2) +#define BMCTL_RXDIS (1 << 1) +#define BMCTL_RXEN (1 << 0) + +#define BMSTS_TXACT (1 << 7) +#define BMSTS_TP (1 << 4) +#define BMSTS_RXACT (1 << 3) +#define BMSTS_QID_MASK 0x07 +#define BMSTS_QID_RXDATA 0x00 +#define BMSTS_QID_TXDATA 0x01 +#define BMSTS_QID_RXSTS 0x02 +#define BMSTS_QID_TXSTS 0x03 +#define BMSTS_QID_RXDESC 0x04 +#define BMSTS_QID_TXDESC 0x05 + +#define AFP_MASK 0x07 +#define AFP_IAPRIMARY 0x00 +#define AFP_IASECONDARY1 0x01 +#define AFP_IASECONDARY2 0x02 +#define AFP_IASECONDARY3 0x03 +#define AFP_TX 0x06 +#define AFP_HASH 0x07 + +#define RXCTL_PAUSEA (1 << 20) +#define RXCTL_RXFCE1 (1 << 19) +#define RXCTL_RXFCE0 (1 << 18) +#define RXCTL_BCRC (1 << 17) +#define RXCTL_SRXON (1 << 16) +#define RXCTL_RCRCA (1 << 13) +#define RXCTL_RA (1 << 12) +#define RXCTL_PA (1 << 11) +#define RXCTL_BA (1 << 10) +#define RXCTL_MA (1 << 9) +#define RXCTL_IAHA (1 << 8) +#define RXCTL_IA3 (1 << 3) +#define RXCTL_IA2 (1 << 2) +#define RXCTL_IA1 (1 << 1) +#define RXCTL_IA0 (1 << 0) + +#define TXCTL_DEFDIS (1 << 7) +#define TXCTL_MBE (1 << 6) +#define TXCTL_ICRC (1 << 5) +#define TXCTL_TPD (1 << 4) +#define TXCTL_OCOLL (1 << 3) +#define TXCTL_SP (1 << 2) +#define TXCTL_PB (1 << 1) +#define TXCTL_STXON (1 << 0) + +#define MIICMD_REGAD_MASK (0x001F) +#define MIICMD_PHYAD_MASK (0x03E0) +#define MIICMD_OPCODE_MASK (0xC000) +#define MIICMD_PHYAD_8950 (0x0000) +#define MIICMD_OPCODE_READ (0x8000) +#define MIICMD_OPCODE_WRITE (0x4000) + +#define MIISTS_BUSY (1 << 0) + +/* ----------------------------------------------------------------------------- + * 0x80020000 - 0x8002FFFF: USB OHCI + */ +#define USB_OFFSET 0x020000 +#define USB_BASE (EP93XX_AHB_BASE | USB_OFFSET) + +#define USB_HCREVISION (USB_BASE + 0x0000) +#define USB_HCCONTROL (USB_BASE + 0x0004) +#define USB_HCCOMMANDSTATUS (USB_BASE + 0x0008) +#define USB_HCINTERRUPTSTATUS (USB_BASE + 0x000C) +#define USB_HCINTERRUPTENABLE (USB_BASE + 0x0010) +#define USB_HCINTERRUPTDISABLE (USB_BASE + 0x0014) +#define USB_HCHCCA (USB_BASE + 0x0018) +#define USB_HCPERIODCURRENTED (USB_BASE + 0x001C) +#define USB_HCCONTROLHEADED (USB_BASE + 0x0020) +#define USB_HCCONTROLCURRENTED (USB_BASE + 0x0024) +#define USB_HCBULKHEADED (USB_BASE + 0x0028) +#define USB_HCBULKCURRENTED (USB_BASE + 0x002C) +#define USB_HCDONEHEAD (USB_BASE + 0x0030) +#define USB_HCFMINTERVAL (USB_BASE + 0x0034) +#define USB_HCFMREMAINING (USB_BASE + 0x0038) +#define USB_HCFMNUMBER (USB_BASE + 0x003C) +#define USB_HCPERIODICSTART (USB_BASE + 0x0040) +#define USB_HCLSTHRESHOLD (USB_BASE + 0x0044) +#define USB_HCRHDESCRIPTORA (USB_BASE + 0x0048) +#define USB_HCRHDESCRIPTORB (USB_BASE + 0x004C) +#define USB_HCRHSTATUS (USB_BASE + 0x0050) +#define USB_HCRHPORTSTATUS0 (USB_BASE + 0x0054) +#if (defined(CONFIG_EP9302) || defined(CONFIG_EP9307) ||\ + defined(CONFIG_EP9312) || defined(CONFIG_EP9315)) +#define USB_HCRHPORTSTATUS1 (USB_BASE + 0x0058) +#endif +#define USB_HCRHPORTSTATUS2 (USB_BASE + 0x005C) +#define USB_CFGCTRL (USB_BASE + 0x0080) +#define USB_HCISTS (USB_BASE + 0x0084) + + +/* ----------------------------------------------------------------------------- + * 0x80030000 - 0x8003FFFF: Raster engine + */ +#if (defined(CONFIG_EP9307) || defined(CONFIG_EP9312) || defined(CONFIG_EP9315)) +#define RASTER_OFFSET 0x030000 +#define RASTER_BASE (EP93XX_AHB_BASE | RASTER_OFFSET) + +#define RASTER_VLINESTOTAL (RASTER_BASE + 0x0000) +#define RASTER_VSYNCSTRTSTOP (RASTER_BASE + 0x0004) +#define RASTER_VACTIVESTRTSTOP (RASTER_BASE + 0x0008) +#define RASTER_VCLKSTRTSTOP (RASTER_BASE + 0x000C) +#define RASTER_HCLKSTOTAL (RASTER_BASE + 0x0010) +#define RASTER_HSYNCSTRTSTOP (RASTER_BASE + 0x0014) +#define RASTER_HACTIVESTRTSTOP (RASTER_BASE + 0x0018) +#define RASTER_HCLKSTRTSTOP (RASTER_BASE + 0x001C) +#define RASTER_BRIGHTNESS (RASTER_BASE + 0x0020) +#define RASTER_VIDEOATTRIBS (RASTER_BASE + 0x0024) +#define RASTER_VIDSCRNPAGE (RASTER_BASE + 0x0028) +#define RASTER_VIDSCRNHPG (RASTER_BASE + 0x002C) +#define RASTER_SCRNLINES (RASTER_BASE + 0x0030) +#define RASTER_LINELENGTH (RASTER_BASE + 0x0034) +#define RASTER_VLINESTEP (RASTER_BASE + 0x0038) +#define RASTER_LINECARRY (RASTER_BASE + 0x003C) +#define RASTER_BLINKRATE (RASTER_BASE + 0x0040) +#define RASTER_BLINKMASK (RASTER_BASE + 0x0044) +#define RASTER_BLINKPATTRN (RASTER_BASE + 0x0048) +#define RASTER_PATTRNMASK (RASTER_BASE + 0x004C) +#define RASTER_BG_OFFSET (RASTER_BASE + 0x0050) +#define RASTER_PIXELMODE (RASTER_BASE + 0x0054) +#define RASTER_PARLLIFOUT (RASTER_BASE + 0x0058) +#define RASTER_PARLLIFIN (RASTER_BASE + 0x005C) +#define RASTER_CURSOR_ADR_START (RASTER_BASE + 0x0060) +#define RASTER_CURSOR_ADR_RESET (RASTER_BASE + 0x0064) +#define RASTER_CURSORSIZE (RASTER_BASE + 0x0068) +#define RASTER_CURSORCOLOR1 (RASTER_BASE + 0x006C) +#define RASTER_CURSORCOLOR2 (RASTER_BASE + 0x0070) +#define RASTER_CURSORXYLOC (RASTER_BASE + 0x0074) +#define RASTER_CURSOR_DHSCAN_LH_YLOC (RASTER_BASE + 0x0078) +#define RASTER_REALITI_SWLOCK (RASTER_BASE + 0x007C) +#define RASTER_GS_LUT (RASTER_BASE + 0x0080) +#define RASTER_REALITI_TCR (RASTER_BASE + 0x0100) +#define RASTER_REALITI_TISRA (RASTER_BASE + 0x0104) +#define RASTER_REALITI_TISRB (RASTER_BASE + 0x0108) +#define RASTER_CURSOR_TISR (RASTER_BASE + 0x010C) +#define RASTER_REALITI_TOCRA (RASTER_BASE + 0x0110) +#define RASTER_REALITI_TOCRB (RASTER_BASE + 0x0114) +#define RASTER_FIFO_TOCRA (RASTER_BASE + 0x0118) +#define RASTER_FIFO_TOCRB (RASTER_BASE + 0x011C) +#define RASTER_BLINK_TISR (RASTER_BASE + 0x0120) +#define RASTER_DAC_TISRA (RASTER_BASE + 0x0124) +#define RASTER_DAC_TISRB (RASTER_BASE + 0x0128) +#define RASTER_SHIFT_TISR (RASTER_BASE + 0x012C) +#define RASTER_DACMUX_TOCRA (RASTER_BASE + 0x0130) +#define RASTER_DACMUX_TOCRB (RASTER_BASE + 0x0134) +#define RASTER_PELMUX_TOCR (RASTER_BASE + 0x0138) +#define RASTER_VIDEO_TOCRA (RASTER_BASE + 0x013C) +#define RASTER_VIDEO_TOCRB (RASTER_BASE + 0x0140) +#define RASTER_YCRCB_TOCR (RASTER_BASE + 0x0144) +#define RASTER_CURSOR_TOCR (RASTER_BASE + 0x0148) +#define RASTER_VIDEO_TOCRC (RASTER_BASE + 0x014C) +#define RASTER_SHIFT_TOCR (RASTER_BASE + 0x0150) +#define RASTER_BLINK_TOCR (RASTER_BASE + 0x0154) +#define RASTER_REALITI_TCER (RASTER_BASE + 0x0180) +#define RASTER_SIGVAL (RASTER_BASE + 0x0200) +#define RASTER_SIGCTL (RASTER_BASE + 0x0204) +#define RASTER_VSIGSTRTSTOP (RASTER_BASE + 0x0208) +#define RASTER_HSIGSTRTSTOP (RASTER_BASE + 0x020C) +#define RASTER_SIGCLR (RASTER_BASE + 0x0210) +#define RASTER_ACRATE (RASTER_BASE + 0x0214) +#define RASTER_LUTCONT (RASTER_BASE + 0x0218) +#define RASTER_VBLANKSTRTSTOP (RASTER_BASE + 0x0228) +#define RASTER_HBLANKSTRTSTOP (RASTER_BASE + 0x022C) +#define RASTER_LUT (RASTER_BASE + 0x0400) +#define RASTER_CURSORBLINK1 (RASTER_BASE + 0x021C) +#define RASTER_CURSORBLINK2 (RASTER_BASE + 0x0220) +#define RASTER_CURSORBLINK (RASTER_BASE + 0x0224) +#define RASTER_EOLOFFSET (RASTER_BASE + 0x0230) +#define RASTER_FIFOLEVEL (RASTER_BASE + 0x0234) +#define RASTER_GS_LUT2 (RASTER_BASE + 0x0280) +#define RASTER_GS_LUT3 (RASTER_BASE + 0x0300) +#define RASTER_COLOR_LUT (RASTER_BASE + 0x0400) +#endif + + +/* ----------------------------------------------------------------------------- + * 0x80040000 - 0x8004FFFF: Graphics accelerator + */ +#if defined(CONFIG_EP9315) +#define GFX_OFFSET 0x040000 +#define GFX_BASE (EP93XX_AHB_BASE | GFX_OFFSET) +#endif + + +/* ----------------------------------------------------------------------------- + * 0x80050000 - 0x8005FFFF: Reserved + */ + + +/* ----------------------------------------------------------------------------- + * 0x80060000 - 0x8006FFFF: SDRAM controller + */ +#define SDRAM_OFFSET 0x060000 +#define SDRAM_BASE (EP93XX_AHB_BASE | SDRAM_OFFSET) + +#define SDRAM_GLCONFIG (SDRAM_BASE + 0x0004) +#define SDRAM_REFRSHTIMR (SDRAM_BASE + 0x0008) +#define SDRAM_BOOTSTS (SDRAM_BASE + 0x000C) +#define SDRAM_DEVCFG0 (SDRAM_BASE + 0x0010) +#define SDRAM_DEVCFG1 (SDRAM_BASE + 0x0014) +#define SDRAM_DEVCFG2 (SDRAM_BASE + 0x0018) +#define SDRAM_DEVCFG3 (SDRAM_BASE + 0x001C) + +#define SDRAM_DEVCFG_EXTBUSWIDTH (1 << 2) +#define SDRAM_DEVCFG_BANKCOUNT (1 << 3) +#define SDRAM_DEVCFG_SROMLL (1 << 5) +#define SDRAM_DEVCFG_CASLAT_2 0x00010000 +#define SDRAM_DEVCFG_RASTOCAS_2 0x00200000 + +#define GLCONFIG_INIT (1 << 0) +#define GLCONFIG_MRS (1 << 1) +#define GLCONFIG_SMEMBUSY (1 << 5) +#define GLCONFIG_LCR (1 << 6) +#define GLCONFIG_REARBEN (1 << 7) +#define GLCONFIG_CLKSHUTDOWN (1 << 30) +#define GLCONFIG_CKE (1 << 31) + + +/* ----------------------------------------------------------------------------- + * 0x80070000 - 0x8007FFFF: Reserved + */ + + +/* ----------------------------------------------------------------------------- + * 0x80080000 - 0x8008FFFF: SRAM controller & PCMCIA + */ +#define SMC_OFFSET 0x080000 +#define SMC_BASE (EP93XX_AHB_BASE | SMC_OFFSET) + +#define SMC_BCR0 (SMC_BASE + 0x0000) +#define SMC_BCR1 (SMC_BASE + 0x0004) +#define SMC_BCR2 (SMC_BASE + 0x0008) +#define SMC_BCR3 (SMC_BASE + 0x000C) +#define SMC_BCR6 (SMC_BASE + 0x0018) +#define SMC_BCR7 (SMC_BASE + 0x001C) +#if (defined(CONFIG_EP9307) || defined(CONFIG_EP9315)) +#define SMC_PCATTRIBUTE (SMC_BASE + 0x0020) +#define SMC_PCCOMMON (SMC_BASE + 0x0024) +#define SMC_PCIO (SMC_BASE + 0x0028) +#define SMC_PCMCIACTRL (SMC_BASE + 0x0040) +#endif + +#define SMC_BCR_IDCY_SHIFT 0 +#define SMC_BCR_WST1_SHIFT 5 +#define SMC_BCR_BLE (1 << 10) +#define SMC_BCR_WST2_SHIFT 11 +#define SMC_BCR_MW_SHIFT 28 + + +/* ----------------------------------------------------------------------------- + * 0x80090000 - 0x8009FFFF: Boot ROM + */ + + +/* ----------------------------------------------------------------------------- + * 0x800A0000 - 0x800AFFFF: IDE interface + */ + + +/* ----------------------------------------------------------------------------- + * 0x800B0000 - 0x800BFFFF: VIC1 + */ + + +/* ----------------------------------------------------------------------------- + * 0x800C0000 - 0x800CFFFF: VIC2 + */ + + +/* ----------------------------------------------------------------------------- + * 0x800D0000 - 0x800FFFFF: Reserved + */ + + +/* ----------------------------------------------------------------------------- + * 0x80800000 - 0x8080FFFF: Reserved + */ + + +/* ----------------------------------------------------------------------------- + * 0x80810000 - 0x8081FFFF: Timers + */ +#define TIMER_OFFSET 0x010000 +#define TIMER_BASE (EP93XX_APB_BASE | TIMER_OFFSET) + +#define TIMER1_LOAD (TIMER_BASE + 0x0000) +#define TIMER1_VALUE (TIMER_BASE + 0x0004) +#define TIMER1_CONTROL (TIMER_BASE + 0x0008) +#define TIMER1_CLEAR (TIMER_BASE + 0x000c) + +#define TIMER2_LOAD (TIMER_BASE + 0x0020) +#define TIMER2_VALUE (TIMER_BASE + 0x0024) +#define TIMER2_CONTROL (TIMER_BASE + 0x0028) +#define TIMER2_CLEAR (TIMER_BASE + 0x002c) + +#define TIMER3_LOAD (TIMER_BASE + 0x0080) +#define TIMER3_VALUE (TIMER_BASE + 0x0084) +#define TIMER3_CONTROL (TIMER_BASE + 0x0088) +#define TIMER3_CLEAR (TIMER_BASE + 0x008c) + + +/* ----------------------------------------------------------------------------- + * 0x80820000 - 0x8082FFFF: I2S + */ +#define I2S_OFFSET 0x020000 +#define I2S_BASE (EP93XX_APB_BASE | I2S_OFFSET) + + +/* ----------------------------------------------------------------------------- + * 0x80830000 - 0x8083FFFF: Security + */ +#define SECURITY_OFFSET 0x030000 +#define SECURITY_BASE (EP93XX_APB_BASE | SECURITY_OFFSET) + +#define EXTENSIONID (SECURITY_BASE + 0x2714) + + +/* ----------------------------------------------------------------------------- + * 0x80840000 - 0x8084FFFF: GPIO + */ +#define GPIO_OFFSET 0x040000 +#define GPIO_BASE (EP93XX_APB_BASE | GPIO_OFFSET) + +#define GPIO_PADR (GPIO_BASE + 0x0000) +#define GPIO_PBDR (GPIO_BASE + 0x0004) +#define GPIO_PCDR (GPIO_BASE + 0x0008) +#define GPIO_PDDR (GPIO_BASE + 0x000c) + +#define GPIO_PADDR (GPIO_BASE + 0x0010) +#define GPIO_PBDDR (GPIO_BASE + 0x0014) +#define GPIO_PCDDR (GPIO_BASE + 0x0018) +#define GPIO_PDDDR (GPIO_BASE + 0x001c) + +#define GPIO_PEDR (GPIO_BASE + 0x0020) +#define GPIO_PEDDR (GPIO_BASE + 0x0024) +#define GPIO_PFDR (GPIO_BASE + 0x0030) +#define GPIO_PFDDR (GPIO_BASE + 0x0034) +#define GPIO_PGDR (GPIO_BASE + 0x0038) +#define GPIO_PGDDR (GPIO_BASE + 0x003c) +#define GPIO_PHDR (GPIO_BASE + 0x0040) +#define GPIO_PHDDR (GPIO_BASE + 0x0044) + +#define GPIO_FINTTYPE1 (GPIO_BASE + 0x004c) +#define GPIO_FINTTYPE2 (GPIO_BASE + 0x0050) +#define GPIO_FEOI (GPIO_BASE + 0x0054) +#define GPIO_FINTEN (GPIO_BASE + 0x0058) +#define GPIO_INTSTSF (GPIO_BASE + 0x005c) +#define GPIO_RAWINTSTSF (GPIO_BASE + 0x0060) +#define GPIO_FDB (GPIO_BASE + 0x0064) + +#define GPIO_AINTTYPE1 (GPIO_BASE + 0x0090) +#define GPIO_AINTTYPE2 (GPIO_BASE + 0x0094) +#define GPIO_AEOI (GPIO_BASE + 0x0098) +#define GPIO_AINTEN (GPIO_BASE + 0x009c) +#define GPIO_INTSTSA (GPIO_BASE + 0x00a0) +#define GPIO_RAWINTSTSA (GPIO_BASE + 0x00a4) +#define GPIO_ADB (GPIO_BASE + 0x00a8) + +#define GPIO_BINTTYPE1 (GPIO_BASE + 0x00ac) +#define GPIO_BINTTYPE2 (GPIO_BASE + 0x00b0) +#define GPIO_BEOI (GPIO_BASE + 0x00b4) +#define GPIO_BINTEN (GPIO_BASE + 0x00b8) +#define GPIO_INTSTSB (GPIO_BASE + 0x00bc) +#define GPIO_RAWINTSTSB (GPIO_BASE + 0x00c0) +#define GPIO_BDB (GPIO_BASE + 0x00c4) + +#define GPIO_EEDRIVE (GPIO_BASE + 0x00c8) + + +/* ----------------------------------------------------------------------------- + * 0x80850000 - 0x8087FFFF: Reserved + */ + + +/* ----------------------------------------------------------------------------- + * 0x80880000 - 0x8088FFFF: AAC + */ +#define AAC_OFFSET 0x080000 +#define AAC_BASE (EP93XX_APB_BASE | AAC_OFFSET) + + +/* ----------------------------------------------------------------------------- + * 0x80890000 - 0x8089FFFF: Reserved + */ + + +/* ----------------------------------------------------------------------------- + * 0x808A0000 - 0x808AFFFF: SPI + */ +#define SPI_OFFSET 0x0A0000 +#define SPI_BASE (EP93XX_APB_BASE | SPI_OFFSET) + +#define SPI_SSP1CR0 (SPI_BASE + 0x0000) +#define SPI_SSP1CR1 (SPI_BASE + 0x0004) +#define SPI_SSP1DR (SPI_BASE + 0x0008) +#define SPI_SSP1SR (SPI_BASE + 0x000c) +#define SPI_SSP1CPSR (SPI_BASE + 0x0010) +#define SPI_SSP1IIR (SPI_BASE + 0x0014) + + +/* ----------------------------------------------------------------------------- + * 0x808B0000 - 0x808BFFFF: IrDA + */ +#define IRDA_OFFSET 0x0B0000 +#define IRDA_BASE (EP93XX_APB_BASE | IRDA_OFFSET) + + +/* ----------------------------------------------------------------------------- + * 0x808C0000 - 0x808CFFFF: UART1 + */ +#define UART1_OFFSET 0x0C0000 +#define UART1_BASE (EP93XX_APB_BASE | UART1_OFFSET) + +#define UART1_DATA (UART1_BASE + 0x0000) +#define UART1_RXSTS (UART1_BASE + 0x0004) +#define UART1_LIN_CTRLHIGH (UART1_BASE + 0x0008) +#define UART1_LIN_CTRLMID (UART1_BASE + 0x000c) +#define UART1_LIN_CTRLLOW (UART1_BASE + 0x0010) +#define UART1_CTRL (UART1_BASE + 0x0014) +#define UART1_FLAG (UART1_BASE + 0x0018) +#define UART1_INTIDINTCLR (UART1_BASE + 0x001c) + +#define UART1_DMA_CTRL (UART1_BASE + 0x0028) + +#define UART1_MODEM_CTRL (UART1_BASE + 0x0100) +#define UART1_MODEM_STS (UART1_BASE + 0x0104) + +#define UART1_HDLC_CTRL (UART1_BASE + 0x020c) +#define UART1_HDLC_ADDMTCHVAL (UART1_BASE + 0x0210) +#define UART1_HDLC_ADDMASK (UART1_BASE + 0x0214) +#define UART1_HDLC_RXINFOBUF (UART1_BASE + 0x0218) +#define UART1_HDLC_STS (UART1_BASE + 0x021c) + + +/* ----------------------------------------------------------------------------- + * 0x808D0000 - 0x808DFFFF: UART2 + */ +#define UART2_OFFSET 0x0D0000 +#define UART2_BASE (EP93XX_APB_BASE | UART2_OFFSET) + +#define UART2_DATA (UART2_BASE + 0x0000) +#define UART2_RXSTS (UART2_BASE + 0x0004) +#define UART2_LIN_CTRLHIGH (UART2_BASE + 0x0008) +#define UART2_LIN_CTRLMID (UART2_BASE + 0x000c) +#define UART2_LIN_CTRLLOW (UART2_BASE + 0x0010) +#define UART2_CTRL (UART2_BASE + 0x0014) +#define UART2_FLAG (UART2_BASE + 0x0018) +#define UART2_INTIDINTCLR (UART2_BASE + 0x001c) +#define UART2_IRLOWPWRCNTR (UART2_BASE + 0x0020) + +#define UART2_DMA_CTRL (UART2_BASE + 0x0028) + + +/* ----------------------------------------------------------------------------- + * 0x808E0000 - 0x808EFFFF: UART3 + */ +#define UART3_OFFSET 0x0E0000 +#define UART3_BASE (EP93XX_APB_BASE | UART3_OFFSET) + +#define UART3_DATA (UART3_BASE + 0x0000) +#define UART3_RXSTS (UART3_BASE + 0x0004) +#define UART3_LIN_CTRLHIGH (UART3_BASE + 0x0008) +#define UART3_LIN_CTRLMID (UART3_BASE + 0x000c) +#define UART3_LIN_CTRLLOW (UART3_BASE + 0x0010) +#define UART3_CTRL (UART3_BASE + 0x0014) +#define UART3_FLAG (UART3_BASE + 0x0018) +#define UART3_INTIDINTCLR (UART3_BASE + 0x001c) +#define UART3_IRLOWPWRCNTR (UART3_BASE + 0x0020) + +#define UART3_DMA_CTRL (UART3_BASE + 0x0028) + +#define UART3_MODEM_CTRL (UART3_BASE + 0x0100) +#define UART3_MODEM_STS (UART3_BASE + 0x0104) +#define UART2_MODEM_TSTCTRL (UART2_BASE + 0x0108) + +#define UART3_HDLC_CTRL (UART3_BASE + 0x020c) +#define UART3_HDLC_ADDMTCHVAL (UART3_BASE + 0x0210) +#define UART3_HDLC_ADDMASK (UART3_BASE + 0x0214) +#define UART3_HDLC_RXINFOBUF (UART3_BASE + 0x0218) +#define UART3_HDLC_STS (UART3_BASE + 0x021c) + + +/* ----------------------------------------------------------------------------- + * 0x808F0000 - 0x808FFFFF: Key Matrix + */ +#define KEY_OFFSET 0x0F0000 +#define KEY_BASE (EP93XX_APB_BASE | KEY_OFFSET) + + +/* ----------------------------------------------------------------------------- + * 0x80900000 - 0x8090FFFF: Touchscreen + */ +#define TOUCH_OFFSET 0x900000 +#define TOUCH_BASE (EP93XX_APB_BASE | TOUCH_OFFSET) + + +/* ----------------------------------------------------------------------------- + * 0x80910000 - 0x8091FFFF: Pulse Width Modulation + */ +#define PWM_OFFSET 0x910000 +#define PWM_BASE (EP93XX_APB_BASE | PWM_OFFSET) + + +/* ----------------------------------------------------------------------------- + * 0x80920000 - 0x8092FFFF: Real time clock + */ +#define RTC_OFFSET 0x920000 +#define RTC_BASE (EP93XX_APB_BASE | RTC_OFFSET) + + +/* ----------------------------------------------------------------------------- + * 0x80930000 - 0x8093FFFF: Syscon + */ +#define SYSCON_OFFSET 0x930000 +#define SYSCON_BASE (EP93XX_APB_BASE | SYSCON_OFFSET) + +#define SYSCON_PWRSTS (SYSCON_BASE + 0x0000) +#define SYSCON_PWRCNT (SYSCON_BASE + 0x0004) +#define SYSCON_HALT (SYSCON_BASE + 0x0008) +#define SYSCON_STBY (SYSCON_BASE + 0x000c) +#define SYSCON_TEOI (SYSCON_BASE + 0x0018) +#define SYSCON_STFCLR (SYSCON_BASE + 0x001c) +#define SYSCON_CLKSET1 (SYSCON_BASE + 0x0020) +#define SYSCON_CLKSET2 (SYSCON_BASE + 0x0024) +#define SYSCON_SCRATCH0 (SYSCON_BASE + 0x0040) +#define SYSCON_SCRATCH1 (SYSCON_BASE + 0x0044) +#define SYSCON_APBWAIT (SYSCON_BASE + 0x0050) +#define SYSCON_BUSMSTRARB (SYSCON_BASE + 0x0054) +#define SYSCON_BOOTMODECLR (SYSCON_BASE + 0x0058) +#define SYSCON_DEVICECFG (SYSCON_BASE + 0x0080) +#define SYSCON_VIDCLKDIV (SYSCON_BASE + 0x0084) +#define SYSCON_MIRCLKDIV (SYSCON_BASE + 0x0088) +#define SYSCON_I2SCLKDIV (SYSCON_BASE + 0x008c) +#define SYSCON_KEYTCHCLKDIV (SYSCON_BASE + 0x0090) +#define SYSCON_CHIPID (SYSCON_BASE + 0x0094) +#define SYSCON_SYSCFG (SYSCON_BASE + 0x009c) +#define SYSCON_SYSSWLOCK (SYSCON_BASE + 0x00c0) + +#define SYSCON_PWRCNT_UART_BAUD (1 << 29) + +#define SYSCON_CLKSET_PLL_X2IPD_SHIFT 0 +#define SYSCON_CLKSET_PLL_X2FBD2_SHIFT 5 +#define SYSCON_CLKSET_PLL_X1FBD1_SHIFT 11 +#define SYSCON_CLKSET_PLL_PS_SHIFT 16 +#define SYSCON_CLKSET1_PCLK_DIV_SHIFT 18 +#define SYSCON_CLKSET1_HCLK_DIV_SHIFT 20 +#define SYSCON_CLKSET1_NBYP1 (1 << 23) +#define SYSCON_CLKSET1_FCLK_DIV_SHIFT 25 + +#define SYSCON_CLKSET2_PLL2_EN (1 << 18) +#define SYSCON_CLKSET2_NBYP2 (1 << 19) +#define SYSCON_CLKSET2_USB_DIV_SHIFT 28 + + +#define SYSCON_CHIPID_REV_MASK 0xF0000000 +#define SYSCON_DEVICECFG_SWRST (1 << 31) + + +/* ----------------------------------------------------------------------------- + * 0x80930000 - 0x8093FFFF: Watchdog Timer + */ +#define WATCHDOG_OFFSET 0x940000 +#define WATCHDOG_BASE (EP93XX_APB_BASE | WATCHDOG_OFFSET) + +#define WATCHDOG_TIMER (WATCHDOG_BASE + 0x0000) +#define WATCHDOG_STATUS (WATCHDOG_BASE + 0x0004) + + +/* ----------------------------------------------------------------------------- + * 0x80950000 - 0x9000FFFF: Reserved + */ + diff --git a/include/common.h b/include/common.h index f7c93bf..eec225c 100644 --- a/include/common.h +++ b/include/common.h @@ -502,6 +502,12 @@ ulong get_HCLK (void); ulong get_PCLK (void); ulong get_UCLK (void); #endif +#ifdef CONFIG_EP93XX +ulong get_FCLK(void); +ulong get_HCLK(void); +ulong get_PCLK(void); +ulong get_UCLK(void); +#endif #if defined(CONFIG_LH7A40X) ulong get_PLLCLK (void); #endif diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h new file mode 100644 index 0000000..6c4576b --- /dev/null +++ b/include/configs/edb93xx.h @@ -0,0 +1,235 @@ +/* + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* Initial environment and monitor configuration options. */ +#define CONFIG_ETHADDR 08:00:3E:26:0A:5B +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_IPADDR 192.168.99.225 +#define CONFIG_SERVERIP 192.168.99.1 +#define CONFIG_GATEWAYIP 192.168.99.1 + +#define CONFIG_BOOTDELAY 5 +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_BOOTARGS "root=/dev/nfs console=ttyAM0,115200 ip=dhcp" +#define CONFIG_BOOTFILE "edb93xx.img" + +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#ifdef CONFIG_EDB9301 +#define CONFIG_EP9301 +#elif defined(CONFIG_EDB9302) || defined(CONFIG_EDB9302A) +#define CONFIG_EP9302 +#elif defined(CONFIG_EDB9307) || defined(CONFIG_EDB9307A) +#define CONFIG_EP9307 +#elif defined(CONFIG_EDB9312) +#define CONFIG_EP9312 +#elif defined(CONFIG_EDB9315) || defined(CONFIG_EDB9315A) +#define CONFIG_EP9315 +#endif + +/* High-level configuration options */ +#define CONFIG_ARM920T 1 /* This is an ARM920T core... */ +#define CONFIG_EP93XX 1 /* in a Cirrus Logic 93xx SoC */ + +#define CONFIG_SYS_CLK_FREQ 14745600 /* EP93xx has a 14.7456 clock */ +#define CONFIG_SYS_HZ 2048 /* Timer 3 set for 2KHz */ +#define CONFIG_SYS_CLKS_IN_HZ /* Everything in Hz */ +#undef CONFIG_USE_IRQ /* Don't need IRQ/FIQ */ + +/* Monitor configuration */ +#include <config_cmd_default.h> +#if 0 +#undef CONFIG_CMD_BDI +#endif +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_XIMG + +#undef CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_FAT +#define CONFIG_CMD_JFFS2 + +#if !defined USE_920T_MMU +#undef CONFIG_CMD_CACHE +#endif + +#ifdef CONFIG_EDB9301 +#define CONFIG_SYS_PROMPT "EDB9301> " +#elif (defined CONFIG_EDB9302) +#define CONFIG_SYS_PROMPT "EDB9302> " +#elif (defined CONFIG_EDB9302A) +#define CONFIG_SYS_PROMPT "EDB9302a> " +#elif (defined CONFIG_EDB9307) +#define CONFIG_SYS_PROMPT "EDB9307> " +#elif (defined CONFIG_EDB9307A) +#define CONFIG_SYS_PROMPT "EDB9307a> " +#elif (defined CONFIG_EDB9312) +#define CONFIG_SYS_PROMPT "EDB9312> " +#elif (defined CONFIG_EDB9315) +#define CONFIG_SYS_PROMPT "EDB9315> " +#elif (defined CONFIG_EDB9315A) +#define CONFIG_SYS_PROMPT "EDB9315a> " +#endif + +#define CONFIG_SYS_LONGHELP /* Enable "long" help in mon */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print buffer size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot argument buffer size */ +#define CONFIG_SYS_MAXARGS 16 /* Max number of command args */ + +/* Serial port hardware configuration */ +#define CONFIG_PL010_SERIAL +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} +#define CONFIG_SYS_SERIAL0 0x808C0000 +#define CONFIG_SYS_SERIAL1 0x808D0000 +#define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0, (void *)CONFIG_SYS_SERIAL1} + +/* Network hardware configuration */ +#define CONFIG_DRIVER_EP93XX_MAC +#define CONFIG_MII_SUPPRESS_PREAMBLE +#define CONFIG_MII +#define CONFIG_PHY_ADDR 1 +#undef CONFIG_NETCONSOLE + + +/* SDRAM configuration */ +#if defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) +#define CONFIG_NR_DRAM_BANKS 4 /* EDB9301/2 has 1 bank of SDRAM */ +#define PHYS_SDRAM_1 0x00000000 /* consisting of 1x Samsung */ +#define PHYS_SDRAM_SIZE_1 0x00800000 /* K4S561632E-TC75 256 Mbit */ +#define PHYS_SDRAM_2 0x01000000 /* SDRAM on a 16-bit data bus, */ +#define PHYS_SDRAM_SIZE_2 0x00800000 /* for a total of 32MB of SDRAM. */ +#define PHYS_SDRAM_3 0x04000000 /* We set the SROMLL bit on the */ +#define PHYS_SDRAM_SIZE_3 0x00800000 /* processor, resulting in this */ +#define PHYS_SDRAM_4 0x05000000 /* non-contiguous memory map. */ +#define PHYS_SDRAM_SIZE_4 0x00800000 +#define CONFIG_EDB93XX_SDCS3 +#define CONFIG_SYS_MEMTEST_START 0x00000000 +#define CONFIG_SYS_MEMTEST_END 0x00800000 + +#elif defined(CONFIG_EDB9302A) +#define CONFIG_NR_DRAM_BANKS 4 /* EDB9302a has 4 banks of SDRAM */ +#define PHYS_SDRAM_1 0xc0000000 /* consisting of 1x Samsung */ +#define PHYS_SDRAM_SIZE_1 0x00800000 /* K4S561632E-TC75 256 Mbit */ +#define PHYS_SDRAM_2 0xc1000000 /* SDRAM on a 16-bit data bus, */ +#define PHYS_SDRAM_SIZE_2 0x00800000 /* for a total of 32MB of SDRAM. */ +#define PHYS_SDRAM_3 0xc4000000 /* We set the SROMLL bit on the */ +#define PHYS_SDRAM_SIZE_3 0x00800000 /* processor, resulting in this */ +#define PHYS_SDRAM_4 0xc5000000 /* non-contiguous memory map. */ +#define PHYS_SDRAM_SIZE_4 0x00800000 +#define CONFIG_EDB93XX_SDCS0 +#define CONFIG_SYS_MEMTEST_START 0xc0000000 +#define CONFIG_SYS_MEMTEST_END 0xc0800000 + +#elif defined(CONFIG_EDB9307) || defined CONFIG_EDB9312 || defined(CONFIG_EDB9315) +#define CONFIG_NR_DRAM_BANKS 2 /* The EDB9307, EDB9312, and EDB9315 have */ +#define PHYS_SDRAM_1 0x00000000 /* 2 banks of SDRAM consisting of 2x Samsung */ +#define PHYS_SDRAM_SIZE_1 0x02000000 /* K4S561632E-TC75 256 Mbit on a 32-bit data */ +#define PHYS_SDRAM_2 0x04000000 /* bus, for a total of 64 MB of SDRAM. */ +#define PHYS_SDRAM_SIZE_2 0x02000000 +#define CONFIG_EDB93XX_SDCS3 +#define CONFIG_SYS_MEMTEST_START 0x00000000 +#define CONFIG_SYS_MEMTEST_END 0x02000000 + +#elif defined(CONFIG_EDB9307A) || defined(CONFIG_EDB9315A) +#define CONFIG_NR_DRAM_BANKS 2 /* The EDB9307A and EDB9315A have */ +#define PHYS_SDRAM_1 0xc0000000 /* 2 banks of SDRAM consisting of 2x Samsung */ +#define PHYS_SDRAM_SIZE_1 0x02000000 /* K4S561632E-TC75 256 Mbit on a 32-bit data */ +#define PHYS_SDRAM_2 0xc4000000 /* bus, for a total of 64 MB of SDRAM. */ +#define PHYS_SDRAM_SIZE_2 0x02000000 +#define CONFIG_EDB93XX_SDCS0 +#define CONFIG_SYS_MEMTEST_START 0xc0000000 +#define CONFIG_SYS_MEMTEST_END 0xc2000000 +#endif + +#if defined(CONFIG_EDB93XX_SDCS3) +#define CONFIG_SYS_LOAD_ADDR 0x01000000 /* Default load address */ +#elif defined(CONFIG_EDB93XX_SDCS0) +#define CONFIG_SYS_LOAD_ADDR 0xc1000000 /* Default load address */ +#endif + +#define LINUX_BOOT_PARAM_ADDR (PHYS_SDRAM_1 + 0x100) /* Must match kernel config */ + +/* Run-time memory allocatons */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_STACKSIZE (128 * 1024) + +#if defined(CONFIG_USE_IRQ) +#define CONFIG_STACKSIZE_IRQ (4 * 1024) +#define CONFIG_STACKSIZE_FIQ (4 * 1024) +#endif + +#define CONFIG_SYS_MALLOC_LEN (512 * 1024) + +/* ----------------------------------------------------------------------------- + * FLASH and environment organization + * + * The EDB9301 and EDB9302(a) have 1 bank of flash memory at 0x60000000 + * consisting of 1x Intel TE28F128J3C-150 128 Mbit flash on a 16-bit data bus, + * for a total of 16 MB of CFI-compatible flash. + * + * The EDB9307(a), EDB9312, and EDB9315(a) have 1 bank of flash memory at + * 0x60000000 consisting of 2x Micron MT28F128J3-12 128 Mbit flash on a 32-bit + * data bus, for a total of 32 MB of CFI-compatible flash. + * + * EDB9301/02(a) EDB9307(a)/12/15(a) + * 0x00000000 - 0x0003FFFF u-boot u-boot + * 0x00040000 - 0x0005FFFF environment #1 environment #1 + * 0x00060000 - 0x0007FFFF unused environment #1 (continued) + * 0x00080000 - 0x0009FFFF environment #2 environment #2 + * 0x000A0000 - 0x000BFFFF unused environment #2 (continued) + * 0x000C0000 - 0x000FFFFF unused unused + * 0x00100000 - 0x002FFFFF kernel image #1 kernel image #1 + * 0x00300000 - 0x004FFFFF kernel image #2 kernel image #2 + * 0x00500000 - 0x00FFFFFF JFFS2 JFFS2 + * 0x01000000 - 0x01FFFFFF not present JFFS2 (continued) + */ + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 128 + +#define PHYS_FLASH_1 0x60000000 +#define CONFIG_SYS_FLASH_BASE (PHYS_FLASH_1) +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) + +#define CONFIG_ENV_OVERWRITE /* Vendor params unprotected */ +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR 0x60040000 +#if (defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) ||\ + defined(CONFIG_EDB9302A)) +#define CONFIG_ENV_SECT_SIZE 0x00020000 +#elif (defined(CONFIG_EDB9307) || defined(CONFIG_EDB9307A) ||\ + defined(CONFIG_EDB9312) || defined(CONFIG_EDB9315) ||\ + defined(CONFIG_EDB9315A)) +#define CONFIG_ENV_SECT_SIZE 0x00040000 +#endif +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) + +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + +#define CONFIG_SYS_JFFS2_FIRST_BANK 0 +#if (defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) ||\ + defined(CONFIG_EDB9302A)) +#define CONFIG_SYS_JFFS2_FIRST_SECTOR 28 +#elif (defined(CONFIG_EDB9307) || defined(CONFIG_EDB9307A) ||\ + defined(CONFIG_EDB9312) || defined(CONFIG_EDB9315) ||\ + defined(CONFIG_EDB9315A)) +#define CONFIG_SYS_JFFS2_FIRST_SECTOR 14 +#endif + +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 + +#endif /* !defined (__CONFIG_H) */
Matthias Kaehlcke wrote:
Add support for the Cirrus EP93xx platform and EDB93xx boards
Signed-off-by: Matthias Kaehlcke matthias@kaehlcke.net
This work is based on the patch from Dominic Rath for the Olimex CS-E9301 board (http://article.gmane.org/gmane.linux.ports.arm.cirrus/722) and some input from a patch for EDB93xx boards from Herbert Valerio Riedel (http://stud3.tuwien.ac.at/~e9725348/Projects/ep93xx/u-boot-1.2.0-edb93xx_sup...)
For now it has been tested on boards based on the EDB9301 and EDB9307A design.
You must run your patch through the kernel's checkpatch.pl script. Please fix the whitespace problems. It looked like most of these warnings where complaining about the line length exceeding 80 char's. Please fix this. The error was about the hard coded eth mac address. No hard coded mac addressing.
total: 5 errors, 43 warnings, 3153 lines checked
[U-Boot] [PATCH] ARM: Add support for edb93xx boards.txt has style problems, please review. If any of these errors are false positives report them to the maintainer, see
You should also run your patch through a test 'git am -3' on a clean dir The current patch has this
git am -3 ../../for-test/091207/[U-Boot]\ [PATCH]\ ARM:\ Add\ support\ for\ edb93xx\ boards.txt Applying: ARM: Add support for edb93xx boards /home/trix/tmp/utmp/u23/u-boot/src/u-boot-arm/.git/rebase-apply/patch:490: space before tab in indent. * /home/trix/tmp/utmp/u23/u-boot/src/u-boot-arm/.git/rebase-apply/patch:498: space before tab in indent. * warning: 2 lines add whitespace errors.
You should also have no compile warnings when building.
test > make edb9302_config Configuring for edb93xx board... test > make > /dev/null eth.c:497:2: warning: #warning Ethernet driver is deprecated. Please update to use CONFIG_NET_MULTI
Makefile | 36 ++
Add yourself to the MAINTAINER's file. Add this board(s) to the MAKEALL file. Add in alphabetical order.
board/edb93xx/Makefile | 51 ++ board/edb93xx/config.mk | 1 + board/edb93xx/edb93xx.c | 120 +++++ board/edb93xx/flash_cfg.S | 42 ++ board/edb93xx/pll_cfg.S | 93 ++++ board/edb93xx/sdram_cfg.S | 217 +++++++++ board/edb93xx/u-boot.lds | 59 +++ cpu/arm920t/ep93xx/Makefile | 55 +++ cpu/arm920t/ep93xx/cpu.c | 125 +++++ cpu/arm920t/ep93xx/eth.c | 876 ++++++++++++++++++++++++++++++++++
Break eth support into its own patch.
cpu/arm920t/ep93xx/lowlevel_init.S | 74 +++ cpu/arm920t/ep93xx/speed.c | 120 +++++ cpu/arm920t/ep93xx/timer.c | 163 +++++++
Break cpu into its own patch
include/asm-arm/arch-ep93xx/ep93xx.h | 868 +++++++++++++++++++++++++++++++++ include/common.h | 6 + include/configs/edb93xx.h | 235 +++++++++
You should have 1. cpu patch 2. eth patch 3. board patch
17 files changed, 3141 insertions(+), 0 deletions(-)
diff --git a/Makefile b/Makefile index bcb3fe9..8ddd19d 100644 --- a/Makefile +++ b/Makefile @@ -2429,6 +2429,42 @@ TQM834x_config: unconfig vme8349_config: unconfig @$(MKCONFIG) $(@:_config=) ppc mpc83xx vme8349 esd
+edb93xx_config \ +edb9301_config \ +edb9302_config \ +edb9302a_config \ +edb9307_config \ +edb9307a_config \ +edb9315a_config: unconfig
- @if [ "$(findstring 01_,$@)" ] ; then \
echo "#define CONFIG_EDB9301" >> $(obj)include/config.h ; \
- elif [ "$(findstring 02_,$@)" ] ; then \
echo "#define CONFIG_EDB9302" >> $(obj)include/config.h ; \
- elif [ "$(findstring 02a_,$@)" ] ; then \
echo "#define CONFIG_EDB9302A" >> $(obj)include/config.h ; \
- elif [ "$(findstring 07_,$@)" ] ; then \
echo "#define CONFIG_EDB9307" >> $(obj)include/config.h ; \
- elif [ "$(findstring 07a_,$@)" ] ; then \
echo "#define CONFIG_EDB9307A" >> $(obj)include/config.h ; \
- elif [ "$(findstring 12_,$@)" ] ; then \
echo "#define CONFIG_EDB9312" >> $(obj)include/config.h ; \
No edb9312_config
- elif [ "$(findstring 15_,$@)" ] ; then \
echo "#define CONFIG_EDB9315" >> $(obj)include/config.h ; \
No edb9315_config
- elif [ "$(findstring 15a_,$@)" ] ; then \
echo "#define CONFIG_EDB9315A" >> $(obj)include/config.h ; \
- fi ;
- @$(MKCONFIG) -a edb93xx arm arm920t edb93xx NULL ep93xx
- @if [ "$(findstring 01_,$@)" ] || [ "$(findstring 02_,$@)" ]; then \
echo "TEXT_BASE = 0x05400000" >> $(obj)include/config.mk ; \
- elif [ "$(findstring 02a_,$@)" ]; then \
echo "TEXT_BASE = 0xc5400000" >> $(obj)include/config.mk ; \
- elif [ "$(findstring 07_,$@)" ] || [ "$(findstring 12_,$@)" ] || [ "$(findstring 15_,$@)" ]; then \
echo "TEXT_BASE = 0x01f00000" >> $(obj)include/config.mk ; \
- elif [ "$(findstring 07a_,$@)" ] || [ "$(findstring 15a_,$@)" ]; then \
echo "TEXT_BASE = 0xc1f00000" >> $(obj)include/config.mk ; \
- fi ;
Combine this TEXT_BASE if check's with the CONFIG_* if check's above.
######################################################################### ## MPC85xx Systems ######################################################################### diff --git a/board/edb93xx/Makefile b/board/edb93xx/Makefile new file mode 100644 index 0000000..57c109d --- /dev/null +++ b/board/edb93xx/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2003-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +#
+include $(TOPDIR)/config.mk
+LIB = $(obj)lib$(BOARD).a
+COBJS := edb93xx.o +SOBJS := flash_cfg.o pll_cfg.o sdram_cfg.o
+SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS))
+$(LIB): $(obj).depend $(OBJS) $(SOBJS)
- $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS)
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak .depend
+# defines $(obj).depend target +include $(SRCTREE)/rules.mk
+sinclude $(obj).depend
+######################################################################### diff --git a/board/edb93xx/config.mk b/board/edb93xx/config.mk new file mode 100644 index 0000000..dffa83e --- /dev/null +++ b/board/edb93xx/config.mk @@ -0,0 +1 @@ +LDSCRIPT := $(SRCTREE)/board/$(BOARDDIR)/u-boot.lds \ No newline at end of file
Add a '\n'
diff --git a/board/edb93xx/edb93xx.c b/board/edb93xx/edb93xx.c new file mode 100644 index 0000000..fdbb956 --- /dev/null +++ b/board/edb93xx/edb93xx.c @@ -0,0 +1,120 @@ +/*
- vim: set ts=4 sw=4 noet:
Remove vim comment. Apply globlly
- Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net
- (C) Copyright 2002 2003
- Network Audio Technologies, Inc. <www.netaudiotech.com>
- Adam Bezanson bezanson@netaudiotech.com
Remove extra space
- project.
- MA 02111-1307 USA
+int board_init(void) +{
- DECLARE_GLOBAL_DATA_PTR;
- icache_enable();
+#ifdef USE_920T_MMU
- dcache_enable();
- /* set UARTBAUD bit to drive UARTs with 14.7456MHz instead of
* 14.7456/2 MHz
Multi line comments are in the format /* * Comment ln * Comment ln */ Fix globally
- uint32_t value = readl(SYSCON_PWRCNT);
- value |= SYSCON_PWRCNT_UART_BAUD;
- writel(value, SYSCON_PWRCNT);
- /* Machine number, as defined in linux/arch/arm/tools/mach-types
Single line comments are /* Comment ln */ Fix globally
- gd->bd->bi_arch_number = 462;
- gd->bd->bi_arch_number = 538;
- gd->bd->bi_arch_number = 1127;
- gd->bd->bi_arch_number = 607;
- gd->bd->bi_arch_number = 1128;
- gd->bd->bi_arch_number = 451;
- gd->bd->bi_arch_number = 463;
+#elif defined(CONFIG_EDB9315A)
- gd->bd->bi_arch_number = 772;
You must use the mach-types.h
#elif defined(CONFIG_EDB9315A) gd->bd->bi_arch_number = MACH_TYPE_EDB9315A; #endif
- /* adress of boot parameters
- gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR;
- /* We have a console
- gd->have_console = 1;
+int dram_init(void) +{
- unsigned int *src, *dst;
- int i;
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE_1;
+#ifdef PHYS_SDRAM_2
- gd->bd->bi_dram[1].start = PHYS_SDRAM_2;
- gd->bd->bi_dram[1].size = PHYS_SDRAM_SIZE_2;
+#ifdef PHYS_SDRAM_3
- gd->bd->bi_dram[2].start = PHYS_SDRAM_3;
- gd->bd->bi_dram[2].size = PHYS_SDRAM_SIZE_3;
+#ifdef PHYS_SDRAM_4
- gd->bd->bi_dram[3].start = PHYS_SDRAM_4;
- gd->bd->bi_dram[3].size = PHYS_SDRAM_SIZE_4;
+#ifdef CONFIG_EDB93XX_SDCS3
- dst = (unsigned int *)0x00000000;
+#else
- dst = (unsigned int *)0xc0000000;
- /* copy exception vectors */
- src = (unsigned int *)_armboot_start;
- for (i = 0; i < 16; i++)
*dst++ = *src++;
+} diff --git a/board/edb93xx/flash_cfg.S b/board/edb93xx/flash_cfg.S new file mode 100644 index 0000000..aa61a3c --- /dev/null +++ b/board/edb93xx/flash_cfg.S @@ -0,0 +1,42 @@ +/*
- Flash setup for Olimex CS-E9302 board
- Copyright (C) 2006 Dominic Rath Dominic.Rath@gmx.de
- project.
Tab before 'See' should be a space
- MA 02111-1307 USA
+.globl flash_cfg +flash_cfg:
- /* configure smc bank 6 (Intel TE28F128J3D75 Strata Flash)
* ebibrkdis: 0, mw: 0x1 (16 bit), pme: 0, wp: 0, wst2: 2(+1),
* wst1: 5(+1), rble: 1, idcy: 2(+1)
* TODO: we don't enable page mode for now
- ldr r0, =SMC_BCR6
- ldr r1, =(2 << SMC_BCR_IDCY_SHIFT | 5 << SMC_BCR_WST1_SHIFT | \
SMC_BCR_BLE | 2 << SMC_BCR_WST2_SHIFT | 1 << SMC_BCR_MW_SHIFT)
- str r1, [r0]
- mov pc, lr
diff --git a/board/edb93xx/pll_cfg.S b/board/edb93xx/pll_cfg.S new file mode 100644 index 0000000..ae69a7d --- /dev/null +++ b/board/edb93xx/pll_cfg.S @@ -0,0 +1,93 @@ +/*
- PLL setup for Cirrus EDB93xx boards
- project.
- MA 02111-1307 USA
+#include <config.h> +#include <asm/arch/ep93xx.h>
+.globl pll_cfg +pll_cfg:
- /* configure PLL1 */
- ldr r0, =SYSCON_CLKSET1
+#if defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) || \
- defined(CONFIG_EDB9302A)
- /* fclk_div: 2, nbyp1: 1, hclk_div: 5, pclk_div: 2
* pll1_x1: 294912000.000000, pll1_x2ip: 36864000.000000,
* pll1_x2: 331776000.000000, pll1_out: 331776000.000000
- ldr r1, =(7 << SYSCON_CLKSET_PLL_X2IPD_SHIFT | \
8 << SYSCON_CLKSET_PLL_X2FBD2_SHIFT | \
19 << SYSCON_CLKSET_PLL_X1FBD1_SHIFT | \
1 << SYSCON_CLKSET1_PCLK_DIV_SHIFT | \
3 << SYSCON_CLKSET1_HCLK_DIV_SHIFT | \
SYSCON_CLKSET1_NBYP1 | \
1 << SYSCON_CLKSET1_FCLK_DIV_SHIFT)
+#elif defined(CONFIG_EDB9307) || defined(CONFIG_EDB9307A) ||\
- defined CONFIG_EDB9312 || defined(CONFIG_EDB9315) ||\
- defined(CONFIG_EDB9315A)
- /* fclk_div: 2, nbyp1: 1, hclk_div: 4, pclk_div: 2
* pll1_x1: 3096576000.000000, pll1_x2ip: 129024000.000000,
* pll1_x2: 3999744000.000000, pll1_out: 1999872000.000000
- ldr r1, =(23 << SYSCON_CLKSET_PLL_X2IPD_SHIFT | \
30 << SYSCON_CLKSET_PLL_X2FBD2_SHIFT | \
20 << SYSCON_CLKSET_PLL_X1FBD1_SHIFT | \
2 << SYSCON_CLKSET1_HCLK_DIV_SHIFT | \
Add an #else #error "Undefined board" #endif
- str r1, [r0]
- /* flush the pipeline
* writing to CLKSET1 causes the EP9302 to enter standby for between
* 8 ms to 16 ms, until PLL1 stabilizes
- nop
- nop
- nop
- nop
- nop
- /* configure PLL2
* usb_div: 4, nbyp2: 1, pll2_en: 1
* pll2_x1: 368640000.000000, pll2_x2ip: 15360000.000000,
* pll2_x2: 384000000.000000, pll2_out: 192000000.000000
- ldr r0, =SYSCON_CLKSET2
24 << SYSCON_CLKSET_PLL_X2FBD2_SHIFT | \
24 << SYSCON_CLKSET_PLL_X1FBD1_SHIFT | \
1 << SYSCON_CLKSET_PLL_PS_SHIFT | \
SYSCON_CLKSET2_PLL2_EN | \
SYSCON_CLKSET2_NBYP2 | \
3 << SYSCON_CLKSET2_USB_DIV_SHIFT)
- str r1, [r0]
- /* the user's guide recommends to wait at least 1 ms for PLL2 to
* stabilize, but Cirrus' Redboot doesn't do that, either
- mov pc, lr
diff --git a/board/edb93xx/sdram_cfg.S b/board/edb93xx/sdram_cfg.S new file mode 100644 index 0000000..752bb72 --- /dev/null +++ b/board/edb93xx/sdram_cfg.S @@ -0,0 +1,217 @@ +/*
- SDRAM setup for edb93xx boards
- project.
- MA 02111-1307 USA
+/* delay for 200us
- loop takes 4 cycles at 5.0ns (worst case, running at 200MHz)
- per cycle = 20ns, 0x3000 (12288) gives us 246us to be safe
+.macro delay200
- ldr r0, =0x3000
+200:
- subs r0, r0, #1
- bne 200b
+.endm
+.globl sdram_cfg +sdram_cfg:
+#ifdef CONFIG_EDB93XX_SDCS0
- ldr r1, =SDRAM_DEVCFG0
+#elif defined(CONFIG_EDB93XX_SDCS3)
- ldr r1, =SDRAM_DEVCFG3
+#else +#error "SDRAM bank configuration" +#endif
Good.
+#if defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) ||\
- /* 1x Samsung K4S561632C-TC/L75 4M x 16bit x 4 banks SDRAM
* CLK cycle time min:
* @ CAS latency = 3: 7.5ns
* @ CAS latency = 2: 10ns
* We're running at 66MHz (15ns cycle time) external bus speed (HCLK),
* so it's safe to use CAS latency = 2
* RAS-to-CAS delay min:
* 20ns
* At 15ns cycle time, we use RAS-to-CAS delay = 2
* SROMLL = 1: Swap BA[1:0] with A[13:12], making the SDRAM appear
* as four blocks of 8MB size, instead of eight blocks of 4MB size:
* EDB9301/EDB9302:
* 0x00000000 - 0x007fffff
* 0x01000000 - 0x017fffff
* 0x04000000 - 0x047fffff
* 0x05000000 - 0x057fffff
* EDB9302a:
* 0xc0000000 - 0xc07fffff
* 0xc1000000 - 0xc17fffff
* 0xc4000000 - 0xc47fffff
* 0xc5000000 - 0xc57fffff
* BANKCOUNT = 1: This is a device with four banks
- ldr r0, =(SDRAM_DEVCFG_BANKCOUNT | SDRAM_DEVCFG_SROMLL |\
SDRAM_DEVCFG_CASLAT_2 | SDRAM_DEVCFG_RASTOCAS_2 |\
SDRAM_DEVCFG_EXTBUSWIDTH)
- /* 2x Samsung K4S561632C-TC/L75 4M x 16bit x 4 banks SDRAM
* We're running at 100MHz (10ns cycle time) external bus speed (HCLK),
* 20ns
* At 10ns cycle time, we use RAS-to-CAS delay = 2
* EDB9307, EDB9312, EDB9315:
* 0x00000000 - 0x01ffffff
* 0x04000000 - 0x05ffffff
* EDB9307a, EDB9315a:
* 0xc0000000 - 0xc1ffffff
* 0xc4000000 - 0xc5ffffff
SDRAM_DEVCFG_CASLAT_2 | SDRAM_DEVCFG_RASTOCAS_2)
- str r0, [r1]
- /* Issue continous NOP commands */
- ldr r1, =SDRAM_GLCONFIG
- ldr r0, =(GLCONFIG_INIT | GLCONFIG_MRS | GLCONFIG_CKE)
- str r0, [r1]
- delay200
+#if defined(CONFIG_EP9301) || defined(CONFIG_EP9302)
- /* Errata for EP9301/2 rev. E0 says that PRECHARGE ALL isn't always
* issued.
* Do a read from each bank to make sure they're precharged
* Logical address bits A[22:21] map to BA[1:0] (SROMLL is set)
* The errata further says that this isn't going to be fixed,
* therefor do it for all revisions
- ldr r0, =(GLCONFIG_CKE)
- str r0, [r1] /* SDRAM_GLCONFIG */
- ldr r0, =0x00000000 /* A[22:21] = b00 */
- str r0, [r0]
- ldr r0, =0x00200000 /* A[22:21] = b01 */
- str r0, [r0]
- ldr r0, =0x00400000 /* A[22:21] = b10 */
- str r0, [r0]
- ldr r0, =0x00600000 /* A[22:21] = b11 */
- str r0, [r0]
- /* Load refresh timer with 10 to issue refresh every 10 cycles */
- ldr r1, =SDRAM_REFRSHTIMR
- ldr r0, =0x0a
- str r0, [r1]
- /* Wait at least 80 clock cycles to provide 8 refresh cycles
to all SDRAMs */
- delay200 /* we wait 200us, which is a lot more than necessary */
- /* Program refresh timer with normal value
* We need 8192 refresh cycles every 64ms
* at 15ns (HCLK >= 66MHz) per cycle:
* 64ms / 8192 = 7.8125us
* 7.8125us / 15ns = 520 (0x208)
- /* TODO: redboot uses 0x1e0 for the slowest possible device
but i don't understand how this value is calculated */
- ldr r0, =0x208
- str r0, [r1]
Extra space
- /* Select mode register update mode */
- ldr r0, =(GLCONFIG_CKE | GLCONFIG_MRS)
- str r0, [r1]
- /* Program mode register
* A[22:09] is output as SYA[13:0] on a 16 bit ext. bus
* CAS latency: 2
* Burst type: sequential
* Burst length: 8 (required for 16 bit ext. bus)
* SYA[13:0] = 0x0023
- ldr r0, =0x00004600
- ldr r0, [r0]
It may be better to structure this as #if sdc3 #if ep9301 || ep9302 /* Comment explaining why this is handled differently */ # else /* Normal sdc3 */ #endif #else /* sdc0 */
#endif
- ldr r0, =0x00008800
- ldr r0, [r0]
- ldr r0, [r0]
- ldr r0, =0x00808800
- ldr r0, [r0]
- ldr r0, =0x00c08800
- ldr r0, [r0]
+#else
- ldr r0, [r0]
- ldr r0, =0xc0400000
- ldr r0, [r0]
- ldr r0, =0xc0808800
- ldr r0, [r0]
- ldr r0, =0xc0c08800
- ldr r0, [r0]
- /* Select normal operation mode */
- str r0, [r1]
- mov pc, lr
diff --git a/board/edb93xx/u-boot.lds b/board/edb93xx/u-boot.lds new file mode 100644 index 0000000..76caef3 --- /dev/null +++ b/board/edb93xx/u-boot.lds @@ -0,0 +1,59 @@ +/*
- Gary Jennejohn, DENX Software Engineering, gj@denx.de
- project.
- MA 02111-1307 USA
+OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +/*OUTPUT_FORMAT("elf32-arm", "elf32-arm", "elf32-arm")*/ +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{
- . = 0x00000000;
- . = ALIGN(4);
- .text :
cpu/arm920t/start.o (.text)
. = 0x1000;
LONG(0x53555243)
*(.text)
- . = ALIGN(4);
- .rodata : { *(.rodata) }
- . = ALIGN(4);
- .data : { *(.data) }
- . = ALIGN(4);
- .got : { *(.got) }
- __u_boot_cmd_start = .;
- .u_boot_cmd : { *(.u_boot_cmd) }
- __u_boot_cmd_end = .;
- . = ALIGN(4);
- __bss_start = .;
- .bss : { *(.bss) }
- _end = .;
+} diff --git a/cpu/arm920t/ep93xx/Makefile b/cpu/arm920t/ep93xx/Makefile new file mode 100644 index 0000000..9763e15 --- /dev/null +++ b/cpu/arm920t/ep93xx/Makefile @@ -0,0 +1,55 @@ +# vim: set ts=8 sw=8 noet: +# +# Cirrus Logic EP93xx CPU-specific Makefile +# +# Copyright (C) 2004, 2005 +# Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com +# +# Copyright (C) 2006 +# Dominic Rath Dominic.Rath@gmx.de +# +# Based on an original Makefile, which is +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this project. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, but +# WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY +# or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +# for more details. +# +# You should have received a copy of the GNU General Public License along +# with this program; if not, write to the Free Software Foundation, Inc., +# 675 Mass Ave, Cambridge, MA 02139, USA. +# +include $(TOPDIR)/config.mk
+LIB = $(obj)lib$(SOC).a
+COBJS = cpu.o eth.o timer.o speed.o +SOBJS = lowlevel_init.o
+SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS))
+all: $(obj).depend $(LIB)
+$(LIB): $(OBJS)
diff --git a/cpu/arm920t/ep93xx/cpu.c b/cpu/arm920t/ep93xx/cpu.c new file mode 100644 index 0000000..3989ee8 --- /dev/null +++ b/cpu/arm920t/ep93xx/cpu.c @@ -0,0 +1,125 @@ +/* vim: set ts=8 sw=8 noet:
Remove vim comment Apply globally.
- Cirrus Logic EP93xx CPU-specific support.
- Copyright (C) 2004, 2005
- Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com
- See file CREDITS for list of people who contributed to this project.
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- This program is distributed in the hope that it will be useful, but
- WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY
- or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
- for more details.
- You should have received a copy of the GNU General Public License along
- with this program; if not, write to the Free Software Foundation, Inc.,
- 675 Mass Ave, Cambridge, MA 02139, USA.
+#include <common.h>
+#if defined(CONFIG_EP93XX) +#include <asm/arch/ep93xx.h> +#include <asm/io.h>
+/* The errata for silicon revision E1 states that the PartID of the
- ExtensionID register is not programmed, and that this feature has been
- removed from the chip.
- Note also that the chip revision indication found in the CHIP_ID register
- (0x80930094) has proven reliable for determining a particular core's
- silicon version.
+extern int checkcpu(void) +{
This function is not used.
- const uint32_t chip_id = readl(SYSCON_CHIPID);
- printf("CPU: Cirrus Logic EP93xx");
- printf(" - Rev. ");
- switch (chip_id & SYSCON_CHIPID_REV_MASK) {
- case 0x00000000:
printf("A");
break;
- case 0x10000000:
printf("B");
break;
- case 0x20000000:
printf("C");
break;
- case 0x30000000:
printf("D0");
break;
- case 0x40000000:
printf("D1");
break;
- case 0x50000000:
printf("E0");
break;
- default:
printf("?");
break;
+/* All EP93xx variants have 16 KiB I-cache. */ +extern int checkicache(void) +{
This function is not used either. Please check for unused functions and remove if unneeded.
- return 16 << 10;
+/* All EP93xx variants have 16 KiB D-cache. */ +extern int checkdcache(void) +{
- return 16 << 10;
+/* This is a nop on ARM, and is included here for completeness only. */ +extern void upmconfig(unsigned int upm, unsigned int *table, unsigned int size) +{
- /* nop */
/* noop */
+/* We reset the CPU by generating a 1-->0 transition on DeviceCfg bit 31. */ +extern void reset_cpu(ulong addr) +{
- uint32_t value;
- /* Unlock DeviceCfg and set SWRST */
- writel(0xAA, SYSCON_SYSSWLOCK);
- value = readl(SYSCON_DEVICECFG);
- value |= SYSCON_DEVICECFG_SWRST;
- writel(value, SYSCON_DEVICECFG);
- /* Unlock DeviceCfg and clear SWRST */
- value &= ~SYSCON_DEVICECFG_SWRST;
- /* Dying... */
- while (1)
; /* nop */
+#endif /* defined(CONFIG_EP93XX) */ diff --git a/cpu/arm920t/ep93xx/eth.c b/cpu/arm920t/ep93xx/eth.c new file mode 100644 index 0000000..513c221 --- /dev/null +++ b/cpu/arm920t/ep93xx/eth.c @@ -0,0 +1,876 @@ +/* vim: set ts=8 sw=8 noet:
- Cirrus Logic EP93xx ethernet MAC / MII driver.
- Based on the original eth.[ch] Cirrus Logic EP93xx Rev D. Ethernet Driver,
- which is
- Adam Bezanson, Network Audio Technologies, Inc.
- for more details.
+#include <command.h> +#include <common.h> +#include <asm/arch/ep93xx.h> +#include <asm/io.h> +#include <malloc.h> +#include <miiphy.h> +#include <net.h> +#include <linux/types.h>
- Send an error message to the terminal.
+#define ERROR(x) \
- do { \
char *__foo = strrchr(__FILE__, '/'); \
printf("%s: %d: %s(): ", \
(__foo == NULL ? __FILE__ : (__foo + 1)), \
__LINE__, __func__); \
printf x; printf("\n"); \
- } while (0);
Use the existing debug macros in common.h See #define debug Apply changes globally
- Send a trace message to the terminal.
+#if 0 +#define TRACE(x) \
- do { \
- } while (0);
+#else +#define TRACE(x) +#endif
- EP93xx ethernet MAC functionality
+#if defined(CONFIG_DRIVER_EP93XX_MAC)
- #define this to dump device status and queue info during initialization and
- following errors.
+#undef EP93XX_MAC_DEBUG
- Number of descriptor and status entries in our RX queues.
- It must be power of 2 !
+#define NUMRXDESC PKTBUFSRX
- Number of descriptor and status entries in our TX queues.
+#define NUMTXDESC 1
- 944 = (1024 - 64) - 16, Fifo size - Minframesize - 16 (Chip FACT)
+#define TXSTARTMAX 944
- Ethernet MAC interface return values for public functions.
+enum eth_status {
- ETH_STATUS_SUCCESS = 0,
- ETH_STATUS_FAILURE = 1,
- Receive descriptor queue entry
+struct rx_descriptor {
- union {
uint32_t word1;
struct {
unsigned buffer_address:32;
- union {
uint32_t word2;
struct {
unsigned buffer_length:16;
unsigned buffer_index:15;
unsigned not_sof:1;
+} __attribute__((packed));
- Receive status queue entry
+struct rx_status {
- union {
uint32_t word1;
struct {
unsigned:8;
unsigned hti:6;
unsigned:1;
unsigned crci:1;
unsigned crce:1;
unsigned edata:1;
unsigned runt:1;
unsigned fe:1;
unsigned oe:1;
unsigned rx_err:1;
unsigned am:2;
unsigned:4;
unsigned eob:1;
unsigned eof:1;
unsigned rwe:1;
unsigned rfp:1;
- union {
uint32_t word2;
struct {
unsigned frame_length:16;
unsigned rfp:1;
- Transmit descriptor queue entry
+struct tx_descriptor {
- union {
uint32_t word1;
struct {
- union {
uint32_t word2;
struct {
unsigned buffer_length:12;
unsigned:3;
unsigned abort_frame:1;
unsigned eof:1;
- Transmit status queue entry
+struct tx_status {
- union {
uint32_t word1;
struct {
unsigned tbi:15;
unsigned:1;
unsigned ncoll:5;
unsigned:3;
unsigned ecoll:1;
unsigned txu:1;
unsigned ow:1;
unsigned:1;
unsigned lcrs:1;
unsigned fa:1;
unsigned txwe:1;
unsigned txfp:1;
+struct tx_descriptor_queue {
- struct tx_descriptor *base;
- struct tx_descriptor *current;
- struct tx_descriptor *end;
+struct tx_status_queue {
- struct tx_status *base;
- struct tx_status *current;
- struct tx_status *end;
+struct rx_descriptor_queue {
- struct rx_descriptor *base;
- struct rx_descriptor *current;
- struct rx_descriptor *end;
+struct rx_status_queue {
- struct rx_status *base;
- struct rx_status *current;
- struct rx_status *end;
- EP93xx MAC private data structure
+struct ep93xx_mac {
- int is_initialized;
- struct rx_descriptor_queue rx_dq;
- struct rx_status_queue rx_sq;
- void *rx_buffer[NUMRXDESC];
- struct tx_descriptor_queue tx_dq;
- struct tx_status_queue tx_sq;
+/* ep93xx_miiphy ops forward declarations */ +static int ep93xx_miiphy_read(char * const dev, unsigned char const addr,
unsigned char const reg, unsigned short * const value);
+static int ep93xx_miiphy_write(char * const dev, unsigned char const addr,
unsigned char const reg, unsigned short const value);
+/* Reserve memory for the MAC's private data */ +static struct ep93xx_mac dev = { 0 };
- Dump ep93xx_mac values to the terminal.
+inline void dump_dev(void) +{ +#if defined(EP93XX_MAC_DEBUG)
- int i;
- printf("\ndump_dev()\n");
- printf(" is_initialized %02X\n", dev.is_initialized);
- printf(" rx_dq.base %08X\n", dev.rx_dq.base);
- printf(" rx_dq.current %08X\n", dev.rx_dq.current);
- printf(" rx_dq.end %08X\n", dev.rx_dq.end);
- printf(" rx_sq.base %08X\n", dev.rx_sq.base);
- printf(" rx_sq.current %08X\n", dev.rx_sq.current);
- printf(" rx_sq.end %08X\n", dev.rx_sq.end);
- for (i = 0; i < NUMRXDESC; i++)
printf(" rx_buffer[%2.d] %08X\n", i, NetRxPackets[i]);
- printf(" tx_dq.base %08X\n", dev.tx_dq.base);
- printf(" tx_dq.current %08X\n", dev.tx_dq.current);
- printf(" tx_dq.end %08X\n", dev.tx_dq.end);
- printf(" tx_sq.base %08X\n", dev.tx_sq.base);
- printf(" tx_sq.current %08X\n", dev.tx_sq.current);
- printf(" tx_sq.end %08X\n", dev.tx_sq.end);
+#endif /* defined(EP93XX_MAC_DEBUG) */ +}
- Dump all RX descriptor queue entries to the terminal.
+inline void dump_rx_descriptor_queue(void) +{ +#if defined(EP93XX_MAC_DEBUG)
- int i;
- printf("\ndump_rx_descriptor_queue()\n");
- printf(" descriptor address word1 word2\n");
- for (i = 0; i < NUMRXDESC; i++) {
printf(" [ %08X ] %08X %08X\n",
(dev.rx_dq.base + i),
(dev.rx_dq.base + i)->word1,
(dev.rx_dq.base + i)->word2);
- Dump all RX status queue entries to the terminal.
+inline void dump_rx_status_queue(void) +{ +#if defined(EP93XX_MAC_DEBUG)
- int i;
- printf("\ndump_rx_status_queue()\n");
(dev.rx_sq.base + i),
(dev.rx_sq.base + i)->word1,
(dev.rx_sq.base + i)->word2);
- Dump all TX descriptor queue entries to the terminal.
+inline void dump_tx_descriptor_queue(void) +{ +#if defined(EP93XX_MAC_DEBUG)
- int i;
- printf("\ndump_tx_descriptor_queue()\n");
- for (i = 0; i < NUMTXDESC; i++) {
(dev.tx_dq.base + i),
(dev.tx_dq.base + i)->word1,
(dev.tx_dq.base + i)->word2);
- Dump all TX status queue entries to the terminal.
+inline void dump_tx_status_queue(void) +{ +#if defined(EP93XX_MAC_DEBUG)
- int i;
- printf("\ndump_tx_status_queue()\n");
- printf(" descriptor address word1\n");
printf(" [ %08X ] %08X\n",
(dev.rx_sq.base + i)->word1);
- Reset the EP93xx MAC by twiddling the soft reset bit and spinning until
- it's cleared.
+static void ep93xx_mac_reset(void) +{
- TRACE(("+ep93xx_mac_reset"));
- uint32_t value = readl(MAC_SELFCTL);
- value |= SELFCTL_RESET;
- writel(value, MAC_SELFCTL);
- while (readl(MAC_SELFCTL) & SELFCTL_RESET)
; /* nop */
- TRACE(("-ep93xx_mac_reset"));
- Halt EP93xx MAC transmit and receive by clearing the TxCTL and RxCTL
- registers.
+extern void eth_halt(void) +{
- TRACE(("+eth_halt"));
- writel(0x00000000, MAC_RXCTL);
- writel(0x00000000, MAC_TXCTL);
- TRACE(("-eth_halt"));
+#if defined(CONFIG_MII) +int ep93xx_miiphy_initialize(bd_t * const bd) +{
- miiphy_register("ep93xx_eth0", ep93xx_miiphy_read, ep93xx_miiphy_write);
+} +#endif
- Initialize the EP93xx MAC. The MAC hardware is reset. Buffers are
- allocated, if necessary, for the TX and RX descriptor and status queues,
- as well as for received packets. The EP93XX MAC hardware is initialized.
- Transmit and receive operations are enabled.
+extern int eth_init(bd_t * const bd) +{
- int ret = ETH_STATUS_FAILURE;
- int i;
- uchar enetaddr[6];
- TRACE(("+eth_init"));
- /* Parameter check */
- if (bd == NULL) {
ERROR(("NULL bd"));
goto eth_init_failed_0;
- /* Reset the MAC */
- ep93xx_mac_reset();
- /* Allocate space for the queues and RX packet buffers if we're not
* already initialized */
- if (!dev.is_initialized) {
dev.tx_dq.base = calloc(NUMTXDESC,
sizeof(struct tx_descriptor));
if (dev.tx_dq.base == NULL) {
ERROR(("calloc() failed"));
dev.tx_sq.base = calloc(NUMTXDESC,
sizeof(struct tx_status));
if (dev.tx_sq.base == NULL) {
goto eth_init_failed_1;
dev.rx_dq.base = calloc(NUMRXDESC,
sizeof(struct rx_descriptor));
if (dev.rx_dq.base == NULL) {
goto eth_init_failed_2;
dev.rx_sq.base = calloc(NUMRXDESC,
sizeof(struct rx_status));
if (dev.rx_sq.base == NULL) {
goto eth_init_failed_3;
/* Set is_initialized flag so we don't go through allocation
* portion of init again. */
dev.is_initialized = 1;
- /* Reset the descriptor queues' current and end address values */
- dev.tx_dq.current = dev.tx_dq.base;
- dev.tx_dq.end = (dev.tx_dq.base + NUMTXDESC);
- dev.tx_sq.current = dev.tx_sq.base;
- dev.tx_sq.end = (dev.tx_sq.base + NUMTXDESC);
- dev.rx_dq.current = dev.rx_dq.base;
- dev.rx_dq.end = (dev.rx_dq.base + NUMRXDESC);
- dev.rx_sq.current = dev.rx_sq.base;
- dev.rx_sq.end = (dev.rx_sq.base + NUMRXDESC);
- /* Set the transmit descriptor and status queues' base address,
* current address, and length registers. Set the maximum frame
* length and threshold. Enable the transmit descriptor processor. */
- writel((uint32_t)dev.tx_dq.base, MAC_TXDQBADD);
- writel((uint32_t)dev.tx_dq.base, MAC_TXDQCURADD);
- writel(sizeof(struct tx_descriptor) * NUMTXDESC, MAC_TXDQBLEN);
- writel((uint32_t)dev.tx_sq.base, MAC_TXSTSQBADD);
- writel((uint32_t)dev.tx_sq.base, MAC_TXSTSQCURADD);
- writel(sizeof(struct tx_status) * NUMTXDESC, MAC_TXSTSQBLEN);
- writel(0x00040000, MAC_TXDTHRSHLD);
- writel(0x00040000, MAC_TXSTSTHRSHLD);
- writel((TXSTARTMAX << 0) | (PKTSIZE_ALIGN << 16), MAC_MAXFRMLEN);
- writel(BMCTL_TXEN, MAC_BMCTL);
- /* Set the receive descriptor and status queues' base address,
* current address, and length registers. Enable the receive
* descriptor processor. */
- writel((uint32_t)dev.rx_dq.base, MAC_RXDQBADD);
- writel((uint32_t)dev.rx_dq.base, MAC_RXDQCURADD);
- writel(sizeof(struct rx_descriptor) * NUMRXDESC, MAC_RXDQBLEN);
- writel((uint32_t)dev.rx_sq.base, MAC_RXSTSQBADD);
- writel((uint32_t)dev.rx_sq.base, MAC_RXSTSQCURADD);
- writel(sizeof(struct rx_status) * NUMRXDESC, MAC_RXSTSQBLEN);
- writel(0x00040000, MAC_RXDTHRSHLD);
- writel(BMCTL_RXEN, MAC_BMCTL);
- writel(0x00040000, MAC_RXSTSTHRSHLD);
- /* Wait until the receive descriptor processor is active */
- while (!(readl(MAC_BMSTS) & BMSTS_RXACT))
; /* nop */
- /* Initialize the RX descriptor queue. Clear the TX descriptor queue.
* Clear the RX and TX status queues. Enqueue the RX descriptor and
* status entries to the MAC. */
(dev.rx_dq.base + i)->buffer_address =
(uint32_t)NetRxPackets[i];
(dev.rx_dq.base + i)->buffer_length = PKTSIZE_ALIGN;
(dev.rx_dq.base + i)->buffer_index = 0;
- memset(dev.tx_dq.base, 0, (sizeof(struct tx_descriptor) * NUMTXDESC));
- memset(dev.rx_sq.base, 0, (sizeof(struct rx_status) * NUMRXDESC));
- memset(dev.tx_sq.base, 0, (sizeof(struct tx_status) * NUMTXDESC));
- writel(NUMRXDESC, MAC_RXDENQ);
- writel(NUMRXDESC, MAC_RXSTSENQ);
- /* Set the primary MAC address */
- writel(AFP_IAPRIMARY, MAC_AFP);
- eth_getenv_enetaddr("ethaddr", enetaddr);
- writel(enetaddr[0] | (enetaddr[1] << 8) |
(enetaddr[2] << 16) | (enetaddr[3] << 24),
MAC_INDAD);
- writel(enetaddr[4] | (enetaddr[5] << 8), MAC_INDAD_UPPER);
- /* Turn on RX and TX */
- writel(RXCTL_IA0 | RXCTL_BA | RXCTL_SRXON |
RXCTL_RCRCA | RXCTL_MA, MAC_RXCTL);
- writel(TXCTL_STXON, MAC_TXCTL);
- /* Dump data structures if we're debugging */
- dump_dev();
- dump_rx_descriptor_queue();
- dump_rx_status_queue();
- dump_tx_descriptor_queue();
- dump_tx_status_queue();
- /* Done! */
- ret = ETH_STATUS_SUCCESS;
- goto eth_init_done;
- free(dev.rx_sq.base);
- /* Fall through */
+eth_init_failed_3:
- free(dev.rx_dq.base);
+eth_init_failed_2:
- free(dev.tx_sq.base);
+eth_init_failed_1:
- free(dev.tx_dq.base);
+eth_init_failed_0: +eth_init_done:
- TRACE(("-eth_init %d", ret));
- return ret;
- Copy a frame of data from the MAC into the protocol layer for further
- processing.
- TODO: Enhance this to deal with as many packets as are available at
- the MAC at one time? */
+extern int eth_rx(void) +{
- TRACE(("+eth_rx"));
- if (dev.rx_sq.current->rfp) {
if (dev.rx_sq.current->rwe) {
/* We have a good frame. Extract the frame's length
* from the current rx_status_queue entry, and copy
* the frame's data into NetRxPackets[] of the
* protocol stack. We track the total number of
* bytes in the frame (nbytes_frame) which will be
* used when we pass the data off to the protocol
* layer via NetReceive(). */
NetReceive((uchar *)dev.rx_dq.current->buffer_address,
dev.rx_sq.current->frame_length);
TRACE(("reporting %d bytes...\n",
dev.rx_sq.current->frame_length));
} else {
/* Do we have an erroneous packet? */
ERROR(("packet rx error, status %08X %08X",
dev.rx_sq.current->word1,
dev.rx_sq.current->word2));
/* Clear the associated status queue entry, and
* increment our current pointers to the next RX
* descriptor and status queue entries (making sure
* we wrap properly). */
memset(dev.rx_sq.current, 0, sizeof(struct rx_status));
dev.rx_sq.current++;
if (dev.rx_sq.current >= dev.rx_sq.end)
dev.rx_dq.current++;
if (dev.rx_dq.current >= dev.rx_dq.end)
/* Finally, return the RX descriptor and status entries
* back to the MAC engine, and loop again, checking for
* more descriptors to process. */
writel(1, MAC_RXDENQ);
writel(1, MAC_RXSTSENQ);
- } else {
- TRACE(("-eth_rx %d", ret));
- return ret;
- Send a block of data via ethernet.
- TODO: Enhance this to deal with as much data as are available at one time? */
+extern int eth_send(volatile void * const packet, int const length) +{
- TRACE(("+eth_send"));
- if (packet == NULL) {
ERROR(("NULL packet"));
goto eth_send_failed_0;
- /* Initialize the TX descriptor queue with the new packet's info.
* Clear the associated status queue entry. Enqueue the packet
* to the MAC for transmission. */
- dev.tx_dq.current->buffer_address = (uint32_t)packet;
- dev.tx_dq.current->buffer_length = length;
- dev.tx_dq.current->buffer_index = 0;
- dev.tx_dq.current->eof = 1;
- dev.tx_sq.current->word1 = 0;
- writel(1, MAC_TXDENQ);
- /* Wait for TX to complete, and check status entry for errors. */
- while (!(readl(MAC_INTSTSC) & INTSTS_TXSQ))
; /* nop */
- if (!dev.tx_sq.current->txfp || !dev.tx_sq.current->txwe) {
ERROR(("packet tx error, status %08X",
dev.tx_sq.current->word1));
/* TODO: Add better error handling? */
+eth_send_failed_0:
- TRACE(("-eth_send %d", ret));
- return ret;
+} +#endif /* defined(CONFIG_DRIVER_EP93XX_MAC) */
- EP93xx ethernet MII functionality.
- Maximum MII address we support
+#define MII_ADDRESS_MAX (31)
- Maximum MII register address we support
+#define MII_REGISTER_MAX (31)
- Ethernet MII interface return values for public functions.
+enum mii_status {
- MII_STATUS_SUCCESS = 0,
- MII_STATUS_FAILURE = 1,
- Read a 16-bit value from an MII register.
- int ret = MII_STATUS_FAILURE;
- uint32_t self_ctl;
- TRACE(("+ep93xx_miiphy_read"));
- /* Parameter checks */
- if (dev == NULL) {
ERROR(("NULL dev"));
goto ep93xx_miiphy_read_failed_0;
- if (addr > MII_ADDRESS_MAX) {
ERROR(("invalid addr, 0x%02X", addr));
- if (reg > MII_REGISTER_MAX) {
ERROR(("invalid reg, 0x%02X", reg));
- if (value == NULL) {
ERROR(("NULL value"));
- /* Save the current SelfCTL register value. Set MAC to suppress
* preamble bits. Wait for any previous MII command to complete
* before issuing the new command. */
- self_ctl = MAC_SELFCTL;
+#if defined(CONFIG_MII_SUPPRESS_PREAMBLE)
- writel(self_ctl & ~(1 << 8), MAC_SELFCTL);
+#endif /* defined(CONFIG_MII_SUPPRESS_PREAMBLE) */
- while (readl(MAC_MIISTS) & MIISTS_BUSY)
; /* nop */
- /* Issue the MII 'read' command. Wait for the command to complete.
* Read the MII data value. */
- writel(MIICMD_OPCODE_READ | ((uint32_t)addr << 5) | (uint32_t)reg,
MAC_MIICMD);
; /* nop */
- *value = (unsigned short)readl(MAC_MIIDATA);
- /* Restore the saved SelfCTL value and return. */
- writel(self_ctl, MAC_SELFCTL);
- ret = MII_STATUS_SUCCESS;
+ep93xx_miiphy_read_failed_0:
- TRACE(("-ep93xx_miiphy_read"));
- return ret;
- Write a 16-bit value to an MII register.
- TRACE(("+ep93xx_miiphy_write"));
goto ep93xx_miiphy_write_failed_0;
- self_ctl = readl(MAC_SELFCTL);
; /* nop */
- /* Issue the MII 'write' command. Wait for the command to complete. */
- writel((uint32_t)value, MAC_MIIDATA);
- writel(MIICMD_OPCODE_WRITE | ((uint32_t)addr << 5) | (uint32_t)reg,
MAC_MIICMD);
; /* nop */
+ep93xx_miiphy_write_failed_0:
- TRACE(("-ep93xx_miiphy_write"));
- return ret;
+} +#endif /* defined(CONFIG_MII) */ diff --git a/cpu/arm920t/ep93xx/lowlevel_init.S b/cpu/arm920t/ep93xx/lowlevel_init.S new file mode 100644 index 0000000..34a2100 --- /dev/null +++ b/cpu/arm920t/ep93xx/lowlevel_init.S @@ -0,0 +1,74 @@ +/*
- Low-level initialization for EP93xx
- project.
- MA 02111-1307 USA
+#include <version.h> +#include <asm/arch/ep93xx.h>
+.globl lowlevel_init +lowlevel_init:
- /* Turn on both LEDs */
- ldr r1, =GPIO_PEDR
- ldr r0, [r1]
- orr r0, r0, #(0x1 | 0x2)
- str r0, [r1]
- /* backup return address */
- ldr r1, =SYSCON_SCRATCH0
- str lr, [r1]
- /* Configure flash wait states before we switch to the PLL */
- bl flash_cfg
- /* Set up PLL */
- bl pll_cfg
- /* Turn off the Green LED and leave the Red LED on */
- ldr r0, [r1]
- bic r0, r0, #(0x1)
- str r0, [r1]
- /* Setup SDRAM */
- bl sdram_cfg
- /* Turn on Green LED, Turn off the Red LED */
- ldr r0, [r1]
- bic r0, r0, #(0x2)
- orr r0, r0, #(0x1)
- str r0, [r1]
- /* FIXME: we use async mode for now */
- mrc p15, 0, r0, c1, c0, 0
- orr r0, r0, #0xc0000000
- mcr p15, 0, r0, c1, c0, 0
- /* restore return address */
- ldr lr, [r1]
- mov pc, lr
diff --git a/cpu/arm920t/ep93xx/speed.c b/cpu/arm920t/ep93xx/speed.c new file mode 100644 index 0000000..cc32ec7 --- /dev/null +++ b/cpu/arm920t/ep93xx/speed.c @@ -0,0 +1,120 @@ +/* vim: set ts=8 sw=8 noet:
- Cirrus Logic EP93xx PLL support.
- Based on the S3C24x0 speed.c, which is
- (C) Copyright 2001-2002
- Wolfgang Denk, DENX Software Engineering, wd@denx.de
- David Mueller, ELSOFT AG, d.mueller@elsoft.ch
- for more details.
+#include <common.h> +#include <asm/arch/ep93xx.h> +#include <asm/io.h> +#include <div64.h>
+/* ------------------------------------------------------------------------- */ +/* NOTE: This describes the proper use of this file.
- CONFIG_SYS_CLK_FREQ should be defined as the input frequency of the PLL.
- get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of
- the specified bus in HZ.
+static char fclk_divisors[] = { 1, 2, 4, 8, 16, 1, 1, 1 }; +static char hclk_divisors[] = { 1, 2, 4, 5, 6, 8, 16, 32 }; +static char pclk_divisors[] = { 1, 2, 4, 8 };
+/* return the PLL output frequency */ +/* PLL rate = CONFIG_SYS_CLK_FREQ * (X1FBD + 1) * (X2FBD + 1)
- / (X2IPD + 1) / 2^PS
+static ulong get_PLLCLK(int pllreg) +{
- uint8_t i;
- const uint32_t clkset = readl(pllreg);
- uint64_t rate = CONFIG_SYS_CLK_FREQ;
Return is 32, you are likely getting a compiler warning.
- rate *= ((clkset >> SYSCON_CLKSET_PLL_X1FBD1_SHIFT) & 0x1f) + 1;
- rate *= ((clkset >> SYSCON_CLKSET_PLL_X2FBD2_SHIFT) & 0x3f) + 1;
- do_div(rate, (clkset & 0x1f) + 1); /* X2IPD */
- for (i = 0; i < ((clkset >> SYSCON_CLKSET_PLL_PS_SHIFT) & 3); i++)
rate >>= 1;
- return rate;
+/* return FCLK frequency */ +ulong get_FCLK() +{
- const uint32_t clkset1 = readl(SYSCON_CLKSET1);
- const uint8_t fclk_div =
fclk_divisors[(clkset1 >> SYSCON_CLKSET1_FCLK_DIV_SHIFT) & 0x7];
- const ulong fclk_rate = get_PLLCLK(SYSCON_CLKSET1) / fclk_div;
- return fclk_rate;
+/* return HCLK frequency */ +ulong get_HCLK(void) +{
- const uint8_t hclk_div =
hclk_divisors[(clkset1 >> SYSCON_CLKSET1_HCLK_DIV_SHIFT) & 0x7];
- const ulong hclk_rate = get_PLLCLK(SYSCON_CLKSET1) / hclk_div;
- return hclk_rate;
+/* return PCLK frequency */ +ulong get_PCLK(void) +{
- const uint8_t pclk_div =
pclk_divisors[(clkset1 >> SYSCON_CLKSET1_PCLK_DIV_SHIFT) & 0x3];
- const ulong pclk_rate = get_HCLK() / pclk_div;
- return pclk_rate;
+/* return UCLK frequency */ +ulong get_UCLK(void) +{
- ulong uclk_rate;
- const uint32_t value = readl(SYSCON_PWRCNT);
- if (value & SYSCON_PWRCNT_UART_BAUD)
uclk_rate = CONFIG_SYS_CLK_FREQ;
- else
uclk_rate = CONFIG_SYS_CLK_FREQ / 2;
- return uclk_rate;
+} diff --git a/cpu/arm920t/ep93xx/timer.c b/cpu/arm920t/ep93xx/timer.c new file mode 100644 index 0000000..28660d0 --- /dev/null +++ b/cpu/arm920t/ep93xx/timer.c @@ -0,0 +1,163 @@ +/* vim: set ts=8 sw=8 noet:
- Cirrus Logic EP93xx interrupt support.
- Based on the original intr.c Cirrus Logic EP93xx Rev D. interrupt support,
- author unknown.
- for more details.
+#if defined(CONFIG_EP93XX) +#include <linux/types.h> +#include <asm/arch/ep93xx.h> +#include <asm/io.h>
Extra space. Please reduce double empty lines to single empty lines Apply globally
+static int timer_load_val;
+/* macro to read the 16 bit timer */ +static inline ulong READ_TIMER(void)
Lowercase function names Apply globally
- return readl(TIMER1_VALUE) & 0xffff;
+static ulong timestamp; +static ulong lastdec;
+int timer_init(void) +{
- /* use timer 1 with 2KHz and free running */
- writel(0x00, TIMER1_CONTROL);
- if (timer_load_val == 0) {
* for 10 ms clock period @ PCLK with 4 bit divider = 1/2
* (default) and prescaler = 16. Should be 10390
* @33.25MHz and 15625 @ 50 MHz
/* set to constant just now, until I resolve clocking issues */
timer_load_val = 21;
Clean up this comment. Explain the problem.
- /* auto load, manual update of Timer 1 */
- lastdec = timer_load_val;
- writel(timer_load_val, TIMER1_LOAD);
- /* Enable the timer and periodic mode */
- writel(0xC0, TIMER1_CONTROL);
- timer without interrupts
+void reset_timer(void) +{
- reset_timer_masked();
+ulong get_timer(ulong base) +{
- return get_timer_masked() - base;
+void set_timer(ulong t) +{
- timestamp = t;
+void udelay(unsigned long usec) +{
- ulong tmo;
- tmo = usec / 1000;
- tmo *= (timer_load_val * 100);
- tmo /= 1000;
- tmo += get_timer(0);
- while (get_timer_masked() < tmo)
/*NOP*/;
+void reset_timer_masked(void) +{
- /* reset time */
- lastdec = READ_TIMER();
- timestamp = 0;
+ulong get_timer_masked(void) +{
- ulong now = READ_TIMER();
- if (lastdec >= now) {
/* normal mode */
timestamp += lastdec - now;
- } else {
/* we have an overflow ... */
timestamp += lastdec + timer_load_val - now;
- lastdec = now;
- return timestamp;
+void udelay_masked(unsigned long usec) +{
- ulong tmo;
- tmo /= 1000;
/*NOP*/;
- This function is derived from PowerPC code (read timebase as long long).
- On ARM it just returns the timer value.
+unsigned long long get_ticks(void) +{
- return get_timer(0);
- This function is derived from PowerPC code (timebase clock frequency).
- On ARM it returns the number of timer ticks per second.
+ulong get_tbclk(void) +{
- ulong tbclk;
- tbclk = timer_load_val * 100;
- return tbclk;
+#endif /* defined(CONFIG_EP93XX) */ diff --git a/include/asm-arm/arch-ep93xx/ep93xx.h b/include/asm-arm/arch-ep93xx/ep93xx.h new file mode 100644 index 0000000..47e2a21 --- /dev/null +++ b/include/asm-arm/arch-ep93xx/ep93xx.h @@ -0,0 +1,868 @@ +/* -----------------------------------------------------------------------------
- Cirrus Logic EP93xx register definitions.
- Matthias Kaehlcke matthias@kaehlcke.net
- Dominic Rath Dominic.Rath@gmx.de
- Based in large part on linux/include/asm-arm/arch-ep93xx/regmap.h, which is
- Copyright (C) 2004 Ray Lehtiniemi
- Copyright (C) 2003 Cirrus Logic, Inc
- Copyright (C) 1999 ARM Limited.
- for more details.
+#define EP93XX_AHB_BASE 0x80000000 +#define EP93XX_APB_BASE 0x80800000
- 0x80000000 - 0x8000FFFF: DMA
+#define DMA_OFFSET 0x000000 +#define DMA_BASE (EP93XX_AHB_BASE | DMA_OFFSET)
+#define DMAMP_TX_0_CONTROL (DMA_BASE + 0x0000) +#define DMAMP_TX_0_INTERRUPT (DMA_BASE + 0x0004) +#define DMAMP_TX_0_PPALLOC (DMA_BASE + 0x0008) +#define DMAMP_TX_0_STATUS (DMA_BASE + 0x000C) +#define DMAMP_TX_0_REMAIN (DMA_BASE + 0x0014) +#define DMAMP_TX_0_MAXCNT0 (DMA_BASE + 0x0020) +#define DMAMP_TX_0_BASE0 (DMA_BASE + 0x0024) +#define DMAMP_TX_0_CURRENT0 (DMA_BASE + 0x0028) +#define DMAMP_TX_0_MAXCNT1 (DMA_BASE + 0x0030) +#define DMAMP_TX_0_BASE1 (DMA_BASE + 0x0034) +#define DMAMP_TX_0_CURRENT1 (DMA_BASE + 0x0038)
This looks like a memory map of registers. Registers maps should be defined with structures. Use lowercase for element names.
+#define DMAMP_RX_1_CONTROL (DMA_BASE + 0x0040) +#define DMAMP_RX_1_INTERRUPT (DMA_BASE + 0x0044) +#define DMAMP_RX_1_PPALLOC (DMA_BASE + 0x0048) +#define DMAMP_RX_1_STATUS (DMA_BASE + 0x004C) +#define DMAMP_RX_1_REMAIN (DMA_BASE + 0x0054) +#define DMAMP_RX_1_MAXCNT0 (DMA_BASE + 0x0060) +#define DMAMP_RX_1_BASE0 (DMA_BASE + 0x0064) +#define DMAMP_RX_1_CURRENT0 (DMA_BASE + 0x0068) +#define DMAMP_RX_1_MAXCNT1 (DMA_BASE + 0x0070) +#define DMAMP_RX_1_BASE1 (DMA_BASE + 0x0074) +#define DMAMP_RX_1_CURRENT1 (DMA_BASE + 0x0078)
+#define DMAMP_TX_2_CONTROL (DMA_BASE + 0x0080) +#define DMAMP_TX_2_INTERRUPT (DMA_BASE + 0x0084) +#define DMAMP_TX_2_PPALLOC (DMA_BASE + 0x0088) +#define DMAMP_TX_2_STATUS (DMA_BASE + 0x008C) +#define DMAMP_TX_2_REMAIN (DMA_BASE + 0x0094) +#define DMAMP_TX_2_MAXCNT0 (DMA_BASE + 0x00A0) +#define DMAMP_TX_2_BASE0 (DMA_BASE + 0x00A4) +#define DMAMP_TX_2_CURRENT0 (DMA_BASE + 0x00A8) +#define DMAMP_TX_2_MAXCNT1 (DMA_BASE + 0x00B0) +#define DMAMP_TX_2_BASE1 (DMA_BASE + 0x00B4) +#define DMAMP_TX_2_CURRENT1 (DMA_BASE + 0x00B8)
+#define DMAMP_RX_3_CONTROL (DMA_BASE + 0x00C0) +#define DMAMP_RX_3_INTERRUPT (DMA_BASE + 0x00C4) +#define DMAMP_RX_3_PPALLOC (DMA_BASE + 0x00C8) +#define DMAMP_RX_3_STATUS (DMA_BASE + 0x00CC) +#define DMAMP_RX_3_REMAIN (DMA_BASE + 0x00D4) +#define DMAMP_RX_3_MAXCNT0 (DMA_BASE + 0x00E0) +#define DMAMP_RX_3_BASE0 (DMA_BASE + 0x00E4) +#define DMAMP_RX_3_CURRENT0 (DMA_BASE + 0x00E8) +#define DMAMP_RX_3_MAXCNT1 (DMA_BASE + 0x00F0) +#define DMAMP_RX_3_BASE1 (DMA_BASE + 0x00F4) +#define DMAMP_RX_3_CURRENT1 (DMA_BASE + 0x00F8)
+#define DMAMM_0_CONTROL (DMA_BASE + 0x0100) +#define DMAMM_0_INTERRUPT (DMA_BASE + 0x0104) +#define DMAMM_0_STATUS (DMA_BASE + 0x010C) +#define DMAMM_0_BCR0 (DMA_BASE + 0x0110) +#define DMAMM_0_BCR1 (DMA_BASE + 0x0114) +#define DMAMM_0_SAR_BASE0 (DMA_BASE + 0x0118) +#define DMAMM_0_SAR_BASE1 (DMA_BASE + 0x011C) +#define DMAMM_0_SAR_CURRENT0 (DMA_BASE + 0x0124) +#define DMAMM_0_SAR_CURRENT1 (DMA_BASE + 0x0128) +#define DMAMM_0_DAR_BASE0 (DMA_BASE + 0x012C) +#define DMAMM_0_DAR_BASE1 (DMA_BASE + 0x0130) +#define DMAMM_0_DAR_CURRENT0 (DMA_BASE + 0x0134) +#define DMAMM_0_DAR_CURRENT1 (DMA_BASE + 0x013C)
+#define DMAMM_1_CONTROL (DMA_BASE + 0x0140) +#define DMAMM_1_INTERRUPT (DMA_BASE + 0x0144) +#define DMAMM_1_STATUS (DMA_BASE + 0x014C) +#define DMAMM_1_BCR0 (DMA_BASE + 0x0150) +#define DMAMM_1_BCR1 (DMA_BASE + 0x0154) +#define DMAMM_1_SAR_BASE0 (DMA_BASE + 0x0158) +#define DMAMM_1_SAR_BASE1 (DMA_BASE + 0x015C) +#define DMAMM_1_SAR_CURRENT0 (DMA_BASE + 0x0164) +#define DMAMM_1_SAR_CURRENT1 (DMA_BASE + 0x0168) +#define DMAMM_1_DAR_BASE0 (DMA_BASE + 0x016C) +#define DMAMM_1_DAR_BASE1 (DMA_BASE + 0x0170) +#define DMAMM_1_DAR_CURRENT0 (DMA_BASE + 0x0174) +#define DMAMM_1_DAR_CURRENT1 (DMA_BASE + 0x017C)
+#define DMAMP_RX_5_CONTROL (DMA_BASE + 0x0200) +#define DMAMP_RX_5_INTERRUPT (DMA_BASE + 0x0204) +#define DMAMP_RX_5_PPALLOC (DMA_BASE + 0x0208) +#define DMAMP_RX_5_STATUS (DMA_BASE + 0x020C) +#define DMAMP_RX_5_REMAIN (DMA_BASE + 0x0214) +#define DMAMP_RX_5_MAXCNT0 (DMA_BASE + 0x0220) +#define DMAMP_RX_5_BASE0 (DMA_BASE + 0x0224) +#define DMAMP_RX_5_CURRENT0 (DMA_BASE + 0x0228) +#define DMAMP_RX_5_MAXCNT1 (DMA_BASE + 0x0230) +#define DMAMP_RX_5_BASE1 (DMA_BASE + 0x0234) +#define DMAMP_RX_5_CURRENT1 (DMA_BASE + 0x0238)
+#define DMAMP_TX_4_CONTROL (DMA_BASE + 0x0240) +#define DMAMP_TX_4_INTERRUPT (DMA_BASE + 0x0244) +#define DMAMP_TX_4_PPALLOC (DMA_BASE + 0x0248) +#define DMAMP_TX_4_STATUS (DMA_BASE + 0x024C) +#define DMAMP_TX_4_REMAIN (DMA_BASE + 0x0254) +#define DMAMP_TX_4_MAXCNT0 (DMA_BASE + 0x0260) +#define DMAMP_TX_4_BASE0 (DMA_BASE + 0x0264) +#define DMAMP_TX_4_CURRENT0 (DMA_BASE + 0x0268) +#define DMAMP_TX_4_MAXCNT1 (DMA_BASE + 0x0270) +#define DMAMP_TX_4_BASE1 (DMA_BASE + 0x0274) +#define DMAMP_TX_4_CURRENT1 (DMA_BASE + 0x0278)
+#define DMAMP_RX_7_CONTROL (DMA_BASE + 0x0280) +#define DMAMP_RX_7_INTERRUPT (DMA_BASE + 0x0284) +#define DMAMP_RX_7_PPALLOC (DMA_BASE + 0x0288) +#define DMAMP_RX_7_STATUS (DMA_BASE + 0x028C) +#define DMAMP_RX_7_REMAIN (DMA_BASE + 0x0294) +#define DMAMP_RX_7_MAXCNT0 (DMA_BASE + 0x02A0) +#define DMAMP_RX_7_BASE0 (DMA_BASE + 0x02A4) +#define DMAMP_RX_7_CURRENT0 (DMA_BASE + 0x02A8) +#define DMAMP_RX_7_MAXCNT1 (DMA_BASE + 0x02B0) +#define DMAMP_RX_7_BASE1 (DMA_BASE + 0x02B4) +#define DMAMP_RX_7_CURRENT1 (DMA_BASE + 0x02B8)
+#define DMAMP_TX_6_CONTROL (DMA_BASE + 0x02C0) +#define DMAMP_TX_6_INTERRUPT (DMA_BASE + 0x02C4) +#define DMAMP_TX_6_PPALLOC (DMA_BASE + 0x02C8) +#define DMAMP_TX_6_STATUS (DMA_BASE + 0x02CC) +#define DMAMP_TX_6_REMAIN (DMA_BASE + 0x02D4) +#define DMAMP_TX_6_MAXCNT0 (DMA_BASE + 0x02E0) +#define DMAMP_TX_6_BASE0 (DMA_BASE + 0x02E4) +#define DMAMP_TX_6_CURRENT0 (DMA_BASE + 0x02E8) +#define DMAMP_TX_6_MAXCNT1 (DMA_BASE + 0x02F0) +#define DMAMP_TX_6_BASE1 (DMA_BASE + 0x02F4) +#define DMAMP_TX_6_CURRENT1 (DMA_BASE + 0x02F8)
+#define DMAMP_RX_9_CONTROL (DMA_BASE + 0x0300) +#define DMAMP_RX_9_INTERRUPT (DMA_BASE + 0x0304) +#define DMAMP_RX_9_PPALLOC (DMA_BASE + 0x0308) +#define DMAMP_RX_9_STATUS (DMA_BASE + 0x030C) +#define DMAMP_RX_9_REMAIN (DMA_BASE + 0x0314) +#define DMAMP_RX_9_MAXCNT0 (DMA_BASE + 0x0320) +#define DMAMP_RX_9_BASE0 (DMA_BASE + 0x0324) +#define DMAMP_RX_9_CURRENT0 (DMA_BASE + 0x0328) +#define DMAMP_RX_9_MAXCNT1 (DMA_BASE + 0x0330) +#define DMAMP_RX_9_BASE1 (DMA_BASE + 0x0334) +#define DMAMP_RX_9_CURRENT1 (DMA_BASE + 0x0338)
+#define DMAMP_TX_8_CONTROL (DMA_BASE + 0x0340) +#define DMAMP_TX_8_INTERRUPT (DMA_BASE + 0x0344) +#define DMAMP_TX_8_PPALLOC (DMA_BASE + 0x0348) +#define DMAMP_TX_8_STATUS (DMA_BASE + 0x034C) +#define DMAMP_TX_8_REMAIN (DMA_BASE + 0x0354) +#define DMAMP_TX_8_MAXCNT0 (DMA_BASE + 0x0360) +#define DMAMP_TX_8_BASE0 (DMA_BASE + 0x0364) +#define DMAMP_TX_8_CURRENT0 (DMA_BASE + 0x0368) +#define DMAMP_TX_8_MAXCNT1 (DMA_BASE + 0x0370) +#define DMAMP_TX_8_BASE1 (DMA_BASE + 0x0374) +#define DMAMP_TX_8_CURRENT1 (DMA_BASE + 0x0378)
+#define DMA_ARBITRATION (DMA_BASE + 0x0380) +#define DMA_INTERRUPT (DMA_BASE + 0x03C0)
- 0x80010000 - 0x8001FFFF: Ethernet MAC
+#define MAC_OFFSET 0x010000 +#define MAC_BASE (EP93XX_AHB_BASE | MAC_OFFSET)
+#define MAC_RXCTL (MAC_BASE + 0x0000) +#define MAC_TXCTL (MAC_BASE + 0x0004) +#define MAC_TESTCTL (MAC_BASE + 0x0008) +#define MAC_MIICMD (MAC_BASE + 0x0010) +#define MAC_MIIDATA (MAC_BASE + 0x0014) +#define MAC_MIISTS (MAC_BASE + 0x0018) +#define MAC_SELFCTL (MAC_BASE + 0x0020) +#define MAC_INTEN (MAC_BASE + 0x0024) +#define MAC_INTSTSP (MAC_BASE + 0x0028) +#define MAC_INTSTSC (MAC_BASE + 0x002C) +#define MAC_DIAGAD (MAC_BASE + 0x0038) +#define MAC_DIAGDATA (MAC_BASE + 0x003C) +#define MAC_GT (MAC_BASE + 0x0040) +#define MAC_FCT (MAC_BASE + 0x0044) +#define MAC_FCF (MAC_BASE + 0x0048) +#define MAC_AFP (MAC_BASE + 0x004C) +#define MAC_HASHTBL (MAC_BASE + 0x0050) +#define MAC_INDAD (MAC_BASE + 0x0050) +#define MAC_INDAD_UPPER (MAC_BASE + 0x0054) +#define MAC_GIINTSTS (MAC_BASE + 0x0060) +#define MAC_GIINTMSK (MAC_BASE + 0x0064) +#define MAC_GIINTROSTS (MAC_BASE + 0x0068) +#define MAC_GIINTFRC (MAC_BASE + 0x006C) +#define MAC_TXCOLLCNT (MAC_BASE + 0x0070) +#define MAC_RXMISSCNT (MAC_BASE + 0x0074) +#define MAC_RXRUNTCNT (MAC_BASE + 0x0078) +#define MAC_BMCTL (MAC_BASE + 0x0080) +#define MAC_BMSTS (MAC_BASE + 0x0084) +#define MAC_RXBCA (MAC_BASE + 0x0088) +#define MAC_RXDQBADD (MAC_BASE + 0x0090) +#define MAC_RXDQBLEN (MAC_BASE + 0x0094) +#define MAC_RXDQCURLEN (MAC_BASE + 0x0096) +#define MAC_RXDQCURADD (MAC_BASE + 0x0098) +#define MAC_RXDENQ (MAC_BASE + 0x009C) +#define MAC_RXSTSQBADD (MAC_BASE + 0x00A0) +#define MAC_RXSTSQBLEN (MAC_BASE + 0x00A4) +#define MAC_RXSTSQCURLEN (MAC_BASE + 0x00A6) +#define MAC_RXSTSQCURADD (MAC_BASE + 0x00A8) +#define MAC_RXSTSENQ (MAC_BASE + 0x00AC) +#define MAC_TXDQBADD (MAC_BASE + 0x00B0) +#define MAC_TXDQBLEN (MAC_BASE + 0x00B4) +#define MAC_TXDQCURLEN (MAC_BASE + 0x00B6) +#define MAC_TXDQCURADD (MAC_BASE + 0x00B8) +#define MAC_TXDENQ (MAC_BASE + 0x00BC) +#define MAC_TXSTSQBADD (MAC_BASE + 0x00C0) +#define MAC_TXSTSQBLEN (MAC_BASE + 0x00C4) +#define MAC_TXSTSQCURLEN (MAC_BASE + 0x00C6) +#define MAC_TXSTSQCURADD (MAC_BASE + 0x00C8) +#define MAC_RXBUFTHRSHLD (MAC_BASE + 0x00D0) +#define MAC_TXBUFTHRSHLD (MAC_BASE + 0x00D4) +#define MAC_RXSTSTHRSHLD (MAC_BASE + 0x00D8) +#define MAC_TXSTSTHRSHLD (MAC_BASE + 0x00DC) +#define MAC_RXDTHRSHLD (MAC_BASE + 0x00E0) +#define MAC_TXDTHRSHLD (MAC_BASE + 0x00E4) +#define MAC_MAXFRMLEN (MAC_BASE + 0x00E8) +#define MAC_RXHDRLEN (MAC_BASE + 0x00EC)
+#define SELFCTL_RWP (1 << 7) +#define SELFCTL_GPO0 (1 << 5) +#define SELFCTL_PUWE (1 << 4) +#define SELFCTL_PDWE (1 << 3) +#define SELFCTL_MIIL (1 << 2) +#define SELFCTL_RESET (1 << 0)
+#define INTSTS_RWI (1 << 30) +#define INTSTS_RXMI (1 << 29) +#define INTSTS_RXBI (1 << 28) +#define INTSTS_RXSQI (1 << 27) +#define INTSTS_TXLEI (1 << 26) +#define INTSTS_ECIE (1 << 25) +#define INTSTS_TXUHI (1 << 24) +#define INTSTS_MOI (1 << 18) +#define INTSTS_TXCOI (1 << 17) +#define INTSTS_RXROI (1 << 16) +#define INTSTS_MIII (1 << 12) +#define INTSTS_PHYI (1 << 11) +#define INTSTS_TI (1 << 10) +#define INTSTS_AHBE (1 << 8) +#define INTSTS_OTHER (1 << 4) +#define INTSTS_TXSQ (1 << 3) +#define INTSTS_RXSQ (1 << 2)
+#define BMCTL_MT (1 << 13) +#define BMCTL_TT (1 << 12) +#define BMCTL_UNH (1 << 11) +#define BMCTL_TXCHR (1 << 10) +#define BMCTL_TXDIS (1 << 9) +#define BMCTL_TXEN (1 << 8) +#define BMCTL_EH2 (1 << 6) +#define BMCTL_EH1 (1 << 5) +#define BMCTL_EEOB (1 << 4) +#define BMCTL_RXCHR (1 << 2) +#define BMCTL_RXDIS (1 << 1) +#define BMCTL_RXEN (1 << 0)
+#define BMSTS_TXACT (1 << 7) +#define BMSTS_TP (1 << 4) +#define BMSTS_RXACT (1 << 3) +#define BMSTS_QID_MASK 0x07 +#define BMSTS_QID_RXDATA 0x00 +#define BMSTS_QID_TXDATA 0x01 +#define BMSTS_QID_RXSTS 0x02 +#define BMSTS_QID_TXSTS 0x03 +#define BMSTS_QID_RXDESC 0x04 +#define BMSTS_QID_TXDESC 0x05
+#define AFP_MASK 0x07 +#define AFP_IAPRIMARY 0x00 +#define AFP_IASECONDARY1 0x01 +#define AFP_IASECONDARY2 0x02 +#define AFP_IASECONDARY3 0x03 +#define AFP_TX 0x06 +#define AFP_HASH 0x07
+#define RXCTL_PAUSEA (1 << 20) +#define RXCTL_RXFCE1 (1 << 19) +#define RXCTL_RXFCE0 (1 << 18) +#define RXCTL_BCRC (1 << 17) +#define RXCTL_SRXON (1 << 16) +#define RXCTL_RCRCA (1 << 13) +#define RXCTL_RA (1 << 12) +#define RXCTL_PA (1 << 11) +#define RXCTL_BA (1 << 10) +#define RXCTL_MA (1 << 9) +#define RXCTL_IAHA (1 << 8) +#define RXCTL_IA3 (1 << 3) +#define RXCTL_IA2 (1 << 2) +#define RXCTL_IA1 (1 << 1) +#define RXCTL_IA0 (1 << 0)
+#define TXCTL_DEFDIS (1 << 7) +#define TXCTL_MBE (1 << 6) +#define TXCTL_ICRC (1 << 5) +#define TXCTL_TPD (1 << 4) +#define TXCTL_OCOLL (1 << 3) +#define TXCTL_SP (1 << 2) +#define TXCTL_PB (1 << 1) +#define TXCTL_STXON (1 << 0)
+#define MIICMD_REGAD_MASK (0x001F) +#define MIICMD_PHYAD_MASK (0x03E0) +#define MIICMD_OPCODE_MASK (0xC000) +#define MIICMD_PHYAD_8950 (0x0000) +#define MIICMD_OPCODE_READ (0x8000) +#define MIICMD_OPCODE_WRITE (0x4000)
+#define MIISTS_BUSY (1 << 0)
- 0x80020000 - 0x8002FFFF: USB OHCI
+#define USB_OFFSET 0x020000 +#define USB_BASE (EP93XX_AHB_BASE | USB_OFFSET)
+#define USB_HCREVISION (USB_BASE + 0x0000) +#define USB_HCCONTROL (USB_BASE + 0x0004) +#define USB_HCCOMMANDSTATUS (USB_BASE + 0x0008) +#define USB_HCINTERRUPTSTATUS (USB_BASE + 0x000C) +#define USB_HCINTERRUPTENABLE (USB_BASE + 0x0010) +#define USB_HCINTERRUPTDISABLE (USB_BASE + 0x0014) +#define USB_HCHCCA (USB_BASE + 0x0018) +#define USB_HCPERIODCURRENTED (USB_BASE + 0x001C) +#define USB_HCCONTROLHEADED (USB_BASE + 0x0020) +#define USB_HCCONTROLCURRENTED (USB_BASE + 0x0024) +#define USB_HCBULKHEADED (USB_BASE + 0x0028) +#define USB_HCBULKCURRENTED (USB_BASE + 0x002C) +#define USB_HCDONEHEAD (USB_BASE + 0x0030) +#define USB_HCFMINTERVAL (USB_BASE + 0x0034) +#define USB_HCFMREMAINING (USB_BASE + 0x0038) +#define USB_HCFMNUMBER (USB_BASE + 0x003C) +#define USB_HCPERIODICSTART (USB_BASE + 0x0040) +#define USB_HCLSTHRESHOLD (USB_BASE + 0x0044) +#define USB_HCRHDESCRIPTORA (USB_BASE + 0x0048) +#define USB_HCRHDESCRIPTORB (USB_BASE + 0x004C) +#define USB_HCRHSTATUS (USB_BASE + 0x0050) +#define USB_HCRHPORTSTATUS0 (USB_BASE + 0x0054) +#if (defined(CONFIG_EP9302) || defined(CONFIG_EP9307) ||\
- defined(CONFIG_EP9312) || defined(CONFIG_EP9315))
+#define USB_HCRHPORTSTATUS1 (USB_BASE + 0x0058) +#endif +#define USB_HCRHPORTSTATUS2 (USB_BASE + 0x005C) +#define USB_CFGCTRL (USB_BASE + 0x0080) +#define USB_HCISTS (USB_BASE + 0x0084)
I did not see usb used. Are these and maybe others defined here for completeness ? Or are other patches forthcoming?
- 0x80030000 - 0x8003FFFF: Raster engine
+#if (defined(CONFIG_EP9307) || defined(CONFIG_EP9312) || defined(CONFIG_EP9315)) +#define RASTER_OFFSET 0x030000 +#define RASTER_BASE (EP93XX_AHB_BASE | RASTER_OFFSET)
+#define RASTER_VLINESTOTAL (RASTER_BASE + 0x0000) +#define RASTER_VSYNCSTRTSTOP (RASTER_BASE + 0x0004) +#define RASTER_VACTIVESTRTSTOP (RASTER_BASE + 0x0008) +#define RASTER_VCLKSTRTSTOP (RASTER_BASE + 0x000C) +#define RASTER_HCLKSTOTAL (RASTER_BASE + 0x0010) +#define RASTER_HSYNCSTRTSTOP (RASTER_BASE + 0x0014) +#define RASTER_HACTIVESTRTSTOP (RASTER_BASE + 0x0018) +#define RASTER_HCLKSTRTSTOP (RASTER_BASE + 0x001C) +#define RASTER_BRIGHTNESS (RASTER_BASE + 0x0020) +#define RASTER_VIDEOATTRIBS (RASTER_BASE + 0x0024) +#define RASTER_VIDSCRNPAGE (RASTER_BASE + 0x0028) +#define RASTER_VIDSCRNHPG (RASTER_BASE + 0x002C) +#define RASTER_SCRNLINES (RASTER_BASE + 0x0030) +#define RASTER_LINELENGTH (RASTER_BASE + 0x0034) +#define RASTER_VLINESTEP (RASTER_BASE + 0x0038) +#define RASTER_LINECARRY (RASTER_BASE + 0x003C) +#define RASTER_BLINKRATE (RASTER_BASE + 0x0040) +#define RASTER_BLINKMASK (RASTER_BASE + 0x0044) +#define RASTER_BLINKPATTRN (RASTER_BASE + 0x0048) +#define RASTER_PATTRNMASK (RASTER_BASE + 0x004C) +#define RASTER_BG_OFFSET (RASTER_BASE + 0x0050) +#define RASTER_PIXELMODE (RASTER_BASE + 0x0054) +#define RASTER_PARLLIFOUT (RASTER_BASE + 0x0058) +#define RASTER_PARLLIFIN (RASTER_BASE + 0x005C) +#define RASTER_CURSOR_ADR_START (RASTER_BASE + 0x0060) +#define RASTER_CURSOR_ADR_RESET (RASTER_BASE + 0x0064) +#define RASTER_CURSORSIZE (RASTER_BASE + 0x0068) +#define RASTER_CURSORCOLOR1 (RASTER_BASE + 0x006C) +#define RASTER_CURSORCOLOR2 (RASTER_BASE + 0x0070) +#define RASTER_CURSORXYLOC (RASTER_BASE + 0x0074) +#define RASTER_CURSOR_DHSCAN_LH_YLOC (RASTER_BASE + 0x0078) +#define RASTER_REALITI_SWLOCK (RASTER_BASE + 0x007C) +#define RASTER_GS_LUT (RASTER_BASE + 0x0080) +#define RASTER_REALITI_TCR (RASTER_BASE + 0x0100) +#define RASTER_REALITI_TISRA (RASTER_BASE + 0x0104) +#define RASTER_REALITI_TISRB (RASTER_BASE + 0x0108) +#define RASTER_CURSOR_TISR (RASTER_BASE + 0x010C) +#define RASTER_REALITI_TOCRA (RASTER_BASE + 0x0110) +#define RASTER_REALITI_TOCRB (RASTER_BASE + 0x0114) +#define RASTER_FIFO_TOCRA (RASTER_BASE + 0x0118) +#define RASTER_FIFO_TOCRB (RASTER_BASE + 0x011C) +#define RASTER_BLINK_TISR (RASTER_BASE + 0x0120) +#define RASTER_DAC_TISRA (RASTER_BASE + 0x0124) +#define RASTER_DAC_TISRB (RASTER_BASE + 0x0128) +#define RASTER_SHIFT_TISR (RASTER_BASE + 0x012C) +#define RASTER_DACMUX_TOCRA (RASTER_BASE + 0x0130) +#define RASTER_DACMUX_TOCRB (RASTER_BASE + 0x0134) +#define RASTER_PELMUX_TOCR (RASTER_BASE + 0x0138) +#define RASTER_VIDEO_TOCRA (RASTER_BASE + 0x013C) +#define RASTER_VIDEO_TOCRB (RASTER_BASE + 0x0140) +#define RASTER_YCRCB_TOCR (RASTER_BASE + 0x0144) +#define RASTER_CURSOR_TOCR (RASTER_BASE + 0x0148) +#define RASTER_VIDEO_TOCRC (RASTER_BASE + 0x014C) +#define RASTER_SHIFT_TOCR (RASTER_BASE + 0x0150) +#define RASTER_BLINK_TOCR (RASTER_BASE + 0x0154) +#define RASTER_REALITI_TCER (RASTER_BASE + 0x0180) +#define RASTER_SIGVAL (RASTER_BASE + 0x0200) +#define RASTER_SIGCTL (RASTER_BASE + 0x0204) +#define RASTER_VSIGSTRTSTOP (RASTER_BASE + 0x0208) +#define RASTER_HSIGSTRTSTOP (RASTER_BASE + 0x020C) +#define RASTER_SIGCLR (RASTER_BASE + 0x0210) +#define RASTER_ACRATE (RASTER_BASE + 0x0214) +#define RASTER_LUTCONT (RASTER_BASE + 0x0218) +#define RASTER_VBLANKSTRTSTOP (RASTER_BASE + 0x0228) +#define RASTER_HBLANKSTRTSTOP (RASTER_BASE + 0x022C) +#define RASTER_LUT (RASTER_BASE + 0x0400) +#define RASTER_CURSORBLINK1 (RASTER_BASE + 0x021C) +#define RASTER_CURSORBLINK2 (RASTER_BASE + 0x0220) +#define RASTER_CURSORBLINK (RASTER_BASE + 0x0224) +#define RASTER_EOLOFFSET (RASTER_BASE + 0x0230) +#define RASTER_FIFOLEVEL (RASTER_BASE + 0x0234) +#define RASTER_GS_LUT2 (RASTER_BASE + 0x0280) +#define RASTER_GS_LUT3 (RASTER_BASE + 0x0300) +#define RASTER_COLOR_LUT (RASTER_BASE + 0x0400) +#endif
- 0x80040000 - 0x8004FFFF: Graphics accelerator
+#if defined(CONFIG_EP9315) +#define GFX_OFFSET 0x040000 +#define GFX_BASE (EP93XX_AHB_BASE | GFX_OFFSET) +#endif
- 0x80050000 - 0x8005FFFF: Reserved
- 0x80060000 - 0x8006FFFF: SDRAM controller
+#define SDRAM_OFFSET 0x060000 +#define SDRAM_BASE (EP93XX_AHB_BASE | SDRAM_OFFSET)
+#define SDRAM_GLCONFIG (SDRAM_BASE + 0x0004) +#define SDRAM_REFRSHTIMR (SDRAM_BASE + 0x0008) +#define SDRAM_BOOTSTS (SDRAM_BASE + 0x000C) +#define SDRAM_DEVCFG0 (SDRAM_BASE + 0x0010) +#define SDRAM_DEVCFG1 (SDRAM_BASE + 0x0014) +#define SDRAM_DEVCFG2 (SDRAM_BASE + 0x0018) +#define SDRAM_DEVCFG3 (SDRAM_BASE + 0x001C)
+#define SDRAM_DEVCFG_EXTBUSWIDTH (1 << 2) +#define SDRAM_DEVCFG_BANKCOUNT (1 << 3) +#define SDRAM_DEVCFG_SROMLL (1 << 5) +#define SDRAM_DEVCFG_CASLAT_2 0x00010000 +#define SDRAM_DEVCFG_RASTOCAS_2 0x00200000
+#define GLCONFIG_INIT (1 << 0) +#define GLCONFIG_MRS (1 << 1) +#define GLCONFIG_SMEMBUSY (1 << 5) +#define GLCONFIG_LCR (1 << 6) +#define GLCONFIG_REARBEN (1 << 7) +#define GLCONFIG_CLKSHUTDOWN (1 << 30) +#define GLCONFIG_CKE (1 << 31)
- 0x80070000 - 0x8007FFFF: Reserved
- 0x80080000 - 0x8008FFFF: SRAM controller & PCMCIA
+#define SMC_OFFSET 0x080000 +#define SMC_BASE (EP93XX_AHB_BASE | SMC_OFFSET)
+#define SMC_BCR0 (SMC_BASE + 0x0000) +#define SMC_BCR1 (SMC_BASE + 0x0004) +#define SMC_BCR2 (SMC_BASE + 0x0008) +#define SMC_BCR3 (SMC_BASE + 0x000C) +#define SMC_BCR6 (SMC_BASE + 0x0018) +#define SMC_BCR7 (SMC_BASE + 0x001C) +#if (defined(CONFIG_EP9307) || defined(CONFIG_EP9315)) +#define SMC_PCATTRIBUTE (SMC_BASE + 0x0020) +#define SMC_PCCOMMON (SMC_BASE + 0x0024) +#define SMC_PCIO (SMC_BASE + 0x0028) +#define SMC_PCMCIACTRL (SMC_BASE + 0x0040) +#endif
+#define SMC_BCR_IDCY_SHIFT 0 +#define SMC_BCR_WST1_SHIFT 5 +#define SMC_BCR_BLE (1 << 10) +#define SMC_BCR_WST2_SHIFT 11 +#define SMC_BCR_MW_SHIFT 28
- 0x80090000 - 0x8009FFFF: Boot ROM
- 0x800A0000 - 0x800AFFFF: IDE interface
- 0x800B0000 - 0x800BFFFF: VIC1
- 0x800C0000 - 0x800CFFFF: VIC2
- 0x800D0000 - 0x800FFFFF: Reserved
- 0x80800000 - 0x8080FFFF: Reserved
- 0x80810000 - 0x8081FFFF: Timers
+#define TIMER_OFFSET 0x010000 +#define TIMER_BASE (EP93XX_APB_BASE | TIMER_OFFSET)
+#define TIMER1_LOAD (TIMER_BASE + 0x0000) +#define TIMER1_VALUE (TIMER_BASE + 0x0004) +#define TIMER1_CONTROL (TIMER_BASE + 0x0008) +#define TIMER1_CLEAR (TIMER_BASE + 0x000c)
+#define TIMER2_LOAD (TIMER_BASE + 0x0020) +#define TIMER2_VALUE (TIMER_BASE + 0x0024) +#define TIMER2_CONTROL (TIMER_BASE + 0x0028) +#define TIMER2_CLEAR (TIMER_BASE + 0x002c)
+#define TIMER3_LOAD (TIMER_BASE + 0x0080) +#define TIMER3_VALUE (TIMER_BASE + 0x0084) +#define TIMER3_CONTROL (TIMER_BASE + 0x0088) +#define TIMER3_CLEAR (TIMER_BASE + 0x008c)
- 0x80820000 - 0x8082FFFF: I2S
+#define I2S_OFFSET 0x020000 +#define I2S_BASE (EP93XX_APB_BASE | I2S_OFFSET)
- 0x80830000 - 0x8083FFFF: Security
+#define SECURITY_OFFSET 0x030000 +#define SECURITY_BASE (EP93XX_APB_BASE | SECURITY_OFFSET)
+#define EXTENSIONID (SECURITY_BASE + 0x2714)
- 0x80840000 - 0x8084FFFF: GPIO
+#define GPIO_OFFSET 0x040000 +#define GPIO_BASE (EP93XX_APB_BASE | GPIO_OFFSET)
+#define GPIO_PADR (GPIO_BASE + 0x0000) +#define GPIO_PBDR (GPIO_BASE + 0x0004) +#define GPIO_PCDR (GPIO_BASE + 0x0008) +#define GPIO_PDDR (GPIO_BASE + 0x000c)
+#define GPIO_PADDR (GPIO_BASE + 0x0010) +#define GPIO_PBDDR (GPIO_BASE + 0x0014) +#define GPIO_PCDDR (GPIO_BASE + 0x0018) +#define GPIO_PDDDR (GPIO_BASE + 0x001c)
+#define GPIO_PEDR (GPIO_BASE + 0x0020) +#define GPIO_PEDDR (GPIO_BASE + 0x0024) +#define GPIO_PFDR (GPIO_BASE + 0x0030) +#define GPIO_PFDDR (GPIO_BASE + 0x0034) +#define GPIO_PGDR (GPIO_BASE + 0x0038) +#define GPIO_PGDDR (GPIO_BASE + 0x003c) +#define GPIO_PHDR (GPIO_BASE + 0x0040) +#define GPIO_PHDDR (GPIO_BASE + 0x0044)
+#define GPIO_FINTTYPE1 (GPIO_BASE + 0x004c) +#define GPIO_FINTTYPE2 (GPIO_BASE + 0x0050) +#define GPIO_FEOI (GPIO_BASE + 0x0054) +#define GPIO_FINTEN (GPIO_BASE + 0x0058) +#define GPIO_INTSTSF (GPIO_BASE + 0x005c) +#define GPIO_RAWINTSTSF (GPIO_BASE + 0x0060) +#define GPIO_FDB (GPIO_BASE + 0x0064)
+#define GPIO_AINTTYPE1 (GPIO_BASE + 0x0090) +#define GPIO_AINTTYPE2 (GPIO_BASE + 0x0094) +#define GPIO_AEOI (GPIO_BASE + 0x0098) +#define GPIO_AINTEN (GPIO_BASE + 0x009c) +#define GPIO_INTSTSA (GPIO_BASE + 0x00a0) +#define GPIO_RAWINTSTSA (GPIO_BASE + 0x00a4) +#define GPIO_ADB (GPIO_BASE + 0x00a8)
+#define GPIO_BINTTYPE1 (GPIO_BASE + 0x00ac) +#define GPIO_BINTTYPE2 (GPIO_BASE + 0x00b0) +#define GPIO_BEOI (GPIO_BASE + 0x00b4) +#define GPIO_BINTEN (GPIO_BASE + 0x00b8) +#define GPIO_INTSTSB (GPIO_BASE + 0x00bc) +#define GPIO_RAWINTSTSB (GPIO_BASE + 0x00c0) +#define GPIO_BDB (GPIO_BASE + 0x00c4)
+#define GPIO_EEDRIVE (GPIO_BASE + 0x00c8)
- 0x80850000 - 0x8087FFFF: Reserved
- 0x80880000 - 0x8088FFFF: AAC
+#define AAC_OFFSET 0x080000 +#define AAC_BASE (EP93XX_APB_BASE | AAC_OFFSET)
- 0x80890000 - 0x8089FFFF: Reserved
- 0x808A0000 - 0x808AFFFF: SPI
+#define SPI_OFFSET 0x0A0000 +#define SPI_BASE (EP93XX_APB_BASE | SPI_OFFSET)
+#define SPI_SSP1CR0 (SPI_BASE + 0x0000) +#define SPI_SSP1CR1 (SPI_BASE + 0x0004) +#define SPI_SSP1DR (SPI_BASE + 0x0008) +#define SPI_SSP1SR (SPI_BASE + 0x000c) +#define SPI_SSP1CPSR (SPI_BASE + 0x0010) +#define SPI_SSP1IIR (SPI_BASE + 0x0014)
- 0x808B0000 - 0x808BFFFF: IrDA
+#define IRDA_OFFSET 0x0B0000 +#define IRDA_BASE (EP93XX_APB_BASE | IRDA_OFFSET)
- 0x808C0000 - 0x808CFFFF: UART1
+#define UART1_OFFSET 0x0C0000 +#define UART1_BASE (EP93XX_APB_BASE | UART1_OFFSET)
+#define UART1_DATA (UART1_BASE + 0x0000) +#define UART1_RXSTS (UART1_BASE + 0x0004) +#define UART1_LIN_CTRLHIGH (UART1_BASE + 0x0008) +#define UART1_LIN_CTRLMID (UART1_BASE + 0x000c) +#define UART1_LIN_CTRLLOW (UART1_BASE + 0x0010) +#define UART1_CTRL (UART1_BASE + 0x0014) +#define UART1_FLAG (UART1_BASE + 0x0018) +#define UART1_INTIDINTCLR (UART1_BASE + 0x001c)
+#define UART1_DMA_CTRL (UART1_BASE + 0x0028)
+#define UART1_MODEM_CTRL (UART1_BASE + 0x0100) +#define UART1_MODEM_STS (UART1_BASE + 0x0104)
+#define UART1_HDLC_CTRL (UART1_BASE + 0x020c) +#define UART1_HDLC_ADDMTCHVAL (UART1_BASE + 0x0210) +#define UART1_HDLC_ADDMASK (UART1_BASE + 0x0214) +#define UART1_HDLC_RXINFOBUF (UART1_BASE + 0x0218) +#define UART1_HDLC_STS (UART1_BASE + 0x021c)
- 0x808D0000 - 0x808DFFFF: UART2
+#define UART2_OFFSET 0x0D0000 +#define UART2_BASE (EP93XX_APB_BASE | UART2_OFFSET)
+#define UART2_DATA (UART2_BASE + 0x0000) +#define UART2_RXSTS (UART2_BASE + 0x0004) +#define UART2_LIN_CTRLHIGH (UART2_BASE + 0x0008) +#define UART2_LIN_CTRLMID (UART2_BASE + 0x000c) +#define UART2_LIN_CTRLLOW (UART2_BASE + 0x0010) +#define UART2_CTRL (UART2_BASE + 0x0014) +#define UART2_FLAG (UART2_BASE + 0x0018) +#define UART2_INTIDINTCLR (UART2_BASE + 0x001c) +#define UART2_IRLOWPWRCNTR (UART2_BASE + 0x0020)
+#define UART2_DMA_CTRL (UART2_BASE + 0x0028)
- 0x808E0000 - 0x808EFFFF: UART3
+#define UART3_OFFSET 0x0E0000 +#define UART3_BASE (EP93XX_APB_BASE | UART3_OFFSET)
+#define UART3_DATA (UART3_BASE + 0x0000) +#define UART3_RXSTS (UART3_BASE + 0x0004) +#define UART3_LIN_CTRLHIGH (UART3_BASE + 0x0008) +#define UART3_LIN_CTRLMID (UART3_BASE + 0x000c) +#define UART3_LIN_CTRLLOW (UART3_BASE + 0x0010) +#define UART3_CTRL (UART3_BASE + 0x0014) +#define UART3_FLAG (UART3_BASE + 0x0018) +#define UART3_INTIDINTCLR (UART3_BASE + 0x001c) +#define UART3_IRLOWPWRCNTR (UART3_BASE + 0x0020)
+#define UART3_DMA_CTRL (UART3_BASE + 0x0028)
+#define UART3_MODEM_CTRL (UART3_BASE + 0x0100) +#define UART3_MODEM_STS (UART3_BASE + 0x0104) +#define UART2_MODEM_TSTCTRL (UART2_BASE + 0x0108)
+#define UART3_HDLC_CTRL (UART3_BASE + 0x020c) +#define UART3_HDLC_ADDMTCHVAL (UART3_BASE + 0x0210) +#define UART3_HDLC_ADDMASK (UART3_BASE + 0x0214) +#define UART3_HDLC_RXINFOBUF (UART3_BASE + 0x0218) +#define UART3_HDLC_STS (UART3_BASE + 0x021c)
- 0x808F0000 - 0x808FFFFF: Key Matrix
+#define KEY_OFFSET 0x0F0000 +#define KEY_BASE (EP93XX_APB_BASE | KEY_OFFSET)
- 0x80900000 - 0x8090FFFF: Touchscreen
+#define TOUCH_OFFSET 0x900000 +#define TOUCH_BASE (EP93XX_APB_BASE | TOUCH_OFFSET)
- 0x80910000 - 0x8091FFFF: Pulse Width Modulation
+#define PWM_OFFSET 0x910000 +#define PWM_BASE (EP93XX_APB_BASE | PWM_OFFSET)
- 0x80920000 - 0x8092FFFF: Real time clock
+#define RTC_OFFSET 0x920000 +#define RTC_BASE (EP93XX_APB_BASE | RTC_OFFSET)
- 0x80930000 - 0x8093FFFF: Syscon
+#define SYSCON_OFFSET 0x930000 +#define SYSCON_BASE (EP93XX_APB_BASE | SYSCON_OFFSET)
+#define SYSCON_PWRSTS (SYSCON_BASE + 0x0000) +#define SYSCON_PWRCNT (SYSCON_BASE + 0x0004) +#define SYSCON_HALT (SYSCON_BASE + 0x0008) +#define SYSCON_STBY (SYSCON_BASE + 0x000c) +#define SYSCON_TEOI (SYSCON_BASE + 0x0018) +#define SYSCON_STFCLR (SYSCON_BASE + 0x001c) +#define SYSCON_CLKSET1 (SYSCON_BASE + 0x0020) +#define SYSCON_CLKSET2 (SYSCON_BASE + 0x0024) +#define SYSCON_SCRATCH0 (SYSCON_BASE + 0x0040) +#define SYSCON_SCRATCH1 (SYSCON_BASE + 0x0044) +#define SYSCON_APBWAIT (SYSCON_BASE + 0x0050) +#define SYSCON_BUSMSTRARB (SYSCON_BASE + 0x0054) +#define SYSCON_BOOTMODECLR (SYSCON_BASE + 0x0058) +#define SYSCON_DEVICECFG (SYSCON_BASE + 0x0080) +#define SYSCON_VIDCLKDIV (SYSCON_BASE + 0x0084) +#define SYSCON_MIRCLKDIV (SYSCON_BASE + 0x0088) +#define SYSCON_I2SCLKDIV (SYSCON_BASE + 0x008c) +#define SYSCON_KEYTCHCLKDIV (SYSCON_BASE + 0x0090) +#define SYSCON_CHIPID (SYSCON_BASE + 0x0094) +#define SYSCON_SYSCFG (SYSCON_BASE + 0x009c) +#define SYSCON_SYSSWLOCK (SYSCON_BASE + 0x00c0)
+#define SYSCON_PWRCNT_UART_BAUD (1 << 29)
+#define SYSCON_CLKSET_PLL_X2IPD_SHIFT 0 +#define SYSCON_CLKSET_PLL_X2FBD2_SHIFT 5 +#define SYSCON_CLKSET_PLL_X1FBD1_SHIFT 11 +#define SYSCON_CLKSET_PLL_PS_SHIFT 16 +#define SYSCON_CLKSET1_PCLK_DIV_SHIFT 18 +#define SYSCON_CLKSET1_HCLK_DIV_SHIFT 20 +#define SYSCON_CLKSET1_NBYP1 (1 << 23) +#define SYSCON_CLKSET1_FCLK_DIV_SHIFT 25
+#define SYSCON_CLKSET2_PLL2_EN (1 << 18) +#define SYSCON_CLKSET2_NBYP2 (1 << 19) +#define SYSCON_CLKSET2_USB_DIV_SHIFT 28
+#define SYSCON_CHIPID_REV_MASK 0xF0000000 +#define SYSCON_DEVICECFG_SWRST (1 << 31)
- 0x80930000 - 0x8093FFFF: Watchdog Timer
+#define WATCHDOG_OFFSET 0x940000 +#define WATCHDOG_BASE (EP93XX_APB_BASE | WATCHDOG_OFFSET)
+#define WATCHDOG_TIMER (WATCHDOG_BASE + 0x0000) +#define WATCHDOG_STATUS (WATCHDOG_BASE + 0x0004)
- 0x80950000 - 0x9000FFFF: Reserved
diff --git a/include/common.h b/include/common.h index f7c93bf..eec225c 100644 --- a/include/common.h +++ b/include/common.h @@ -502,6 +502,12 @@ ulong get_HCLK (void); ulong get_PCLK (void); ulong get_UCLK (void); #endif +#ifdef CONFIG_EP93XX +ulong get_FCLK(void); +ulong get_HCLK(void); +ulong get_PCLK(void); +ulong get_UCLK(void); +#endif
This can be combined with the existing #if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) || \ defined(CONFIG_LH7A40X) || defined(CONFIG_S3C6400) ulong get_FCLK (void); ulong get_HCLK (void); ulong get_PCLK (void); ulong get_UCLK (void); #endif
#if defined(CONFIG_LH7A40X) ulong get_PLLCLK (void); #endif diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h new file mode 100644 index 0000000..6c4576b --- /dev/null +++ b/include/configs/edb93xx.h @@ -0,0 +1,235 @@ +/*
+#ifndef __CONFIG_H +#define __CONFIG_H
+/* Initial environment and monitor configuration options. */ +#define CONFIG_ETHADDR 08:00:3E:26:0A:5B +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_IPADDR 192.168.99.225 +#define CONFIG_SERVERIP 192.168.99.1 +#define CONFIG_GATEWAYIP 192.168.99.1
+#define CONFIG_BOOTDELAY 5 +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_BOOTARGS "root=/dev/nfs console=ttyAM0,115200 ip=dhcp" +#define CONFIG_BOOTFILE "edb93xx.img"
+#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
+#ifdef CONFIG_EDB9301 +#define CONFIG_EP9301 +#elif defined(CONFIG_EDB9302) || defined(CONFIG_EDB9302A) +#define CONFIG_EP9302 +#elif defined(CONFIG_EDB9307) || defined(CONFIG_EDB9307A) +#define CONFIG_EP9307 +#elif defined(CONFIG_EDB9312) +#define CONFIG_EP9312 +#elif defined(CONFIG_EDB9315) || defined(CONFIG_EDB9315A) +#define CONFIG_EP9315 +#endif
Add an #else Either add a default board or an #error
+/* High-level configuration options */ +#define CONFIG_ARM920T 1 /* This is an ARM920T core... */ +#define CONFIG_EP93XX 1 /* in a Cirrus Logic 93xx SoC */
+#define CONFIG_SYS_CLK_FREQ 14745600 /* EP93xx has a 14.7456 clock */ +#define CONFIG_SYS_HZ 2048 /* Timer 3 set for 2KHz */ +#define CONFIG_SYS_CLKS_IN_HZ /* Everything in Hz */ +#undef CONFIG_USE_IRQ /* Don't need IRQ/FIQ */
+/* Monitor configuration */ +#include <config_cmd_default.h> +#if 0 +#undef CONFIG_CMD_BDI +#endif
Remove #if 0
+#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_XIMG
+#undef CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_FAT +#define CONFIG_CMD_JFFS2
+#if !defined USE_920T_MMU +#undef CONFIG_CMD_CACHE +#endif
Where is USE_920T_MMU being set. If you are never setting this, remove the logic.
+#ifdef CONFIG_EDB9301 +#define CONFIG_SYS_PROMPT "EDB9301> " +#elif (defined CONFIG_EDB9302) +#define CONFIG_SYS_PROMPT "EDB9302> " +#elif (defined CONFIG_EDB9302A) +#define CONFIG_SYS_PROMPT "EDB9302a> " +#elif (defined CONFIG_EDB9307) +#define CONFIG_SYS_PROMPT "EDB9307> " +#elif (defined CONFIG_EDB9307A) +#define CONFIG_SYS_PROMPT "EDB9307a> " +#elif (defined CONFIG_EDB9312) +#define CONFIG_SYS_PROMPT "EDB9312> " +#elif (defined CONFIG_EDB9315) +#define CONFIG_SYS_PROMPT "EDB9315> " +#elif (defined CONFIG_EDB9315A) +#define CONFIG_SYS_PROMPT "EDB9315a> " +#endif
+#define CONFIG_SYS_LONGHELP /* Enable "long" help in mon */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print buffer size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot argument buffer size */ +#define CONFIG_SYS_MAXARGS 16 /* Max number of command args */
+/* Serial port hardware configuration */ +#define CONFIG_PL010_SERIAL +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} +#define CONFIG_SYS_SERIAL0 0x808C0000 +#define CONFIG_SYS_SERIAL1 0x808D0000 +#define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0, (void *)CONFIG_SYS_SERIAL1}
+/* Network hardware configuration */ +#define CONFIG_DRIVER_EP93XX_MAC +#define CONFIG_MII_SUPPRESS_PREAMBLE +#define CONFIG_MII +#define CONFIG_PHY_ADDR 1 +#undef CONFIG_NETCONSOLE
+/* SDRAM configuration */ +#if defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) +#define CONFIG_NR_DRAM_BANKS 4 /* EDB9301/2 has 1 bank of SDRAM */
Fix comment to be '4 banks'
+#define PHYS_SDRAM_1 0x00000000 /* consisting of 1x Samsung */ +#define PHYS_SDRAM_SIZE_1 0x00800000 /* K4S561632E-TC75 256 Mbit */ +#define PHYS_SDRAM_2 0x01000000 /* SDRAM on a 16-bit data bus, */ +#define PHYS_SDRAM_SIZE_2 0x00800000 /* for a total of 32MB of SDRAM. */ +#define PHYS_SDRAM_3 0x04000000 /* We set the SROMLL bit on the */ +#define PHYS_SDRAM_SIZE_3 0x00800000 /* processor, resulting in this */ +#define PHYS_SDRAM_4 0x05000000 /* non-contiguous memory map. */ +#define PHYS_SDRAM_SIZE_4 0x00800000 +#define CONFIG_EDB93XX_SDCS3 +#define CONFIG_SYS_MEMTEST_START 0x00000000 +#define CONFIG_SYS_MEMTEST_END 0x00800000
+#elif defined(CONFIG_EDB9302A) +#define CONFIG_NR_DRAM_BANKS 4 /* EDB9302a has 4 banks of SDRAM */ +#define PHYS_SDRAM_1 0xc0000000 /* consisting of 1x Samsung */ +#define PHYS_SDRAM_SIZE_1 0x00800000 /* K4S561632E-TC75 256 Mbit */ +#define PHYS_SDRAM_2 0xc1000000 /* SDRAM on a 16-bit data bus, */ +#define PHYS_SDRAM_SIZE_2 0x00800000 /* for a total of 32MB of SDRAM. */ +#define PHYS_SDRAM_3 0xc4000000 /* We set the SROMLL bit on the */ +#define PHYS_SDRAM_SIZE_3 0x00800000 /* processor, resulting in this */ +#define PHYS_SDRAM_4 0xc5000000 /* non-contiguous memory map. */ +#define PHYS_SDRAM_SIZE_4 0x00800000 +#define CONFIG_EDB93XX_SDCS0 +#define CONFIG_SYS_MEMTEST_START 0xc0000000 +#define CONFIG_SYS_MEMTEST_END 0xc0800000
+#elif defined(CONFIG_EDB9307) || defined CONFIG_EDB9312 || defined(CONFIG_EDB9315) +#define CONFIG_NR_DRAM_BANKS 2 /* The EDB9307, EDB9312, and EDB9315 have */ +#define PHYS_SDRAM_1 0x00000000 /* 2 banks of SDRAM consisting of 2x Samsung */ +#define PHYS_SDRAM_SIZE_1 0x02000000 /* K4S561632E-TC75 256 Mbit on a 32-bit data */ +#define PHYS_SDRAM_2 0x04000000 /* bus, for a total of 64 MB of SDRAM. */ +#define PHYS_SDRAM_SIZE_2 0x02000000 +#define CONFIG_EDB93XX_SDCS3 +#define CONFIG_SYS_MEMTEST_START 0x00000000 +#define CONFIG_SYS_MEMTEST_END 0x02000000
+#elif defined(CONFIG_EDB9307A) || defined(CONFIG_EDB9315A) +#define CONFIG_NR_DRAM_BANKS 2 /* The EDB9307A and EDB9315A have */ +#define PHYS_SDRAM_1 0xc0000000 /* 2 banks of SDRAM consisting of 2x Samsung */ +#define PHYS_SDRAM_SIZE_1 0x02000000 /* K4S561632E-TC75 256 Mbit on a 32-bit data */ +#define PHYS_SDRAM_2 0xc4000000 /* bus, for a total of 64 MB of SDRAM. */ +#define PHYS_SDRAM_SIZE_2 0x02000000 +#define CONFIG_EDB93XX_SDCS0 +#define CONFIG_SYS_MEMTEST_START 0xc0000000 +#define CONFIG_SYS_MEMTEST_END 0xc2000000 +#endif
+#if defined(CONFIG_EDB93XX_SDCS3) +#define CONFIG_SYS_LOAD_ADDR 0x01000000 /* Default load address */ +#elif defined(CONFIG_EDB93XX_SDCS0) +#define CONFIG_SYS_LOAD_ADDR 0xc1000000 /* Default load address */ +#endif
+#define LINUX_BOOT_PARAM_ADDR (PHYS_SDRAM_1 + 0x100) /* Must match kernel config */
+/* Run-time memory allocatons */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_STACKSIZE (128 * 1024)
+#if defined(CONFIG_USE_IRQ) +#define CONFIG_STACKSIZE_IRQ (4 * 1024) +#define CONFIG_STACKSIZE_FIQ (4 * 1024) +#endif
+#define CONFIG_SYS_MALLOC_LEN (512 * 1024)
- FLASH and environment organization
- The EDB9301 and EDB9302(a) have 1 bank of flash memory at 0x60000000
- consisting of 1x Intel TE28F128J3C-150 128 Mbit flash on a 16-bit data bus,
- for a total of 16 MB of CFI-compatible flash.
- The EDB9307(a), EDB9312, and EDB9315(a) have 1 bank of flash memory at
- 0x60000000 consisting of 2x Micron MT28F128J3-12 128 Mbit flash on a 32-bit
- data bus, for a total of 32 MB of CFI-compatible flash.
EDB9301/02(a) EDB9307(a)/12/15(a)
- 0x00000000 - 0x0003FFFF u-boot u-boot
- 0x00040000 - 0x0005FFFF environment #1 environment #1
- 0x00060000 - 0x0007FFFF unused environment #1 (continued)
- 0x00080000 - 0x0009FFFF environment #2 environment #2
- 0x000A0000 - 0x000BFFFF unused environment #2 (continued)
- 0x000C0000 - 0x000FFFFF unused unused
- 0x00100000 - 0x002FFFFF kernel image #1 kernel image #1
- 0x00300000 - 0x004FFFFF kernel image #2 kernel image #2
- 0x00500000 - 0x00FFFFFF JFFS2 JFFS2
- 0x01000000 - 0x01FFFFFF not present JFFS2 (continued)
+#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 128
+#define PHYS_FLASH_1 0x60000000 +#define CONFIG_SYS_FLASH_BASE (PHYS_FLASH_1) +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_MONITOR_LEN (256 * 1024)
+#define CONFIG_ENV_OVERWRITE /* Vendor params unprotected */ +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR 0x60040000 +#if (defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) ||\
defined(CONFIG_EDB9302A))
+#define CONFIG_ENV_SECT_SIZE 0x00020000 +#elif (defined(CONFIG_EDB9307) || defined(CONFIG_EDB9307A) ||\
defined(CONFIG_EDB9312) || defined(CONFIG_EDB9315) ||\
defined(CONFIG_EDB9315A))
+#define CONFIG_ENV_SECT_SIZE 0x00040000 +#endif +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE)
+#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
+#define CONFIG_SYS_JFFS2_FIRST_BANK 0 +#if (defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) ||\
+#define CONFIG_SYS_JFFS2_FIRST_SECTOR 28 +#elif (defined(CONFIG_EDB9307) || defined(CONFIG_EDB9307A) ||\
+#define CONFIG_SYS_JFFS2_FIRST_SECTOR 14 +#endif
+#define CONFIG_SYS_JFFS2_NUM_BANKS 1
+#endif /* !defined (__CONFIG_H) */
Dear Matthias Kaehlcke,
In message 20091206145444.GE22689@darwin you wrote:
Add support for the Cirrus EP93xx platform and EDB93xx boards
In addition to Tom's comments:
@@ -2429,6 +2429,42 @@ TQM834x_config: unconfig vme8349_config: unconfig @$(MKCONFIG) $(@:_config=) ppc mpc83xx vme8349 esd
+edb93xx_config \ +edb9301_config \ +edb9302_config \ +edb9302a_config \ +edb9307_config \ +edb9307a_config \ +edb9315a_config: unconfig
Keep all such lists sorted!
- @if [ "$(findstring 01_,$@)" ] ; then \
echo "#define CONFIG_EDB9301" >> $(obj)include/config.h ; \
- elif [ "$(findstring 02_,$@)" ] ; then \
echo "#define CONFIG_EDB9302" >> $(obj)include/config.h ; \
- elif [ "$(findstring 02a_,$@)" ] ; then \
echo "#define CONFIG_EDB9302A" >> $(obj)include/config.h ; \
- elif [ "$(findstring 07_,$@)" ] ; then \
echo "#define CONFIG_EDB9307" >> $(obj)include/config.h ; \
- elif [ "$(findstring 07a_,$@)" ] ; then \
echo "#define CONFIG_EDB9307A" >> $(obj)include/config.h ; \
- elif [ "$(findstring 12_,$@)" ] ; then \
echo "#define CONFIG_EDB9312" >> $(obj)include/config.h ; \
- elif [ "$(findstring 15_,$@)" ] ; then \
echo "#define CONFIG_EDB9315" >> $(obj)include/config.h ; \
- elif [ "$(findstring 15a_,$@)" ] ; then \
echo "#define CONFIG_EDB9315A" >> $(obj)include/config.h ; \
- fi ;
Please don't do scripting in the Makefile. Move this logic into your board config file instead.
- @$(MKCONFIG) -a edb93xx arm arm920t edb93xx NULL ep93xx
- @if [ "$(findstring 01_,$@)" ] || [ "$(findstring 02_,$@)" ]; then \
echo "TEXT_BASE = 0x05400000" >> $(obj)include/config.mk ; \
- elif [ "$(findstring 02a_,$@)" ]; then \
echo "TEXT_BASE = 0xc5400000" >> $(obj)include/config.mk ; \
- elif [ "$(findstring 07_,$@)" ] || [ "$(findstring 12_,$@)" ] || [ "$(findstring 15_,$@)" ]; then \
echo "TEXT_BASE = 0x01f00000" >> $(obj)include/config.mk ; \
- elif [ "$(findstring 07a_,$@)" ] || [ "$(findstring 15a_,$@)" ]; then \
echo "TEXT_BASE = 0xc1f00000" >> $(obj)include/config.mk ; \
- fi ;
Ditto.
- /* Machine number, as defined in linux/arch/arm/tools/mach-types
- gd->bd->bi_arch_number = 462;
- gd->bd->bi_arch_number = 538;
- gd->bd->bi_arch_number = 1127;
- gd->bd->bi_arch_number = 607;
- gd->bd->bi_arch_number = 1128;
- gd->bd->bi_arch_number = 451;
- gd->bd->bi_arch_number = 463;
+#elif defined(CONFIG_EDB9315A)
- gd->bd->bi_arch_number = 772;
Please use symbolic constants from <asm/mach-types.h>, and move the logic into your board config file.
+int dram_init(void) +{
- DECLARE_GLOBAL_DATA_PTR;
- unsigned int *src, *dst;
- int i;
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE_1;
+#ifdef PHYS_SDRAM_2
- gd->bd->bi_dram[1].start = PHYS_SDRAM_2;
- gd->bd->bi_dram[1].size = PHYS_SDRAM_SIZE_2;
+#ifdef PHYS_SDRAM_3
- gd->bd->bi_dram[2].start = PHYS_SDRAM_3;
- gd->bd->bi_dram[2].size = PHYS_SDRAM_SIZE_3;
+#ifdef PHYS_SDRAM_4
- gd->bd->bi_dram[3].start = PHYS_SDRAM_4;
- gd->bd->bi_dram[3].size = PHYS_SDRAM_SIZE_4;
Make sure to use get_ram_size() on all banks for checking and auto-sizing.
diff --git a/board/edb93xx/flash_cfg.S b/board/edb93xx/flash_cfg.S new file mode 100644 index 0000000..aa61a3c --- /dev/null +++ b/board/edb93xx/flash_cfg.S
+.globl flash_cfg +flash_cfg:
- /* configure smc bank 6 (Intel TE28F128J3D75 Strata Flash)
* ebibrkdis: 0, mw: 0x1 (16 bit), pme: 0, wp: 0, wst2: 2(+1),
* wst1: 5(+1), rble: 1, idcy: 2(+1)
* TODO: we don't enable page mode for now
- ldr r0, =SMC_BCR6
- ldr r1, =(2 << SMC_BCR_IDCY_SHIFT | 5 << SMC_BCR_WST1_SHIFT | \
SMC_BCR_BLE | 2 << SMC_BCR_WST2_SHIFT | 1 << SMC_BCR_MW_SHIFT)
- str r1, [r0]
- mov pc, lr
Why is this written in assembler? Please rewrite in C.
diff --git a/board/edb93xx/pll_cfg.S b/board/edb93xx/pll_cfg.S new file mode 100644 index 0000000..ae69a7d --- /dev/null +++ b/board/edb93xx/pll_cfg.S @@ -0,0 +1,93 @@
- /* the user's guide recommends to wait at least 1 ms for PLL2 to
* stabilize, but Cirrus' Redboot doesn't do that, either
- mov pc, lr
Why don't you write this as C code? And why do you copy bad (or at least not recommended behaviour, even if it seems to work for you? Adding a "udelay(1000);" seems so trivial that I wonder why you don;t follow the docs?
diff --git a/board/edb93xx/sdram_cfg.S b/board/edb93xx/sdram_cfg.S new file mode 100644 index 0000000..752bb72 --- /dev/null +++ b/board/edb93xx/sdram_cfg.S
Stop here. Why again assembler?
U-Boot uses assembler only when ther eis no reasonable way to implement the code in C, and I don't see any such justification here. Please rewrite all this in C.
diff --git a/board/edb93xx/u-boot.lds b/board/edb93xx/u-boot.lds new file mode 100644 index 0000000..76caef3 --- /dev/null +++ b/board/edb93xx/u-boot.lds
This looks pretty generic. Please explain why exactly you think you need a board specific linker script here, instead of using the generic one?
diff --git a/cpu/arm920t/ep93xx/Makefile b/cpu/arm920t/ep93xx/Makefile new file mode 100644 index 0000000..9763e15 --- /dev/null +++ b/cpu/arm920t/ep93xx/Makefile @@ -0,0 +1,55 @@ +# vim: set ts=8 sw=8 noet: +# +# Cirrus Logic EP93xx CPU-specific Makefile +# +# Copyright (C) 2004, 2005 +# Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com +# +# Copyright (C) 2006 +# Dominic Rath Dominic.Rath@gmx.de
Hm... Your signed-off-by: line does not mention Cory Tusar nor Dominic Rath, so which part exactly do these have in the code you are submitting here?
diff --git a/cpu/arm920t/ep93xx/cpu.c b/cpu/arm920t/ep93xx/cpu.c new file mode 100644 index 0000000..3989ee8 --- /dev/null +++ b/cpu/arm920t/ep93xx/cpu.c
In which cases would this #define be needed? Your Makefiles should only build files which are needed in the first place - such a #define here seems wrong to me.
+/* All EP93xx variants have 16 KiB I-cache. */ +extern int checkicache(void) +{
- return 16 << 10;
+/* All EP93xx variants have 16 KiB D-cache. */ +extern int checkdcache(void) +{
- return 16 << 10;
If you need something like this, then provide it as static inline functions in the respective header file.
+/* This is a nop on ARM, and is included here for completeness only. */ +extern void upmconfig(unsigned int upm, unsigned int *table, unsigned int size) +{
- /* nop */
Get rid of unused crap, please.
+/* We reset the CPU by generating a 1-->0 transition on DeviceCfg bit 31. */ +extern void reset_cpu(ulong addr) +{
- uint32_t value;
- /* Unlock DeviceCfg and set SWRST */
- writel(0xAA, SYSCON_SYSSWLOCK);
- value = readl(SYSCON_DEVICECFG);
- value |= SYSCON_DEVICECFG_SWRST;
- writel(value, SYSCON_DEVICECFG);
- /* Unlock DeviceCfg and clear SWRST */
- value &= ~SYSCON_DEVICECFG_SWRST;
- /* Dying... */
- while (1)
; /* nop */
+#endif /* defined(CONFIG_EP93XX) */ diff --git a/cpu/arm920t/ep93xx/eth.c b/cpu/arm920t/ep93xx/eth.c new file mode 100644 index 0000000..513c221 --- /dev/null +++ b/cpu/arm920t/ep93xx/eth.c
- Send a trace message to the terminal.
+#if 0
Here and elsewhere: please do not add dead code.
+struct rx_status {
- union {
uint32_t word1;
struct {
unsigned:8;
unsigned hti:6;
unsigned:1;
unsigned crci:1;
unsigned crce:1;
unsigned edata:1;
unsigned runt:1;
unsigned fe:1;
unsigned oe:1;
unsigned rx_err:1;
unsigned am:2;
unsigned:4;
unsigned eob:1;
unsigned eof:1;
unsigned rwe:1;
unsigned rfp:1;
Do not use bit fields. These are unportable and a major PITA in any case.
- union {
uint32_t word2;
struct {
unsigned frame_length:16;
unsigned buffer_index:15;
unsigned rfp:1;
+} __attribute__((packed));
- Transmit descriptor queue entry
+struct tx_descriptor {
I think this whole declarations stuff belongs to some separate header file.
- Dump ep93xx_mac values to the terminal.
+inline void dump_dev(void) +{ +#if defined(EP93XX_MAC_DEBUG)
Don't compile the function at all when debug is not selected. Ditto for the other debug functions.
This line just adds bloat.
Why is the file name "timer.c" when it's interrupt support actually?
Hm.... does not seem to be too much of interrupt support, so please fix the comments!
This needs to be adapted to the current implementation. Make this __udelay() here.
Get rid of all this address / offset based register accesses. Turn this into a C struct instead. Please fix globally.
NAK. We don't allow board specific settings like these.
Also note that the MAC address seems to be hijacked - it actually belongs to the codex corporation. Please make sure to get your own set of MAC addresses.
CONFIG_SYS_HZ must always and everywhere be 1000.
This was removed a long time ago. Don't re-introduce it.
See above - don;t add dead code.
The comment is all single line comments, so it is supposed to refer to the actual code in the same line. This is obviously not the case. Please fix.
Has this actually been tested?
Hm... this looks very much like being completely unmaintainable.
Please simplify the code - in your own interest.
hi wolfgang,
thanks a lot for you review, below some comments and questions
El Mon, Dec 07, 2009 at 08:46:29PM +0100 Wolfgang Denk ha dit:
ok
- fi ;
i got the inspiration to handle it this way from the U-Boot Makefile (Total5100, TQM5200, et al). could you please point me to an example of a well done multi-board configuration file?
- fi ;
same here, further i don't understand how to set the TEXT_BASE from the board configuration file. any pointer?
ok
- int i;
ok
- ldr r0, =SMC_BCR6
- str r1, [r0]
- mov pc, lr
ok
- mov pc, lr
ok
ignorance ...
i'm just starting to get my feet wet with low level initialization and supposed sdram setup is always done in assembler.
the ep93xx expects to find the pattern 'CRUS' (in ASCII) at position 0x1000. is there a more canonical way to achieve this?
as i stated in the patch description this patch is based on a patch (http://article.gmane.org/gmane.linux.ports.arm.cirrus/722) from Dominic Rath.
my contribution consists mainly in porting the patch to the current U-Boot version, add support for more boards, tweak pll settings, introduce the use of i/o accessors, adding comments and trying to bring the patch in a shape ready for mainline.
as the header files contain a GPL header i interpreted that it's ok to submit them without signed-off-by lines from the original authors (what doesn't mean that i claim authorship on their work):
"The contribution is based upon previous work that, to the best of my knowledge, is covered under an appropriate open source license and I have the right under that license to submit that work with modifications, whether created in whole or in part by me, under the same open source license (unless I am permitted to submit under a different license), as indicated in the file"
(Developer's Certificate of Origin 1.1, point b)
agreed
- return 16 << 10;
- return 16 << 10;
ok
- /* nop */
ok
- uint32_t value;
- /* Dying... */
- while (1)
; /* nop */
+#if 0
ok
+struct rx_status {
- union {
uint32_t word1;
struct {
unsigned:8;
unsigned hti:6;
unsigned:1;
unsigned crci:1;
unsigned crce:1;
unsigned edata:1;
unsigned runt:1;
unsigned fe:1;
unsigned oe:1;
unsigned rx_err:1;
unsigned am:2;
unsigned:4;
unsigned eob:1;
unsigned eof:1;
unsigned rwe:1;
unsigned rfp:1;
ok
- union {
uint32_t word2;
struct {
unsigned rfp:1;
ok
ok
ok
bad comment, will fix
ok
ok
ok
hm, a whole bunch of boards do this, so i thought that's the way to go. what is the correct thing, not defining this values at all?
good point
i'm not working for cirrus, so i think getting my own set of MAC address is not really what i'm supposed to do. any further advice?
ok
ok
ok
ok
gotcha, will fix
i'm not sure if i understand what you mean bt simplifying in this case
do you propose something like
#ifdef CONFIG_EDB9301 #define CONFIG_ENV_SECT_SIZE 0x00020000 #elif defined(CONFIG_EDB9302) #define CONFIG_ENV_SECT_SIZE 0x00020000 #elif ...
#ifdef CONFIG_EDB9301 #define CONFIG_SYS_JFFS2_FIRST_SECTOR 28 #elif defined(CONFIG_EDB9302) #define CONFIG_SYS_JFFS2_FIRST_SECTOR 28 #elif ...
or even
#ifdef CONFIG_EDB9301 #define CONFIG_ENV_SECT_SIZE 0x00020000 #define CONFIG_SYS_JFFS2_FIRST_SECTOR 28 #elif ...
though the settings aren't related?
with the current approach i tried to avoid redundancy in the declarations, with the result of more complex conditions. please give me a pointer to the preferred way to do this kind of stuff.
thanks again for your time and for helping me to get the patch into the right shape.
i'll address the issues you and tom brought up and submit a second revision of the patch at a later time
best regards
This is the old style, which we want to get rid of.
See for example here:
2439 MPC8536DS_NAND_config \ 2440 MPC8536DS_SDCARD_config \ 2441 MPC8536DS_SPIFLASH_config \ 2442 MPC8536DS_36BIT_config \ 2443 MPC8536DS_config: unconfig 2444 @$(MKCONFIG) -t $(@:_config=) MPC8536DS ppc mpc85xx mpc8536ds freescale
See for example board/freescale/mpc8536ds/config.mk
There is no reason for assembly. We almost always do this in C.
This is a processor feature, right? So it's the same for all ep93xx based boards? Then why put that in a board specific directory?
It's OK, but it would be even better if we had their S-o-b's, too. Maybe you can ask them?
Right. You don't really want to have several boards all using the same MAC address...
It's up to the hardware manufacturer to provide MAC addresses.
No, that would even be worse.
or even
It would still be better to have everything related to one configuration bundled together - otherwise you will not be able to see in the code which settings apply to which board.
Also note that something like CONFIG_SYS_JFFS2_FIRST_SECTOR is pretty much unlucky - you make yoursself dependent on specific hardware features. Why not use for example an offset, so flash chips with other sector sizes can be dropped in?
Eventually you want to check if mtdparts would not be a better approach here?
Keep the code simple, so you can read it without too much thinking.
Hello Wolfgang,
El Tue, Dec 08, 2009 at 12:51:47AM +0100 Wolfgang Denk ha dit:
i am starting to look at this issue and it seems i need some more guidance:
before relocating U-Boot to RAM for ARM920T processors a jump to the label *lowlevel_init* is performed, where RAM timings are supposed to be set up. in the patch i sent these operations are performed in assembly and you asked me to rewrite them in C.
i'm relativly new to low-level setup, so i apologize if the following question sounds plain stupid to you: is C really available at this point? if my interpretation of the code in cpu/arm920t/start.S is correct, C code starts at start_armboot, after relocation of U-Boot. and after that point i'd think it's to late to change RAM timings as U-Boot is running from RAM.
could you please give some advice to clear my confusion and maybe provide a pointer to a board/cpu which handles low-level setup in the intended way?
thanks
Matthias Kaehlcke wrote:
Hello Wolfgang,
thanks
I would've thought that you need a working stack before you can run 'C' code so you'd need the RAM timing set up before you could run C code hence you'd need to set the RAM timings up in assembler. Between start-up and the point the RAM timing gets configured it's running with the default values of the RAM timing registers which probably aren't ideal for the particular RAM chips on the board.
At the moment the RAM timings for a specific board are set in the board-specific lowlevel_init assembler code. Any change would affect all s3c24x0 boards as well as the new edb93xx board.
Kevin
Dear "kevin.morfitt@fearnside-systems.co.uk",
In general this is correct, but then - what does a C program need a stack for? To push register contents and local variables on it. So if you make sure not to use any, it works even without a stack ;-)
This is not actually true. You _can_ do this in C even here.
Also, some processors and some boards provide on-chip-memory and/or static RAM areas that can be used for an initial stack and data, and on some processors we can lock parts of the (data) cache and use it as RAM.
There is many ways to do this.
I don't see how an implementation for a specific CPU / board would cause changes to other processors?
After relocation we have a full-blown, "normal" C runtime environment. Before that, you can use C as well, if you mind the restrictions (like data and bss not being available/writable yet, no real stack, etc.).
If you check theinit code in cpu/arm920t/start.S you will notice that one of the really early things it does is calling coloured_LED_init() and red_LED_on(). Note that these functions are implemented in C.
What can be done here, should also be possible in your case.
hi wolfgang,
El Tue, Dec 08, 2009 at 09:33:18PM +0100 Wolfgang Denk ha dit:
thanks a lot for your explications and for providing an example
best regards
hi,
as suggested i reimplemented the flash, pll and sdram initialization in C, what is working so far.
now i am trying to reimplement the lowlevel_init() function in C. this seems to be an easy task, but gcc insists to use the stack, which isn't set up at this point
the C implementation is:
void lowlevel_init(void) { red_LED_on(); green_LED_on();
/* Configure flash wait states before we switch to the PLL */ flash_cfg();
/* Set up PLL */ pll_cfg();
green_LED_off();
/* Setup SDRAM */ sdram_cfg();
green_LED_on(); red_LED_off();
/* FIXME: we use async mode for now */ __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 0\n" "orr r0, r0, #0xc0000000\n" "mcr p15, 0, r0, c1, c0, 0"); }
which results in the following machine/assembly code:
c1f01094 <lowlevel_init>: c1f01094: e52de004 push {lr} ; (str lr, [sp, #-4]!) c1f01098: e24dd004 sub sp, sp, #4 ; 0x4 c1f0109c: ebffffe4 bl c1f01034 <red_LED_on> c1f010a0: ebffffef bl c1f01064 <green_LED_on> c1f010a4: eb00483d bl c1f131a0 <flash_cfg> c1f010a8: eb004842 bl c1f131b8 <pll_cfg> c1f010ac: ebfffff2 bl c1f0107c <green_LED_off> c1f010b0: eb004852 bl c1f13200 <sdram_cfg> c1f010b4: ebffffea bl c1f01064 <green_LED_on> c1f010b8: ebffffe3 bl c1f0104c <red_LED_off> c1f010bc: ee110f10 mrc 15, 0, r0, cr1, cr0, {0} c1f010c0: e3800103 orr r0, r0, #-1073741824 ; 0xc0000000 c1f010c4: ee010f10 mcr 15, 0, r0, cr1, cr0, {0} c1f010c8: e28dd004 add sp, sp, #4 ; 0x4 c1f010cc: e8bd8000 pop {pc}
is there a way to convince the compiler not to use the stack, or is it for some reason impossible to translate this routine to C without having a stack?
kind regards
Matthias Kaehlcke
Tom
