[PATCH] spi: zynqmp_qspi: Add support for 64-bit read/write
When we pass the 64-bit address to read/write, only lower 32-bit address is getting updated. Program the upper 32-bit address in the DMA destination memory address MSBs register, which can handle upto 44-bit destination address.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com ---
drivers/spi/zynqmp_gqspi.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/zynqmp_gqspi.c b/drivers/spi/zynqmp_gqspi.c index 48eff777df..10f6b85cd3 100644 --- a/drivers/spi/zynqmp_gqspi.c +++ b/drivers/spi/zynqmp_gqspi.c @@ -662,7 +662,7 @@ static int zynqmp_qspi_start_io(struct zynqmp_qspi_priv *priv, static int zynqmp_qspi_start_dma(struct zynqmp_qspi_priv *priv, u32 gen_fifo_cmd, u32 *buf) { - u32 addr; + unsigned long addr; u32 size; u32 actuallen = priv->len; u32 totallen = priv->len; @@ -678,7 +678,9 @@ static int zynqmp_qspi_start_dma(struct zynqmp_qspi_priv *priv, totallen -= priv->len; /* Save remaining bytes length to read */ actuallen = priv->len; /* Actual number of bytes reading */
- writel((unsigned long)buf, &dma_regs->dmadst); + writel(lower_32_bits((unsigned long)buf), &dma_regs->dmadst); + writel(upper_32_bits((unsigned long)buf) & GENMASK(11, 0), + &dma_regs->dmadstmsb); writel(roundup(priv->len, GQSPI_DMA_ALIGN), &dma_regs->dmasize); writel(GQSPI_DMA_DST_I_STS_MASK, &dma_regs->dmaier); addr = (unsigned long)buf;
pá 25. 11. 2022 v 15:00 odesílatel Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com napsal:
u32 addr;
-- 2.17.1
Applied. M
Michal Simek
