[GIT PULL] Please pull u-boot-imx-master-20250120
Hi Tom,
Please pull from u-boot-imx/master, thanks.
The following changes since commit 639cd409987acf173eaffebe7876968b42fd7c32:
Merge patch series "add the support of sha256_hmac and sha256_hkdf" (2025-01-18 17:13:01 -0600)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20250120
for you to fetch changes up to e38a490810af76169f7cf1d298966ea9ba3c005b:
phycore-imx8mp: Enable CAAM in spl (2025-01-20 08:41:38 -0300)
u-boot-imx-master-20250120 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/24263
- Add i.MX95 EMDIO support - Guard binman nodes with CONFIG_OPTEE on imx8m - Enable CAAM in phycore-imx8mp SPL. - Fix Fix NULL dereference in imx_pinctrl_probe(). ---------------------------------------------------------------- Alice Guo (2): net: fsl_enetc: add i.MX95 EMDIO support net: fsl_enetc: Update enetc driver to support i.MX95
Fabio Estevam (1): imx8m: Guard binman nodes with CONFIG_OPTEE
Jesse Taube (1): pinctrl: imx: Fix NULL dereference in imx_pinctrl_probe()
Leonard Anderweit (1): phycore-imx8mp: Enable CAAM in spl
Marek Vasut (11): net: fsl_enetc: Introduce enetc_is_ls1028a() net: fsl_enetc: Remove ifdef around enetc_set_ierb_primary_mac() net: fsl_enetc: Fold DT MAC address update into enetc_set_ierb_primary_mac() net: fsl_enetc: Pass udevice pointer into enetc_enable_si_port() net: fsl_enetc: Rename the driver and related structures net: fsl_enetc: Introduce enetc_dev_id() net: fsl_enetc: Inline register accessors net: fsl_enetc: Split register accessors net: fsl_enetc: Introduce driver data net: fsl_enetc: Pass udevice pointer to accessors net: fsl_enetc: Add initial netc-blk-ctrl driver support
arch/arm/dts/imx8mm-u-boot.dtsi | 6 + arch/arm/dts/imx8mn-u-boot.dtsi | 6 + arch/arm/dts/imx8mp-u-boot.dtsi | 6 + arch/arm/dts/imx8mq-u-boot.dtsi | 6 + board/phytec/phycore_imx8mp/spl.c | 2 + configs/phycore-imx8mp_defconfig | 2 - drivers/net/Kconfig | 14 + drivers/net/Makefile | 1 + drivers/net/fsl_enetc.c | 487 +++++++++++++++++++++++++++++----- drivers/net/fsl_enetc.h | 88 +++--- drivers/net/fsl_enetc_mdio.c | 20 +- drivers/net/fsl_enetc_netc_blk_ctrl.c | 346 ++++++++++++++++++++++++ drivers/pinctrl/nxp/pinctrl-imx.c | 4 +- 13 files changed, 876 insertions(+), 112 deletions(-) create mode 100644 drivers/net/fsl_enetc_netc_blk_ctrl.c
Merged into u-boot/master, thanks!
Fabio Estevam
