[U-Boot] [PATCH] cmd: mmc: add mmc partconf read capability
This patch allows to show the EXT_CSD[179] partition_config register info, just by specifying the dev param:
U-Boot> mmc partconf 0 EXT_CSD[179], PARTITION_CONFIG: BOOT_ACK: 0x0 BOOT_PARTITION_ENABLE: 0x0 PARTITION_ACCESS: 0x0
Signed-off-by: Angelo Dureghello angelo@sysam.it Signed-off-by: Anatolij Gustschin agust@denx.de --- Changes for v4: - rebase on v2017.09-rc1 - don't read the PARTITION_CONFIG register again, show the PARTITION_CONFIG info as saved during mmc device initialisation - update the part_config field of the mmc device when the partconf setting command succeeded - output values in hex format, as these are register bit fields
Changes for v3: - fixed command output to a single printf - fixed return codes - fixed macroes with parenthesis around parameter Changes for v2: - fixed commit message - added white lines in cmd/mmc.c - fixed help in cmd/mmc.c
cmd/mmc.c | 38 ++++++++++++++++++++++++++++++++------ drivers/mmc/mmc_boot.c | 17 +++++++++++++---- include/mmc.h | 4 ++++ 3 files changed, 49 insertions(+), 10 deletions(-)
diff --git a/cmd/mmc.c b/cmd/mmc.c index f7b7568..00697fc 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -643,6 +643,28 @@ static int do_mmc_boot_resize(cmd_tbl_t *cmdtp, int flag, printf("EMMC RPMB partition Size %d MB\n", rpmbsize); return CMD_RET_SUCCESS; } + +static int mmc_partconf_print(struct mmc *mmc) +{ + u8 ack, access, part; + + if (mmc->part_config == MMCPART_NOAVAILABLE) { + printf("No part_config info for ver. 0x%x\n", mmc->version); + return CMD_RET_FAILURE; + } + + access = EXT_CSD_EXTRACT_PARTITION_ACCESS(mmc->part_config); + ack = EXT_CSD_EXTRACT_BOOT_ACK(mmc->part_config); + part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); + + printf("EXT_CSD[179], PARTITION_CONFIG:\n" + "BOOT_ACK: 0x%x\n" + "BOOT_PARTITION_ENABLE: 0x%x\n" + "PARTITION_ACCESS: 0x%x\n", ack, part, access); + + return CMD_RET_SUCCESS; +} + static int do_mmc_partconf(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -650,13 +672,10 @@ static int do_mmc_partconf(cmd_tbl_t *cmdtp, int flag, struct mmc *mmc; u8 ack, part_num, access;
- if (argc != 5) + if (argc != 2 && argc != 5) return CMD_RET_USAGE;
dev = simple_strtoul(argv[1], NULL, 10); - ack = simple_strtoul(argv[2], NULL, 10); - part_num = simple_strtoul(argv[3], NULL, 10); - access = simple_strtoul(argv[4], NULL, 10);
mmc = init_mmc_device(dev, false); if (!mmc) @@ -667,6 +686,13 @@ static int do_mmc_partconf(cmd_tbl_t *cmdtp, int flag, return CMD_RET_FAILURE; }
+ if (argc == 2) + return mmc_partconf_print(mmc); + + ack = simple_strtoul(argv[2], NULL, 10); + part_num = simple_strtoul(argv[3], NULL, 10); + access = simple_strtoul(argv[4], NULL, 10); + /* acknowledge to be sent during boot operation */ return mmc_set_part_conf(mmc, ack, part_num, access); } @@ -832,8 +858,8 @@ U_BOOT_CMD( " - Set the BOOT_BUS_WIDTH field of the specified device\n" "mmc bootpart-resize <dev> <boot part size MB> <RPMB part size MB>\n" " - Change sizes of boot and RPMB partitions of specified device\n" - "mmc partconf dev boot_ack boot_partition partition_access\n" - " - Change the bits of the PARTITION_CONFIG field of the specified device\n" + "mmc partconf dev [boot_ack boot_partition partition_access]\n" + " - Show or change the bits of the PARTITION_CONFIG field of the specified device\n" "mmc rst-function dev value\n" " - Change the RST_n_FUNCTION field of the specified device\n" " WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.\n" diff --git a/drivers/mmc/mmc_boot.c b/drivers/mmc/mmc_boot.c index ac6f56f..6d77ce9 100644 --- a/drivers/mmc/mmc_boot.c +++ b/drivers/mmc/mmc_boot.c @@ -100,10 +100,19 @@ int mmc_set_boot_bus_width(struct mmc *mmc, u8 width, u8 reset, u8 mode) */ int mmc_set_part_conf(struct mmc *mmc, u8 ack, u8 part_num, u8 access) { - return mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_PART_CONF, - EXT_CSD_BOOT_ACK(ack) | - EXT_CSD_BOOT_PART_NUM(part_num) | - EXT_CSD_PARTITION_ACCESS(access)); + int ret; + u8 part_conf; + + part_conf = EXT_CSD_BOOT_ACK(ack) | + EXT_CSD_BOOT_PART_NUM(part_num) | + EXT_CSD_PARTITION_ACCESS(access); + + ret = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_PART_CONF, + part_conf); + if (!ret) + mmc->part_config = part_conf; + + return ret; }
/* diff --git a/include/mmc.h b/include/mmc.h index 00576fa..4277cb0 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -221,6 +221,10 @@ #define EXT_CSD_BOOT_PART_NUM(x) (x << 3) #define EXT_CSD_PARTITION_ACCESS(x) (x << 0)
+#define EXT_CSD_EXTRACT_BOOT_ACK(x) (((x) >> 6) & 0x1) +#define EXT_CSD_EXTRACT_BOOT_PART(x) (((x) >> 3) & 0x7) +#define EXT_CSD_EXTRACT_PARTITION_ACCESS(x) ((x) & 0x7) + #define EXT_CSD_BOOT_BUS_WIDTH_MODE(x) (x << 3) #define EXT_CSD_BOOT_BUS_WIDTH_RESET(x) (x << 2) #define EXT_CSD_BOOT_BUS_WIDTH_WIDTH(x) (x)
Sorry for late. Applied to u-boot-mmc. Thanks!
Best Regards, Jaehoon Chung
Changes for v4:
Changes for v3:
Changes for v2:
- u8 ack, access, part;
- if (mmc->part_config == MMCPART_NOAVAILABLE) {
- access = EXT_CSD_EXTRACT_PARTITION_ACCESS(mmc->part_config);
- ack = EXT_CSD_EXTRACT_BOOT_ACK(mmc->part_config);
- part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config);
- printf("EXT_CSD[179], PARTITION_CONFIG:\n"
"BOOT_ACK: 0x%x\n"
- return CMD_RET_SUCCESS;
- if (argc != 5)
- if (argc == 2)
- /* acknowledge to be sent during boot operation */ return mmc_set_part_conf(mmc, ack, part_num, access);
- "mmc partconf dev [boot_ack boot_partition partition_access]\n"
- " - Show or change the bits of the PARTITION_CONFIG field of the specified device\n" "mmc rst-function dev value\n" " - Change the RST_n_FUNCTION field of the specified device\n" " WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.\n"
- int ret;
- u8 part_conf;
- part_conf = EXT_CSD_BOOT_ACK(ack) |
- ret = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_PART_CONF,
part_conf);
- if (!ret)
- return ret;
Anatolij Gustschin
Jaehoon Chung
