[U-Boot] Please pull u-boot-video/master
Hi Tom,
The following changes since commit 40a808f173008729a0c631ab84693b6a2b0dcfc9:
ARCv2: SLC: Make sure busy bit is set properly on SLC flushing (2017-04-11 17:54:31 +0300)
git://git.denx.de/u-boot-video.git master
for you to fetch changes up to 7682736c891d2b6f0cce167f4ecd55d2df0f562f:
video: Fix crash when scroll screen (2017-04-14 16:11:38 +0200)
---------------------------------------------------------------- Sanchayan Maity (1): Convert CONFIG_FSL_DCU_FB to Kconfig
Songjun Wu (2): at91: video: Support driver-model for the HLCD driver at91: video: DT binding for HLCDC driver
Stefan Agner (5): video: fsl_dcu_fb: fix framebuffer to the end of memory video: fsl_dcu_fb: Enable pixel clock after initialization video: fsl_dcu_fb: Fix DCU_MODE_BLEND_ITER setting video: fsl_dcu_fb: add additional modes for DCU board: toradex: colibri_vf: Add DCU support for Colibri Vybrid
eric.gao@rock-chips.com (1): video: Fix crash when scroll screen
arch/arm/cpu/armv7/ls102xa/soc.c | 2 +- arch/arm/include/asm/arch-vf610/crm_regs.h | 14 + arch/arm/include/asm/arch-vf610/imx-regs.h | 2 + arch/arm/include/asm/arch-vf610/iomux-vf610.h | 31 ++ arch/arm/include/asm/imx-common/iomux-v3.h | 3 + board/freescale/ls1021aiot/Makefile | 2 +- board/freescale/ls1021aqds/Makefile | 2 +- board/freescale/ls1021atwr/Makefile | 2 +- board/toradex/colibri_vf/Makefile | 1 + board/toradex/colibri_vf/colibri_vf.c | 76 +++- board/toradex/colibri_vf/dcu.c | 38 ++ configs/colibri_vf_defconfig | 4 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + doc/device-tree-bindings/video/atmel-hlcdc.txt | 42 ++ drivers/video/Kconfig | 21 + drivers/video/Makefile | 2 +- drivers/video/atmel_hlcdfb.c | 482 ++++++++++++++++++--- drivers/video/console_normal.c | 2 +- drivers/video/fsl_dcu_fb.c | 121 +++++- include/configs/colibri_vf.h | 13 + include/configs/ls1021aqds.h | 4 +- include/configs/ls1021atwr.h | 4 +- include/fsl_dcu_fb.h | 1 + scripts/config_whitelist.txt | 1 - 39 files changed, 773 insertions(+), 113 deletions(-) create mode 100644 board/toradex/colibri_vf/dcu.c create mode 100644 doc/device-tree-bindings/video/atmel-hlcdc.txt
Please pull. Thanks!
Anatolij
On Fri, Apr 14, 2017 at 09:00:16PM +0200, Anatolij Gustschin wrote:
Hi Tom,
Anatolij Gustschin
