[PATCHv4 1/3] pci: pcie_dw_rockchip: Fixed the below compilation error
Use the generic error number instead of specific error number. Changes fix the below error.
drivers/pci/pcie_dw_rockchip.c: In function 'rk_pcie_read': drivers/pci/pcie_dw_rockchip.c:70:10: error: 'PCIBIOS_UNSUPPORTED' undeclared (first use in this function) 70 | return PCIBIOS_UNSUPPORTED; | ^~~~~~~~~~~~~~~~~~~ drivers/pci/pcie_dw_rockchip.c: In function 'rk_pcie_write': drivers/pci/pcie_dw_rockchip.c:90:10: error: 'PCIBIOS_UNSUPPORTED' undeclared (first use in this function) 90 | return PCIBIOS_UNSUPPORTED; | ^~~~~~~~~~~~~~~~~~~
Cc: Patrick Wildt patrick@blueri.se Cc: Neil Armstrong narmstrong@baylibre.com Cc: Kever Yang kever.yang@rock-chips.com Reviewed-by: Neil Armstrong narmstrong@baylibre.com Reviewed-by: Patrick Wildt patrick@blueri.se Signed-off-by: Anand Moon linux.amoon@gmail.com --- drivers/pci/pcie_dw_rockchip.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/pcie_dw_rockchip.c b/drivers/pci/pcie_dw_rockchip.c index bc22af4230..3ac2434b69 100644 --- a/drivers/pci/pcie_dw_rockchip.c +++ b/drivers/pci/pcie_dw_rockchip.c @@ -67,7 +67,7 @@ static int rk_pcie_read(void __iomem *addr, int size, u32 *val) { if ((uintptr_t)addr & (size - 1)) { *val = 0; - return PCIBIOS_UNSUPPORTED; + return -EOPNOTSUPP; }
if (size == 4) { @@ -87,7 +87,7 @@ static int rk_pcie_read(void __iomem *addr, int size, u32 *val) static int rk_pcie_write(void __iomem *addr, int size, u32 val) { if ((uintptr_t)addr & (size - 1)) - return PCIBIOS_UNSUPPORTED; + return -EOPNOTSUPP;
if (size == 4) writel(val, addr);
Drop the unused variable warning below.
drivers/pci/pcie_dw_rockchip.c:161:6: warning: unused variable 'val' [-Wunused-variable] 161 | u32 val; | ^~~ Cc: Patrick Wildt patrick@blueri.se Cc: Neil Armstrong narmstrong@baylibre.com Cc: Kever Yang kever.yang@rock-chips.com Reviewed-by: Neil Armstrong narmstrong@baylibre.com Reviewed-by: Patrick Wildt patrick@blueri.se Signed-off-by: Anand Moon linux.amoon@gmail.com --- drivers/pci/pcie_dw_rockchip.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/pci/pcie_dw_rockchip.c b/drivers/pci/pcie_dw_rockchip.c index 3ac2434b69..4e448c0a3d 100644 --- a/drivers/pci/pcie_dw_rockchip.c +++ b/drivers/pci/pcie_dw_rockchip.c @@ -158,8 +158,6 @@ static inline void rk_pcie_writel_apb(struct rk_pcie *rk_pcie, u32 reg, */ static void rk_pcie_configure(struct rk_pcie *pci, u32 cap_speed) { - u32 val; - dw_pcie_dbi_write_enable(&pci->dw, true);
clrsetbits_le32(pci->dw.dbi_base + PCIE_LINK_CAPABILITY,
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
u32 val;
Replace msleep occurences by udelay.
drivers/pci/pcie_dw_rockchip.c:254:3: warning: implicit declaration of function 'msleep' [-Wimplicit-function-declaration]
Cc: Patrick Wildt patrick@blueri.se Cc: Neil Armstrong narmstrong@baylibre.com Cc: Kever Yang kever.yang@rock-chips.com Signed-off-by: Anand Moon linux.amoon@gmail.com --- Keep is simple...sorry !!! --- drivers/pci/pcie_dw_rockchip.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/pci/pcie_dw_rockchip.c b/drivers/pci/pcie_dw_rockchip.c index 4e448c0a3d..9322e735b9 100644 --- a/drivers/pci/pcie_dw_rockchip.c +++ b/drivers/pci/pcie_dw_rockchip.c @@ -61,7 +61,7 @@ struct rk_pcie { #define PCIE_CLIENT_DBF_EN 0xffff0003
/* Parameters for the waiting for #perst signal */ -#define PERST_WAIT_MS 1000 +#define MACRO_US 1000
static int rk_pcie_read(void __iomem *addr, int size, u32 *val) { @@ -249,7 +249,7 @@ static int rk_pcie_link_up(struct rk_pcie *priv, u32 cap_speed) * some wired devices need much more, such as 600ms. * Add a enough delay to cover all cases. */ - msleep(PERST_WAIT_MS); + udelay(MACRO_US * 1000); dm_gpio_set_value(&priv->rst_gpio, 1); }
@@ -271,12 +271,12 @@ static int rk_pcie_link_up(struct rk_pcie *priv, u32 cap_speed) dev_info(priv->dw.dev, "PCIe Linking... LTSSM is 0x%x\n", rk_pcie_readl_apb(priv, PCIE_CLIENT_LTSSM_STATUS)); rk_pcie_debug_dump(priv); - msleep(1000); + udelay(MACRO_US * 1000); }
dev_err(priv->dw.dev, "PCIe-%d Link Fail\n", dev_seq(priv->dw.dev)); /* Link maybe in Gen switch recovery but we need to wait more 1s */ - msleep(1000); + udelay(MACRO_US * 1000); return -EIO; }
@@ -296,7 +296,7 @@ static int rockchip_pcie_init_port(struct udevice *dev) } }
ret = generic_phy_init(&priv->phy); if (ret) {
Thanks, - Kever
dm_gpio_set_value(&priv->rst_gpio, 1); }udelay(MACRO_US * 1000);
msleep(1000);
- msleep(1000);
- udelay(MACRO_US * 1000); return -EIO; }
- msleep(1000);
Thanks, - Kever
return -EOPNOTSUPP;
if (size == 4) {
return -EOPNOTSUPP;
Anand Moon
Kever Yang
