[U-Boot] Please pull u-boot-marvell/master
Hi Tom,
I'm a bit late because of a longer week vacation from which I just returned. Here my patch queue for the Marvell MVEBU SoC family.
Thanks, Stefan
The following changes since commit bb694d4e898b1368ba96e01481dc0a79c491e77c:
Merge branch 'master' of git://git.denx.de/u-boot-spi (2018-08-04 19:41:43 -0400)
git://www.denx.de/git/u-boot-marvell.git
for you to fetch changes up to 79a0188679df53862e06fd7c8fecb7f3d7d44502:
arm64: a37xx: add CONFIG_MTD_DEVICE and CONFIG_MTD_PARTITIONS (2018-08-07 10:53:52 +0200)
---------------------------------------------------------------- Baruch Siach (9): mvebu: turris_omnia: use u-boot-spl-dtb.bin mvebu: a38x: drop duplicate platform id symbols mvebu: consolidate SPL boot device config symbols mvebu: select boot device at SoC level mvebu: support UART boot image mvebu: clearfog: use kconfig symbols to select boot device arm: mvebu: solidrun-microsom: update SPI flash compatible arm: mvebu: clearfog: use the microsom .dtsi arm: mvebu: helios4: remove duplicate sdhci pins node
Chris Packham (4): configs: kirkwood: ds109: switch to DM_I2C configs: move RTC_MV config from mv-plug-common.h to boards configs: kirkwood: Move RTC_MV to DM and Kconfig ARM: kirkwood: add SBx81LIFXCAT board
Jon Nettleton (2): arm: mvebu: Better align Clearfog dts file with Linux kernel arm: mvebu: clearfog: add u-boot, dm-spl tag for spi
Vladimir Vid (1): arm64: a37xx: add CONFIG_MTD_DEVICE and CONFIG_MTD_PARTITIONS
Willy Tarreau (2): tools: kwboot: unbreak terminal-only mode tools: kwboot: properly quit when read() returns 0
arch/arm/Kconfig | 1 - arch/arm/dts/armada-388-clearfog-u-boot.dtsi | 9 + arch/arm/dts/armada-388-clearfog.dts | 449 +++++++-------------- arch/arm/dts/armada-388-helios4.dts | 8 +- arch/arm/dts/armada-38x-solidrun-microsom.dtsi | 2 +- arch/arm/dts/kirkwood-atl-sbx81lifxcat.dts | 145 +++++++ arch/arm/mach-kirkwood/Kconfig | 4 + .../gdsys/a38x => arch/arm/mach-mvebu}/.gitignore | 0 arch/arm/mach-mvebu/Kconfig | 17 +- arch/arm/mach-mvebu/Makefile | 33 ++ arch/arm/mach-mvebu/include/mach/config.h | 4 +- .../a38x => arch/arm/mach-mvebu}/kwbimage.cfg.in | 0 board/CZ.NIC/turris_omnia/kwbimage.cfg | 12 - board/Marvell/db-88f6720/kwbimage.cfg | 12 - board/Marvell/db-88f6820-amc/kwbimage.cfg | 12 - board/Marvell/db-88f6820-gp/kwbimage.cfg | 12 - board/Marvell/db-mv784mp-gp/kwbimage.cfg | 12 - board/Synology/ds414/kwbimage.cfg | 12 - board/alliedtelesis/SBx81LIFXCAT/Kconfig | 12 + board/alliedtelesis/SBx81LIFXCAT/MAINTAINERS | 7 + board/alliedtelesis/SBx81LIFXCAT/Makefile | 7 + board/alliedtelesis/SBx81LIFXCAT/kwbimage.cfg | 49 +++ board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c | 134 ++++++ board/gdsys/a38x/Kconfig | 36 -- board/gdsys/a38x/Makefile | 31 -- board/kobol/helios4/kwbimage.cfg | 13 - board/maxbcm/kwbimage.cfg | 12 - board/solidrun/clearfog/kwbimage.cfg | 12 - board/theadorable/kwbimage.cfg | 12 - configs/SBx81LIFKW_defconfig | 2 + configs/SBx81LIFXCAT_defconfig | 44 ++ configs/clearfog_defconfig | 2 +- configs/dns325_defconfig | 5 +- configs/dreamplug_defconfig | 5 +- configs/ds109_defconfig | 7 +- configs/goflexhome_defconfig | 5 +- configs/guruplug_defconfig | 5 +- configs/helios4_defconfig | 1 + configs/nas220_defconfig | 5 +- configs/sheevaplug_defconfig | 5 +- include/configs/SBx81LIFKW.h | 5 - include/configs/SBx81LIFXCAT.h | 114 ++++++ include/configs/clearfog.h | 16 +- include/configs/dns325.h | 7 - include/configs/goflexhome.h | 7 - include/configs/mv-plug-common.h | 7 - include/configs/mvebu_armada-37xx.h | 2 + include/configs/nas220.h | 7 - include/configs/turris_omnia.h | 4 +- tools/kwboot.c | 6 +- 50 files changed, 772 insertions(+), 558 deletions(-) create mode 100644 arch/arm/dts/armada-388-clearfog-u-boot.dtsi create mode 100644 arch/arm/dts/kirkwood-atl-sbx81lifxcat.dts rename {board/gdsys/a38x => arch/arm/mach-mvebu}/.gitignore (100%) rename {board/gdsys/a38x => arch/arm/mach-mvebu}/kwbimage.cfg.in (100%) delete mode 100644 board/CZ.NIC/turris_omnia/kwbimage.cfg delete mode 100644 board/Marvell/db-88f6720/kwbimage.cfg delete mode 100644 board/Marvell/db-88f6820-amc/kwbimage.cfg delete mode 100644 board/Marvell/db-88f6820-gp/kwbimage.cfg delete mode 100644 board/Marvell/db-mv784mp-gp/kwbimage.cfg delete mode 100644 board/Synology/ds414/kwbimage.cfg create mode 100644 board/alliedtelesis/SBx81LIFXCAT/Kconfig create mode 100644 board/alliedtelesis/SBx81LIFXCAT/MAINTAINERS create mode 100644 board/alliedtelesis/SBx81LIFXCAT/Makefile create mode 100644 board/alliedtelesis/SBx81LIFXCAT/kwbimage.cfg create mode 100644 board/alliedtelesis/SBx81LIFXCAT/sbx81lifxcat.c delete mode 100644 board/gdsys/a38x/Kconfig delete mode 100644 board/kobol/helios4/kwbimage.cfg delete mode 100644 board/maxbcm/kwbimage.cfg delete mode 100644 board/solidrun/clearfog/kwbimage.cfg delete mode 100644 board/theadorable/kwbimage.cfg create mode 100644 configs/SBx81LIFXCAT_defconfig create mode 100644 include/configs/SBx81LIFXCAT.h
On Tue, Aug 07, 2018 at 03:10:27PM +0200, Stefan Roese wrote:
Hi Tom,
Thanks, Stefan
Stefan Roese
