Re: [U-Boot] CONFIG_OF_EMBED
On Fri, 22 Mar 2019 at 05:37, Marek Vasut marex@denx.de wrote:
On 3/21/19 5:37 PM, Dalon L Westergreen wrote:
On Thu, 2019-03-21 at 16:48 +0100, Marek Vasut wrote:
On 3/21/19 3:33 PM, Dalon L Westergreen wrote:
On Thu, 2019-03-21 at 03:30 +0100, Marek Vasut wrote:
On 3/20/19 9:24 PM, Dalon L Westergreen wrote:
On Wed, 2019-03-20 at 19:37 +0100, Marek Vasut wrote: > On 3/20/19 6:28 PM, Dalon L Westergreen wrote: >> Hey Marek, > > Hi, > >> A while ago, when adding the hex output required for stratix10, I >> enabled >> CONFIG_OF_EMBED so that the spl elf included the dtb. This avoided >> the >> -- >> change-address option when using objcopy to convert the u-boot-spl- >> dtb.bin >> into >> a hex file with the correct address as required by the quartus >> tools. >> >> In any case, there is now a warning that CONFIG_OF_EMBED should only >> be >> used >> for >> development and debug. I am wondering how best to resolve this >> issue, >> should i >> revert back to using objcopy with the u-boot-spl-dtb.bin, is there a >> way >> to >> have >> CONFIG_OF_EMBED only apply to SPL? > > CONFIG_OF_SEPARATE is what you want.
I dont think this is what i want exactly. I was thinking of this. From 82c1d1bc6092ce40f33a04f2bc7713b0143e30a5 Mon Sep 17 00:00:00 2001 From: Dalon Westergreen dalon.westergreen@intel.com Date: Wed, 20 Mar 2019 11:21:20 -0700 Subject: [PATCH 1/2] Makefile: Add target to generate hex output for combined spl and dtb
Some architectures, Stratix10, require a hex formatted spl that combines the spl image and dtb. This adds a target to create said hex file with and offset of SPL_TEXT_BASE.
I don't really follow this thread, but you should not use CONFIG_OF_EMBED. If there is a problem with setting up the image with CONFIG_OF_SEPARATE, we should discuss it.
- Simon
The CONFIG_OF_SEPARATE doesn't generate a combined image anymore ? Seems like it does at least on the renesas platforms (cfr e.g. stout_defconfig, where I use exactly that).
It generates a combined binary, u-boot-spl-dtb.bin, as far as i know. The elf is not combined, so using objcopy on the elf results in a hex file without the dtb. Stratix 10 needs a combined hex file that starts at CONFIG_SPL_TEXT_BASE. This file is then combined by quartus with the fpga image. The SDM loads the spl image into the cpu's onchip ram and releases it from reset.
So what i am trying to do is get a hex file generated that is appriopriate for the quartus tools. With CONFIG_OF_EMBED, this was easy, as you just run objcopy on the elf to create the hex output. With CONFIG_OF_SEPARATE you need the combined binary to do the same. hence,
+OBJCOPYFLAGS_u-boot-spl-dtb.hex := -I binary -O ihex --change-
address=$(CONFIG_SPL_TEXT_BASE)
+spl/u-boot-spl-dtb.hex: spl/u-boot-spl-dtb.bin FORCE
$(call if_changed,objcopy)
Aha, right. CCing Simon, maybe he has some better idea.
Otherwise, let's add the custom target. Maybe we can add it to arch/arm/mach-socfpga instead though.
After a quick test to add the target to mach-socfpga instead of the root Makefile, it seems i would still need to modify the root Makefile to call the mach-socfpga makefile for the target in any case. If acceptable, i think it cleaner to just add the target to the root Makefile.
I think that's fine. The root Makefile is growing like dough. that needs to stop.
-- Best regards, Marek Vasut
On 3/20/19 9:24 PM, Dalon L Westergreen wrote: > On Wed, 2019-03-20 at 19:37 +0100, Marek Vasut wrote: > > On 3/20/19 6:28 PM, Dalon L Westergreen wrote: > > > Hey Marek, > > > > Hi, > > > > > A while ago, when adding the hex output required for > > > stratix10, I > > > enabled > > > CONFIG_OF_EMBED so that the spl elf included the dtb. This > > > avoided > > > the > > > -- > > > change-address option when using objcopy to convert the u- > > > boot-spl- > > > dtb.bin > > > into > > > a hex file with the correct address as required by the quartus > > > tools. > > > > > > In any case, there is now a warning that CONFIG_OF_EMBED > > > should only > > > be > > > used > > > for > > > development and debug. I am wondering how best to resolve > > > this > > > issue, > > > should i > > > revert back to using objcopy with the u-boot-spl-dtb.bin, is > > > there a > > > way > > > to > > > have > > > CONFIG_OF_EMBED only apply to SPL? > > > > CONFIG_OF_SEPARATE is what you want. > > I dont think this is what i want exactly. I was thinking of this. > From 82c1d1bc6092ce40f33a04f2bc7713b0143e30a5 Mon Sep 17 00:00:00 > 2001 > From: Dalon Westergreen dalon.westergreen@intel.com > Date: Wed, 20 Mar 2019 11:21:20 -0700 > Subject: [PATCH 1/2] Makefile: Add target to generate hex output > for > combined > spl and dtb > > Some architectures, Stratix10, require a hex formatted spl that > combines > the spl image and dtb. This adds a target to create said hex file > with > and offset of SPL_TEXT_BASE.
- Simon
Simon,
Did you see my patches following this email? They resolve the issues with S10 around CONFIG_OF_EMBED.
--dalon
> address=$(CONFIG_SPL_TEXT_BASE) > + > +spl/u-boot-spl-dtb.hex: spl/u-boot-spl-dtb.bin FORCE > + $(call if_changed,objcopy)
HI Dalon,
On Thu, 28 Mar 2019 at 10:32, Dalon L Westergreen dalon.westergreen@linux.intel.com wrote:
On Thu, 2019-03-21 at 03:30 +0100, Marek Vasut wrote: > On 3/20/19 9:24 PM, Dalon L Westergreen wrote: > > On Wed, 2019-03-20 at 19:37 +0100, Marek Vasut wrote: > > > On 3/20/19 6:28 PM, Dalon L Westergreen wrote: > > > > Hey Marek, > > > > > > Hi, > > > > > > > A while ago, when adding the hex output required for > > > > stratix10, I > > > > enabled > > > > CONFIG_OF_EMBED so that the spl elf included the dtb. This > > > > avoided > > > > the > > > > -- > > > > change-address option when using objcopy to convert the u- > > > > boot-spl- > > > > dtb.bin > > > > into > > > > a hex file with the correct address as required by the quartus > > > > tools. > > > > > > > > In any case, there is now a warning that CONFIG_OF_EMBED > > > > should only > > > > be > > > > used > > > > for > > > > development and debug. I am wondering how best to resolve > > > > this > > > > issue, > > > > should i > > > > revert back to using objcopy with the u-boot-spl-dtb.bin, is > > > > there a > > > > way > > > > to > > > > have > > > > CONFIG_OF_EMBED only apply to SPL? > > > > > > CONFIG_OF_SEPARATE is what you want. > > > > I dont think this is what i want exactly. I was thinking of this. > > From 82c1d1bc6092ce40f33a04f2bc7713b0143e30a5 Mon Sep 17 00:00:00 > > 2001 > > From: Dalon Westergreen dalon.westergreen@intel.com > > Date: Wed, 20 Mar 2019 11:21:20 -0700 > > Subject: [PATCH 1/2] Makefile: Add target to generate hex output > > for > > combined > > spl and dtb > > > > Some architectures, Stratix10, require a hex formatted spl that > > combines > > the spl image and dtb. This adds a target to create said hex file > > with > > and offset of SPL_TEXT_BASE.
- Simon
Simon,
No, or at least not yet. But that's good, thank you.
Dalon L Westergreen
