[PATCH 01/12] net: dc2114x: Use PCI_DEVICE() to define PCI device compat list
Use this macro to fully fill the PCI device ID table. This is mandatory for the DM PCI support, which checks all the fields.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index c55358ef83..e537b29f3d 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -568,8 +568,8 @@ static void read_hw_addr(struct eth_device *dev, bd_t *bis) }
static struct pci_device_id supported[] = { - { PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_TULIP_FAST }, - { PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_21142 }, + { PCI_DEVICE(PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_TULIP_FAST) }, + { PCI_DEVICE(PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_21142) }, { } };
For the usage in this driver, the chips are identical, so support all of them.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index e537b29f3d..245218080e 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -581,7 +581,6 @@ int dc21x4x_initialize(bd_t *bis) unsigned int iobase; int card_number = 0; pci_dev_t devbusfn; - unsigned int cfrv; int idx = 0;
while (1) { @@ -589,14 +588,6 @@ int dc21x4x_initialize(bd_t *bis) if (devbusfn == -1) break;
- /* Get the chip configuration revision register. */ - pci_read_config_dword(devbusfn, PCI_REVISION_ID, &cfrv); - - if ((cfrv & CFRV_RN) < DC2114x_BRK) { - printf("Error: The chip is not DC21143.\n"); - continue; - } - pci_read_config_word(devbusfn, PCI_COMMAND, &status); status |= PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER; pci_write_config_word(devbusfn, PCI_COMMAND, status);
Add Kconfig entries for the dc2114x driver and convert various boards.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- README | 3 --- configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + drivers/net/Kconfig | 6 ++++++ include/configs/MPC8349EMDS.h | 1 - include/configs/MPC8349EMDS_SDRAM.h | 1 - include/configs/MPC8540ADS.h | 1 - include/configs/MPC8541CDS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8548CDS.h | 1 - include/configs/MPC8555CDS.h | 1 - include/configs/MPC8560ADS.h | 1 - include/configs/MPC8568MDS.h | 1 - include/configs/MPC8569MDS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/TQM834x.h | 1 - include/configs/caddy2.h | 1 - include/configs/integratorap.h | 1 - include/configs/sbc8349.h | 1 - include/configs/sbc8548.h | 1 - include/configs/sbc8641d.h | 1 - include/configs/vme8349.h | 1 - scripts/config_whitelist.txt | 1 - 26 files changed, 10 insertions(+), 23 deletions(-)
diff --git a/README b/README index 020918a543..d3de7c41c9 100644 --- a/README +++ b/README @@ -871,9 +871,6 @@ The following options need to be configured: Allow generic access to the SPI bus on the Intel 8257x, for example with the "sspi" command.
- CONFIG_TULIP - Support for Digital 2114x chips. - CONFIG_NATSEMI Support for National dp83815 chips.
diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index 1b7d672bcb..0d9746b485 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -25,6 +25,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_EEPRO100=y +CONFIG_TULIP=y CONFIG_PCI=y CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index 116ac015a0..7d71648a86 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -25,6 +25,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_EEPRO100=y +CONFIG_TULIP=y CONFIG_PCI=y CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index 9c1a3fa2f5..921a75e326 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -25,6 +25,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_EEPRO100=y +CONFIG_TULIP=y CONFIG_PCI=y CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index ee9c69bce0..4032da97b4 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -25,6 +25,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_EEPRO100=y +CONFIG_TULIP=y CONFIG_PCI=y CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index ec3fb49832..15030b8165 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -491,6 +491,12 @@ config SH_ETHER
source "drivers/net/ti/Kconfig"
+config TULIP + bool "DEC Tulip DC2114x Ethernet support" + depends on (DM_ETH && DM_PCI) || !DM_ETH + help + This driver supports DEC DC2114x Fast ethernet chips. + config XILINX_AXIEMAC depends on DM_ETH && (MICROBLAZE || ARCH_ZYNQ || ARCH_ZYNQMP) select PHYLIB diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 41ef3d80e1..c2f44416b9 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -220,7 +220,6 @@
#define CONFIG_83XX_PCI_STREAMING
-#undef CONFIG_TULIP
#if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xFIXME diff --git a/include/configs/MPC8349EMDS_SDRAM.h b/include/configs/MPC8349EMDS_SDRAM.h index 4b43ee1d44..618e210e4e 100644 --- a/include/configs/MPC8349EMDS_SDRAM.h +++ b/include/configs/MPC8349EMDS_SDRAM.h @@ -275,7 +275,6 @@
#if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xFIXME diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index d2a92619fb..8b7e0da9ca 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -234,7 +234,6 @@ #define CONFIG_SYS_PCI1_IO_SIZE 0x100000 /* 1M */
#if defined(CONFIG_PCI) -#undef CONFIG_TULIP
#if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xe0000000 diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 834bf7a0ff..d174b27309 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -280,7 +280,6 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_MPC85XX_PCI2
#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1057 /* Motorola */ diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index b9c57e1f51..e473c0f531 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -256,7 +256,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET #endif
#ifndef CONFIG_PCI_PNP #define PCI_ENET0_IOADDR CONFIG_SYS_PCI1_IO_BUS diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 1cb62ae849..9be5e64fad 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -379,7 +379,6 @@ extern unsigned long get_clock_freq(void); #endif
#if !defined(CONFIG_DM_PCI) #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index c25b04e979..dcb09b056f 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -278,7 +278,6 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1057 /* Motorola */ diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 4d1a417e42..a9f3029292 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -231,7 +231,6 @@ #define CONFIG_SYS_PCI1_IO_SIZE 0x100000 /* 1M */
#if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xe0000000 diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 14663644d1..c49f786ee0 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -288,7 +288,6 @@ extern unsigned long get_clock_freq(void); #endif /* CONFIG_QE */
#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1057 /* Motorola */ diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index dd291aca1e..acb8dec819 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -394,7 +394,6 @@ extern unsigned long get_clock_freq(void); #endif /* CONFIG_QE */
diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index b4e5e3b3e2..23c757a71e 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -441,7 +441,6 @@ #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET #endif
#ifndef CONFIG_PCI_PNP #define PCI_ENET0_IOADDR CONFIG_SYS_PCIE3_IO_BUS diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index a7f02aef29..0bf6cf41b6 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -332,7 +332,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
/************************************************************ * USB support diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index d43d217956..aa70f01ddd 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -167,7 +167,6 @@ #define CONFIG_SYS_PCI1_IO_PHYS CONFIG_SYS_PCI1_IO_BASE #define CONFIG_SYS_PCI1_IO_SIZE 0x1000000 /* 16M */
#if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR CONFIG_SYS_PCI1_IO_BASE diff --git a/include/configs/caddy2.h b/include/configs/caddy2.h index a7c667711b..e51398d531 100644 --- a/include/configs/caddy2.h +++ b/include/configs/caddy2.h @@ -155,7 +155,6 @@
#if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xFIXME diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index 96c1d53b9b..2f8ac20a76 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -34,7 +34,6 @@ * PCI definitions */
-#define CONFIG_TULIP #define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */
/*----------------------------------------------------------------------- diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index cca596d43a..0561ec2024 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -180,7 +180,6 @@
#if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xFIXME diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index f94683329b..6ac5d7b0c0 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -432,7 +432,6 @@ #endif
diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 5b93ccbda1..27a15eddd3 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -274,7 +274,6 @@
#if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xe0000000 diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 52d632ba0a..bd94352179 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -155,7 +155,6 @@
#if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xFIXME diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 747583089b..f9668b2bb3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4032,7 +4032,6 @@ CONFIG_TSECV2 CONFIG_TSECV2_1 CONFIG_TSEC_TBI CONFIG_TSEC_TBICR_SETTINGS -CONFIG_TULIP CONFIG_TWL6030_INPUT CONFIG_TWL6030_POWER CONFIG_TWR
This code is never used, remove it.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 91 ------------------------------------------- 1 file changed, 91 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 245218080e..af582c5415 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -11,8 +11,6 @@
#define SROM_DLEVEL 0
-#undef UPDATE_SROM - /* PCI Registers. */ #define PCI_CFDA_PSM 0x43
@@ -270,92 +268,6 @@ static int read_srom(struct eth_device *dev, u_long ioaddr, int index) 3 + ee_addr_size + 16); }
-#ifdef UPDATE_SROM -static int write_srom(struct eth_device *dev, u_long ioaddr, int index, - int new_value) -{ - unsigned short newval; - int ee_addr_size; - int i; - - ee_addr_size = (do_read_eeprom(dev, ioaddr, 0xff, 8) & BIT(18)) ? 8 : 6; - - udelay(10 * 1000); /* test-only */ - - debug_cond(SROM_DLEVEL >= 1, "ee_addr_size=%d.\n", ee_addr_size); - debug_cond(SROM_DLEVEL >= 1, - "Writing new entry 0x%4.4x to offset %d.\n", - new_value, index); - - /* Enable programming modes. */ - do_eeprom_cmd(dev, ioaddr, 0x4f << (ee_addr_size - 4), - 3 + ee_addr_size); - - /* Do the actual write. */ - do_eeprom_cmd(dev, ioaddr, new_value | - (((SROM_WRITE_CMD << ee_addr_size) | index) << 16), - 3 + ee_addr_size + 16); - - /* Poll for write finished. */ - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); - for (i = 0; i < 10000; i++) { /* Typical 2000 ticks */ - if (getfrom_srom(dev, ioaddr) & EE_DATA_READ) - break; - } - - debug_cond(SROM_DLEVEL >= 1, " Write finished after %d ticks.\n", i); - - /* Disable programming. */ - do_eeprom_cmd(dev, ioaddr, (0x40 << (ee_addr_size - 4)), - 3 + ee_addr_size); - - /* And read the result. */ - newval = do_eeprom_cmd(dev, ioaddr, - (((SROM_READ_CMD << ee_addr_size) | index) << 16) - | 0xffff, 3 + ee_addr_size + 16); - - debug_cond(SROM_DLEVEL >= 1, " New value at offset %d is %4.4x.\n", - index, newval); - - return 1; -} - -static void update_srom(struct eth_device *dev, bd_t *bis) -{ - static unsigned short eeprom[0x40] = { - 0x140b, 0x6610, 0x0000, 0x0000, /* 00 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 04 */ - 0x00a3, 0x0103, 0x0000, 0x0000, /* 08 */ - 0x0000, 0x1f00, 0x0000, 0x0000, /* 0c */ - 0x0108, 0x038d, 0x0000, 0x0000, /* 10 */ - 0xe078, 0x0001, 0x0040, 0x0018, /* 14 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 18 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 1c */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 20 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 24 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 28 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 2c */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 30 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 34 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 38 */ - 0x0000, 0x0000, 0x0000, 0x4e07, /* 3c */ - }; - uchar enetaddr[6]; - int i; - - /* Ethernet Addr... */ - if (!eth_env_get_enetaddr("ethaddr", enetaddr)) - return; - - eeprom[0x0a] = (enetaddr[1] << 8) | enetaddr[0]; - eeprom[0x0b] = (enetaddr[3] << 8) | enetaddr[2]; - eeprom[0x0c] = (enetaddr[5] << 8) | enetaddr[4]; - - for (i = 0; i < 0x40; i++) - write_srom(dev, DE4X5_APROM, i, eeprom[i]); -} -#endif /* UPDATE_SROM */ - static void send_setup_frame(struct eth_device *dev, bd_t *bis) { char setup_frame[SETUP_FRAME_LEN]; @@ -561,9 +473,6 @@ static void read_hw_addr(struct eth_device *dev, bd_t *bis) if (!j || j == 0x2fffd) { memset(dev->enetaddr, 0, ETH_ALEN); debug("Warning: can't read HW address from SROM.\n"); -#ifdef UPDATE_SROM - update_srom(dev, bis); -#endif } }
The current dc21x4x driver accesses its memory mapped registers directly instead of using the standard I/O accessors. This can cause problems on some systems as the accesses can get out of order. So convert the direct volatile dereferences to use the normal in/out macros.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index af582c5415..9dd36e74de 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+
#include <common.h> +#include <asm/io.h> #include <env.h> #include <malloc.h> #include <net.h> @@ -104,12 +105,12 @@ static char tx_ring_size;
static u32 dc2114x_inl(struct eth_device *dev, u32 addr) { - return le32_to_cpu(*(volatile u32 *)(addr + dev->iobase)); + return le32_to_cpu(readl(dev->iobase + addr)); }
static void dc2114x_outl(struct eth_device *dev, u32 command, u32 addr) { - *(volatile u32 *)(addr + dev->iobase) = cpu_to_le32(command); + writel(cpu_to_le32(command), dev->iobase + addr); }
static void reset_de4x5(struct eth_device *dev)
Introduce dc2114x_priv, which is a super-structure around eth_device and tracks per-device state and the device IO address.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 25 ++++++++++++++++++------- 1 file changed, 18 insertions(+), 7 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 9dd36e74de..9f16250fe6 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -94,6 +94,13 @@ struct de4x5_desc { u32 next; };
+struct dc2114x_priv { + struct eth_device dev; + char *name; + void __iomem *iobase; + u8 *enetaddr; +}; + /* RX and TX descriptor ring */ static struct de4x5_desc rx_ring[NUM_RX_DESC] __aligned(32); static struct de4x5_desc tx_ring[NUM_TX_DESC] __aligned(32); @@ -460,9 +467,9 @@ static void dc21x4x_halt(struct eth_device *dev) pci_write_config_byte(devbusfn, PCI_CFDA_PSM, SLEEP); }
-static void read_hw_addr(struct eth_device *dev, bd_t *bis) +static void read_hw_addr(struct dc2114x_priv *priv) { - u_short tmp, *p = (u_short *)(&dev->enetaddr[0]); + u_short tmp, *p = (u_short *)(&priv->enetaddr[0]); int i, j = 0;
for (i = 0; i < (ETH_ALEN >> 1); i++) { @@ -472,7 +479,7 @@ static void read_hw_addr(struct eth_device *dev, bd_t *bis) }
if (!j || j == 0x2fffd) { - memset(dev->enetaddr, 0, ETH_ALEN); + memset(priv->enetaddr, 0, ETH_ALEN); debug("Warning: can't read HW address from SROM.\n"); } } @@ -485,6 +492,7 @@ static struct pci_device_id supported[] = {
int dc21x4x_initialize(bd_t *bis) { + struct dc2114x_priv *priv; struct eth_device *dev; unsigned short status; unsigned char timer; @@ -526,15 +534,18 @@ int dc21x4x_initialize(bd_t *bis) iobase &= PCI_BASE_ADDRESS_MEM_MASK; debug("dc21x4x: DEC 21142 PCI Device @0x%x\n", iobase);
- dev = (struct eth_device *)malloc(sizeof(*dev)); - if (!dev) { + priv = malloc(sizeof(*priv)); + if (!priv) { printf("Can not allocalte memory of dc21x4x\n"); break; } + memset(priv, 0, sizeof(*priv));
- memset(dev, 0, sizeof(*dev)); + dev = &priv->dev;
sprintf(dev->name, "dc21x4x#%d", card_number); + priv->name = dev->name; + priv->enetaddr = dev->enetaddr;
dev->iobase = pci_mem_to_phys(devbusfn, iobase); dev->priv = (void *)devbusfn; @@ -548,7 +559,7 @@ int dc21x4x_initialize(bd_t *bis)
udelay(10 * 1000);
- read_hw_addr(dev, bis); + read_hw_addr(priv);
eth_register(dev);
This patch replaces the various uses of struct eth_device for accessing device private data with struct dc2114x_priv, which is compatible both with DM and non-DM operation.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 135 ++++++++++++++++++++++-------------------- 1 file changed, 71 insertions(+), 64 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 9f16250fe6..0438cd3eda 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -110,78 +110,78 @@ static int tx_new; /* TX descriptor ring pointer */ static char rx_ring_size; static char tx_ring_size;
-static u32 dc2114x_inl(struct eth_device *dev, u32 addr) +static u32 dc2114x_inl(struct dc2114x_priv *priv, u32 addr) { - return le32_to_cpu(readl(dev->iobase + addr)); + return le32_to_cpu(readl(priv->iobase + addr)); }
-static void dc2114x_outl(struct eth_device *dev, u32 command, u32 addr) +static void dc2114x_outl(struct dc2114x_priv *priv, u32 command, u32 addr) { - writel(cpu_to_le32(command), dev->iobase + addr); + writel(cpu_to_le32(command), priv->iobase + addr); }
-static void reset_de4x5(struct eth_device *dev) +static void reset_de4x5(struct dc2114x_priv *priv) { u32 i;
- i = dc2114x_inl(dev, DE4X5_BMR); + i = dc2114x_inl(priv, DE4X5_BMR); mdelay(1); - dc2114x_outl(dev, i | BMR_SWR, DE4X5_BMR); + dc2114x_outl(priv, i | BMR_SWR, DE4X5_BMR); mdelay(1); - dc2114x_outl(dev, i, DE4X5_BMR); + dc2114x_outl(priv, i, DE4X5_BMR); mdelay(1);
for (i = 0; i < 5; i++) { - dc2114x_inl(dev, DE4X5_BMR); + dc2114x_inl(priv, DE4X5_BMR); mdelay(10); }
mdelay(1); }
-static void start_de4x5(struct eth_device *dev) +static void start_de4x5(struct dc2114x_priv *priv) { u32 omr;
- omr = dc2114x_inl(dev, DE4X5_OMR); + omr = dc2114x_inl(priv, DE4X5_OMR); omr |= OMR_ST | OMR_SR; - dc2114x_outl(dev, omr, DE4X5_OMR); /* Enable the TX and/or RX */ + dc2114x_outl(priv, omr, DE4X5_OMR); /* Enable the TX and/or RX */ }
-static void stop_de4x5(struct eth_device *dev) +static void stop_de4x5(struct dc2114x_priv *priv) { u32 omr;
- omr = dc2114x_inl(dev, DE4X5_OMR); + omr = dc2114x_inl(priv, DE4X5_OMR); omr &= ~(OMR_ST | OMR_SR); - dc2114x_outl(dev, omr, DE4X5_OMR); /* Disable the TX and/or RX */ + dc2114x_outl(priv, omr, DE4X5_OMR); /* Disable the TX and/or RX */ }
/* SROM Read and write routines. */ -static void sendto_srom(struct eth_device *dev, u_int command, u_long addr) +static void sendto_srom(struct dc2114x_priv *priv, u_int command, u_long addr) { - dc2114x_outl(dev, command, addr); + dc2114x_outl(priv, command, addr); udelay(1); }
-static int getfrom_srom(struct eth_device *dev, u_long addr) +static int getfrom_srom(struct dc2114x_priv *priv, u_long addr) { - u32 tmp = dc2114x_inl(dev, addr); + u32 tmp = dc2114x_inl(priv, addr);
udelay(1); return tmp; }
/* Note: this routine returns extra data bits for size detection. */ -static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, +static int do_read_eeprom(struct dc2114x_priv *priv, u_long ioaddr, int location, int addr_len) { int read_cmd = location | (SROM_READ_CMD << addr_len); unsigned int retval = 0; int i;
- sendto_srom(dev, SROM_RD | SROM_SR, ioaddr); - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); + sendto_srom(priv, SROM_RD | SROM_SR, ioaddr); + sendto_srom(priv, SROM_RD | SROM_SR | DT_CS, ioaddr);
debug_cond(SROM_DLEVEL >= 1, " EEPROM read at %d ", location);
@@ -189,35 +189,35 @@ static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, for (i = 4 + addr_len; i >= 0; i--) { short dataval = (read_cmd & (1 << i)) ? EE_DATA_WRITE : 0;
- sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval, + sendto_srom(priv, SROM_RD | SROM_SR | DT_CS | dataval, ioaddr); udelay(10); - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval | DT_CLK, + sendto_srom(priv, SROM_RD | SROM_SR | DT_CS | dataval | DT_CLK, ioaddr); udelay(10); debug_cond(SROM_DLEVEL >= 2, "%X", - getfrom_srom(dev, ioaddr) & 15); + getfrom_srom(priv, ioaddr) & 15); retval = (retval << 1) | - !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); + !!(getfrom_srom(priv, ioaddr) & EE_DATA_READ); }
- sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); + sendto_srom(priv, SROM_RD | SROM_SR | DT_CS, ioaddr);
- debug_cond(SROM_DLEVEL >= 2, " :%X:", getfrom_srom(dev, ioaddr) & 15); + debug_cond(SROM_DLEVEL >= 2, " :%X:", getfrom_srom(priv, ioaddr) & 15);
for (i = 16; i > 0; i--) { - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | DT_CLK, ioaddr); + sendto_srom(priv, SROM_RD | SROM_SR | DT_CS | DT_CLK, ioaddr); udelay(10); debug_cond(SROM_DLEVEL >= 2, "%X", - getfrom_srom(dev, ioaddr) & 15); + getfrom_srom(priv, ioaddr) & 15); retval = (retval << 1) | - !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); + !!(getfrom_srom(priv, ioaddr) & EE_DATA_READ); + sendto_srom(priv, SROM_RD | SROM_SR | DT_CS, ioaddr); udelay(10); }
/* Terminate the EEPROM access. */ - sendto_srom(dev, SROM_RD | SROM_SR, ioaddr); + sendto_srom(priv, SROM_RD | SROM_SR, ioaddr);
debug_cond(SROM_DLEVEL >= 2, " EEPROM value at %d is %5.5x.\n", location, retval); @@ -230,54 +230,55 @@ static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, * enable. It returns the data output from the EEPROM, and thus may * also be used for reads. */ -static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, +static int do_eeprom_cmd(struct dc2114x_priv *priv, u_long ioaddr, int cmd, int cmd_len) { unsigned int retval = 0;
debug_cond(SROM_DLEVEL >= 1, " EEPROM op 0x%x: ", cmd);
/* Shift the command bits out. */ do { short dataval = (cmd & BIT(cmd_len)) ? EE_WRITE_1 : EE_WRITE_0;
- sendto_srom(dev, dataval, ioaddr); + sendto_srom(priv, dataval, ioaddr); udelay(10);
- sendto_srom(dev, dataval | DT_CLK, ioaddr); + sendto_srom(priv, dataval | DT_CLK, ioaddr); udelay(10); retval = (retval << 1) | - !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); + !!(getfrom_srom(priv, ioaddr) & EE_DATA_READ); } while (--cmd_len >= 0);
debug_cond(SROM_DLEVEL >= 1, " EEPROM result is 0x%5.5x.\n", retval);
return retval; }
-static int read_srom(struct eth_device *dev, u_long ioaddr, int index) +static int read_srom(struct dc2114x_priv *priv, u_long ioaddr, int index) { int ee_addr_size;
- ee_addr_size = (do_read_eeprom(dev, ioaddr, 0xff, 8) & BIT(18)) ? 8 : 6; + ee_addr_size = (do_read_eeprom(priv, ioaddr, 0xff, 8) & BIT(18)) ? 8 : 6;
- return do_eeprom_cmd(dev, ioaddr, 0xffff | + return do_eeprom_cmd(priv, ioaddr, 0xffff | (((SROM_READ_CMD << ee_addr_size) | index) << 16), 3 + ee_addr_size + 16); }
-static void send_setup_frame(struct eth_device *dev, bd_t *bis) +static void send_setup_frame(struct dc2114x_priv *priv, bd_t *bis) { + struct eth_device *dev = &priv->dev; char setup_frame[SETUP_FRAME_LEN]; char *pa = &setup_frame[0]; int i; @@ -285,7 +286,7 @@ static void send_setup_frame(struct eth_device *dev, bd_t *bis) memset(pa, 0xff, SETUP_FRAME_LEN);
for (i = 0; i < ETH_ALEN; i++) { - *(pa + (i & 1)) = dev->enetaddr[i]; + *(pa + (i & 1)) = priv->enetaddr[i]; if (i & 0x01) pa += 4; } @@ -294,7 +295,7 @@ static void send_setup_frame(struct eth_device *dev, bd_t *bis) if (i < TOUT_LOOP) continue;
- printf("%s: tx error buffer not ready\n", dev->name); + printf("%s: tx error buffer not ready\n", priv->name); return; }
@@ -302,13 +303,13 @@ static void send_setup_frame(struct eth_device *dev, bd_t *bis) tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_SET | SETUP_FRAME_LEN); tx_ring[tx_new].status = cpu_to_le32(T_OWN);
- dc2114x_outl(dev, POLL_DEMAND, DE4X5_TPD); + dc2114x_outl(priv, POLL_DEMAND, DE4X5_TPD);
for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { if (i < TOUT_LOOP) continue;
- printf("%s: tx buffer not ready\n", dev->name); + printf("%s: tx buffer not ready\n", priv->name); return; }
@@ -322,11 +323,13 @@ static void send_setup_frame(struct eth_device *dev, bd_t *bis)
static int dc21x4x_send(struct eth_device *dev, void *packet, int length) { + struct dc2114x_priv *priv = + container_of(dev, struct dc2114x_priv, dev); int status = -1; int i;
if (length <= 0) { - printf("%s: bad packet size: %d\n", dev->name, length); + printf("%s: bad packet size: %d\n", priv->name, length); goto done; }
@@ -334,7 +337,7 @@ static int dc21x4x_send(struct eth_device *dev, void *packet, int length) if (i < TOUT_LOOP) continue;
- printf("%s: tx error buffer not ready\n", dev->name); + printf("%s: tx error buffer not ready\n", priv->name); goto done; }
@@ -342,13 +345,13 @@ static int dc21x4x_send(struct eth_device *dev, void *packet, int length) tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_LS | TD_FS | length); tx_ring[tx_new].status = cpu_to_le32(T_OWN);
- printf(".%s: tx buffer not ready\n", dev->name); + printf(".%s: tx buffer not ready\n", priv->name); goto done; }
@@ -406,20 +409,22 @@ static int dc21x4x_recv(struct eth_device *dev)
static int dc21x4x_init(struct eth_device *dev, bd_t *bis) { - int i; + struct dc2114x_priv *priv = + container_of(dev, struct dc2114x_priv, dev); int devbusfn = (int)dev->priv; + int i;
/* Ensure we're not sleeping. */ pci_write_config_byte(devbusfn, PCI_CFDA_PSM, WAKEUP);
- reset_de4x5(dev); + reset_de4x5(priv);
- if (dc2114x_inl(dev, DE4X5_STS) & (STS_TS | STS_RS)) { + if (dc2114x_inl(priv, DE4X5_STS) & (STS_TS | STS_RS)) { printf("Error: Cannot reset ethernet controller.\n"); return -1; }
- dc2114x_outl(dev, OMR_SDP | OMR_PS | OMR_PM, DE4X5_OMR); + dc2114x_outl(priv, OMR_SDP | OMR_PS | OMR_PM, DE4X5_OMR);
for (i = 0; i < NUM_RX_DESC; i++) { rx_ring[i].status = cpu_to_le32(R_OWN); @@ -444,25 +449,27 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis) tx_ring[tx_ring_size - 1].des1 |= cpu_to_le32(TD_TER);
/* Tell the adapter where the TX/RX rings are located. */ - dc2114x_outl(dev, phys_to_bus((u32)&rx_ring), DE4X5_RRBA); - dc2114x_outl(dev, phys_to_bus((u32)&tx_ring), DE4X5_TRBA); + dc2114x_outl(priv, phys_to_bus((u32)&rx_ring), DE4X5_RRBA); + dc2114x_outl(priv, phys_to_bus((u32)&tx_ring), DE4X5_TRBA);
- start_de4x5(dev); + start_de4x5(priv);
tx_new = 0; rx_new = 0;
- send_setup_frame(dev, bis); + send_setup_frame(priv, bis);
return 0; }
static void dc21x4x_halt(struct eth_device *dev) { + struct dc2114x_priv *priv = + container_of(dev, struct dc2114x_priv, dev); int devbusfn = (int)dev->priv;
- stop_de4x5(dev); - dc2114x_outl(dev, 0, DE4X5_SICR); + stop_de4x5(priv); + dc2114x_outl(priv, 0, DE4X5_SICR);
pci_write_config_byte(devbusfn, PCI_CFDA_PSM, SLEEP); } @@ -473,7 +480,7 @@ static void read_hw_addr(struct dc2114x_priv *priv) int i, j = 0;
for (i = 0; i < (ETH_ALEN >> 1); i++) { - tmp = read_srom(dev, DE4X5_APROM, (SROM_HWADD >> 1) + i); + tmp = read_srom(priv, DE4X5_APROM, (SROM_HWADD >> 1) + i); *p = le16_to_cpu(tmp); j += *p++; }
This is a trick in preparation for adding DM support. By passing in the PCI BDF into the phys_to_bus() macros and calling that dev, we can substitute dev with udevice when DM support lands and do minor adjustment to the macros to support both DM and non-DM operation. No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 29 ++++++++++++++++------------- 1 file changed, 16 insertions(+), 13 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 0438cd3eda..32d2034a05 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -74,9 +74,9 @@ #define POLL_DEMAND 1
#if defined(CONFIG_E500) -#define phys_to_bus(a) (a) +#define phys_to_bus(dev, a) (a) #else -#define phys_to_bus(a) pci_phys_to_mem((pci_dev_t)dev->priv, a) +#define phys_to_bus(dev, a) pci_phys_to_mem((dev), (a)) #endif
#define NUM_RX_DESC PKTBUFSRX @@ -96,6 +96,7 @@ struct de4x5_desc {
struct dc2114x_priv { struct eth_device dev; + pci_dev_t devno; char *name; void __iomem *iobase; u8 *enetaddr; @@ -278,7 +279,6 @@ static int read_srom(struct dc2114x_priv *priv, u_long ioaddr, int index)
static void send_setup_frame(struct dc2114x_priv *priv, bd_t *bis) { - struct eth_device *dev = &priv->dev; char setup_frame[SETUP_FRAME_LEN]; char *pa = &setup_frame[0]; int i; @@ -299,7 +299,8 @@ static void send_setup_frame(struct dc2114x_priv *priv, bd_t *bis) return; }
- tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus((u32)&setup_frame[0])); + tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus(priv->devno, + (u32)&setup_frame[0])); tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_SET | SETUP_FRAME_LEN); tx_ring[tx_new].status = cpu_to_le32(T_OWN);
@@ -341,7 +342,8 @@ static int dc21x4x_send(struct eth_device *dev, void *packet, int length) goto done; }
- tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus((u32)packet)); + tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus(priv->devno, + (u32)packet)); tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_LS | TD_FS | length); tx_ring[tx_new].status = cpu_to_le32(T_OWN);
@@ -411,11 +413,10 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis) { struct dc2114x_priv *priv = container_of(dev, struct dc2114x_priv, dev); - int devbusfn = (int)dev->priv; int i;
/* Ensure we're not sleeping. */ - pci_write_config_byte(devbusfn, PCI_CFDA_PSM, WAKEUP); + pci_write_config_byte(priv->devno, PCI_CFDA_PSM, WAKEUP);
reset_de4x5(priv);
@@ -429,8 +430,8 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis) for (i = 0; i < NUM_RX_DESC; i++) { rx_ring[i].status = cpu_to_le32(R_OWN); rx_ring[i].des1 = cpu_to_le32(RX_BUFF_SZ); - rx_ring[i].buf = - cpu_to_le32(phys_to_bus((u32)net_rx_packets[i])); + rx_ring[i].buf = cpu_to_le32(phys_to_bus(priv->devno, + (u32)net_rx_packets[i])); rx_ring[i].next = 0; }
@@ -449,8 +450,10 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis) tx_ring[tx_ring_size - 1].des1 |= cpu_to_le32(TD_TER);
/* Tell the adapter where the TX/RX rings are located. */ - dc2114x_outl(priv, phys_to_bus((u32)&rx_ring), DE4X5_RRBA); - dc2114x_outl(priv, phys_to_bus((u32)&tx_ring), DE4X5_TRBA); + dc2114x_outl(priv, phys_to_bus(priv->devno, (u32)&rx_ring), + DE4X5_RRBA); + dc2114x_outl(priv, phys_to_bus(priv->devno, (u32)&tx_ring), + DE4X5_TRBA);
start_de4x5(priv);
@@ -466,12 +469,11 @@ static void dc21x4x_halt(struct eth_device *dev) { struct dc2114x_priv *priv = container_of(dev, struct dc2114x_priv, dev); - int devbusfn = (int)dev->priv;
stop_de4x5(priv); dc2114x_outl(priv, 0, DE4X5_SICR);
- pci_write_config_byte(devbusfn, PCI_CFDA_PSM, SLEEP); + pci_write_config_byte(priv->devno, PCI_CFDA_PSM, SLEEP); }
static void read_hw_addr(struct dc2114x_priv *priv) @@ -551,6 +553,7 @@ int dc21x4x_initialize(bd_t *bis) dev = &priv->dev;
sprintf(dev->name, "dc21x4x#%d", card_number); + priv->devno = devbusfn; priv->name = dev->name; priv->enetaddr = dev->enetaddr;
The RX/TX DMA descriptor rings are per-device-instance private data, so move them into the private data.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 92 +++++++++++++++++++++---------------------- 1 file changed, 46 insertions(+), 46 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 32d2034a05..a91749584f 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -95,6 +95,12 @@ struct de4x5_desc { };
struct dc2114x_priv { + struct de4x5_desc rx_ring[NUM_RX_DESC] __aligned(32); + struct de4x5_desc tx_ring[NUM_TX_DESC] __aligned(32); + int rx_new; /* RX descriptor ring pointer */ + int tx_new; /* TX descriptor ring pointer */ + char rx_ring_size; + char tx_ring_size; struct eth_device dev; pci_dev_t devno; char *name; @@ -103,14 +109,6 @@ struct dc2114x_priv { };
/* RX and TX descriptor ring */ -static struct de4x5_desc rx_ring[NUM_RX_DESC] __aligned(32); -static struct de4x5_desc tx_ring[NUM_TX_DESC] __aligned(32); -static int rx_new; /* RX descriptor ring pointer */ -static int tx_new; /* TX descriptor ring pointer */ - -static char rx_ring_size; -static char tx_ring_size; - static u32 dc2114x_inl(struct dc2114x_priv *priv, u32 addr) { return le32_to_cpu(readl(priv->iobase + addr)); @@ -291,7 +289,7 @@ static void send_setup_frame(struct dc2114x_priv *priv, bd_t *bis) pa += 4; }
- for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { + for (i = 0; priv->tx_ring[priv->tx_new].status & cpu_to_le32(T_OWN); i++) { if (i < TOUT_LOOP) continue;
@@ -299,14 +297,14 @@ static void send_setup_frame(struct dc2114x_priv *priv, bd_t *bis) return; }
- tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus(priv->devno, + priv->tx_ring[priv->tx_new].buf = cpu_to_le32(phys_to_bus(priv->devno, (u32)&setup_frame[0])); - tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_SET | SETUP_FRAME_LEN); - tx_ring[tx_new].status = cpu_to_le32(T_OWN); + priv->tx_ring[priv->tx_new].des1 = cpu_to_le32(TD_TER | TD_SET | SETUP_FRAME_LEN); + priv->tx_ring[priv->tx_new].status = cpu_to_le32(T_OWN);
@@ -314,12 +312,12 @@ static void send_setup_frame(struct dc2114x_priv *priv, bd_t *bis) return; }
- if (le32_to_cpu(tx_ring[tx_new].status) != 0x7FFFFFFF) { + if (le32_to_cpu(priv->tx_ring[priv->tx_new].status) != 0x7FFFFFFF) { printf("TX error status2 = 0x%08X\n", - le32_to_cpu(tx_ring[tx_new].status)); + le32_to_cpu(priv->tx_ring[priv->tx_new].status)); }
- tx_new = (tx_new + 1) % NUM_TX_DESC; + priv->tx_new = (priv->tx_new + 1) % NUM_TX_DESC; }
static int dc21x4x_send(struct eth_device *dev, void *packet, int length) @@ -334,7 +332,7 @@ static int dc21x4x_send(struct eth_device *dev, void *packet, int length) goto done; }
@@ -342,14 +340,14 @@ static int dc21x4x_send(struct eth_device *dev, void *packet, int length) goto done; }
- tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus(priv->devno, + priv->tx_ring[priv->tx_new].buf = cpu_to_le32(phys_to_bus(priv->devno, (u32)packet)); - tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_LS | TD_FS | length); - tx_ring[tx_new].status = cpu_to_le32(T_OWN); + priv->tx_ring[priv->tx_new].des1 = cpu_to_le32(TD_TER | TD_LS | TD_FS | length); + priv->tx_ring[priv->tx_new].status = cpu_to_le32(T_OWN);
@@ -357,25 +355,27 @@ static int dc21x4x_send(struct eth_device *dev, void *packet, int length) goto done; }
- if (le32_to_cpu(tx_ring[tx_new].status) & TD_ES) { - tx_ring[tx_new].status = 0x0; + if (le32_to_cpu(priv->tx_ring[priv->tx_new].status) & TD_ES) { + priv->tx_ring[priv->tx_new].status = 0x0; goto done; }
status = length;
done: - tx_new = (tx_new + 1) % NUM_TX_DESC; + priv->tx_new = (priv->tx_new + 1) % NUM_TX_DESC; return status; }
static int dc21x4x_recv(struct eth_device *dev) { + struct dc2114x_priv *priv = + container_of(dev, struct dc2114x_priv, dev); int length = 0; u32 status;
while (true) { - status = le32_to_cpu(rx_ring[rx_new].status); + status = le32_to_cpu(priv->rx_ring[priv->rx_new].status);
if (status & R_OWN) break; @@ -387,23 +387,23 @@ static int dc21x4x_recv(struct eth_device *dev) printf("RX error status = 0x%08X\n", status); } else { /* A valid frame received. */ - length = (le32_to_cpu(rx_ring[rx_new].status) + length = (le32_to_cpu(priv->rx_ring[priv->rx_new].status) >> 16);
/* Pass the packet up to the protocol layers */ net_process_received_packet - (net_rx_packets[rx_new], length - 4); + (net_rx_packets[priv->rx_new], length - 4); }
/* * Change buffer ownership for this frame, * back to the adapter. */ - rx_ring[rx_new].status = cpu_to_le32(R_OWN); + priv->rx_ring[priv->rx_new].status = cpu_to_le32(R_OWN); }
/* Update entry information. */ - rx_new = (rx_new + 1) % rx_ring_size; + priv->rx_new = (priv->rx_new + 1) % priv->rx_ring_size; }
return length; @@ -428,37 +428,37 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis) dc2114x_outl(priv, OMR_SDP | OMR_PS | OMR_PM, DE4X5_OMR);
for (i = 0; i < NUM_RX_DESC; i++) { - rx_ring[i].status = cpu_to_le32(R_OWN); - rx_ring[i].des1 = cpu_to_le32(RX_BUFF_SZ); - rx_ring[i].buf = cpu_to_le32(phys_to_bus(priv->devno, + priv->rx_ring[i].status = cpu_to_le32(R_OWN); + priv->rx_ring[i].des1 = cpu_to_le32(RX_BUFF_SZ); + priv->rx_ring[i].buf = cpu_to_le32(phys_to_bus(priv->devno, (u32)net_rx_packets[i])); - rx_ring[i].next = 0; + priv->rx_ring[i].next = 0; }
for (i = 0; i < NUM_TX_DESC; i++) { - tx_ring[i].status = 0; - tx_ring[i].des1 = 0; - tx_ring[i].buf = 0; - tx_ring[i].next = 0; + priv->tx_ring[i].status = 0; + priv->tx_ring[i].des1 = 0; + priv->tx_ring[i].buf = 0; + priv->tx_ring[i].next = 0; }
- rx_ring_size = NUM_RX_DESC; - tx_ring_size = NUM_TX_DESC; + priv->rx_ring_size = NUM_RX_DESC; + priv->tx_ring_size = NUM_TX_DESC;
/* Write the end of list marker to the descriptor lists. */ - rx_ring[rx_ring_size - 1].des1 |= cpu_to_le32(RD_RER); - tx_ring[tx_ring_size - 1].des1 |= cpu_to_le32(TD_TER); + priv->rx_ring[priv->rx_ring_size - 1].des1 |= cpu_to_le32(RD_RER); + priv->tx_ring[priv->tx_ring_size - 1].des1 |= cpu_to_le32(TD_TER);
/* Tell the adapter where the TX/RX rings are located. */ - dc2114x_outl(priv, phys_to_bus(priv->devno, (u32)&rx_ring), + dc2114x_outl(priv, phys_to_bus(priv->devno, (u32)&priv->rx_ring), DE4X5_RRBA); - dc2114x_outl(priv, phys_to_bus(priv->devno, (u32)&tx_ring), + dc2114x_outl(priv, phys_to_bus(priv->devno, (u32)&priv->tx_ring), DE4X5_TRBA);
start_de4x5(priv);
- tx_new = 0; - rx_new = 0; + priv->tx_new = 0; + priv->rx_new = 0;
@@ -543,7 +543,7 @@ int dc21x4x_initialize(bd_t *bis) iobase &= PCI_BASE_ADDRESS_MEM_MASK; debug("dc21x4x: DEC 21142 PCI Device @0x%x\n", iobase);
- priv = malloc(sizeof(*priv)); + priv = memalign(32, sizeof(*priv)); if (!priv) { printf("Can not allocalte memory of dc21x4x\n"); break;
Split the RX data check from the rest of the RX function, so that the check can be performed separately from the processing of the packet and the release of the received packet once the processing is finished.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 67 +++++++++++++++++++++++++++---------------- 1 file changed, 43 insertions(+), 24 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index a91749584f..e224d007de 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -367,41 +367,60 @@ done: return status; }
+static int dc21x4x_recv_check(struct dc2114x_priv *priv) +{ + int length = 0; + u32 status; + + status = le32_to_cpu(priv->rx_ring[priv->rx_new].status); + + if (status & R_OWN) + return 0; + + if (status & RD_LS) { + /* Valid frame status. */ + if (status & RD_ES) { + /* There was an error. */ + printf("RX error status = 0x%08X\n", status); + return -EINVAL; + } else { + /* A valid frame received. */ + length = (le32_to_cpu(priv->rx_ring[priv->rx_new].status) + >> 16); + + return length; + } + } + + return -EAGAIN; +} + static int dc21x4x_recv(struct eth_device *dev) { struct dc2114x_priv *priv = container_of(dev, struct dc2114x_priv, dev); int length = 0; - u32 status; + int ret;
while (true) { - status = le32_to_cpu(priv->rx_ring[priv->rx_new].status); - - if (status & R_OWN) + ret = dc21x4x_recv_check(priv); + if (!ret) break;
- if (status & RD_LS) { - /* Valid frame status. */ - if (status & RD_ES) { - /* There was an error. */ - printf("RX error status = 0x%08X\n", status); - } else { - /* A valid frame received. */ - length = (le32_to_cpu(priv->rx_ring[priv->rx_new].status) - >> 16); - - /* Pass the packet up to the protocol layers */ - net_process_received_packet - (net_rx_packets[priv->rx_new], length - 4); - } - - /* - * Change buffer ownership for this frame, - * back to the adapter. - */ - priv->rx_ring[priv->rx_new].status = cpu_to_le32(R_OWN); + if (ret > 0) { + length = ret; + /* Pass the packet up to the protocol layers */ + net_process_received_packet + (net_rx_packets[priv->rx_new], length - 4); }
+ /* + * Change buffer ownership for this frame, + * back to the adapter. + */ + if (ret != -EAGAIN) + priv->rx_ring[priv->rx_new].status = cpu_to_le32(R_OWN); + /* Update entry information. */ priv->rx_new = (priv->rx_new + 1) % priv->rx_ring_size; }
Split the common code from the non-DM code, so it can be reused by the DM code later. As always, the recv() function had to be split into the actual receiving part and free_pkt part to fit with the DM.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 117 ++++++++++++++++++++++++------------------ 1 file changed, 67 insertions(+), 50 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index e224d007de..dc202d81de 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -275,7 +275,7 @@ static int read_srom(struct dc2114x_priv *priv, u_long ioaddr, int index) 3 + ee_addr_size + 16); }
-static void send_setup_frame(struct dc2114x_priv *priv, bd_t *bis) +static void send_setup_frame(struct dc2114x_priv *priv) { char setup_frame[SETUP_FRAME_LEN]; char *pa = &setup_frame[0]; @@ -320,10 +320,8 @@ static void send_setup_frame(struct dc2114x_priv *priv, bd_t *bis) priv->tx_new = (priv->tx_new + 1) % NUM_TX_DESC; }
-static int dc21x4x_send(struct eth_device *dev, void *packet, int length) +static int dc21x4x_send_common(struct dc2114x_priv *priv, void *packet, int length) { - struct dc2114x_priv *priv = - container_of(dev, struct dc2114x_priv, dev); int status = -1; int i;
@@ -395,48 +393,10 @@ static int dc21x4x_recv_check(struct dc2114x_priv *priv) return -EAGAIN; }
-static int dc21x4x_recv(struct eth_device *dev) -{ - struct dc2114x_priv *priv = - container_of(dev, struct dc2114x_priv, dev); - int length = 0; - int ret; - - while (true) { - ret = dc21x4x_recv_check(priv); - if (!ret) - break; - - if (ret > 0) { - length = ret; - /* Pass the packet up to the protocol layers */ - net_process_received_packet - (net_rx_packets[priv->rx_new], length - 4); - } - - /* - * Change buffer ownership for this frame, - * back to the adapter. - */ - if (ret != -EAGAIN) - priv->rx_ring[priv->rx_new].status = cpu_to_le32(R_OWN); - - /* Update entry information. */ - priv->rx_new = (priv->rx_new + 1) % priv->rx_ring_size; - } - - return length; -} - -static int dc21x4x_init(struct eth_device *dev, bd_t *bis) +static int dc21x4x_init_common(struct dc2114x_priv *priv) { - struct dc2114x_priv *priv = - container_of(dev, struct dc2114x_priv, dev); int i;
- /* Ensure we're not sleeping. */ - pci_write_config_byte(priv->devno, PCI_CFDA_PSM, WAKEUP); - reset_de4x5(priv);
if (dc2114x_inl(priv, DE4X5_STS) & (STS_TS | STS_RS)) { @@ -479,20 +439,15 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis) priv->tx_new = 0; priv->rx_new = 0;
- send_setup_frame(priv, bis); + send_setup_frame(priv);
return 0; }
-static void dc21x4x_halt(struct eth_device *dev) +static void dc21x4x_halt_common(struct dc2114x_priv *priv) { - struct dc2114x_priv *priv = - container_of(dev, struct dc2114x_priv, dev); - stop_de4x5(priv); dc2114x_outl(priv, 0, DE4X5_SICR); - - pci_write_config_byte(priv->devno, PCI_CFDA_PSM, SLEEP); }
static void read_hw_addr(struct dc2114x_priv *priv) @@ -518,6 +473,68 @@ static struct pci_device_id supported[] = { { } };
+static int dc21x4x_init(struct eth_device *dev, bd_t *bis) +{ + struct dc2114x_priv *priv = + container_of(dev, struct dc2114x_priv, dev); + + /* Ensure we're not sleeping. */ + pci_write_config_byte(priv->devno, PCI_CFDA_PSM, WAKEUP); + + return dc21x4x_init_common(priv); +} + +static void dc21x4x_halt(struct eth_device *dev) +{ + struct dc2114x_priv *priv = + container_of(dev, struct dc2114x_priv, dev); + + dc21x4x_halt_common(priv); + + pci_write_config_byte(priv->devno, PCI_CFDA_PSM, SLEEP); +} + +static int dc21x4x_send(struct eth_device *dev, void *packet, int length) +{ + struct dc2114x_priv *priv = + container_of(dev, struct dc2114x_priv, dev); + + return dc21x4x_send_common(priv, packet, length); +} + +static int dc21x4x_recv(struct eth_device *dev) +{ + struct dc2114x_priv *priv = + container_of(dev, struct dc2114x_priv, dev); + int length = 0; + int ret; + + while (true) { + ret = dc21x4x_recv_check(priv); + if (!ret) + break; + + if (ret > 0) { + length = ret; + /* Pass the packet up to the protocol layers */ + net_process_received_packet + (net_rx_packets[priv->rx_new], length - 4); + } + + /* + * Change buffer ownership for this frame, + * back to the adapter. + */ + if (ret != -EAGAIN) + priv->rx_ring[priv->rx_new].status = cpu_to_le32(R_OWN); + + /* Update entry information. */ + priv->rx_new = (priv->rx_new + 1) % priv->rx_ring_size; + } + + return length; +} + int dc21x4x_initialize(bd_t *bis) { struct dc2114x_priv *priv;
With all the changes in place, add support for DM into the dc2114x driver.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/dc2114x.c | 147 +++++++++++++++++++++++++++++++++++++++++- 1 file changed, 145 insertions(+), 2 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index dc202d81de..26ca40e115 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -2,7 +2,7 @@
#include <common.h> #include <asm/io.h> -#include <env.h> +#include <dm.h> #include <malloc.h> #include <net.h> #include <netdev.h> @@ -73,7 +73,9 @@
-#if defined(CONFIG_E500) +#if defined(CONFIG_DM_ETH) +#define phys_to_bus(dev, a) dm_pci_phys_to_mem((dev), (a)) +#elif defined(CONFIG_E500) #define phys_to_bus(dev, a) (a) #else #define phys_to_bus(dev, a) pci_phys_to_mem((dev), (a)) @@ -101,8 +103,12 @@ struct dc2114x_priv { int tx_new; /* TX descriptor ring pointer */ char rx_ring_size; char tx_ring_size; +#ifdef CONFIG_DM_ETH + struct udevice *devno; +#else struct eth_device dev; pci_dev_t devno; +#endif char *name; void __iomem *iobase; u8 *enetaddr; @@ -473,6 +479,7 @@ static struct pci_device_id supported[] = { { } };
+#ifndef CONFIG_DM_ETH static int dc21x4x_init(struct eth_device *dev, bd_t *bis) { struct dc2114x_priv *priv = @@ -614,3 +621,139 @@ int dc21x4x_initialize(bd_t *bis)
return card_number; } + +#else /* DM_ETH */ +static int dc2114x_start(struct udevice *dev) +{ + struct eth_pdata *plat = dev_get_platdata(dev); + struct dc2114x_priv *priv = dev_get_priv(dev); + + memcpy(priv->enetaddr, plat->enetaddr, sizeof(plat->enetaddr)); + + /* Ensure we're not sleeping. */ + dm_pci_write_config8(dev, PCI_CFDA_PSM, WAKEUP); + + return dc21x4x_init_common(priv); +} + +static void dc2114x_stop(struct udevice *dev) +{ + struct dc2114x_priv *priv = dev_get_priv(dev); + + dc21x4x_halt_common(priv); + + dm_pci_write_config8(dev, PCI_CFDA_PSM, SLEEP); +} + +static int dc2114x_send(struct udevice *dev, void *packet, int length) +{ + struct dc2114x_priv *priv = dev_get_priv(dev); + int ret; + + ret = dc21x4x_send_common(priv, packet, length); + + return ret ? 0 : -ETIMEDOUT; +} + +static int dc2114x_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct dc2114x_priv *priv = dev_get_priv(dev); + int ret; + + ret = dc21x4x_recv_check(priv); + + if (ret < 0) { + /* Update entry information. */ + priv->rx_new = (priv->rx_new + 1) % priv->rx_ring_size; + ret = 0; + } + + if (!ret) + return 0; + + *packetp = net_rx_packets[priv->rx_new]; + + return ret - 4; +} + +static int dc2114x_free_pkt(struct udevice *dev, uchar *packet, int length) +{ + struct dc2114x_priv *priv = dev_get_priv(dev); + + priv->rx_ring[priv->rx_new].status = cpu_to_le32(R_OWN); + + /* Update entry information. */ + priv->rx_new = (priv->rx_new + 1) % priv->rx_ring_size; + + return 0; +} + +static int dc2114x_read_rom_hwaddr(struct udevice *dev) +{ + struct dc2114x_priv *priv = dev_get_priv(dev); + + read_hw_addr(priv); + + return 0; +} + +static int dc2114x_bind(struct udevice *dev) +{ + static int card_number; + char name[16]; + + sprintf(name, "dc2114x#%u", card_number++); + + return device_set_name(dev, name); +} + +static int dc2114x_probe(struct udevice *dev) +{ + struct eth_pdata *plat = dev_get_platdata(dev); + struct dc2114x_priv *priv = dev_get_priv(dev); + u16 command, status; + u32 iobase; + + dm_pci_read_config32(dev, PCI_BASE_ADDRESS_1, &iobase); + iobase &= ~0xf; + + debug("dc2114x: DEC 2114x PCI Device @0x%x\n", iobase); + + priv->devno = dev; + priv->enetaddr = plat->enetaddr; + priv->iobase = (void __iomem *)dm_pci_mem_to_phys(dev, iobase); + + command = PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER; + dm_pci_write_config16(dev, PCI_COMMAND, command); + dm_pci_read_config16(dev, PCI_COMMAND, &status); + if ((status & command) != command) { + printf("dc2114x: Couldn't enable IO access or Bus Mastering\n"); + return -EINVAL; + } + + dm_pci_write_config8(dev, PCI_LATENCY_TIMER, 0x60); + + return 0; +} + +static const struct eth_ops dc2114x_ops = { + .start = dc2114x_start, + .send = dc2114x_send, + .recv = dc2114x_recv, + .stop = dc2114x_stop, + .free_pkt = dc2114x_free_pkt, + .read_rom_hwaddr = dc2114x_read_rom_hwaddr, +}; + +U_BOOT_DRIVER(eth_dc2114x) = { + .name = "eth_dc2114x", + .id = UCLASS_ETH, + .bind = dc2114x_bind, + .probe = dc2114x_probe, + .ops = &dc2114x_ops, + .priv_auto_alloc_size = sizeof(struct dc2114x_priv), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; + +U_BOOT_PCI_DEVICE(eth_dc2114x, supported); +#endif
