[PATCH 1/1] efi_loader: efi_dp_part_node check dp_alloc return value
dp_alloc() may return NULL. This needs to be caught.
Fixes: 98d48bdf415e ("efi_loader: provide a function to create a partition node") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_device_path.c | 3 ++- lib/efi_loader/efi_disk.c | 5 +++++ 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index ebffb77122..acae007f26 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -936,7 +936,8 @@ struct efi_device_path *efi_dp_part_node(struct blk_desc *desc, int part) dpsize = sizeof(struct efi_device_path_hard_drive_path); buf = dp_alloc(dpsize);
- dp_part_node(buf, desc, part); + if (buf) + dp_part_node(buf, desc, part);
return buf; } diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 39ea1a68a6..79b28097b6 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -415,6 +415,11 @@ static efi_status_t efi_disk_add_dev( struct efi_handler *handler; void *protocol_interface;
+ if (!node) { + ret = EFI_OUT_OF_RESOURCES; + goto error; + } + /* Parent must expose EFI_BLOCK_IO_PROTOCOL */ ret = efi_search_protocol(parent, &efi_block_io_guid, &handler); if (ret != EFI_SUCCESS)
On Thu, 6 Oct 2022 at 14:45, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
if (buf)
dp_part_node(buf, desc, part); return buf;
if (!node) {
goto error;
There's a diskobj that has been allocated here and a handle we added. We should clean those up too
Cheers /Ilias
-- 2.37.2
if (buf)
if (!node) {
goto error;
512 error: 513 efi_delete_handle(&diskobj->header);
What is missing here?
Best regards
Heinrich
On Thu, 6 Oct 2022 at 15:18, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
if (buf)
if (!node) {
goto error;
If deleting the handle fails we won't free that memory
Regards /Ilias
Best regards
Heinrich
if (buf)
if (!node) {
goto error;
If deleting succeeds, we won't free it either. And we don't reclaim the memory on the success path.
Not reclaiming the device-path is a separate bug to what I am looking at here.
Best regards
Heinrich
Ilias Apalodimas
