[U-Boot] Please pull u-boot-sunxi/master into master
Hi Tom,
Please pull u-boot-sunxi/master into master, highlights:
1) sun6i dram init / SPL support, allowing full-boot of sun6i SoCs with just u-boot + linux 2) sun6i ehci support 3) A bugfix for the gmac on the bananapi
The following changes since commit 63f7af9a4cfb4a3b9136674c6612c6d13957c2cd:
Merge branch 'master' of git://git.denx.de/u-boot-uniphier (2014-11-11 15:49:10 -0500)
http://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to 64a97599b79e277600bc6f1b22cf48aa04ee9bd0:
sunxi: gmac: Update bananapi fixup to the new CONFIG_TARGET_<BOARD> structure (2014-11-13 14:49:02 +0100)
---------------------------------------------------------------- Hans de Goede (9): sun6i: Add clock functions needed for SPL / DRAM init sun6i: Add cpucfg register definitions sun4i: Rename dram files to dram_sun4i.x sun6i: Add dram initialization code sun6i: Poke magic sram controller register to avoid cache issues sun6i: Enable SPL sun6i: Add Mele M9 board sunxi: ehci: Add proper Kconfig options to select the usb Vbus gpio-s sun6i: ehci: Add sun6i ehci support
Oliver Schinagl (2): sun6i: Add new p2wi controller driver sun6i: Add basic axp221 driver
Zoltan HERPAI (1): sunxi: gmac: Update bananapi fixup to the new CONFIG_TARGET_<BOARD> structure
arch/arm/cpu/armv7/sunxi/Makefile | 8 +- arch/arm/cpu/armv7/sunxi/board.c | 5 + arch/arm/cpu/armv7/sunxi/clock_sun6i.c | 77 ++++ arch/arm/cpu/armv7/sunxi/{dram.c => dram_sun4i.c} | 0 arch/arm/cpu/armv7/sunxi/dram_sun6i.c | 435 ++++++++++++++++++++++ arch/arm/cpu/armv7/sunxi/p2wi.c | 117 ++++++ arch/arm/cpu/armv7/sunxi/psci.S | 4 +- arch/arm/include/asm/arch-sunxi/clock.h | 1 + arch/arm/include/asm/arch-sunxi/clock_sun4i.h | 3 + arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 38 +- arch/arm/include/asm/arch-sunxi/cpu.h | 19 +- arch/arm/include/asm/arch-sunxi/cpucfg_sun6i.h | 67 ++++ arch/arm/include/asm/arch-sunxi/dram.h | 171 +-------- arch/arm/include/asm/arch-sunxi/dram_sun4i.h | 182 +++++++++ arch/arm/include/asm/arch-sunxi/dram_sun6i.h | 359 ++++++++++++++++++ arch/arm/include/asm/arch-sunxi/gpio.h | 3 + arch/arm/include/asm/arch-sunxi/p2wi.h | 140 +++++++ arch/arm/include/asm/arch-sunxi/prcm.h | 1 + board/sunxi/Kconfig | 21 ++ board/sunxi/MAINTAINERS | 1 + board/sunxi/board.c | 26 ++ board/sunxi/gmac.c | 2 +- configs/A10s-OLinuXino-M_defconfig | 3 +- configs/A13-OLinuXinoM_defconfig | 3 +- configs/A13-OLinuXino_defconfig | 3 +- configs/Auxtek-T004_defconfig | 3 +- configs/Colombus_defconfig | 9 +- configs/Mele_M9_defconfig | 18 + configs/ba10_tv_box_defconfig | 3 +- configs/r7-tv-dongle_defconfig | 3 +- drivers/power/Kconfig | 47 +++ drivers/power/Makefile | 1 + drivers/power/axp221.c | 186 +++++++++ drivers/usb/host/ehci-sunxi.c | 80 ++-- include/axp221.h | 50 +++ include/configs/sun4i.h | 7 - include/configs/sun6i.h | 6 + include/configs/sun7i.h | 7 - 38 files changed, 1883 insertions(+), 226 deletions(-) rename arch/arm/cpu/armv7/sunxi/{dram.c => dram_sun4i.c} (100%) create mode 100644 arch/arm/cpu/armv7/sunxi/dram_sun6i.c create mode 100644 arch/arm/cpu/armv7/sunxi/p2wi.c create mode 100644 arch/arm/include/asm/arch-sunxi/cpucfg_sun6i.h create mode 100644 arch/arm/include/asm/arch-sunxi/dram_sun4i.h create mode 100644 arch/arm/include/asm/arch-sunxi/dram_sun6i.h create mode 100644 arch/arm/include/asm/arch-sunxi/p2wi.h create mode 100644 configs/Mele_M9_defconfig create mode 100644 drivers/power/axp221.c create mode 100644 include/axp221.h
Regards,
Hans
On Thu, Nov 13, 2014 at 04:04:25PM +0100, Hans de Goede wrote:
Hi Tom,
- sun6i dram init / SPL support, allowing full-boot of sun6i SoCs with just u-boot + linux
- sun6i ehci support
- A bugfix for the gmac on the bananapi
Hans de Goede
