[U-Boot] [PATCH] ti: k2g: increase phy autoneg timeout
After power cycle of a K2G EVM dhcp fails due to a auto-negotiation timeout. This commit increases the timeout to fix the issue.
Signed-off-by: Vitaly Andrianov vitalya@ti.com ---
board/ti/ks2_evm/board.c | 2 +- include/configs/k2g_evm.h | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/board/ti/ks2_evm/board.c b/board/ti/ks2_evm/board.c index 73f0f27..a2c7542 100644 --- a/board/ti/ks2_evm/board.c +++ b/board/ti/ks2_evm/board.c @@ -7,8 +7,8 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include "board.h" #include <common.h> +#include "board.h" #include <spl.h> #include <exports.h> #include <fdt_support.h> diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index d67d091..805f75e 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -52,6 +52,7 @@ #define CONFIG_KSNET_NETCP_V1_5 #define CONFIG_KSNET_CPSW_NUM_PORTS 2 #define CONFIG_PHY_MICREL +#define PHY_ANEG_TIMEOUT 10000 /* PHY needs longer aneg time */
/* MMC/SD */ #define CONFIG_MMC
Spurious change?
for the rest tho.
Spurious change?
for the rest tho.
Without this change it gives compilation warning:
In file included from include/config.h:5:0, from include/common.h:18, from board/ti/ks2_evm/board.c:11: include/configs/k2g_evm.h:55:0: warning: "PHY_ANEG_TIMEOUT" redefined #define PHY_ANEG_TIMEOUT 10000 /* PHY needs longer aneg time */ ^ In file included from ./arch/arm/include/asm/ti-common/keystone_net.h:14:0, from board/ti/ks2_evm/board.h:13, from board/ti/ks2_evm/board.c:10: include/phy.h:36:0: note: this is the location of the previous definition #define PHY_ANEG_TIMEOUT 4000
Spurious change?
for the rest tho.
Ah, OK, thanks for explaining then.
Signed-off-by: Vitaly Andrianov vitalya@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Vitaly Andrianov
