[U-Boot] [PATCH] doc: rmobile: Update README
Update the README with build instructions for R8A7795/R8A7796 boards.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- doc/README.rmobile | 41 +++++++++++++++++++++++++++++++++-------- 1 file changed, 33 insertions(+), 8 deletions(-)
diff --git a/doc/README.rmobile b/doc/README.rmobile index 4fbbcb3ef7..c65cbabc70 100644 --- a/doc/README.rmobile +++ b/doc/README.rmobile @@ -2,8 +2,8 @@ Summary =======
This README is about U-Boot support for Renesas's ARM Cortex-A9 based RMOBILE[1] -and R-Car[2]family of SoCs. Renesas's RMOBILE/R-Car SoC family contains an ARM -Cortex-A9. +and Cortex-A9/A53/A57 based R-Car[2] family of SoCs. Renesas's RMOBILE/R-Car SoC +family contains an ARM Cortex-A9/A53/A57.
Currently the following boards are supported:
@@ -11,16 +11,21 @@ Currently the following boards are supported: * Atmark-Techno Armadillo-800-EVA [4] * Renesas Electronics Lager * Renesas Electronics Koelsch +* Renesas Electronics Salvator-X M3 +* Renesas Electronics Salvator-XS H3 ES2.0+ +* Renesas Electronics ULCB M3 / H3 ES2.0+
Toolchain =========
-ARM Cortex-A9 support ARM v7 instruction set (-march=armv7a). -But currently we compile with -march=armv5 to allow more compilers to work. -(For U-Boot code this has no performance impact.) -Because there was no compiler which is supporting armv7a not much before. -Currently, ELDK[5], Linaro[6], CodeSourcey[7] and Emdebian[8] supports -march=armv7a -and you can get. +Either ARMv7 toolchain for 32bit Cortex-A9 systems or ARMv8 (aarch64) +toolchain for 64bit Cortex-A53/A57 systems. Currently we compile the +32bit systems with -march=armv5 to allow more compilers to work. (For +U-Boot code this has no performance impact.) + +Currently, ELDK[5], Linaro[6], CodeSourcery[7] and Emdebian[8] supports +ARMv7. Modern distributions also contain ARMv7 and ARMv8 crosstoolchains +in their package feeds.
Build ===== @@ -48,6 +53,26 @@ Build make koelsch_config make
+* Salvator-X M3 + + make r8a7796_salvator-x_defconfig + make + +* Salvator-XS H3 ES2.0 + + make r8a7795_salvator-x_defconfig + make + +* ULCB M3 + + make r8a7796_ulcb_defconfig + make + +* ULCB H3 ES2.0 + + make r8a7795_ulcb_defconfig + make + Links =====
