[PATCH] [RFC] net: smc911x: Drop the standalone EEPROM example
Drop the example, for two reasons. First, it is tapping directly into the IO accessors of the SMC911x, while it should instead go through the net device API. Second, this makes conversion of the SMC911x driver to DM real hard.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Tom Rini trini@konsulko.com --- examples/standalone/Makefile | 1 - examples/standalone/smc911x_eeprom.c | 379 --------------------------- 2 files changed, 380 deletions(-) delete mode 100644 examples/standalone/smc911x_eeprom.c
diff --git a/examples/standalone/Makefile b/examples/standalone/Makefile index 0b17a91804..5c8d56c92c 100644 --- a/examples/standalone/Makefile +++ b/examples/standalone/Makefile @@ -5,7 +5,6 @@
extra-y := hello_world extra-$(CONFIG_SMC91111) += smc91111_eeprom -extra-$(CONFIG_SMC911X) += smc911x_eeprom extra-$(CONFIG_SPI_FLASH_ATMEL) += atmel_df_pow2 extra-$(CONFIG_PPC) += sched
diff --git a/examples/standalone/smc911x_eeprom.c b/examples/standalone/smc911x_eeprom.c deleted file mode 100644 index 2c05ed902d..0000000000 --- a/examples/standalone/smc911x_eeprom.c +++ /dev/null @@ -1,379 +0,0 @@ -/* - * smc911x_eeprom.c - EEPROM interface to SMC911x parts. - * Only tested on SMSC9118 though ... - * - * Copyright 2004-2009 Analog Devices Inc. - * - * Licensed under the GPL-2 or later. - * - * Based on smc91111_eeprom.c which: - * Heavily borrowed from the following peoples GPL'ed software: - * - Wolfgang Denk, DENX Software Engineering, wd@denx.de - * Das U-Boot - * - Ladislav Michl ladis@linux-mips.org - * A rejected patch on the U-Boot mailing list - */ - -#include <common.h> -#include <console.h> -#include <exports.h> -#include <linux/ctype.h> -#include "../drivers/net/smc911x.h" - -/** - * smsc_ctrlc - detect press of CTRL+C (common ctrlc() isnt exported!?) - */ -static int smsc_ctrlc(void) -{ - return (tstc() && getc() == 0x03); -} - -/** - * usage - dump usage information - */ -static void usage(void) -{ - puts( - "MAC/EEPROM Commands:\n" - " P : Print the MAC addresses\n" - " D : Dump the EEPROM contents\n" - " M : Dump the MAC contents\n" - " C : Copy the MAC address from the EEPROM to the MAC\n" - " W : Write a register in the EEPROM or in the MAC\n" - " Q : Quit\n" - "\n" - "Some commands take arguments:\n" - " W <E|M> <register> <value>\n" - " E: EEPROM M: MAC\n" - ); -} - -/** - * dump_regs - dump the MAC registers - * - * Registers 0x00 - 0x50 are FIFOs. The 0x50+ are the control registers - * and they're all 32bits long. 0xB8+ are reserved, so don't bother. - */ -static void dump_regs(struct eth_device *dev) -{ - u8 i, j = 0; - for (i = 0x50; i < 0xB8; i += sizeof(u32)) - printf("%02x: 0x%08x %c", i, - smc911x_reg_read(dev, i), - (j++ % 2 ? '\n' : ' ')); -} - -/** - * do_eeprom_cmd - handle eeprom communication - */ -static int do_eeprom_cmd(struct eth_device *dev, int cmd, u8 reg) -{ - if (smc911x_reg_read(dev, E2P_CMD) & E2P_CMD_EPC_BUSY) { - printf("eeprom_cmd: busy at start (E2P_CMD = 0x%08x)\n", - smc911x_reg_read(dev, E2P_CMD)); - return -1; - } - - smc911x_reg_write(dev, E2P_CMD, E2P_CMD_EPC_BUSY | cmd | reg); - - while (smc911x_reg_read(dev, E2P_CMD) & E2P_CMD_EPC_BUSY) - if (smsc_ctrlc()) { - printf("eeprom_cmd: timeout (E2P_CMD = 0x%08x)\n", - smc911x_reg_read(dev, E2P_CMD)); - return -1; - } - - return 0; -} - -/** - * read_eeprom_reg - read specified register in EEPROM - */ -static u8 read_eeprom_reg(struct eth_device *dev, u8 reg) -{ - int ret = do_eeprom_cmd(dev, E2P_CMD_EPC_CMD_READ, reg); - return (ret ? : smc911x_reg_read(dev, E2P_DATA)); -} - -/** - * write_eeprom_reg - write specified value into specified register in EEPROM - */ -static int write_eeprom_reg(struct eth_device *dev, u8 value, u8 reg) -{ - int ret; - - /* enable erasing/writing */ - ret = do_eeprom_cmd(dev, E2P_CMD_EPC_CMD_EWEN, reg); - if (ret) - goto done; - - /* erase the eeprom reg */ - ret = do_eeprom_cmd(dev, E2P_CMD_EPC_CMD_ERASE, reg); - if (ret) - goto done; - - /* write the eeprom reg */ - smc911x_reg_write(dev, E2P_DATA, value); - ret = do_eeprom_cmd(dev, E2P_CMD_EPC_CMD_WRITE, reg); - if (ret) - goto done; - - /* disable erasing/writing */ - ret = do_eeprom_cmd(dev, E2P_CMD_EPC_CMD_EWDS, reg); - - done: - return ret; -} - -/** - * skip_space - find first non-whitespace in given pointer - */ -static char *skip_space(char *buf) -{ - while (isblank(buf[0])) - ++buf; - return buf; -} - -/** - * write_stuff - handle writing of MAC registers / eeprom - */ -static void write_stuff(struct eth_device *dev, char *line) -{ - char dest; - char *endp; - u8 reg; - u32 value; - - /* Skip over the "W " part of the command */ - line = skip_space(line + 1); - - /* Figure out destination */ - switch (line[0]) { - case 'E': - case 'M': - dest = line[0]; - break; - default: - invalid_usage: - printf("ERROR: Invalid write usage\n"); - usage(); - return; - } - - /* Get the register to write */ - line = skip_space(line + 1); - reg = simple_strtoul(line, &endp, 16); - if (line == endp) - goto invalid_usage; - - /* Get the value to write */ - line = skip_space(endp); - value = simple_strtoul(line, &endp, 16); - if (line == endp) - goto invalid_usage; - - /* Check for trailing cruft */ - line = skip_space(endp); - if (line[0]) - goto invalid_usage; - - /* Finally, execute the command */ - if (dest == 'E') { - printf("Writing EEPROM register %02x with %02x\n", reg, value); - write_eeprom_reg(dev, value, reg); - } else { - printf("Writing MAC register %02x with %08x\n", reg, value); - smc911x_reg_write(dev, reg, value); - } -} - -/** - * copy_from_eeprom - copy MAC address in eeprom to address registers - */ -static void copy_from_eeprom(struct eth_device *dev) -{ - ulong addrl = - read_eeprom_reg(dev, 0x01) | - read_eeprom_reg(dev, 0x02) << 8 | - read_eeprom_reg(dev, 0x03) << 16 | - read_eeprom_reg(dev, 0x04) << 24; - ulong addrh = - read_eeprom_reg(dev, 0x05) | - read_eeprom_reg(dev, 0x06) << 8; - smc911x_set_mac_csr(dev, ADDRL, addrl); - smc911x_set_mac_csr(dev, ADDRH, addrh); - puts("EEPROM contents copied to MAC\n"); -} - -/** - * print_macaddr - print MAC address registers and MAC address in eeprom - */ -static void print_macaddr(struct eth_device *dev) -{ - puts("Current MAC Address in MAC: "); - ulong addrl = smc911x_get_mac_csr(dev, ADDRL); - ulong addrh = smc911x_get_mac_csr(dev, ADDRH); - printf("%02x:%02x:%02x:%02x:%02x:%02x\n", - (u8)(addrl), (u8)(addrl >> 8), (u8)(addrl >> 16), - (u8)(addrl >> 24), (u8)(addrh), (u8)(addrh >> 8)); - - puts("Current MAC Address in EEPROM: "); - int i; - for (i = 1; i < 6; ++i) - printf("%02x:", read_eeprom_reg(dev, i)); - printf("%02x\n", read_eeprom_reg(dev, i)); -} - -/** - * dump_eeprom - dump the whole content of the EEPROM - */ -static void dump_eeprom(struct eth_device *dev) -{ - int i; - puts("EEPROM:\n"); - for (i = 0; i < 7; ++i) - printf("%02x: 0x%02x\n", i, read_eeprom_reg(dev, i)); -} - -/** - * smc911x_init - get the MAC/EEPROM up and ready for use - */ -static int smc911x_init(struct eth_device *dev) -{ - /* See if there is anything there */ - if (smc911x_detect_chip(dev)) - return 1; - - smc911x_reset(dev); - - /* Make sure we set EEDIO/EECLK to the EEPROM */ - if (smc911x_reg_read(dev, GPIO_CFG) & GPIO_CFG_EEPR_EN) { - while (smc911x_reg_read(dev, E2P_CMD) & E2P_CMD_EPC_BUSY) - if (smsc_ctrlc()) { - printf("init: timeout (E2P_CMD = 0x%08x)\n", - smc911x_reg_read(dev, E2P_CMD)); - return 1; - } - smc911x_reg_write(dev, GPIO_CFG, - smc911x_reg_read(dev, GPIO_CFG) & ~GPIO_CFG_EEPR_EN); - } - - return 0; -} - -/** - * getline - consume a line of input and handle some escape sequences - */ -static char *getline(void) -{ - static char buffer[100]; - char c; - size_t i; - - i = 0; - while (1) { - buffer[i] = '\0'; - while (!tstc()) - continue; - - c = getc(); - /* Convert to uppercase */ - if (c >= 'a' && c <= 'z') - c -= ('a' - 'A'); - - switch (c) { - case '\r': /* Enter/Return key */ - case '\n': - puts("\n"); - return buffer; - - case 0x03: /* ^C - break */ - return NULL; - - case 0x5F: - case 0x08: /* ^H - backspace */ - case 0x7F: /* DEL - backspace */ - if (i) { - puts("\b \b"); - i--; - } - break; - - default: - /* Ignore control characters */ - if (c < 0x20) - break; - /* Queue up all other characters */ - buffer[i++] = c; - printf("%c", c); - break; - } - } -} - -/** - * smc911x_eeprom - our application's main() function - */ -int smc911x_eeprom(int argc, char * const argv[]) -{ - /* Avoid initializing on stack as gcc likes to call memset() */ - struct eth_device dev; - dev.iobase = CONFIG_SMC911X_BASE; - - /* Print the ABI version */ - app_startup(argv); - if (XF_VERSION != get_version()) { - printf("Expects ABI version %d\n", XF_VERSION); - printf("Actual U-Boot ABI version %lu\n", get_version()); - printf("Can't run\n\n"); - return 1; - } - - /* Initialize the MAC/EEPROM somewhat */ - puts("\n"); - if (smc911x_init(&dev)) - return 1; - - /* Dump helpful usage information */ - puts("\n"); - usage(); - puts("\n"); - - while (1) { - char *line; - - /* Send the prompt and wait for a line */ - puts("eeprom> "); - line = getline(); - - /* Got a ctrl+c */ - if (!line) - return 0; - - /* Eat leading space */ - line = skip_space(line); - - /* Empty line, try again */ - if (!line[0]) - continue; - - /* Only accept 1 letter commands */ - if (line[0] && line[1] && !isblank(line[1])) - goto unknown_cmd; - - /* Now parse the command */ - switch (line[0]) { - case 'W': write_stuff(&dev, line); break; - case 'D': dump_eeprom(&dev); break; - case 'M': dump_regs(&dev); break; - case 'C': copy_from_eeprom(&dev); break; - case 'P': print_macaddr(&dev); break; - unknown_cmd: - default: puts("ERROR: Unknown command!\n\n"); - case '?': - case 'H': usage(); break; - case 'Q': return 0; - } - } -}
Yeah, I was disturbed by this example code.
I agree we should drop it.
Reviewed-by: Masahiro Yamada yamada.masahiro@socionext.com
Well I dunno. Can this be rewritten on top of DM somehow ? Do we even have U-Boot application API to access DM EEPROM ?
We should just drop it I think. The biggest surface we have today for external application is EFI application now, not U-Boot specific API. We can't drop the API but we don't expand it without very good reason.
But this drops the ability to access the SMC911x EEPROM too. So maybe we need some DM EEPROM implementation in the SMC911x driver ? Does anyone have SMC911x with an external EEPROM ?
All this does is drop an example. I don't see anything removing API code itself.
Where did I say anything about API code ?
On Sun, Mar 15, 2020 at 8:19 AM Marek Vasut marek.vasut@gmail.com wrote: > > Drop the example, for two reasons. First, it is tapping directly into > the IO accessors of the SMC911x, while it should instead go through > the net device API. Second, this makes conversion of the SMC911x driver > to DM real hard. > > Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com > Cc: Joe Hershberger joe.hershberger@ni.com > Cc: Tom Rini trini@konsulko.com > --- > examples/standalone/Makefile | 1 - > examples/standalone/smc911x_eeprom.c | 379 --------------------------- > 2 files changed, 380 deletions(-) > delete mode 100644 examples/standalone/smc911x_eeprom.c
Nowhere, which is my point. You're just dropping an example, not the ability to do $X.
On 3/17/20 7:10 PM, Masahiro Yamada wrote: > On Sun, Mar 15, 2020 at 8:19 AM Marek Vasut marek.vasut@gmail.com wrote: >> >> Drop the example, for two reasons. First, it is tapping directly into >> the IO accessors of the SMC911x, while it should instead go through >> the net device API. Second, this makes conversion of the SMC911x driver >> to DM real hard. >> >> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >> Cc: Joe Hershberger joe.hershberger@ni.com >> Cc: Tom Rini trini@konsulko.com >> --- >> examples/standalone/Makefile | 1 - >> examples/standalone/smc911x_eeprom.c | 379 --------------------------- >> 2 files changed, 380 deletions(-) >> delete mode 100644 examples/standalone/smc911x_eeprom.c > > > Yeah, I was disturbed by this example code. > > I agree we should drop it. > > Reviewed-by: Masahiro Yamada yamada.masahiro@socionext.com
If $X is ability to access the EEPROM, then I am dropping $X here.
On Tue, Mar 17, 2020 at 07:23:07PM +0100, Marek Vasut wrote: > On 3/17/20 7:10 PM, Masahiro Yamada wrote: >> On Sun, Mar 15, 2020 at 8:19 AM Marek Vasut marek.vasut@gmail.com wrote: >>> >>> Drop the example, for two reasons. First, it is tapping directly into >>> the IO accessors of the SMC911x, while it should instead go through >>> the net device API. Second, this makes conversion of the SMC911x driver >>> to DM real hard. >>> >>> Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com >>> Cc: Joe Hershberger joe.hershberger@ni.com >>> Cc: Tom Rini trini@konsulko.com >>> --- >>> examples/standalone/Makefile | 1 - >>> examples/standalone/smc911x_eeprom.c | 379 --------------------------- >>> 2 files changed, 380 deletions(-) >>> delete mode 100644 examples/standalone/smc911x_eeprom.c >> >> >> Yeah, I was disturbed by this example code. >> >> I agree we should drop it. >> >> Reviewed-by: Masahiro Yamada yamada.masahiro@socionext.com > > Well I dunno. Can this be rewritten on top of DM somehow ? Do we even > have U-Boot application API to access DM EEPROM ?
No, you're dropping an example of doing $X.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Tom Rini trini@konsulko.com Acked-by: Joe Hershberger joe.hershberger@ni.com
Joe Hershberger
Masahiro Yamada
