[U-Boot] [PATCH 1/3] imximage: Add MX53 to the documentation
i.MX53 is supported, too. Add this to the introduction of the documentation.
Signed-off-by: Dirk Behme dirk.behme@de.bosch.com CC: Fabio Estevam festevam@gmail.com CC: Stefano Babic sbabic@denx.de CC: Jason Liu jason.hui@linaro.org --- doc/README.imximage | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/doc/README.imximage b/doc/README.imximage index c74239d..c3704a4 100644 --- a/doc/README.imximage +++ b/doc/README.imximage @@ -3,7 +3,7 @@ Imximage Boot Image generation using mkimage ---------------------------------------------
This document describes how to set up a U-Boot image -that can be booted by Freescale MX25, MX35 and MX51 +that can be booted by Freescale MX25, MX35, MX51 and MX53 processors via internal boot mode.
These processors can boot directly from NAND, SPI flash and SD card flash
The i.MX6 processor can boot from NOR flash and SATA disks, additionally. Add the flash offsets for these additional boot modes.
Signed-off-by: Dirk Behme dirk.behme@de.bosch.com Signed-off-by: Fabio Estevam festevam@gmail.com CC: Stefano Babic sbabic@denx.de CC: Jason Liu jason.hui@linaro.org --- doc/README.imximage | 13 +++++++------ tools/imximage.c | 4 +++- tools/imximage.h | 2 ++ 3 files changed, 12 insertions(+), 7 deletions(-)
diff --git a/doc/README.imximage b/doc/README.imximage index c3704a4..073e3fc 100644 --- a/doc/README.imximage +++ b/doc/README.imximage @@ -2,12 +2,13 @@ Imximage Boot Image generation using mkimage ---------------------------------------------
-This document describes how to set up a U-Boot image -that can be booted by Freescale MX25, MX35, MX51 and MX53 -processors via internal boot mode. +This document describes how to set up a U-Boot image that can be booted +by Freescale MX25, MX35, MX51, MX53 and MX6 processors via internal boot +mode.
These processors can boot directly from NAND, SPI flash and SD card flash -using its internal boot ROM support. They can boot from an internal +using its internal boot ROM support. MX6 processors additionally support +boot from NOR flash and SATA disks. All processors can boot from an internal UART, if booting from device media fails. Booting from NOR flash does not require to use this image type.
@@ -59,12 +60,12 @@ Configuration command line syntax: -------------- ----------- IMXIMAGE_VERSION 1/2 1 is for mx25/mx35/mx51 compatible, - 2 is for mx53 compatible, + 2 is for mx53/mx6 compatible, others is invalid and error is generated. This command need appear the fist before other valid commands in configuration file.
- BOOT_FROM nand/spi/sd/onenand + BOOT_FROM nand/spi/sd/onenand/nor/sata Example: BOOT_FROM spi DATA type address value diff --git a/tools/imximage.c b/tools/imximage.c index 8e81bdb..f3da139 100644 --- a/tools/imximage.c +++ b/tools/imximage.c @@ -51,6 +51,8 @@ static table_entry_t imximage_bootops[] = { {FLASH_OFFSET_NAND, "nand", "NAND Flash", }, {FLASH_OFFSET_SD, "sd", "SD Card", }, {FLASH_OFFSET_ONENAND, "onenand", "OneNAND Flash",}, + {FLASH_OFFSET_NOR, "nor", "NOR Flash", }, + {FLASH_OFFSET_SATA, "sata", "SATA Disk", }, {-1, "", "Invalid", }, };
@@ -59,7 +61,7 @@ static table_entry_t imximage_bootops[] = { */ static table_entry_t imximage_versions[] = { {IMXIMAGE_V1, "", " (i.MX25/35/51 compatible)", }, - {IMXIMAGE_V2, "", " (i.MX53 compatible)", }, + {IMXIMAGE_V2, "", " (i.MX53/6 compatible)", }, {-1, "", " (Invalid)", }, };
diff --git a/tools/imximage.h b/tools/imximage.h index d126a46..d784a8d 100644 --- a/tools/imximage.h +++ b/tools/imximage.h @@ -37,6 +37,8 @@ #define FLASH_OFFSET_SD FLASH_OFFSET_STANDARD #define FLASH_OFFSET_SPI FLASH_OFFSET_STANDARD #define FLASH_OFFSET_ONENAND 0x100 +#define FLASH_OFFSET_NOR 0x1000 +#define FLASH_OFFSET_SATA FLASH_OFFSET_STANDARD
#define IVT_HEADER_TAG 0xD1 #define IVT_VERSION 0x40
- 2 is for mx53/mx6 compatible,
- BOOT_FROM nand/spi/sd/onenand/nor/sata
- {FLASH_OFFSET_NOR, "nor", "NOR Flash", },
- {FLASH_OFFSET_SATA, "sata", "SATA Disk", },
- {IMXIMAGE_V2, "", " (i.MX53/6 compatible)", },
Acked-by: Jason Liu jason.hui@linaro.org
-- 1.7.0.4
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Signed-off-by: Dirk Behme dirk.behme@de.bosch.com CC: Fabio Estevam festevam@gmail.com CC: Stefano Babic sbabic@denx.de CC: Jason Liu jason.hui@linaro.org --- Note: This was requested by Wolfgang in http://www.mail-archive.com/u-boot@lists.denx.de/msg71842.html
tools/imximage.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/tools/imximage.c b/tools/imximage.c index f3da139..1e0f5d4 100644 --- a/tools/imximage.c +++ b/tools/imximage.c @@ -47,12 +47,12 @@ static table_entry_t imximage_cmds[] = { * this is needed to set the correct flash offset */ static table_entry_t imximage_bootops[] = { - {FLASH_OFFSET_SPI, "spi", "SPI Flash", }, - {FLASH_OFFSET_NAND, "nand", "NAND Flash", }, - {FLASH_OFFSET_SD, "sd", "SD Card", }, {FLASH_OFFSET_ONENAND, "onenand", "OneNAND Flash",}, + {FLASH_OFFSET_NAND, "nand", "NAND Flash", }, {FLASH_OFFSET_NOR, "nor", "NOR Flash", }, {FLASH_OFFSET_SATA, "sata", "SATA Disk", }, + {FLASH_OFFSET_SD, "sd", "SD Card", }, + {FLASH_OFFSET_SPI, "spi", "SPI Flash", }, {-1, "", "Invalid", }, };
Yes, this looks better.
-- 1.7.0.4
This change is too trivial. I wonder whether it can be squashed with pach 2/3?
Jason
-- 1.7.0.4
Sure, it could. But from logical point of view I've done two patches to separate
1/3: Correct existing stuff 2/3: Add new stuff (mx6)
Best regards
Dirk
Well, another way to see (as I can understand Jason's point of view) was to set them as: 1/2 Update documentation 2/2 Add new feature (mx6)
By the way, even if I agree that the first patch could be squashed together with the second one, there is no open issues and the substance is not changed at all ;-)
I will merge the current three patches into u-boot-imx.
Dirk Behme
Jason Hui
Stefano Babic
