[PATCH 1/1] efi_selftest: ReinstallProtocolInterface test
Test ReinstallProtocolInterface() more rigorously.
Replacing the sole installed protocol interface must not result in deleting the handle and creating a new one.
Check which interface is actually installed before and after ReinstallProtocolInterface().
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- .../efi_selftest_register_notify.c | 21 +++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/lib/efi_selftest/efi_selftest_register_notify.c b/lib/efi_selftest/efi_selftest_register_notify.c index ad4bcce1a1..2c6b625ddf 100644 --- a/lib/efi_selftest/efi_selftest_register_notify.c +++ b/lib/efi_selftest/efi_selftest_register_notify.c @@ -124,6 +124,7 @@ static int execute(void) { efi_status_t ret; efi_handle_t handle1 = NULL, handle2 = NULL; + struct interface *interface; struct interface interface1, interface2;
ret = boottime->install_protocol_interface(&handle1, &guid1, @@ -145,6 +146,16 @@ static int execute(void) efi_st_error("LocateHandle failed\n"); return EFI_ST_FAILURE; } + interface = NULL; + ret = boottime->handle_protocol(handle1, &guid1, (void **)&interface); + if (ret != EFI_SUCCESS) { + efi_st_error("Cannot find installed protocol on handle\n"); + return EFI_ST_FAILURE; + } + if (interface != &interface1) { + efi_st_error("Wrong interface after install\n"); + return EFI_ST_FAILURE; + } ret = boottime->free_pool(context.handles); if (ret != EFI_SUCCESS) { efi_st_error("FreePool failed\n"); @@ -186,6 +197,16 @@ static int execute(void) efi_st_error("FreePool failed\n"); return EFI_ST_FAILURE; } + interface = NULL; + ret = boottime->handle_protocol(handle1, &guid1, (void **)&interface); + if (ret != EFI_SUCCESS) { + efi_st_error("Cannot find reinstalled protocol on handle\n"); + return EFI_ST_FAILURE; + } + if (interface != &interface2) { + efi_st_error("Wrong interface after reinstall\n"); + return EFI_ST_FAILURE; + } context.notify_count = 0; ret = boottime->install_protocol_interface(&handle2, &guid1, EFI_NATIVE_INTERFACE,
