[U-Boot] [PATCH 0/3] mx6: ddr: updates for dynamic DDR calibration
This set of patches updates the interface to the DDR calibration in preparation for the addition of a pseudo-board for calibration on i.MX6.
The first patch fixes an ommission in the use of the DG_CMP_CYC flag in register MPDGCTRL0.
The second patch cleans up the handling of bus widths by passing the system configuration information to the calibration routines.
The third routine adds support for returning the calibration data written to the MMDC registers.
Eric Nelson (3): mx6: ddr: allow 32 cycles for DQS gating calibration mx6: ddr: pass mx6_ddr_sysinfo to calibration routines mx6: ddr: add mmdc_read_calibration routine to return dynamic data
arch/arm/cpu/armv7/mx6/ddr.c | 128 +++++++++++++++++++++----------- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 6 +- board/kosagi/novena/novena_spl.c | 4 +- 3 files changed, 92 insertions(+), 46 deletions(-)
The DDR calibration code is only setting flag DG_CMP_CYC (DQS gating sample cycle) for the first PHY.
Set the 32-cycle flag for both PHYs and clear when done so the MPDGCTRL0 output value isn't polluted with calibration artifacts.
Signed-off-by: Eric Nelson eric@nelint.com --- arch/arm/cpu/armv7/mx6/ddr.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/ddr.c b/arch/arm/cpu/armv7/mx6/ddr.c index 7beb7ea..b15f376 100644 --- a/arch/arm/cpu/armv7/mx6/ddr.c +++ b/arch/arm/cpu/armv7/mx6/ddr.c @@ -347,6 +347,8 @@ int mmdc_do_dqs_calibration(void) * 16 before comparing read data. */ setbits_le32(&mmdc0->mpdgctrl0, 1 << 30); + if (sysinfo->dsize == 2) + setbits_le32(&mmdc1->mpdgctrl0, 1 << 30);
/* Set bit 28 to start automatic read DQS gating calibration */ setbits_le32(&mmdc0->mpdgctrl0, 5 << 28); @@ -365,6 +367,11 @@ int mmdc_do_dqs_calibration(void) if ((bus_size == 0x2) && (readl(&mmdc1->mpdgctrl0) & 0x00001000)) errors |= 2;
+ /* now disable mpdgctrl0[DG_CMP_CYC] */ + clrbits_le32(&mmdc0->mpdgctrl0, 1 << 30); + if (sysinfo->dsize == 2) + clrbits_le32(&mmdc1->mpdgctrl0, 1 << 30); + /* * DQS gating absolute offset should be modified from * reflecting (HW_DG_LOWx + HW_DG_UPx)/2 to
- /* now disable mpdgctrl0[DG_CMP_CYC] */
- clrbits_le32(&mmdc0->mpdgctrl0, 1 << 30);
- if (sysinfo->dsize == 2)
- DQS gating absolute offset should be modified from
- reflecting (HW_DG_LOWx + HW_DG_UPx)/2 to
The DDR calibration routines have scattered support for bus widths other than 64-bits:
-- The mmdc_do_write_level_calibration() routine assumes the presence of PHY1, and -- The mmdc_do_dqs_calibration() routine tries to determine whether one or two DDR PHYs are active by reading MDCTL.
Since a caller of these routines must have a valid struct mx6_ddr_sysinfo for use in calling mx6_dram_cfg(), and the bus width is available in the "dsize" field, use this structure to inform the calibration routines which PHYs are active.
This allows the use of the DDR calibration routines on CPU variants like i.MX6SL that only have a single MMDC port.
Signed-off-by: Eric Nelson eric@nelint.com --- arch/arm/cpu/armv7/mx6/ddr.c | 98 +++++++++++++++++++-------------- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 4 +- board/kosagi/novena/novena_spl.c | 4 +- 3 files changed, 60 insertions(+), 46 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/ddr.c b/arch/arm/cpu/armv7/mx6/ddr.c index b15f376..274a0ba 100644 --- a/arch/arm/cpu/armv7/mx6/ddr.c +++ b/arch/arm/cpu/armv7/mx6/ddr.c @@ -86,14 +86,15 @@ static void modify_dg_result(u32 *reg_st0, u32 *reg_st1, u32 *reg_ctrl) writel(val_ctrl, reg_ctrl); }
-int mmdc_do_write_level_calibration(void) +int mmdc_do_write_level_calibration(struct mx6_ddr_sysinfo const *sysinfo) { struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; struct mmdc_p_regs *mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR; u32 esdmisc_val, zq_val; u32 errors = 0; - u32 ldectrl[4]; + u32 ldectrl[4] = {0}; u32 ddr_mr1 = 0x4; + u32 rwalat_max;
/* * Stash old values in case calibration fails, @@ -101,8 +102,10 @@ int mmdc_do_write_level_calibration(void) */ ldectrl[0] = readl(&mmdc0->mpwldectrl0); ldectrl[1] = readl(&mmdc0->mpwldectrl1); - ldectrl[2] = readl(&mmdc1->mpwldectrl0); - ldectrl[3] = readl(&mmdc1->mpwldectrl1); + if (sysinfo->dsize == 2) { + ldectrl[2] = readl(&mmdc1->mpwldectrl0); + ldectrl[3] = readl(&mmdc1->mpwldectrl1); + }
/* disable DDR logic power down timer */ clrbits_le32(&mmdc0->mdpdc, 0xff00); @@ -122,10 +125,10 @@ int mmdc_do_write_level_calibration(void) writel(zq_val & ~0x3, &mmdc0->mpzqhwctrl);
/* 3. increase walat and ralat to maximum */ - setbits_le32(&mmdc0->mdmisc, - (1 << 6) | (1 << 7) | (1 << 8) | (1 << 16) | (1 << 17)); - setbits_le32(&mmdc1->mdmisc, - (1 << 6) | (1 << 7) | (1 << 8) | (1 << 16) | (1 << 17)); + rwalat_max = (1 << 6) | (1 << 7) | (1 << 8) | (1 << 16) | (1 << 17); + setbits_le32(&mmdc0->mdmisc, rwalat_max); + if (sysinfo->dsize == 2) + setbits_le32(&mmdc1->mdmisc, rwalat_max); /* * 4 & 5. Configure the external DDR device to enter write-leveling * mode through Load Mode Register command. @@ -152,21 +155,25 @@ int mmdc_do_write_level_calibration(void) */ if (readl(&mmdc0->mpwlgcr) & 0x00000F00) errors |= 1; - if (readl(&mmdc1->mpwlgcr) & 0x00000F00) - errors |= 2; + if (sysinfo->dsize == 2) + if (readl(&mmdc1->mpwlgcr) & 0x00000F00) + errors |= 2;
debug("Ending write leveling calibration. Error mask: 0x%x\n", errors);
/* check to see if cal failed */ if ((readl(&mmdc0->mpwldectrl0) == 0x001F001F) && (readl(&mmdc0->mpwldectrl1) == 0x001F001F) && - (readl(&mmdc1->mpwldectrl0) == 0x001F001F) && - (readl(&mmdc1->mpwldectrl1) == 0x001F001F)) { + ((sysinfo->dsize < 2) || + ((readl(&mmdc1->mpwldectrl0) == 0x001F001F) && + (readl(&mmdc1->mpwldectrl1) == 0x001F001F)))) { debug("Cal seems to have soft-failed due to memory not supporting write leveling on all channels. Restoring original write leveling values.\n"); writel(ldectrl[0], &mmdc0->mpwldectrl0); writel(ldectrl[1], &mmdc0->mpwldectrl1); - writel(ldectrl[2], &mmdc1->mpwldectrl0); - writel(ldectrl[3], &mmdc1->mpwldectrl1); + if (sysinfo->dsize == 2) { + writel(ldectrl[2], &mmdc1->mpwldectrl0); + writel(ldectrl[3], &mmdc1->mpwldectrl1); + } errors |= 4; }
@@ -189,16 +196,20 @@ int mmdc_do_write_level_calibration(void) readl(&mmdc0->mpwldectrl0)); debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08X\n", readl(&mmdc0->mpwldectrl1)); - debug("\tMMDC_MPWLDECTRL0 after write level cal: 0x%08X\n", - readl(&mmdc1->mpwldectrl0)); - debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08X\n", - readl(&mmdc1->mpwldectrl1)); + if (sysinfo->dsize == 2) { + debug("\tMMDC_MPWLDECTRL0 after write level cal: 0x%08X\n", + readl(&mmdc1->mpwldectrl0)); + debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08X\n", + readl(&mmdc1->mpwldectrl1)); + }
/* We must force a readback of these values, to get them to stick */ readl(&mmdc0->mpwldectrl0); readl(&mmdc0->mpwldectrl1); - readl(&mmdc1->mpwldectrl0); - readl(&mmdc1->mpwldectrl1); + if (sysinfo->dsize == 2) { + readl(&mmdc1->mpwldectrl0); + readl(&mmdc1->mpwldectrl1); + }
/* enable DDR logic power down timer: */ setbits_le32(&mmdc0->mdpdc, 0x00005500); @@ -212,7 +223,7 @@ int mmdc_do_write_level_calibration(void) return errors; }
-int mmdc_do_dqs_calibration(void) +int mmdc_do_dqs_calibration(struct mx6_ddr_sysinfo const *sysinfo) { struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; struct mmdc_p_regs *mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR; @@ -223,7 +234,6 @@ int mmdc_do_dqs_calibration(void) bool cs0_enable_initial; bool cs1_enable_initial; u32 esdmisc_val; - u32 bus_size; u32 temp_ref; u32 pddword = 0x00ffff00; /* best so far, place into MPPDCMPR1 */ u32 errors = 0; @@ -292,10 +302,6 @@ int mmdc_do_dqs_calibration(void) cs0_enable = readl(&mmdc0->mdctl) & 0x80000000; cs1_enable = readl(&mmdc0->mdctl) & 0x40000000;
- /* Check to see what the data bus size is */ - bus_size = (readl(&mmdc0->mdctl) & 0x30000) >> 16; - debug("Data bus size: %d (%d bits)\n", bus_size, 1 << (bus_size + 4)); - precharge_all(cs0_enable, cs1_enable);
/* Write the pre-defined value into MPPDCMPR1 */ @@ -314,11 +320,11 @@ int mmdc_do_dqs_calibration(void) * Both PHYs for x64 configuration, if x32, do only PHY0. */ writel(initdelay, &mmdc0->mprddlctl); - if (bus_size == 0x2) + if (sysinfo->dsize == 0x2) writel(initdelay, &mmdc1->mprddlctl);
/* Force a measurment, for previous delay setup to take effect. */ - force_delay_measurement(bus_size); + force_delay_measurement(sysinfo->dsize);
/* * *************************** @@ -364,7 +370,7 @@ int mmdc_do_dqs_calibration(void) if (readl(&mmdc0->mpdgctrl0) & 0x00001000) errors |= 1;
- if ((bus_size == 0x2) && (readl(&mmdc1->mpdgctrl0) & 0x00001000)) + if ((sysinfo->dsize == 0x2) && (readl(&mmdc1->mpdgctrl0) & 0x00001000)) errors |= 2;
/* now disable mpdgctrl0[DG_CMP_CYC] */ @@ -381,7 +387,7 @@ int mmdc_do_dqs_calibration(void) &mmdc0->mpdgctrl0); modify_dg_result(&mmdc0->mpdghwst2, &mmdc0->mpdghwst3, &mmdc0->mpdgctrl1); - if (bus_size == 0x2) { + if (sysinfo->dsize == 0x2) { modify_dg_result(&mmdc1->mpdghwst0, &mmdc1->mpdghwst1, &mmdc1->mpdgctrl0); modify_dg_result(&mmdc1->mpdghwst2, &mmdc1->mpdghwst3, @@ -424,7 +430,8 @@ int mmdc_do_dqs_calibration(void) if (readl(&mmdc0->mprddlhwctl) & 0x0000000f) errors |= 4;
- if ((bus_size == 0x2) && (readl(&mmdc1->mprddlhwctl) & 0x0000000f)) + if ((sysinfo->dsize == 0x2) && + (readl(&mmdc1->mprddlhwctl) & 0x0000000f)) errors |= 8;
debug("Ending Read Delay calibration. Error mask: 0x%x\n", errors); @@ -450,14 +457,14 @@ int mmdc_do_dqs_calibration(void) * Both PHYs for x64 configuration, if x32, do only PHY0. */ writel(initdelay, &mmdc0->mpwrdlctl); - if (bus_size == 0x2) + if (sysinfo->dsize == 0x2) writel(initdelay, &mmdc1->mpwrdlctl);
/* * XXX This isn't in the manual. Force a measurement, * for previous delay setup to effect. */ - force_delay_measurement(bus_size); + force_delay_measurement(sysinfo->dsize);
/* * 9. 10. Start the automatic write calibration process @@ -477,7 +484,8 @@ int mmdc_do_dqs_calibration(void) if (readl(&mmdc0->mpwrdlhwctl) & 0x0000000f) errors |= 16;
- if ((bus_size == 0x2) && (readl(&mmdc1->mpwrdlhwctl) & 0x0000000f)) + if ((sysinfo->dsize == 0x2) && + (readl(&mmdc1->mpwrdlhwctl) & 0x0000000f)) errors |= 32;
debug("Ending Write Delay calibration. Error mask: 0x%x\n", errors); @@ -529,14 +537,18 @@ int mmdc_do_dqs_calibration(void) debug("Read DQS gating calibration:\n"); debug("\tMPDGCTRL0 PHY0 = 0x%08X\n", readl(&mmdc0->mpdgctrl0)); debug("\tMPDGCTRL1 PHY0 = 0x%08X\n", readl(&mmdc0->mpdgctrl1)); - debug("\tMPDGCTRL0 PHY1 = 0x%08X\n", readl(&mmdc1->mpdgctrl0)); - debug("\tMPDGCTRL1 PHY1 = 0x%08X\n", readl(&mmdc1->mpdgctrl1)); + if (sysinfo->dsize == 2) { + debug("\tMPDGCTRL0 PHY1 = 0x%08X\n", readl(&mmdc1->mpdgctrl0)); + debug("\tMPDGCTRL1 PHY1 = 0x%08X\n", readl(&mmdc1->mpdgctrl1)); + } debug("Read calibration:\n"); debug("\tMPRDDLCTL PHY0 = 0x%08X\n", readl(&mmdc0->mprddlctl)); - debug("\tMPRDDLCTL PHY1 = 0x%08X\n", readl(&mmdc1->mprddlctl)); + if (sysinfo->dsize == 2) + debug("\tMPRDDLCTL PHY1 = 0x%08X\n", readl(&mmdc1->mprddlctl)); debug("Write calibration:\n"); debug("\tMPWRDLCTL PHY0 = 0x%08X\n", readl(&mmdc0->mpwrdlctl)); - debug("\tMPWRDLCTL PHY1 = 0x%08X\n", readl(&mmdc1->mpwrdlctl)); + if (sysinfo->dsize == 2) + debug("\tMPWRDLCTL PHY1 = 0x%08X\n", readl(&mmdc1->mpwrdlctl));
/* * Registers below are for debugging purposes. These print out @@ -548,10 +560,12 @@ int mmdc_do_dqs_calibration(void) debug("\tMPDGHWST1 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst1)); debug("\tMPDGHWST2 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst2)); debug("\tMPDGHWST3 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst3)); - debug("\tMPDGHWST0 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst0)); - debug("\tMPDGHWST1 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst1)); - debug("\tMPDGHWST2 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst2)); - debug("\tMPDGHWST3 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst3)); + if (sysinfo->dsize == 2) { + debug("\tMPDGHWST0 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst0)); + debug("\tMPDGHWST1 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst1)); + debug("\tMPDGHWST2 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst2)); + debug("\tMPDGHWST3 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst3)); + }
debug("Final do_dqs_calibration error mask: 0x%x\n", errors);
diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h index 53eb5fa..cd5bc97 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -459,8 +459,8 @@ void mx6sl_dram_iocfg(unsigned width, const struct mx6sl_iomux_grp_regs *);
#if defined(CONFIG_MX6QDL) || defined(CONFIG_MX6Q) || defined(CONFIG_MX6D) -int mmdc_do_write_level_calibration(void); -int mmdc_do_dqs_calibration(void); +int mmdc_do_write_level_calibration(struct mx6_ddr_sysinfo const *sysinfo); +int mmdc_do_dqs_calibration(struct mx6_ddr_sysinfo const *sysinfo); #endif
/* configure mx6 mmdc registers */ diff --git a/board/kosagi/novena/novena_spl.c b/board/kosagi/novena/novena_spl.c index 92c61ae..b934d36 100644 --- a/board/kosagi/novena/novena_spl.c +++ b/board/kosagi/novena/novena_spl.c @@ -605,8 +605,8 @@ void board_init_f(ulong dummy)
/* Perform DDR DRAM calibration */ udelay(100); - mmdc_do_write_level_calibration(); - mmdc_do_dqs_calibration(); + mmdc_do_write_level_calibration(&novena_ddr_info); + mmdc_do_dqs_calibration(&novena_ddr_info);
/* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
Add routine mmdc_read_calibration() to return the output of DDR calibration. This can be used for debugging or to aid in construction of static memory configuration.
Signed-off-by: Eric Nelson eric@nelint.com --- arch/arm/cpu/armv7/mx6/ddr.c | 23 +++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/mx6-ddr.h | 2 ++ 2 files changed, 25 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/ddr.c b/arch/arm/cpu/armv7/mx6/ddr.c index 274a0ba..b12fb64 100644 --- a/arch/arm/cpu/armv7/mx6/ddr.c +++ b/arch/arm/cpu/armv7/mx6/ddr.c @@ -1501,6 +1501,29 @@ void mx6_ddr3_cfg(const struct mx6_ddr_sysinfo *sysinfo, mdelay(1); }
+void mmdc_read_calibration(struct mx6_ddr_sysinfo const *sysinfo, + struct mx6_mmdc_calibration *calib) +{ + struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; + struct mmdc_p_regs *mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR; + + calib->p0_mpwldectrl0 = readl(&mmdc0->mpwldectrl0); + calib->p0_mpwldectrl1 = readl(&mmdc0->mpwldectrl1); + calib->p0_mpdgctrl0 = readl(&mmdc0->mpdgctrl0); + calib->p0_mpdgctrl1 = readl(&mmdc0->mpdgctrl1); + calib->p0_mprddlctl = readl(&mmdc0->mprddlctl); + calib->p0_mpwrdlctl = readl(&mmdc0->mpwrdlctl); + + if (sysinfo->dsize == 2) { + calib->p1_mpwldectrl0 = readl(&mmdc1->mpwldectrl0); + calib->p1_mpwldectrl1 = readl(&mmdc1->mpwldectrl1); + calib->p1_mpdgctrl0 = readl(&mmdc1->mpdgctrl0); + calib->p1_mpdgctrl1 = readl(&mmdc1->mpdgctrl1); + calib->p1_mprddlctl = readl(&mmdc1->mprddlctl); + calib->p1_mpwrdlctl = readl(&mmdc1->mpwrdlctl); + } +} + void mx6_dram_cfg(const struct mx6_ddr_sysinfo *sysinfo, const struct mx6_mmdc_calibration *calib, const void *ddr_cfg) diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h index cd5bc97..12454fa 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -461,6 +461,8 @@ void mx6sl_dram_iocfg(unsigned width, #if defined(CONFIG_MX6QDL) || defined(CONFIG_MX6Q) || defined(CONFIG_MX6D) int mmdc_do_write_level_calibration(struct mx6_ddr_sysinfo const *sysinfo); int mmdc_do_dqs_calibration(struct mx6_ddr_sysinfo const *sysinfo); +void mmdc_read_calibration(struct mx6_ddr_sysinfo const *sysinfo, + struct mx6_mmdc_calibration *calib); #endif
Do you plan to use it or will this be mostly dead code ?
- struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR;
- struct mmdc_p_regs *mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR;
- calib->p0_mpwldectrl0 = readl(&mmdc0->mpwldectrl0);
- calib->p0_mpwldectrl1 = readl(&mmdc0->mpwldectrl1);
- calib->p0_mpdgctrl0 = readl(&mmdc0->mpdgctrl0);
- calib->p0_mpdgctrl1 = readl(&mmdc0->mpdgctrl1);
- calib->p0_mprddlctl = readl(&mmdc0->mprddlctl);
- calib->p0_mpwrdlctl = readl(&mmdc0->mpwrdlctl);
- if (sysinfo->dsize == 2) {
#endif
Hi Marek,
I plan to use it.
I'm cleaning things up before (re)sending a patch adding the virtual "mx6memcal" board and wanted to push the supporting changes in a separate set.
I have one more independent patch (4/3?) to send before the new board.
On 10/30/2016 08:14 PM, Eric Nelson wrote:
Hi Marek,
Hi!
I plan to use it.
Oh cool, all right.
The DDR calibration routines are gated by conditionals for the i.MX6DQ SOCs, but with the use of the sysinfo parameter, these are usable on at least i.MX6SDL and i.MX6SL variants with DDR3.
Also, since only the Novena board currently uses the dynamic DDR calibration routines, these routines waste space on other boards using SPL.
Add a KConfig entry to allow boards to selectively include the DDR calibration routines.
Signed-off-by: Eric Nelson eric@nelint.com --- arch/arm/cpu/armv7/mx6/Kconfig | 5 +++++ arch/arm/cpu/armv7/mx6/ddr.c | 3 +-- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 2 +- configs/novena_defconfig | 1 + 4 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 762a581..32536c0 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -35,6 +35,11 @@ config MX6ULL bool select MX6UL
+config MX6_DDRCAL + bool "Include dynamic DDR calibration routines" + depends on SPL + default n + choice prompt "MX6 board select" optional diff --git a/arch/arm/cpu/armv7/mx6/ddr.c b/arch/arm/cpu/armv7/mx6/ddr.c index b12fb64..0cf391e 100644 --- a/arch/arm/cpu/armv7/mx6/ddr.c +++ b/arch/arm/cpu/armv7/mx6/ddr.c @@ -14,8 +14,7 @@ #include <asm/types.h> #include <wait_bit.h>
-#if defined(CONFIG_MX6QDL) || defined(CONFIG_MX6Q) || defined(CONFIG_MX6D) - +#if defined(CONFIG_MX6_DDRCAL) static void reset_read_data_fifos(void) { struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h index 12454fa..2a8d443 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -458,7 +458,7 @@ void mx6sl_dram_iocfg(unsigned width, const struct mx6sl_iomux_ddr_regs *, const struct mx6sl_iomux_grp_regs *);
-#if defined(CONFIG_MX6QDL) || defined(CONFIG_MX6Q) || defined(CONFIG_MX6D) +#if defined(CONFIG_MX6_DDRCAL) int mmdc_do_write_level_calibration(struct mx6_ddr_sysinfo const *sysinfo); int mmdc_do_dqs_calibration(struct mx6_ddr_sysinfo const *sysinfo); void mmdc_read_calibration(struct mx6_ddr_sysinfo const *sysinfo, diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 1ffdddc..9d47d5b 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y CONFIG_TARGET_KOSAGI_NOVENA=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_FAT_SUPPORT=y
+config MX6_DDRCAL
- bool "Include dynamic DDR calibration routines"
- depends on SPL
- default n
Help text would really be helpful ;)
Thanks Marek,
+config MX6_DDRCAL
- depends on SPL
- default n
Cool.
I'll fix this and re-send the series as V2 (with the fourth patch).
The third patch adds support for returning the calibration data written to the MMDC registers.
The fourth patch adds a Kconfig selection to inclut the DDR calibration routines.
Eric Nelson (4): mx6: ddr: allow 32 cycles for DQS gating calibration mx6: ddr: pass mx6_ddr_sysinfo to calibration routines mx6: ddr: add routine to return DDR calibration data ARM: mx6: ddr: use Kconfig for inclusion of DDR calibration routines
arch/arm/cpu/armv7/mx6/Kconfig | 5 ++ arch/arm/cpu/armv7/mx6/ddr.c | 131 +++++++++++++++++++++----------- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 8 +- board/kosagi/novena/novena_spl.c | 4 +- configs/novena_defconfig | 1 + 5 files changed, 100 insertions(+), 49 deletions(-)
Signed-off-by: Eric Nelson eric@nelint.com Reviewed-by: Marek Vasut marex@denx.de --- No change in V2. arch/arm/cpu/armv7/mx6/ddr.c | 7 +++++++ 1 file changed, 7 insertions(+)
Signed-off-by: Eric Nelson eric@nelint.com Reviewed-by: Marek Vasut marex@denx.de --- No change in V2 arch/arm/cpu/armv7/mx6/ddr.c | 98 +++++++++++++++++++-------------- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 4 +- board/kosagi/novena/novena_spl.c | 4 +- 3 files changed, 60 insertions(+), 46 deletions(-)
This routine will be used in a subsequent patch set adding a virtual "mx6memcal" board, but could also be useful when gathering statistics during an initial production run.
Signed-off-by: Eric Nelson eric@nelint.com --- Commit message expanded in V2
Signed-off-by: Eric Nelson eric@nelint.com --- arch/arm/cpu/armv7/mx6/Kconfig | 8 ++++++++ arch/arm/cpu/armv7/mx6/ddr.c | 3 +-- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 2 +- configs/novena_defconfig | 1 + 4 files changed, 11 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 762a581..8b2217e 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -35,6 +35,14 @@ config MX6ULL bool select MX6UL
+config MX6_DDRCAL + bool "Include dynamic DDR calibration routines" + depends on SPL + default n + help + Say "Y" if your board uses dynamic (per-boot) DDR calibration. + If unsure, say N. + choice prompt "MX6 board select" optional diff --git a/arch/arm/cpu/armv7/mx6/ddr.c b/arch/arm/cpu/armv7/mx6/ddr.c index b12fb64..0cf391e 100644 --- a/arch/arm/cpu/armv7/mx6/ddr.c +++ b/arch/arm/cpu/armv7/mx6/ddr.c @@ -14,8 +14,7 @@ #include <asm/types.h> #include <wait_bit.h>
What's the current state in regard of applying this patchset?
Does it also work on i.MX6SX like the sabresd board?
Thanks -- Christoph
Best regards, Stefano Babic
This patch series adds a DDR calibration tool in the form of a virtual i.MX6 board named "mx6memcal".
I was hoping to send this without the RFC, but found something that needs some investigation in the process of cleanup (see ccgr_init in patch 1) and would like to get it out so that others can experiment and so I can get some additional feedback.
The board is added in patch 1.
The second patch is kept separate because I don't yet know why this is needed. If the initial calibration is left as all zero, the calibration of the Nitrogen6_Max board will fail. Other boards don't appear to have this problem.
The rest of the patches add configurations for use in testing.
Most of the boards are supported in main-line U-Boot, though I did add the Nitrogen6_max board as a test of a 4GiB DDR arrangement.
The 'tr1x' board is a custom design that uses i.MX6SL and DDR3 that I've been testing against and it works fine.
The mx6slevk and warp boards aren't currently supported because LPDDR2 isn't fully supported.
I did have them working in a local tree that pre-dated Marek's addition of the calibration code into main-line:
https://github.com/ericnelsonaz/u-boot/tree/memcal-pass1
Finally, as noted in the commit message, I saw some quirkiness with a Wandboard Quad. For some reason, the dynamic calibration failed on this platform when I selected 64-bit bus width and I haven't taken time to investigate.
Eric Nelson (9): mx6: Add board mx6memcal for use in validating DDR mx6memcal: zero values for MPWRDLCTL cause read DQS calibration errors mx6memcal: add configuration for SABRE Lite mx6memcal: add configuration for Nitrogen6_max board mx6memcal: add configuration for tr1x board (i.MX6SL with DDR3) mx6memcal: add configuration for Wandboard Solo (512MiB of x32 DDR3) mx6memcal: add configuration for Wandboard Quad mx6memcal: add configuration for mx6slevk mx6memcal: add configuration for warp board (i.MX6SL)
arch/arm/cpu/armv7/mx6/Kconfig | 9 + board/freescale/mx6memcal/Kconfig | 235 +++++++++++++++ board/freescale/mx6memcal/MAINTAINERS | 7 + board/freescale/mx6memcal/Makefile | 13 + board/freescale/mx6memcal/README | 49 +++ board/freescale/mx6memcal/mx6memcal.c | 32 ++ board/freescale/mx6memcal/spl.c | 462 +++++++++++++++++++++++++++++ configs/mx6memcal_defconfig | 32 ++ configs/mx6memcal_mx6slevk_defconfig | 37 +++ configs/mx6memcal_nitrogen6_max_defconfig | 33 +++ configs/mx6memcal_sabrelite_defconfig | 34 +++ configs/mx6memcal_tr1x_defconfig | 36 +++ configs/mx6memcal_wandboard_quad_defconfig | 34 +++ configs/mx6memcal_wandboard_solo_defconfig | 35 +++ configs/mx6memcal_warpboard_defconfig | 39 +++ include/configs/mx6memcal.h | 62 ++++ scripts/config_whitelist.txt | 5 + 17 files changed, 1154 insertions(+) create mode 100644 board/freescale/mx6memcal/Kconfig create mode 100644 board/freescale/mx6memcal/MAINTAINERS create mode 100644 board/freescale/mx6memcal/Makefile create mode 100644 board/freescale/mx6memcal/README create mode 100644 board/freescale/mx6memcal/mx6memcal.c create mode 100644 board/freescale/mx6memcal/spl.c create mode 100644 configs/mx6memcal_defconfig create mode 100644 configs/mx6memcal_mx6slevk_defconfig create mode 100644 configs/mx6memcal_nitrogen6_max_defconfig create mode 100644 configs/mx6memcal_sabrelite_defconfig create mode 100644 configs/mx6memcal_tr1x_defconfig create mode 100644 configs/mx6memcal_wandboard_quad_defconfig create mode 100644 configs/mx6memcal_wandboard_solo_defconfig create mode 100644 configs/mx6memcal_warpboard_defconfig create mode 100644 include/configs/mx6memcal.h
This is a virtual "board" that uses configuration files and Kconfig to define the memory layout used by a real board during the board bring-up process.
It generates an SPL image that can be loaded using imx_usb or SB_LOADER.exe.
When run, it will generate a set of calibration constants for use in either or both a DCD configuration file for boards that use u-boot.imx or struct mx6_mmdc_calibration for boards that boot via SPL.
In essence, it is a configurable, open-source variant of the Freescale ddr-stress tool.
https://community.nxp.com/docs/DOC-105652
File mx6memcal_defconfig configures the board for use with mx6sabresd or mx6qsabreauto.
Signed-off-by: Eric Nelson eric@nelint.com --- arch/arm/cpu/armv7/mx6/Kconfig | 9 + board/freescale/mx6memcal/Kconfig | 235 +++++++++++++++++ board/freescale/mx6memcal/MAINTAINERS | 7 + board/freescale/mx6memcal/Makefile | 13 + board/freescale/mx6memcal/README | 49 ++++ board/freescale/mx6memcal/mx6memcal.c | 32 +++ board/freescale/mx6memcal/spl.c | 458 ++++++++++++++++++++++++++++++++++ configs/mx6memcal_defconfig | 32 +++ include/configs/mx6memcal.h | 62 +++++ scripts/config_whitelist.txt | 5 + 10 files changed, 902 insertions(+) create mode 100644 board/freescale/mx6memcal/Kconfig create mode 100644 board/freescale/mx6memcal/MAINTAINERS create mode 100644 board/freescale/mx6memcal/Makefile create mode 100644 board/freescale/mx6memcal/README create mode 100644 board/freescale/mx6memcal/mx6memcal.c create mode 100644 board/freescale/mx6memcal/spl.c create mode 100644 configs/mx6memcal_defconfig create mode 100644 include/configs/mx6memcal.h
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 8b2217e..ac4b0fd 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -100,6 +100,14 @@ config TARGET_MX6CUBOXI bool "Solid-run mx6 boards" select SUPPORT_SPL
+config TARGET_MX6MEMCAL + bool "mx6memcal" + select SUPPORT_SPL + help + The mx6memcal board is a virtual board that can be used to validate + and characterize the memory layout of a new design during the initial + development and pre-production stages. + config TARGET_MX6QARM2 bool "mx6qarm2"
@@ -245,6 +253,7 @@ source "board/el/el6x/Kconfig" source "board/embest/mx6boards/Kconfig" source "board/engicam/icorem6/Kconfig" source "board/freescale/mx6qarm2/Kconfig" +source "board/freescale/mx6memcal/Kconfig" source "board/freescale/mx6qsabreauto/Kconfig" source "board/freescale/mx6sabresd/Kconfig" source "board/freescale/mx6slevk/Kconfig" diff --git a/board/freescale/mx6memcal/Kconfig b/board/freescale/mx6memcal/Kconfig new file mode 100644 index 0000000..443804d --- /dev/null +++ b/board/freescale/mx6memcal/Kconfig @@ -0,0 +1,235 @@ +if TARGET_MX6MEMCAL + +config SYS_BOARD + default "mx6memcal" + +config SYS_VENDOR + default "freescale" + +config SYS_CONFIG_NAME + default "mx6memcal" + +menu "mx6memcal specifics" +choice + prompt "Serial console" + help + Either UART1 or UART2 will be used as the console for + displaying the calibration values or errors. + +config SERIAL_CONSOLE_UART1 + bool "UART1" + help + Select this if your board uses UART1 for its' console. + +config SERIAL_CONSOLE_UART2 + bool "UART2" + help + Select this if your board uses UART2 for its' console. + +endchoice + +choice + prompt "UART pads" + help + Select the RX and TX pads used for your serial console. + The choices below reflect the most commonly used options + for your UART. + + config UART2_EIM_D26_27 + bool "UART2 on EIM_D26/27 (SabreLite, Nitrogen6x)" + depends on SERIAL_CONSOLE_UART2 + help + Choose this configuration if you're using pads + EIM_D26 and D27 for a console on UART2. + This is typical for designs that are based on the + NXP SABRELite. + + config UART1_CSI0_DAT10_11 + bool "UART1 on CSI0_DAT10/11 (Wand)" + depends on SERIAL_CONSOLE_UART1 + help + Choose this configuration if you're using pads + CSI0_DAT10 and DAT11 for a console on UART1 as + is done on the i.MX6 Wand board. + + config UART1_SD3_DAT6_7 + bool "UART1 on SD3_DAT6/7 (SabreSD, SabreAuto)" + depends on SERIAL_CONSOLE_UART1 + help + Choose this configuration if you're using pads + SD3_DAT6 and DAT7 for a console on UART1 as is + done on the NXP SABRESD or SABREAUTO designs. + + config UART1_UART1 + bool "UART1 on UART1 (i.MX6SL EVK, WaRP)" + depends on SERIAL_CONSOLE_UART1 + help + Choose this configuration if you're using pads + UART1_TXD/RXD for a console on UART1 as is done + on most i.MX6SL designs. + +endchoice + +config IMXIMAGE_OUTPUT + bool "Include output for imximage .cfg files" + default y + help + Say "Y" if you want output formatted for use in non-SPL + (DCD-style) configuration files. + +config DDRWIDTH + int "DDR bus width" + default 64 + help + Select either 32 or 64 to reflect the DDR bus width. + +config DDRCS + int "DDR chip selects" + default 2 + range 1 2 + help + Select the number of chip selects used in your board design + +choice + prompt "Memory type" + help + Select the type of DDR (DDR3 or LPDDR2) used on your design + +config DDR3 + bool "DDR3" + help + Select this if your board design uses DDR3. + +config LPDDR2 + bool "LPDDR2" + help + Select this if your board design uses LPDDR2. + +endchoice + +choice + prompt "Memory device" + +config MT41K512M16TNA + bool "Micron MT41K512M16TNA 512Mx16 (1GiB/chip)" + depends on DDR3 + +config MT41K128M16JT + bool "Micron MT41K128M16JT 128Mx16 (256 MiB/chip)" + depends on DDR3 + +config H5TQ4G63AFR + bool "Hynix H5TQ4G63AFR 256Mx16 (512 MiB/chip)" + depends on DDR3 + +config H5TQ2G63DFR + bool "Hynix H5TQ2G63DFR 128Mx16 (256 MiB/chip)" + depends on DDR3 + +config MT42L256M32D2LG + bool "Micron MT42L256M32D2LG LPDDR2 256Mx32 (1GiB/chip)" + depends on LPDDR2 + +config MT29PZZZ4D4BKESK + bool "Micron MT29PZZZ4D4BKESK multi-chip 512MiB LPDDR2/4GiB eMMC" + depends on LPDDR2 + +endchoice + +config DDR_ODT + int "DDR On-die-termination" + default 2 + range 0 7 + help + Enter the on-die termination value as an index defined for + IOMUX settings for PAD_DRAM_SDCLK0_P and others. + 0 == Disabled + 1 == 120 Ohm + 2 == 60 Ohm + 3 == 40 Ohm + 4 == 30 Ohm + 5 == 24 Ohm + 6 == 20 Ohm + 7 == 17 Ohm + Value will be applied to all clock and data lines + + +config DRAM_DRIVE_STRENGTH + int "DRAM Drive strength" + default 6 + range 0 7 + help + Enter drive strength as an index defined for IOMUX settings + for GRP_B1DS and others. + 0 == Hi Z + 6 == 40 Ohm (default) + 7 == 34 Ohm + Value will be applied to all clock and data lines + +config RTT_NOM + int "RTT_NOM" + default 1 + range 1 2 + help + Enter the RTT_NOM selector + 1 == RZQ/4 (60ohm) + 2 == RZQ/2 (120ohm) + +config RTT_WR + int "RTT_WR" + default 1 + range 0 2 + help + Enter the RTT_WR selector for MR2 + 0 == Dynamic ODT disabled + 1 == RZQ/4 (60ohm) + 2 == RZQ/2 (120ohm) + +config RALAT + int "Read additional latency" + default 5 + range 0 7 + help + Enter a latency in number of cycles. This will be added to + CAS and internal delays for which the MMDC will retrieve the + read data from the internal FIFO. + This is used to compensate for board/chip delays. + +config WALAT + int "Write additional latency" + default 0 + range 0 7 + help + Enter a latency in number of cycles. This will be added to + CAS and internal delays for which the MMDC will retrieve the + read data from the internal FIFO + This is used to compensate for board/chip delays. + +config REFSEL + int "Refresh period" + range 0 3 + default 1 + help + Select the DDR refresh period. + See the description of bitfield REF_SEL in the reference manual + for details. + 0 == disabled + 1 == 32 kHz + 2 == 64 kHz + 3 == fast counter + +config REFR + int "Number of refreshes" + range 0 7 + default 7 + help + This selects the number of refreshes (-1) during each period. + i.e.: + 0 == 1 refresh (tRFC) + 7 == 8 refreshes (tRFC*8) + See the description of MDREF[REFR] in the reference manual for + details. + +endmenu +endif + diff --git a/board/freescale/mx6memcal/MAINTAINERS b/board/freescale/mx6memcal/MAINTAINERS new file mode 100644 index 0000000..5da38f7 --- /dev/null +++ b/board/freescale/mx6memcal/MAINTAINERS @@ -0,0 +1,7 @@ +MX6MEMCAL BOARD +M: Eric Nelson eric@nelint.com +S: Maintained +F: board/freescale/mx6memcal/ +F: include/configs/mx6memcal.h +F: configs/mx6memcal_defconfig + diff --git a/board/freescale/mx6memcal/Makefile b/board/freescale/mx6memcal/Makefile new file mode 100644 index 0000000..2d7a6fa --- /dev/null +++ b/board/freescale/mx6memcal/Makefile @@ -0,0 +1,13 @@ +# +# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2011 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifdef CONFIG_SPL_BUILD +obj-y := spl.o +else +obj-y := mx6memcal.o +endif diff --git a/board/freescale/mx6memcal/README b/board/freescale/mx6memcal/README new file mode 100644 index 0000000..9fe2fe2 --- /dev/null +++ b/board/freescale/mx6memcal/README @@ -0,0 +1,49 @@ +mx6memcal - a tool for calibrating DDR on i.MX6 boards. + +The mx6memcal board isn't a real board, but a tool for use in bring-up of +new i.MX6 board designs. + +It provides a similar function to the tool from NXP([1]) with a number +of advantages: + +1. It's open-source, so it's easier to change if needed. + Typical reasons for needing to change include the use of alternate + UARTs and PMIC initialization. +2. It produces an image that's directly loadable with imx_usb [2] or + SB_LOADER.exe [3]. + The NXP tool requires either a cumbersome JTAG connection that + makes running the DDR very slow or a working U-Boot image that + suffers from a chicken-and-egg problem (i.e. where do you get the + DDR parameters for U-Boot?). +3. It doesn't prompt for parameters, so it's much faster to gather + data from multiple boards. +4. Parameters to the calibration process can be chosen through + 'make menuconfig'. + +When booted, the mx6memcal board will run the DDR calibration +routines and display the result in a form suitable for cut and +paste into struct mx6_mmdc_calibration. It can also optionally +produce output in a form usable in a DCD-style .cfg file. + +Selections in Kconfig allow most system design settings to be chosen: + +1. The UART number and pad configuration for the UART. Options + include support for the most frequent reference designs on + i.MX6DQ/SDL (SABRE Lite and SABRESD designs). +2. The memory bus width (64 and 32-bit) +3. The number of chip-selects in use +4. The type of DDR (DDR3 or LPDDR2). Note that LPDDR2 support + is incomplete as of this writing. +5. The type of DDR chips in use. This selection allows re-use of common + parts and four DDR3 and two LPDDR2 parts are currently defined +6. The On-die termination value for the DRAM lines +7. The DRAM drive strength +8. The RTT_NOM and RTT_WR termination settings +9. RALAT/WALAT latency values + +References: +[1] - NXP DDR Stress Test Tool - https://community.nxp.com/docs/DOC-105652 +[2] - Boundary Devices imx_usb_loader + https://github.com/boundarydevices/imx_usb_loader +[3] - Use of SB_Loader.exe + https://boundarydevices.com/windows-users-and-unbricking diff --git a/board/freescale/mx6memcal/mx6memcal.c b/board/freescale/mx6memcal/mx6memcal.c new file mode 100644 index 0000000..afea0fb --- /dev/null +++ b/board/freescale/mx6memcal/mx6memcal.c @@ -0,0 +1,32 @@ +/* + * mx6memcal board support - provides a minimal, UART-only + * U-Boot that's capable of running a memory test. + * + * Copyright (C) 2016 Nelson Integration, LLC + * Author: Eric Nelson eric@nelint.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int checkboard(void) +{ + puts("Board: mx6memcal\n"); + return 0; +} + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + return 0; +} + diff --git a/board/freescale/mx6memcal/spl.c b/board/freescale/mx6memcal/spl.c new file mode 100644 index 0000000..90e240f --- /dev/null +++ b/board/freescale/mx6memcal/spl.c @@ -0,0 +1,458 @@ +/* + * Copyright (C) 2016 Nelson Integration, LLC + * Author: Eric Nelson eric@nelint.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/iomux.h> +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart_pads[] = { +#ifdef CONFIG_UART2_EIM_D26_27 + IOMUX_PADS(PAD_EIM_D26__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D27__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +#elif defined(CONFIG_UART1_CSI0_DAT10_11) + IOMUX_PADS(PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +#elif defined(CONFIG_UART1_SD3_DAT6_7) + IOMUX_PADS(PAD_SD3_DAT6__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT7__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +#elif defined(CONFIG_UART1_UART1) + MX6_PAD_UART1_TXD__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RXD__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), +#else +#error select UART console pads +#endif +}; + +#ifdef CONFIG_DDR3 +#define GRP_DDRTYPE 0x000C0000 +#else +#define GRP_DDRTYPE 0x00080000 +#endif + +/* all existing designs have this disabled */ +#define DDR_PKE 0 + +/* use Kconfig for ODT and DRIVE_STRENGTH */ +#define DDR_ODT \ + (CONFIG_DDR_ODT<<8) +#define DRAM_DRIVE_STRENGTH \ + (CONFIG_DRAM_DRIVE_STRENGTH << 3) + +/* configure MX6Q/DUAL mmdc DDR io registers */ +static struct mx6dq_iomux_ddr_regs const mx6dq_ddr_ioregs = { + /* SDCLK[0:1], CAS, RAS, Reset: Differential input, 40ohm */ + .dram_sdclk_0 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_sdclk_1 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_cas = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_ras = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_reset = DDR_ODT+DRAM_DRIVE_STRENGTH, + /* SDCKE[0:1]: 100k pull-up */ + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + /* SDBA2: pull-up disabled */ + .dram_sdba2 = 0x00000000, + /* SDODT[0:1]: 100k pull-up, 40 ohm */ + .dram_sdodt0 = 0x00003000+DRAM_DRIVE_STRENGTH, + .dram_sdodt1 = 0x00003000+DRAM_DRIVE_STRENGTH, + /* SDQS[0:7]: Differential input, 40 ohm */ + .dram_sdqs0 = DRAM_DRIVE_STRENGTH, + .dram_sdqs1 = DRAM_DRIVE_STRENGTH, + .dram_sdqs2 = DRAM_DRIVE_STRENGTH, + .dram_sdqs3 = DRAM_DRIVE_STRENGTH, + .dram_sdqs4 = DRAM_DRIVE_STRENGTH, + .dram_sdqs5 = DRAM_DRIVE_STRENGTH, + .dram_sdqs6 = DRAM_DRIVE_STRENGTH, + .dram_sdqs7 = DRAM_DRIVE_STRENGTH, + + /* DQM[0:7]: Differential input, 40 ohm */ + .dram_dqm0 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm1 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm2 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm3 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm4 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm5 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm6 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm7 = DDR_ODT+DRAM_DRIVE_STRENGTH, +}; + +/* configure MX6Q/DUAL mmdc GRP io registers */ +static struct mx6dq_iomux_grp_regs const mx6dq_grp_ioregs = { + /* DDR3 */ + .grp_ddr_type = GRP_DDRTYPE, + .grp_ddrmode_ctl = DDR_ODT, + /* disable DDR pullups */ + .grp_ddrpke = DDR_PKE, + /* ADDR[00:16], SDBA[0:1]: 40 ohm */ + .grp_addds = DRAM_DRIVE_STRENGTH, + /* CS0/CS1/SDBA2/CKE0/CKE1/SDWE: 40 ohm */ + .grp_ctlds = DRAM_DRIVE_STRENGTH, + /* DATA[00:63]: Differential input, 40 ohm */ + .grp_ddrmode = DDR_ODT, + .grp_b0ds = DRAM_DRIVE_STRENGTH, + .grp_b1ds = DRAM_DRIVE_STRENGTH, + .grp_b2ds = DRAM_DRIVE_STRENGTH, + .grp_b3ds = DRAM_DRIVE_STRENGTH, + .grp_b4ds = DRAM_DRIVE_STRENGTH, + .grp_b5ds = DRAM_DRIVE_STRENGTH, + .grp_b6ds = DRAM_DRIVE_STRENGTH, + .grp_b7ds = DRAM_DRIVE_STRENGTH, +}; + +static struct mx6sdl_iomux_ddr_regs const mx6sdl_ddr_ioregs = { + /* SDCLK[0:1], CAS, RAS, Reset: Differential input, 40ohm */ + .dram_sdclk_0 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_sdclk_1 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_cas = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_ras = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_reset = DDR_ODT+DRAM_DRIVE_STRENGTH, + /* SDCKE[0:1]: 100k pull-up */ + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + /* SDBA2: pull-up disabled */ + .dram_sdba2 = 0x00000000, + /* SDODT[0:1]: 100k pull-up, 40 ohm */ + .dram_sdodt0 = 0x00003000+DRAM_DRIVE_STRENGTH, + .dram_sdodt1 = 0x00003000+DRAM_DRIVE_STRENGTH, + /* SDQS[0:7]: Differential input, 40 ohm */ + .dram_sdqs0 = DRAM_DRIVE_STRENGTH, + .dram_sdqs1 = DRAM_DRIVE_STRENGTH, + .dram_sdqs2 = DRAM_DRIVE_STRENGTH, + .dram_sdqs3 = DRAM_DRIVE_STRENGTH, + .dram_sdqs4 = DRAM_DRIVE_STRENGTH, + .dram_sdqs5 = DRAM_DRIVE_STRENGTH, + .dram_sdqs6 = DRAM_DRIVE_STRENGTH, + .dram_sdqs7 = DRAM_DRIVE_STRENGTH, + + /* DQM[0:7]: Differential input, 40 ohm */ + .dram_dqm0 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm1 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm2 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm3 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm4 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm5 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm6 = DDR_ODT+DRAM_DRIVE_STRENGTH, + .dram_dqm7 = DDR_ODT+DRAM_DRIVE_STRENGTH, +}; + +/* configure MX6SOLO/DUALLITE mmdc GRP io registers */ +static struct mx6sdl_iomux_grp_regs const mx6sdl_grp_ioregs = { + /* DDR3 */ + .grp_ddr_type = GRP_DDRTYPE, + /* SDQS[0:7]: Differential input, 40 ohm */ + .grp_ddrmode_ctl = DDR_ODT, + /* disable DDR pullups */ + .grp_ddrpke = DDR_PKE, + /* ADDR[00:16], SDBA[0:1]: 40 ohm */ + .grp_addds = DRAM_DRIVE_STRENGTH, + /* CS0/CS1/SDBA2/CKE0/CKE1/SDWE: 40 ohm */ + .grp_ctlds = DRAM_DRIVE_STRENGTH, + /* DATA[00:63]: Differential input, 40 ohm */ + .grp_ddrmode = DDR_ODT, + .grp_b0ds = DRAM_DRIVE_STRENGTH, + .grp_b1ds = DRAM_DRIVE_STRENGTH, + .grp_b2ds = DRAM_DRIVE_STRENGTH, + .grp_b3ds = DRAM_DRIVE_STRENGTH, + .grp_b4ds = DRAM_DRIVE_STRENGTH, + .grp_b5ds = DRAM_DRIVE_STRENGTH, + .grp_b6ds = DRAM_DRIVE_STRENGTH, + .grp_b7ds = DRAM_DRIVE_STRENGTH, +}; + +const struct mx6sl_iomux_ddr_regs mx6sl_ddr_ioregs = { + .dram_sdqs0 = DRAM_DRIVE_STRENGTH, + .dram_sdqs1 = DRAM_DRIVE_STRENGTH, + .dram_sdqs2 = DRAM_DRIVE_STRENGTH, + .dram_sdqs3 = DRAM_DRIVE_STRENGTH, + .dram_dqm0 = DRAM_DRIVE_STRENGTH, + .dram_dqm1 = DRAM_DRIVE_STRENGTH, + .dram_dqm2 = DRAM_DRIVE_STRENGTH, + .dram_dqm3 = DRAM_DRIVE_STRENGTH, + .dram_cas = DRAM_DRIVE_STRENGTH, + .dram_ras = DRAM_DRIVE_STRENGTH, + .dram_sdclk_0 = DRAM_DRIVE_STRENGTH, + .dram_reset = DRAM_DRIVE_STRENGTH, + .dram_sdba2 = 0x00020000, + .dram_odt0 = 0x00030000+DRAM_DRIVE_STRENGTH, + .dram_odt1 = 0x00030000+DRAM_DRIVE_STRENGTH, +}; + +const struct mx6sl_iomux_grp_regs mx6sl_grp_ioregs = { + .grp_b0ds = DRAM_DRIVE_STRENGTH, + .grp_b1ds = DRAM_DRIVE_STRENGTH, + .grp_b2ds = DRAM_DRIVE_STRENGTH, + .grp_b3ds = DRAM_DRIVE_STRENGTH, + .grp_addds = DRAM_DRIVE_STRENGTH, + .grp_ctlds = DRAM_DRIVE_STRENGTH, + .grp_ddrmode_ctl = DDR_ODT, + .grp_ddrpke = DDR_PKE, + .grp_ddrmode = DDR_ODT, + .grp_ddr_type = GRP_DDRTYPE, +}; + +static struct mx6_ddr_sysinfo const sysinfo = { + /* width of data bus:0=16,1=32,2=64 */ +#if CONFIG_DDRWIDTH == 32 + .dsize = 1, +#elif CONFIG_DDRWIDTH == 64 + .dsize = 2, +#else +#error missing CONFIG_DDRWIDTH +#endif + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, /* 32Gb per CS */ + + /* # of chip selects */ + .ncs = CONFIG_DDRCS, + .cs1_mirror = 0, + .bi_on = 1, /* Bank interleaving enabled */ + .rtt_nom = CONFIG_RTT_NOM, + .rtt_wr = CONFIG_RTT_WR, + .ralat = CONFIG_RALAT, /* Read additional latency */ + .walat = CONFIG_WALAT, /* Write additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ +#ifdef CONFIG_DDR3 + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + .sde_to_rst = 0x10, /* JEDEC value for LPDDR2 - 200us */ + .pd_fast_exit = 0, /* immaterial for calibration */ + .ddr_type = DDR_TYPE_DDR3, +#else + .rst_to_cke = 0x10, /* JEDEC value for LPDDR2: 200us */ + .sde_to_rst = 0, /* LPDDR2 does not need this field */ + .pd_fast_exit = 0, /* immaterial for calibration */ + .ddr_type = DDR_TYPE_LPDDR2, +#endif + .refsel = CONFIG_REFSEL, + .refr = CONFIG_REFR, +}; + +#ifdef CONFIG_MT41K512M16TNA +/* Micron MT41K512M16TNA-125 */ +static struct mx6_ddr3_cfg const ddrtype = { + .mem_speed = 1600, + .density = 8, + .width = 16, + .banks = 8, + .rowaddr = 15, + .coladdr = 10, + .pagesz = 1, + .trcd = 1375, + .trcmin = 5062, + .trasmin = 3750, +}; +#elif defined(CONFIG_MT41K128M16JT) +/* Micron MT41K128M16JT-125 */ +static struct mx6_ddr3_cfg const ddrtype = { + .mem_speed = 1600, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; +#elif defined(CONFIG_H5TQ4G63AFR) +/* Hynix H5TQ4G63AFR */ +static struct mx6_ddr3_cfg const ddrtype = { + .mem_speed = 1600, + .density = 4, + .width = 16, + .banks = 8, + .rowaddr = 15, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; +#elif defined CONFIG_H5TQ2G63DFR +/* Hynix H5TQ2G63DFR */ +static struct mx6_ddr3_cfg const ddrtype = { + .mem_speed = 1333, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1350, + .trcmin = 4950, + .trasmin = 3600, +}; +#elif defined(CONFIG_MT42L256M32D2LG) +/* Micron MT42L256M32D2LG */ +static struct mx6_lpddr2_cfg ddrtype = { + .mem_speed = 800, + .density = 4, + .width = 32, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .trcd_lp = 2000, + .trppb_lp = 2000, + .trpab_lp = 2250, + .trasmin = 4200, +}; +#elif defined(CONFIG_MT29PZZZ4D4BKESK) +/* Micron MT29PZZZ4D4BKESK */ +static struct mx6_lpddr2_cfg ddrtype = { + .mem_speed = 800, + .density = 4, + .width = 32, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .trcd_lp = 2000, + .trppb_lp = 2000, + .trpab_lp = 2250, + .trasmin = 4200, +}; +#else +#error please select DDR type using menuconfig +#endif + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* FIXME: these should probably be checked, especially + * for i.MX6SL, UL, ULL + */ + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static void display_calibration(struct mx6_mmdc_calibration *calib) +{ + printf(".p0_mpdgctrl0\t= 0x%08X\n", calib->p0_mpdgctrl0); + printf(".p0_mpdgctrl1\t= 0x%08X\n", calib->p0_mpdgctrl1); + printf(".p0_mprddlctl\t= 0x%08X\n", calib->p0_mprddlctl); + printf(".p0_mpwrdlctl\t= 0x%08X\n", calib->p0_mpwrdlctl); + printf(".p0_mpwldectrl0\t= 0x%08X\n", calib->p0_mpwldectrl0); + printf(".p0_mpwldectrl1\t= 0x%08X\n", calib->p0_mpwldectrl1); + if (sysinfo.dsize == 2) { + printf(".p1_mpdgctrl0\t= 0x%08X\n", calib->p1_mpdgctrl0); + printf(".p1_mpdgctrl1\t= 0x%08X\n", calib->p1_mpdgctrl1); + printf(".p1_mprddlctl\t= 0x%08X\n", calib->p1_mprddlctl); + printf(".p1_mpwrdlctl\t= 0x%08X\n", calib->p1_mpwrdlctl); + printf(".p1_mpwldectrl0\t= 0x%08X\n", calib->p1_mpwldectrl0); + printf(".p1_mpwldectrl1\t= 0x%08X\n", calib->p1_mpwldectrl1); + } +#ifdef CONFIG_IMXIMAGE_OUTPUT + printf("DATA 4 MX6_MMDC_P0_MPDGCTRL0\t= 0x%08X\n", calib->p0_mpdgctrl0); + printf("DATA 4 MX6_MMDC_P0_MPDGCTRL1\t= 0x%08X\n", calib->p0_mpdgctrl1); + printf("DATA 4 MX6_MMDC_P0_MPRDDLCTL\t= 0x%08X\n", calib->p0_mprddlctl); + printf("DATA 4 MX6_MMDC_P0_MPWRDLCTL\t= 0x%08X\n", calib->p0_mpwrdlctl); + printf("DATA 4 MX6_MMDC_P0_MPWLDECTRL0\t= 0x%08X\n", + calib->p0_mpwldectrl0); + printf("DATA 4 MX6_MMDC_P0_MPWLDECTRL1\t= 0x%08X\n", + calib->p0_mpwldectrl1); + if (sysinfo.dsize == 2) { + printf("DATA 4 MX6_MMDC_P1_MPDGCTRL0\t= 0x%08X\n", + calib->p1_mpdgctrl0); + printf("DATA 4 MX6_MMDC_P1_MPDGCTRL1\t= 0x%08X\n", + calib->p1_mpdgctrl1); + printf("DATA 4 MX6_MMDC_P1_MPRDDLCTL\t= 0x%08X\n", + calib->p1_mprddlctl); + printf("DATA 4 MX6_MMDC_P1_MPWRDLCTL\t= 0x%08X\n", + calib->p1_mpwrdlctl); + printf("DATA 4 MX6_MMDC_P1_MPWLDECTRL0\t= 0x%08X\n", + calib->p1_mpwldectrl0); + printf("DATA 4 MX6_MMDC_P1_MPWLDECTRL1\t= 0x%08X\n", + calib->p1_mpwldectrl1); + } +#endif +} + +/* + * called from C runtime startup code (arch/arm/lib/crt0.S:_main) + * - we have a stack and a place to store GD, both in SRAM + * - no variable global data is available + */ +void board_init_f(ulong dummy) +{ + int errs; + struct mx6_mmdc_calibration calibration = {0}; + u32 cpurev = get_cpu_rev(); + + memset((void *)gd, 0, sizeof(struct global_data)); + + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + + SETUP_IOMUX_PADS(uart_pads); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + if (sysinfo.dsize != 1) { + if (is_cpu_type(MXC_CPU_MX6SX) || + is_cpu_type(MXC_CPU_MX6UL) || + is_cpu_type(MXC_CPU_MX6SL)) { + printf("cpu type 0x%x doesn't support 64-bit bus\n", + get_cpu_type()); + reset_cpu(0); + } + } + printf("CPU: NXP i.MX%s rev%d.%d at %d MHz\n", + get_imx_type((cpurev & 0xFF000) >> 12), + (cpurev & 0x000F0) >> 4, + (cpurev & 0x0000F) >> 0, + mxc_get_clock(MXC_ARM_CLK) / 1000000); +#ifdef CONFIG_MX6SL + mx6sl_dram_iocfg(CONFIG_DDRWIDTH, &mx6sl_ddr_ioregs, + &mx6sl_grp_ioregs); +#else + if (is_cpu_type(MXC_CPU_MX6Q)) { + mx6dq_dram_iocfg(CONFIG_DDRWIDTH, &mx6dq_ddr_ioregs, + &mx6dq_grp_ioregs); + } else { + mx6sdl_dram_iocfg(CONFIG_DDRWIDTH, &mx6sdl_ddr_ioregs, + &mx6sdl_grp_ioregs); + } +#endif + mx6_dram_cfg(&sysinfo, &calibration, &ddrtype); + + errs = mmdc_do_write_level_calibration(&sysinfo); + if (errs) { + printf("error %d from write level calibration\n", errs); + } else { + errs = mmdc_do_dqs_calibration(&sysinfo); + if (errs) { + printf("error %d from write level calibration\n", errs); + } else { + printf("completed successfully\n"); + mmdc_read_calibration(&sysinfo, &calibration); + display_calibration(&calibration); + } + } + reset_cpu(0); +} diff --git a/configs/mx6memcal_defconfig b/configs/mx6memcal_defconfig new file mode 100644 index 0000000..7e07182 --- /dev/null +++ b/configs/mx6memcal_defconfig @@ -0,0 +1,32 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_MX6MEMCAL=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_REGEX=y diff --git a/include/configs/mx6memcal.h b/include/configs/mx6memcal.h new file mode 100644 index 0000000..75125f2 --- /dev/null +++ b/include/configs/mx6memcal.h @@ -0,0 +1,62 @@ +/* + * Copyright (C) 2010-2011 Freescale Semiconductor, Inc. + * + * Configuration settings for the Boundary Devices Nitrogen6X + * and Freescale i.MX6Q Sabre Lite boards. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* SPL */ + +#include "mx6_common.h" +#include "imx6_spl.h" + +#undef CONFIG_FSL_ESDHC +#undef CONFIG_MMC +#undef CONFIG_SPL_MMC_SUPPORT +#undef CONFIG_GENERIC_MMC +#undef CONFIG_CMD_FUSE + +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x20000000 +#define CONFIG_SYS_MALLOC_LEN (64 * 1024 * 1024) + +#define CONFIG_MXC_UART +#ifdef CONFIG_SERIAL_CONSOLE_UART1 +#if defined(CONFIG_MX6SL) +#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR +#else +#define CONFIG_MXC_UART_BASE UART1_BASE +#endif +#elif defined(CONFIG_SERIAL_CONSOLE_UART2) +#define CONFIG_MXC_UART_BASE UART2_BASE +#else +#error please define serial console (CONFIG_SERIAL_CONSOLE_UARTx) +#endif +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + 16) + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_IS_NOWHERE + +#endif /* __CONFIG_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 04e9536..6b67f7c 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -781,6 +781,7 @@ CONFIG_DCACHE_OFF CONFIG_DCACHE_WB CONFIG_DCFG_ADDR CONFIG_DCLK_DIV +CONFIG_DDR3 CONFIG_DDR_ CONFIG_DDR_2HCLK CONFIG_DDR_2T_TIMING @@ -1947,6 +1948,7 @@ CONFIG_LPC32XX_SSP CONFIG_LPC32XX_SSP_TIMEOUT CONFIG_LPC_BASE CONFIG_LPC_IO_BASE +CONFIG_LPDDR2 CONFIG_LPUART CONFIG_LPUART_32B_REG CONFIG_LQ035Q1_LCD_MODE @@ -8048,6 +8050,9 @@ CONFIG_TWR_P1025 CONFIG_TX_DESCR_NUM CONFIG_TZSW_RESERVED_DRAM_SIZE CONFIG_T_SH7706LSR +CONFIG_UART1_CSI0_DAT10_11 +CONFIG_UART1_UART1 +CONFIG_UART2_EIM_D26_27 CONFIG_UART_BASE CONFIG_UART_BR_PRELIM CONFIG_UART_CONSOLE
Hi Eric,
Do you still have plans on refreshing this series?
It does seem very useful.
Thanks
Hi Fabio,
On 07/14/2017 07:18 AM, Fabio Estevam wrote:
Hi Eric,
Plans is a strong word, but I certainly hope to find some time to continue this effort.
I haven't been doing too many new board bring-ups lately though, so it moved away from my front burner.
I set this aside because I wasn't able to get the "return to RBL" code working and figured I'd try to reverse-engineer the API.
Any hints you have in that area would be helpful, and will solve that other long-standing issue of how to live with SPL on i.MX.
It is, and even the RFC patch allows very quick testing of large numbers of boards to gather calibration data.
Regards,
Eric
Hi Eric,
Sorry, but what does "return to RBL" mean?
Regards,
Fabio Estevam
Hi Fabio,
On Fri, Jul 14, 2017 at 12:01 PM, Fabio Estevam festevam@gmail.com wrote:
Hi Eric,
I was trying to get the SPL to act as a plugin in this patch set, so we could send a full U-Boot with a memory test as a payload, but got stuck on the details.
https://lists.denx.de/pipermail/u-boot/2016-June/258784.html
Looking back at the patch set, the plugin support wasn't explicitly included.
I sent some notes in November:
https://lists.denx.de/pipermail/u-boot/2016-November/271647.html
And there was some follow-up in January:
https://lists.denx.de/pipermail/u-boot/2017-January/278518.html
Signed-off-by: Eric Nelson eric@nelint.com --- board/freescale/mx6memcal/spl.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/freescale/mx6memcal/spl.c b/board/freescale/mx6memcal/spl.c index 90e240f..4e63e34 100644 --- a/board/freescale/mx6memcal/spl.c +++ b/board/freescale/mx6memcal/spl.c @@ -400,6 +400,10 @@ void board_init_f(ulong dummy)
+ /* write leveling calibration defaults */ + calibration.p0_mpwrdlctl = 0x40404040; + calibration.p1_mpwrdlctl = 0x40404040; + /* setup AIPS and disable watchdog */ arch_cpu_init();
Signed-off-by: Eric Nelson eric@nelint.com --- configs/mx6memcal_sabrelite_defconfig | 34 ++++++++++++++++++++++++++++++++++ 1 file changed, 34 insertions(+) create mode 100644 configs/mx6memcal_sabrelite_defconfig
diff --git a/configs/mx6memcal_sabrelite_defconfig b/configs/mx6memcal_sabrelite_defconfig new file mode 100644 index 0000000..f0c7148 --- /dev/null +++ b/configs/mx6memcal_sabrelite_defconfig @@ -0,0 +1,34 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_MX6MEMCAL=y +CONFIG_MT41K128M16JT=y +CONFIG_SERIAL_CONSOLE_UART2=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_REGEX=y
Signed-off-by: Eric Nelson eric@nelint.com --- configs/mx6memcal_nitrogen6_max_defconfig | 33 +++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+) create mode 100644 configs/mx6memcal_nitrogen6_max_defconfig
diff --git a/configs/mx6memcal_nitrogen6_max_defconfig b/configs/mx6memcal_nitrogen6_max_defconfig new file mode 100644 index 0000000..097d27d --- /dev/null +++ b/configs/mx6memcal_nitrogen6_max_defconfig @@ -0,0 +1,33 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_MX6MEMCAL=y +CONFIG_SERIAL_CONSOLE_UART2=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_REGEX=y
Signed-off-by: Eric Nelson eric@nelint.com --- configs/mx6memcal_tr1x_defconfig | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+) create mode 100644 configs/mx6memcal_tr1x_defconfig
diff --git a/configs/mx6memcal_tr1x_defconfig b/configs/mx6memcal_tr1x_defconfig new file mode 100644 index 0000000..c79fd72 --- /dev/null +++ b/configs/mx6memcal_tr1x_defconfig @@ -0,0 +1,36 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_MX6MEMCAL=y +CONFIG_DDRWIDTH=32 +CONFIG_DDRCS=1 +CONFIG_MT41K128M16JT=y +CONFIG_UART1_UART1=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6SL" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_REGEX=y
Signed-off-by: Eric Nelson eric@nelint.com --- configs/mx6memcal_wandboard_solo_defconfig | 35 ++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+) create mode 100644 configs/mx6memcal_wandboard_solo_defconfig
diff --git a/configs/mx6memcal_wandboard_solo_defconfig b/configs/mx6memcal_wandboard_solo_defconfig new file mode 100644 index 0000000..f47ce43 --- /dev/null +++ b/configs/mx6memcal_wandboard_solo_defconfig @@ -0,0 +1,35 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_MX6MEMCAL=y +CONFIG_DDRWIDTH=32 +CONFIG_DDRCS=1 +CONFIG_H5TQ2G63DFR=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_REGEX=y
Note that for some reason, this is failing for me unless I select a DDR bus width of 32 bits.
Signed-off-by: Eric Nelson eric@nelint.com --- configs/mx6memcal_wandboard_quad_defconfig | 34 ++++++++++++++++++++++++++++++ 1 file changed, 34 insertions(+) create mode 100644 configs/mx6memcal_wandboard_quad_defconfig
diff --git a/configs/mx6memcal_wandboard_quad_defconfig b/configs/mx6memcal_wandboard_quad_defconfig new file mode 100644 index 0000000..291c273 --- /dev/null +++ b/configs/mx6memcal_wandboard_quad_defconfig @@ -0,0 +1,34 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_MX6MEMCAL=y +CONFIG_DDRCS=1 +CONFIG_H5TQ4G63AFR=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_REGEX=y
Signed-off-by: Eric Nelson eric@nelint.com --- configs/mx6memcal_mx6slevk_defconfig | 37 ++++++++++++++++++++++++++++++++++++ 1 file changed, 37 insertions(+) create mode 100644 configs/mx6memcal_mx6slevk_defconfig
diff --git a/configs/mx6memcal_mx6slevk_defconfig b/configs/mx6memcal_mx6slevk_defconfig new file mode 100644 index 0000000..aaa81bc --- /dev/null +++ b/configs/mx6memcal_mx6slevk_defconfig @@ -0,0 +1,37 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_MX6MEMCAL=y +CONFIG_DDRWIDTH=32 +CONFIG_DDRCS=1 +CONFIG_LPDDR2=y +CONFIG_RALAT=2 +CONFIG_UART1_UART1=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6SL" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_REGEX=y
Signed-off-by: Eric Nelson eric@nelint.com --- configs/mx6memcal_warpboard_defconfig | 39 +++++++++++++++++++++++++++++++++++ 1 file changed, 39 insertions(+) create mode 100644 configs/mx6memcal_warpboard_defconfig
diff --git a/configs/mx6memcal_warpboard_defconfig b/configs/mx6memcal_warpboard_defconfig new file mode 100644 index 0000000..1786e57 --- /dev/null +++ b/configs/mx6memcal_warpboard_defconfig @@ -0,0 +1,39 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_MX6MEMCAL=y +CONFIG_DDRWIDTH=32 +CONFIG_DDRCS=1 +CONFIG_LPDDR2=y +CONFIG_MT29PZZZ4D4BKESK=y +CONFIG_DRAM_DRIVE_STRENGTH=4 +CONFIG_RALAT=2 +CONFIG_UART1_UART1=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6SL" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_REGEX=y
I forgot to mention in the cover letter for the previous patch set that because the mx6memcal board has no implementation of storage (it only supports a serial console and DDR), I haven't tested the resulting U-Boot, which has very little besides "mtest" included.
I'm hoping to use this code base (mx6memcal) as a straw man for loading both SPL (as a plugin) and U-Boot through the serial download path as we've previously discussed in at least [1], [2] and [3].
Now that Peng's patch to imximage has been applied, we can start to look at the implementation details, and I hope this patch set can help move us toward an implementation.
The gist of what's needed to allow SPL to be loaded as a plugin and avoid the need for removable storage or a full (non-SPL) U-Boot is shown in patch 2.
That is, we need something akin to setjmp/longjmp to: 1. to save the early state of the machine before SPL configures the DDR controller, and 2. a routine that we can call to return to the boot ROM
To address #1, there's a clear precedent in the support for a save_boot_params() routine and patch 2 adds one that simply saves the working register set. Examining the registers used by the ROM code shows that r0-r9 plus sp and lr are sufficient.
Experimentally, I've found that the boot ROM stack is initialized to 0x91ffb4 and that the stack pointer is at 0x91febc (248 bytes) on all of the machines I've tested against (MX6Q, MX6DL, MX6S and MX6SL), so we can save the stack just by moving the SPL stack (patch #1).
We'll also need to determine where the decision to return to the boot ROM occurs (i.e. when we call routine #2).
The obvious place for use during development is right after DDR initialization if loaded through the serial downloader, but it might also be useful to invoke the serial loader as a last resort instead of the current call to hang().
Patch 3 adds a config file which will allow a build of u-boot.imx with SPL as a plugin followed by u-boot.bin as the primary payload. It highlights the issue of only having a single IMX_CONFIG variable so it breaks the build of a stand-alone SPL. Rather, it doesn't break the build, but produces SPL that is effectively the same as u-boot.imx.
This leaves only the question of what the return_to_rom code should look like, and I'm a bit stumped. The ROM API isn't documented in any document I have.
In Troy's original patch ([4]), he calls a routine that he names HAB_RVT_LOAD_DATA. On i.MX Community ([5]), I found a reference to a plugin_download() routine and I'm not sure where that came from. The Community post suggests that it's used in EBOOT.
I tried a simplistic copy of the tail end of plugin start from [6] that calls pu_irom_hwcnfg_setup() and then returns to ROM without success. I'm not certain that this was the right approach and am hoping for some guidance.
References: [1] - http://lists.denx.de/pipermail/u-boot/2015-June/thread.html#215606 [2] - http://lists.denx.de/pipermail/u-boot/2016-September/thread.html#266303 [3] - http://lists.denx.de/pipermail/u-boot/2015-May/thread.html#215573 [4] - http://patchwork.ozlabs.org/patch/186054/ [5] - http://community.nxp.com/thread/303794 [6] - http://git.denx.de/?p=u-boot.git;a=blob;f=arch/arm/include/asm/arch-mx6/mx6_...
Eric Nelson (3): ARM: mx6: preserve Boot ROM stack in SPL ARM: mx6: ddr: add plugin-utils placeholder ARM: imx: mx6memcal: allow build of combined SPL+U-Boot
arch/arm/cpu/armv7/mx6/Makefile | 2 +- arch/arm/cpu/armv7/mx6/ddr.c | 4 ++++ arch/arm/cpu/armv7/mx6/plugin-utils.S | 24 ++++++++++++++++++++++++ arch/arm/imx-common/spl-plus-u-boot.cfg | 4 ++++ arch/arm/include/asm/arch-mx6/mx6-ddr.h | 19 +++++++++++++++++++ configs/mx6memcal_defconfig | 2 +- include/configs/imx6_spl.h | 2 +- 7 files changed, 54 insertions(+), 3 deletions(-) create mode 100644 arch/arm/cpu/armv7/mx6/plugin-utils.S create mode 100644 arch/arm/imx-common/spl-plus-u-boot.cfg
The i.MX6 Boot ROM starts its' stack at 0x091ffb4 and appears to be a little less than 256 bytes deep when starting U-Boot.
This was determined experimentally on i.MX6DL and i.MX6SL.
Allow this stack to be preserved to simplify returning to ROM when SPL is loaded as a plugin.
Signed-off-by: Eric Nelson eric@nelint.com --- include/configs/imx6_spl.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 76d1ca0..fb1b237 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -28,7 +28,7 @@ #define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv7/omap-common/u-boot-spl.lds" #define CONFIG_SPL_TEXT_BASE 0x00908000 #define CONFIG_SPL_MAX_SIZE 0x10000 -#define CONFIG_SPL_STACK 0x0091FFB8 +#define CONFIG_SPL_STACK 0x0091FEB8
/* NAND support */ #if defined(CONFIG_SPL_NAND_SUPPORT)
Add entry points for saving the state of the machine at entry from the Boot ROM and for restoring the state before a return.
Note that this needs some fixup before it's useful, so I'm forwarding it as an RFC to solicit advice.
This placeholder is little more than a setjmp/longjmp that saves the SP, LR and registers 0-9. Disassembling the ROM for i.MX6DL and i.MX6SL shows that these are the only registers used by the ROM on those SOCs.
Signed-off-by: Eric Nelson eric@nelint.com --- arch/arm/cpu/armv7/mx6/Makefile | 2 +- arch/arm/cpu/armv7/mx6/ddr.c | 4 ++++ arch/arm/cpu/armv7/mx6/plugin-utils.S | 24 ++++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/mx6-ddr.h | 19 +++++++++++++++++++ 4 files changed, 48 insertions(+), 1 deletion(-) create mode 100644 arch/arm/cpu/armv7/mx6/plugin-utils.S
diff --git a/arch/arm/cpu/armv7/mx6/Makefile b/arch/arm/cpu/armv7/mx6/Makefile index 8af191d..d0d0103 100644 --- a/arch/arm/cpu/armv7/mx6/Makefile +++ b/arch/arm/cpu/armv7/mx6/Makefile @@ -8,5 +8,5 @@ #
obj-y := soc.o clock.o -obj-$(CONFIG_SPL_BUILD) += ddr.o +obj-$(CONFIG_SPL_BUILD) += ddr.o plugin-utils.o obj-$(CONFIG_MP) += mp.o diff --git a/arch/arm/cpu/armv7/mx6/ddr.c b/arch/arm/cpu/armv7/mx6/ddr.c index 0cf391e..7f8e30d 100644 --- a/arch/arm/cpu/armv7/mx6/ddr.c +++ b/arch/arm/cpu/armv7/mx6/ddr.c @@ -1536,3 +1536,7 @@ void mx6_dram_cfg(const struct mx6_ddr_sysinfo *sysinfo, hang(); } } + +#ifdef CONFIG_SPL_BUILD +struct plugin_state plugin_state __attribute__((section(".data"))); +#endif diff --git a/arch/arm/cpu/armv7/mx6/plugin-utils.S b/arch/arm/cpu/armv7/mx6/plugin-utils.S new file mode 100644 index 0000000..c284a76 --- /dev/null +++ b/arch/arm/cpu/armv7/mx6/plugin-utils.S @@ -0,0 +1,24 @@ +/* + * Utility functions for executing as an i.MX plugin + * + * Copyright (c) 2016 Nelson Integration, LLC + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/system.h> +#include <linux/linkage.h> + +ENTRY(save_boot_params) + ldr r10, =plugin_state + stmia r10, {r0, r1, r2, r3, r4, r5, r6, r7, r8, r9, fp, sp, lr} + b save_boot_params_ret +ENDPROC(save_boot_params) + +ENTRY(return_to_rom) + ldr r10, =plugin_state + ldmia r10, {r0, r1, r2, r3, r4, r5, r6, r7, r8, r9, fp, sp, lr} + bx lr +ENDPROC(return_to_rom) diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h index 2a8d443..52420da 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -528,4 +528,23 @@ void mx6_dram_cfg(const struct mx6_ddr_sysinfo *, #define MX6_MMDC_P1_MPZQLP2CTL 0x021b485C #define MX6_MMDC_P1_MPMUR0 0x021b48b8
+#ifdef CONFIG_SPL_BUILD +struct plugin_state { + uint32_t r0; + uint32_t r1; + uint32_t r2; + uint32_t r3; + uint32_t r4; + uint32_t r5; + uint32_t r6; + uint32_t r7; + uint32_t r8; + uint32_t r9; + uint32_t fp; + uint32_t sp; + uint32_t lr; +}; +void return_to_rom(void); +#endif + #endif /*__ASM_ARCH_MX6_DDR_H__ */
Add an imximage config file to construct u-boot.imx with SPL as a plugin and use it as a straw-man for the mx6memcal virtual board.
Note that this breaks the build of SPL because only one value can be listed for IMX_CONFIG.
As it stands, all imx SPL builds use an almost empty .cfg file from arch/arm/configs/spl_sd.cfg.
This could be hard-coded for use in building SPL if we just remove the comments from the file (copyright).
Signed-off-by: Eric Nelson eric@nelint.com --- arch/arm/imx-common/spl-plus-u-boot.cfg | 4 ++++ configs/mx6memcal_defconfig | 2 +- 2 files changed, 5 insertions(+), 1 deletion(-) create mode 100644 arch/arm/imx-common/spl-plus-u-boot.cfg
diff --git a/arch/arm/imx-common/spl-plus-u-boot.cfg b/arch/arm/imx-common/spl-plus-u-boot.cfg new file mode 100644 index 0000000..5940cb0 --- /dev/null +++ b/arch/arm/imx-common/spl-plus-u-boot.cfg @@ -0,0 +1,4 @@ +IMAGE_VERSION 2 +BOOT_FROM sd +PLUGIN spl/u-boot-spl.bin 0x00907000 + diff --git a/configs/mx6memcal_defconfig b/configs/mx6memcal_defconfig index 7e07182..06aa85f 100644 --- a/configs/mx6memcal_defconfig +++ b/configs/mx6memcal_defconfig @@ -6,7 +6,7 @@ CONFIG_MX6_DDRCAL=y CONFIG_TARGET_MX6MEMCAL=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl-plus-u-boot.cfg,SPL,MX6QDL" CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set
- to save the early state of the machine before SPL configures the DDR controller, and
- a routine that we can call to return to the boot ROM
-- 2.7.4
Hi Eric,
I'm interested loading U-Boot from the OTG serial downloader and this looks like a good approach. Thanks for continuing to plug away at this!
If I understand correctly the approach here is to use the plugin support such that the boot ROM will execute the SPL as a plugin which then returns and jumps to U-boot?
I've applied your mx6memcal series to master and support for one of the Gateworks boards I'm working with and can boot that SPL (23KB) fine (so I've got the UART and configured correctly at least). When I adapt that to use pl-plus-u-boot.cfg on top of this patch series the resulting SPL (85KB) image doens't appear to boot (nothing over the serial console) but I'm thinking I'm doing something wrong as imx_usb_loader seems like its not loading it fully or loading it too quickly. Do I need patches to imx_usb_loader or am I doing something obvious wrong here?
Incidentally, did anyone ever proof out the other discussed method where an SPL is built with zmodem and allows loading u-boot.img over that?
Regards,
Tim
Hi Tim,
-- 2.7.4
Hi Eric,
NP. It seems like the easy route if we can figure out the details of the ROM API calls.
I was hoping to get some feedback from Peng or Troy, but it seems that they're also overloaded.
That's the idea. Both SB_LOADER and imx_usb support this, so the key is figuring out how to return to the Boot ROM.
I've applied your mx6memcal series to master and support for one of the Gateworks boards I'm working with and can boot that SPL (23KB) fine (so I've got the UART and configured correctly at least). When I adapt that to use spl-plus-u-boot.cfg on top of this patch series the resulting SPL (85KB) image doens't appear to boot (nothing over the serial console) but I'm thinking I'm doing something wrong as imx_usb_loader seems like its not loading it fully or loading it too quickly. Do I need patches to imx_usb_loader or am I doing something obvious wrong here?
I need to re-visit this. My recollection is that the SPL portion should load and run, but the return-to-ROM portion will fail.
My next thought is to use JTAG to trace things through the return to BOOT ROM and use an image from the Freescale fork as a working example.
Yeah.
Stefano had that working, though I had some issues getting microcom working. I had to stop and restart microcom and initiate the upload.
Regards,
Eric
On Wed, Jan 18, 2017 at 9:05 AM, Eric Nelson eric@nelint.com wrote:
Hi Tim,
-- 2.7.4
Hi Eric,
ok - I thought you had it fully working, but it does sound like you at least got further than I'm getting (you saw the SPL boot at least) so let me know what you find when you re-visit it.
Yeah.
Stefano,
Did you document the 'IMX6 SPL to U-Boot over serial' setup anywhere, or can you talk me through what you did?
Thanks,
Tim
Hi Tim,
It is available at doc/README.imx6 (2. Using imx_usb_loader for first install with SPL).
On Wed, Jan 18, 2017 at 11:01 AM, Fabio Estevam festevam@gmail.com wrote:
Hi Tim,
Fabio,
Thanks for pointing me in the right direction. I did manage to get IMX6 SPL Ymodem working although I had to hack the return value of spl_boot_device(). In my current situation with a board that has no BOOT MODE pin strapping, and no fuses blown imx_usb_loader spl_boot_device() returns BOOT_DEVICE_NOR which is wrong.
The SRC_SBMR register reflects the BOOT MODE pins of the chip (strapping) but the reference manual defines SRC_GPR9 and SRC_GPR10[28] as reserved and I don't recall the reasoning for using these for the boot mode. Can you provide some documentation that we can put in the code? I'm thinking there is something else missing from this function that should be able to determine that the serial downloader was used in my case and return BOOT_DEVICE_UART appropriately.
Regards,
Tim
Hi Tim,
I could also not found any documentation about SRC_GPR9 and SRC_GPR10[28].
I also find it confusing that we use such undocumented registers in U-Boot for determining the boot mode.
I think the BootROM is the ultimate resource here. Did you look internally for its source?
participants (7)
Christoph Fritz
Eric Nelson
Fabio Estevam
Otavio Salvador
Stefano Babic
Tim Harvey
