[U-Boot] [PATCH] ARM: fix build error
error message: /home/leiwen/reps/clones/uboot/include/asm/u-boot-arm.h:66: error: conflicting types for 'setenv' /home/leiwen/reps/clones/uboot/include/common.h:271: note: previous declaration of 'setenv' was here
Since common code has change the setenv declaration method, follow the common code to do the same change.
Signed-off-by: Lei Wen leiwen@marvell.com --- arch/arm/include/asm/u-boot-arm.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/include/asm/u-boot-arm.h b/arch/arm/include/asm/u-boot-arm.h index 3904027..b01a0e9 100644 --- a/arch/arm/include/asm/u-boot-arm.h +++ b/arch/arm/include/asm/u-boot-arm.h @@ -63,7 +63,7 @@ void setup_revision_tag (struct tag **params); /* To be fixed! */ /* ------------------------------------------------------------ */ /* common/cmd_nvedit.c */ -int setenv (char *, char *); +int setenv (const char *, const char *);
/* cpu/.../interrupt.c */ int arch_interrupt_init (void);
Dear Lei Wen,
No, this is the wrong approach. Instead of maintaining several duplicated versions of the prototype (and even with a bogus comment above it) whe should use a single definition only. See previously posted patches.
Thanks anyway.
Lei Wen
