[PATCH] docs: Fix conf.py for Sphinx 2.0
commit 3bc8088464712fdcb078eefb68837ccfcc413c88 upstream.
Our version check in Documentation/conf.py never envisioned a world where Sphinx moved beyond 1.x. Now that the unthinkable has happened, fix our version check to handle higher version numbers correctly.
Signed-off-by: Jonathan Corbet corbet@lwn.net [rebase for u-boot] Signed-off-by: Sean Anderson seanga2@gmail.com ---
doc/conf.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/doc/conf.py b/doc/conf.py index 0772fb6f0c..8bb27ad9e2 100644 --- a/doc/conf.py +++ b/doc/conf.py @@ -37,7 +37,7 @@ needs_sphinx = '1.3' extensions = ['kerneldoc', 'rstFlatTable', 'kernel_include', 'cdomain', 'kfigure']
# The name of the math extension changed on Sphinx 1.4 -if major == 1 and minor > 3: +if (major == 1 and minor > 3) or (major > 1): extensions.append("sphinx.ext.imgmath") else: extensions.append("sphinx.ext.pngmath")
*bump*
It's been a month, any comments on this?
--Sean
Sean Anderson
