[PATCH 00/10] efi: Improvements to booting and debugging
This series provides support for booting a kernel from the EFI app. So far this is pretty basic, since it only supports the actual booting, not providing ACPI tables, etc. But it is a start.
It also includes an enhancement to the 'efi' command and a few other clean-ups.
Simon Glass (10): efi: Set RUN_64BIT correctly for the EFI app x86: Adjust bootparam.h to be more like linux x86: Add return-value comment to cpu_jump_to_64bit() x86: Support booting a 64-bit kernel from 64-bit U-Boot x86: Exit EFI boot services before starting kernel x86: Support zboot and bootm in the EFI app efi: Add another tranch of GUIDs doc: Add help for the efi command efi: Support showing tables efI: Allow packaging a kernel in the debugging script
arch/x86/Kconfig | 4 +- arch/x86/include/asm/bootm.h | 12 +- arch/x86/include/asm/bootparam.h | 70 ++++++---- arch/x86/include/asm/cpu.h | 1 + arch/x86/lib/bootm.c | 43 ++++-- arch/x86/lib/zimage.c | 17 ++- cmd/efi.c | 40 +++++- configs/efi-x86_app32_defconfig | 2 +- configs/efi-x86_app64_defconfig | 3 +- doc/usage/cmd/efi.rst | 219 +++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + include/efi_api.h | 28 ++++ lib/uuid.c | 12 ++ scripts/build-efi.sh | 14 +- 14 files changed, 419 insertions(+), 47 deletions(-) create mode 100644 doc/usage/cmd/efi.rst
The U-Boot EFI app can run as a 64-bit program, so set the Kconfig correctly in that case. Make sure it doesn't build SPL, since there is no need to switch from 32 to 64 bit when running.
arch/x86/Kconfig | 4 ++-- configs/efi-x86_app64_defconfig | 1 + 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 07be5cd05ec..99e59d94c60 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -32,8 +32,8 @@ config X86_RUN_32BIT config X86_RUN_64BIT bool "64-bit" select X86_64 - select SPL - select SPL_SEPARATE_BSS + select SPL if !EFI_APP + select SPL_SEPARATE_BSS if !EFI_APP help Build U-Boot as a 64-bit binary with a 32-bit SPL. This is experimental and many features are missing. U-Boot SPL starts up, diff --git a/configs/efi-x86_app64_defconfig b/configs/efi-x86_app64_defconfig index dae48840493..f1cf43c1ef6 100644 --- a/configs/efi-x86_app64_defconfig +++ b/configs/efi-x86_app64_defconfig @@ -4,6 +4,7 @@ CONFIG_ENV_SIZE=0x1000 CONFIG_DEFAULT_DEVICE_TREE="efi-x86_app" CONFIG_DEBUG_UART_BASE=0 CONFIG_DEBUG_UART_CLOCK=0 +CONFIG_X86_RUN_64BIT=y CONFIG_VENDOR_EFI=y CONFIG_TARGET_EFI_APP64=y CONFIG_DEBUG_UART=y
This likely came from Linux originally, so update it to match v6.2 more. This has no functional change.
arch/x86/include/asm/bootparam.h | 70 +++++++++++++++++++++----------- arch/x86/lib/zimage.c | 2 +- 2 files changed, 47 insertions(+), 25 deletions(-)
diff --git a/arch/x86/include/asm/bootparam.h b/arch/x86/include/asm/bootparam.h index 7a3c1f51554..ea816ca7469 100644 --- a/arch/x86/include/asm/bootparam.h +++ b/arch/x86/include/asm/bootparam.h @@ -9,19 +9,54 @@ #include <asm/ist.h> #include <asm/video/edid.h>
-/* setup data types */ -enum { - SETUP_NONE = 0, - SETUP_E820_EXT, - SETUP_DTB, -}; +/* setup_data/setup_indirect types */ +#define SETUP_NONE 0 +#define SETUP_E820_EXT 1 +#define SETUP_DTB 2 +#define SETUP_PCI 3 +#define SETUP_EFI 4 +#define SETUP_APPLE_PROPERTIES 5 +#define SETUP_JAILHOUSE 6 +#define SETUP_CC_BLOB 7 +#define SETUP_IMA 8 +#define SETUP_RNG_SEED 9 +#define SETUP_ENUM_MAX SETUP_RNG_SEED + +#define SETUP_INDIRECT BIT(31) +#define SETUP_TYPE_MAX (SETUP_ENUM_MAX | SETUP_INDIRECT) + +/* ram_size flags */ +#define RAMDISK_IMAGE_START_MASK 0x07FF +#define RAMDISK_PROMPT_FLAG 0x8000 +#define RAMDISK_LOAD_FLAG 0x4000 + +/* loadflags */ +#define LOADED_HIGH BIT(0) +#define KASLR_FLAG BIT(1) +#define QUIET_FLAG BIT(5) +#define KEEP_SEGMENTS BIT(6) +#define CAN_USE_HEAP BIT(7) + +#define XLF_KERNEL_64 BIT(0) +#define XLF_CAN_BE_LOADED_ABOVE_4G BIT(1) +#define XLF_EFI_HANDOVER_32 BIT(2) +#define XLF_EFI_HANDOVER_64 BIT(3) +#define XLF_EFI_KEXEC BIT(4)
/* extensible setup data list node */ struct setup_data { __u64 next; __u32 type; __u32 len; - __u8 data[0]; + __u8 data[]; +}; + +/* extensible setup indirect data node */ +struct setup_indirect { + __u32 type; + __u32 reserved; /* Reserved, must be set to zero. */ + __u64 len; + __u64 addr; };
/** @@ -34,9 +69,6 @@ struct setup_header { __u16 root_flags; __u32 syssize; __u16 ram_size; -#define RAMDISK_IMAGE_START_MASK 0x07FF -#define RAMDISK_PROMPT_FLAG 0x8000 -#define RAMDISK_LOAD_FLAG 0x4000 __u16 vid_mode; __u16 root_dev; __u16 boot_flag; @@ -44,15 +76,10 @@ struct setup_header { __u32 header; __u16 version; __u32 realmode_swtch; - __u16 start_sys; + __u16 start_sys_seg; __u16 kernel_version; __u8 type_of_loader; __u8 loadflags; -#define LOADED_HIGH BIT(0) -#define KASLR_FLAG BIT(1) -#define QUIET_FLAG BIT(5) -#define KEEP_SEGMENTS BIT(6) /* Obsolete */ -#define CAN_USE_HEAP BIT(7) __u16 setup_move_size; __u32 code32_start; __u32 ramdisk_image; @@ -65,13 +92,8 @@ struct setup_header { __u32 initrd_addr_max; __u32 kernel_alignment; __u8 relocatable_kernel; - u8 min_alignment; -#define XLF_KERNEL_64 BIT(0) -#define XLF_CAN_BE_LOADED_ABOVE_4G BIT(1) -#define XLF_EFI_HANDOVER_32 BIT(2) -#define XLF_EFI_HANDOVER_64 BIT(3) -#define XLF_EFI_KEXEC BIT(4) - u16 xloadflags; + __u8 min_alignment; + __u16 xloadflags; __u32 cmdline_size; __u32 hardware_subarch; __u64 hardware_subarch_data; @@ -81,7 +103,7 @@ struct setup_header { __u64 pref_address; __u32 init_size; __u32 handover_offset; - u32 kernel_info_offset; + __u32 kernel_info_offset; } __attribute__((packed));
struct sys_desc_table { diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index 9cc04490307..a6d9151c324 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -655,7 +655,7 @@ void zimage_dump(struct boot_params *base_ptr) printf("%-20s %s\n", "", "Ancient kernel, using version 100"); print_num("Version", hdr->version); print_num("Real mode switch", hdr->realmode_swtch); - print_num("Start sys", hdr->start_sys); + print_num("Start sys seg", hdr->start_sys_seg); print_num("Kernel version", hdr->kernel_version); version = get_kernel_version(base_ptr, (void *)state.bzimage_addr); if (version)
This does not mention what it returns. Add the missing documentation.
arch/x86/include/asm/cpu.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/x86/include/asm/cpu.h b/arch/x86/include/asm/cpu.h index 3346012d335..aa03ef598e1 100644 --- a/arch/x86/include/asm/cpu.h +++ b/arch/x86/include/asm/cpu.h @@ -262,6 +262,7 @@ void cpu_call32(ulong code_seg32, ulong target, ulong table); * * @setup_base: Pointer to the setup.bin information for the kernel * @target: Pointer to the start of the kernel image + * Returns: -EFAULT if the kernel returned; otherwise does not return */ int cpu_jump_to_64bit(ulong setup_base, ulong target);
Add the missing code to handle this. For a 64-bit kernel the entry address is 0x200 bytes after the normal entry.
Rename the parameter to boot_linux_kernel() accordingly. Update the comments to indicate that these are addresses, not pointers.
arch/x86/include/asm/bootm.h | 12 ++++++------ arch/x86/lib/bootm.c | 25 +++++++++++++++++-------- arch/x86/lib/zimage.c | 15 +++++++++++++-- 3 files changed, 36 insertions(+), 16 deletions(-)
diff --git a/arch/x86/include/asm/bootm.h b/arch/x86/include/asm/bootm.h index 109f686f740..3b641783b9c 100644 --- a/arch/x86/include/asm/bootm.h +++ b/arch/x86/include/asm/bootm.h @@ -14,14 +14,14 @@ void bootm_announce_and_cleanup(void); * This boots a kernel image, either 32-bit or 64-bit. It will also work with * a self-extracting kernel, if you set @image_64bit to false. * - * @setup_base: Pointer to the setup.bin information for the kernel - * @load_address: Pointer to the start of the kernel image - * @image_64bit: true if the image is a raw 64-bit kernel, false if it - * is raw 32-bit or any type of self-extracting kernel - * such as a bzImage. + * @setup_base: Address of the setup.bin information for the kernel + * @entry: Address of the kernel entry point + * @image_64bit: true if the image is a raw 64-bit kernel, or a kernel + * which supports booting in 64-bit mode; false if it is raw 32-bit or any type + * of self-extracting kernel such as a bzImage. * Return: -ve error code. This function does not return if the kernel was * booted successfully. */ -int boot_linux_kernel(ulong setup_base, ulong load_address, bool image_64bit); +int boot_linux_kernel(ulong setup_base, ulong entry, bool image_64bit);
#endif diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index 873e2bc176f..9beb376bb9c 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -149,7 +149,7 @@ error: return 1; }
-int boot_linux_kernel(ulong setup_base, ulong load_address, bool image_64bit) +int boot_linux_kernel(ulong setup_base, ulong entry, bool image_64bit) { bootm_announce_and_cleanup();
@@ -161,14 +161,23 @@ int boot_linux_kernel(ulong setup_base, ulong load_address, bool image_64bit) puts("Cannot boot 64-bit kernel on 32-bit machine\n"); return -EFAULT; } - /* At present 64-bit U-Boot does not support booting a + /* + * At present 64-bit U-Boot only supports booting a 64-bit * kernel. - * TODO(sjg@chromium.org): Support booting both 32-bit and - * 64-bit kernels from 64-bit U-Boot. + * + * TODO(sjg@chromium.org): Support booting 32-bit kernels from + * 64-bit U-Boot */ -#if !CONFIG_IS_ENABLED(X86_64) - return cpu_jump_to_64bit(setup_base, load_address); -#endif + if (CONFIG_IS_ENABLED(X86_64)) { + typedef void (*h_func)(ulong zero, ulong setup); + h_func func; + + /* jump to Linux with rdi=0, rsi=setup_base */ + func = (h_func)entry; + func(0, setup_base); + } else { + return cpu_jump_to_64bit(setup_base, entry); + } } else { /* * Set %ebx, %ebp, and %edi to 0, %esi to point to the @@ -190,7 +199,7 @@ int boot_linux_kernel(ulong setup_base, ulong load_address, bool image_64bit) "movl $0, %%ebp\n" "cli\n" "jmp *%[kernel_entry]\n" - :: [kernel_entry]"a"(load_address), + :: [kernel_entry]"a"(entry), [boot_params] "S"(setup_base), "b"(0), "D"(0) ); diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index a6d9151c324..e5ea5129c1e 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -504,13 +504,24 @@ static int do_zboot_info(struct cmd_tbl *cmdtp, int flag, int argc, static int do_zboot_go(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { + struct boot_params *params = state.base_ptr; + struct setup_header *hdr = ¶ms->hdr; + bool image_64bit; + ulong entry; int ret;
disable_interrupts();
+ entry = state.load_address; + image_64bit = false; + if (IS_ENABLED(CONFIG_X86_RUN_64BIT) && + (hdr->xloadflags & XLF_KERNEL_64)) { + entry += 0x200; + image_64bit = true; + } + /* we assume that the kernel is in place */ - ret = boot_linux_kernel((ulong)state.base_ptr, state.load_address, - false); + ret = boot_linux_kernel((ulong)state.base_ptr, entry, image_64bit); printf("Kernel returned! (err=%d)\n", ret);
return CMD_RET_FAILURE;
When running the EFI app, we need to exit boot services before jumping to Linux.
At some point it may be possible to jump to Linux and pass on the boot services, so that the Linux efistub can be used. For now, this is not implemented.
arch/x86/lib/bootm.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index 9beb376bb9c..61cb7bc6116 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -10,6 +10,7 @@ #include <common.h> #include <bootstage.h> #include <command.h> +#include <efi.h> #include <hang.h> #include <log.h> #include <asm/global_data.h> @@ -156,6 +157,23 @@ int boot_linux_kernel(ulong setup_base, ulong entry, bool image_64bit) #ifdef CONFIG_SYS_COREBOOT timestamp_add_now(TS_U_BOOT_START_KERNEL); #endif + + /* + * Exit EFI boot services just before jumping, after all console + * output, since the console won't be available afterwards. + */ + if (IS_ENABLED(CONFIG_EFI_APP)) { + int ret; + + ret = efi_store_memory_map(efi_get_priv()); + if (ret) + return ret; + printf("Exiting EFI boot services\n"); + ret = efi_call_exit_boot_services(); + if (ret) + return ret; + } + if (image_64bit) { if (!cpu_has_64bit()) { puts("Cannot boot 64-bit kernel on 32-bit machine\n");
These have been disabled due to the rudimentary support available. It is a little better now, so enable these options.
configs/efi-x86_app32_defconfig | 2 +- configs/efi-x86_app64_defconfig | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/efi-x86_app32_defconfig b/configs/efi-x86_app32_defconfig index 905f375a3ef..50975dbfaaf 100644 --- a/configs/efi-x86_app32_defconfig +++ b/configs/efi-x86_app32_defconfig @@ -19,7 +19,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_LAST_STAGE_INIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=532 -# CONFIG_CMD_BOOTM is not set +CONFIG_CMD_BOOTZ=y CONFIG_CMD_PART=y # CONFIG_CMD_NET is not set CONFIG_CMD_TIME=y diff --git a/configs/efi-x86_app64_defconfig b/configs/efi-x86_app64_defconfig index f1cf43c1ef6..0fc358ddcdf 100644 --- a/configs/efi-x86_app64_defconfig +++ b/configs/efi-x86_app64_defconfig @@ -20,7 +20,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_LAST_STAGE_INIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=532 -# CONFIG_CMD_BOOTM is not set +CONFIG_CMD_BOOTZ=y CONFIG_CMD_PART=y # CONFIG_CMD_NET is not set CONFIG_CMD_CACHE=y
Provide information about the GUIDs supplied by QEMU, so far as it is known.
include/efi_api.h | 28 ++++++++++++++++++++++++++++ lib/uuid.c | 12 ++++++++++++ 2 files changed, 40 insertions(+)
diff --git a/include/efi_api.h b/include/efi_api.h index 2d18d25a713..90caee4038c 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -1909,6 +1909,34 @@ struct efi_system_resource_table { EFI_GUID(0x4aafd29d, 0x68df, 0x49ee, 0x8a, 0xa9, \ 0x34, 0x7d, 0x37, 0x56, 0x65, 0xa7)
+#define EFI_LZMA_COMPRESSED \ + EFI_GUID(0xee4e5898, 0x3914, 0x4259, 0x9d, 0x6e, \ + 0xdc, 0x7b, 0xd7, 0x94, 0x03, 0xcf) +#define EFI_DXE_SERVICES \ + EFI_GUID(0x05ad34ba, 0x6f02, 0x4214, 0x95, 0x2e, \ + 0x4d, 0xa0, 0x39, 0x8e, 0x2b, 0xb9) +#define EFI_HOB_LIST \ + EFI_GUID(0x7739f24c, 0x93d7, 0x11d4, 0x9a, 0x3a, \ + 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d) +#define EFI_MEMORY_TYPE \ + EFI_GUID(0x4c19049f, 0x4137, 0x4dd3, 0x9c, 0x10, \ + 0x8b, 0x97, 0xa8, 0x3f, 0xfd, 0xfa) +#define EFI_SMBIOS \ + EFI_GUID(0xeb9d2d31, 0x2d88, 0x11d3, 0x9a, 0x16, \ + 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d) +#define EFI_MEM_STATUS_CODE_REC \ + EFI_GUID(0x060cc026, 0x4c0d, 0x4dda, 0x8f, 0x41, \ + 0x59, 0x5f, 0xef, 0x00, 0xa5, 0x02) +#define EFI_GUID_SNBIOS \ + EFI_GUID(0xeb9d2d31, 0x2d88, 0x11d3, 0x9a, 0x16, \ + 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d) +#define EFI_GUID_EFI_ACPI1 \ + EFI_GUID(0xeb9d2d30, 0x2d88, 0x11d3, 0x9a, 0x16, \ + 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d) +#define EFI_GUID_EFI_ACPI2 \ + EFI_GUID(0x8868e871, 0xe4f1, 0x11d3, 0xbc, 0x22, \ + 0x00, 0x80, 0xc7, 0x3c, 0x88, 0x81) + /** * struct win_certificate_uefi_guid - A certificate that encapsulates * a GUID-specific signature diff --git a/lib/uuid.c b/lib/uuid.c index 465e1ac38f5..77aef746a2e 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -255,6 +255,18 @@ static const struct { EFI_CERT_TYPE_PKCS7_GUID, }, #endif +#ifdef CONFIG_EFI_APP +#endif + { "EFI_LZMA_COMPRESSED", EFI_LZMA_COMPRESSED }, + { "EFI_DXE_SERVICES", EFI_DXE_SERVICES }, + { "EFI_HOB_LIST", EFI_HOB_LIST }, + { "EFI_MEMORY_TYPE", EFI_MEMORY_TYPE }, + { "EFI_SMBIOS", EFI_SMBIOS }, + { "EFI_MEM_STATUS_CODE_REC", EFI_MEM_STATUS_CODE_REC }, + { "EFI_GUID_SNBIOS", EFI_GUID_SNBIOS }, + { "EFI_GUID_EFI_ACPI1", EFI_GUID_EFI_ACPI1 }, + { "EFI_GUID_EFI_ACPI2", EFI_GUID_EFI_ACPI2 }, + };
Hi Simon
What the patch does is obvious. Can you explain why this is needed though?
This already exists as SMBIOS_TABLE_GUID
what is SNBIOS? I assume it's a typos since it matches the existing SMBIOS_TABLE_GUID?
Already exists as EFI_ACPI_TABLE_GUID
- struct win_certificate_uefi_guid - A certificate that encapsulates
- a GUID-specific signature
2.39.2.637.g21b0678d19-goog
Thanks /Ilias
Hi Ilias,
On Wed, 1 Mar 2023 at 01:52, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon
Yes. It allows seeing what the tables actually are, since the GUIDs are impenetrable for that. See for example the 'efi table' command in this series.
I think %sU uses it too.
Oh dear, OK. Would you mind if I rename it? It is hard to find things if the naming is inconsistent.
Yes, a typo
OK, bind if I rename it so we have these consistent?
Hi Simon,
On Thu, 2 Mar 2023 at 01:38, Simon Glass sjg@chromium.org wrote:
Hi Ilias,
Hi Simon
Yes, but please put that in the commit message in the next version.
I think the naming is already quite consistent here. We are trying to follow what's in the EFI specification, so it's easy to search and find things in there (ยง4.6.1.1 Industry Standard Configuration Tables). I'd rather leave it as is
Yes, a typo
The same thing applies to this one, it's described as-is in the EFI spec.
Thanks /Ilias
This command currently has no help. Add some.
doc/usage/cmd/efi.rst | 197 ++++++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 198 insertions(+) create mode 100644 doc/usage/cmd/efi.rst
diff --git a/doc/usage/cmd/efi.rst b/doc/usage/cmd/efi.rst new file mode 100644 index 00000000000..c029c423879 --- /dev/null +++ b/doc/usage/cmd/efi.rst @@ -0,0 +1,197 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright 2020, Heinrich Schuchardt xypron.glpk@gmx.de + +efi command +=========== + +Synopsis +-------- + +:: + + efi mem [all] + +Description +----------- + +The *efi* command provides information about the EFI environment U-Boot is +running in, when it is started from EFI. + +When running as an EFI app, this command queries EFI boot services for the +information. When running as an EFI payload, EFI boot services have been +stopped, so it uses the information collected by the boot stub before that +happened. + +efi mem +~~~~~~~ + +This shows the EFI memory map, sorted in order of physical address. + +This is normally a very large table. To help reduce the amount of detritus, +boot-time memory is normally merged with conventional memory. Use the 'all' +argument to show everything. + +The fields are as follows: + +# + Entry number (sequentially from 0) + +Type + Memory type. EFI has a large number of memory types. The type is shown in + the format <n>:<name> where in is the format number in hex and <name> is the + name. + +Physical + Physical address + +Virtual + Virtual address + +Size + Size of memory area in bytes + +Attributes + Shows a code for memory attributes. The key for this is shown below the + table. + +Example +------- + +:: + + => efi mem + EFI table at 0, memory map 000000001ad38b60, size 1260, key a79, version 1, descr. size 0x30 + # Type Physical Virtual Size Attributes + 0 7:conv 0000000000 0000000000 00000a0000 f + <gap> 00000a0000 0000060000 + 1 7:conv 0000100000 0000000000 0000700000 f + 2 a:acpi_nvs 0000800000 0000000000 0000008000 f + 3 7:conv 0000808000 0000000000 0000008000 f + 4 a:acpi_nvs 0000810000 0000000000 00000f0000 f + 5 7:conv 0000900000 0000000000 001efef000 f + 6 6:rt_data 001f8ef000 0000000000 0000100000 rf + 7 5:rt_code 001f9ef000 0000000000 0000100000 rf + 8 0:reserved 001faef000 0000000000 0000080000 f + 9 9:acpi_reclaim 001fb6f000 0000000000 0000010000 f + 10 a:acpi_nvs 001fb7f000 0000000000 0000080000 f + 11 7:conv 001fbff000 0000000000 0000359000 f + 12 6:rt_data 001ff58000 0000000000 0000020000 rf + 13 a:acpi_nvs 001ff78000 0000000000 0000088000 f + <gap> 0020000000 0090000000 + 14 0:reserved 00b0000000 0000000000 0010000000 1 + + Attributes key: + f: uncached, write-coalescing, write-through, write-back + rf: uncached, write-coalescing, write-through, write-back, needs runtime mapping + 1: uncached + *Some areas are merged (use 'all' to see) + + + => efi mem all + EFI table at 0, memory map 000000001ad38bb0, size 1260, key a79, version 1, descr. size 0x30 + # Type Physical Virtual Size Attributes + 0 3:bs_code 0000000000 0000000000 0000001000 f + 1 7:conv 0000001000 0000000000 000009f000 f + <gap> 00000a0000 0000060000 + 2 7:conv 0000100000 0000000000 0000700000 f + 3 a:acpi_nvs 0000800000 0000000000 0000008000 f + 4 7:conv 0000808000 0000000000 0000008000 f + 5 a:acpi_nvs 0000810000 0000000000 00000f0000 f + 6 4:bs_data 0000900000 0000000000 0000c00000 f + 7 7:conv 0001500000 0000000000 000aa36000 f + 8 2:loader_data 000bf36000 0000000000 0010000000 f + 9 4:bs_data 001bf36000 0000000000 0000020000 f + 10 7:conv 001bf56000 0000000000 00021e1000 f + 11 1:loader_code 001e137000 0000000000 00000c4000 f + 12 7:conv 001e1fb000 0000000000 000009b000 f + 13 1:loader_code 001e296000 0000000000 00000e2000 f + 14 7:conv 001e378000 0000000000 000005b000 f + 15 4:bs_data 001e3d3000 0000000000 000001e000 f + 16 7:conv 001e3f1000 0000000000 0000016000 f + 17 4:bs_data 001e407000 0000000000 0000016000 f + 18 2:loader_data 001e41d000 0000000000 0000002000 f + 19 4:bs_data 001e41f000 0000000000 0000828000 f + 20 3:bs_code 001ec47000 0000000000 0000045000 f + 21 4:bs_data 001ec8c000 0000000000 0000001000 f + 22 3:bs_code 001ec8d000 0000000000 000000e000 f + 23 4:bs_data 001ec9b000 0000000000 0000001000 f + 24 3:bs_code 001ec9c000 0000000000 000002c000 f + 25 4:bs_data 001ecc8000 0000000000 0000001000 f + 26 3:bs_code 001ecc9000 0000000000 000000c000 f + 27 4:bs_data 001ecd5000 0000000000 0000006000 f + 28 3:bs_code 001ecdb000 0000000000 0000014000 f + 29 4:bs_data 001ecef000 0000000000 0000001000 f + 30 3:bs_code 001ecf0000 0000000000 000005b000 f + 31 4:bs_data 001ed4b000 0000000000 000000b000 f + 32 3:bs_code 001ed56000 0000000000 0000024000 f + 33 4:bs_data 001ed7a000 0000000000 0000006000 f + 34 3:bs_code 001ed80000 0000000000 0000010000 f + 35 4:bs_data 001ed90000 0000000000 0000002000 f + 36 3:bs_code 001ed92000 0000000000 0000025000 f + 37 4:bs_data 001edb7000 0000000000 0000003000 f + 38 3:bs_code 001edba000 0000000000 0000011000 f + 39 4:bs_data 001edcb000 0000000000 0000008000 f + 40 3:bs_code 001edd3000 0000000000 000002d000 f + 41 4:bs_data 001ee00000 0000000000 0000201000 f + 42 3:bs_code 001f001000 0000000000 0000024000 f + 43 4:bs_data 001f025000 0000000000 0000002000 f + 44 3:bs_code 001f027000 0000000000 0000009000 f + 45 4:bs_data 001f030000 0000000000 0000005000 f + 46 3:bs_code 001f035000 0000000000 000002f000 f + 47 4:bs_data 001f064000 0000000000 0000001000 f + 48 3:bs_code 001f065000 0000000000 0000005000 f + 49 4:bs_data 001f06a000 0000000000 0000005000 f + 50 3:bs_code 001f06f000 0000000000 0000007000 f + 51 4:bs_data 001f076000 0000000000 0000007000 f + 52 3:bs_code 001f07d000 0000000000 000000d000 f + 53 4:bs_data 001f08a000 0000000000 0000001000 f + 54 3:bs_code 001f08b000 0000000000 0000006000 f + 55 4:bs_data 001f091000 0000000000 0000004000 f + 56 3:bs_code 001f095000 0000000000 000000d000 f + 57 4:bs_data 001f0a2000 0000000000 0000003000 f + 58 3:bs_code 001f0a5000 0000000000 0000026000 f + 59 4:bs_data 001f0cb000 0000000000 0000005000 f + 60 3:bs_code 001f0d0000 0000000000 0000019000 f + 61 4:bs_data 001f0e9000 0000000000 0000004000 f + 62 3:bs_code 001f0ed000 0000000000 0000024000 f + 63 4:bs_data 001f111000 0000000000 0000008000 f + 64 3:bs_code 001f119000 0000000000 000000b000 f + 65 4:bs_data 001f124000 0000000000 0000001000 f + 66 3:bs_code 001f125000 0000000000 0000002000 f + 67 4:bs_data 001f127000 0000000000 0000002000 f + 68 3:bs_code 001f129000 0000000000 0000009000 f + 69 4:bs_data 001f132000 0000000000 0000003000 f + 70 3:bs_code 001f135000 0000000000 0000005000 f + 71 4:bs_data 001f13a000 0000000000 0000003000 f + 72 3:bs_code 001f13d000 0000000000 0000005000 f + 73 4:bs_data 001f142000 0000000000 0000003000 f + 74 3:bs_code 001f145000 0000000000 0000011000 f + 75 4:bs_data 001f156000 0000000000 000000b000 f + 76 3:bs_code 001f161000 0000000000 0000009000 f + 77 4:bs_data 001f16a000 0000000000 0000400000 f + 78 3:bs_code 001f56a000 0000000000 0000006000 f + 79 4:bs_data 001f570000 0000000000 0000001000 f + 80 3:bs_code 001f571000 0000000000 0000001000 f + 81 4:bs_data 001f572000 0000000000 0000002000 f + 82 3:bs_code 001f574000 0000000000 0000017000 f + 83 4:bs_data 001f58b000 0000000000 0000364000 f + 84 6:rt_data 001f8ef000 0000000000 0000100000 rf + 85 5:rt_code 001f9ef000 0000000000 0000100000 rf + 86 0:reserved 001faef000 0000000000 0000080000 f + 87 9:acpi_reclaim 001fb6f000 0000000000 0000010000 f + 88 a:acpi_nvs 001fb7f000 0000000000 0000080000 f + 89 4:bs_data 001fbff000 0000000000 0000201000 f + 90 7:conv 001fe00000 0000000000 00000e8000 f + 91 4:bs_data 001fee8000 0000000000 0000020000 f + 92 3:bs_code 001ff08000 0000000000 0000026000 f + 93 4:bs_data 001ff2e000 0000000000 0000009000 f + 94 3:bs_code 001ff37000 0000000000 0000021000 f + 95 6:rt_data 001ff58000 0000000000 0000020000 rf + 96 a:acpi_nvs 001ff78000 0000000000 0000088000 f + <gap> 0020000000 0090000000 + 97 0:reserved 00b0000000 0000000000 0010000000 1 + + Attributes key: + f: uncached, write-coalescing, write-through, write-back + rf: uncached, write-coalescing, write-through, write-back, needs runtime mapping + 1: uncached diff --git a/doc/usage/index.rst b/doc/usage/index.rst index cde7dcb14a6..68522c18c04 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -42,6 +42,7 @@ Shell commands cmd/cyclic cmd/dm cmd/echo + cmd/efi cmd/eficonfig cmd/env cmd/event
Add a command to display the tables provided by EFI.
cmd/efi.c | 40 +++++++++++++++++++++++++++++++++++++++- doc/usage/cmd/efi.rst | 22 ++++++++++++++++++++++ 2 files changed, 61 insertions(+), 1 deletion(-)
diff --git a/cmd/efi.c b/cmd/efi.c index c0384e0db28..86988d9e9e2 100644 --- a/cmd/efi.c +++ b/cmd/efi.c @@ -7,10 +7,12 @@ #include <common.h> #include <command.h> #include <efi.h> +#include <efi_api.h> #include <errno.h> #include <log.h> #include <malloc.h> #include <sort.h> +#include <uuid.h> #include <asm/global_data.h>
DECLARE_GLOBAL_DATA_PTR; @@ -273,8 +275,43 @@ done: return ret ? CMD_RET_FAILURE : 0; }
+static int do_efi_tables(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct efi_system_table *systab; + int i; + + if (IS_ENABLED(CONFIG_EFI_APP)) { + systab = efi_get_sys_table(); + if (!systab) { + printf("Cannot read system table\n"); + return CMD_RET_FAILURE; + } + } else { + int size; + int ret; + + ret = efi_info_get(EFIET_SYS_TABLE, (void **)&systab, &size); + if (ret) { + printf("Cannot find EFI system table (err=%d)\n", ret); + return CMD_RET_FAILURE; + } + } + for (i = 0; i < systab->nr_tables; i++) { + struct efi_configuration_table *tab = &systab->tables[i]; + char guid_str[37]; + + uuid_bin_to_str(tab->guid.b, guid_str, 1); + printf("%p %s %s\n", tab->table, guid_str, + uuid_guid_get_str(tab->guid.b)); + } + + return 0; +} + static struct cmd_tbl efi_commands[] = { U_BOOT_CMD_MKENT(mem, 1, 1, do_efi_mem, "", ""), + U_BOOT_CMD_MKENT(tables, 1, 1, do_efi_tables, "", ""), };
static int do_efi(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) @@ -298,5 +335,6 @@ static int do_efi(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) U_BOOT_CMD( efi, 3, 1, do_efi, "EFI access", - "mem [all] Dump memory information [include boot services]" + "mem [all] Dump memory information [include boot services]\n" + "tables Dump tables" ); diff --git a/doc/usage/cmd/efi.rst b/doc/usage/cmd/efi.rst index c029c423879..2424d3bb587 100644 --- a/doc/usage/cmd/efi.rst +++ b/doc/usage/cmd/efi.rst @@ -10,6 +10,7 @@ Synopsis ::
efi mem [all] + efi tables
Description ----------- @@ -54,6 +55,14 @@ Attributes Shows a code for memory attributes. The key for this is shown below the table.
+efi tables +~~~~~~~~~~ + +This shows a list of the EFI tables provided in the system table. These use +GUIDs so it is not possible in general to show the name of a table. But some +effort is made to provide a useful table, where the GUID is known by U-Boot. + + Example -------
@@ -195,3 +204,16 @@ Example f: uncached, write-coalescing, write-through, write-back rf: uncached, write-coalescing, write-through, write-back, needs runtime mapping 1: uncached + + + => efi tables + 000000001f8eda98 ee4e5898-3914-4259-9d6e-dc7bd79403cf EFI_LZMA_COMPRESSED + 000000001ff2ace0 05ad34ba-6f02-4214-952e-4da0398e2bb9 EFI_DXE_SERVICES + 000000001f8ea018 7739f24c-93d7-11d4-9a3a-0090273fc14d EFI_HOB_LIST + 000000001ff2bac0 4c19049f-4137-4dd3-9c10-8b97a83ffdfa EFI_MEMORY_TYPE + 000000001ff2cb10 49152e77-1ada-4764-b7a2-7afefed95e8b <NULL> + 000000001f9ac018 060cc026-4c0d-4dda-8f41-595fef00a502 EFI_MEM_STATUS_CODE_REC + 000000001f9ab000 eb9d2d31-2d88-11d3-9a16-0090273fc14d EFI_SMBIOS + 000000001fb7e000 eb9d2d30-2d88-11d3-9a16-0090273fc14d EFI_GUID_EFI_ACPI1 + 000000001fb7e014 8868e871-e4f1-11d3-bc22-0080c73c8881 EFI_GUID_EFI_ACPI2 + 000000001e550018 dcfa911d-26eb-469f-a220-38b7dc461220 <NULL>
char *const argv[])
We already have function do_efi_show_tables() to print the list of EFI configuration tables. Please, avoid code duplication.
- struct efi_system_table *systab;
- int i;
- if (IS_ENABLED(CONFIG_EFI_APP)) {
if (!systab) {
- } else {
int size;
int ret;
if (ret) {
- for (i = 0; i < systab->nr_tables; i++) {
char guid_str[37];
do_efi_show_tables() does this with printf("%pUl (%pUs)\n",..).
- "mem [all] Dump memory information [include boot services]\n"
- "tables Dump tables" );
efi mem [all]
efi tables
Description
Example
- => efi tables
- 000000001f8eda98 ee4e5898-3914-4259-9d6e-dc7bd79403cf EFI_LZMA_COMPRESSED
- 000000001ff2ace0 05ad34ba-6f02-4214-952e-4da0398e2bb9 EFI_DXE_SERVICES
- 000000001f8ea018 7739f24c-93d7-11d4-9a3a-0090273fc14d EFI_HOB_LIST
- 000000001ff2bac0 4c19049f-4137-4dd3-9c10-8b97a83ffdfa EFI_MEMORY_TYPE
- 000000001ff2cb10 49152e77-1ada-4764-b7a2-7afefed95e8b <NULL>
This is what 'efi tables' / printf("%pUl (%pUs)\n",..). would output for an unknown table:
8868e871-e4f1-11d3-bc22-0080c73c8881 (8868e871-e4f1-11d3-bc22-0080c73c8881)
Maybe uuid_guid_get_str() should return an empty string in case of an unknown GUID.
- 000000001f9ac018 060cc026-4c0d-4dda-8f41-595fef00a502 EFI_MEM_STATUS_CODE_REC
- 000000001f9ab000 eb9d2d31-2d88-11d3-9a16-0090273fc14d EFI_SMBIOS
- 000000001fb7e000 eb9d2d30-2d88-11d3-9a16-0090273fc14d EFI_GUID_EFI_ACPI1
- 000000001fb7e014 8868e871-e4f1-11d3-bc22-0080c73c8881 EFI_GUID_EFI_ACPI2
- 000000001e550018 dcfa911d-26eb-469f-a220-38b7dc461220 <NULL>
Who would care about the address of the table?
Best regards
Heinrich
Hi Heinrich,
char *const argv[])
OK I created a separate file.
Of course the 'efidebug' command cannot be used in the app or payload, since it did not create the systab.
int i;
if (!systab) {
} else {
int size;
int ret;
if (ret) {
char guid_str[37];
);"tables Dump tables"
efi mem [all]
efi tables
Description
Example
- => efi tables
OK
Me when I am looking at them!
Add an option to package a kernel into the debugging script used for EFI.
The name of the kernel must be added to the script. Bd efault it is assumed that the kernel is built in the /tmp/kernel directory.
scripts/build-efi.sh | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/scripts/build-efi.sh b/scripts/build-efi.sh index 46c28807ef1..6b7df2e9bfe 100755 --- a/scripts/build-efi.sh +++ b/scripts/build-efi.sh @@ -18,12 +18,15 @@ # OVMF-pure-efi.x64.fd at # https://drive.google.com/file/d/1c39YI9QtpByGQ4V0UNNQtGqttEzS-eFV/view?usp=s...
+bzimage_fname=/tmp/kernel/arch/x86/boot/bzImage + set -e
usage() { echo "Usage: $0 [-a | -p] [other opts]" 1>&2 echo 1>&2 echo " -a - Package up the app" 1>&2 + echo " -k - Add a kernel" 1>&2 echo " -o - Use old EFI app build (before 32/64 split)" 1>&2 echo " -p - Package up the payload" 1>&2 echo " -P - Create a partition table" 1>&2 @@ -52,11 +55,14 @@ serial= # before the 32/64 split of the app old=
+# package up a kernel as well +kernel= + # Set ubdir to the build directory where you build U-Boot out-of-tree # We avoid in-tree build because it gets confusing trying different builds ubdir=/tmp/b/
-while getopts "aopPrsw" opt; do +while getopts "akopPrsw" opt; do case "${opt}" in a) type=app @@ -64,6 +70,9 @@ while getopts "aopPrsw" opt; do p) type=payload ;; + k) + kernel=1 + ;; r) run=1 ;; @@ -124,6 +133,9 @@ EOF # Copy files into the filesystem copy_files() { sudo cp $TMP/* $MNT + if [[ -n "${kernel}" ]]; then + sudo cp ${bzimage_fname} $MNT/vmlinuz + fi }
# Create a filesystem on a raw device and copy in the files
Ilias Apalodimas
