[U-Boot-Users] [PATCH] 85xx: Convert MPC8544 DS to new TLB setup
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8544ds/Makefile | 4 +- board/freescale/mpc8544ds/init.S | 174 ---------------------------------- board/freescale/mpc8544ds/tlb.c | 104 ++++++++++++++++++++ board/freescale/mpc8544ds/u-boot.lds | 2 - include/configs/MPC8544DS.h | 1 + 5 files changed, 106 insertions(+), 179 deletions(-) delete mode 100644 board/freescale/mpc8544ds/init.S create mode 100644 board/freescale/mpc8544ds/tlb.c
diff --git a/board/freescale/mpc8544ds/Makefile b/board/freescale/mpc8544ds/Makefile index 665251d..53368b2 100644 --- a/board/freescale/mpc8544ds/Makefile +++ b/board/freescale/mpc8544ds/Makefile @@ -26,9 +26,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS := $(BOARD).o law.o - -SOBJS := init.o +COBJS := $(BOARD).o law.o tlb.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/mpc8544ds/init.S b/board/freescale/mpc8544ds/init.S deleted file mode 100644 index 3918176..0000000 --- a/board/freescale/mpc8544ds/init.S +++ /dev/null @@ -1,174 +0,0 @@ -/* - * Copyright 2007 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <ppc_asm.tmpl> -#include <ppc_defs.h> -#include <asm/cache.h> -#include <asm/mmu.h> -#include <config.h> -#include <mpc85xx.h> - -/* - * TLB0 and TLB1 Entries - * - * Out of reset, TLB1's Entry 0 maps the highest 4K for CCSRBAR. - * However, CCSRBAR is then relocated to CFG_CCSRBAR right after - * these TLB entries are established. - * - * The TLB entries for DDR are dynamically setup in spd_sdram() - * and use TLB1 Entries 8 through 15 as needed according to the - * size of DDR memory. - * - * MAS0: tlbsel, esel, nv - * MAS1: valid, iprot, tid, ts, tsize - * MAS2: epn, x0, x1, w, i, m, g, e - * MAS3: rpn, u0-u3, ux, sx, uw, sw, ur, sr - */ - -#define entry_start \ - mflr r1 ; \ - bl 0f ; - -#define entry_end \ -0: mflr r0 ; \ - mtlr r1 ; \ - blr ; - - - .section .bootpg, "ax" - .globl tlb1_entry -tlb1_entry: - entry_start - - /* - * Number of TLB0 and TLB1 entries in the following table - */ - .long (2f-1f)/16 -1: - /* - * TLB0 4K Non-cacheable, guarded - * 0xff700000 4K Initial CCSRBAR mapping - * - * This ends up at a TLB0 Index==0 entry, and must not collide - * with other TLB0 Entries. - */ - .long FSL_BOOKE_MAS0(0, 0, 0) - .long FSL_BOOKE_MAS1(1, 0, 0, 0, 0) - .long FSL_BOOKE_MAS2(CFG_CCSRBAR_DEFAULT, (MAS2_I|MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_CCSRBAR_DEFAULT, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) - - /* - * TLB0 16K Cacheable, guarded - * Temporary Global data for initialization - * - * Use four 4K TLB0 entries. These entries must be cacheable - * as they provide the bootstrap memory before the memory - * controler and real memory have been configured. - * - * These entries end up at TLB0 Indicies 0x10, 0x14, 0x18 and 0x1c, - * and must not collide with other TLB0 entries. - */ - .long FSL_BOOKE_MAS0(0, 0, 0) - .long FSL_BOOKE_MAS1(1, 0, 0, 0, 0) - .long FSL_BOOKE_MAS2(CFG_INIT_RAM_ADDR, (MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_INIT_RAM_ADDR, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) - - .long FSL_BOOKE_MAS0(0, 0, 0) - .long FSL_BOOKE_MAS1(1, 0, 0, 0, 0) - .long FSL_BOOKE_MAS2(CFG_INIT_RAM_ADDR + 4 * 1024, (MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_INIT_RAM_ADDR + 4 * 1024, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) - - .long FSL_BOOKE_MAS0(0, 0, 0) - .long FSL_BOOKE_MAS1(1, 0, 0, 0, 0) - .long FSL_BOOKE_MAS2(CFG_INIT_RAM_ADDR + 8 * 1024, (MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_INIT_RAM_ADDR + 8 * 1024, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) - - .long FSL_BOOKE_MAS0(0, 0, 0) - .long FSL_BOOKE_MAS1(1, 0, 0, 0, 0) - .long FSL_BOOKE_MAS2(CFG_INIT_RAM_ADDR + 12 * 1024, (MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_INIT_RAM_ADDR + 12 * 1024, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) - - - /* - * TLB 0: 64M Non-cacheable, guarded - * 0xfc000000 64M Covers FLASH at 0xFE800000 and 0xFF800000 - * Out of reset this entry is only 4K. - */ - .long FSL_BOOKE_MAS0(1, 0, 0) - .long FSL_BOOKE_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64M) - .long FSL_BOOKE_MAS2(CFG_BOOT_BLOCK, (MAS2_I|MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_BOOT_BLOCK, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) - - /* - * TLB 1: 1G Non-cacheable, guarded - * 0x80000000 1G PCIE 8,9,a,b - */ - .long FSL_BOOKE_MAS0(1, 1, 0) - .long FSL_BOOKE_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_1G) - .long FSL_BOOKE_MAS2(CFG_PCIE_PHYS, (MAS2_I|MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_PCIE_PHYS, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) - - /* - * TLB 2: 256M Non-cacheable, guarded - */ - .long FSL_BOOKE_MAS0(1, 2, 0) - .long FSL_BOOKE_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_256M) - .long FSL_BOOKE_MAS2(CFG_PCI_PHYS, (MAS2_I|MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_PCI_PHYS, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) - - /* - * TLB 3: 256M Non-cacheable, guarded - */ - .long FSL_BOOKE_MAS0(1, 3, 0) - .long FSL_BOOKE_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_256M) - .long FSL_BOOKE_MAS2(CFG_PCI_PHYS + 0x10000000, (MAS2_I|MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_PCI_PHYS + 0x10000000, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) - - /* - * TLB 4: 64M Non-cacheable, guarded - * 0xe000_0000 1M CCSRBAR - * 0xe100_0000 255M PCI IO range - */ - .long FSL_BOOKE_MAS0(1, 4, 0) - .long FSL_BOOKE_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64M) - .long FSL_BOOKE_MAS2(CFG_CCSRBAR, (MAS2_I|MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_CCSRBAR, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) - -#ifdef CFG_LBC_CACHE_BASE - /* - * TLB 5: 64M Cacheable, non-guarded - */ - .long FSL_BOOKE_MAS0(1, 5, 0) - .long FSL_BOOKE_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64M) - .long FSL_BOOKE_MAS2(CFG_LBC_CACHE_BASE, 0) - .long FSL_BOOKE_MAS3(CFG_LBC_CACHE_BASE, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) -#endif - /* - * TLB 6: 64M Non-cacheable, guarded - * 0xf8000000 64M PIXIS 0xF8000000 - 0xFBFFFFFF - */ - .long FSL_BOOKE_MAS0(1, 6, 0) - .long FSL_BOOKE_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64M) - .long FSL_BOOKE_MAS2(CFG_LBC_NONCACHE_BASE, (MAS2_I|MAS2_G)) - .long FSL_BOOKE_MAS3(CFG_LBC_NONCACHE_BASE, 0, (MAS3_SX|MAS3_SW|MAS3_SR)) -2: - entry_end diff --git a/board/freescale/mpc8544ds/tlb.c b/board/freescale/mpc8544ds/tlb.c new file mode 100644 index 0000000..6594579 --- /dev/null +++ b/board/freescale/mpc8544ds/tlb.c @@ -0,0 +1,104 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +#define SET_TLB_ENTRY(_tlb, _epn, _rpn, _perms, _wimge, _ts, _esel, _sz, _iprot) \ + { .tlb = _tlb, .epn = _epn, .rpn = _rpn, .perms = _perms, \ + .wimge = _wimge, .ts = _ts, .esel = _esel, .tsize = _sz, .iprot = _iprot } + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CFG_INIT_RAM_ADDR, CFG_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CFG_INIT_RAM_ADDR + 4 * 1024 , CFG_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CFG_INIT_RAM_ADDR + 8 * 1024 , CFG_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CFG_INIT_RAM_ADDR + 12 * 1024 , CFG_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + /* + * TLB 0: 64M Non-cacheable, guarded + * 0xfc000000 64M Covers FLASH at 0xFE800000 and 0xFF800000 + * Out of reset this entry is only 4K. + */ + SET_TLB_ENTRY(1, CFG_BOOT_BLOCK, CFG_BOOT_BLOCK, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_64M, 1), + /* + * TLB 1: 1G Non-cacheable, guarded + * 0x80000000 1G PCIE 8,9,a,b + */ + SET_TLB_ENTRY(1, CFG_PCIE_PHYS, CFG_PCIE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1G, 1), + + /* + * TLB 2: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CFG_PCI_PHYS, CFG_PCI_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 3: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CFG_PCI_PHYS + 0x10000000, CFG_PCI_PHYS + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 4: 64M Non-cacheable, guarded + * 0xe000_0000 1M CCSRBAR + * 0xe100_0000 255M PCI IO range + */ + SET_TLB_ENTRY(1, CFG_CCSRBAR, CFG_CCSRBAR, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_64M, 1), + +#ifdef CFG_LBC_CACHE_BASE + /* + * TLB 5: 64M Cacheable, non-guarded + */ + SET_TLB_ENTRY(1, CFG_LBC_CACHE_BASE, CFG_LBC_CACHE_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 5, BOOKE_PAGESZ_64M, 1), +#endif + /* + * TLB 6: 64M Non-cacheable, guarded + * 0xf8000000 64M PIXIS 0xF8000000 - 0xFBFFFFFF + */ + SET_TLB_ENTRY(1, CFG_LBC_NONCACHE_BASE, CFG_LBC_NONCACHE_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_64M, 1), +}; + +#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/board/freescale/mpc8544ds/u-boot.lds b/board/freescale/mpc8544ds/u-boot.lds index 66bd4b6..17db8c0 100644 --- a/board/freescale/mpc8544ds/u-boot.lds +++ b/board/freescale/mpc8544ds/u-boot.lds @@ -34,7 +34,6 @@ SECTIONS .bootpg 0xFFFFF000 : { cpu/mpc85xx/start.o (.bootpg) - board/freescale/mpc8544ds/init.o (.bootpg) } = 0xffff
/* Read-only sections, merged into text segment: */ @@ -64,7 +63,6 @@ SECTIONS .text : { cpu/mpc85xx/start.o (.text) - board/freescale/mpc8544ds/init.o (.text) cpu/mpc85xx/traps.o (.text) cpu/mpc85xx/interrupts.o (.text) cpu/mpc85xx/cpu_init.o (.text) diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index a894209..1269c8a 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -43,6 +43,7 @@ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */
#define CONFIG_FSL_LAW 1 /* Use common FSL init code */ +#define CONFIG_FSL_INIT_TLBS 1 /* Use common FSL init code */
#define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE
Kumar Gala
