[U-Boot] [PATCH] ppc4xx: Support PPC460EX rev B on gdsys CompactCenter
This patch is based on a patch for canyonlands by Stefan Roese.
Signed-off-by: Dirk Eibach eibach@gdsys.de --- board/gdsys/compactcenter/compactcenter.c | 16 ++++++++++++---- 1 files changed, 12 insertions(+), 4 deletions(-)
diff --git a/board/gdsys/compactcenter/compactcenter.c b/board/gdsys/compactcenter/compactcenter.c index 477ef70..4861cc8 100644 --- a/board/gdsys/compactcenter/compactcenter.c +++ b/board/gdsys/compactcenter/compactcenter.c @@ -39,10 +39,19 @@ DECLARE_GLOBAL_DATA_PTR;
#define CONFIG_SYS_BCSR3_PCIE 0x10
-int board_early_init_f(void) +static int pvr_460ex(void) { u32 pvr = get_pvr();
+ if ((pvr == PVR_460EX_RA) || (pvr == PVR_460EX_SE_RA) || + (pvr == PVR_460EX_RB)) + return 1; + + return 0; +} + +int board_early_init_f(void) +{ /* * Setup the interrupt controller polarities, triggers, etc. */ @@ -95,7 +104,7 @@ int board_early_init_f(void) mtdcr(AHB_TOP, 0x8000004B); mtdcr(AHB_BOT, 0x8000004B);
- if ((pvr == PVR_460EX_RA) || (pvr == PVR_460EX_SE_RA)) { + if (pvr_460ex()) { /* * Configure USB-STP pins as alternate and not GPIO * It seems to be neccessary to configure the STP pins as GPIO @@ -250,7 +259,6 @@ int misc_init_r(void) { u32 sdr0_srst1 = 0; u32 eth_cfg; - u32 pvr = get_pvr();
/* * Set EMAC mode/configuration (GMII, SGMII, RGMII...). @@ -264,7 +272,7 @@ int misc_init_r(void) /* Set the for 2 RGMII mode */ /* GMC0 EMAC4_0, GMC0 EMAC4_1, RGMII Bridge 0 */ eth_cfg &= ~SDR0_ETH_CFG_GMC0_BRIDGE_SEL; - if ((pvr == PVR_460EX_RA) || (pvr == PVR_460EX_SE_RA)) + if (pvr_460ex()) eth_cfg |= SDR0_ETH_CFG_GMC1_BRIDGE_SEL; else eth_cfg &= ~SDR0_ETH_CFG_GMC1_BRIDGE_SEL;
Hi Dirk,
- if ((pvr == PVR_460EX_RA) || (pvr == PVR_460EX_SE_RA) ||
return 1;
Do you really need this 460EX check at all on your boards? It's only needed on Canyonlands since this board port also support Glacier 460GT. From looking at your port, you don't need to support 460GT at all. So you could easily drop all these 460EX checks in your code.
Best regards, Stefan
Dirk Eibach
Stefan Roese
