[U-Boot] [PATCH] ppc4xx: Make pll_write global
This patch makes pll_write on PPC405EP boards global and callable from C code.
pll_write can be used to dynamically modify the PLB:PCI divider as it is required for 33/66 MHz pci adapters based on the 405EP.
board_early_init_f() is a good place to do that (check M66EN signal and call pll_write() when it is required).
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- cpu/ppc4xx/start.S | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index ac96fc2..582c781 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -2021,6 +2021,7 @@ pci_wait: ! Output r3 = none !----------------------------------------------------------------------------- */ + .globl pll_write pll_write: mfdcr r5, CPC0_UCR andis. r5,r5,0xFFFF
Applied to ppc4xx. Thanks.
Best regards, Stefan
Matthias Fuchs
Stefan Roese
