[U-Boot] [PATCH v3 2/2] Freescale 85xx/P1/P2 eSPI controller driver
Add support for Freescale eSPI driver in P1/P2 board configuration
Signed-off-by: Can Aydin can.aydin@locatacorp.com --- Changes for v2: - Coding style cleanup - Removed modifications to common code
Changes for v3: - fixed whitespace between function calls and parameters - replaced unneeded byte copy test function with memcpy - removed dead code and C++ style comments - separated board configuration patch from driver patch
include/configs/P1_P2_RDB.h | 7 +++++++ 1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index cff0ed3..33f1b1e 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -172,6 +172,13 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); */
/* + * eSPI - Enhanced SPI + */ +#define CONFIG_FSL_ESPI +#define CONFIG_HARD_SPI +#define CONFIG_CMD_SPI + +/* * Local Bus Definitions */ #define CONFIG_SYS_FLASH_BASE 0xef000000 /* start of FLASH 16M */
Can Aydin
