[U-Boot] at91sam9g20 MAC address in EEPROM?
Hello everyone,
I am working on a product based on Atmel's sam9g20. Atmel's flashing procedure stores the MAC address as a u-boot environment variable (ethaddr).
We are not comfortable with storing the MAC address this way, and would rather keep it in EEPROM. Does anyone have experience with this?
Thanks, Jim
On Sat, Jul 10, 2010 at 7:53 AM, Jim Sheldon jims@russound.com wrote:
Hello everyone,
Not on that chip, but we do it for Freescale PowerPC SOCs. Take a look at board/freescale/common/sys_eeprom.c
Jim Sheldon wrote:
Hello everyone,
You can just connect an I2C EEPROM (At24C64 or such), define the necessary macros to access it. An exampe how to special read and set environment you can find in board/emk/common/vpd.c.
Reinhard
Dear Jim Sheldon,
May I ask WHY you are not comfortable with using the U-Boot environment? Usually it's a very convenient place to store configuration data, and a pretty reliable one (especially when you use redundant environment).
I have seen _way_ more cases where data in EEPROM got lost than data loss from the environment.
Hello Mr. Denk,
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Saturday, August 07, 2010 4:00 PM To: Jim Sheldon Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] at91sam9g20 MAC address in EEPROM?
Dear Jim Sheldon,
We're not concerned about u-boot's environment not being reliable, we just want the ability to completely erase the nand without worrying about losing essential data (like a MAC address). I suppose we could work around that area of the flash if/when erasing the nand is necessary, but then we would have to keep track of each environment variable that could be stored there.
That's discouraging, do you have any advice for where to store the MAC outside of nand, and not in an EEPROM?
Thanks for all your work on such a great open source bootloader! :)
Take care, Jim
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de A witty saying proves nothing, but saying something pointless gets people's attention.
Dear Jim Sheldon,
That is exactly my concern as well.
I cannot second that, we have always stored environment and vital product data in EEPROM (AT24C64). But VPD (includes MAC adresses) is never writen by u-boot; only read and made into respective setenv() variables. Check boards/emk/common/vpd.c for an idea.
Greetings, Reinhard
Dear Reinhard Meyer,
Most people think they are safe when they only read the EEPROM. They are under a misapprehension. If you reset the processor at the right time within a I2C read command, and if you (or your I2C controller) don't take special care, the next read access might cause a write operation on that device. See doc/I2C_Edge_Conditions for details.
Note that this is NOT a theoretical case. Many people have seen this. I had this myself with a customer who was switching to another, cheaper power supply. Upon power on, the voltage ramp up was relatively slow, which caused the system watchdog to reset the system 2 or 3 times because of too low voltages - and with 3 out of 5 power-ons the EEPROM content got corrupted.
If you need reliable read-only storage, use NOR.
participants (5)
Jim Sheldon
Reinhard Meyer
Reinhard Meyer
Timur Tabi
