[U-Boot] [PATCH] Blackfin: update some missed board config.mk files
Seems these two files were missed during the big lib shuffle.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf527-ad7160-eval/config.mk | 4 ++-- board/ip04/config.mk | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/bf527-ad7160-eval/config.mk b/board/bf527-ad7160-eval/config.mk index f85bef5..3f9d41f 100644 --- a/board/bf527-ad7160-eval/config.mk +++ b/board/bf527-ad7160-eval/config.mk @@ -26,8 +26,8 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
-CFLAGS_lib_generic += -O2 -CFLAGS_lzma += -O2 +CFLAGS_lib += -O2 +CFLAGS_lib/lzma += -O2
# Set some default LDR flags based on boot mode. LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/ip04/config.mk b/board/ip04/config.mk index bc14257..5766829 100644 --- a/board/ip04/config.mk +++ b/board/ip04/config.mk @@ -26,8 +26,8 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
# Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8
Mike Frysinger
