[U-Boot] [PATCH v2 0/3] MX31: NAND boot for phyCORE and PDK boards.
Hi all,
I have now updated the i.MX31 NAND boot patches. It applies to the -next tree (aka v2009.06-rc1) as of now.
I've taken care of most of the comments/questions that were sent to Maxim Artamonov when he posted his latest (last?) patch. The comments received on my parts has been taken care of as well.
Some general comments: * phyCORE support has not been updated. I don't have such a board to test on. * The code has been tested on real hardware an boots Linux from ethernet. * There are infinite loops on nand_boot_mx31.c and looking at other nand_spl boards, they're there as well. If something goes wrong that early in the boot process there's really not a lot to do and remember that the NAND_SPL code has to fit in 2048 bytes.
Regards, Magnus
Magnus Lilja (3): MX31: Add NAND SPL for i.MX31. MX31: Add basic support for Freescale i.MX31 PDK board. MX31: Add NAND SPL boot support to i.MX31 PDK board.
MAKEALL | 2 + Makefile | 12 ++- board/freescale/mx31pdk/Makefile | 53 +++++++ board/freescale/mx31pdk/config.mk | 5 + board/freescale/mx31pdk/lowlevel_init.S | 123 +++++++++++++++ board/freescale/mx31pdk/mx31pdk.c | 76 +++++++++ board/freescale/mx31pdk/u-boot-nand.lds | 33 ++++ board/freescale/mx31pdk/u-boot.lds | 59 +++++++ cpu/arm1136/start.S | 29 ++-- include/asm-arm/arch-mx31/mx31-regs.h | 92 +++++++++++ include/configs/mx31pdk.h | 175 +++++++++++++++++++++ nand_spl/board/freescale/mx31pdk/Makefile | 54 +++++++ nand_spl/board/freescale/mx31pdk/config.mk | 5 + nand_spl/board/freescale/mx31pdk/u-boot.lds | 36 +++++ nand_spl/nand_boot_mx31.c | 223 +++++++++++++++++++++++++++ 15 files changed, 965 insertions(+), 12 deletions(-) create mode 100644 board/freescale/mx31pdk/Makefile create mode 100644 board/freescale/mx31pdk/config.mk create mode 100644 board/freescale/mx31pdk/lowlevel_init.S create mode 100644 board/freescale/mx31pdk/mx31pdk.c create mode 100644 board/freescale/mx31pdk/u-boot-nand.lds create mode 100644 board/freescale/mx31pdk/u-boot.lds create mode 100644 include/configs/mx31pdk.h create mode 100644 nand_spl/board/freescale/mx31pdk/Makefile create mode 100644 nand_spl/board/freescale/mx31pdk/config.mk create mode 100644 nand_spl/board/freescale/mx31pdk/u-boot.lds create mode 100644 nand_spl/nand_boot_mx31.c
This patch adds the NAND SPL framework needed to boot i.MX31 boards from NAND.
The patch is based on the work by Maxim Artamonov <scn1874 at yandex.ru > (which was signed-off-by him).
Signed-off-by: Magnus Lilja lilja.magnus@gmail.com --- cpu/arm1136/start.S | 29 +++-- include/asm-arm/arch-mx31/mx31-regs.h | 90 +++++++++++++ nand_spl/nand_boot_mx31.c | 223 +++++++++++++++++++++++++++++++++ 3 files changed, 331 insertions(+), 11 deletions(-) create mode 100644 nand_spl/nand_boot_mx31.c
diff --git a/cpu/arm1136/start.S b/cpu/arm1136/start.S index e622338..9bbbaf1 100644 --- a/cpu/arm1136/start.S +++ b/cpu/arm1136/start.S @@ -1,6 +1,9 @@ /* * armboot - Startup Code for OMP2420/ARM1136 CPU-core * + * + * Copyright (c) 2008 Maxim Artamonov, <scn1874 at yandex.ru> + * * Copyright (c) 2004 Texas Instruments r-woodruff2@ti.com * * Copyright (c) 2001 Marius Gröger mag@sysgo.de @@ -32,7 +35,7 @@ #include <version.h> .globl _start _start: b reset -#ifdef CONFIG_ONENAND_IPL +#if defined(CONFIG_ONENAND_IPL) || defined(CONFIG_NAND_SPL) ldr pc, _hang ldr pc, _hang ldr pc, _hang @@ -156,9 +159,9 @@ relocate: /* relocate U-Boot to RAM */ adr r0, _start /* r0 <- current position of code */ ldr r1, _TEXT_BASE /* test if we run from flash or RAM */ cmp r0, r1 /* don't reloc during debug */ -#ifndef CONFIG_ONENAND_IPL +#if !defined(CONFIG_ONENAND_IPL) && !defined(CONFIG_NAND_SPL) beq stack_setup -#endif /* CONFIG_ONENAND_IPL */ +#endif /* !CONFIG_ONENAND_IPL && !CONFIG_NAND_SPL*/
ldr r2, _armboot_start ldr r3, _bss_start @@ -175,7 +178,7 @@ copy_loop: /* Set up the stack */ stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ -#ifdef CONFIG_ONENAND_IPL +#if defined(CONFIG_ONENAND_IPL) || defined (CONFIG_NAND_SPL) sub sp, r0, #128 /* leave 32 words for abort-stack */ #else sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ @@ -184,14 +187,14 @@ stack_setup: sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif sub sp, r0, #12 /* leave 3 words for abort-stack */ -#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_ONENAND_IPL || CONFIG_NAND_SPL*/
clear_bss: ldr r0, _bss_start /* find start of bss segment */ ldr r1, _bss_end /* stop here */ mov r2, #0x00000000 /* clear */
-#ifndef CONFIG_ONENAND_IPL +#if !defined(CONFIG_ONENAND_IPL) && !defined(CONFIG_NAND_SPL) clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 @@ -200,12 +203,15 @@ clbss_l:str r2, [r0] /* clear loop... */
ldr pc, _start_armboot
+#ifdef CONFIG_NAND_SPL +_start_armboot: .word nand_boot +#else #ifdef CONFIG_ONENAND_IPL _start_armboot: .word start_oneboot #else _start_armboot: .word start_armboot -#endif - +#endif /* CONFIG_ONENAND_IPL */ +#endif /* CONFIG_NAND_SPL */
/* ************************************************************************* @@ -244,7 +250,7 @@ cpu_init_crit: mov lr, ip /* restore link */ mov pc, lr /* back to my caller */
-#ifndef CONFIG_ONENAND_IPL +#if !defined(CONFIG_ONENAND_IPL) && !defined(CONFIG_NAND_SPL) /* ************************************************************************* * @@ -357,12 +363,12 @@ cpu_init_crit: .macro get_fiq_stack @ setup FIQ stack ldr sp, FIQ_STACK_START .endm -#endif /* CONFIG_ONENAND_IPL */ +#endif /* !CONFIG_ONENAND_IPL && !CONFIG_NAND_SPL*/
/* * exception handlers */ -#ifdef CONFIG_ONENAND_IPL +#if defined(CONFIG_ONENAND_IPL) || defined(CONFIG_NAND_SPL) .align 5 do_hang: ldr sp, _TEXT_BASE /* use 32 words about stack */ @@ -436,3 +442,4 @@ arm1136_cache_flush: mcr p15, 0, r1, c7, c5, 0 @ invalidate I cache mov pc, lr @ back to caller #endif /* CONFIG_ONENAND_IPL */ + diff --git a/include/asm-arm/arch-mx31/mx31-regs.h b/include/asm-arm/arch-mx31/mx31-regs.h index a8a05c8..3d811d7 100644 --- a/include/asm-arm/arch-mx31/mx31-regs.h +++ b/include/asm-arm/arch-mx31/mx31-regs.h @@ -194,4 +194,94 @@ #define CS5_BASE 0xB6000000 #define PCMCIA_MEM_BASE 0xC0000000
+/* + * NAND controller + */ +#define NFC_BASE_ADDR 0xB8000000 + +/* + * Addresses for NFC registers + */ +#define NFC_BUF_SIZE (NFC_BASE_ADDR + 0xE00) +#define NFC_BUF_ADDR (NFC_BASE_ADDR + 0xE04) +#define NFC_FLASH_ADDR (NFC_BASE_ADDR + 0xE06) +#define NFC_FLASH_CMD (NFC_BASE_ADDR + 0xE08) +#define NFC_CONFIG (NFC_BASE_ADDR + 0xE0A) +#define NFC_ECC_STATUS_RESULT (NFC_BASE_ADDR + 0xE0C) +#define NFC_RSLTMAIN_AREA (NFC_BASE_ADDR + 0xE0E) +#define NFC_RSLTSPARE_AREA (NFC_BASE_ADDR + 0xE10) +#define NFC_WRPROT (NFC_BASE_ADDR + 0xE12) +#define NFC_UNLOCKSTART_BLKADDR (NFC_BASE_ADDR + 0xE14) +#define NFC_UNLOCKEND_BLKADDR (NFC_BASE_ADDR + 0xE16) +#define NFC_NF_WRPRST (NFC_BASE_ADDR + 0xE18) +#define NFC_CONFIG1 (NFC_BASE_ADDR + 0xE1A) +#define NFC_CONFIG2 (NFC_BASE_ADDR + 0xE1C) + +/* + * Addresses for NFC RAM BUFFER Main area 0 + */ +#define MAIN_AREA0 (NFC_BASE_ADDR + 0x000) +#define MAIN_AREA1 (NFC_BASE_ADDR + 0x200) +#define MAIN_AREA2 (NFC_BASE_ADDR + 0x400) +#define MAIN_AREA3 (NFC_BASE_ADDR + 0x600) + +/* + * Addresses for NFC SPARE BUFFER Spare area 0 + */ +#define SPARE_AREA0 (NFC_BASE_ADDR + 0x800) +#define SPARE_AREA1 (NFC_BASE_ADDR + 0x810) +#define SPARE_AREA2 (NFC_BASE_ADDR + 0x820) +#define SPARE_AREA3 (NFC_BASE_ADDR + 0x830) + +/* + * Set INT to 0, FCMD to 1, rest to 0 in NFC_CONFIG2 Register for Command + * operation + */ +#define NFC_CMD 0x1 + +/* + * Set INT to 0, FADD to 1, rest to 0 in NFC_CONFIG2 Register for Address + * operation + */ +#define NFC_ADDR 0x2 + +/* + * Set INT to 0, FDI to 1, rest to 0 in NFC_CONFIG2 Register for Input + * operation + */ +#define NFC_INPUT 0x4 + +/* + * Set INT to 0, FDO to 001, rest to 0 in NFC_CONFIG2 Register for Data + * Output operation + */ +#define NFC_OUTPUT 0x8 + +/* + * Set INT to 0, FD0 to 010, rest to 0 in NFC_CONFIG2 Register for Read ID + * operation + */ +#define NFC_ID 0x10 + +/* + * Set INT to 0, FDO to 100, rest to 0 in NFC_CONFIG2 Register for Read + * Status operation + */ +#define NFC_STATUS 0x20 + +/* + * Set INT to 1, rest to 0 in NFC_CONFIG2 Register for Read Status + * operation + */ +#define NFC_INT 0x8000 + +#define NFC_SP_EN (1 << 2) +#define NFC_ECC_EN (1 << 3) +#define NFC_INT_MSK (1 << 4) +#define NFC_BIG (1 << 5) +#define NFC_RST (1 << 6) +#define NFC_CE (1 << 7) +#define NFC_ONE_CYCLE (1 << 8) + #endif /* __ASM_ARCH_MX31_REGS_H */ + diff --git a/nand_spl/nand_boot_mx31.c b/nand_spl/nand_boot_mx31.c new file mode 100644 index 0000000..d698d2a --- /dev/null +++ b/nand_spl/nand_boot_mx31.c @@ -0,0 +1,223 @@ +/* + * (C) Copyright 2008 + * Maxim Artamonov, <scn1874 at yandex.ru> + * + * (C) Copyright 2006-2008 + * Stefan Roese, DENX Software Engineering, sr at denx.de. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <nand.h> +#include <asm-arm/arch/mx31-regs.h> +#include <asm/io.h> + +static void mx31_wait_ready(void) +{ + while (1) { + if (readw(NFC_CONFIG2) & NFC_INT) { + uint32_t tmp; + /* Reset interrupt flag */ + tmp = readw(NFC_CONFIG2); + tmp &= ~NFC_INT; + writew(tmp, NFC_CONFIG2); + break; + } + } +} + +static void mx31_nand_init(void) +{ + /* unlocking RAM Buff */ + writew(0x2, NFC_CONFIG); + + /* hardware ECC checking and correct */ + writew(NFC_ECC_EN, NFC_CONFIG1); +} + +static void mx31_nand_command(unsigned short command) +{ + writew(command, NFC_FLASH_CMD); + writew(NFC_CMD, NFC_CONFIG2); + mx31_wait_ready(); +} + +static void mx31_nand_page_address(unsigned int page_address) +{ + unsigned int page_count; + + writew(0x00, NFC_FLASH_ADDR); + writew(NFC_ADDR, NFC_CONFIG2); + mx31_wait_ready(); + + /* code only for 2kb flash */ + if (CFG_NAND_PAGE_SIZE == 0x800) { + writew(0x00, NFC_FLASH_ADDR); + writew(NFC_ADDR, NFC_CONFIG2); + mx31_wait_ready(); + } + + page_count = CFG_NAND_CHIP_SIZE / CFG_NAND_PAGE_SIZE; + + if (page_address <= page_count) { + page_count--; /* transform 0x01000000 to 0x00ffffff */ + do { + writew(page_address & 0xff, NFC_FLASH_ADDR); + writew(NFC_ADDR, NFC_CONFIG2); + mx31_wait_ready(); + page_address = page_address >> 8; + page_count = page_count >> 8; + } while (page_count); + } +} + +static void mx31_nand_data_output(void) +{ + int i; + + /* + * The NAND controller requires four output commands for + * large page devices. + */ + for (i = 0; i < (CFG_NAND_PAGE_SIZE / 512); i++) { + writew(NFC_ECC_EN, NFC_CONFIG1); + writew(i, NFC_BUF_ADDR); /* read in i:th buffer */ + writew(NFC_OUTPUT, NFC_CONFIG2); + mx31_wait_ready(); + } +} + +static int mx31_nand_check_ecc(void) +{ + unsigned short ecc_status_register; + + ecc_status_register = readw(NFC_ECC_STATUS_RESULT); + + if (ecc_status_register != 0) + return 1; /* error */ + return 0; +} + +static int mx31_read_page(unsigned int page_address, unsigned char *buf) +{ + int i; + volatile u32 *p1; + volatile u32 *p2; + u32 a; + + writew(0, NFC_BUF_ADDR); /* read in first 0 buffer */ + mx31_nand_command(NAND_CMD_READ0); + mx31_nand_page_address(page_address); + + if (CFG_NAND_CHIP_SIZE >= 0x08000000) + mx31_nand_command(NAND_CMD_READSTART); + + mx31_nand_data_output(); /* fill the main buffer 0 */ + + if (mx31_nand_check_ecc()) + return -1; + + p1 = (u32 *)MAIN_AREA0; + p2 = (u32 *)buf; + + /* main copy loop from NAND-buffer to SDRAM memory */ + for (i = 0; i < (CFG_NAND_PAGE_SIZE / 4); i++) { + *p2 = *p1; + p1++; + p2++; + } + + p1 = (u32 *)SPARE_AREA0; + + /* it is hardware specific code for 8-bit 512B NAND-flash spare area */ + p1++; + a = *p1; + a = (a & 0x0000ff00) >> 8; + + if (a != 0xff) /* bad block marker verify */ + return 1; /* potential bad block */ + + return 0; +} + +static int nand_load(unsigned int from, unsigned int size, unsigned char *buf) +{ + int i, bb; + + mx31_nand_init(); + + /* convert from to page number */ + from = from / CFG_NAND_PAGE_SIZE; + + i = 0; + + while (i < (size/CFG_NAND_PAGE_SIZE)) { + if ((from * CFG_NAND_PAGE_SIZE) >= CFG_NAND_CHIP_SIZE) + return 2; /* memory segment violation */ + + bb = mx31_read_page(from, buf); + + if (bb < 0) + return -1; + + /* checking first page of each block */ + /* if this page has bb marker, then skip whole block */ + if ((!(from % CFG_NAND_PAGES_PER_BLOCK)) && bb) { + from = from + CFG_NAND_PAGES_PER_BLOCK; + } else { + i++; + from++; + buf = buf + CFG_NAND_PAGE_SIZE; + } + } + + return 0; +} + +/* + * The main entry for NAND booting. It's necessary that SDRAM is already + * configured and available since this code loads the main U-Boot image + * from NAND into SDRAM and starts it from there. + */ +void nand_boot(void) +{ + __attribute__((noreturn)) void (*uboot)(void); + + /* CFG_NAND_U_BOOT_OFFS and CFG_NAND_U_BOOT_SIZE must */ + /* be aligned to full pages */ + if (!nand_load(CFG_NAND_U_BOOT_OFFS, CFG_NAND_U_BOOT_SIZE, + (uchar *)CFG_NAND_U_BOOT_DST)) { + /* Copy from NAND successful, start U-boot */ + uboot = (void *)CFG_NAND_U_BOOT_START; + uboot(); + } else { + /* Unrecoverable error when copying from NAND */ + while (1) { + /* Loop forever */ + } + } +} + +/* + * Called from start.S in case of an exception. + */ +void hang(void) +{ + while (1) { + /* Loop forever */ + } +} +
Add support for Freescale's i.MX31 PDK board (a.k.a. 3 stack board).
This patch assumes that some other program performs the actual NAND boot.
Signed-off-by: Magnus Lilja lilja.magnus@gmail.com --- MAKEALL | 1 + Makefile | 3 + board/freescale/mx31pdk/Makefile | 53 ++++++++++ board/freescale/mx31pdk/config.mk | 1 + board/freescale/mx31pdk/lowlevel_init.S | 30 ++++++ board/freescale/mx31pdk/mx31pdk.c | 76 ++++++++++++++ board/freescale/mx31pdk/u-boot.lds | 59 +++++++++++ include/asm-arm/arch-mx31/mx31-regs.h | 2 + include/configs/mx31pdk.h | 162 +++++++++++++++++++++++++++++++ 9 files changed, 387 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx31pdk/Makefile create mode 100644 board/freescale/mx31pdk/config.mk create mode 100644 board/freescale/mx31pdk/lowlevel_init.S create mode 100644 board/freescale/mx31pdk/mx31pdk.c create mode 100644 board/freescale/mx31pdk/u-boot.lds create mode 100644 include/configs/mx31pdk.h
diff --git a/MAKEALL b/MAKEALL index f13c81a..aaa6dea 100755 --- a/MAKEALL +++ b/MAKEALL @@ -548,6 +548,7 @@ LIST_ARM11=" \ imx31_phycore \ imx31_phycore_eet \ mx31ads \ + mx31pdk \ qong \ smdk6400 \ " diff --git a/Makefile b/Makefile index 137c88f..99ebcc5 100644 --- a/Makefile +++ b/Makefile @@ -3084,6 +3084,9 @@ imx31_phycore_config : unconfig mx31ads_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 mx31ads freescale mx31
+mx31pdk_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm1136 mx31pdk freescale mx31 + omap2420h4_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 omap2420h4 NULL omap24xx
diff --git a/board/freescale/mx31pdk/Makefile b/board/freescale/mx31pdk/Makefile new file mode 100644 index 0000000..b64cec8 --- /dev/null +++ b/board/freescale/mx31pdk/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2008 Magnus Lilja lilja.magnus@gmail.com +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := mx31pdk.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx31pdk/config.mk b/board/freescale/mx31pdk/config.mk new file mode 100644 index 0000000..d34dc02 --- /dev/null +++ b/board/freescale/mx31pdk/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x87f00000 diff --git a/board/freescale/mx31pdk/lowlevel_init.S b/board/freescale/mx31pdk/lowlevel_init.S new file mode 100644 index 0000000..ec5eedb --- /dev/null +++ b/board/freescale/mx31pdk/lowlevel_init.S @@ -0,0 +1,30 @@ +/* + * (C) Copyright 2008 Magnus Lilja lilja.magnus@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * This is just to keep the linker happy. + */ + +.globl lowlevel_init + +lowlevel_init: + mov pc, lr diff --git a/board/freescale/mx31pdk/mx31pdk.c b/board/freescale/mx31pdk/mx31pdk.c new file mode 100644 index 0000000..9eed979 --- /dev/null +++ b/board/freescale/mx31pdk/mx31pdk.c @@ -0,0 +1,76 @@ +/* + * + * (C) Copyright 2008 Magnus Lilja lilja.magnus@gmail.com + * + * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + + +#include <common.h> +#include <asm/arch/mx31.h> +#include <asm/arch/mx31-regs.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +int board_init(void) +{ + /* CS5: CPLD incl. network controller */ + __REG(CSCR_U(5)) = 0x0000d843; + __REG(CSCR_L(5)) = 0x22252521; + __REG(CSCR_A(5)) = 0x22220a00; + + /* setup pins for UART1 */ + mx31_gpio_mux(MUX_RXD1__UART1_RXD_MUX); + mx31_gpio_mux(MUX_TXD1__UART1_TXD_MUX); + mx31_gpio_mux(MUX_RTS1__UART1_RTS_B); + mx31_gpio_mux(MUX_CTS1__UART1_CTS_B); + + /* SPI2 */ + mx31_gpio_mux(MUX_CSPI2_SS2__CSPI2_SS2_B); + mx31_gpio_mux(MUX_CSPI2_SCLK__CSPI2_CLK); + mx31_gpio_mux(MUX_CSPI2_SPI_RDY__CSPI2_DATAREADY_B); + mx31_gpio_mux(MUX_CSPI2_MOSI__CSPI2_MOSI); + mx31_gpio_mux(MUX_CSPI2_MISO__CSPI2_MISO); + mx31_gpio_mux(MUX_CSPI2_SS0__CSPI2_SS0_B); + mx31_gpio_mux(MUX_CSPI2_SS1__CSPI2_SS1_B); + + /* start SPI2 clock */ + __REG(CCM_CGR2) = __REG(CCM_CGR2) | (3 << 4); + + gd->bd->bi_arch_number = MACH_TYPE_MX31_3DS; /* board id for linux */ + gd->bd->bi_boot_params = 0x80000100; /* adress of boot parameters */ + + return 0; +} + +int checkboard(void) +{ + printf("Board: i.MX31 MAX PDK (3DS)\n"); + return 0; +} diff --git a/board/freescale/mx31pdk/u-boot.lds b/board/freescale/mx31pdk/u-boot.lds new file mode 100644 index 0000000..e96509a --- /dev/null +++ b/board/freescale/mx31pdk/u-boot.lds @@ -0,0 +1,59 @@ +/* + * January 2004 - Changed to support H4 device + * Copyright (c) 2004 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm1136/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/include/asm-arm/arch-mx31/mx31-regs.h b/include/asm-arm/arch-mx31/mx31-regs.h index 3d811d7..b18cc85 100644 --- a/include/asm-arm/arch-mx31/mx31-regs.h +++ b/include/asm-arm/arch-mx31/mx31-regs.h @@ -84,6 +84,8 @@ #define IPU_CONF_IC_EN (1<<1) #define IPU_CONF_SCI_EN (1<<0)
+#define ARM_PPMRR 0x40000015 + #define WDOG_BASE 0x53FDC000
/* diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h new file mode 100644 index 0000000..deda70d --- /dev/null +++ b/include/configs/mx31pdk.h @@ -0,0 +1,162 @@ +/* + * (C) Copyright 2008 Magnus Lilja lilja.magnus@gmail.com + * + * (C) Copyright 2004 + * Texas Instruments. + * Richard Woodruff r-woodruff2@ti.com + * Kshitij Gupta kshitij@ti.com + * + * Configuration settings for the Freescale i.MX31 PDK board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/mx31-regs.h> + +/* High Level Configuration Options */ +#define CONFIG_ARM1136 1 /* This is an arm1136 CPU core */ +#define CONFIG_MX31 1 /* in a mx31 */ +#define CONFIG_MX31_HCLK_FREQ 26000000 +#define CONFIG_MX31_CLK32 32768 + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* No support for NAND boot for i.MX31 PDK yet, so we rely on some other + * program to initialize the SDRAM. + */ +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) +/* Bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +/* + * Hardware drivers + */ + +#define CONFIG_MX31_UART 1 +#define CONFIG_SYS_MX31_UART1 1 + +#define CONFIG_HARD_SPI 1 +#define CONFIG_MXC_SPI 1 +#define CONFIG_DEFAULT_SPI_BUS 1 +#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_2 | SPI_CS_HIGH) + +#define CONFIG_RTC_MC13783 1 + +/* MC13783 connected to CSPI2 and SS2 */ +#define CONFIG_MC13783_SPI_BUS 1 +#define CONFIG_MC13783_SPI_CS 2 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + +/*********************************************************** + * Command definition + ***********************************************************/ + +#include <config_cmd_default.h> + +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SPI +#define CONFIG_CMD_DATE + +/* Disabled due to compilation errors in cmd_bootm.c (IMLS seems to require + * that CFG_NO_FLASH is undefined). + */ +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootargs_base=setenv bootargs console=ttymxc0,115200\0" \ + "bootargs_nfs=setenv bootargs $(bootargs) root=/dev/nfs " \ + "ip=dhcp nfsroot=$(serverip):$(nfsrootfs),v3,tcp\0" \ + "bootcmd=run bootcmd_net\0" \ + "bootcmd_net=run bootargs_base bootargs_mtd bootargs_nfs; " \ + "tftpboot 0x81000000 uImage-mx31; bootm\0" + +#define CONFIG_DRIVER_SMC911X 1 +#define CONFIG_DRIVER_SMC911X_BASE CS5_BASE +#define CONFIG_DRIVER_SMC911X_32_BIT 1 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "uboot> " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT)+16) +/* max number of command args */ +#define CONFIG_SYS_MAXARGS 16 +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x10000 + +#define CONFIG_SYS_LOAD_ADDR 0x81000000 /* default load address */ + +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING 1 + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 CSD0_BASE +#define PHYS_SDRAM_1_SIZE (128 * 1024 * 1024) + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +/* No NOR flash present */ +#define CONFIG_SYS_NO_FLASH 1 + +#define CONFIG_ENV_IS_NOWHERE 1 + +#define CONFIG_ENV_SIZE (128 * 1024) + +#endif /* __CONFIG_H */ +
Signed-off-by: Magnus Lilja lilja.magnus@gmail.com --- MAKEALL | 3 +- Makefile | 9 ++- board/freescale/mx31pdk/config.mk | 4 + board/freescale/mx31pdk/lowlevel_init.S | 93 +++++++++++++++++++++++++++ board/freescale/mx31pdk/u-boot-nand.lds | 33 ++++++++++ include/configs/mx31pdk.h | 19 +++++- nand_spl/board/freescale/mx31pdk/Makefile | 54 +++++++++++++++ nand_spl/board/freescale/mx31pdk/config.mk | 5 ++ nand_spl/board/freescale/mx31pdk/u-boot.lds | 36 ++++++++++ 9 files changed, 251 insertions(+), 5 deletions(-) create mode 100644 board/freescale/mx31pdk/u-boot-nand.lds create mode 100644 nand_spl/board/freescale/mx31pdk/Makefile create mode 100644 nand_spl/board/freescale/mx31pdk/config.mk create mode 100644 nand_spl/board/freescale/mx31pdk/u-boot.lds
diff --git a/MAKEALL b/MAKEALL index aaa6dea..615acbb 100755 --- a/MAKEALL +++ b/MAKEALL @@ -548,7 +548,8 @@ LIST_ARM11=" \ imx31_phycore \ imx31_phycore_eet \ mx31ads \ - mx31pdk \ + mx31pdk \ + mx31pdk_nand \ qong \ smdk6400 \ " diff --git a/Makefile b/Makefile index 99ebcc5..c377313 100644 --- a/Makefile +++ b/Makefile @@ -369,7 +369,7 @@ $(LDSCRIPT): depend $(NAND_SPL): $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk $(MAKE) -C nand_spl/board/$(BOARDDIR) all
-$(U_BOOT_NAND): $(NAND_SPL) $(obj)u-boot.bin +$(U_BOOT_NAND): $(NAND_SPL) $(obj)u-boot.bin $(obj)include/autoconf.mk cat $(obj)nand_spl/u-boot-spl-16k.bin $(obj)u-boot.bin > $(obj)u-boot-nand.bin
$(ONENAND_IPL): $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk @@ -3087,6 +3087,13 @@ mx31ads_config : unconfig mx31pdk_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 mx31pdk freescale mx31
+mx31pdk_nand_config : unconfig + @mkdir -p $(obj)include $(obj)board/freescale/mx31pdk + @mkdir -p $(obj)nand_spl/board/freescale/mx31pdk + @echo "#define CONFIG_NAND_U_BOOT" > $(obj)include/config.h + @$(MKCONFIG) -n $@ -a mx31pdk arm arm1136 mx31pdk freescale mx31 + @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk + omap2420h4_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 omap2420h4 NULL omap24xx
diff --git a/board/freescale/mx31pdk/config.mk b/board/freescale/mx31pdk/config.mk index d34dc02..dcaa09f 100644 --- a/board/freescale/mx31pdk/config.mk +++ b/board/freescale/mx31pdk/config.mk @@ -1 +1,5 @@ +ifdef CONFIG_NAND_SPL +TEXT_BASE = 0x87ec0000 +else TEXT_BASE = 0x87f00000 +endif diff --git a/board/freescale/mx31pdk/lowlevel_init.S b/board/freescale/mx31pdk/lowlevel_init.S index ec5eedb..602eb53 100644 --- a/board/freescale/mx31pdk/lowlevel_init.S +++ b/board/freescale/mx31pdk/lowlevel_init.S @@ -26,5 +26,98 @@
+#ifdef CONFIG_NAND_SPL +#include <asm/arch/mx31-regs.h> + +.macro REG reg, val + ldr r2, =\reg + ldr r3, =\val + str r3, [r2] +.endm + +.macro REG8 reg, val + ldr r2, =\reg + ldr r3, =\val + strb r3, [r2] +.endm + +.macro DELAY loops + ldr r2, =\loops +1: + subs r2, r2, #1 + nop + bcs 1b +.endm + +.globl lowlevel_init +lowlevel_init: + /* Also setup the Peripheral Port Remap register inside the core */ + ldr r0, =ARM_PPMRR /* start from AIPS 2GB region */ + mcr p15, 0, r0, c15, c2, 4 + + REG IPU_CONF, IPU_CONF_DI_EN + REG CCM_CCMR, 0x074B0BF5 + + DELAY 0x40000 + + REG CCM_CCMR, 0x074B0BF5 | CCMR_MPE + REG CCM_CCMR, (0x074B0BF5 | CCMR_MPE) & ~CCMR_MDS + + /* Set up clock to 532MHz */ + REG CCM_PDR0, 0xFF871D58 + REG CCM_MPCTL, 0x0033280C + + REG CCM_SPCTL, PLL_PD(1) | PLL_MFD(4) | PLL_MFI(12) | PLL_MFN(1) + + /* Set up CPLD on CS5 */ + REG CSCR_U(5), 0x0000D843 + REG CSCR_L(5), 0x22252521 + REG CSCR_A(5), 0x22220A00 + + /* Set up MX31 DDR Memory Controller */ + REG 0x43FAC26C, 0 /* SDCLK */ + REG 0x43FAC270, 0 /* CAS */ + REG 0x43FAC274, 0 /* RAS */ + REG 0x43FAC27C, 0x1000 /* CS2 CSD0) */ + REG 0x43FAC284, 0 /* DQM3 */ + REG 0x43FAC288, 0 /* DQM2, DQM1, DQM0, SD31-SD0, A25-A0, MA10 0x288..0x2DC) */ + REG 0x43FAC28C, 0 + REG 0x43FAC290, 0 + REG 0x43FAC294, 0 + REG 0x43FAC298, 0 + REG 0x43FAC29C, 0 + REG 0x43FAC2A0, 0 + REG 0x43FAC2A4, 0 + REG 0x43FAC2A8, 0 + REG 0x43FAC2AC, 0 + REG 0x43FAC2B0, 0 + REG 0x43FAC2B4, 0 + REG 0x43FAC2B8, 0 + REG 0x43FAC2BC, 0 + REG 0x43FAC2C0, 0 + REG 0x43FAC2C4, 0 + REG 0x43FAC2C8, 0 + REG 0x43FAC2CC, 0 + REG 0x43FAC2D0, 0 + REG 0x43FAC2D4, 0 + REG 0x43FAC2D8, 0 + REG 0x43FAC2DC, 0 + REG 0xB8001010, 0x00000004 + REG 0xB8001004, 0x006ac73a + REG 0xB8001000, 0x92100000 + REG 0x80000f00, 0x12344321 + REG 0xB8001000, 0xa2100000 + REG 0x80000000, 0x12344321 + REG 0x80000000, 0x12344321 + REG 0xB8001000, 0xb2100000 + REG8 0x80000033, 0xda + REG8 0x81000000, 0xff + REG 0xB8001000, 0x82226080 + REG 0x80000000, 0xDEADBEEF + REG 0xB8001010, 0x0000000c + + mov pc, lr +#else lowlevel_init: mov pc, lr +#endif diff --git a/board/freescale/mx31pdk/u-boot-nand.lds b/board/freescale/mx31pdk/u-boot-nand.lds new file mode 100644 index 0000000..b604480 --- /dev/null +++ b/board/freescale/mx31pdk/u-boot-nand.lds @@ -0,0 +1,33 @@ +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm1136/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index deda70d..5f293ba 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -45,10 +45,10 @@ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1
-/* No support for NAND boot for i.MX31 PDK yet, so we rely on some other - * program to initialize the SDRAM. - */ +#if defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) #define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT +#endif
/* * Size of malloc() pool @@ -158,5 +158,18 @@
+#define CFG_NAND_U_BOOT_OFFS 0x800 +#define CFG_NAND_U_BOOT_SIZE 0x30000 +#define CFG_NAND_U_BOOT_DST 0x87f00000 /* Load U-Boot to this address */ +#define CFG_NAND_U_BOOT_START CFG_NAND_U_BOOT_DST +#define CFG_NAND_SPL_DST (CFG_NAND_U_BOOT_DST - 0x40000) + +#define CFG_NAND_PAGE_SIZE 0x800 +#define CFG_NAND_BLOCK_SIZE (128 * 1024) +#define CFG_NAND_PAGE_COUNT 64 +/* for NAND_SPL */ +#define CFG_NAND_CHIP_SIZE (256 * 1024 * 1024) +#define CFG_NAND_PAGES_PER_BLOCK CFG_NAND_PAGE_COUNT + #endif /* __CONFIG_H */
diff --git a/nand_spl/board/freescale/mx31pdk/Makefile b/nand_spl/board/freescale/mx31pdk/Makefile new file mode 100644 index 0000000..866b35e --- /dev/null +++ b/nand_spl/board/freescale/mx31pdk/Makefile @@ -0,0 +1,54 @@ +CONFIG_NAND_SPL = y + +include $(TOPDIR)/config.mk +include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk + +LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds +LDFLAGS = -Bstatic -T $(LDSCRIPT) -Ttext $(TEXT_BASE) $(PLATFORM_LDFLAGS) +AFLAGS += -DCONFIG_NAND_SPL +CFLAGS += -DCONFIG_NAND_SPL + +SOBJS = start.o lowlevel_init.o +COBJS = nand_boot_mx31.o + +SRCS := $(SRCTREE)/nand_spl/nand_boot_mx31.c +SRCS += $(SRCTREE)/cpu/arm1136/start.S +SRCS += $(SRCTREE)/board/freescale/mx31pdk/lowlevel_init.S +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/nand_spl/board/$(BOARDDIR) + +nandobj := $(OBJTREE)/nand_spl/ + +ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin + +all: $(obj).depend $(ALL) + +$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ + +$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(nandobj)u-boot-spl: $(OBJS) + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + -Map $(nandobj)u-boot-spl.map \ + -o $(nandobj)u-boot-spl + +######################################################################### + +$(obj)%.o: $(SRCTREE)/cpu/arm1136/%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(SRCTREE)/board/freescale/mx31pdk/%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(SRCTREE)/nand_spl/%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/nand_spl/board/freescale/mx31pdk/config.mk b/nand_spl/board/freescale/mx31pdk/config.mk new file mode 100644 index 0000000..119934b --- /dev/null +++ b/nand_spl/board/freescale/mx31pdk/config.mk @@ -0,0 +1,5 @@ +PAD_TO := $(shell expr $$[$(TEXT_BASE) + 2048]) + +ifeq ($(debug),1) +PLATFORM_CPPFLAGS += -DDEBUG +endif diff --git a/nand_spl/board/freescale/mx31pdk/u-boot.lds b/nand_spl/board/freescale/mx31pdk/u-boot.lds new file mode 100644 index 0000000..2780e11 --- /dev/null +++ b/nand_spl/board/freescale/mx31pdk/u-boot.lds @@ -0,0 +1,36 @@ +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + start.o (.text) + lowlevel_init.o (.text) + nand_boot_mx31.o (.text) + *(.text) + . = 2K; + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +}
- mx31pdk \
- mx31pdk \
- mx31pdk_nand \ qong \ smdk6400 \
why?
- @mkdir -p $(obj)include $(obj)board/freescale/mx31pdk
- @mkdir -p $(obj)nand_spl/board/freescale/mx31pdk
- @echo "#define CONFIG_NAND_U_BOOT" > $(obj)include/config.h
- @$(MKCONFIG) -n $@ -a mx31pdk arm arm1136 mx31pdk freescale mx31
- @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk
IIRC no need it will generate from the config.h
- ldr r2, =\reg
- ldr r3, =\val
- str r3, [r2]
+.endm
- ldr r2, =\reg
- ldr r3, =\val
- strb r3, [r2]
+.endm
+.macro DELAY loops
- ldr r2, =\loops
+1:
- subs r2, r2, #1
- nop
- bcs 1b
+.endm
NACK as already reply to the kirwood patch we must have common macro please use the attached file as based work
- /* Also setup the Peripheral Port Remap register inside the core */
- ldr r0, =ARM_PPMRR /* start from AIPS 2GB region */
- mcr p15, 0, r0, c15, c2, 4
for all hard code value please use macro and if possible macro to generate them
- REG IPU_CONF, IPU_CONF_DI_EN
- REG CCM_CCMR, 0x074B0BF5
- REG 0xB8001010, 0x0000000c
<snip>
- mov pc, lr
why?
no need anymore
- Size of malloc() pool
please use CONFIG_ or CONFIG_SYS_
<snip>
- $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@
- $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@
- cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \
please use $@ and $<
- $(CC) $(AFLAGS) -c -o $@ $<
- . = 0x00000000;
- . = ALIGN(4);
- .text :
^^^ whitespace please fix and so on
Best Regards, J.
2009/5/9 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
- mx31pdk \
- mx31pdk \
- mx31pdk_nand \
why?
Maxim added this, I haven't investigated if the dependency is needed or not.
I don't understand the comment. What will generate what from config.h?
- ldr r2, =\reg
- ldr r3, =\val
- str r3, [r2]
+.endm
- ldr r2, =\reg
- ldr r3, =\val
- strb r3, [r2]
+.endm
+.macro DELAY loops
- ldr r2, =\loops
+1:
- subs r2, r2, #1
- nop
- bcs 1b
+.endm
I don't see any file attached to you e-mail, so which attached file? Can you point to the relevant kirkwood patch? Is the patch in some git-tree?
Hmm. You want me to create a macro that expands to the above code?
<snip> > + mov pc, lr > +#else > lowlevel_init: > mov pc, lr why?
See my answer in patch 2.
no need anymore
I'll try with your lds cleanup patch.
Thanks, Magnus
the automake.mk
+.macro DELAY loops
- ldr r2, =\loops
+1:
- subs r2, r2, #1
- nop
- bcs 1b
+.endm
no not yet so I've forget to re-attached it
no I mean macro for 0xB8001010, 0x0000000c, etc... and if possible macro to generate these value
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
the automake.mk
automake.mk ? What's that?
the automake.mk
autoconf.mk I mean
Best Regards, J.
the automake.mk
autoconf.mk I mean
I still don't understand what your terse comment is supposed to mean. Could ypou please try to answer in a complete sentence, and explain your thoughts in a little detail?
> +mx31pdk_nand_config : unconfig > + @mkdir -p $(obj)include $(obj)board/freescale/mx31pdk > + @mkdir -p $(obj)nand_spl/board/freescale/mx31pdk > + @echo "#define CONFIG_NAND_U_BOOT" > $(obj)include/config.h > + @$(MKCONFIG) -n $@ -a mx31pdk arm arm1136 mx31pdk freescale mx31 > + @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk IIRC no need it will generate from the config.h
the automake.mk
autoconf.mk I mean
simple CONFIG_NAND_U_BOOT = y will already be generated from config.h in autoconf.mk
Best Regards, J.
2009/5/10 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
+.macro DELAY loops
- ldr r2, =\loops
+1:
- subs r2, r2, #1
- nop
- bcs 1b
+.endm
Ok.
I'm no .macro expert so I can't promise anything.
Regards, Magnus
there nothing to do with .macro it's somthing like this
#define TOTO1 #define TOTO2 #define TOTO3
and use TOTOx to generate 0x0000000c
please take a look in drivers/net/smc911x.h as example
Best Regards, J.
+.macro DELAY loops
- ldr r2, =\loops
+1:
- subs r2, r2, #1
- nop
- bcs 1b
+.endm
There's a minor problem in the timer macro, fixed by replacing "sub" with "subs".
Are you OK with me posting the file as a separate patch with your From+signed-off as part of my patch series or will you add the file to arm-next yourself?
Regards, Magnus
+.macro DELAY loops
- ldr r2, =\loops
+1:
- subs r2, r2, #1
- nop
- bcs 1b
+.endm
ok please do tks
Best Regards, J.
- (C) Copyright 2008 Magnus Lilja lilja.magnus@gmail.com
- project.
- MA 02111-1307 USA
- This is just to keep the linker happy.
+lowlevel_init:
- mov pc, lr
why do you need it?
- (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de
- project.
- MA 02111-1307 USA
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE;
- /* CS5: CPLD incl. network controller */
- __REG(CSCR_U(5)) = 0x0000d843;
- __REG(CSCR_L(5)) = 0x22252521;
- __REG(CSCR_A(5)) = 0x22220a00;
- /* setup pins for UART1 */
- mx31_gpio_mux(MUX_RXD1__UART1_RXD_MUX);
- mx31_gpio_mux(MUX_TXD1__UART1_TXD_MUX);
- mx31_gpio_mux(MUX_RTS1__UART1_RTS_B);
- mx31_gpio_mux(MUX_CTS1__UART1_CTS_B);
I think it's time to create common device init functions as done for davinci or at91
- /* SPI2 */
- mx31_gpio_mux(MUX_CSPI2_SS2__CSPI2_SS2_B);
- mx31_gpio_mux(MUX_CSPI2_SCLK__CSPI2_CLK);
- mx31_gpio_mux(MUX_CSPI2_SPI_RDY__CSPI2_DATAREADY_B);
- mx31_gpio_mux(MUX_CSPI2_MOSI__CSPI2_MOSI);
- mx31_gpio_mux(MUX_CSPI2_MISO__CSPI2_MISO);
- mx31_gpio_mux(MUX_CSPI2_SS0__CSPI2_SS0_B);
- mx31_gpio_mux(MUX_CSPI2_SS1__CSPI2_SS1_B);
ditto
- /* start SPI2 clock */
- __REG(CCM_CGR2) = __REG(CCM_CGR2) | (3 << 4);
- gd->bd->bi_arch_number = MACH_TYPE_MX31_3DS; /* board id for linux */
- gd->bd->bi_boot_params = 0x80000100; /* adress of boot parameters */
please use this style
RAM_BASE + 0x100 as other arm board
I've send a patch that unify all arm lds so this one is not anymore needed
- MA 02111-1307 USA
why?
^^^^ whitespate please remove
- program to initialize the SDRAM.
- Hardware drivers
- Command definition
- that CFG_NO_FLASH is undefined).
please remove the comment
- "bootargs_base=setenv bootargs console=ttymxc0,115200\0" \
- "bootargs_nfs=setenv bootargs $(bootargs) root=/dev/nfs " \
- "bootcmd=run bootcmd_net\0" \
- "bootcmd_net=run bootargs_base bootargs_mtd bootargs_nfs; " \
- Miscellaneous configurable options
- Stack sizes
- The stack sizes are set up in start.S using the settings below
- Physical Memory Map
- FLASH and environment organization
Best Regards, J.
- project.
- MA 02111-1307 USA
+lowlevel_init:
- mov pc, lr
why do you need it?
start.S:cpu_init_crit needs it and I haven't defined SKIP_LOWLEVEL. Might be possible to define SKIP_LOWLEVEL_INIT and get rid of the above line.
- project.
- MA 02111-1307 USA
I think I prefer the at91 way of doing this, I can create cpu/arm1136/mx31/serial.c and spi.c.
- /* SPI2 */
ditto
I'll try it. Are you planning other major changes that will affect these patches in the near future?
- MA 02111-1307 USA
why?
So we can use symbolic names for Ethernet base address, SDRAM base address. I.e. instead of writing e.g. 0xB6000000 we can write CS5_BASE. I can switch to hard coded numerical values and get rid of the #include if requested.
The comment was added since Wolfgang asked why IMLS was disabled when I posted a similar set of patches last year, so I'm going to keep the comment.
Thanks, Magnus
+lowlevel_init:
- mov pc, lr
why do you need it?
if you do not need to do any lowlevel_init yes please
as I tks please note I'll regroup all devices init fuctions in one file per cpu maybe you can create a devices.c
- /* SPI2 */
no
- MA 02111-1307 USA
why?
if you include it in the final c files you do not need to include mx31-regs.h always
ok
Best Regards, J.
- MA 02111-1307 USA
why?
That works for SoC files, but not for the Ethernet-driver. I don't think the idea is to add #include mx31-regs.h to drivers/net/sms911x.c so I think I have to write the 0xB6.... there.
Regards, Magnus
so please add it too and please fix the @
- armboot - Startup Code for OMP2420/ARM1136 CPU-core
- Copyright (c) 2008 Maxim Artamonov, <scn1874 at yandex.ru>
please remove
- Copyright (c) 2004 Texas Instruments r-woodruff2@ti.com
- Copyright (c) 2001 Marius Gr�ger mag@sysgo.de
create a better CONFIG_ because we could need for other boot mode
<snip>
<snip>
- unsigned int page_count;
- writew(0x00, NFC_FLASH_ADDR);
- writew(NFC_ADDR, NFC_CONFIG2);
- mx31_wait_ready();
- /* code only for 2kb flash */
- if (CFG_NAND_PAGE_SIZE == 0x800) {
mx31_wait_ready();
- page_count = CFG_NAND_CHIP_SIZE / CFG_NAND_PAGE_SIZE;
please use CONFIG_SYS_ or CONFIG_ and why not detect it?
- if (page_address <= page_count) {
do {
mx31_wait_ready();
<snip>
- int i, bb;
- mx31_nand_init();
- /* convert from to page number */
- from = from / CFG_NAND_PAGE_SIZE;
- i = 0;
- while (i < (size/CFG_NAND_PAGE_SIZE)) {
if (bb < 0)
return -1;
} else {
i++;
from++;
- The main entry for NAND booting. It's necessary that SDRAM is already
- configured and available since this code loads the main U-Boot image
- from NAND into SDRAM and starts it from there.
- __attribute__((noreturn)) void (*uboot)(void);
- /* CFG_NAND_U_BOOT_OFFS and CFG_NAND_U_BOOT_SIZE must */
please use CONFIG_SYS_ or CONFIG_ and so on
- /* be aligned to full pages */
please use this style of multiple ligne comment /* * */
Best Regards, J.
A better CONFIG_ than what? CONFIG_NAND_SPL is already used elsewhere in U-boot when booting from NAND.
<snip> > diff --git a/nand_spl/nand_boot_mx31.c b/nand_spl/nand_boot_mx31.c > new file mode 100644 > index 0000000..d698d2a > --- /dev/null > +++ b/nand_spl/nand_boot_mx31.c > @@ -0,0 +1,223 @@ <snip> > +static void mx31_nand_page_address(unsigned int page_address) > +{ > + unsigned int page_count; > + > + writew(0x00, NFC_FLASH_ADDR); > + writew(NFC_ADDR, NFC_CONFIG2); > + mx31_wait_ready(); > + > + /* code only for 2kb flash */ > + if (CFG_NAND_PAGE_SIZE == 0x800) { > + writew(0x00, NFC_FLASH_ADDR); > + writew(NFC_ADDR, NFC_CONFIG2); > + mx31_wait_ready(); > + } > + > + page_count = CFG_NAND_CHIP_SIZE / CFG_NAND_PAGE_SIZE; please use CONFIG_SYS_ or CONFIG_
Will do.
Might be possible, I'll look into it to see if it's doable.
Thanks; Magnus
IIRC in this case the purpose is to reduce the size of the start.S to allow more code in the ipl & spl
Will do.
tks
Best Regards, J.
The main purpose of CONFIG_ONENAND_IPL and NAND_SPL in start.S is to change the behaviour a bit, not so much to save some space.
Regards, Magnus
Will do.
tks
It's not really doable. In order for this to be worthwhile the nand_flash_ids array from drivers/mtd/nand/nand_ids.c would have to fit into the available space (2048 byte in total) and it didn't even though I removed the text-strings. So it's going to be controlled from the board config file.with CONFIG_something.
Regards, Magnus
Will do.
tks
as you mention here there is only 2K so the start.S was reduced to allow more code so CONFIG_xxx_IPL/SPL do not describe this so please chance it to a better one
Best Regards, J.
2009/5/12 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
Will do.
tks
As I said in another email: "The main purpose of CONFIG_ONENAND_IPL and NAND_SPL in start.S is to change the behaviour a bit, not so much to save some space." Given that those CONFIG_s are used in other places as well to indicate the type of boot I don't think it's good to create a new CONFIG_ that one has to specify in addition to one of the above.
Regards, Magnus
Best Regards, J.
Better to define one more in order to test only one... and use the new one for things that are generally applicable to pre-loaders regardless of type.
-Scott
Sorry for the delay...
- NAND controller
- Addresses for NFC registers
The NFC register info should go in its own header, as it exists on more than just MX31 (e.g. mpc5xxx). Should probably use register structs rather than #defines.
- Addresses for NFC RAM BUFFER Main area 0
- Addresses for NFC SPARE BUFFER Spare area 0
NFC_MAIN_AREA0, etc.
What in this file is MX31-specific? Even if you don't have other chips to test on, please try to provide a framework for generic NFC support so the next chip only needs to tweak the details. That may be as simple as s/mx31/nfc/.
- while (1) {
uint32_t tmp;
tmp &= ~NFC_INT;
break;
while (!(readw(NFC_CONFIG2) & NFC_INT)) ;
tmp = readw(NFC_CONFIG2); ...
mx31_wait_ready();
do {
mx31_wait_ready();
Does the number of address bytes really need to depend on the size of the flash chip, or can you base it on the number of non-zero bytes in page_address (the chip will know when the address phase is over because ALE drops)?
- unsigned short ecc_status_register;
- ecc_status_register = readw(NFC_ECC_STATUS_RESULT);
- if (ecc_status_register != 0)
How about just "return readw(NFC_ECC_STATUS_RESULT);"?
- int i;
- volatile u32 *p1;
- volatile u32 *p2;
- u32 a;
s/p1/src/ s/p2/dest/
s/a/something (just a little) more descriptive/ -- my first guess was "address", but that doesn't seem right...
No volatile; use I/O accessors.
- writew(0, NFC_BUF_ADDR); /* read in first 0 buffer */
- mx31_nand_command(NAND_CMD_READ0);
- mx31_nand_page_address(page_address);
- if (CFG_NAND_CHIP_SIZE >= 0x08000000)
Is it guaranteed that all NAND chips above that size will be large page and all chips below that size will be small page?
- /* it is hardware specific code for 8-bit 512B NAND-flash spare area */
- p1++;
- a = *p1;
- a = (a & 0x0000ff00) >> 8;
- if (a != 0xff) /* bad block marker verify */
The bad block location is typically different (offset 0 rather than 5) with large page flash.
I believe some NAND chips may mark a block bad in its second page...
-Scott
2009/5/29 Scott Wood scottwood@freescale.com:
Well, better now than the next time I post these patches.
- NAND controller
Yes, will do that. I'm converting the #define's to struct {} and all accesses will be in the readl/writel(&nfc->flash_cmd) format.
I'll look into that.
- while (1) {
- if (readw(NFC_CONFIG2) & NFC_INT) {
- uint32_t tmp;
- /* Reset interrupt flag */
- tmp = readw(NFC_CONFIG2);
- tmp &= ~NFC_INT;
- writew(tmp, NFC_CONFIG2);
- break;
Ok.
- page_count--; /* transform 0x01000000 to 0x00ffffff */
- do {
- writew(page_address & 0xff, NFC_FLASH_ADDR);
- page_address = page_address >> 8;
- page_count = page_count >> 8;
- } while (page_count);
Ok, will try to look into it.
- return 1; /* error */
ok
- int i;
- volatile u32 *p1;
- volatile u32 *p2;
- u32 a;
Ok
Yes, already on todo-list.
- mx31_nand_command(NAND_CMD_READSTART);
No, I'll change to use the CONFIG_SYS_NAND_PAGE_SIZE to do different stuff depending on the page size.
- p1++;
- a = *p1;
- return 1; /* potential bad block */
I think that's because of the non-standard imlementation of large page support in the i.MX31 NFC.
- /* checking first page of each block */
I'll see what I can do.
/Magnus
We should have comments in the code explaining what's going on in such cases.
-Scott
Hi
2009/6/1 Scott Wood scottwood@freescale.com:
Yes, I'll add that.
/Magnus
Hi
2009/5/30 Magnus Lilja lilja.magnus@gmail.com:
- do {
I did try to output only the non-zero bytes in the page_address but that didn't work at all, u-boot didn't boot Don't know why though.
/Magnus
Yes, I was a bit confused -- it looks like we can't omit high-order zero bytes, but I don't think it'll hurt (at least one chip manual explicitly says it won't) to have extra bytes. So we could still keep the number of bytes fixed at the number for the largest supported chip.
Or, we could leave it the way it is, if you're not having any problems with the extra code fitting in the boot page, and if you don't need to dynamically support multiple chip sizes.
-Scott
I think I'll leave it as is. There is no need to support multiple chip sizes dynamically, in order to do that we have to detect the chip type during boot and I couldn't fit that code into the boot page.
/Magnus
Magnus Lilja
Scott Wood
