[U-Boot] [PATCH v2 0/4] At present the GEM ethernet on SiFive Unleashed board can only work
in 1000 Mbps mode. With a 10/100 Mbps connection it just fails to do any network communication.
This adds a new GEMGXL clock driver to adjust the clock settings per the connection speed so that 10/100 Mbps works.
Changes in v2: - rename driver name to "sifive-gemgxl-mgmt" - add a comment for getting "tx_clk" via clk_get_by_name() - does not change anything in the default case - check the return value of clk_set_rate()
Bin Meng (4): clk: sifive: Add clock driver for GEMGXL MGMT dm: net: macb: Update macb_linkspd_cb() signature dm: net: macb: Implement link speed change callback riscv: sifive: fu540: Enable GEMGXL MGMT driver
board/sifive/fu540/Kconfig | 1 + drivers/clk/sifive/Kconfig | 7 +++++ drivers/clk/sifive/Makefile | 2 ++ drivers/clk/sifive/gemgxl-mgmt.c | 60 ++++++++++++++++++++++++++++++++++++++++ drivers/net/macb.c | 57 +++++++++++++++++++++++++++++++++++++- 5 files changed, 126 insertions(+), 1 deletion(-) create mode 100644 drivers/clk/sifive/gemgxl-mgmt.c
This adds a clock driver to support the GEMGXL management IP block found in FU540 SoCs to control GEM TX clock operation mode for 10/100/1000 Mbps.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Lukas Auer lukas.auer@aisec.fraunhofer.de Tested-by: Lukas Auer lukas.auer@aisec.fraunhofer.de
drivers/clk/sifive/Kconfig | 7 +++++ drivers/clk/sifive/Makefile | 2 ++ drivers/clk/sifive/gemgxl-mgmt.c | 60 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 69 insertions(+) create mode 100644 drivers/clk/sifive/gemgxl-mgmt.c
diff --git a/drivers/clk/sifive/Kconfig b/drivers/clk/sifive/Kconfig index 81fc9f8..644881b 100644 --- a/drivers/clk/sifive/Kconfig +++ b/drivers/clk/sifive/Kconfig @@ -17,3 +17,10 @@ config CLK_SIFIVE_FU540_PRCI Supports the Power Reset Clock interface (PRCI) IP block found in FU540 SoCs. If this kernel is meant to run on a SiFive FU540 SoC, enable this driver. + +config CLK_SIFIVE_GEMGXL_MGMT + bool "GEMGXL management for SiFive FU540 SoCs" + depends on CLK_SIFIVE + help + Supports the GEMGXL management IP block found in FU540 SoCs to + control GEM TX clock operation mode for 10/100/1000 Mbps. diff --git a/drivers/clk/sifive/Makefile b/drivers/clk/sifive/Makefile index 1155e07..f8263e7 100644 --- a/drivers/clk/sifive/Makefile +++ b/drivers/clk/sifive/Makefile @@ -3,3 +3,5 @@ obj-$(CONFIG_CLK_ANALOGBITS_WRPLL_CLN28HPC) += wrpll-cln28hpc.o
obj-$(CONFIG_CLK_SIFIVE_FU540_PRCI) += fu540-prci.o + +obj-$(CONFIG_CLK_SIFIVE_GEMGXL_MGMT) += gemgxl-mgmt.o diff --git a/drivers/clk/sifive/gemgxl-mgmt.c b/drivers/clk/sifive/gemgxl-mgmt.c new file mode 100644 index 0000000..eb37416 --- /dev/null +++ b/drivers/clk/sifive/gemgxl-mgmt.c @@ -0,0 +1,60 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019, Bin Meng bmeng.cn@gmail.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <asm/io.h> + +struct gemgxl_mgmt_regs { + __u32 tx_clk_sel; +}; + +struct gemgxl_mgmt_platdata { + struct gemgxl_mgmt_regs *regs; +}; + +static int gemgxl_mgmt_ofdata_to_platdata(struct udevice *dev) +{ + struct gemgxl_mgmt_platdata *plat = dev_get_platdata(dev); + + plat->regs = (struct gemgxl_mgmt_regs *)dev_read_addr(dev); + + return 0; +} + +static ulong gemgxl_mgmt_set_rate(struct clk *clk, ulong rate) +{ + struct gemgxl_mgmt_platdata *plat = dev_get_platdata(clk->dev); + + /* + * GEMGXL TX clock operation mode: + * + * 0 = GMII mode. Use 125 MHz gemgxlclk from PRCI in TX logic + * and output clock on GMII output signal GTX_CLK + * 1 = MII mode. Use MII input signal TX_CLK in TX logic + */ + writel(rate != 125000000, &plat->regs->tx_clk_sel); + + return 0; +} + +const struct clk_ops gemgxl_mgmt_ops = { + .set_rate = gemgxl_mgmt_set_rate, +}; + +static const struct udevice_id gemgxl_mgmt_match[] = { + { .compatible = "sifive,cadencegemgxlmgmt0", }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(sifive_gemgxl_mgmt) = { + .name = "sifive-gemgxl-mgmt", + .id = UCLASS_CLK, + .of_match = gemgxl_mgmt_match, + .ofdata_to_platdata = gemgxl_mgmt_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct gemgxl_mgmt_platdata), + .ops = &gemgxl_mgmt_ops, +};
Hi Bin,
https://patchwork.ozlabs.org/patch/1103216/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
This updates DM version macb_linkspd_cb() signature for future expansion, eg: adding an implementation for link speed changes.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Lukas Auer lukas.auer@aisec.fraunhofer.de ---
Changes in v2: None
drivers/net/macb.c | 22 +++++++++++++++++++++- 1 file changed, 21 insertions(+), 1 deletion(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 7261416..b7f404e 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -488,15 +488,23 @@ static int macb_phy_find(struct macb_device *macb, const char *name)
/** * macb_linkspd_cb - Linkspeed change callback function - * @regs: Base Register of MACB devices + * @dev/@regs: MACB udevice (DM version) or + * Base Register of MACB devices (non-DM version) * @speed: Linkspeed * Returns 0 when operation success and negative errno number * when operation failed. */ +#ifdef CONFIG_DM_ETH +int __weak macb_linkspd_cb(struct udevice *dev, unsigned int speed) +{ + return 0; +} +#else int __weak macb_linkspd_cb(void *regs, unsigned int speed) { return 0; } +#endif
#ifdef CONFIG_DM_ETH static int macb_phy_init(struct udevice *dev, const char *name) @@ -589,7 +597,11 @@ static int macb_phy_init(struct macb_device *macb, const char *name)
macb_writel(macb, NCFGR, ncfgr);
+#ifdef CONFIG_DM_ETH + ret = macb_linkspd_cb(dev, _1000BASET); +#else ret = macb_linkspd_cb(macb->regs, _1000BASET); +#endif if (ret) return ret;
@@ -614,9 +626,17 @@ static int macb_phy_init(struct macb_device *macb, const char *name) ncfgr &= ~(MACB_BIT(SPD) | MACB_BIT(FD) | GEM_BIT(GBE)); if (speed) { ncfgr |= MACB_BIT(SPD); +#ifdef CONFIG_DM_ETH + ret = macb_linkspd_cb(dev, _100BASET); +#else ret = macb_linkspd_cb(macb->regs, _100BASET); +#endif } else { +#ifdef CONFIG_DM_ETH + ret = macb_linkspd_cb(dev, _10BASET); +#else ret = macb_linkspd_cb(macb->regs, _10BASET); +#endif }
if (ret)
Hi Bin,
https://patchwork.ozlabs.org/patch/1103219/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
At present the link speed change callback is a nop. According to macb device tree bindings, an optional "tx_clk" is used to clock the ethernet controller's TX_CLK under different link speed.
In 10/100 MII mode, transmit logic must be clocked from a free running clock generated by the external PHY. In gigabit GMII mode, the controller, not the external PHY, must generate the 125 MHz transmit clock towards the PHY.
Changes in v2: - add a comment for getting "tx_clk" via clk_get_by_name() - does not change anything in the default case - check the return value of clk_set_rate()
drivers/net/macb.c | 35 +++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index b7f404e..c5560a7 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -497,6 +497,41 @@ static int macb_phy_find(struct macb_device *macb, const char *name) #ifdef CONFIG_DM_ETH int __weak macb_linkspd_cb(struct udevice *dev, unsigned int speed) { +#ifdef CONFIG_CLK + struct clk tx_clk; + ulong rate; + int ret; + + /* + * "tx_clk" is an optional clock source for MACB. + * Ignore if it does not exist in DT. + */ + ret = clk_get_by_name(dev, "tx_clk", &tx_clk); + if (ret) + return 0; + + switch (speed) { + case _10BASET: + rate = 2500000; /* 2.5 MHz */ + break; + case _100BASET: + rate = 25000000; /* 25 MHz */ + break; + case _1000BASET: + rate = 125000000; /* 125 MHz */ + break; + default: + /* does not change anything */ + return 0; + } + + if (tx_clk.dev) { + ret = clk_set_rate(&tx_clk, rate); + if (ret) + return ret; + } +#endif + return 0; } #else
Changes in v2:
Successfully tested the series on a SiFive HiFive Unleashed board at 1000, 100, and 10 Mbps link rates.
Hi Bin,
https://patchwork.ozlabs.org/patch/1103218/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Enable the new GEMGXL MGMT driver so that GEM 10/100 Mbps works now.
Changes in v2: None
board/sifive/fu540/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index f464379..8eb5e30 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -28,6 +28,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply CMD_PING imply CLK_SIFIVE imply CLK_SIFIVE_FU540_PRCI + imply CLK_SIFIVE_GEMGXL_MGMT imply DOS_PARTITION imply EFI_PARTITION imply IP_DYN
Hi Bin,
https://patchwork.ozlabs.org/patch/1103220/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Hi Joe,
Lukas has reviewed and tested this series (thanks Lukas!)
Would you please apply this series for v2019.07?
Regards, Bin
Auer, Lukas
Bin Meng
Joe Hershberger
