[U-Boot] [PATCH 0/3] fix for build break with CONFIG_DISK scsi_init()
This series fixes the build break with the SATA DM bringup series on TI DRA7xx platformi [1].
Simon, I am not able to build the seires for chromebook_link, may be because of the compiler I have, can you verify this series?
arch/x86/lib/built-in.o: In function `__wrap___udivdi3': /home/mugunthan/workspace/git/work/u-boot/dm-sata/arch/x86/lib/gcc.c:25: undefined reference to `__normal___udivdi3' Makefile:1171: recipe for target 'u-boot' failed make: *** [u-boot] Error 1
[1]: https://www.mail-archive.com/u-boot@lists.denx.de/msg202781.html
Mugunthan V N (3): drivers: block: Kconfig: set default n to CONFIG_DISK configs: chromebook_link: enable CONFIG_DISK for accessing sata disk drive cmd: scsi: compile out scsi_init when CONFIG_DISK is defined
cmd/scsi.c | 3 ++- configs/chromebook_link_defconfig | 1 + drivers/block/Kconfig | 2 +- 3 files changed, 4 insertions(+), 2 deletions(-)
When a platform is converted to support DM and when its scsi driver is not converted to support DM, there is a build break as multiple definition of scsi_init(). So select CONFIG_DISK only when the platform supports CONFIG_DISK.
drivers/built-in.o: In function `scsi_init': /home/mugunthan/workspace/git/work/u-boot/dm-sata/drivers/block/disk-uclass.c:37: multiple definition of `scsi_init' board/sunxi/built-in.o:/home/mugunthan/workspace/git/work/u-boot/dm-sata/board/sunxi/ahci.c:74: first defined here Makefile:1171: recipe for target 'u-boot' failed make: *** [u-boot] Error 1
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- drivers/block/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/block/Kconfig b/drivers/block/Kconfig index 915c1eb..e62bf75 100644 --- a/drivers/block/Kconfig +++ b/drivers/block/Kconfig @@ -1,7 +1,7 @@ config DISK bool "Support disk controllers with driver model" depends on DM - default y if DM + default n if DM help This enables a uclass for disk controllers in U-Boot. Various driver types can use this, such as AHCI/SATA. It does not provide any standard
Hi Mugunthan,
This is because you are defining scsi_init() in the uclass, but I don't think that is a great idea. Or at least it should only be defined if DISK is enabled.
Hi Simon
On Monday 07 March 2016 08:09 AM, Simon Glass wrote:
Hi Mugunthan,
By default if DM is enabled DISK is also enabled as the Kconfig default is "y if DM", So this patch makes default n for DISK so that it can be enabled in platform defconfig which supports CONFIG_DISK.
Regards Mugunthan V N
Hi Mugunthan,
On 7 March 2016 at 23:30, Mugunthan V N mugunthanvnm@ti.com wrote:
Hi Simon
Hi Mugunthan,
I'm trying to get my blk uclass applied - part of it is in u-boot-dm/next.
Then I think we should drop UCLASS_DISK. I'll take a look at this and then we can figure out your patch.
I thought it might go in this release, but since it didn't, we may as well do things properly.
On Sat, Mar 12, 2016 at 07:52:01PM -0700, Simon Glass wrote:
Hi Mugunthan,
Hi Simon
Hi Mugunthan,
Yes, I had hoped to take it this release but it got too close to the end before we (mostly...) had the Kconfig changes to not break other boards done so lets do it better in the next release instead.
Hi Mugunthan,
Hi Simon
Hi Mugunthan,
I've been out for a few weeks but I plan to get a new series out next week that drops UCLASS_DISK, among other things.
As the CONFIG_DISK Kconfig default value is changed to 'n', select CONFIG_DISK for chromebook_link in defconfig
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/chromebook_link_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 1cee7d4..4ab03c7 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -48,3 +48,4 @@ CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y +CONFIG_DISK=y
When CONFIG_DISK is defined, disk_uclass takes care of scsi_init, so compile out scsi_init when CONFIG_DISK is defined.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- cmd/scsi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/cmd/scsi.c b/cmd/scsi.c index bc7d1b6..e2ae046 100644 --- a/cmd/scsi.c +++ b/cmd/scsi.c @@ -181,7 +181,8 @@ int scsi_get_disk_count(void) return scsi_max_devs; }
-#if defined(CONFIG_PCI) && !defined(CONFIG_SCSI_AHCI_PLAT) +#if defined(CONFIG_PCI) && !defined(CONFIG_SCSI_AHCI_PLAT) && \ + !defined(CONFIG_DISK) void scsi_init(void) { int busdevfunc = -1;
Mugunthan V N
