[U-Boot] Please pull ARC changes
Hi Tom,
Please pull a series for ARC.
Here we fix L2 cache (AKA SLC) operation found once we disabled usage of IO-coherency in U-Boot, improve support of clock-generation unit (AKA CGU) and also doing some minor clean-up and updates.
The following changes since commit 086ebcd40e9bf8efc520f1b177fd8e3cc0e506fa:
Merge git://git.denx.de/u-boot-fsl-qoriq (2018-01-17 13:48:35 -0500)
git://git.denx.de/u-boot-arc.git
for you to fetch changes up to 8f44e1ee799d75eb2b296a7525dc0c3003a3644c:
ARC: devboards: Allow huge uImages (up to 128 MiB) (2018-01-19 17:59:35 +0300)
---------------------------------------------------------------- Alexey Brodkin (1): ARC: devboards: Allow huge uImages (up to 128 MiB)
Eugeniy Paltsev (9): ARC: ARCv2: Cache: Fixed operation without IOC ARC: Cache: Disable IOC by default ARC: Cache: Fix style violations reported by checkpatch ARC: HSDK: Hang on panic ARC: HSDK: CGU: Update AXI, TUN, ARC clock options ARC: HSDK: CGU: Use plat data instead of priv data ARC: HSDK: CGU: Add 'Hz' when printing clock frequency ARC: HSDK: DTS: Add cgu-clk node ARC: Invalidate instruction and data caches early on boot
arch/arc/dts/hsdk.dts | 6 ++++ arch/arc/include/asm/arcregs.h | 7 ++++ arch/arc/lib/cache.c | 208 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------- ------- arch/arc/lib/start.S | 12 +++++++ configs/hsdk_defconfig | 1 + drivers/clk/clk-hsdk-cgu.c | 177 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------ include/configs/axs10x.h | 2 +- include/configs/hsdk.h | 2 +- include/dt-bindings/clock/snps,hsdk-cgu.h | 8 +++-- 9 files changed, 328 insertions(+), 95 deletions(-)
-Alexey
On Fri, Jan 19, 2018 at 03:08:42PM +0000, Alexey Brodkin wrote:
Hi Tom,
Alexey Brodkin
