[PATCH v1] clk: imxrt: Use dts for anatop base address
In Linux IMX and IMXRT use the device tree to hold the anatop address. The anatop is used in clock drivers as it controls the internal PLLs This will move the macro from asm/arch-imxrt to the device tree. This presumably should also be done with the other IMX boards as well.
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- arch/arm/dts/imxrt1020-evk-u-boot.dtsi | 4 ++++ arch/arm/dts/imxrt1020.dtsi | 5 +++++ arch/arm/dts/imxrt1050-evk-u-boot.dtsi | 4 ++++ arch/arm/dts/imxrt1050.dtsi | 5 +++++ arch/arm/include/asm/arch-imxrt/imx-regs.h | 2 -- drivers/clk/imx/clk-imxrt1020.c | 2 +- drivers/clk/imx/clk-imxrt1050.c | 2 +- 7 files changed, 20 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/imxrt1020-evk-u-boot.dtsi b/arch/arm/dts/imxrt1020-evk-u-boot.dtsi index 121665a2d2..9e1b074d2e 100644 --- a/arch/arm/dts/imxrt1020-evk-u-boot.dtsi +++ b/arch/arm/dts/imxrt1020-evk-u-boot.dtsi @@ -22,6 +22,10 @@ u-boot,dm-spl; };
+&anatop { + u-boot,dm-spl; +}; + &clks { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imxrt1020.dtsi b/arch/arm/dts/imxrt1020.dtsi index 5ba314f995..13511ebb18 100644 --- a/arch/arm/dts/imxrt1020.dtsi +++ b/arch/arm/dts/imxrt1020.dtsi @@ -67,6 +67,11 @@ fsl,mux_mask = <0x7>; };
+ anatop: anatop@400d8000 { + compatible = "fsl,imxrt-anatop"; + reg = <0x400d8000 0x4000>; + }; + clks: ccm@400fc000 { compatible = "fsl,imxrt1020-ccm"; reg = <0x400fc000 0x4000>; diff --git a/arch/arm/dts/imxrt1050-evk-u-boot.dtsi b/arch/arm/dts/imxrt1050-evk-u-boot.dtsi index 3168c2df2c..617cece448 100644 --- a/arch/arm/dts/imxrt1050-evk-u-boot.dtsi +++ b/arch/arm/dts/imxrt1050-evk-u-boot.dtsi @@ -22,6 +22,10 @@ u-boot,dm-spl; };
+&anatop { + u-boot,dm-spl; +}; + &clks { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi index 6560a3827f..09f4712af6 100644 --- a/arch/arm/dts/imxrt1050.dtsi +++ b/arch/arm/dts/imxrt1050.dtsi @@ -59,6 +59,11 @@ fsl,mux_mask = <0x7>; };
+ anatop: anatop@400d8000 { + compatible = "fsl,imxrt-anatop"; + reg = <0x400d8000 0x4000>; + }; + clks: ccm@400fc000 { compatible = "fsl,imxrt1050-ccm"; reg = <0x400fc000 0x4000>; diff --git a/arch/arm/include/asm/arch-imxrt/imx-regs.h b/arch/arm/include/asm/arch-imxrt/imx-regs.h index d01e6ca2e0..ad739caae9 100644 --- a/arch/arm/include/asm/arch-imxrt/imx-regs.h +++ b/arch/arm/include/asm/arch-imxrt/imx-regs.h @@ -15,8 +15,6 @@ #define GPIO4_BASE_ADDR 0x401C4000 #define GPIO5_BASE_ADDR 0x400C0000
-#define ANATOP_BASE_ADDR 0x400d8000 - #define MXS_LCDIF_BASE 0x402b8000
#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) diff --git a/drivers/clk/imx/clk-imxrt1020.c b/drivers/clk/imx/clk-imxrt1020.c index 840f783940..5adc37ebfe 100644 --- a/drivers/clk/imx/clk-imxrt1020.c +++ b/drivers/clk/imx/clk-imxrt1020.c @@ -93,7 +93,7 @@ static int imxrt1020_clk_probe(struct udevice *dev) void *base;
/* Anatop clocks */ - base = (void *)ANATOP_BASE_ADDR; + base = ofnode_get_addr(ofnode_by_compatible(ofnode_null(), "fsl,imxrt-anatop"));
clk_dm(IMXRT1020_CLK_PLL2_SYS, imx_clk_pllv3(IMX_PLLV3_GENERIC, "pll2_sys", "osc", diff --git a/drivers/clk/imx/clk-imxrt1050.c b/drivers/clk/imx/clk-imxrt1050.c index 3e17161002..cced32b758 100644 --- a/drivers/clk/imx/clk-imxrt1050.c +++ b/drivers/clk/imx/clk-imxrt1050.c @@ -117,7 +117,7 @@ static int imxrt1050_clk_probe(struct udevice *dev) void *base;
clk_dm(IMXRT1050_CLK_PLL1_REF_SEL, imx_clk_mux("pll1_arm_ref_sel", base + 0x0, 14, 2,
Jesse Taube
