[U-Boot] [PATCH] rockchip: mkimage: remove (left-over) assignment w/o effect [coverity]
An assignment (of a value to itself) was left over (after removing and addition from the line) from moving the common padding code into rkcommon_vrec_header.
This change removes this to avoid a spurious warning in static code analysis (i.e. Coverity).
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
tools/rkcommon.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index 1316b9a..f4d932b 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -376,7 +376,6 @@ int rkcommon_vrec_header(struct image_tool_params *params, /* Allocate, clear and install the header */ tparams->hdr = malloc(tparams->header_size); memset(tparams->hdr, 0, tparams->header_size); - tparams->header_size = tparams->header_size;
/* * If someone passed in 0 for the alignment, we'd better handle
Reported-by: Coverity (CID: 161418) Reviewed-by: Tom Rini trini@konsulko.com
Thanks!
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reported-by: Coverity (CID: 161418) Reviewed-by: Tom Rini trini@konsulko.com
Philipp Tomsich
