[U-Boot] Pull request: u-boot-net.git master
Hi Wolfgang,
This should include fixes for all the warnings from db288a96027fa1cb3f8a53f330724f864224a56c "net: Remove volatile from net API"
The following changes since commit b86a475c1a602c6ee44f4469d933df8792418a7a: Joe Hershberger (1): MAKEALL: Report boards with errors vs warnings
git://git.denx.de/u-boot-net.git master
Anatolij Gustschin (7): drivers/net/smc911x.c: Fix GCC 4.6 warning drivers/usb/eth/smsc95xx.c: Fix GCC 4.6 warning drivers/net/mpc5xxx_fec.c: Fix build warning arch/arm/cpu/ixp/npe/npe.c: Fix build warning drivers/usb/eth/asix.c: Fix build warning drivers/net/mpc512x_fec.c: Fix build warning drivers/net/4xx_enet.c: Fix build warning
Joe Hershberger (77): ppc: Fix warning in TSEC Ethernet driver davinci: Fix Ethernet driver interface warning drivers/net/armada100_fec.c: Fix compile warning drivers/net/at91_emac.c: Fix compile warning drivers/net/calxedaxgmac.c: Fix compile warning drivers/net/cs8900.c: Fix compile warning drivers/net/dc2114x.c: Fix compile warning drivers/net/dm9000x.c: Fix compile warning drivers/net/dnet.c: Fix compile warning drivers/net/eepro100.c: Fix compile warning drivers/net/enc28j60.c: Fix compile warning drivers/net/fec_mxc.c: Fix compile warning drivers/net/ftmac100.c: Fix compile warning drivers/net/ks8695eth.c: Fix compile warning drivers/net/lan91c96.c: Fix compile warning drivers/net/macb.c: Fix compile warning drivers/net/smc91111.c: Fix compile warning arch/powerpc/cpu/mpc8220/fec.c: Fix compile warning arch/powerpc/cpu/mpc8260/ether_fcc.c: Fix compile warning arch/powerpc/cpu/mpc85xx/ether_fcc.c: Fix compile warning board/esd/cpci405/cpci405.c: Fix compile warning drivers/net/e1000.c: Fix compile warning drivers/net/fm/eth.c: Fix compile warning drivers/net/natsemi.c: Fix compile warning drivers/net/ns8382x.c: Fix compile warning drivers/net/rtl8139.c: Fix compile warning drivers/net/tsi108_eth.c: Fix compile warning drivers/net/uli526x.c: Fix compile warning drivers/qe/uec.c: Fix compile warning net: Remove redefinitions of net.h functions arch/powerpc/cpu/mpc8260/ether_scc.c: Fix compile warning drivers/net/pcnet.c: Fix compile warning drivers/net/rtl8169.c: Fix compile warning net: Fix remaining API interface breakage net: Remove CMD_PING where there's no CMD_NET net: Move MAC-seeded rand out of bootp.c net: Move CDP out of net.c net: Encapsulate CDP packet identification net: Move ARP out of net.c net: Move PING out of net.c net: Move RARP receive logic out of net.c net: cosmetic: Un-typedef IP_t net: cosmetic: Split struct ip_udp_hdr into ip_hdr net: cosmetic: Un-typedef Ethernet_t net: cosmetic: Un-typedef VLAN_Ethernet_t net: cosmetic: Un-typedef ARP_t net: cosmetic: Un-typedef ICMP_t net: cosmetic: Rename parameter len to payload_len net: cosmetic: Add a more explicit comment about 802.2 net: cosmetic: Rename "x" to "eth_proto" net: cosmetic: Rename CDPHandler to cdp_receive net: cosmetic: Rename OPT_SIZE to OPT_FIELD_SIZE net: cosmetic: Alphabetize includes in net.c net: cosmetic: Rename tmp to reply_ip_addr in arp.c net: cosmetic: Replace magic numbers in arp.c with constants net: Refactor IP, UPD, and ICMP header writing functions net: Refactor NetSendUDPPacket to share more code net: Refactor packet length computations net: Refactor bootp packet length computations net: Move debug trace to point of action net: Refactor ping receive handler net: Refactor to use NetSendPacket instead of eth_send directly net: Refactor to protect access to the NetState variable net: Refactor to separate the UDP handler from the ARP handler net: Add net_update_ether() to handle ARP and Ping replies net: Don't write the "serverip" env var if configured not to net: Fix unused variable compile warning net: Add option CONFIG_BOOTP_MAY_FAIL net: Remove static allocation for MAC address in PingSend() net: Remove unused parameter from NetInitLoop() net: Fix net buffer initialization net: Make sure NetLoop is initialized when using NetConsole net: Don't copy every packet that waits for an ARP net: Separate ArpRequest() into lower-level func net: Add link-local addressing support net: Work-around for brain-damaged Cisco equipment with arp-proxy net: Allow filtering on debug traces in the net subsystem
Nobuhiro Iwamatsu (2): net: sh_eth: Add support SH7734 Ethernet device net: sh-eth: Add support Gigabit of SH7734
Stephan Linz (3): drivers/net/xilinx_ll_temac.c: Fix compile warning drivers/net/xilinx_emaclite.c: Fix compile warning drivers/net/xilinx_axi_emac.c: Fix compile warning
Wolfgang Denk (1): MPC8xx: fix "Remove volatile from net API" aftermath
README | 17 + arch/arm/cpu/ixp/npe/npe.c | 2 +- arch/mips/cpu/mips32/au1x00/au1x00_eth.c | 3 +- arch/powerpc/cpu/mpc8220/fec.c | 5 +- arch/powerpc/cpu/mpc8260/ether_fcc.c | 19 +- arch/powerpc/cpu/mpc8260/ether_scc.c | 2 +- arch/powerpc/cpu/mpc85xx/ether_fcc.c | 2 +- arch/powerpc/cpu/mpc8xx/fec.c | 8 +- arch/powerpc/cpu/mpc8xx/scc.c | 4 +- board/Marvell/db64360/mv_eth.c | 5 +- board/Marvell/db64360/mv_eth.h | 4 +- board/Marvell/db64460/mv_eth.c | 5 +- board/Marvell/db64460/mv_eth.h | 4 +- board/esd/cpci405/cpci405.c | 7 +- board/esd/cpci750/mv_eth.c | 5 +- board/esd/cpci750/mv_eth.h | 4 +- board/evb64260/eth.c | 3 +- board/evb64260/eth.h | 2 +- board/prodrive/p3mx/mv_eth.c | 5 +- board/prodrive/p3mx/mv_eth.h | 4 +- common/cmd_net.c | 39 +- doc/README.link-local | 76 ++ drivers/net/4xx_enet.c | 3 +- drivers/net/altera_tse.c | 3 +- drivers/net/armada100_fec.c | 3 +- drivers/net/at91_emac.c | 3 +- drivers/net/ax88180.c | 3 +- drivers/net/bfin_mac.c | 5 +- drivers/net/bfin_mac.h | 2 +- drivers/net/calxedaxgmac.c | 6 +- drivers/net/cs8900.c | 3 +- drivers/net/davinci_emac.c | 2 +- drivers/net/dc2114x.c | 4 +- drivers/net/designware.c | 5 +- drivers/net/dm9000x.c | 3 +- drivers/net/dnet.c | 3 +- drivers/net/e1000.c | 5 +- drivers/net/eepro100.c | 7 +- drivers/net/enc28j60.c | 2 +- drivers/net/ep93xx_eth.c | 2 +- drivers/net/ethoc.c | 2 +- drivers/net/fec_mxc.c | 2 +- drivers/net/fm/eth.c | 2 +- drivers/net/fsl_mcdmafec.c | 7 +- drivers/net/ftgmac100.c | 3 +- drivers/net/ftmac100.c | 3 +- drivers/net/greth.c | 2 +- drivers/net/inca-ip_sw.c | 4 +- drivers/net/ks8695eth.c | 3 +- drivers/net/lan91c96.c | 4 +- drivers/net/macb.c | 3 +- drivers/net/mcffec.c | 3 +- drivers/net/mpc512x_fec.c | 4 +- drivers/net/mpc5xxx_fec.c | 2 +- drivers/net/mvgbe.c | 3 +- drivers/net/natsemi.c | 6 +- drivers/net/ne2000_base.c | 2 +- drivers/net/netarm_eth.c | 2 +- drivers/net/netconsole.c | 24 +- drivers/net/ns8382x.c | 6 +- drivers/net/pcnet.c | 6 +- drivers/net/plb2800_eth.c | 6 +- drivers/net/rtl8139.c | 4 +- drivers/net/rtl8169.c | 2 +- drivers/net/sh_eth.c | 36 +- drivers/net/sh_eth.h | 86 ++- drivers/net/smc91111.c | 3 +- drivers/net/smc911x.c | 3 +- drivers/net/tsec.c | 5 +- drivers/net/tsi108_eth.c | 14 +- drivers/net/uli526x.c | 6 +- drivers/net/xilinx_axi_emac.c | 2 +- drivers/net/xilinx_emaclite.c | 6 +- drivers/net/xilinx_ll_temac_fifo.c | 3 +- drivers/net/xilinx_ll_temac_fifo.h | 3 +- drivers/net/xilinx_ll_temac_sdma.c | 3 +- drivers/net/xilinx_ll_temac_sdma.h | 3 +- drivers/qe/uec.c | 2 +- drivers/usb/eth/asix.c | 2 +- drivers/usb/eth/smsc95xx.c | 3 +- drivers/usb/gadget/ether.c | 7 +- include/common.h | 14 +- include/configs/am3517_crane.h | 2 +- include/configs/am3517_evm.h | 2 +- include/configs/origen.h | 2 +- include/net.h | 157 +++-- net/Makefile | 8 +- net/arp.c | 236 ++++++ net/arp.h | 30 + net/bootp.c | 133 ++--- net/bootp.h | 10 +- net/cdp.c | 366 ++++++++++ net/cdp.h | 21 + net/dns.c | 12 +- net/link_local.c | 334 +++++++++ net/link_local.h | 24 + net/net.c | 1149 ++++++++---------------------- net/net_rand.c | 68 ++ net/net_rand.h | 26 + net/nfs.c | 16 +- net/ping.c | 115 +++ net/ping.h | 34 + net/rarp.c | 61 +- net/rarp.h | 7 +- net/sntp.c | 8 +- net/tftp.c | 14 +- 106 files changed, 2136 insertions(+), 1294 deletions(-) create mode 100644 doc/README.link-local create mode 100644 net/arp.c create mode 100644 net/arp.h create mode 100644 net/cdp.c create mode 100644 net/cdp.h create mode 100644 net/link_local.c create mode 100644 net/link_local.h create mode 100644 net/net_rand.c create mode 100644 net/net_rand.h create mode 100644 net/ping.c create mode 100644 net/ping.h
Dear Joe Hershberger,
In message CANr=Z=YEnfX-C2HpHZ8C-GmGFxSsQE2meDNZ9Ta4nAB8JFT9rw@mail.gmail.com you wrote:
Hi Wolfgang,
Applied, thanks a lot.
Joe Hershberger
