[U-Boot] [PATCH] patman: Allow use outside of u-boot tree
To make it usable in git trees not providing a patch checker implementation, add a command line option, allowing to suppress patch check. While we are at it, sort debug options alphabetically.
Also, do not raise an exception if checkpatch.pl is not found - just print an error message suggesting to use the new option, and return nonzero status.
. unit test passes: $ ./patman -t <unittest.result.TestResult run=7 errors=0 failures=0> . successfully used patman in the autotest tree to generate a patch email (with --no-check option) . successfully used patman in the u-boot tree to generate a patch email . `patman --help' now shows command line options ordered alphabetically
Signed-off-by: Vadim Bendebury vbendeb@chromium.org --- tools/patman/checkpatch.py | 10 +++++----- tools/patman/patman.py | 14 ++++++++++---- 2 files changed, 15 insertions(+), 9 deletions(-)
diff --git a/tools/patman/checkpatch.py b/tools/patman/checkpatch.py index f72f8ee..00aef09 100644 --- a/tools/patman/checkpatch.py +++ b/tools/patman/checkpatch.py @@ -23,6 +23,7 @@ import command import gitutil import os import re +import sys import terminal
def FindCheckPatch(): @@ -47,8 +48,10 @@ def FindCheckPatch(): if os.path.isfile(fname): return fname path = os.path.dirname(path) - print 'Could not find checkpatch.pl' - return None + + print >> sys.stderr, ('Cannot find checkpatch.pl - please put it in your ' + + '~/bin directory or use --no_patch') + sys.exit(1)
def CheckPatch(fname, verbose=False): """Run checkpatch.pl on a file. @@ -67,9 +70,6 @@ def CheckPatch(fname, verbose=False): error_count, warning_count, lines = 0, 0, 0 problems = [] chk = FindCheckPatch() - if not chk: - raise OSError, ('Cannot find checkpatch.pl - please put it in your ' + - '~/bin directory') item = {} stdout = command.Output(chk, '--no-tree', fname) #pipe = subprocess.Popen(cmd, stdout=subprocess.PIPE) diff --git a/tools/patman/patman.py b/tools/patman/patman.py index e56dd01..e049081 100755 --- a/tools/patman/patman.py +++ b/tools/patman/patman.py @@ -50,6 +50,9 @@ parser.add_option('-i', '--ignore-errors', action='store_true', help='Send patches email even if patch errors are found') parser.add_option('-n', '--dry-run', action='store_true', dest='dry_run', default=False, help="Do a try run (create but don't email patches)") +parser.add_option('-p', '--project', default=project.DetectProject(), + help="Project name; affects default option values and " + "aliases [default: %default]") parser.add_option('-s', '--start', dest='start', type='int', default=0, help='Commit to start creating patches from (0 = HEAD)') parser.add_option('-t', '--test', action='store_true', dest='test', @@ -58,11 +61,11 @@ parser.add_option('-v', '--verbose', action='store_true', dest='verbose', default=False, help='Verbose output of errors and warnings') parser.add_option('--cc-cmd', dest='cc_cmd', type='string', action='store', default=None, help='Output cc list for patch file (used by git)') +parser.add_option('--no-check', action='store_false', dest='check_patch', + default=True, + help="Don't check for patch compliance") parser.add_option('--no-tags', action='store_false', dest='process_tags', default=True, help="Don't process subject tags as aliaes") -parser.add_option('-p', '--project', default=project.DetectProject(), - help="Project name; affects default option values and " - "aliases [default: %default]")
parser.usage = """patman [options]
@@ -146,7 +149,10 @@ else: series.DoChecks()
# Check the patches, and run them through 'git am' just to be sure - ok = checkpatch.CheckPatches(options.verbose, args) + if options.check_patch: + ok = checkpatch.CheckPatches(options.verbose, args) + else: + ok = True if not gitutil.ApplyPatches(options.verbose, args, options.count + options.start): ok = False
Vadim Bendebury
