[U-Boot] [PATCH 0/8] arm: socfpga: Board cleanup
This series cleans up the QTS-generated header files and cleans up the SoCDK support such that they fit into the framework just like any other SoCFPGA boards.
Marek Vasut (8): arm: socfpga: Move wrappers into platform directory arm: socfpga: Unbind CPU type from board type arm: socfpga: Split Altera socfpga into AV and CV SoCDK arm: socfpga: Remove CV-specific parts from AV-SoCDK arm: socfpga: Remove AV-specific parts from CV-SoCDK arm: socfpga: Add qts-filter.sh script arm: socfpga: Switch to filtered QTS files arm: socfpga: Make the pinmux table const u8
arch/arm/mach-socfpga/Kconfig | 26 +- arch/arm/mach-socfpga/Makefile | 9 + .../arm/mach-socfpga/include/mach/system_manager.h | 3 +- arch/arm/mach-socfpga/qts-filter.sh | 205 +++ arch/arm/mach-socfpga/system_manager.c | 2 +- .../arm/mach-socfpga}/wrap_iocsr_config.c | 7 +- arch/arm/mach-socfpga/wrap_pinmux_config.c | 17 + .../arm/mach-socfpga}/wrap_pll_config.c | 2 +- .../arm/mach-socfpga}/wrap_sdram_config.c | 8 +- board/altera/{socfpga => arria5-socdk}/MAINTAINERS | 0 board/altera/{socfpga => arria5-socdk}/Makefile | 4 +- board/altera/arria5-socdk/qts/iocsr_config.h | 696 ++++++++++ board/altera/arria5-socdk/qts/pinmux_config.h | 219 ++++ board/altera/arria5-socdk/qts/pll_config.h | 85 ++ board/altera/arria5-socdk/qts/sdram_config.h | 340 +++++ board/altera/{socfpga => arria5-socdk}/socfpga.c | 0 .../altera/{socfpga => cyclone5-socdk}/MAINTAINERS | 0 board/altera/{socfpga => cyclone5-socdk}/Makefile | 4 +- board/altera/cyclone5-socdk/qts/iocsr_config.h | 660 ++++++++++ board/altera/cyclone5-socdk/qts/pinmux_config.h | 219 ++++ board/altera/cyclone5-socdk/qts/pll_config.h | 85 ++ board/altera/cyclone5-socdk/qts/sdram_config.h | 342 +++++ board/altera/{socfpga => cyclone5-socdk}/socfpga.c | 0 board/altera/socfpga/qts/iocsr_config.c | 1345 -------------------- board/altera/socfpga/qts/iocsr_config.h | 26 - board/altera/socfpga/qts/pinmux_config.c | 429 ------- board/altera/socfpga/qts/pinmux_config.h | 54 - board/altera/socfpga/qts/pll_config.h | 109 -- board/altera/socfpga/qts/sdram_config.h | 100 -- board/altera/socfpga/qts/sequencer_auto.h | 128 -- board/altera/socfpga/qts/sequencer_auto_ac_init.h | 84 -- .../altera/socfpga/qts/sequencer_auto_inst_init.h | 268 ---- board/altera/socfpga/qts/sequencer_defines.h | 122 -- board/altera/socfpga/wrap_pinmux_config.c | 35 - configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + 37 files changed, 2908 insertions(+), 2728 deletions(-) create mode 100755 arch/arm/mach-socfpga/qts-filter.sh rename {board/altera/socfpga => arch/arm/mach-socfpga}/wrap_iocsr_config.c (87%) create mode 100644 arch/arm/mach-socfpga/wrap_pinmux_config.c rename {board/altera/socfpga => arch/arm/mach-socfpga}/wrap_pll_config.c (99%) rename {board/altera/socfpga => arch/arm/mach-socfpga}/wrap_sdram_config.c (98%) copy board/altera/{socfpga => arria5-socdk}/MAINTAINERS (100%) copy board/altera/{socfpga => arria5-socdk}/Makefile (57%) create mode 100644 board/altera/arria5-socdk/qts/iocsr_config.h create mode 100644 board/altera/arria5-socdk/qts/pinmux_config.h create mode 100644 board/altera/arria5-socdk/qts/pll_config.h create mode 100644 board/altera/arria5-socdk/qts/sdram_config.h copy board/altera/{socfpga => arria5-socdk}/socfpga.c (100%) rename board/altera/{socfpga => cyclone5-socdk}/MAINTAINERS (100%) rename board/altera/{socfpga => cyclone5-socdk}/Makefile (57%) create mode 100644 board/altera/cyclone5-socdk/qts/iocsr_config.h create mode 100644 board/altera/cyclone5-socdk/qts/pinmux_config.h create mode 100644 board/altera/cyclone5-socdk/qts/pll_config.h create mode 100644 board/altera/cyclone5-socdk/qts/sdram_config.h rename board/altera/{socfpga => cyclone5-socdk}/socfpga.c (100%) delete mode 100644 board/altera/socfpga/qts/iocsr_config.c delete mode 100644 board/altera/socfpga/qts/iocsr_config.h delete mode 100644 board/altera/socfpga/qts/pinmux_config.c delete mode 100644 board/altera/socfpga/qts/pinmux_config.h delete mode 100644 board/altera/socfpga/qts/pll_config.h delete mode 100644 board/altera/socfpga/qts/sdram_config.h delete mode 100644 board/altera/socfpga/qts/sequencer_auto.h delete mode 100644 board/altera/socfpga/qts/sequencer_auto_ac_init.h delete mode 100644 board/altera/socfpga/qts/sequencer_auto_inst_init.h delete mode 100644 board/altera/socfpga/qts/sequencer_defines.h delete mode 100644 board/altera/socfpga/wrap_pinmux_config.c
Move the wrappers for QTS-generated files into platform directory out of the board directory. The trick here is to add -I to CFLAGS such that it points to the board directory in source tree and thus the qts/ directory there is still reachable.
Signed-off-by: Marek Vasut marex@denx.de --- arch/arm/mach-socfpga/Makefile | 9 +++++++++ .../socfpga => arch/arm/mach-socfpga}/wrap_iocsr_config.c | 2 +- .../socfpga => arch/arm/mach-socfpga}/wrap_pinmux_config.c | 2 +- .../altera/socfpga => arch/arm/mach-socfpga}/wrap_pll_config.c | 2 +- .../socfpga => arch/arm/mach-socfpga}/wrap_sdram_config.c | 10 +++++----- board/altera/socfpga/Makefile | 4 +--- 6 files changed, 18 insertions(+), 11 deletions(-) rename {board/altera/socfpga => arch/arm/mach-socfpga}/wrap_iocsr_config.c (96%) rename {board/altera/socfpga => arch/arm/mach-socfpga}/wrap_pinmux_config.c (97%) rename {board/altera/socfpga => arch/arm/mach-socfpga}/wrap_pll_config.c (99%) rename {board/altera/socfpga => arch/arm/mach-socfpga}/wrap_sdram_config.c (98%)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 8a745c9..316b326 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -10,3 +10,12 @@ obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ fpga_manager.o scan_manager.o obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o + +# QTS-generated config file wrappers +obj-y += wrap_pll_config.o +obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ + wrap_sdram_config.o +CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) +CFLAGS_wrap_pinmux_config.o += -I$(srctree)/board/$(BOARDDIR) +CFLAGS_wrap_pll_config.o += -I$(srctree)/board/$(BOARDDIR) +CFLAGS_wrap_sdram_config.o += -I$(srctree)/board/$(BOARDDIR) diff --git a/board/altera/socfpga/wrap_iocsr_config.c b/arch/arm/mach-socfpga/wrap_iocsr_config.c similarity index 96% rename from board/altera/socfpga/wrap_iocsr_config.c rename to arch/arm/mach-socfpga/wrap_iocsr_config.c index 49e9228..31b5426 100644 --- a/board/altera/socfpga/wrap_iocsr_config.c +++ b/arch/arm/mach-socfpga/wrap_iocsr_config.c @@ -10,7 +10,7 @@ /* * Yes, dear reader, we're including a C file here, this is no mistake :-) */ -#include "qts/iocsr_config.c" +#include <qts/iocsr_config.c>
int iocsr_get_config_table(const unsigned int chain_id, const unsigned long **table, diff --git a/board/altera/socfpga/wrap_pinmux_config.c b/arch/arm/mach-socfpga/wrap_pinmux_config.c similarity index 97% rename from board/altera/socfpga/wrap_pinmux_config.c rename to arch/arm/mach-socfpga/wrap_pinmux_config.c index b33e2ca..688f1e4 100644 --- a/board/altera/socfpga/wrap_pinmux_config.c +++ b/arch/arm/mach-socfpga/wrap_pinmux_config.c @@ -25,7 +25,7 @@ */ #define _PRELOADER_PINMUX_CONFIG_H_ #define CONFIG_HPS_PINMUX_NUM -#include "qts/pinmux_config.c" +#include <qts/pinmux_config.c>
void sysmgr_get_pinmux_table(const unsigned long **table, unsigned int *table_len) diff --git a/board/altera/socfpga/wrap_pll_config.c b/arch/arm/mach-socfpga/wrap_pll_config.c similarity index 99% rename from board/altera/socfpga/wrap_pll_config.c rename to arch/arm/mach-socfpga/wrap_pll_config.c index 8dbff68..8a0a0e6 100644 --- a/board/altera/socfpga/wrap_pll_config.c +++ b/arch/arm/mach-socfpga/wrap_pll_config.c @@ -6,7 +6,7 @@
#include <common.h> #include <asm/arch/clock_manager.h> -#include "qts/pll_config.h" +#include <qts/pll_config.h>
#define MAIN_VCO_BASE ( \ (CONFIG_HPS_MAINPLLGRP_VCO_DENOM << \ diff --git a/board/altera/socfpga/wrap_sdram_config.c b/arch/arm/mach-socfpga/wrap_sdram_config.c similarity index 98% rename from board/altera/socfpga/wrap_sdram_config.c rename to arch/arm/mach-socfpga/wrap_sdram_config.c index cd97cc5..72ce565 100644 --- a/board/altera/socfpga/wrap_sdram_config.c +++ b/arch/arm/mach-socfpga/wrap_sdram_config.c @@ -8,12 +8,12 @@ #include <errno.h> #include <asm/arch/sdram.h> /* QTS output file. */ -#include "qts/sdram_config.h" +#include <qts/sdram_config.h>
-#include "qts/sequencer_auto_ac_init.h" -#include "qts/sequencer_auto_inst_init.h" -#include "qts/sequencer_auto.h" -#include "qts/sequencer_defines.h" +#include <qts/sequencer_auto_ac_init.h> +#include <qts/sequencer_auto_inst_init.h> +#include <qts/sequencer_auto.h> +#include <qts/sequencer_defines.h>
static const struct socfpga_sdram_config sdram_config = { .ctrl_cfg = diff --git a/board/altera/socfpga/Makefile b/board/altera/socfpga/Makefile index 5a15c71..86f9b78 100644 --- a/board/altera/socfpga/Makefile +++ b/board/altera/socfpga/Makefile @@ -6,6 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y := socfpga.o wrap_pll_config.o -obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ - wrap_sdram_config.o +obj-y := socfpga.o
The CONFIG_TARGET_SOCFPGA_CYCLONE5 and CONFIG_TARGET_SOCFPGA_ARRIA5 selected both a board and a CPU. This is not correct as these macros are supposed to select only board.
All would be good, if QTS-generated header files didn't check for these macros exactly to determine if the platform is Cyclone V or Arria V. Thus, for the sake of compatibility with not well fleshed out header file generator, this patch makes these two macros into a stub config option and introduces new CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK and CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK targets, which select the previous stub config option.
The result is that compatibility with QTS is preserved and the new CONFIG_TARGET_* select actual target boards.
Signed-off-by: Marek Vasut marex@denx.de --- arch/arm/mach-socfpga/Kconfig | 26 ++++++++++++++++++-------- configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + 4 files changed, 21 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index e46c348..1a441ff 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -1,28 +1,38 @@ if ARCH_SOCFPGA
+config TARGET_SOCFPGA_ARRIA5 + bool + +config TARGET_SOCFPGA_CYCLONE5 + bool + choice prompt "Altera SOCFPGA board select" optional
-config TARGET_SOCFPGA_ARRIA5 - bool "Altera SOCFPGA Arria V" +config TARGET_SOCFPGA_ARRIA5_SOCDK + bool "Altera SOCFPGA SoCDK (Arria V)" + select TARGET_SOCFPGA_ARRIA5
-config TARGET_SOCFPGA_CYCLONE5 - bool "Altera SOCFPGA Cyclone V" +config TARGET_SOCFPGA_CYCLONE5_SOCDK + bool "Altera SOCFPGA SoCDK (Cyclone V)" + select TARGET_SOCFPGA_CYCLONE5
endchoice
config SYS_BOARD - default "socfpga" + default "socfpga" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "socfpga" if TARGET_SOCFPGA_CYCLONE5_SOCDK
config SYS_VENDOR - default "altera" + default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "altera" if TARGET_SOCFPGA_CYCLONE5_SOCDK
config SYS_SOC default "socfpga"
config SYS_CONFIG_NAME - default "socfpga_arria5" if TARGET_SOCFPGA_ARRIA5 - default "socfpga_cyclone5" if TARGET_SOCFPGA_CYCLONE5 + default "socfpga_arria5" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "socfpga_cyclone5" if TARGET_SOCFPGA_CYCLONE5_SOCDK
endif diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index b90686e..b0d6008 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y CONFIG_TARGET_SOCFPGA_ARRIA5=y +CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 5d7362b..39fcc5a 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y CONFIG_TARGET_SOCFPGA_CYCLONE5=y +CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 6ef2f97..1cb9d5d 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y CONFIG_TARGET_SOCFPGA_CYCLONE5=y +CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set
The board/altera/socfpga directory is not a generic SoCFPGA machine anymore, but instead it represents the Altera SoCDK board. To make matters more complicated, it represents both CycloneV and ArriaV variant.
On the other hand, nowadays, the content of this board directory is mostly comprised of QTS-generated header files, while all the generic code is in arch/arm/mach-socfpga already.
Thus, this patch splits the board/altera/socfpga into a separate board directory for ArriaV SoCDK and CycloneV SoCDK, so that each can be populated with the correct QTS-generated header files for that particular board.
Signed-off-by: Marek Vasut marex@denx.de --- arch/arm/mach-socfpga/Kconfig | 4 ++-- board/altera/{socfpga => arria5-socdk}/MAINTAINERS | 0 board/altera/{socfpga => arria5-socdk}/Makefile | 0 board/altera/{socfpga => arria5-socdk}/qts/iocsr_config.c | 0 board/altera/{socfpga => arria5-socdk}/qts/iocsr_config.h | 0 board/altera/{socfpga => arria5-socdk}/qts/pinmux_config.c | 0 board/altera/{socfpga => arria5-socdk}/qts/pinmux_config.h | 0 board/altera/{socfpga => arria5-socdk}/qts/pll_config.h | 0 board/altera/{socfpga => arria5-socdk}/qts/sdram_config.h | 0 board/altera/{socfpga => arria5-socdk}/qts/sequencer_auto.h | 0 board/altera/{socfpga => arria5-socdk}/qts/sequencer_auto_ac_init.h | 0 board/altera/{socfpga => arria5-socdk}/qts/sequencer_auto_inst_init.h | 0 board/altera/{socfpga => arria5-socdk}/qts/sequencer_defines.h | 0 board/altera/{socfpga => arria5-socdk}/socfpga.c | 0 board/altera/{socfpga => cyclone5-socdk}/MAINTAINERS | 0 board/altera/{socfpga => cyclone5-socdk}/Makefile | 0 board/altera/{socfpga => cyclone5-socdk}/qts/iocsr_config.c | 0 board/altera/{socfpga => cyclone5-socdk}/qts/iocsr_config.h | 0 board/altera/{socfpga => cyclone5-socdk}/qts/pinmux_config.c | 0 board/altera/{socfpga => cyclone5-socdk}/qts/pinmux_config.h | 0 board/altera/{socfpga => cyclone5-socdk}/qts/pll_config.h | 0 board/altera/{socfpga => cyclone5-socdk}/qts/sdram_config.h | 0 board/altera/{socfpga => cyclone5-socdk}/qts/sequencer_auto.h | 0 board/altera/{socfpga => cyclone5-socdk}/qts/sequencer_auto_ac_init.h | 0 .../altera/{socfpga => cyclone5-socdk}/qts/sequencer_auto_inst_init.h | 0 board/altera/{socfpga => cyclone5-socdk}/qts/sequencer_defines.h | 0 board/altera/{socfpga => cyclone5-socdk}/socfpga.c | 0 27 files changed, 2 insertions(+), 2 deletions(-) copy board/altera/{socfpga => arria5-socdk}/MAINTAINERS (100%) copy board/altera/{socfpga => arria5-socdk}/Makefile (100%) copy board/altera/{socfpga => arria5-socdk}/qts/iocsr_config.c (100%) copy board/altera/{socfpga => arria5-socdk}/qts/iocsr_config.h (100%) copy board/altera/{socfpga => arria5-socdk}/qts/pinmux_config.c (100%) copy board/altera/{socfpga => arria5-socdk}/qts/pinmux_config.h (100%) copy board/altera/{socfpga => arria5-socdk}/qts/pll_config.h (100%) copy board/altera/{socfpga => arria5-socdk}/qts/sdram_config.h (100%) copy board/altera/{socfpga => arria5-socdk}/qts/sequencer_auto.h (100%) copy board/altera/{socfpga => arria5-socdk}/qts/sequencer_auto_ac_init.h (100%) copy board/altera/{socfpga => arria5-socdk}/qts/sequencer_auto_inst_init.h (100%) copy board/altera/{socfpga => arria5-socdk}/qts/sequencer_defines.h (100%) copy board/altera/{socfpga => arria5-socdk}/socfpga.c (100%) rename board/altera/{socfpga => cyclone5-socdk}/MAINTAINERS (100%) rename board/altera/{socfpga => cyclone5-socdk}/Makefile (100%) rename board/altera/{socfpga => cyclone5-socdk}/qts/iocsr_config.c (100%) rename board/altera/{socfpga => cyclone5-socdk}/qts/iocsr_config.h (100%) rename board/altera/{socfpga => cyclone5-socdk}/qts/pinmux_config.c (100%) rename board/altera/{socfpga => cyclone5-socdk}/qts/pinmux_config.h (100%) rename board/altera/{socfpga => cyclone5-socdk}/qts/pll_config.h (100%) rename board/altera/{socfpga => cyclone5-socdk}/qts/sdram_config.h (100%) rename board/altera/{socfpga => cyclone5-socdk}/qts/sequencer_auto.h (100%) rename board/altera/{socfpga => cyclone5-socdk}/qts/sequencer_auto_ac_init.h (100%) rename board/altera/{socfpga => cyclone5-socdk}/qts/sequencer_auto_inst_init.h (100%) rename board/altera/{socfpga => cyclone5-socdk}/qts/sequencer_defines.h (100%) rename board/altera/{socfpga => cyclone5-socdk}/socfpga.c (100%)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 1a441ff..690e362 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -21,8 +21,8 @@ config TARGET_SOCFPGA_CYCLONE5_SOCDK endchoice
config SYS_BOARD - default "socfpga" if TARGET_SOCFPGA_ARRIA5_SOCDK - default "socfpga" if TARGET_SOCFPGA_CYCLONE5_SOCDK + default "arria5-socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "cyclone5-socdk" if TARGET_SOCFPGA_CYCLONE5_SOCDK
config SYS_VENDOR default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK diff --git a/board/altera/socfpga/MAINTAINERS b/board/altera/arria5-socdk/MAINTAINERS similarity index 100% copy from board/altera/socfpga/MAINTAINERS copy to board/altera/arria5-socdk/MAINTAINERS diff --git a/board/altera/socfpga/Makefile b/board/altera/arria5-socdk/Makefile similarity index 100% copy from board/altera/socfpga/Makefile copy to board/altera/arria5-socdk/Makefile diff --git a/board/altera/socfpga/qts/iocsr_config.c b/board/altera/arria5-socdk/qts/iocsr_config.c similarity index 100% copy from board/altera/socfpga/qts/iocsr_config.c copy to board/altera/arria5-socdk/qts/iocsr_config.c diff --git a/board/altera/socfpga/qts/iocsr_config.h b/board/altera/arria5-socdk/qts/iocsr_config.h similarity index 100% copy from board/altera/socfpga/qts/iocsr_config.h copy to board/altera/arria5-socdk/qts/iocsr_config.h diff --git a/board/altera/socfpga/qts/pinmux_config.c b/board/altera/arria5-socdk/qts/pinmux_config.c similarity index 100% copy from board/altera/socfpga/qts/pinmux_config.c copy to board/altera/arria5-socdk/qts/pinmux_config.c diff --git a/board/altera/socfpga/qts/pinmux_config.h b/board/altera/arria5-socdk/qts/pinmux_config.h similarity index 100% copy from board/altera/socfpga/qts/pinmux_config.h copy to board/altera/arria5-socdk/qts/pinmux_config.h diff --git a/board/altera/socfpga/qts/pll_config.h b/board/altera/arria5-socdk/qts/pll_config.h similarity index 100% copy from board/altera/socfpga/qts/pll_config.h copy to board/altera/arria5-socdk/qts/pll_config.h diff --git a/board/altera/socfpga/qts/sdram_config.h b/board/altera/arria5-socdk/qts/sdram_config.h similarity index 100% copy from board/altera/socfpga/qts/sdram_config.h copy to board/altera/arria5-socdk/qts/sdram_config.h diff --git a/board/altera/socfpga/qts/sequencer_auto.h b/board/altera/arria5-socdk/qts/sequencer_auto.h similarity index 100% copy from board/altera/socfpga/qts/sequencer_auto.h copy to board/altera/arria5-socdk/qts/sequencer_auto.h diff --git a/board/altera/socfpga/qts/sequencer_auto_ac_init.h b/board/altera/arria5-socdk/qts/sequencer_auto_ac_init.h similarity index 100% copy from board/altera/socfpga/qts/sequencer_auto_ac_init.h copy to board/altera/arria5-socdk/qts/sequencer_auto_ac_init.h diff --git a/board/altera/socfpga/qts/sequencer_auto_inst_init.h b/board/altera/arria5-socdk/qts/sequencer_auto_inst_init.h similarity index 100% copy from board/altera/socfpga/qts/sequencer_auto_inst_init.h copy to board/altera/arria5-socdk/qts/sequencer_auto_inst_init.h diff --git a/board/altera/socfpga/qts/sequencer_defines.h b/board/altera/arria5-socdk/qts/sequencer_defines.h similarity index 100% copy from board/altera/socfpga/qts/sequencer_defines.h copy to board/altera/arria5-socdk/qts/sequencer_defines.h diff --git a/board/altera/socfpga/socfpga.c b/board/altera/arria5-socdk/socfpga.c similarity index 100% copy from board/altera/socfpga/socfpga.c copy to board/altera/arria5-socdk/socfpga.c diff --git a/board/altera/socfpga/MAINTAINERS b/board/altera/cyclone5-socdk/MAINTAINERS similarity index 100% rename from board/altera/socfpga/MAINTAINERS rename to board/altera/cyclone5-socdk/MAINTAINERS diff --git a/board/altera/socfpga/Makefile b/board/altera/cyclone5-socdk/Makefile similarity index 100% rename from board/altera/socfpga/Makefile rename to board/altera/cyclone5-socdk/Makefile diff --git a/board/altera/socfpga/qts/iocsr_config.c b/board/altera/cyclone5-socdk/qts/iocsr_config.c similarity index 100% rename from board/altera/socfpga/qts/iocsr_config.c rename to board/altera/cyclone5-socdk/qts/iocsr_config.c diff --git a/board/altera/socfpga/qts/iocsr_config.h b/board/altera/cyclone5-socdk/qts/iocsr_config.h similarity index 100% rename from board/altera/socfpga/qts/iocsr_config.h rename to board/altera/cyclone5-socdk/qts/iocsr_config.h diff --git a/board/altera/socfpga/qts/pinmux_config.c b/board/altera/cyclone5-socdk/qts/pinmux_config.c similarity index 100% rename from board/altera/socfpga/qts/pinmux_config.c rename to board/altera/cyclone5-socdk/qts/pinmux_config.c diff --git a/board/altera/socfpga/qts/pinmux_config.h b/board/altera/cyclone5-socdk/qts/pinmux_config.h similarity index 100% rename from board/altera/socfpga/qts/pinmux_config.h rename to board/altera/cyclone5-socdk/qts/pinmux_config.h diff --git a/board/altera/socfpga/qts/pll_config.h b/board/altera/cyclone5-socdk/qts/pll_config.h similarity index 100% rename from board/altera/socfpga/qts/pll_config.h rename to board/altera/cyclone5-socdk/qts/pll_config.h diff --git a/board/altera/socfpga/qts/sdram_config.h b/board/altera/cyclone5-socdk/qts/sdram_config.h similarity index 100% rename from board/altera/socfpga/qts/sdram_config.h rename to board/altera/cyclone5-socdk/qts/sdram_config.h diff --git a/board/altera/socfpga/qts/sequencer_auto.h b/board/altera/cyclone5-socdk/qts/sequencer_auto.h similarity index 100% rename from board/altera/socfpga/qts/sequencer_auto.h rename to board/altera/cyclone5-socdk/qts/sequencer_auto.h diff --git a/board/altera/socfpga/qts/sequencer_auto_ac_init.h b/board/altera/cyclone5-socdk/qts/sequencer_auto_ac_init.h similarity index 100% rename from board/altera/socfpga/qts/sequencer_auto_ac_init.h rename to board/altera/cyclone5-socdk/qts/sequencer_auto_ac_init.h diff --git a/board/altera/socfpga/qts/sequencer_auto_inst_init.h b/board/altera/cyclone5-socdk/qts/sequencer_auto_inst_init.h similarity index 100% rename from board/altera/socfpga/qts/sequencer_auto_inst_init.h rename to board/altera/cyclone5-socdk/qts/sequencer_auto_inst_init.h diff --git a/board/altera/socfpga/qts/sequencer_defines.h b/board/altera/cyclone5-socdk/qts/sequencer_defines.h similarity index 100% rename from board/altera/socfpga/qts/sequencer_defines.h rename to board/altera/cyclone5-socdk/qts/sequencer_defines.h diff --git a/board/altera/socfpga/socfpga.c b/board/altera/cyclone5-socdk/socfpga.c similarity index 100% rename from board/altera/socfpga/socfpga.c rename to board/altera/cyclone5-socdk/socfpga.c
Just remove the CycloneV specific parts from the ArriaV SoCDK board and they are no longer needed now.
Signed-off-by: Marek Vasut marex@denx.de --- board/altera/arria5-socdk/qts/iocsr_config.c | 652 --------------------- board/altera/arria5-socdk/qts/iocsr_config.h | 9 - board/altera/arria5-socdk/qts/pinmux_config.c | 215 ------- board/altera/arria5-socdk/qts/sdram_config.h | 14 - board/altera/arria5-socdk/qts/sequencer_auto.h | 20 - .../arria5-socdk/qts/sequencer_auto_ac_init.h | 39 -- .../arria5-socdk/qts/sequencer_auto_inst_init.h | 133 ----- board/altera/arria5-socdk/qts/sequencer_defines.h | 35 -- 8 files changed, 1117 deletions(-)
diff --git a/board/altera/arria5-socdk/qts/iocsr_config.c b/board/altera/arria5-socdk/qts/iocsr_config.c index 3b202b5..f588eda 100644 --- a/board/altera/arria5-socdk/qts/iocsr_config.c +++ b/board/altera/arria5-socdk/qts/iocsr_config.c @@ -8,657 +8,6 @@
#include "iocsr_config.h"
-#ifdef CONFIG_TARGET_SOCFPGA_CYCLONE5 -const unsigned long iocsr_scan_chain0_table[(( - CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH / 32) + 1)] = { - 0x00000000, - 0x00000000, - 0x0FF00000, - 0xC0000000, - 0x0000003F, - 0x00008000, - 0x00020080, - 0x08020000, - 0x08000000, - 0x00018020, - 0x00000000, - 0x00004000, - 0x00010040, - 0x04010000, - 0x04000000, - 0x00000010, - 0x00004010, - 0x00002000, - 0x00020000, - 0x02008000, - 0x02000000, - 0x00000008, - 0x00002008, - 0x00001000, -}; - -const unsigned long iocsr_scan_chain1_table[(( - CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH / 32) + 1)] = { - 0x000C0300, - 0x10040000, - 0x100000C0, - 0x00000040, - 0x00010040, - 0x00008000, - 0x00080000, - 0x18060000, - 0x18000000, - 0x00000060, - 0x00018060, - 0x00004000, - 0x00010040, - 0x10000000, - 0x04000000, - 0x00000010, - 0x00004010, - 0x00002000, - 0x06008020, - 0x02008000, - 0x01FE0000, - 0xF8000000, - 0x00000007, - 0x00001000, - 0x00004010, - 0x01004000, - 0x01000000, - 0x00003004, - 0x00001004, - 0x00000800, - 0x00000000, - 0x00000000, - 0x00800000, - 0x00000002, - 0x00002000, - 0x00000400, - 0x00000000, - 0x00401000, - 0x00000003, - 0x00000000, - 0x00000000, - 0x00000200, - 0x00600802, - 0x00000000, - 0x80200000, - 0x80000600, - 0x00000200, - 0x00000100, - 0x00300401, - 0xC0100400, - 0x40100000, - 0x40000300, - 0x000C0100, - 0x00000080, -}; - -const unsigned long iocsr_scan_chain2_table[(( - CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH / 32) + 1)] = { - 0x80040100, - 0x00000000, - 0x0FF00000, - 0x00000000, - 0x0C010040, - 0x00008000, - 0x18020080, - 0x00000000, - 0x08000000, - 0x00040020, - 0x06018060, - 0x00004000, - 0x0C010040, - 0x04010000, - 0x00000030, - 0x00000000, - 0x03004010, - 0x00002000, - 0x06008020, - 0x02008000, - 0x02000018, - 0x00006008, - 0x01802008, - 0x00001000, - 0x03004010, - 0x01004000, - 0x0100000C, - 0x00003004, - 0x00C01004, - 0x00000800, -}; - -const unsigned long iocsr_scan_chain3_table[(( - CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH / 32) + 1)] = { - 0x2C420D80, - 0x082000FF, - 0x0A804001, - 0x07900000, - 0x08020000, - 0x00100000, - 0x0A800000, - 0x07900000, - 0x08020000, - 0x00100000, - 0xC8800000, - 0x00003001, - 0x00C00722, - 0x00000000, - 0x00000021, - 0x82000004, - 0x05400000, - 0x03C80000, - 0x04010000, - 0x00080000, - 0x05400000, - 0x03C80000, - 0x05400000, - 0x03C80000, - 0xE4400000, - 0x00001800, - 0x00600391, - 0x800E4400, - 0x00000001, - 0x40000002, - 0x02A00000, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x72200000, - 0x80000C00, - 0x003001C8, - 0xC0072200, - 0x1C880000, - 0x20000300, - 0x00040000, - 0x50670000, - 0x00000070, - 0x24590000, - 0x00001000, - 0xA0000034, - 0x0D000001, - 0x906808A2, - 0xA2834024, - 0x05141A00, - 0x808A20D0, - 0x34024906, - 0x01A00A28, - 0xA20D0000, - 0x24906808, - 0x00A28340, - 0xD000001A, - 0x06808A20, - 0x10040000, - 0x00200000, - 0x10040000, - 0x00200000, - 0x15000000, - 0x0F200000, - 0x15000000, - 0x0F200000, - 0x01FE0000, - 0x00000000, - 0x01800E44, - 0x00391000, - 0x007F8006, - 0x00000000, - 0x0A800001, - 0x07900000, - 0x0A800000, - 0x07900000, - 0x0A800000, - 0x07900000, - 0x08020000, - 0x00100000, - 0xC8800000, - 0x00003001, - 0x00C00722, - 0x00000FF0, - 0x72200000, - 0x80000C00, - 0x05400000, - 0x02480000, - 0x04000000, - 0x00080000, - 0x05400000, - 0x03C80000, - 0x05400000, - 0x03C80000, - 0x6A1C0000, - 0x00001800, - 0x00600391, - 0x800E4400, - 0x1A870001, - 0x40000600, - 0x02A00040, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x72200000, - 0x80000C00, - 0x003001C8, - 0xC0072200, - 0x1C880000, - 0x20000300, - 0x00040000, - 0x50670000, - 0x00000070, - 0x24590000, - 0x00001000, - 0xA0000034, - 0x0D000001, - 0x906808A2, - 0xA2834024, - 0x05141A00, - 0x808A20D0, - 0x34024906, - 0x01A00040, - 0xA20D0002, - 0x24906808, - 0x00A28340, - 0xD005141A, - 0x06808A20, - 0x10040000, - 0x00200000, - 0x10040000, - 0x00200000, - 0x15000000, - 0x0F200000, - 0x15000000, - 0x0F200000, - 0x01FE0000, - 0x00000000, - 0x01800E44, - 0x00391000, - 0x007F8006, - 0x00000000, - 0x99300001, - 0x34343400, - 0xAA0D4000, - 0x01C3A810, - 0xAA0D4000, - 0x01C3A808, - 0xAA0D4000, - 0x01C3A810, - 0x00040100, - 0x00000800, - 0x00000000, - 0x00001208, - 0x00482000, - 0x000001C1, - 0x00000000, - 0x00410482, - 0x0006A000, - 0x0001B400, - 0x00020000, - 0x00000400, - 0x0002A000, - 0x0001E400, - 0x5506A000, - 0x00E1D404, - 0x00000000, - 0xC880090C, - 0x00003001, - 0x90400000, - 0x00000000, - 0x2020C243, - 0x2A835000, - 0x0070EA04, - 0x2A835000, - 0x0070EA02, - 0x2A835000, - 0x0070EA04, - 0x00010040, - 0x00000200, - 0x00000000, - 0x00000482, - 0x00120800, - 0x00002000, - 0x80000000, - 0x00104120, - 0x00000200, - 0xAC255F80, - 0xF1C71C71, - 0x14F3690D, - 0x1A041414, - 0x00D00000, - 0x14864000, - 0x59647A05, - 0xBA28A3D8, - 0xF511451E, - 0x0341D348, - 0x821A0000, - 0x0000D000, - 0x04510680, - 0xD859647A, - 0x1EBA28A3, - 0x48F51145, - 0x000341D3, - 0x00080200, - 0x00001000, - 0x00080200, - 0x00001000, - 0x000A8000, - 0x00075000, - 0x541A8000, - 0x03875011, - 0x10000000, - 0x00000000, - 0x0080C000, - 0x41000000, - 0x00003FC2, - 0x00820000, - 0xAA0D4000, - 0x01C3A810, - 0xAA0D4000, - 0x01C3A808, - 0xAA0D4000, - 0x01C3A810, - 0x00040100, - 0x00000800, - 0x00000000, - 0x00001208, - 0x00482000, - 0x00008000, - 0x00000000, - 0x00410482, - 0x0006A000, - 0x0001B400, - 0x00020000, - 0x00000400, - 0x00020080, - 0x00000400, - 0x5506A000, - 0x00E1D404, - 0x00000000, - 0x0000090C, - 0x00000010, - 0x90400000, - 0x00000000, - 0x2020C243, - 0x2A835000, - 0x0070EA04, - 0x2A835000, - 0x0070EA02, - 0x2A835000, - 0x0070EA04, - 0x00015000, - 0x0000F200, - 0x00000000, - 0x00000482, - 0x00120800, - 0x00600391, - 0x80000000, - 0x00104120, - 0x00000200, - 0xAC255F80, - 0xF1C71C71, - 0x14F3690D, - 0x1A041414, - 0x00D00000, - 0x14864000, - 0x59647A05, - 0xBA28A3D8, - 0xF511451E, - 0x8341D348, - 0x821A0124, - 0x0000D000, - 0x00000680, - 0xD859647A, - 0x1EBA28A3, - 0x48F51145, - 0x000341D3, - 0x00080200, - 0x00001000, - 0x00080200, - 0x00001000, - 0x000A8000, - 0x00075000, - 0x541A8000, - 0x03875011, - 0x10000000, - 0x00000000, - 0x0080C000, - 0x41000000, - 0x04000002, - 0x00820000, - 0xAA0D4000, - 0x01C3A810, - 0xAA0D4000, - 0x01C3A808, - 0xAA0D4000, - 0x01C3A810, - 0x00040100, - 0x00000800, - 0x00000000, - 0x00001208, - 0x00482000, - 0x00008000, - 0x00000000, - 0x00410482, - 0x0006A000, - 0x0001B400, - 0x00020000, - 0x00000400, - 0x0002A000, - 0x0001E400, - 0x5506A000, - 0x00E1D404, - 0x00000000, - 0xC880090C, - 0x00003001, - 0x90400000, - 0x00000000, - 0x2020C243, - 0x2A835000, - 0x0070EA04, - 0x2A835000, - 0x0070EA02, - 0x2A835000, - 0x0070EA04, - 0x00010040, - 0x00000200, - 0x00000000, - 0x00000482, - 0x00120800, - 0x00002000, - 0x80000000, - 0x00104120, - 0x00000200, - 0xAC255F80, - 0xF1C71C71, - 0x14F3690D, - 0x1A041414, - 0x00D00000, - 0x14864000, - 0x59647A05, - 0xBA28A3D8, - 0xF511451E, - 0x0341D348, - 0x821A0000, - 0x0000D000, - 0x00000680, - 0xD859647A, - 0x1EBA28A3, - 0x48F51145, - 0x000341D3, - 0x00080200, - 0x00001000, - 0x00080200, - 0x00001000, - 0x000A8000, - 0x00075000, - 0x541A8000, - 0x03875011, - 0x10000000, - 0x00000000, - 0x0080C000, - 0x41000000, - 0x04000002, - 0x00820000, - 0xAA0D4000, - 0x01C3A810, - 0xAA0D4000, - 0x01C3A808, - 0xAA0D4000, - 0x01C3A810, - 0x00040100, - 0x00000800, - 0x00000000, - 0x00001208, - 0x00482000, - 0x00008000, - 0x00000000, - 0x00410482, - 0x0006A000, - 0x0001B400, - 0x00020000, - 0x00000400, - 0x00020080, - 0x00000400, - 0x5506A000, - 0x00E1D404, - 0x00000000, - 0x0000090C, - 0x00000010, - 0x90400000, - 0x00000000, - 0x2020C243, - 0x2A835000, - 0x0070EA04, - 0x2A835000, - 0x0070EA02, - 0x2A835000, - 0x0070EA04, - 0x00010040, - 0x00000200, - 0x00000000, - 0x00000482, - 0x40120800, - 0x00000070, - 0x80000000, - 0x00104120, - 0x00000200, - 0xAC255F80, - 0xF1C71C71, - 0x14F1690D, - 0x1A041414, - 0x00D00000, - 0x14864000, - 0x59647A05, - 0xBA28A3D8, - 0xF511451E, - 0x0341D348, - 0x821A0000, - 0x0000D000, - 0x00000680, - 0xD859647A, - 0x1EBA28A3, - 0x48F51145, - 0x000341D3, - 0x00080200, - 0x00001000, - 0x00080200, - 0x00001000, - 0x000A8000, - 0x00075000, - 0x541A8000, - 0x03875011, - 0x10000000, - 0x00000000, - 0x0080C000, - 0x41000000, - 0x04000002, - 0x00820000, - 0x00489800, - 0x001A1A1A, - 0x085506A0, - 0x0000E1D4, - 0x045506A0, - 0x0000E1D4, - 0x085506A0, - 0x8000E1D4, - 0x00000200, - 0x00000004, - 0x04000000, - 0x00000009, - 0x00002410, - 0x00000040, - 0x41000000, - 0x00002082, - 0x00000350, - 0x000000DA, - 0x00000100, - 0x40000002, - 0x00000100, - 0x00000002, - 0x022A8350, - 0x000070EA, - 0x86000000, - 0x08000004, - 0x00000000, - 0x00482000, - 0x21800000, - 0x00101061, - 0x021541A8, - 0x00003875, - 0x011541A8, - 0x00003875, - 0x021541A8, - 0x20003875, - 0x00000080, - 0x00000001, - 0x41000000, - 0x00000002, - 0x00FF0904, - 0x00000000, - 0x90400000, - 0x00000820, - 0xC0000001, - 0x38D612AF, - 0x86F8E38E, - 0x0A0A78B4, - 0x000D020A, - 0x00006800, - 0x028A4320, - 0xEC2CB23D, - 0x8F5D1451, - 0xA47A88A2, - 0x0001A0E9, - 0x00410D00, - 0x40000068, - 0x3D000003, - 0x51EC2CB2, - 0xA28F5D14, - 0xE9A47A88, - 0x000001A0, - 0x00000401, - 0x00000008, - 0x00000401, - 0x00000008, - 0x00000540, - 0x000003A8, - 0x08AA0D40, - 0x8001C3A8, - 0x0000007F, - 0x00000000, - 0x00004060, - 0xE1208000, - 0x0000001F, - 0x00004100, -}; -#endif /* CONFIG_TARGET_SOCFPGA_CYCLONE5 */ - -#ifdef CONFIG_TARGET_SOCFPGA_ARRIA5 const unsigned long iocsr_scan_chain0_table[(( CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH / 32) + 1)] = { 0x00000000, @@ -1342,4 +691,3 @@ const unsigned long iocsr_scan_chain3_table[(( 0x0000001F, 0x00004100, }; -#endif /* CONFIG_TARGET_SOCFPGA_ARRIA5 */ diff --git a/board/altera/arria5-socdk/qts/iocsr_config.h b/board/altera/arria5-socdk/qts/iocsr_config.h index d1c9b0d..857f19c 100644 --- a/board/altera/arria5-socdk/qts/iocsr_config.h +++ b/board/altera/arria5-socdk/qts/iocsr_config.h @@ -9,18 +9,9 @@ #ifndef _PRELOADER_IOCSR_CONFIG_H_ #define _PRELOADER_IOCSR_CONFIG_H_
-#ifdef CONFIG_TARGET_SOCFPGA_CYCLONE5 -#define CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH (764) -#define CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH (1719) -#define CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH (955) -#define CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH (16766) -#endif - -#ifdef CONFIG_TARGET_SOCFPGA_ARRIA5 #define CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH (1337) #define CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH (1719) #define CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH (1528) #define CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH (16766) -#endif
#endif /*_PRELOADER_IOCSR_CONFIG_H_*/ diff --git a/board/altera/arria5-socdk/qts/pinmux_config.c b/board/altera/arria5-socdk/qts/pinmux_config.c index 7e7a184..bf987f9 100644 --- a/board/altera/arria5-socdk/qts/pinmux_config.c +++ b/board/altera/arria5-socdk/qts/pinmux_config.c @@ -2,220 +2,6 @@
#include "pinmux_config.h"
-#ifdef CONFIG_TARGET_SOCFPGA_CYCLONE5 -/* pin mux configuration data */ -unsigned long sys_mgr_init_table[CONFIG_HPS_PINMUX_NUM] = { - 3, /* EMACIO0 */ - 3, /* EMACIO1 */ - 3, /* EMACIO2 */ - 3, /* EMACIO3 */ - 3, /* EMACIO4 */ - 3, /* EMACIO5 */ - 3, /* EMACIO6 */ - 3, /* EMACIO7 */ - 3, /* EMACIO8 */ - 3, /* EMACIO9 */ - 3, /* EMACIO10 */ - 3, /* EMACIO11 */ - 3, /* EMACIO12 */ - 3, /* EMACIO13 */ - 0, /* EMACIO14 */ - 0, /* EMACIO15 */ - 0, /* EMACIO16 */ - 0, /* EMACIO17 */ - 0, /* EMACIO18 */ - 0, /* EMACIO19 */ - 3, /* FLASHIO0 */ - 0, /* FLASHIO1 */ - 3, /* FLASHIO2 */ - 3, /* FLASHIO3 */ - 3, /* FLASHIO4 */ - 3, /* FLASHIO5 */ - 3, /* FLASHIO6 */ - 3, /* FLASHIO7 */ - 0, /* FLASHIO8 */ - 3, /* FLASHIO9 */ - 3, /* FLASHIO10 */ - 3, /* FLASHIO11 */ - 0, /* GENERALIO0 */ - 1, /* GENERALIO1 */ - 1, /* GENERALIO2 */ - 0, /* GENERALIO3 */ - 0, /* GENERALIO4 */ - 1, /* GENERALIO5 */ - 1, /* GENERALIO6 */ - 1, /* GENERALIO7 */ - 1, /* GENERALIO8 */ - 0, /* GENERALIO9 */ - 0, /* GENERALIO10 */ - 0, /* GENERALIO11 */ - 0, /* GENERALIO12 */ - 2, /* GENERALIO13 */ - 2, /* GENERALIO14 */ - 0, /* GENERALIO15 */ - 0, /* GENERALIO16 */ - 2, /* GENERALIO17 */ - 2, /* GENERALIO18 */ - 0, /* GENERALIO19 */ - 0, /* GENERALIO20 */ - 0, /* GENERALIO21 */ - 0, /* GENERALIO22 */ - 0, /* GENERALIO23 */ - 0, /* GENERALIO24 */ - 0, /* GENERALIO25 */ - 0, /* GENERALIO26 */ - 0, /* GENERALIO27 */ - 0, /* GENERALIO28 */ - 0, /* GENERALIO29 */ - 0, /* GENERALIO30 */ - 0, /* GENERALIO31 */ - 0, /* MIXED1IO0 */ - 1, /* MIXED1IO1 */ - 1, /* MIXED1IO2 */ - 1, /* MIXED1IO3 */ - 1, /* MIXED1IO4 */ - 0, /* MIXED1IO5 */ - 0, /* MIXED1IO6 */ - 0, /* MIXED1IO7 */ - 1, /* MIXED1IO8 */ - 1, /* MIXED1IO9 */ - 1, /* MIXED1IO10 */ - 1, /* MIXED1IO11 */ - 0, /* MIXED1IO12 */ - 0, /* MIXED1IO13 */ - 0, /* MIXED1IO14 */ - 1, /* MIXED1IO15 */ - 1, /* MIXED1IO16 */ - 1, /* MIXED1IO17 */ - 1, /* MIXED1IO18 */ - 0, /* MIXED1IO19 */ - 0, /* MIXED1IO20 */ - 0, /* MIXED1IO21 */ - 0, /* MIXED2IO0 */ - 0, /* MIXED2IO1 */ - 0, /* MIXED2IO2 */ - 0, /* MIXED2IO3 */ - 0, /* MIXED2IO4 */ - 0, /* MIXED2IO5 */ - 0, /* MIXED2IO6 */ - 0, /* MIXED2IO7 */ - 0, /* GPLINMUX48 */ - 0, /* GPLINMUX49 */ - 0, /* GPLINMUX50 */ - 0, /* GPLINMUX51 */ - 0, /* GPLINMUX52 */ - 0, /* GPLINMUX53 */ - 0, /* GPLINMUX54 */ - 0, /* GPLINMUX55 */ - 0, /* GPLINMUX56 */ - 0, /* GPLINMUX57 */ - 0, /* GPLINMUX58 */ - 0, /* GPLINMUX59 */ - 0, /* GPLINMUX60 */ - 0, /* GPLINMUX61 */ - 0, /* GPLINMUX62 */ - 0, /* GPLINMUX63 */ - 0, /* GPLINMUX64 */ - 0, /* GPLINMUX65 */ - 0, /* GPLINMUX66 */ - 0, /* GPLINMUX67 */ - 0, /* GPLINMUX68 */ - 0, /* GPLINMUX69 */ - 0, /* GPLINMUX70 */ - 1, /* GPLMUX0 */ - 1, /* GPLMUX1 */ - 1, /* GPLMUX2 */ - 1, /* GPLMUX3 */ - 1, /* GPLMUX4 */ - 1, /* GPLMUX5 */ - 1, /* GPLMUX6 */ - 1, /* GPLMUX7 */ - 1, /* GPLMUX8 */ - 1, /* GPLMUX9 */ - 1, /* GPLMUX10 */ - 1, /* GPLMUX11 */ - 1, /* GPLMUX12 */ - 1, /* GPLMUX13 */ - 1, /* GPLMUX14 */ - 1, /* GPLMUX15 */ - 1, /* GPLMUX16 */ - 1, /* GPLMUX17 */ - 1, /* GPLMUX18 */ - 1, /* GPLMUX19 */ - 1, /* GPLMUX20 */ - 1, /* GPLMUX21 */ - 1, /* GPLMUX22 */ - 1, /* GPLMUX23 */ - 1, /* GPLMUX24 */ - 1, /* GPLMUX25 */ - 1, /* GPLMUX26 */ - 1, /* GPLMUX27 */ - 1, /* GPLMUX28 */ - 1, /* GPLMUX29 */ - 1, /* GPLMUX30 */ - 1, /* GPLMUX31 */ - 1, /* GPLMUX32 */ - 1, /* GPLMUX33 */ - 1, /* GPLMUX34 */ - 1, /* GPLMUX35 */ - 1, /* GPLMUX36 */ - 1, /* GPLMUX37 */ - 1, /* GPLMUX38 */ - 1, /* GPLMUX39 */ - 1, /* GPLMUX40 */ - 1, /* GPLMUX41 */ - 1, /* GPLMUX42 */ - 1, /* GPLMUX43 */ - 1, /* GPLMUX44 */ - 1, /* GPLMUX45 */ - 1, /* GPLMUX46 */ - 1, /* GPLMUX47 */ - 1, /* GPLMUX48 */ - 1, /* GPLMUX49 */ - 1, /* GPLMUX50 */ - 1, /* GPLMUX51 */ - 1, /* GPLMUX52 */ - 1, /* GPLMUX53 */ - 1, /* GPLMUX54 */ - 1, /* GPLMUX55 */ - 1, /* GPLMUX56 */ - 1, /* GPLMUX57 */ - 1, /* GPLMUX58 */ - 1, /* GPLMUX59 */ - 1, /* GPLMUX60 */ - 1, /* GPLMUX61 */ - 1, /* GPLMUX62 */ - 1, /* GPLMUX63 */ - 1, /* GPLMUX64 */ - 1, /* GPLMUX65 */ - 1, /* GPLMUX66 */ - 1, /* GPLMUX67 */ - 1, /* GPLMUX68 */ - 1, /* GPLMUX69 */ - 1, /* GPLMUX70 */ - 0, /* NANDUSEFPGA */ - 0, /* UART0USEFPGA */ - 0, /* RGMII1USEFPGA */ - 0, /* SPIS0USEFPGA */ - 0, /* CAN0USEFPGA */ - 0, /* I2C0USEFPGA */ - 0, /* SDMMCUSEFPGA */ - 0, /* QSPIUSEFPGA */ - 0, /* SPIS1USEFPGA */ - 0, /* RGMII0USEFPGA */ - 0, /* UART1USEFPGA */ - 0, /* CAN1USEFPGA */ - 0, /* USB1USEFPGA */ - 0, /* I2C3USEFPGA */ - 0, /* I2C2USEFPGA */ - 0, /* I2C1USEFPGA */ - 0, /* SPIM1USEFPGA */ - 0, /* USB0USEFPGA */ - 0 /* SPIM0USEFPGA */ -}; -#endif /* CONFIG_TARGET_SOCFPGA_CYCLONE5 */ - -#ifdef CONFIG_TARGET_SOCFPGA_ARRIA5 /* pin mux configuration data */ unsigned long sys_mgr_init_table[CONFIG_HPS_PINMUX_NUM] = { 0, /* EMACIO0 */ @@ -426,4 +212,3 @@ unsigned long sys_mgr_init_table[CONFIG_HPS_PINMUX_NUM] = { 0, /* USB0USEFPGA */ 0 /* SPIM0USEFPGA */ }; -#endif /* CONFIG_TARGET_SOCFPGA_ARRIA5 */ diff --git a/board/altera/arria5-socdk/qts/sdram_config.h b/board/altera/arria5-socdk/qts/sdram_config.h index f6d51ca..2e26ae5 100644 --- a/board/altera/arria5-socdk/qts/sdram_config.h +++ b/board/altera/arria5-socdk/qts/sdram_config.h @@ -20,7 +20,6 @@ #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCWL 6 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_AL 0 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCL 7 -#ifdef CONFIG_SOCFPGA_ARRIA5 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRRD 4 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TFAW 19 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRFC 139 @@ -32,19 +31,6 @@ #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRTP 4 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRAS 19 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRC 26 -#else -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRRD 3 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TFAW 14 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRFC 104 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TREFI 3120 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRCD 6 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRP 6 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWR 6 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWTR 4 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRTP 3 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRAS 14 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRC 20 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TMRD 4 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TCCD 4 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_SELFRFSHEXIT 512 diff --git a/board/altera/arria5-socdk/qts/sequencer_auto.h b/board/altera/arria5-socdk/qts/sequencer_auto.h index 0c5d83b..df1c224 100644 --- a/board/altera/arria5-socdk/qts/sequencer_auto.h +++ b/board/altera/arria5-socdk/qts/sequencer_auto.h @@ -19,29 +19,14 @@ #define RW_MGR_MRS2 0x04 #define RW_MGR_LFSR_WR_RD_DM_BANK_0_WL_1 0x34 #define RW_MGR_MRS1 0x03 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ #define RW_MGR_IDLE_LOOP1 0x7A -#else -#define RW_MGR_IDLE_LOOP1 0x7C -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define RW_MGR_GUARANTEED_WRITE_WAIT2 0x18 #define RW_MGR_MRS3 0x05 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ #define RW_MGR_IDLE_LOOP2 0x79 -#else -#define RW_MGR_IDLE_LOOP2 0x7B -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define RW_MGR_GUARANTEED_WRITE_WAIT1 0x1E #define RW_MGR_LFSR_WR_RD_BANK_0_DATA 0x24 #define RW_MGR_GUARANTEED_WRITE_WAIT3 0x1C -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ #define RW_MGR_RDIMM_CMD 0x78 -#else -#define RW_MGR_RDIMM_CMD 0x7A -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define RW_MGR_LFSR_WR_RD_DM_BANK_0_NOP 0x36 #define RW_MGR_GUARANTEED_WRITE_WAIT0 0x1A #define RW_MGR_LFSR_WR_RD_DM_BANK_0_DATA 0x38 @@ -54,12 +39,7 @@ #define RW_MGR_GUARANTEED_WRITE 0x17 #define RW_MGR_PRECHARGE_ALL 0x12 #define RW_MGR_INIT_RESET_1_CKE_0_inloop_1 0x74 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ #define RW_MGR_SGLE_READ 0x7C -#else -#define RW_MGR_SGLE_READ 0x7E -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define RW_MGR_MRS0_USER_MIRR 0x0C #define RW_MGR_RETURN 0x01 #define RW_MGR_LFSR_WR_RD_DM_BANK_0 0x35 diff --git a/board/altera/arria5-socdk/qts/sequencer_auto_ac_init.h b/board/altera/arria5-socdk/qts/sequencer_auto_ac_init.h index c46421b..1c9d8f3 100644 --- a/board/altera/arria5-socdk/qts/sequencer_auto_ac_init.h +++ b/board/altera/arria5-socdk/qts/sequencer_auto_ac_init.h @@ -5,7 +5,6 @@ */
const uint32_t ac_rom_init[] = { -#ifdef CONFIG_SOCFPGA_ARRIA5 /* The if..else... is not required if generated by tools */ 0x20700000, 0x20780000, @@ -43,42 +42,4 @@ const uint32_t ac_rom_init[] = { 0x33780000, 0x10580008, 0x10780000 -#else - 0x20700000, - 0x20780000, - 0x10080431, - 0x10080530, - 0x10090004, - 0x100a0008, - 0x100b0000, - 0x10380400, - 0x10080449, - 0x100804c8, - 0x100a0004, - 0x10090010, - 0x100b0000, - 0x30780000, - 0x38780000, - 0x30780000, - 0x10680000, - 0x106b0000, - 0x10280400, - 0x10480000, - 0x1c980000, - 0x1c9b0000, - 0x1c980008, - 0x1c9b0008, - 0x38f80000, - 0x3cf80000, - 0x38780000, - 0x18180000, - 0x18980000, - 0x13580000, - 0x135b0000, - 0x13580008, - 0x135b0008, - 0x33780000, - 0x10580008, - 0x10780000 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ }; diff --git a/board/altera/arria5-socdk/qts/sequencer_auto_inst_init.h b/board/altera/arria5-socdk/qts/sequencer_auto_inst_init.h index ad0395b..c8dbeab 100644 --- a/board/altera/arria5-socdk/qts/sequencer_auto_inst_init.h +++ b/board/altera/arria5-socdk/qts/sequencer_auto_inst_init.h @@ -4,7 +4,6 @@ * SPDX-License-Identifier: BSD-3-Clause */
-#ifdef CONFIG_SOCFPGA_ARRIA5 /* The if..else... is not required if generated by tools */ const u32 inst_rom_init[] = { 0x80000, @@ -134,135 +133,3 @@ const u32 inst_rom_init[] = { 0x40f08, 0x80680 }; -#else -const u32 inst_rom_init[] = { - 0x80000, - 0x80680, - 0x8180, - 0x8200, - 0x8280, - 0x8300, - 0x8380, - 0x8100, - 0x8480, - 0x8500, - 0x8580, - 0x8600, - 0x8400, - 0x800, - 0x8680, - 0x880, - 0xa680, - 0x80680, - 0x900, - 0x80680, - 0x980, - 0x8680, - 0x80680, - 0xb68, - 0xcce8, - 0xae8, - 0x8ce8, - 0xb88, - 0xec88, - 0xa08, - 0xac88, - 0x80680, - 0xce00, - 0xcd80, - 0xe700, - 0xc00, - 0x20ce0, - 0x20ce0, - 0x20ce0, - 0x20ce0, - 0xd00, - 0x680, - 0x680, - 0x680, - 0x680, - 0x60e80, - 0x61080, - 0x61080, - 0x61080, - 0xa680, - 0x8680, - 0x80680, - 0xce00, - 0xcd80, - 0xe700, - 0xc00, - 0x30ce0, - 0x30ce0, - 0x30ce0, - 0x30ce0, - 0xd00, - 0x680, - 0x680, - 0x680, - 0x680, - 0x70e80, - 0x71080, - 0x71080, - 0x71080, - 0xa680, - 0x8680, - 0x80680, - 0x1158, - 0x6d8, - 0x80680, - 0x1168, - 0x7e8, - 0x7e8, - 0x87e8, - 0x40fe8, - 0x410e8, - 0x410e8, - 0x410e8, - 0x1168, - 0x7e8, - 0x7e8, - 0xa7e8, - 0x80680, - 0x40e88, - 0x41088, - 0x41088, - 0x41088, - 0x40f68, - 0x410e8, - 0x410e8, - 0x410e8, - 0xa680, - 0x40fe8, - 0x410e8, - 0x410e8, - 0x410e8, - 0x41008, - 0x41088, - 0x41088, - 0x41088, - 0x1100, - 0xc680, - 0x8680, - 0xe680, - 0x80680, - 0x0, - 0x0, - 0xa000, - 0x8000, - 0x80000, - 0x80, - 0x80, - 0x80, - 0x80, - 0xa080, - 0x8080, - 0x80080, - 0x9180, - 0x8680, - 0xa680, - 0x80680, - 0x40f08, - 0x80680 -}; -#endif /* CONFIG_SOCFPGA_ARRIA5 */ diff --git a/board/altera/arria5-socdk/qts/sequencer_defines.h b/board/altera/arria5-socdk/qts/sequencer_defines.h index bfe5b27..6e41175 100644 --- a/board/altera/arria5-socdk/qts/sequencer_defines.h +++ b/board/altera/arria5-socdk/qts/sequencer_defines.h @@ -12,39 +12,20 @@ #define AC_ROM_MR2_MIRR 0000000010000 #define AC_ROM_MR3_MIRR 0000000000000 #define AC_ROM_MR0_CALIB -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ #define AC_ROM_MR0_DLL_RESET_MIRR 0100011001000 #define AC_ROM_MR0_DLL_RESET 0100100110000 #define AC_ROM_MR0_MIRR 0100001001001 #define AC_ROM_MR0 0100000110001 -#else -#define AC_ROM_MR0_DLL_RESET_MIRR 0010011001000 -#define AC_ROM_MR0_DLL_RESET 0010100110000 -#define AC_ROM_MR0_MIRR 0010001001001 -#define AC_ROM_MR0 0010000110001 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define AC_ROM_MR1 0000000000100 #define AC_ROM_MR2 0000000001000 #define AC_ROM_MR3 0000000000000 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ #define AFI_CLK_FREQ 534 -#else -#define AFI_CLK_FREQ 401 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define AFI_RATE_RATIO 1 #define AVL_CLK_FREQ 67 #define BFM_MODE 0 #define BURST2 0 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ #define CALIB_LFIFO_OFFSET 8 #define CALIB_VFIFO_OFFSET 6 -#else -#define CALIB_LFIFO_OFFSET 7 -#define CALIB_VFIFO_OFFSET 5 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define ENABLE_EXPORT_SEQ_DEBUG_BRIDGE 0 #define ENABLE_SUPER_QUICK_CALIBRATION 0 #define GUARANTEED_READ_BRINGUP_TEST 0 @@ -54,23 +35,12 @@ #define HR_DDIO_OUT_HAS_THREE_REGS 0 #define IO_DELAY_PER_DCHAIN_TAP 25 #define IO_DELAY_PER_DQS_EN_DCHAIN_TAP 25 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ #define IO_DELAY_PER_OPA_TAP 234 -#else -#define IO_DELAY_PER_OPA_TAP 312 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define IO_DLL_CHAIN_LENGTH 8 #define IO_DM_OUT_RESERVE 0 #define IO_DQDQS_OUT_PHASE_MAX 0 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ #define IO_DQS_EN_DELAY_MAX 15 #define IO_DQS_EN_DELAY_OFFSET 16 -#else -#define IO_DQS_EN_DELAY_MAX 31 -#define IO_DQS_EN_DELAY_OFFSET 0 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define IO_DQS_EN_PHASE_MAX 7 #define IO_DQS_IN_DELAY_MAX 31 #define IO_DQS_IN_RESERVE 4 @@ -84,12 +54,7 @@ #define MAX_LATENCY_COUNT_WIDTH 5 #define MEM_ADDR_WIDTH 13 #define READ_VALID_FIFO_SIZE 16 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ #define REG_FILE_INIT_SEQ_SIGNATURE 0x5555048c -#else -#define REG_FILE_INIT_SEQ_SIGNATURE 0x55550483 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define RW_MGR_MEM_ADDRESS_MIRRORING 0 #define RW_MGR_MEM_ADDRESS_WIDTH 15 #define RW_MGR_MEM_BANK_WIDTH 3
Just remove the ArriaV specific parts from the CycloneV SoCDK board and they are no longer needed now.
Signed-off-by: Marek Vasut marex@denx.de --- board/altera/cyclone5-socdk/qts/iocsr_config.c | 688 --------------------- board/altera/cyclone5-socdk/qts/iocsr_config.h | 9 - board/altera/cyclone5-socdk/qts/pinmux_config.c | 215 ------- board/altera/cyclone5-socdk/qts/sdram_config.h | 14 - board/altera/cyclone5-socdk/qts/sequencer_auto.h | 20 - .../cyclone5-socdk/qts/sequencer_auto_ac_init.h | 40 -- .../cyclone5-socdk/qts/sequencer_auto_inst_init.h | 132 ---- .../altera/cyclone5-socdk/qts/sequencer_defines.h | 35 -- 8 files changed, 1153 deletions(-)
diff --git a/board/altera/cyclone5-socdk/qts/iocsr_config.c b/board/altera/cyclone5-socdk/qts/iocsr_config.c index 3b202b5..a2d238c 100644 --- a/board/altera/cyclone5-socdk/qts/iocsr_config.c +++ b/board/altera/cyclone5-socdk/qts/iocsr_config.c @@ -8,7 +8,6 @@
-#ifdef CONFIG_TARGET_SOCFPGA_CYCLONE5 const unsigned long iocsr_scan_chain0_table[(( CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH / 32) + 1)] = { 0x00000000, @@ -656,690 +655,3 @@ const unsigned long iocsr_scan_chain3_table[(( 0x0000001F, 0x00004100, }; -#endif /* CONFIG_TARGET_SOCFPGA_CYCLONE5 */ - -#ifdef CONFIG_TARGET_SOCFPGA_ARRIA5 -const unsigned long iocsr_scan_chain0_table[(( - CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH / 32) + 1)] = { - 0x00000000, - 0x00000000, - 0x00000000, - 0x00000000, - 0x00000000, - 0x00008000, - 0x00060180, - 0x18060000, - 0x18000060, - 0x00018060, - 0x06018060, - 0x00004000, - 0x0C0300C0, - 0x0C030000, - 0x00000030, - 0x00000000, - 0x00000000, - 0x00002000, - 0x00000000, - 0x00000000, - 0x06000000, - 0x00006018, - 0x01806018, - 0x00001000, - 0x0000C030, - 0x04000000, - 0x03000000, - 0x0000300C, - 0x00000000, - 0x00000800, - 0x00006018, - 0x01806000, - 0x01800000, - 0x00000006, - 0x00001806, - 0x00000400, - 0x0000300C, - 0x00C03000, - 0x00C00000, - 0x00000003, - 0x00000C03, - 0x00000200, -}; - -const unsigned long iocsr_scan_chain1_table[(( - CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH / 32) + 1)] = { - 0x00100000, - 0x300C0000, - 0x300000C0, - 0x000000C0, - 0x000300C0, - 0x00008000, - 0x00060180, - 0x18060000, - 0x18000000, - 0x00000060, - 0x00018060, - 0x00004000, - 0x000300C0, - 0x10000000, - 0x0C000000, - 0x00000030, - 0x0000C030, - 0x00002000, - 0x06018060, - 0x06018000, - 0x01FE0000, - 0xF8000000, - 0x00000007, - 0x00001000, - 0x0000C030, - 0x0300C000, - 0x03000000, - 0x0000300C, - 0x0000300C, - 0x00000800, - 0x00006018, - 0x01806000, - 0x01800000, - 0x00000006, - 0x00002000, - 0x00000400, - 0x0000300C, - 0x01000000, - 0x00000000, - 0x00000004, - 0x00000C03, - 0x00000200, - 0x00001806, - 0x00800000, - 0x00000000, - 0x00000002, - 0x00000800, - 0x00000100, - 0x00001000, - 0x00400000, - 0xC0300000, - 0x00000000, - 0x00000400, - 0x00000080, -}; - -const unsigned long iocsr_scan_chain2_table[(( - CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH / 32) + 1)] = { - 0x00100000, - 0x40000000, - 0x00000000, - 0x00000100, - 0x00040000, - 0x00008000, - 0x18060180, - 0x20000000, - 0x00000000, - 0x00000080, - 0x00020000, - 0x00004000, - 0x00040000, - 0x10000000, - 0x00000000, - 0x00000000, - 0x00010000, - 0x00002000, - 0x10038060, - 0x00000000, - 0x00000000, - 0x00000020, - 0x01806018, - 0x00001000, - 0x00010000, - 0x04000000, - 0x03000000, - 0x0000801C, - 0x00004000, - 0x00000800, - 0x01806018, - 0x02000000, - 0x00000000, - 0x00000008, - 0x00002000, - 0x00000400, - 0x00C0300C, - 0x00C03000, - 0x00C00003, - 0x00000C03, - 0x00300C03, - 0x00000200, - 0x00601806, - 0x80601800, - 0x80600001, - 0x80000601, - 0x00180601, - 0x00000100, -}; - -const unsigned long iocsr_scan_chain3_table[(( - CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH / 32) + 1)] = { - 0x2C820D80, - 0x082000FF, - 0x0A804001, - 0x07900000, - 0x08020000, - 0x00100000, - 0x0A800000, - 0x07900000, - 0x08020000, - 0x00100000, - 0xC8800000, - 0x00003001, - 0x00C00722, - 0x00000000, - 0x00000021, - 0x82000004, - 0x05400000, - 0x03C80000, - 0x04010000, - 0x00080000, - 0x05400000, - 0x03C80000, - 0x05400000, - 0x03C80000, - 0xE4400000, - 0x00001800, - 0x00600391, - 0x800E4400, - 0x00000001, - 0x40000002, - 0x02A00000, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x72200000, - 0x80000C00, - 0x003001C8, - 0xC0072200, - 0x1C880000, - 0x20000300, - 0x00040000, - 0x50670000, - 0x00000050, - 0x24590000, - 0x00001000, - 0xA0000034, - 0x0D000001, - 0x906808A2, - 0xA2834024, - 0x05141A00, - 0x808A20D0, - 0x34024906, - 0x01A00A28, - 0xA20D0000, - 0x24906808, - 0x00A28340, - 0xD000001A, - 0x06808A20, - 0x10040000, - 0x00200000, - 0x10040000, - 0x00200000, - 0x15000000, - 0x0F200000, - 0x15000000, - 0x0F200000, - 0x01FE0000, - 0x00000000, - 0x01800E44, - 0x00391000, - 0x007F8006, - 0x00000000, - 0x0A800001, - 0x07900000, - 0x0A800000, - 0x07900000, - 0x0A800000, - 0x07900000, - 0x08020000, - 0x00100000, - 0xC8800000, - 0x00003001, - 0x00C00722, - 0x00000FF0, - 0x72200000, - 0x80000C00, - 0x05400000, - 0x02480000, - 0x04000000, - 0x00080000, - 0x05400000, - 0x03C80000, - 0x05400000, - 0x03C80000, - 0x6A1C0000, - 0x00001800, - 0x00600391, - 0x800E4400, - 0x1A870001, - 0x40000600, - 0x02A00040, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x02A00000, - 0x01E40000, - 0x72200000, - 0x80000C00, - 0x003001C8, - 0xC0072200, - 0x1C880000, - 0x20000300, - 0x00040000, - 0x50670000, - 0x00000050, - 0x24590000, - 0x00001000, - 0xA0000034, - 0x0D000001, - 0x906808A2, - 0xA2834024, - 0x05141A00, - 0x808A20D0, - 0x34024906, - 0x01A00040, - 0xA20D0002, - 0x24906808, - 0x00A28340, - 0xD005141A, - 0x06808A20, - 0x10040000, - 0x00200000, - 0x10040000, - 0x00200000, - 0x15000000, - 0x0F200000, - 0x15000000, - 0x0F200000, - 0x01FE0000, - 0x00000000, - 0x01800E44, - 0x00391000, - 0x007F8006, - 0x00000000, - 0x99300001, - 0x34343400, - 0xAA0D4000, - 0x01C3A810, - 0xAA0D4000, - 0x01C3A808, - 0xAA0D4000, - 0x01C3A810, - 0x00040100, - 0x00000800, - 0x00000000, - 0x00001208, - 0x00482000, - 0x01000000, - 0x00000000, - 0x00410482, - 0x0006A000, - 0x0001B400, - 0x00020000, - 0x00000400, - 0x0002A000, - 0x0001E400, - 0x5506A000, - 0x00E1D404, - 0x00000000, - 0xC880090C, - 0x00003001, - 0x90400000, - 0x00000000, - 0x2020C243, - 0x2A835000, - 0x0070EA04, - 0x2A835000, - 0x0070EA02, - 0x2A835000, - 0x0070EA04, - 0x00010040, - 0x00000200, - 0x00000000, - 0x00000482, - 0x00120800, - 0x00002000, - 0x80000000, - 0x00104120, - 0x00000200, - 0xAC055F80, - 0xFFFFFFFF, - 0x14F3690D, - 0x1A041414, - 0x00D00000, - 0x14864000, - 0x59647A05, - 0xBA28A3D8, - 0xF511451E, - 0x0341D348, - 0x821A0000, - 0x0000D000, - 0x04510680, - 0xD859647A, - 0x1EBA28A3, - 0x48F51145, - 0x000341D3, - 0x00080200, - 0x00001000, - 0x00080200, - 0x00001000, - 0x000A8000, - 0x00075000, - 0x541A8000, - 0x03875011, - 0x10000000, - 0x00000000, - 0x0080C000, - 0x41000000, - 0x00003FC2, - 0x00820000, - 0xAA0D4000, - 0x01C3A810, - 0xAA0D4000, - 0x01C3A808, - 0xAA0D4000, - 0x01C3A810, - 0x00040100, - 0x00000800, - 0x00000000, - 0x00001208, - 0x00482000, - 0x00008000, - 0x00000000, - 0x00410482, - 0x0006A000, - 0x0001B400, - 0x00020000, - 0x00000400, - 0x00020080, - 0x00000400, - 0x5506A000, - 0x00E1D404, - 0x00000000, - 0x0000090C, - 0x00000010, - 0x90400000, - 0x00000000, - 0x2020C243, - 0x2A835000, - 0x0070EA04, - 0x2A835000, - 0x0070EA02, - 0x2A835000, - 0x0070EA04, - 0x00015000, - 0x0000F200, - 0x00000000, - 0x00000482, - 0x00120800, - 0x00600391, - 0x80000000, - 0x00104120, - 0x00000200, - 0xAC055F80, - 0xFFFFFFFF, - 0x14F3690D, - 0x1A041414, - 0x00D00000, - 0x14864000, - 0x59647A05, - 0xBA28A3D8, - 0xF511451E, - 0x8341D348, - 0x821A0124, - 0x0000D000, - 0x00000680, - 0xD859647A, - 0x1EBA28A3, - 0x48F51145, - 0x000341D3, - 0x00080200, - 0x00001000, - 0x00080200, - 0x00001000, - 0x000A8000, - 0x00075000, - 0x541A8000, - 0x03875011, - 0x10000000, - 0x00000000, - 0x0080C000, - 0x41000000, - 0x04000002, - 0x00820000, - 0xAA0D4000, - 0x01C3A810, - 0xAA0D4000, - 0x01C3A808, - 0xAA0D4000, - 0x01C3A810, - 0x00040100, - 0x00000800, - 0x00000000, - 0x00001208, - 0x00482000, - 0x00008000, - 0x00000000, - 0x00410482, - 0x0006A000, - 0x0001B400, - 0x00020000, - 0x00000400, - 0x0002A000, - 0x0001E400, - 0x5506A000, - 0x00E1D404, - 0x00000000, - 0xC880090C, - 0x00003001, - 0x90400000, - 0x00000000, - 0x2020C243, - 0x2A835000, - 0x0070EA04, - 0x2A835000, - 0x0070EA02, - 0x2A835000, - 0x0070EA04, - 0x00010040, - 0x00000200, - 0x00000000, - 0x00000482, - 0x00120800, - 0x00002000, - 0x80000000, - 0x00104120, - 0x00000200, - 0xAC055F80, - 0xFFFFFFFF, - 0x14F3690D, - 0x1A041414, - 0x00D00000, - 0x14864000, - 0x59647A05, - 0xBA28A3D8, - 0xF511451E, - 0x0341D348, - 0x821A0000, - 0x0000D000, - 0x00000680, - 0xD859647A, - 0x1EBA28A3, - 0x48F51145, - 0x000341D3, - 0x00080200, - 0x00001000, - 0x00080200, - 0x00001000, - 0x000A8000, - 0x00075000, - 0x541A8000, - 0x03875011, - 0x10000000, - 0x00000000, - 0x0080C000, - 0x41000000, - 0x04000002, - 0x00820000, - 0xAA0D4000, - 0x01C3A810, - 0xAA0D4000, - 0x01C3A808, - 0xAA0D4000, - 0x01C3A810, - 0x00040100, - 0x00000800, - 0x00000000, - 0x00001208, - 0x00482000, - 0x00008000, - 0x00000000, - 0x00410482, - 0x0006A000, - 0x0001B400, - 0x00020000, - 0x00000400, - 0x00020080, - 0x00000400, - 0x5506A000, - 0x00E1D404, - 0x00000000, - 0x0000090C, - 0x00000010, - 0x90400000, - 0x00000000, - 0x2020C243, - 0x2A835000, - 0x0070EA04, - 0x2A835000, - 0x0070EA02, - 0x2A835000, - 0x0070EA04, - 0x00010040, - 0x00000200, - 0x00000000, - 0x00000482, - 0x00120800, - 0x00400000, - 0x80000000, - 0x00104120, - 0x00000200, - 0xAC055F80, - 0xFFFFFFFF, - 0x14F1690D, - 0x1A041414, - 0x00D00000, - 0x14864000, - 0x59647A05, - 0xBA28A3D8, - 0xF511451E, - 0x0341D348, - 0x821A0000, - 0x0000D000, - 0x00000680, - 0xD859647A, - 0x1EBA28A3, - 0x48F51145, - 0x000341D3, - 0x00080200, - 0x00001000, - 0x00080200, - 0x00001000, - 0x000A8000, - 0x00075000, - 0x541A8000, - 0x03875011, - 0x10000000, - 0x00000000, - 0x0080C000, - 0x41000000, - 0x04000002, - 0x00820000, - 0x00481800, - 0x001A1A1A, - 0x085506A0, - 0x0000E1D4, - 0x045506A0, - 0x0000E1D4, - 0x085506A0, - 0x8000E1D4, - 0x00000200, - 0x00000004, - 0x04000000, - 0x00000009, - 0x00002410, - 0x00000040, - 0x41000000, - 0x00002082, - 0x00000350, - 0x000000DA, - 0x00000100, - 0x40000002, - 0x00000100, - 0x00000002, - 0x022A8350, - 0x000070EA, - 0x86000000, - 0x08000004, - 0x00000000, - 0x00482000, - 0x21800000, - 0x00101061, - 0x021541A8, - 0x00003875, - 0x011541A8, - 0x00003875, - 0x021541A8, - 0x20003875, - 0x00000080, - 0x00000001, - 0x41000000, - 0x00000002, - 0x00FF0904, - 0x00000000, - 0x90400000, - 0x00000820, - 0xC0000001, - 0xFFD602AF, - 0x86FFFFFF, - 0x0A0A78B4, - 0x000D020A, - 0x00006800, - 0x028A4320, - 0xEC2CB23D, - 0x8F5D1451, - 0xA47A88A2, - 0x0001A0E9, - 0x00410D00, - 0x40000068, - 0x3D000003, - 0x51EC2CB2, - 0xA28F5D14, - 0xE9A47A88, - 0x000001A0, - 0x00000401, - 0x00000008, - 0x00000401, - 0x00000008, - 0x00000540, - 0x000003A8, - 0x08AA0D40, - 0x8001C3A8, - 0x0000007F, - 0x00000000, - 0x00004060, - 0xE1208000, - 0x0000001F, - 0x00004100, -}; -#endif /* CONFIG_TARGET_SOCFPGA_ARRIA5 */ diff --git a/board/altera/cyclone5-socdk/qts/iocsr_config.h b/board/altera/cyclone5-socdk/qts/iocsr_config.h index d1c9b0d..4a7ed46 100644 --- a/board/altera/cyclone5-socdk/qts/iocsr_config.h +++ b/board/altera/cyclone5-socdk/qts/iocsr_config.h @@ -9,18 +9,9 @@ #ifndef _PRELOADER_IOCSR_CONFIG_H_ #define _PRELOADER_IOCSR_CONFIG_H_
-#ifdef CONFIG_TARGET_SOCFPGA_CYCLONE5 #define CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH (764) #define CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH (1719) #define CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH (955) #define CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH (16766) -#endif - -#ifdef CONFIG_TARGET_SOCFPGA_ARRIA5 -#define CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH (1337) -#define CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH (1719) -#define CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH (1528) -#define CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH (16766) -#endif
#endif /*_PRELOADER_IOCSR_CONFIG_H_*/ diff --git a/board/altera/cyclone5-socdk/qts/pinmux_config.c b/board/altera/cyclone5-socdk/qts/pinmux_config.c index 7e7a184..cb58689 100644 --- a/board/altera/cyclone5-socdk/qts/pinmux_config.c +++ b/board/altera/cyclone5-socdk/qts/pinmux_config.c @@ -2,7 +2,6 @@
-#ifdef CONFIG_TARGET_SOCFPGA_CYCLONE5 /* pin mux configuration data */ unsigned long sys_mgr_init_table[CONFIG_HPS_PINMUX_NUM] = { 3, /* EMACIO0 */ @@ -213,217 +212,3 @@ unsigned long sys_mgr_init_table[CONFIG_HPS_PINMUX_NUM] = { 0, /* USB0USEFPGA */ 0 /* SPIM0USEFPGA */ }; -#endif /* CONFIG_TARGET_SOCFPGA_CYCLONE5 */ - -#ifdef CONFIG_TARGET_SOCFPGA_ARRIA5 -/* pin mux configuration data */ -unsigned long sys_mgr_init_table[CONFIG_HPS_PINMUX_NUM] = { - 0, /* EMACIO0 */ - 2, /* EMACIO1 */ - 2, /* EMACIO2 */ - 2, /* EMACIO3 */ - 2, /* EMACIO4 */ - 2, /* EMACIO5 */ - 2, /* EMACIO6 */ - 2, /* EMACIO7 */ - 2, /* EMACIO8 */ - 0, /* EMACIO9 */ - 2, /* EMACIO10 */ - 2, /* EMACIO11 */ - 2, /* EMACIO12 */ - 2, /* EMACIO13 */ - 3, /* EMACIO14 */ - 3, /* EMACIO15 */ - 3, /* EMACIO16 */ - 3, /* EMACIO17 */ - 3, /* EMACIO18 */ - 3, /* EMACIO19 */ - 3, /* FLASHIO0 */ - 0, /* FLASHIO1 */ - 3, /* FLASHIO2 */ - 3, /* FLASHIO3 */ - 0, /* FLASHIO4 */ - 0, /* FLASHIO5 */ - 0, /* FLASHIO6 */ - 0, /* FLASHIO7 */ - 0, /* FLASHIO8 */ - 3, /* FLASHIO9 */ - 3, /* FLASHIO10 */ - 3, /* FLASHIO11 */ - 3, /* GENERALIO0 */ - 3, /* GENERALIO1 */ - 3, /* GENERALIO2 */ - 3, /* GENERALIO3 */ - 3, /* GENERALIO4 */ - 3, /* GENERALIO5 */ - 3, /* GENERALIO6 */ - 3, /* GENERALIO7 */ - 3, /* GENERALIO8 */ - 0, /* GENERALIO9 */ - 0, /* GENERALIO10 */ - 0, /* GENERALIO11 */ - 0, /* GENERALIO12 */ - 0, /* GENERALIO13 */ - 0, /* GENERALIO14 */ - 3, /* GENERALIO15 */ - 3, /* GENERALIO16 */ - 2, /* GENERALIO17 */ - 2, /* GENERALIO18 */ - 0, /* GENERALIO19 */ - 0, /* GENERALIO20 */ - 0, /* GENERALIO21 */ - 0, /* GENERALIO22 */ - 3, /* GENERALIO23 */ - 3, /* GENERALIO24 */ - 0, /* GENERALIO25 */ - 0, /* GENERALIO26 */ - 0, /* GENERALIO27 */ - 0, /* GENERALIO28 */ - 0, /* GENERALIO29 */ - 0, /* GENERALIO30 */ - 0, /* GENERALIO31 */ - 0, /* MIXED1IO0 */ - 0, /* MIXED1IO1 */ - 0, /* MIXED1IO2 */ - 0, /* MIXED1IO3 */ - 0, /* MIXED1IO4 */ - 0, /* MIXED1IO5 */ - 0, /* MIXED1IO6 */ - 0, /* MIXED1IO7 */ - 0, /* MIXED1IO8 */ - 0, /* MIXED1IO9 */ - 0, /* MIXED1IO10 */ - 0, /* MIXED1IO11 */ - 0, /* MIXED1IO12 */ - 0, /* MIXED1IO13 */ - 0, /* MIXED1IO14 */ - 3, /* MIXED1IO15 */ - 3, /* MIXED1IO16 */ - 3, /* MIXED1IO17 */ - 3, /* MIXED1IO18 */ - 3, /* MIXED1IO19 */ - 3, /* MIXED1IO20 */ - 0, /* MIXED1IO21 */ - 3, /* MIXED2IO0 */ - 3, /* MIXED2IO1 */ - 3, /* MIXED2IO2 */ - 3, /* MIXED2IO3 */ - 3, /* MIXED2IO4 */ - 3, /* MIXED2IO5 */ - 3, /* MIXED2IO6 */ - 3, /* MIXED2IO7 */ - 0, /* GPLINMUX48 */ - 0, /* GPLINMUX49 */ - 0, /* GPLINMUX50 */ - 0, /* GPLINMUX51 */ - 0, /* GPLINMUX52 */ - 0, /* GPLINMUX53 */ - 0, /* GPLINMUX54 */ - 0, /* GPLINMUX55 */ - 0, /* GPLINMUX56 */ - 0, /* GPLINMUX57 */ - 0, /* GPLINMUX58 */ - 0, /* GPLINMUX59 */ - 0, /* GPLINMUX60 */ - 0, /* GPLINMUX61 */ - 0, /* GPLINMUX62 */ - 0, /* GPLINMUX63 */ - 0, /* GPLINMUX64 */ - 0, /* GPLINMUX65 */ - 0, /* GPLINMUX66 */ - 0, /* GPLINMUX67 */ - 0, /* GPLINMUX68 */ - 0, /* GPLINMUX69 */ - 0, /* GPLINMUX70 */ - 1, /* GPLMUX0 */ - 1, /* GPLMUX1 */ - 1, /* GPLMUX2 */ - 1, /* GPLMUX3 */ - 1, /* GPLMUX4 */ - 1, /* GPLMUX5 */ - 1, /* GPLMUX6 */ - 1, /* GPLMUX7 */ - 1, /* GPLMUX8 */ - 1, /* GPLMUX9 */ - 1, /* GPLMUX10 */ - 1, /* GPLMUX11 */ - 1, /* GPLMUX12 */ - 1, /* GPLMUX13 */ - 1, /* GPLMUX14 */ - 1, /* GPLMUX15 */ - 1, /* GPLMUX16 */ - 1, /* GPLMUX17 */ - 1, /* GPLMUX18 */ - 1, /* GPLMUX19 */ - 1, /* GPLMUX20 */ - 1, /* GPLMUX21 */ - 1, /* GPLMUX22 */ - 1, /* GPLMUX23 */ - 1, /* GPLMUX24 */ - 1, /* GPLMUX25 */ - 1, /* GPLMUX26 */ - 1, /* GPLMUX27 */ - 1, /* GPLMUX28 */ - 1, /* GPLMUX29 */ - 1, /* GPLMUX30 */ - 1, /* GPLMUX31 */ - 1, /* GPLMUX32 */ - 1, /* GPLMUX33 */ - 1, /* GPLMUX34 */ - 1, /* GPLMUX35 */ - 1, /* GPLMUX36 */ - 1, /* GPLMUX37 */ - 1, /* GPLMUX38 */ - 1, /* GPLMUX39 */ - 1, /* GPLMUX40 */ - 1, /* GPLMUX41 */ - 1, /* GPLMUX42 */ - 1, /* GPLMUX43 */ - 1, /* GPLMUX44 */ - 1, /* GPLMUX45 */ - 1, /* GPLMUX46 */ - 1, /* GPLMUX47 */ - 1, /* GPLMUX48 */ - 1, /* GPLMUX49 */ - 1, /* GPLMUX50 */ - 1, /* GPLMUX51 */ - 1, /* GPLMUX52 */ - 1, /* GPLMUX53 */ - 1, /* GPLMUX54 */ - 1, /* GPLMUX55 */ - 1, /* GPLMUX56 */ - 1, /* GPLMUX57 */ - 1, /* GPLMUX58 */ - 1, /* GPLMUX59 */ - 1, /* GPLMUX60 */ - 1, /* GPLMUX61 */ - 1, /* GPLMUX62 */ - 1, /* GPLMUX63 */ - 1, /* GPLMUX64 */ - 1, /* GPLMUX65 */ - 1, /* GPLMUX66 */ - 1, /* GPLMUX67 */ - 1, /* GPLMUX68 */ - 1, /* GPLMUX69 */ - 1, /* GPLMUX70 */ - 0, /* NANDUSEFPGA */ - 0, /* UART0USEFPGA */ - 0, /* RGMII1USEFPGA */ - 0, /* SPIS0USEFPGA */ - 0, /* CAN0USEFPGA */ - 0, /* I2C0USEFPGA */ - 0, /* SDMMCUSEFPGA */ - 0, /* QSPIUSEFPGA */ - 0, /* SPIS1USEFPGA */ - 0, /* RGMII0USEFPGA */ - 0, /* UART1USEFPGA */ - 0, /* CAN1USEFPGA */ - 0, /* USB1USEFPGA */ - 0, /* I2C3USEFPGA */ - 0, /* I2C2USEFPGA */ - 0, /* I2C1USEFPGA */ - 0, /* SPIM1USEFPGA */ - 0, /* USB0USEFPGA */ - 0 /* SPIM0USEFPGA */ -}; -#endif /* CONFIG_TARGET_SOCFPGA_ARRIA5 */ diff --git a/board/altera/cyclone5-socdk/qts/sdram_config.h b/board/altera/cyclone5-socdk/qts/sdram_config.h index f6d51ca..15df808 100644 --- a/board/altera/cyclone5-socdk/qts/sdram_config.h +++ b/board/altera/cyclone5-socdk/qts/sdram_config.h @@ -20,19 +20,6 @@ #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCWL 6 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_AL 0 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCL 7 -#ifdef CONFIG_SOCFPGA_ARRIA5 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRRD 4 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TFAW 19 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRFC 139 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TREFI 4160 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRCD 8 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRP 8 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWR 8 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWTR 4 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRTP 4 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRAS 19 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRC 26 -#else #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRRD 3 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TFAW 14 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRFC 104 @@ -44,7 +31,6 @@ #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRTP 3 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRAS 14 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRC 20 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TMRD 4 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TCCD 4 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_SELFRFSHEXIT 512 diff --git a/board/altera/cyclone5-socdk/qts/sequencer_auto.h b/board/altera/cyclone5-socdk/qts/sequencer_auto.h index 0c5d83b..d3c2251 100644 --- a/board/altera/cyclone5-socdk/qts/sequencer_auto.h +++ b/board/altera/cyclone5-socdk/qts/sequencer_auto.h @@ -19,29 +19,14 @@ #define RW_MGR_MRS2 0x04 #define RW_MGR_LFSR_WR_RD_DM_BANK_0_WL_1 0x34 #define RW_MGR_MRS1 0x03 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -#define RW_MGR_IDLE_LOOP1 0x7A -#else #define RW_MGR_IDLE_LOOP1 0x7C -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define RW_MGR_GUARANTEED_WRITE_WAIT2 0x18 #define RW_MGR_MRS3 0x05 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -#define RW_MGR_IDLE_LOOP2 0x79 -#else #define RW_MGR_IDLE_LOOP2 0x7B -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define RW_MGR_GUARANTEED_WRITE_WAIT1 0x1E #define RW_MGR_LFSR_WR_RD_BANK_0_DATA 0x24 #define RW_MGR_GUARANTEED_WRITE_WAIT3 0x1C -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -#define RW_MGR_RDIMM_CMD 0x78 -#else #define RW_MGR_RDIMM_CMD 0x7A -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define RW_MGR_LFSR_WR_RD_DM_BANK_0_NOP 0x36 #define RW_MGR_GUARANTEED_WRITE_WAIT0 0x1A #define RW_MGR_LFSR_WR_RD_DM_BANK_0_DATA 0x38 @@ -54,12 +39,7 @@ #define RW_MGR_GUARANTEED_WRITE 0x17 #define RW_MGR_PRECHARGE_ALL 0x12 #define RW_MGR_INIT_RESET_1_CKE_0_inloop_1 0x74 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -#define RW_MGR_SGLE_READ 0x7C -#else #define RW_MGR_SGLE_READ 0x7E -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define RW_MGR_MRS0_USER_MIRR 0x0C #define RW_MGR_RETURN 0x01 #define RW_MGR_LFSR_WR_RD_DM_BANK_0 0x35 diff --git a/board/altera/cyclone5-socdk/qts/sequencer_auto_ac_init.h b/board/altera/cyclone5-socdk/qts/sequencer_auto_ac_init.h index c46421b..0d26281 100644 --- a/board/altera/cyclone5-socdk/qts/sequencer_auto_ac_init.h +++ b/board/altera/cyclone5-socdk/qts/sequencer_auto_ac_init.h @@ -5,45 +5,6 @@ */
const uint32_t ac_rom_init[] = { -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ - 0x20700000, - 0x20780000, - 0x10080831, - 0x10080930, - 0x10090004, - 0x100a0008, - 0x100b0000, - 0x10380400, - 0x10080849, - 0x100808c8, - 0x100a0004, - 0x10090010, - 0x100b0000, - 0x30780000, - 0x38780000, - 0x30780000, - 0x10680000, - 0x106b0000, - 0x10280400, - 0x10480000, - 0x1c980000, - 0x1c9b0000, - 0x1c980008, - 0x1c9b0008, - 0x38f80000, - 0x3cf80000, - 0x38780000, - 0x18180000, - 0x18980000, - 0x13580000, - 0x135b0000, - 0x13580008, - 0x135b0008, - 0x33780000, - 0x10580008, - 0x10780000 -#else 0x20700000, 0x20780000, 0x10080431, @@ -80,5 +41,4 @@ const uint32_t ac_rom_init[] = { 0x33780000, 0x10580008, 0x10780000 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ }; diff --git a/board/altera/cyclone5-socdk/qts/sequencer_auto_inst_init.h b/board/altera/cyclone5-socdk/qts/sequencer_auto_inst_init.h index ad0395b..2b4c78f 100644 --- a/board/altera/cyclone5-socdk/qts/sequencer_auto_inst_init.h +++ b/board/altera/cyclone5-socdk/qts/sequencer_auto_inst_init.h @@ -4,137 +4,6 @@ * SPDX-License-Identifier: BSD-3-Clause */
-#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -const u32 inst_rom_init[] = { - 0x80000, - 0x80680, - 0x8180, - 0x8200, - 0x8280, - 0x8300, - 0x8380, - 0x8100, - 0x8480, - 0x8500, - 0x8580, - 0x8600, - 0x8400, - 0x800, - 0x8680, - 0x880, - 0xa680, - 0x80680, - 0x900, - 0x80680, - 0x980, - 0x8680, - 0x80680, - 0xb68, - 0xcce8, - 0xae8, - 0x8ce8, - 0xb88, - 0xec88, - 0xa08, - 0xac88, - 0x80680, - 0xce00, - 0xcd80, - 0xe700, - 0xc00, - 0x20ce0, - 0x20ce0, - 0x20ce0, - 0x20ce0, - 0xd00, - 0x680, - 0x680, - 0x680, - 0x680, - 0x60e80, - 0x61080, - 0x61080, - 0x61080, - 0xa680, - 0x8680, - 0x80680, - 0xce00, - 0xcd80, - 0xe700, - 0xc00, - 0x30ce0, - 0x30ce0, - 0x30ce0, - 0x30ce0, - 0xd00, - 0x680, - 0x680, - 0x680, - 0x680, - 0x70e80, - 0x71080, - 0x71080, - 0x71080, - 0xa680, - 0x8680, - 0x80680, - 0x1158, - 0x6d8, - 0x80680, - 0x1168, - 0x7e8, - 0x7e8, - 0x87e8, - 0x40fe8, - 0x410e8, - 0x410e8, - 0x410e8, - 0x1168, - 0x7e8, - 0x7e8, - 0xa7e8, - 0x80680, - 0x40e88, - 0x41088, - 0x41088, - 0x41088, - 0x40f68, - 0x410e8, - 0x410e8, - 0x410e8, - 0xa680, - 0x40fe8, - 0x410e8, - 0x410e8, - 0x410e8, - 0x41008, - 0x41088, - 0x41088, - 0x41088, - 0x1100, - 0xc680, - 0x8680, - 0xe680, - 0x80680, - 0x0, - 0x8000, - 0xa000, - 0xc000, - 0x80000, - 0x80, - 0x8080, - 0xa080, - 0xc080, - 0x80080, - 0x9180, - 0x8680, - 0xa680, - 0x80680, - 0x40f08, - 0x80680 -}; -#else const u32 inst_rom_init[] = { 0x80000, 0x80680, @@ -265,4 +134,3 @@ const u32 inst_rom_init[] = { 0x40f08, 0x80680 }; -#endif /* CONFIG_SOCFPGA_ARRIA5 */ diff --git a/board/altera/cyclone5-socdk/qts/sequencer_defines.h b/board/altera/cyclone5-socdk/qts/sequencer_defines.h index bfe5b27..27ace02 100644 --- a/board/altera/cyclone5-socdk/qts/sequencer_defines.h +++ b/board/altera/cyclone5-socdk/qts/sequencer_defines.h @@ -12,39 +12,20 @@ #define AC_ROM_MR2_MIRR 0000000010000 #define AC_ROM_MR3_MIRR 0000000000000 #define AC_ROM_MR0_CALIB -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -#define AC_ROM_MR0_DLL_RESET_MIRR 0100011001000 -#define AC_ROM_MR0_DLL_RESET 0100100110000 -#define AC_ROM_MR0_MIRR 0100001001001 -#define AC_ROM_MR0 0100000110001 -#else #define AC_ROM_MR0_DLL_RESET_MIRR 0010011001000 #define AC_ROM_MR0_DLL_RESET 0010100110000 #define AC_ROM_MR0_MIRR 0010001001001 #define AC_ROM_MR0 0010000110001 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define AC_ROM_MR1 0000000000100 #define AC_ROM_MR2 0000000001000 #define AC_ROM_MR3 0000000000000 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -#define AFI_CLK_FREQ 534 -#else #define AFI_CLK_FREQ 401 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define AFI_RATE_RATIO 1 #define AVL_CLK_FREQ 67 #define BFM_MODE 0 #define BURST2 0 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -#define CALIB_LFIFO_OFFSET 8 -#define CALIB_VFIFO_OFFSET 6 -#else #define CALIB_LFIFO_OFFSET 7 #define CALIB_VFIFO_OFFSET 5 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define ENABLE_EXPORT_SEQ_DEBUG_BRIDGE 0 #define ENABLE_SUPER_QUICK_CALIBRATION 0 #define GUARANTEED_READ_BRINGUP_TEST 0 @@ -54,23 +35,12 @@ #define HR_DDIO_OUT_HAS_THREE_REGS 0 #define IO_DELAY_PER_DCHAIN_TAP 25 #define IO_DELAY_PER_DQS_EN_DCHAIN_TAP 25 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -#define IO_DELAY_PER_OPA_TAP 234 -#else #define IO_DELAY_PER_OPA_TAP 312 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define IO_DLL_CHAIN_LENGTH 8 #define IO_DM_OUT_RESERVE 0 #define IO_DQDQS_OUT_PHASE_MAX 0 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -#define IO_DQS_EN_DELAY_MAX 15 -#define IO_DQS_EN_DELAY_OFFSET 16 -#else #define IO_DQS_EN_DELAY_MAX 31 #define IO_DQS_EN_DELAY_OFFSET 0 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define IO_DQS_EN_PHASE_MAX 7 #define IO_DQS_IN_DELAY_MAX 31 #define IO_DQS_IN_RESERVE 4 @@ -84,12 +54,7 @@ #define MAX_LATENCY_COUNT_WIDTH 5 #define MEM_ADDR_WIDTH 13 #define READ_VALID_FIFO_SIZE 16 -#ifdef CONFIG_SOCFPGA_ARRIA5 -/* The if..else... is not required if generated by tools */ -#define REG_FILE_INIT_SEQ_SIGNATURE 0x5555048c -#else #define REG_FILE_INIT_SEQ_SIGNATURE 0x55550483 -#endif /* CONFIG_SOCFPGA_ARRIA5 */ #define RW_MGR_MEM_ADDRESS_MIRRORING 0 #define RW_MGR_MEM_ADDRESS_WIDTH 15 #define RW_MGR_MEM_BANK_WIDTH 3
Add script which loads the QTS-generated sources and headers and converts them into sensible format which can be used with much more easy in mainline U-Boot. The script also filters out macros which makes no sense anymore, so they don't pollute namespace and waste space.
Signed-off-by: Marek Vasut marex@denx.de --- arch/arm/mach-socfpga/qts-filter.sh | 205 ++++++++++++++++++++++++++++++++++++ 1 file changed, 205 insertions(+) create mode 100755 arch/arm/mach-socfpga/qts-filter.sh
diff --git a/arch/arm/mach-socfpga/qts-filter.sh b/arch/arm/mach-socfpga/qts-filter.sh new file mode 100755 index 0000000..16d3a2a --- /dev/null +++ b/arch/arm/mach-socfpga/qts-filter.sh @@ -0,0 +1,205 @@ +#!/bin/sh + +# +# Process iocsr_config_*.[ch] +# $1: SoC type +# $2: Input directory +# $3: Output directory +# +process_iocsr_config() { + soc="$1" + in_dir="$2" + out_dir="$3" + + ( + cat << EOF +/* + * Altera SoCFPGA IOCSR configuration + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#ifndef __SOCFPGA_IOCSR_CONFIG_H__ +#define __SOCFPGA_IOCSR_CONFIG_H__ + +EOF + + # Retrieve the scan chain lengths + grep 'CONFIG_HPS_IOCSR_SCANCHAIN[0-9]+_LENGTH' \ + ${in_dir}/generated/iocsr_config_${soc}.h | tr -d "()" + + echo "" + + # Retrieve the scan chain config and zap the ad-hoc length encoding + sed -n '/^const/ !b; :next {/^const/ s/(.*)//;p;n;b next}' \ + ${in_dir}/generated/iocsr_config_${soc}.c + + cat << EOF + +#endif /* __SOCFPGA_IOCSR_CONFIG_H__ */ +EOF + ) > "${out_dir}/iocsr_config.h" +} + +# +# Process pinmux_config_*.c (and ignore pinmux_config.h) +# $1: SoC type +# $2: Input directory +# $3: Output directory +# +process_pinmux_config() { + soc="$1" + in_dir="$2" + out_dir="$3" + + ( + cat << EOF +/* + * Altera SoCFPGA PinMux configuration + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#ifndef __SOCFPGA_PINMUX_CONFIG_H__ +#define __SOCFPGA_PINMUX_CONFIG_H__ + +EOF + + # Retrieve the pinmux config and zap the ad-hoc length encoding + sed -n '/^unsigned/ !b; :next {/^unsigned/ s/[.*]/[]/;p;n;b next}' \ + ${in_dir}/generated/pinmux_config_${soc}.c + + cat << EOF + +#endif /* __SOCFPGA_PINMUX_CONFIG_H__ */ +EOF + ) > "${out_dir}/pinmux_config.h" +} + +# +# Process pll_config.h +# $1: SoC type (not used) +# $2: Input directory +# $3: Output directory +# +process_pll_config() { + soc="$1" + in_dir="$2" + out_dir="$3" + + ( + cat << EOF +/* + * Altera SoCFPGA Clock and PLL configuration + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#ifndef __SOCFPGA_PLL_CONFIG_H__ +#define __SOCFPGA_PLL_CONFIG_H__ + +EOF + + # Retrieve the pll config and zap parenthesis + sed -n '/CONFIG_HPS/ !b; :next {/CONFIG_HPS/ s/[()]//g;/endif/ b;p;n;b next}' \ + ${in_dir}/generated/pll_config.h + + cat << EOF + +#endif /* __SOCFPGA_PLL_CONFIG_H__ */ +EOF + ) > "${out_dir}/pll_config.h" +} + +# +# Filter out only the macros which are actually used by the code +# +grep_sdram_config() { + egrep "#define (CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMTYPE|CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMBL|CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ADDRORDER|CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ECCEN|CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ECCCORREN|CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_REORDEREN|CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_STARVELIMIT|CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_DQSTRKEN|CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_NODMPINS|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCWL|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_AL|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCL|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRRD|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TFAW|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRFC|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TREFI|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRCD|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRP|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWR|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWTR|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRTP|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRAS|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRC|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TMRD|CONFIG_HPS_ SDR_CTRLCFG_DRAMTIMING3_TCCD|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_SELFRFSHEXIT|CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_PWRDOWNEXIT|CONFIG_HPS_SDR_CTRLCFG_LOWPWRTIMING_AUTOPDCYCLES|CONFIG_HPS_SDR_CTRLCFG_LOWPWRTIMING_CLKDISABLECYCLES|CONFIG_HPS_SDR_CTRLCFG_DRAMODT_READ|CONFIG_HPS_SDR_CTRLCFG_DRAMODT_WRITE|CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_COLBITS|CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_ROWBITS|CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_BANKBITS|CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_CSBITS|CONFIG_HPS_SDR_CTRLCFG_DRAMIFWIDTH_IFWIDTH|CONFIG_HPS_SDR_CTRLCFG_DRAMDEVWIDTH_DEVWIDTH|CONFIG_HPS_SDR_CTRLCFG_DRAMINTR_INTREN|CONFIG_HPS_SDR_CTRLCFG_LOWPWREQ_SELFRFSHMASK|CONFIG_HPS_SDR_CTRLCFG_STATICCFG_MEMBL|CONFIG_HPS_SDR_CTRLCFG_STATICCFG_USEECCASDATA|CONFIG_HPS_SDR_CTRLCFG_CTRLWIDTH_CTRLWIDTH|CONFIG_HPS_SDR_CTRLCFG_CPORTWIDTH_CPORTWIDTH|CONFIG_HPS_SDR_CTRLCFG_CPORTWMAP_CPORTWMAP|CONFIG_HPS_SDR_CTRLCFG_CPORTRMAP_CPORTRMAP|CONFIG_HPS_SDR_CTRLCFG_RFIFOCMAP_RFIFOCMAP|CONFIG_HPS_SDR_CTRLCFG_WFIFOCMAP_WFIFOCMAP|CONFIG_HPS_SDR_CT RLCFG_CPORTRDWR_CPORTRDWR|CONFIG_HPS_SDR_CTRLCFG_PORTCFG_AUTOPCHEN|CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST|CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_SYNCMODE|CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_INCSYNC|CONFIG_HPS_SDR_CTRLCFG_MPPRIORITY_USERPRIORITY|CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_0_STATICWEIGHT_31_0|CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_1_STATICWEIGHT_49_32|CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_1_SUMOFWEIGHT_13_0|CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_2_SUMOFWEIGHT_45_14|CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_3_SUMOFWEIGHT_63_46|CONFIG_HPS_SDR_CTRLCFG_PHYCTRL_PHYCTRL_0|CONFIG_HPS_SDR_CTRLCFG_MPPACING_0_THRESHOLD1_31_0|CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD1_59_32|CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD2_3_0|CONFIG_HPS_SDR_CTRLCFG_MPPACING_2_THRESHOLD2_35_4|CONFIG_HPS_SDR_CTRLCFG_MPPACING_3_THRESHOLD2_59_36|CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_0_THRESHOLDRSTCYCLES_31_0|CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_1_THRESHOLDRSTCYCLES_63_32|CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_2_THRESHOLDRSTCYCLES_79_64|RW_MGR_ACTIVATE_0_ AND_1|RW_MGR_ACTIVATE_0_AND_1_WAIT1|RW_MGR_ACTIVATE_0_AND_1_WAIT2|RW_MGR_ACTIVATE_1|RW_MGR_CLEAR_DQS_ENABLE|RW_MGR_GUARANTEED_READ|RW_MGR_GUARANTEED_READ_CONT|RW_MGR_GUARANTEED_WRITE|RW_MGR_GUARANTEED_WRITE_WAIT0|RW_MGR_GUARANTEED_WRITE_WAIT1|RW_MGR_GUARANTEED_WRITE_WAIT2|RW_MGR_GUARANTEED_WRITE_WAIT3|RW_MGR_IDLE|RW_MGR_IDLE_LOOP1|RW_MGR_IDLE_LOOP2|RW_MGR_INIT_RESET_0_CKE_0|RW_MGR_INIT_RESET_1_CKE_0|RW_MGR_LFSR_WR_RD_BANK_0|RW_MGR_LFSR_WR_RD_BANK_0_DATA|RW_MGR_LFSR_WR_RD_BANK_0_DQS|RW_MGR_LFSR_WR_RD_BANK_0_NOP|RW_MGR_LFSR_WR_RD_BANK_0_WAIT|RW_MGR_LFSR_WR_RD_BANK_0_WL_1|RW_MGR_LFSR_WR_RD_DM_BANK_0|RW_MGR_LFSR_WR_RD_DM_BANK_0_DATA|RW_MGR_LFSR_WR_RD_DM_BANK_0_DQS|RW_MGR_LFSR_WR_RD_DM_BANK_0_NOP|RW_MGR_LFSR_WR_RD_DM_BANK_0_WAIT|RW_MGR_LFSR_WR_RD_DM_BANK_0_WL_1|RW_MGR_MRS0_DLL_RESET|RW_MGR_MRS0_DLL_RESET_MIRR|RW_MGR_MRS0_USER|RW_MGR_MRS0_USER_MIRR|RW_MGR_MRS1|RW_MGR_MRS1_MIRR|RW_MGR_MRS2|RW_MGR_MRS2_MIRR|RW_MGR_MRS3|RW_MGR_MRS3_MIRR|RW_MGR_PRECHARGE_ALL|RW_MGR_READ_B2B|RW_MGR_READ_B2B_WA IT1|RW_MGR_READ_B2B_WAIT2|RW_MGR_REFRESH_ALL|RW_MGR_RETURN|RW_MGR_SGLE_READ|RW_MGR_ZQCL|RW_MGR_TRUE_MEM_DATA_MASK_WIDTH|RW_MGR_MEM_ADDRESS_MIRRORING|RW_MGR_MEM_DATA_MASK_WIDTH|RW_MGR_MEM_DATA_WIDTH|RW_MGR_MEM_DQ_PER_READ_DQS|RW_MGR_MEM_DQ_PER_WRITE_DQS|RW_MGR_MEM_IF_READ_DQS_WIDTH|RW_MGR_MEM_IF_WRITE_DQS_WIDTH|RW_MGR_MEM_NUMBER_OF_CS_PER_DIMM|RW_MGR_MEM_NUMBER_OF_RANKS|RW_MGR_MEM_VIRTUAL_GROUPS_PER_READ_DQS|RW_MGR_MEM_VIRTUAL_GROUPS_PER_WRITE_DQS|IO_DELAY_PER_DCHAIN_TAP|IO_DELAY_PER_DQS_EN_DCHAIN_TAP|IO_DELAY_PER_OPA_TAP|IO_DLL_CHAIN_LENGTH|IO_DQDQS_OUT_PHASE_MAX|IO_DQS_EN_DELAY_MAX|IO_DQS_EN_DELAY_OFFSET|IO_DQS_EN_PHASE_MAX|IO_DQS_IN_DELAY_MAX|IO_DQS_IN_RESERVE|IO_DQS_OUT_RESERVE|IO_IO_IN_DELAY_MAX|IO_IO_OUT1_DELAY_MAX|IO_IO_OUT2_DELAY_MAX|IO_SHIFT_DQS_EN_WHEN_SHIFT_DQS|AFI_RATE_RATIO|CALIB_LFIFO_OFFSET|CALIB_VFIFO_OFFSET|ENABLE_SUPER_QUICK_CALIBRATION|MAX_LATENCY_COUNT_WIDTH|READ_VALID_FIFO_SIZE|REG_FILE_INIT_SEQ_SIGNATURE|TINIT_CNTR0_VAL|TINIT_CNTR1_VAL|TINIT_CNTR2_VAL|TRESET_CNT R0_VAL|TRESET_CNTR1_VAL|TRESET_CNTR2_VAL)[[:space:]]" +} + +# +# Process sdram_config.h, sequencer_auto*h and sequencer_defines.h +# $1: SoC type (not used) +# $2: Input directory +# $3: Output directory +# +process_sdram_config() { + soc="$1" + in_dir="$2" + out_dir="$3" + + ( + cat << EOF +/* + * Altera SoCFPGA SDRAM configuration + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#ifndef __SOCFPGA_SDRAM_CONFIG_H__ +#define __SOCFPGA_SDRAM_CONFIG_H__ + +EOF + + echo "/* SDRAM configuration */" + # Retrieve the sdram config, zap broken lines and zap parenthesis + sed -n "/\\$/ {N;s/ \\\n/\t/};p" ${in_dir}/generated/sdram/sdram_config.h | + sed -n '/CONFIG_HPS/ !b; :next {/CONFIG_HPS/ s/[()]//g;/endif/ b;p;n;b next}' | + sort -u | grep_sdram_config + + echo "" + echo "/* Sequencer auto configuration */" + sed -n "/__RW_MGR/ {s/__//;s/ +([^ ]+)$/\t\1/p}" \ + ${in_dir}/hps_isw_handoff/*/sequencer_auto.h | sort -u | grep_sdram_config + + echo "" + echo "/* Sequencer defines configuration */" + sed -n "/^#define [^_]/ {s/__//;s/ +([^ ]+)$/\t\1/p}" \ + ${in_dir}/hps_isw_handoff/*/sequencer_defines.h | sort -u | grep_sdram_config + + echo "" + echo "/* Sequencer ac_rom_init configuration */" + sed -n '/^const.*[/ !b; :next {/^const.*[/ {N;s/\n//;s/alt_u32/u32/;s/[.*]/[]/};/endif/ b;p;n;b next}'\ + ${in_dir}/hps_isw_handoff/*/sequencer_auto_ac_init.c + + echo "" + echo "/* Sequencer inst_rom_init configuration */" + sed -n '/^const.*[/ !b; :next {/^const.*[/ {N;s/\n//;s/alt_u32/u32/;s/[.*]/[]/};/endif/ b;p;n;b next}'\ + ${in_dir}/hps_isw_handoff/*/sequencer_auto_inst_init.c + + cat << EOF + +#endif /* __SOCFPGA_SDRAM_CONFIG_H__ */ +EOF + ) > "${out_dir}/sdram_config.h" +} + +usage() { + echo "$0 [soc_type] [input_dir] [output_dir]" + echo "Process QTS-generated headers into U-Boot compatible ones." + echo "" + echo " soc_type\t\tType of SoC, either 'cyclone5' or 'arria5'," + echo " input_dir\t\tDirectory with the QTS project." + echo " output_dir\t\tDirectory to store the U-Boot compatible headers." + echo "" +} + +soc="$1" +in_dir="$2" +out_dir="$3" + +if [ "$#" -ne 3 ] ; then + usage + exit 1 +fi + +if [ ! -d "${in_dir}" -o ! -d "${out_dir}" -o -z "${soc}" ] ; then + usage + exit 3 +fi + +process_iocsr_config "${soc}" "${in_dir}" "${out_dir}" +process_pinmux_config "${soc}" "${in_dir}" "${out_dir}" +process_pll_config "${soc}" "${in_dir}" "${out_dir}" +process_sdram_config "${soc}" "${in_dir}" "${out_dir}"
Signed-off-by: Marek Vasut marex@denx.de --- arch/arm/mach-socfpga/wrap_iocsr_config.c | 7 +- arch/arm/mach-socfpga/wrap_pinmux_config.c | 23 +- arch/arm/mach-socfpga/wrap_sdram_config.c | 8 +- board/altera/arria5-socdk/qts/iocsr_config.c | 693 -------------------- board/altera/arria5-socdk/qts/iocsr_config.h | 699 ++++++++++++++++++++- board/altera/arria5-socdk/qts/pinmux_config.c | 214 ------- board/altera/arria5-socdk/qts/pinmux_config.h | 265 ++++++-- board/altera/arria5-socdk/qts/pll_config.h | 172 +++-- board/altera/arria5-socdk/qts/sdram_config.h | 362 +++++++++-- board/altera/arria5-socdk/qts/sequencer_auto.h | 108 ---- .../arria5-socdk/qts/sequencer_auto_ac_init.h | 45 -- .../arria5-socdk/qts/sequencer_auto_inst_init.h | 135 ---- board/altera/arria5-socdk/qts/sequencer_defines.h | 87 --- board/altera/cyclone5-socdk/qts/iocsr_config.c | 657 ------------------- board/altera/cyclone5-socdk/qts/iocsr_config.h | 663 ++++++++++++++++++- board/altera/cyclone5-socdk/qts/pinmux_config.c | 214 ------- board/altera/cyclone5-socdk/qts/pinmux_config.h | 265 ++++++-- board/altera/cyclone5-socdk/qts/pll_config.h | 172 +++-- board/altera/cyclone5-socdk/qts/sdram_config.h | 364 +++++++++-- board/altera/cyclone5-socdk/qts/sequencer_auto.h | 108 ---- .../cyclone5-socdk/qts/sequencer_auto_ac_init.h | 44 -- .../cyclone5-socdk/qts/sequencer_auto_inst_init.h | 136 ---- .../altera/cyclone5-socdk/qts/sequencer_defines.h | 87 --- 23 files changed, 2546 insertions(+), 2982 deletions(-) delete mode 100644 board/altera/arria5-socdk/qts/iocsr_config.c delete mode 100644 board/altera/arria5-socdk/qts/pinmux_config.c delete mode 100644 board/altera/arria5-socdk/qts/sequencer_auto.h delete mode 100644 board/altera/arria5-socdk/qts/sequencer_auto_ac_init.h delete mode 100644 board/altera/arria5-socdk/qts/sequencer_auto_inst_init.h delete mode 100644 board/altera/arria5-socdk/qts/sequencer_defines.h delete mode 100644 board/altera/cyclone5-socdk/qts/iocsr_config.c delete mode 100644 board/altera/cyclone5-socdk/qts/pinmux_config.c delete mode 100644 board/altera/cyclone5-socdk/qts/sequencer_auto.h delete mode 100644 board/altera/cyclone5-socdk/qts/sequencer_auto_ac_init.h delete mode 100644 board/altera/cyclone5-socdk/qts/sequencer_auto_inst_init.h delete mode 100644 board/altera/cyclone5-socdk/qts/sequencer_defines.h
diff --git a/arch/arm/mach-socfpga/wrap_iocsr_config.c b/arch/arm/mach-socfpga/wrap_iocsr_config.c index 31b5426..5e3f057 100644 --- a/arch/arm/mach-socfpga/wrap_iocsr_config.c +++ b/arch/arm/mach-socfpga/wrap_iocsr_config.c @@ -7,10 +7,9 @@ #include <common.h> #include <errno.h> #include <asm/arch/clock_manager.h> -/* - * Yes, dear reader, we're including a C file here, this is no mistake :-) - */ -#include <qts/iocsr_config.c> + +/* Board-specific header. */ +#include <qts/iocsr_config.h>
int iocsr_get_config_table(const unsigned int chain_id, const unsigned long **table, diff --git a/arch/arm/mach-socfpga/wrap_pinmux_config.c b/arch/arm/mach-socfpga/wrap_pinmux_config.c index 688f1e4..bcb7781 100644 --- a/arch/arm/mach-socfpga/wrap_pinmux_config.c +++ b/arch/arm/mach-socfpga/wrap_pinmux_config.c @@ -6,26 +6,9 @@
#include <common.h> #include <errno.h> -/* - * Yes, dear reader, we're including a C file here, this is no mistake. - * But this time around, we do even more perverse hacking here to be - * compatible with QTS headers and obtain reasonably nice results too. - * - * First, we define _PRELOADER_PINMUX_CONFIG_H_, which will neutralise - * the pinmux_config.h inclusion in pinmux_config.c . Since we are - * probing everything from DT, we do NOT want those macros from the - * pinmux_config.h to ooze into our build system, anywhere, ever. So - * we nip it at the bud. - * - * Next, pinmux_config.c needs CONFIG_HPS_PINMUX_NUM and uses it to - * specify sized array explicitly. Instead, we want to use ARRAY_SIZE - * to figure out the size of the array, so define this macro as an - * empty one, so that the preprocessor optimizes things such that the - * arrays are not sized by default. - */ -#define _PRELOADER_PINMUX_CONFIG_H_ -#define CONFIG_HPS_PINMUX_NUM -#include <qts/pinmux_config.c> + +/* Board-specific header. */ +#include <qts/pinmux_config.h>
void sysmgr_get_pinmux_table(const unsigned long **table, unsigned int *table_len) diff --git a/arch/arm/mach-socfpga/wrap_sdram_config.c b/arch/arm/mach-socfpga/wrap_sdram_config.c index 72ce565..31cc7de 100644 --- a/arch/arm/mach-socfpga/wrap_sdram_config.c +++ b/arch/arm/mach-socfpga/wrap_sdram_config.c @@ -7,13 +7,9 @@ #include <common.h> #include <errno.h> #include <asm/arch/sdram.h> -/* QTS output file. */ -#include <qts/sdram_config.h>
-#include <qts/sequencer_auto_ac_init.h> -#include <qts/sequencer_auto_inst_init.h> -#include <qts/sequencer_auto.h> -#include <qts/sequencer_defines.h> +/* Board-specific header. */ +#include <qts/sdram_config.h>
static const struct socfpga_sdram_config sdram_config = { .ctrl_cfg = diff --git a/board/altera/arria5-socdk/qts/iocsr_config.c b/board/altera/arria5-socdk/qts/iocsr_config.c deleted file mode 100644 index f588eda..0000000 diff --git a/board/altera/arria5-socdk/qts/iocsr_config.h b/board/altera/arria5-socdk/qts/iocsr_config.h index 857f19c..e2bb4bb 100644 --- a/board/altera/arria5-socdk/qts/iocsr_config.h +++ b/board/altera/arria5-socdk/qts/iocsr_config.h @@ -1,17 +1,696 @@ /* - * Copyright Altera Corporation (C) 2012-2014. All rights reserved + * Altera SoCFPGA IOCSR configuration * - * SPDX-License-Identifier: BSD-3-Clause + * SPDX-License-Identifier: BSD-3-Clause */
-/* This file is generated by Preloader Generator */ +#ifndef __SOCFPGA_IOCSR_CONFIG_H__ +#define __SOCFPGA_IOCSR_CONFIG_H__
-#ifndef _PRELOADER_IOCSR_CONFIG_H_ -#define _PRELOADER_IOCSR_CONFIG_H_ +#define CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH 1337 +#define CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH 1719 +#define CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH 1528 +#define CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH 16766
-#define CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH (1337) -#define CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH (1719) -#define CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH (1528) -#define CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH (16766) +const unsigned long iocsr_scan_chain0_table[] = { + 0x00000000, + 0x00000000, + 0x00000000, + 0x00000000, + 0x00000000, + 0x00008000, + 0x00060180, + 0x18060000, + 0x18000060, + 0x00018060, + 0x06018060, + 0x00004000, + 0x0C0300C0, + 0x0C030000, + 0x00000030, + 0x00000000, + 0x00000000, + 0x00002000, + 0x00000000, + 0x00000000, + 0x06000000, + 0x00006018, + 0x01806018, + 0x00001000, + 0x0000C030, + 0x04000000, + 0x03000000, + 0x0000300C, + 0x00000000, + 0x00000800, + 0x00006018, + 0x01806000, + 0x01800000, + 0x00000006, + 0x00001806, + 0x00000400, + 0x0000300C, + 0x00C03000, + 0x00C00000, + 0x00000003, + 0x00000C03, + 0x00000200, +};
-#endif /*_PRELOADER_IOCSR_CONFIG_H_*/ +const unsigned long iocsr_scan_chain1_table[] = { + 0x00100000, + 0x300C0000, + 0x300000C0, + 0x000000C0, + 0x000300C0, + 0x00008000, + 0x00060180, + 0x18060000, + 0x18000000, + 0x00000060, + 0x00018060, + 0x00004000, + 0x000300C0, + 0x10000000, + 0x0C000000, + 0x00000030, + 0x0000C030, + 0x00002000, + 0x06018060, + 0x06018000, + 0x01FE0000, + 0xF8000000, + 0x00000007, + 0x00001000, + 0x0000C030, + 0x0300C000, + 0x03000000, + 0x0000300C, + 0x0000300C, + 0x00000800, + 0x00006018, + 0x01806000, + 0x01800000, + 0x00000006, + 0x00002000, + 0x00000400, + 0x0000300C, + 0x01000000, + 0x00000000, + 0x00000004, + 0x00000C03, + 0x00000200, + 0x00001806, + 0x00800000, + 0x00000000, + 0x00000002, + 0x00000800, + 0x00000100, + 0x00001000, + 0x00400000, + 0xC0300000, + 0x00000000, + 0x00000400, + 0x00000080, +}; + +const unsigned long iocsr_scan_chain2_table[] = { + 0x00100000, + 0x40000000, + 0x00000000, + 0x00000100, + 0x00040000, + 0x00008000, + 0x18060180, + 0x20000000, + 0x00000000, + 0x00000080, + 0x00020000, + 0x00004000, + 0x00040000, + 0x10000000, + 0x00000000, + 0x00000000, + 0x00010000, + 0x00002000, + 0x10038060, + 0x00000000, + 0x00000000, + 0x00000020, + 0x01806018, + 0x00001000, + 0x00010000, + 0x04000000, + 0x03000000, + 0x0000801C, + 0x00004000, + 0x00000800, + 0x01806018, + 0x02000000, + 0x00000000, + 0x00000008, + 0x00002000, + 0x00000400, + 0x00C0300C, + 0x00C03000, + 0x00C00003, + 0x00000C03, + 0x00300C03, + 0x00000200, + 0x00601806, + 0x80601800, + 0x80600001, + 0x80000601, + 0x00180601, + 0x00000100, +}; + +const unsigned long iocsr_scan_chain3_table[] = { + 0x2C820D80, + 0x082000FF, + 0x0A804001, + 0x07900000, + 0x08020000, + 0x00100000, + 0x0A800000, + 0x07900000, + 0x08020000, + 0x00100000, + 0xC8800000, + 0x00003001, + 0x00C00722, + 0x00000000, + 0x00000021, + 0x82000004, + 0x05400000, + 0x03C80000, + 0x04010000, + 0x00080000, + 0x05400000, + 0x03C80000, + 0x05400000, + 0x03C80000, + 0xE4400000, + 0x00001800, + 0x00600391, + 0x800E4400, + 0x00000001, + 0x40000002, + 0x02A00000, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x72200000, + 0x80000C00, + 0x003001C8, + 0xC0072200, + 0x1C880000, + 0x20000300, + 0x00040000, + 0x50670000, + 0x00000050, + 0x24590000, + 0x00001000, + 0xA0000034, + 0x0D000001, + 0x906808A2, + 0xA2834024, + 0x05141A00, + 0x808A20D0, + 0x34024906, + 0x01A00A28, + 0xA20D0000, + 0x24906808, + 0x00A28340, + 0xD000001A, + 0x06808A20, + 0x10040000, + 0x00200000, + 0x10040000, + 0x00200000, + 0x15000000, + 0x0F200000, + 0x15000000, + 0x0F200000, + 0x01FE0000, + 0x00000000, + 0x01800E44, + 0x00391000, + 0x007F8006, + 0x00000000, + 0x0A800001, + 0x07900000, + 0x0A800000, + 0x07900000, + 0x0A800000, + 0x07900000, + 0x08020000, + 0x00100000, + 0xC8800000, + 0x00003001, + 0x00C00722, + 0x00000FF0, + 0x72200000, + 0x80000C00, + 0x05400000, + 0x02480000, + 0x04000000, + 0x00080000, + 0x05400000, + 0x03C80000, + 0x05400000, + 0x03C80000, + 0x6A1C0000, + 0x00001800, + 0x00600391, + 0x800E4400, + 0x1A870001, + 0x40000600, + 0x02A00040, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x72200000, + 0x80000C00, + 0x003001C8, + 0xC0072200, + 0x1C880000, + 0x20000300, + 0x00040000, + 0x50670000, + 0x00000050, + 0x24590000, + 0x00001000, + 0xA0000034, + 0x0D000001, + 0x906808A2, + 0xA2834024, + 0x05141A00, + 0x808A20D0, + 0x34024906, + 0x01A00040, + 0xA20D0002, + 0x24906808, + 0x00A28340, + 0xD005141A, + 0x06808A20, + 0x10040000, + 0x00200000, + 0x10040000, + 0x00200000, + 0x15000000, + 0x0F200000, + 0x15000000, + 0x0F200000, + 0x01FE0000, + 0x00000000, + 0x01800E44, + 0x00391000, + 0x007F8006, + 0x00000000, + 0x99300001, + 0x34343400, + 0xAA0D4000, + 0x01C3A810, + 0xAA0D4000, + 0x01C3A808, + 0xAA0D4000, + 0x01C3A810, + 0x00040100, + 0x00000800, + 0x00000000, + 0x00001208, + 0x00482000, + 0x01000000, + 0x00000000, + 0x00410482, + 0x0006A000, + 0x0001B400, + 0x00020000, + 0x00000400, + 0x0002A000, + 0x0001E400, + 0x5506A000, + 0x00E1D404, + 0x00000000, + 0xC880090C, + 0x00003001, + 0x90400000, + 0x00000000, + 0x2020C243, + 0x2A835000, + 0x0070EA04, + 0x2A835000, + 0x0070EA02, + 0x2A835000, + 0x0070EA04, + 0x00010040, + 0x00000200, + 0x00000000, + 0x00000482, + 0x00120800, + 0x00002000, + 0x80000000, + 0x00104120, + 0x00000200, + 0xAC055F80, + 0xFFFFFFFF, + 0x14F3690D, + 0x1A041414, + 0x00D00000, + 0x14864000, + 0x59647A05, + 0xBA28A3D8, + 0xF511451E, + 0x0341D348, + 0x821A0000, + 0x0000D000, + 0x04510680, + 0xD859647A, + 0x1EBA28A3, + 0x48F51145, + 0x000341D3, + 0x00080200, + 0x00001000, + 0x00080200, + 0x00001000, + 0x000A8000, + 0x00075000, + 0x541A8000, + 0x03875011, + 0x10000000, + 0x00000000, + 0x0080C000, + 0x41000000, + 0x00003FC2, + 0x00820000, + 0xAA0D4000, + 0x01C3A810, + 0xAA0D4000, + 0x01C3A808, + 0xAA0D4000, + 0x01C3A810, + 0x00040100, + 0x00000800, + 0x00000000, + 0x00001208, + 0x00482000, + 0x00008000, + 0x00000000, + 0x00410482, + 0x0006A000, + 0x0001B400, + 0x00020000, + 0x00000400, + 0x00020080, + 0x00000400, + 0x5506A000, + 0x00E1D404, + 0x00000000, + 0x0000090C, + 0x00000010, + 0x90400000, + 0x00000000, + 0x2020C243, + 0x2A835000, + 0x0070EA04, + 0x2A835000, + 0x0070EA02, + 0x2A835000, + 0x0070EA04, + 0x00015000, + 0x0000F200, + 0x00000000, + 0x00000482, + 0x00120800, + 0x00600391, + 0x80000000, + 0x00104120, + 0x00000200, + 0xAC055F80, + 0xFFFFFFFF, + 0x14F3690D, + 0x1A041414, + 0x00D00000, + 0x14864000, + 0x59647A05, + 0xBA28A3D8, + 0xF511451E, + 0x8341D348, + 0x821A0124, + 0x0000D000, + 0x00000680, + 0xD859647A, + 0x1EBA28A3, + 0x48F51145, + 0x000341D3, + 0x00080200, + 0x00001000, + 0x00080200, + 0x00001000, + 0x000A8000, + 0x00075000, + 0x541A8000, + 0x03875011, + 0x10000000, + 0x00000000, + 0x0080C000, + 0x41000000, + 0x04000002, + 0x00820000, + 0xAA0D4000, + 0x01C3A810, + 0xAA0D4000, + 0x01C3A808, + 0xAA0D4000, + 0x01C3A810, + 0x00040100, + 0x00000800, + 0x00000000, + 0x00001208, + 0x00482000, + 0x00008000, + 0x00000000, + 0x00410482, + 0x0006A000, + 0x0001B400, + 0x00020000, + 0x00000400, + 0x0002A000, + 0x0001E400, + 0x5506A000, + 0x00E1D404, + 0x00000000, + 0xC880090C, + 0x00003001, + 0x90400000, + 0x00000000, + 0x2020C243, + 0x2A835000, + 0x0070EA04, + 0x2A835000, + 0x0070EA02, + 0x2A835000, + 0x0070EA04, + 0x00010040, + 0x00000200, + 0x00000000, + 0x00000482, + 0x00120800, + 0x00002000, + 0x80000000, + 0x00104120, + 0x00000200, + 0xAC055F80, + 0xFFFFFFFF, + 0x14F3690D, + 0x1A041414, + 0x00D00000, + 0x14864000, + 0x59647A05, + 0xBA28A3D8, + 0xF511451E, + 0x0341D348, + 0x821A0000, + 0x0000D000, + 0x00000680, + 0xD859647A, + 0x1EBA28A3, + 0x48F51145, + 0x000341D3, + 0x00080200, + 0x00001000, + 0x00080200, + 0x00001000, + 0x000A8000, + 0x00075000, + 0x541A8000, + 0x03875011, + 0x10000000, + 0x00000000, + 0x0080C000, + 0x41000000, + 0x04000002, + 0x00820000, + 0xAA0D4000, + 0x01C3A810, + 0xAA0D4000, + 0x01C3A808, + 0xAA0D4000, + 0x01C3A810, + 0x00040100, + 0x00000800, + 0x00000000, + 0x00001208, + 0x00482000, + 0x00008000, + 0x00000000, + 0x00410482, + 0x0006A000, + 0x0001B400, + 0x00020000, + 0x00000400, + 0x00020080, + 0x00000400, + 0x5506A000, + 0x00E1D404, + 0x00000000, + 0x0000090C, + 0x00000010, + 0x90400000, + 0x00000000, + 0x2020C243, + 0x2A835000, + 0x0070EA04, + 0x2A835000, + 0x0070EA02, + 0x2A835000, + 0x0070EA04, + 0x00010040, + 0x00000200, + 0x00000000, + 0x00000482, + 0x00120800, + 0x00400000, + 0x80000000, + 0x00104120, + 0x00000200, + 0xAC055F80, + 0xFFFFFFFF, + 0x14F1690D, + 0x1A041414, + 0x00D00000, + 0x14864000, + 0x59647A05, + 0xBA28A3D8, + 0xF511451E, + 0x0341D348, + 0x821A0000, + 0x0000D000, + 0x00000680, + 0xD859647A, + 0x1EBA28A3, + 0x48F51145, + 0x000341D3, + 0x00080200, + 0x00001000, + 0x00080200, + 0x00001000, + 0x000A8000, + 0x00075000, + 0x541A8000, + 0x03875011, + 0x10000000, + 0x00000000, + 0x0080C000, + 0x41000000, + 0x04000002, + 0x00820000, + 0x00481800, + 0x001A1A1A, + 0x085506A0, + 0x0000E1D4, + 0x045506A0, + 0x0000E1D4, + 0x085506A0, + 0x8000E1D4, + 0x00000200, + 0x00000004, + 0x04000000, + 0x00000009, + 0x00002410, + 0x00000040, + 0x41000000, + 0x00002082, + 0x00000350, + 0x000000DA, + 0x00000100, + 0x40000002, + 0x00000100, + 0x00000002, + 0x022A8350, + 0x000070EA, + 0x86000000, + 0x08000004, + 0x00000000, + 0x00482000, + 0x21800000, + 0x00101061, + 0x021541A8, + 0x00003875, + 0x011541A8, + 0x00003875, + 0x021541A8, + 0x20003875, + 0x00000080, + 0x00000001, + 0x41000000, + 0x00000002, + 0x00FF0904, + 0x00000000, + 0x90400000, + 0x00000820, + 0xC0000001, + 0xFFD602AF, + 0x86FFFFFF, + 0x0A0A78B4, + 0x000D020A, + 0x00006800, + 0x028A4320, + 0xEC2CB23D, + 0x8F5D1451, + 0xA47A88A2, + 0x0001A0E9, + 0x00410D00, + 0x40000068, + 0x3D000003, + 0x51EC2CB2, + 0xA28F5D14, + 0xE9A47A88, + 0x000001A0, + 0x00000401, + 0x00000008, + 0x00000401, + 0x00000008, + 0x00000540, + 0x000003A8, + 0x08AA0D40, + 0x8001C3A8, + 0x0000007F, + 0x00000000, + 0x00004060, + 0xE1208000, + 0x0000001F, + 0x00004100, +}; + + +#endif /* __SOCFPGA_IOCSR_CONFIG_H__ */ diff --git a/board/altera/arria5-socdk/qts/pinmux_config.c b/board/altera/arria5-socdk/qts/pinmux_config.c deleted file mode 100644 index bf987f9..0000000 diff --git a/board/altera/arria5-socdk/qts/pinmux_config.h b/board/altera/arria5-socdk/qts/pinmux_config.h index 21fabb0..5a714a3 100644 --- a/board/altera/arria5-socdk/qts/pinmux_config.h +++ b/board/altera/arria5-socdk/qts/pinmux_config.h @@ -1,54 +1,219 @@ -/* This file is generated by Preloader Generator */ - -#ifndef _PRELOADER_PINMUX_CONFIG_H_ -#define _PRELOADER_PINMUX_CONFIG_H_ - /* - * State of enabling for which IP connected out through the muxing. - * Value 1 mean the IP connection is muxed out + * Altera SoCFPGA PinMux configuration + * + * SPDX-License-Identifier: BSD-3-Clause */ -#define CONFIG_HPS_EMAC0 (1) -#define CONFIG_HPS_EMAC1 (0) -#define CONFIG_HPS_USB0 (0) -#define CONFIG_HPS_USB1 (1) -#define CONFIG_HPS_NAND (0) -#define CONFIG_HPS_SDMMC (1) -#define CONFIG_HPS_QSPI (0) -#define CONFIG_HPS_UART0 (1) -#define CONFIG_HPS_UART1 (0) -#define CONFIG_HPS_TRACE (0) -#define CONFIG_HPS_I2C0 (1) -#define CONFIG_HPS_I2C1 (0) -#define CONFIG_HPS_I2C2 (0) -#define CONFIG_HPS_I2C3 (0) -#define CONFIG_HPS_SPIM0 (0) -#define CONFIG_HPS_SPIM1 (0) -#define CONFIG_HPS_SPIS0 (0) -#define CONFIG_HPS_SPIS1 (0) -#define CONFIG_HPS_CAN0 (1) -#define CONFIG_HPS_CAN1 (0) - -/* IP attribute value (which affected by pin muxing configuration) */ -#define CONFIG_HPS_SDMMC_BUSWIDTH (8) - -/* 1 if the pins are connected out */ -#define CONFIG_HPS_QSPI_CS0 (0) -#define CONFIG_HPS_QSPI_CS1 (0) -#define CONFIG_HPS_QSPI_CS2 (0) -#define CONFIG_HPS_QSPI_CS3 (0) - -/* UART */ -/* 1 means the pin is mux out or available */ -#define CONFIG_HPS_UART0_TX (1) -#define CONFIG_HPS_UART0_RX (1) -#define CONFIG_HPS_UART0_CTS (0) -#define CONFIG_HPS_UART0_RTS (0) -#define CONFIG_HPS_UART1_TX (0) -#define CONFIG_HPS_UART1_RX (0) -#define CONFIG_HPS_UART1_CTS (0) -#define CONFIG_HPS_UART1_RTS (0)
-/* Pin mux data */ -#define CONFIG_HPS_PINMUX_NUM (207) +#ifndef __SOCFPGA_PINMUX_CONFIG_H__ +#define __SOCFPGA_PINMUX_CONFIG_H__
-#endif /* _PRELOADER_PINMUX_CONFIG_H_ */ +unsigned long sys_mgr_init_table[] = { + 0, /* EMACIO0 */ + 2, /* EMACIO1 */ + 2, /* EMACIO2 */ + 2, /* EMACIO3 */ + 2, /* EMACIO4 */ + 2, /* EMACIO5 */ + 2, /* EMACIO6 */ + 2, /* EMACIO7 */ + 2, /* EMACIO8 */ + 0, /* EMACIO9 */ + 2, /* EMACIO10 */ + 2, /* EMACIO11 */ + 2, /* EMACIO12 */ + 2, /* EMACIO13 */ + 3, /* EMACIO14 */ + 3, /* EMACIO15 */ + 3, /* EMACIO16 */ + 3, /* EMACIO17 */ + 3, /* EMACIO18 */ + 3, /* EMACIO19 */ + 3, /* FLASHIO0 */ + 0, /* FLASHIO1 */ + 3, /* FLASHIO2 */ + 3, /* FLASHIO3 */ + 0, /* FLASHIO4 */ + 0, /* FLASHIO5 */ + 0, /* FLASHIO6 */ + 0, /* FLASHIO7 */ + 0, /* FLASHIO8 */ + 3, /* FLASHIO9 */ + 3, /* FLASHIO10 */ + 3, /* FLASHIO11 */ + 3, /* GENERALIO0 */ + 3, /* GENERALIO1 */ + 3, /* GENERALIO2 */ + 3, /* GENERALIO3 */ + 3, /* GENERALIO4 */ + 3, /* GENERALIO5 */ + 3, /* GENERALIO6 */ + 3, /* GENERALIO7 */ + 3, /* GENERALIO8 */ + 0, /* GENERALIO9 */ + 0, /* GENERALIO10 */ + 0, /* GENERALIO11 */ + 0, /* GENERALIO12 */ + 0, /* GENERALIO13 */ + 0, /* GENERALIO14 */ + 3, /* GENERALIO15 */ + 3, /* GENERALIO16 */ + 2, /* GENERALIO17 */ + 2, /* GENERALIO18 */ + 0, /* GENERALIO19 */ + 0, /* GENERALIO20 */ + 0, /* GENERALIO21 */ + 0, /* GENERALIO22 */ + 3, /* GENERALIO23 */ + 3, /* GENERALIO24 */ + 0, /* GENERALIO25 */ + 0, /* GENERALIO26 */ + 0, /* GENERALIO27 */ + 0, /* GENERALIO28 */ + 0, /* GENERALIO29 */ + 0, /* GENERALIO30 */ + 0, /* GENERALIO31 */ + 0, /* MIXED1IO0 */ + 0, /* MIXED1IO1 */ + 0, /* MIXED1IO2 */ + 0, /* MIXED1IO3 */ + 0, /* MIXED1IO4 */ + 0, /* MIXED1IO5 */ + 0, /* MIXED1IO6 */ + 0, /* MIXED1IO7 */ + 0, /* MIXED1IO8 */ + 0, /* MIXED1IO9 */ + 0, /* MIXED1IO10 */ + 0, /* MIXED1IO11 */ + 0, /* MIXED1IO12 */ + 0, /* MIXED1IO13 */ + 0, /* MIXED1IO14 */ + 3, /* MIXED1IO15 */ + 3, /* MIXED1IO16 */ + 3, /* MIXED1IO17 */ + 3, /* MIXED1IO18 */ + 3, /* MIXED1IO19 */ + 3, /* MIXED1IO20 */ + 0, /* MIXED1IO21 */ + 3, /* MIXED2IO0 */ + 3, /* MIXED2IO1 */ + 3, /* MIXED2IO2 */ + 3, /* MIXED2IO3 */ + 3, /* MIXED2IO4 */ + 3, /* MIXED2IO5 */ + 3, /* MIXED2IO6 */ + 3, /* MIXED2IO7 */ + 0, /* GPLINMUX48 */ + 0, /* GPLINMUX49 */ + 0, /* GPLINMUX50 */ + 0, /* GPLINMUX51 */ + 0, /* GPLINMUX52 */ + 0, /* GPLINMUX53 */ + 0, /* GPLINMUX54 */ + 0, /* GPLINMUX55 */ + 0, /* GPLINMUX56 */ + 0, /* GPLINMUX57 */ + 0, /* GPLINMUX58 */ + 0, /* GPLINMUX59 */ + 0, /* GPLINMUX60 */ + 0, /* GPLINMUX61 */ + 0, /* GPLINMUX62 */ + 0, /* GPLINMUX63 */ + 0, /* GPLINMUX64 */ + 0, /* GPLINMUX65 */ + 0, /* GPLINMUX66 */ + 0, /* GPLINMUX67 */ + 0, /* GPLINMUX68 */ + 0, /* GPLINMUX69 */ + 0, /* GPLINMUX70 */ + 1, /* GPLMUX0 */ + 1, /* GPLMUX1 */ + 1, /* GPLMUX2 */ + 1, /* GPLMUX3 */ + 1, /* GPLMUX4 */ + 1, /* GPLMUX5 */ + 1, /* GPLMUX6 */ + 1, /* GPLMUX7 */ + 1, /* GPLMUX8 */ + 1, /* GPLMUX9 */ + 1, /* GPLMUX10 */ + 1, /* GPLMUX11 */ + 1, /* GPLMUX12 */ + 1, /* GPLMUX13 */ + 1, /* GPLMUX14 */ + 1, /* GPLMUX15 */ + 1, /* GPLMUX16 */ + 1, /* GPLMUX17 */ + 1, /* GPLMUX18 */ + 1, /* GPLMUX19 */ + 1, /* GPLMUX20 */ + 1, /* GPLMUX21 */ + 1, /* GPLMUX22 */ + 1, /* GPLMUX23 */ + 1, /* GPLMUX24 */ + 1, /* GPLMUX25 */ + 1, /* GPLMUX26 */ + 1, /* GPLMUX27 */ + 1, /* GPLMUX28 */ + 1, /* GPLMUX29 */ + 1, /* GPLMUX30 */ + 1, /* GPLMUX31 */ + 1, /* GPLMUX32 */ + 1, /* GPLMUX33 */ + 1, /* GPLMUX34 */ + 1, /* GPLMUX35 */ + 1, /* GPLMUX36 */ + 1, /* GPLMUX37 */ + 1, /* GPLMUX38 */ + 1, /* GPLMUX39 */ + 1, /* GPLMUX40 */ + 1, /* GPLMUX41 */ + 1, /* GPLMUX42 */ + 1, /* GPLMUX43 */ + 1, /* GPLMUX44 */ + 1, /* GPLMUX45 */ + 1, /* GPLMUX46 */ + 1, /* GPLMUX47 */ + 1, /* GPLMUX48 */ + 1, /* GPLMUX49 */ + 1, /* GPLMUX50 */ + 1, /* GPLMUX51 */ + 1, /* GPLMUX52 */ + 1, /* GPLMUX53 */ + 1, /* GPLMUX54 */ + 1, /* GPLMUX55 */ + 1, /* GPLMUX56 */ + 1, /* GPLMUX57 */ + 1, /* GPLMUX58 */ + 1, /* GPLMUX59 */ + 1, /* GPLMUX60 */ + 1, /* GPLMUX61 */ + 1, /* GPLMUX62 */ + 1, /* GPLMUX63 */ + 1, /* GPLMUX64 */ + 1, /* GPLMUX65 */ + 1, /* GPLMUX66 */ + 1, /* GPLMUX67 */ + 1, /* GPLMUX68 */ + 1, /* GPLMUX69 */ + 1, /* GPLMUX70 */ + 0, /* NANDUSEFPGA */ + 0, /* UART0USEFPGA */ + 0, /* RGMII1USEFPGA */ + 0, /* SPIS0USEFPGA */ + 0, /* CAN0USEFPGA */ + 0, /* I2C0USEFPGA */ + 0, /* SDMMCUSEFPGA */ + 0, /* QSPIUSEFPGA */ + 0, /* SPIS1USEFPGA */ + 0, /* RGMII0USEFPGA */ + 0, /* UART1USEFPGA */ + 0, /* CAN1USEFPGA */ + 0, /* USB1USEFPGA */ + 0, /* I2C3USEFPGA */ + 0, /* I2C2USEFPGA */ + 0, /* I2C1USEFPGA */ + 0, /* SPIM1USEFPGA */ + 0, /* USB0USEFPGA */ + 0 /* SPIM0USEFPGA */ +}; +#endif /* __SOCFPGA_PINMUX_CONFIG_H__ */ diff --git a/board/altera/arria5-socdk/qts/pll_config.h b/board/altera/arria5-socdk/qts/pll_config.h index 7cd25df..3d621ed 100644 --- a/board/altera/arria5-socdk/qts/pll_config.h +++ b/board/altera/arria5-socdk/qts/pll_config.h @@ -1,109 +1,85 @@ /* - * Copyright Altera Corporation (C) 2012-2014. All rights reserved + * Altera SoCFPGA Clock and PLL configuration * - * SPDX-License-Identifier: BSD-3-Clause + * SPDX-License-Identifier: BSD-3-Clause */
-/* This file is generated by Preloader Generator */ +#ifndef __SOCFPGA_PLL_CONFIG_H__ +#define __SOCFPGA_PLL_CONFIG_H__
-#ifndef _PRELOADER_PLL_CONFIG_H_ -#define _PRELOADER_PLL_CONFIG_H_ +#define CONFIG_HPS_DBCTRL_STAYOSC1 1
-/* PLL configuration data */ -/* Main PLL */ -#define CONFIG_HPS_MAINPLLGRP_VCO_DENOM (0) -#define CONFIG_HPS_MAINPLLGRP_VCO_NUMER (63) -#define CONFIG_HPS_MAINPLLGRP_MPUCLK_CNT (0) -#define CONFIG_HPS_MAINPLLGRP_MAINCLK_CNT (0) -#define CONFIG_HPS_MAINPLLGRP_DBGATCLK_CNT (0) -#define CONFIG_HPS_MAINPLLGRP_MAINQSPICLK_CNT (511) -#define CONFIG_HPS_MAINPLLGRP_MAINNANDSDMMCCLK_CNT (511) -#define CONFIG_HPS_MAINPLLGRP_CFGS2FUSER0CLK_CNT (15) -#define CONFIG_HPS_MAINPLLGRP_MAINDIV_L3MPCLK (1) -#define CONFIG_HPS_MAINPLLGRP_MAINDIV_L3SPCLK (1) -#define CONFIG_HPS_MAINPLLGRP_MAINDIV_L4MPCLK (1) -#define CONFIG_HPS_MAINPLLGRP_MAINDIV_L4SPCLK (1) -#define CONFIG_HPS_MAINPLLGRP_DBGDIV_DBGATCLK (0) -#define CONFIG_HPS_MAINPLLGRP_DBGDIV_DBGCLK (1) -#define CONFIG_HPS_MAINPLLGRP_TRACEDIV_TRACECLK (0) -/* - * To tell where is the clock source: - * 0 = MAINPLL - * 1 = PERIPHPLL - */ -#define CONFIG_HPS_MAINPLLGRP_L4SRC_L4MP (1) -#define CONFIG_HPS_MAINPLLGRP_L4SRC_L4SP (1) +#define CONFIG_HPS_MAINPLLGRP_VCO_DENOM 0 +#define CONFIG_HPS_MAINPLLGRP_VCO_NUMER 63 +#define CONFIG_HPS_MAINPLLGRP_MPUCLK_CNT 0 +#define CONFIG_HPS_MAINPLLGRP_MAINCLK_CNT 0 +#define CONFIG_HPS_MAINPLLGRP_DBGATCLK_CNT 0 +#define CONFIG_HPS_MAINPLLGRP_MAINQSPICLK_CNT 511 +#define CONFIG_HPS_MAINPLLGRP_MAINNANDSDMMCCLK_CNT 511 +#define CONFIG_HPS_MAINPLLGRP_CFGS2FUSER0CLK_CNT 15 +#define CONFIG_HPS_MAINPLLGRP_MAINDIV_L3MPCLK 1 +#define CONFIG_HPS_MAINPLLGRP_MAINDIV_L3SPCLK 1 +#define CONFIG_HPS_MAINPLLGRP_MAINDIV_L4MPCLK 1 +#define CONFIG_HPS_MAINPLLGRP_MAINDIV_L4SPCLK 1 +#define CONFIG_HPS_MAINPLLGRP_DBGDIV_DBGATCLK 0 +#define CONFIG_HPS_MAINPLLGRP_DBGDIV_DBGCLK 1 +#define CONFIG_HPS_MAINPLLGRP_TRACEDIV_TRACECLK 0 +#define CONFIG_HPS_MAINPLLGRP_L4SRC_L4MP 1 +#define CONFIG_HPS_MAINPLLGRP_L4SRC_L4SP 1
-/* Peripheral PLL */ -#define CONFIG_HPS_PERPLLGRP_VCO_DENOM (1) -#define CONFIG_HPS_PERPLLGRP_VCO_NUMER (79) -/* - * To tell where is the VCOs source: - * 0 = EOSC1 - * 1 = EOSC2 - * 2 = F2S - */ -#define CONFIG_HPS_PERPLLGRP_VCO_PSRC (0) -#define CONFIG_HPS_PERPLLGRP_EMAC0CLK_CNT (3) -#define CONFIG_HPS_PERPLLGRP_EMAC1CLK_CNT (511) -#define CONFIG_HPS_PERPLLGRP_PERQSPICLK_CNT (511) -#define CONFIG_HPS_PERPLLGRP_PERNANDSDMMCCLK_CNT (4) -#define CONFIG_HPS_PERPLLGRP_PERBASECLK_CNT (4) -#define CONFIG_HPS_PERPLLGRP_S2FUSER1CLK_CNT (511) -#define CONFIG_HPS_PERPLLGRP_DIV_USBCLK (0) -#define CONFIG_HPS_PERPLLGRP_DIV_SPIMCLK (4) -#define CONFIG_HPS_PERPLLGRP_DIV_CAN0CLK (1) -#define CONFIG_HPS_PERPLLGRP_DIV_CAN1CLK (1) -#define CONFIG_HPS_PERPLLGRP_GPIODIV_GPIODBCLK (6249) -/* - * To tell where is the clock source: - * 0 = F2S_PERIPH_REF_CLK - * 1 = MAIN_CLK - * 2 = PERIPH_CLK - */ -#define CONFIG_HPS_PERPLLGRP_SRC_SDMMC (2) -#define CONFIG_HPS_PERPLLGRP_SRC_NAND (2) -#define CONFIG_HPS_PERPLLGRP_SRC_QSPI (1) +#define CONFIG_HPS_PERPLLGRP_VCO_DENOM 1 +#define CONFIG_HPS_PERPLLGRP_VCO_NUMER 79 +#define CONFIG_HPS_PERPLLGRP_VCO_PSRC 0 +#define CONFIG_HPS_PERPLLGRP_EMAC0CLK_CNT 3 +#define CONFIG_HPS_PERPLLGRP_EMAC1CLK_CNT 511 +#define CONFIG_HPS_PERPLLGRP_PERQSPICLK_CNT 511 +#define CONFIG_HPS_PERPLLGRP_PERNANDSDMMCCLK_CNT 4 +#define CONFIG_HPS_PERPLLGRP_PERBASECLK_CNT 4 +#define CONFIG_HPS_PERPLLGRP_S2FUSER1CLK_CNT 511 +#define CONFIG_HPS_PERPLLGRP_DIV_USBCLK 0 +#define CONFIG_HPS_PERPLLGRP_DIV_SPIMCLK 4 +#define CONFIG_HPS_PERPLLGRP_DIV_CAN0CLK 1 +#define CONFIG_HPS_PERPLLGRP_DIV_CAN1CLK 1 +#define CONFIG_HPS_PERPLLGRP_GPIODIV_GPIODBCLK 6249 +#define CONFIG_HPS_PERPLLGRP_SRC_SDMMC 2 +#define CONFIG_HPS_PERPLLGRP_SRC_NAND 2 +#define CONFIG_HPS_PERPLLGRP_SRC_QSPI 1
-/* SDRAM PLL */ -#define CONFIG_HPS_SDRPLLGRP_VCO_DENOM (2) -#define CONFIG_HPS_SDRPLLGRP_VCO_NUMER (79) +#define CONFIG_HPS_SDRPLLGRP_VCO_DENOM 2 +#define CONFIG_HPS_SDRPLLGRP_VCO_NUMER 79 +#define CONFIG_HPS_SDRPLLGRP_VCO_SSRC 0 +#define CONFIG_HPS_SDRPLLGRP_DDRDQSCLK_CNT 1 +#define CONFIG_HPS_SDRPLLGRP_DDRDQSCLK_PHASE 0 +#define CONFIG_HPS_SDRPLLGRP_DDR2XDQSCLK_CNT 0 +#define CONFIG_HPS_SDRPLLGRP_DDR2XDQSCLK_PHASE 0 +#define CONFIG_HPS_SDRPLLGRP_DDRDQCLK_CNT 1 +#define CONFIG_HPS_SDRPLLGRP_DDRDQCLK_PHASE 4 +#define CONFIG_HPS_SDRPLLGRP_S2FUSER2CLK_CNT 5 +#define CONFIG_HPS_SDRPLLGRP_S2FUSER2CLK_PHASE 0
-/* - * To tell where is the VCOs source: - * 0 = EOSC1 - * 1 = EOSC2 - * 2 = F2S - */ -#define CONFIG_HPS_SDRPLLGRP_VCO_SSRC (0) -#define CONFIG_HPS_SDRPLLGRP_DDRDQSCLK_CNT (1) -#define CONFIG_HPS_SDRPLLGRP_DDRDQSCLK_PHASE (0) -#define CONFIG_HPS_SDRPLLGRP_DDR2XDQSCLK_CNT (0) -#define CONFIG_HPS_SDRPLLGRP_DDR2XDQSCLK_PHASE (0) -#define CONFIG_HPS_SDRPLLGRP_DDRDQCLK_CNT (1) -#define CONFIG_HPS_SDRPLLGRP_DDRDQCLK_PHASE (4) -#define CONFIG_HPS_SDRPLLGRP_S2FUSER2CLK_CNT (5) -#define CONFIG_HPS_SDRPLLGRP_S2FUSER2CLK_PHASE (0) +#define CONFIG_HPS_CLK_OSC1_HZ 25000000 +#define CONFIG_HPS_CLK_OSC2_HZ 25000000 +#define CONFIG_HPS_CLK_F2S_SDR_REF_HZ 0 +#define CONFIG_HPS_CLK_F2S_PER_REF_HZ 0 +#define CONFIG_HPS_CLK_MAINVCO_HZ 1600000000 +#define CONFIG_HPS_CLK_PERVCO_HZ 1000000000 +#define CONFIG_HPS_CLK_SDRVCO_HZ 666666666 +#define CONFIG_HPS_CLK_EMAC0_HZ 250000000 +#define CONFIG_HPS_CLK_EMAC1_HZ 250000000 +#define CONFIG_HPS_CLK_USBCLK_HZ 200000000 +#define CONFIG_HPS_CLK_NAND_HZ 50000000 +#define CONFIG_HPS_CLK_SDMMC_HZ 200000000 +#define CONFIG_HPS_CLK_QSPI_HZ 400000000 +#define CONFIG_HPS_CLK_SPIM_HZ 200000000 +#define CONFIG_HPS_CLK_CAN0_HZ 100000000 +#define CONFIG_HPS_CLK_CAN1_HZ 100000000 +#define CONFIG_HPS_CLK_GPIODB_HZ 32000 +#define CONFIG_HPS_CLK_L4_MP_HZ 100000000 +#define CONFIG_HPS_CLK_L4_SP_HZ 100000000 + +#define CONFIG_HPS_ALTERAGRP_MPUCLK 1 +#define CONFIG_HPS_ALTERAGRP_MAINCLK 3 +#define CONFIG_HPS_ALTERAGRP_DBGATCLK 3
-/* Info for driver */ -#define CONFIG_HPS_CLK_OSC1_HZ (25000000) -#define CONFIG_HPS_CLK_OSC2_HZ (25000000) -#define CONFIG_HPS_CLK_F2S_SDR_REF_HZ 0 -#define CONFIG_HPS_CLK_F2S_PER_REF_HZ 0 -#define CONFIG_HPS_CLK_MAINVCO_HZ (1600000000) -#define CONFIG_HPS_CLK_PERVCO_HZ (1000000000) -#define CONFIG_HPS_CLK_SDRVCO_HZ (666666666) -#define CONFIG_HPS_CLK_EMAC0_HZ (250000000) -#define CONFIG_HPS_CLK_EMAC1_HZ (250000000) -#define CONFIG_HPS_CLK_USBCLK_HZ (200000000) -#define CONFIG_HPS_CLK_NAND_HZ (50000000) -#define CONFIG_HPS_CLK_SDMMC_HZ (200000000) -#define CONFIG_HPS_CLK_QSPI_HZ (400000000) -#define CONFIG_HPS_CLK_SPIM_HZ (200000000) -#define CONFIG_HPS_CLK_CAN0_HZ (100000000) -#define CONFIG_HPS_CLK_CAN1_HZ (100000000) -#define CONFIG_HPS_CLK_GPIODB_HZ (32000) -#define CONFIG_HPS_CLK_L4_MP_HZ (100000000) -#define CONFIG_HPS_CLK_L4_SP_HZ (100000000)
-#endif /* _PRELOADER_PLL_CONFIG_H_ */ +#endif /* __SOCFPGA_PLL_CONFIG_H__ */ diff --git a/board/altera/arria5-socdk/qts/sdram_config.h b/board/altera/arria5-socdk/qts/sdram_config.h index 2e26ae5..e9fe60f 100644 --- a/board/altera/arria5-socdk/qts/sdram_config.h +++ b/board/altera/arria5-socdk/qts/sdram_config.h @@ -1,86 +1,340 @@ /* - * Copyright Altera Corporation (C) 2012-2015 + * Altera SoCFPGA SDRAM configuration * - * SPDX-License-Identifier: BSD-3-Clause + * SPDX-License-Identifier: BSD-3-Clause */
-/* This file is autogenerated from tools provided by Altera.*/ -#ifndef __SDRAM_CONFIG_H -#define __SDRAM_CONFIG_H +#ifndef __SOCFPGA_SDRAM_CONFIG_H__ +#define __SOCFPGA_SDRAM_CONFIG_H__
-#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMTYPE 2 -#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMBL 8 +/* SDRAM configuration */ +#define CONFIG_HPS_SDR_CTRLCFG_CPORTRDWR_CPORTRDWR 0x5A56A +#define CONFIG_HPS_SDR_CTRLCFG_CPORTRMAP_CPORTRMAP 0xB00088 +#define CONFIG_HPS_SDR_CTRLCFG_CPORTWIDTH_CPORTWIDTH 0x44555 +#define CONFIG_HPS_SDR_CTRLCFG_CPORTWMAP_CPORTWMAP 0x2C011000 #define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ADDRORDER 0 -#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ECCEN 1 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_DQSTRKEN 0 #define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ECCCORREN 1 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ECCEN 1 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMBL 8 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMTYPE 2 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_NODMPINS 0 #define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_REORDEREN 1 #define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_STARVELIMIT 10 -#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_DQSTRKEN 0 -#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_NODMPINS 0 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCWL 6 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLWIDTH_CTRLWIDTH 2 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_BANKBITS 3 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_COLBITS 10 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_CSBITS 1 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_ROWBITS 15 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMDEVWIDTH_DEVWIDTH 8 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMIFWIDTH_IFWIDTH 40 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMINTR_INTREN 0 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMODT_READ 0 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMODT_WRITE 1 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_AL 0 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCL 7 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRRD 4 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCWL 6 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TFAW 19 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRFC 139 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TREFI 4160 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRRD 4 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRCD 8 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TREFI 4160 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRP 8 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWR 8 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWTR 4 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRTP 4 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TCCD 4 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TMRD 4 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRAS 19 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRC 26 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TMRD 4 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TCCD 4 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_SELFRFSHEXIT 512 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRTP 4 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_PWRDOWNEXIT 3 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_SELFRFSHEXIT 512 +#define CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_INCSYNC 0 +#define CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_SYNCMODE 0 +#define CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST 0 +#define CONFIG_HPS_SDR_CTRLCFG_LOWPWREQ_SELFRFSHMASK 3 #define CONFIG_HPS_SDR_CTRLCFG_LOWPWRTIMING_AUTOPDCYCLES 0 #define CONFIG_HPS_SDR_CTRLCFG_LOWPWRTIMING_CLKDISABLECYCLES 8 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_COLBITS 10 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_ROWBITS 15 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_BANKBITS 3 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_CSBITS 1 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMIFWIDTH_IFWIDTH 40 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMDEVWIDTH_DEVWIDTH 8 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMINTR_INTREN 0 -#define CONFIG_HPS_SDR_CTRLCFG_LOWPWREQ_SELFRFSHMASK 3 -#define CONFIG_HPS_SDR_CTRLCFG_STATICCFG_MEMBL 2 -#define CONFIG_HPS_SDR_CTRLCFG_STATICCFG_USEECCASDATA 0 -#define CONFIG_HPS_SDR_CTRLCFG_CTRLWIDTH_CTRLWIDTH 2 -#define CONFIG_HPS_SDR_CTRLCFG_PORTCFG_AUTOPCHEN 0 -#define CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_SYNCMODE 0 -#define CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_INCSYNC 0 +#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_0_THRESHOLD1_31_0 0x20820820 +#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD1_59_32 0x8208208 +#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD2_3_0 0 +#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_2_THRESHOLD2_35_4 0x41041041 +#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_3_THRESHOLD2_59_36 0x410410 #define CONFIG_HPS_SDR_CTRLCFG_MPPRIORITY_USERPRIORITY 0x3FFD1088 +#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_0_THRESHOLDRSTCYCLES_31_0 0x01010101 +#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_1_THRESHOLDRSTCYCLES_63_32 0x01010101 +#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_2_THRESHOLDRSTCYCLES_79_64 0x0101 #define CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_0_STATICWEIGHT_31_0 0x21084210 #define CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_1_STATICWEIGHT_49_32 0x1EF84 #define CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_1_SUMOFWEIGHT_13_0 0x2020 #define CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_2_SUMOFWEIGHT_45_14 0x0 #define CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_3_SUMOFWEIGHT_63_46 0xF800 #define CONFIG_HPS_SDR_CTRLCFG_PHYCTRL_PHYCTRL_0 0x200 - -#define CONFIG_HPS_SDR_CTRLCFG_CPORTWIDTH_CPORTWIDTH 0x44555 -#define CONFIG_HPS_SDR_CTRLCFG_CPORTWMAP_CPORTWMAP 0x2C011000 -#define CONFIG_HPS_SDR_CTRLCFG_CPORTRMAP_CPORTRMAP 0xB00088 +#define CONFIG_HPS_SDR_CTRLCFG_PORTCFG_AUTOPCHEN 0 #define CONFIG_HPS_SDR_CTRLCFG_RFIFOCMAP_RFIFOCMAP 0x760210 +#define CONFIG_HPS_SDR_CTRLCFG_STATICCFG_MEMBL 2 +#define CONFIG_HPS_SDR_CTRLCFG_STATICCFG_USEECCASDATA 0 #define CONFIG_HPS_SDR_CTRLCFG_WFIFOCMAP_WFIFOCMAP 0x980543 -#define CONFIG_HPS_SDR_CTRLCFG_CPORTRDWR_CPORTRDWR 0x5A56A -#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_0_THRESHOLD1_31_0 0x20820820 -#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD1_59_32 0x8208208 -#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD2_3_0 0 -#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_2_THRESHOLD2_35_4 0x41041041 -#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_3_THRESHOLD2_59_36 0x410410 -#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_0_THRESHOLDRSTCYCLES_31_0 \ -0x01010101 -#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_1_THRESHOLDRSTCYCLES_63_32 \ -0x01010101 -#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_2_THRESHOLDRSTCYCLES_79_64 \ -0x0101 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMODT_READ 0 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMODT_WRITE 1 -#define CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST_READ_PORT_USED 0 -#define CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST_WRITE_PORT_USED 0 -#define CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST_COMMAND_PORT_USED 0 -#define CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST 0
-#endif /*#ifndef__SDRAM_CONFIG_H*/ +/* Sequencer auto configuration */ +#define RW_MGR_ACTIVATE_0_AND_1 0x0D +#define RW_MGR_ACTIVATE_0_AND_1_WAIT1 0x0E +#define RW_MGR_ACTIVATE_0_AND_1_WAIT2 0x10 +#define RW_MGR_ACTIVATE_1 0x0F +#define RW_MGR_CLEAR_DQS_ENABLE 0x48 +#define RW_MGR_GUARANTEED_READ 0x4B +#define RW_MGR_GUARANTEED_READ_CONT 0x53 +#define RW_MGR_GUARANTEED_WRITE 0x17 +#define RW_MGR_GUARANTEED_WRITE_WAIT0 0x1A +#define RW_MGR_GUARANTEED_WRITE_WAIT1 0x1E +#define RW_MGR_GUARANTEED_WRITE_WAIT2 0x18 +#define RW_MGR_GUARANTEED_WRITE_WAIT3 0x1C +#define RW_MGR_IDLE 0x00 +#define RW_MGR_IDLE_LOOP1 0x7A +#define RW_MGR_IDLE_LOOP2 0x79 +#define RW_MGR_INIT_RESET_0_CKE_0 0x6E +#define RW_MGR_INIT_RESET_1_CKE_0 0x73 +#define RW_MGR_LFSR_WR_RD_BANK_0 0x21 +#define RW_MGR_LFSR_WR_RD_BANK_0_DATA 0x24 +#define RW_MGR_LFSR_WR_RD_BANK_0_DQS 0x23 +#define RW_MGR_LFSR_WR_RD_BANK_0_NOP 0x22 +#define RW_MGR_LFSR_WR_RD_BANK_0_WAIT 0x31 +#define RW_MGR_LFSR_WR_RD_BANK_0_WL_1 0x20 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0 0x35 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0_DATA 0x38 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0_DQS 0x37 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0_NOP 0x36 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0_WAIT 0x45 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0_WL_1 0x34 +#define RW_MGR_MRS0_DLL_RESET 0x02 +#define RW_MGR_MRS0_DLL_RESET_MIRR 0x08 +#define RW_MGR_MRS0_USER 0x07 +#define RW_MGR_MRS0_USER_MIRR 0x0C +#define RW_MGR_MRS1 0x03 +#define RW_MGR_MRS1_MIRR 0x09 +#define RW_MGR_MRS2 0x04 +#define RW_MGR_MRS2_MIRR 0x0A +#define RW_MGR_MRS3 0x05 +#define RW_MGR_MRS3_MIRR 0x0B +#define RW_MGR_PRECHARGE_ALL 0x12 +#define RW_MGR_READ_B2B 0x58 +#define RW_MGR_READ_B2B_WAIT1 0x60 +#define RW_MGR_READ_B2B_WAIT2 0x6A +#define RW_MGR_REFRESH_ALL 0x14 +#define RW_MGR_RETURN 0x01 +#define RW_MGR_SGLE_READ 0x7C +#define RW_MGR_ZQCL 0x06 + +/* Sequencer defines configuration */ +#define AFI_RATE_RATIO 1 +#define CALIB_LFIFO_OFFSET 8 +#define CALIB_VFIFO_OFFSET 6 +#define ENABLE_SUPER_QUICK_CALIBRATION 0 +#define IO_DELAY_PER_DCHAIN_TAP 25 +#define IO_DELAY_PER_DQS_EN_DCHAIN_TAP 25 +#define IO_DELAY_PER_OPA_TAP 234 +#define IO_DLL_CHAIN_LENGTH 8 +#define IO_DQDQS_OUT_PHASE_MAX 0 +#define IO_DQS_EN_DELAY_MAX 15 +#define IO_DQS_EN_DELAY_OFFSET 16 +#define IO_DQS_EN_PHASE_MAX 7 +#define IO_DQS_IN_DELAY_MAX 31 +#define IO_DQS_IN_RESERVE 4 +#define IO_DQS_OUT_RESERVE 6 +#define IO_IO_IN_DELAY_MAX 31 +#define IO_IO_OUT1_DELAY_MAX 31 +#define IO_IO_OUT2_DELAY_MAX 0 +#define IO_SHIFT_DQS_EN_WHEN_SHIFT_DQS 0 +#define MAX_LATENCY_COUNT_WIDTH 5 +#define READ_VALID_FIFO_SIZE 16 +#define REG_FILE_INIT_SEQ_SIGNATURE 0x5555048c +#define RW_MGR_MEM_ADDRESS_MIRRORING 0 +#define RW_MGR_MEM_DATA_MASK_WIDTH 5 +#define RW_MGR_MEM_DATA_WIDTH 40 +#define RW_MGR_MEM_DQ_PER_READ_DQS 8 +#define RW_MGR_MEM_DQ_PER_WRITE_DQS 8 +#define RW_MGR_MEM_IF_READ_DQS_WIDTH 5 +#define RW_MGR_MEM_IF_WRITE_DQS_WIDTH 5 +#define RW_MGR_MEM_NUMBER_OF_CS_PER_DIMM 1 +#define RW_MGR_MEM_NUMBER_OF_RANKS 1 +#define RW_MGR_MEM_VIRTUAL_GROUPS_PER_READ_DQS 1 +#define RW_MGR_MEM_VIRTUAL_GROUPS_PER_WRITE_DQS 1 +#define RW_MGR_TRUE_MEM_DATA_MASK_WIDTH 5 +#define TINIT_CNTR0_VAL 132 +#define TINIT_CNTR1_VAL 32 +#define TINIT_CNTR2_VAL 32 +#define TRESET_CNTR0_VAL 132 +#define TRESET_CNTR1_VAL 99 +#define TRESET_CNTR2_VAL 10 + +/* Sequencer ac_rom_init configuration */ +const u32 ac_rom_init[] ={ + 0x20700000, + 0x20780000, + 0x10080831, + 0x10080930, + 0x10090004, + 0x100a0008, + 0x100b0000, + 0x10380400, + 0x10080849, + 0x100808c8, + 0x100a0004, + 0x10090010, + 0x100b0000, + 0x30780000, + 0x38780000, + 0x30780000, + 0x10680000, + 0x106b0000, + 0x10280400, + 0x10480000, + 0x1c980000, + 0x1c9b0000, + 0x1c980008, + 0x1c9b0008, + 0x38f80000, + 0x3cf80000, + 0x38780000, + 0x18180000, + 0x18980000, + 0x13580000, + 0x135b0000, + 0x13580008, + 0x135b0008, + 0x33780000, + 0x10580008, + 0x10780000 +}; + +/* Sequencer inst_rom_init configuration */ +const u32 inst_rom_init[] ={ + 0x80000, + 0x80680, + 0x8180, + 0x8200, + 0x8280, + 0x8300, + 0x8380, + 0x8100, + 0x8480, + 0x8500, + 0x8580, + 0x8600, + 0x8400, + 0x800, + 0x8680, + 0x880, + 0xa680, + 0x80680, + 0x900, + 0x80680, + 0x980, + 0x8680, + 0x80680, + 0xb68, + 0xcce8, + 0xae8, + 0x8ce8, + 0xb88, + 0xec88, + 0xa08, + 0xac88, + 0x80680, + 0xce00, + 0xcd80, + 0xe700, + 0xc00, + 0x20ce0, + 0x20ce0, + 0x20ce0, + 0x20ce0, + 0xd00, + 0x680, + 0x680, + 0x680, + 0x680, + 0x60e80, + 0x61080, + 0x61080, + 0x61080, + 0xa680, + 0x8680, + 0x80680, + 0xce00, + 0xcd80, + 0xe700, + 0xc00, + 0x30ce0, + 0x30ce0, + 0x30ce0, + 0x30ce0, + 0xd00, + 0x680, + 0x680, + 0x680, + 0x680, + 0x70e80, + 0x71080, + 0x71080, + 0x71080, + 0xa680, + 0x8680, + 0x80680, + 0x1158, + 0x6d8, + 0x80680, + 0x1168, + 0x7e8, + 0x7e8, + 0x87e8, + 0x40fe8, + 0x410e8, + 0x410e8, + 0x410e8, + 0x1168, + 0x7e8, + 0x7e8, + 0xa7e8, + 0x80680, + 0x40e88, + 0x41088, + 0x41088, + 0x41088, + 0x40f68, + 0x410e8, + 0x410e8, + 0x410e8, + 0xa680, + 0x40fe8, + 0x410e8, + 0x410e8, + 0x410e8, + 0x41008, + 0x41088, + 0x41088, + 0x41088, + 0x1100, + 0xc680, + 0x8680, + 0xe680, + 0x80680, + 0x0, + 0x8000, + 0xa000, + 0xc000, + 0x80000, + 0x80, + 0x8080, + 0xa080, + 0xc080, + 0x80080, + 0x9180, + 0x8680, + 0xa680, + 0x80680, + 0x40f08, + 0x80680 +}; + +#endif /* __SOCFPGA_SDRAM_CONFIG_H__ */ diff --git a/board/altera/arria5-socdk/qts/sequencer_auto.h b/board/altera/arria5-socdk/qts/sequencer_auto.h deleted file mode 100644 index df1c224..0000000 diff --git a/board/altera/arria5-socdk/qts/sequencer_auto_ac_init.h b/board/altera/arria5-socdk/qts/sequencer_auto_ac_init.h deleted file mode 100644 index 1c9d8f3..0000000 diff --git a/board/altera/arria5-socdk/qts/sequencer_auto_inst_init.h b/board/altera/arria5-socdk/qts/sequencer_auto_inst_init.h deleted file mode 100644 index c8dbeab..0000000 diff --git a/board/altera/arria5-socdk/qts/sequencer_defines.h b/board/altera/arria5-socdk/qts/sequencer_defines.h deleted file mode 100644 index 6e41175..0000000 diff --git a/board/altera/cyclone5-socdk/qts/iocsr_config.c b/board/altera/cyclone5-socdk/qts/iocsr_config.c deleted file mode 100644 index a2d238c..0000000 diff --git a/board/altera/cyclone5-socdk/qts/iocsr_config.h b/board/altera/cyclone5-socdk/qts/iocsr_config.h index 4a7ed46..49a4fee 100644 --- a/board/altera/cyclone5-socdk/qts/iocsr_config.h +++ b/board/altera/cyclone5-socdk/qts/iocsr_config.h @@ -1,17 +1,660 @@ /* - * Copyright Altera Corporation (C) 2012-2014. All rights reserved + * Altera SoCFPGA IOCSR configuration * - * SPDX-License-Identifier: BSD-3-Clause + * SPDX-License-Identifier: BSD-3-Clause */
-#ifndef _PRELOADER_IOCSR_CONFIG_H_ -#define _PRELOADER_IOCSR_CONFIG_H_ +#define CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH 764 +#define CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH 1719 +#define CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH 955 +#define CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH 16766
-#define CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH (764) -#define CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH (1719) -#define CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH (955) -#define CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH (16766) +const unsigned long iocsr_scan_chain0_table[] = { + 0x00000000, + 0x00000000, + 0x0FF00000, + 0xC0000000, + 0x0000003F, + 0x00008000, + 0x00020080, + 0x08020000, + 0x08000000, + 0x00018020, + 0x00000000, + 0x00004000, + 0x00010040, + 0x04010000, + 0x04000000, + 0x00000010, + 0x00004010, + 0x00002000, + 0x00020000, + 0x02008000, + 0x02000000, + 0x00000008, + 0x00002008, + 0x00001000, +};
-#endif /*_PRELOADER_IOCSR_CONFIG_H_*/ +const unsigned long iocsr_scan_chain1_table[] = { + 0x000C0300, + 0x10040000, + 0x100000C0, + 0x00000040, + 0x00010040, + 0x00008000, + 0x00080000, + 0x18060000, + 0x18000000, + 0x00000060, + 0x00018060, + 0x00004000, + 0x00010040, + 0x10000000, + 0x04000000, + 0x00000010, + 0x00004010, + 0x00002000, + 0x06008020, + 0x02008000, + 0x01FE0000, + 0xF8000000, + 0x00000007, + 0x00001000, + 0x00004010, + 0x01004000, + 0x01000000, + 0x00003004, + 0x00001004, + 0x00000800, + 0x00000000, + 0x00000000, + 0x00800000, + 0x00000002, + 0x00002000, + 0x00000400, + 0x00000000, + 0x00401000, + 0x00000003, + 0x00000000, + 0x00000000, + 0x00000200, + 0x00600802, + 0x00000000, + 0x80200000, + 0x80000600, + 0x00000200, + 0x00000100, + 0x00300401, + 0xC0100400, + 0x40100000, + 0x40000300, + 0x000C0100, + 0x00000080, +}; + +const unsigned long iocsr_scan_chain2_table[] = { + 0x80040100, + 0x00000000, + 0x0FF00000, + 0x00000000, + 0x0C010040, + 0x00008000, + 0x18020080, + 0x00000000, + 0x08000000, + 0x00040020, + 0x06018060, + 0x00004000, + 0x0C010040, + 0x04010000, + 0x00000030, + 0x00000000, + 0x03004010, + 0x00002000, + 0x06008020, + 0x02008000, + 0x02000018, + 0x00006008, + 0x01802008, + 0x00001000, + 0x03004010, + 0x01004000, + 0x0100000C, + 0x00003004, + 0x00C01004, + 0x00000800, +}; + +const unsigned long iocsr_scan_chain3_table[] = { + 0x2C420D80, + 0x082000FF, + 0x0A804001, + 0x07900000, + 0x08020000, + 0x00100000, + 0x0A800000, + 0x07900000, + 0x08020000, + 0x00100000, + 0xC8800000, + 0x00003001, + 0x00C00722, + 0x00000000, + 0x00000021, + 0x82000004, + 0x05400000, + 0x03C80000, + 0x04010000, + 0x00080000, + 0x05400000, + 0x03C80000, + 0x05400000, + 0x03C80000, + 0xE4400000, + 0x00001800, + 0x00600391, + 0x800E4400, + 0x00000001, + 0x40000002, + 0x02A00000, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x72200000, + 0x80000C00, + 0x003001C8, + 0xC0072200, + 0x1C880000, + 0x20000300, + 0x00040000, + 0x50670000, + 0x00000070, + 0x24590000, + 0x00001000, + 0xA0000034, + 0x0D000001, + 0x906808A2, + 0xA2834024, + 0x05141A00, + 0x808A20D0, + 0x34024906, + 0x01A00A28, + 0xA20D0000, + 0x24906808, + 0x00A28340, + 0xD000001A, + 0x06808A20, + 0x10040000, + 0x00200000, + 0x10040000, + 0x00200000, + 0x15000000, + 0x0F200000, + 0x15000000, + 0x0F200000, + 0x01FE0000, + 0x00000000, + 0x01800E44, + 0x00391000, + 0x007F8006, + 0x00000000, + 0x0A800001, + 0x07900000, + 0x0A800000, + 0x07900000, + 0x0A800000, + 0x07900000, + 0x08020000, + 0x00100000, + 0xC8800000, + 0x00003001, + 0x00C00722, + 0x00000FF0, + 0x72200000, + 0x80000C00, + 0x05400000, + 0x02480000, + 0x04000000, + 0x00080000, + 0x05400000, + 0x03C80000, + 0x05400000, + 0x03C80000, + 0x6A1C0000, + 0x00001800, + 0x00600391, + 0x800E4400, + 0x1A870001, + 0x40000600, + 0x02A00040, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x02A00000, + 0x01E40000, + 0x72200000, + 0x80000C00, + 0x003001C8, + 0xC0072200, + 0x1C880000, + 0x20000300, + 0x00040000, + 0x50670000, + 0x00000070, + 0x24590000, + 0x00001000, + 0xA0000034, + 0x0D000001, + 0x906808A2, + 0xA2834024, + 0x05141A00, + 0x808A20D0, + 0x34024906, + 0x01A00040, + 0xA20D0002, + 0x24906808, + 0x00A28340, + 0xD005141A, + 0x06808A20, + 0x10040000, + 0x00200000, + 0x10040000, + 0x00200000, + 0x15000000, + 0x0F200000, + 0x15000000, + 0x0F200000, + 0x01FE0000, + 0x00000000, + 0x01800E44, + 0x00391000, + 0x007F8006, + 0x00000000, + 0x99300001, + 0x34343400, + 0xAA0D4000, + 0x01C3A810, + 0xAA0D4000, + 0x01C3A808, + 0xAA0D4000, + 0x01C3A810, + 0x00040100, + 0x00000800, + 0x00000000, + 0x00001208, + 0x00482000, + 0x000001C1, + 0x00000000, + 0x00410482, + 0x0006A000, + 0x0001B400, + 0x00020000, + 0x00000400, + 0x0002A000, + 0x0001E400, + 0x5506A000, + 0x00E1D404, + 0x00000000, + 0xC880090C, + 0x00003001, + 0x90400000, + 0x00000000, + 0x2020C243, + 0x2A835000, + 0x0070EA04, + 0x2A835000, + 0x0070EA02, + 0x2A835000, + 0x0070EA04, + 0x00010040, + 0x00000200, + 0x00000000, + 0x00000482, + 0x00120800, + 0x00002000, + 0x80000000, + 0x00104120, + 0x00000200, + 0xAC255F80, + 0xF1C71C71, + 0x14F3690D, + 0x1A041414, + 0x00D00000, + 0x14864000, + 0x59647A05, + 0xBA28A3D8, + 0xF511451E, + 0x0341D348, + 0x821A0000, + 0x0000D000, + 0x04510680, + 0xD859647A, + 0x1EBA28A3, + 0x48F51145, + 0x000341D3, + 0x00080200, + 0x00001000, + 0x00080200, + 0x00001000, + 0x000A8000, + 0x00075000, + 0x541A8000, + 0x03875011, + 0x10000000, + 0x00000000, + 0x0080C000, + 0x41000000, + 0x00003FC2, + 0x00820000, + 0xAA0D4000, + 0x01C3A810, + 0xAA0D4000, + 0x01C3A808, + 0xAA0D4000, + 0x01C3A810, + 0x00040100, + 0x00000800, + 0x00000000, + 0x00001208, + 0x00482000, + 0x00008000, + 0x00000000, + 0x00410482, + 0x0006A000, + 0x0001B400, + 0x00020000, + 0x00000400, + 0x00020080, + 0x00000400, + 0x5506A000, + 0x00E1D404, + 0x00000000, + 0x0000090C, + 0x00000010, + 0x90400000, + 0x00000000, + 0x2020C243, + 0x2A835000, + 0x0070EA04, + 0x2A835000, + 0x0070EA02, + 0x2A835000, + 0x0070EA04, + 0x00015000, + 0x0000F200, + 0x00000000, + 0x00000482, + 0x00120800, + 0x00600391, + 0x80000000, + 0x00104120, + 0x00000200, + 0xAC255F80, + 0xF1C71C71, + 0x14F3690D, + 0x1A041414, + 0x00D00000, + 0x14864000, + 0x59647A05, + 0xBA28A3D8, + 0xF511451E, + 0x8341D348, + 0x821A0124, + 0x0000D000, + 0x00000680, + 0xD859647A, + 0x1EBA28A3, + 0x48F51145, + 0x000341D3, + 0x00080200, + 0x00001000, + 0x00080200, + 0x00001000, + 0x000A8000, + 0x00075000, + 0x541A8000, + 0x03875011, + 0x10000000, + 0x00000000, + 0x0080C000, + 0x41000000, + 0x04000002, + 0x00820000, + 0xAA0D4000, + 0x01C3A810, + 0xAA0D4000, + 0x01C3A808, + 0xAA0D4000, + 0x01C3A810, + 0x00040100, + 0x00000800, + 0x00000000, + 0x00001208, + 0x00482000, + 0x00008000, + 0x00000000, + 0x00410482, + 0x0006A000, + 0x0001B400, + 0x00020000, + 0x00000400, + 0x0002A000, + 0x0001E400, + 0x5506A000, + 0x00E1D404, + 0x00000000, + 0xC880090C, + 0x00003001, + 0x90400000, + 0x00000000, + 0x2020C243, + 0x2A835000, + 0x0070EA04, + 0x2A835000, + 0x0070EA02, + 0x2A835000, + 0x0070EA04, + 0x00010040, + 0x00000200, + 0x00000000, + 0x00000482, + 0x00120800, + 0x00002000, + 0x80000000, + 0x00104120, + 0x00000200, + 0xAC255F80, + 0xF1C71C71, + 0x14F3690D, + 0x1A041414, + 0x00D00000, + 0x14864000, + 0x59647A05, + 0xBA28A3D8, + 0xF511451E, + 0x0341D348, + 0x821A0000, + 0x0000D000, + 0x00000680, + 0xD859647A, + 0x1EBA28A3, + 0x48F51145, + 0x000341D3, + 0x00080200, + 0x00001000, + 0x00080200, + 0x00001000, + 0x000A8000, + 0x00075000, + 0x541A8000, + 0x03875011, + 0x10000000, + 0x00000000, + 0x0080C000, + 0x41000000, + 0x04000002, + 0x00820000, + 0xAA0D4000, + 0x01C3A810, + 0xAA0D4000, + 0x01C3A808, + 0xAA0D4000, + 0x01C3A810, + 0x00040100, + 0x00000800, + 0x00000000, + 0x00001208, + 0x00482000, + 0x00008000, + 0x00000000, + 0x00410482, + 0x0006A000, + 0x0001B400, + 0x00020000, + 0x00000400, + 0x00020080, + 0x00000400, + 0x5506A000, + 0x00E1D404, + 0x00000000, + 0x0000090C, + 0x00000010, + 0x90400000, + 0x00000000, + 0x2020C243, + 0x2A835000, + 0x0070EA04, + 0x2A835000, + 0x0070EA02, + 0x2A835000, + 0x0070EA04, + 0x00010040, + 0x00000200, + 0x00000000, + 0x00000482, + 0x40120800, + 0x00000070, + 0x80000000, + 0x00104120, + 0x00000200, + 0xAC255F80, + 0xF1C71C71, + 0x14F1690D, + 0x1A041414, + 0x00D00000, + 0x14864000, + 0x59647A05, + 0xBA28A3D8, + 0xF511451E, + 0x0341D348, + 0x821A0000, + 0x0000D000, + 0x00000680, + 0xD859647A, + 0x1EBA28A3, + 0x48F51145, + 0x000341D3, + 0x00080200, + 0x00001000, + 0x00080200, + 0x00001000, + 0x000A8000, + 0x00075000, + 0x541A8000, + 0x03875011, + 0x10000000, + 0x00000000, + 0x0080C000, + 0x41000000, + 0x04000002, + 0x00820000, + 0x00489800, + 0x001A1A1A, + 0x085506A0, + 0x0000E1D4, + 0x045506A0, + 0x0000E1D4, + 0x085506A0, + 0x8000E1D4, + 0x00000200, + 0x00000004, + 0x04000000, + 0x00000009, + 0x00002410, + 0x00000040, + 0x41000000, + 0x00002082, + 0x00000350, + 0x000000DA, + 0x00000100, + 0x40000002, + 0x00000100, + 0x00000002, + 0x022A8350, + 0x000070EA, + 0x86000000, + 0x08000004, + 0x00000000, + 0x00482000, + 0x21800000, + 0x00101061, + 0x021541A8, + 0x00003875, + 0x011541A8, + 0x00003875, + 0x021541A8, + 0x20003875, + 0x00000080, + 0x00000001, + 0x41000000, + 0x00000002, + 0x00FF0904, + 0x00000000, + 0x90400000, + 0x00000820, + 0xC0000001, + 0x38D612AF, + 0x86F8E38E, + 0x0A0A78B4, + 0x000D020A, + 0x00006800, + 0x028A4320, + 0xEC2CB23D, + 0x8F5D1451, + 0xA47A88A2, + 0x0001A0E9, + 0x00410D00, + 0x40000068, + 0x3D000003, + 0x51EC2CB2, + 0xA28F5D14, + 0xE9A47A88, + 0x000001A0, + 0x00000401, + 0x00000008, + 0x00000401, + 0x00000008, + 0x00000540, + 0x000003A8, + 0x08AA0D40, + 0x8001C3A8, + 0x0000007F, + 0x00000000, + 0x00004060, + 0xE1208000, + 0x0000001F, + 0x00004100, +}; + + +#endif /* __SOCFPGA_IOCSR_CONFIG_H__ */ diff --git a/board/altera/cyclone5-socdk/qts/pinmux_config.c b/board/altera/cyclone5-socdk/qts/pinmux_config.c deleted file mode 100644 index cb58689..0000000 diff --git a/board/altera/cyclone5-socdk/qts/pinmux_config.h b/board/altera/cyclone5-socdk/qts/pinmux_config.h index 21fabb0..aa282e1 100644 --- a/board/altera/cyclone5-socdk/qts/pinmux_config.h +++ b/board/altera/cyclone5-socdk/qts/pinmux_config.h @@ -1,54 +1,219 @@ -/* This file is generated by Preloader Generator */ - -#ifndef _PRELOADER_PINMUX_CONFIG_H_ -#define _PRELOADER_PINMUX_CONFIG_H_ - /* - * State of enabling for which IP connected out through the muxing. - * Value 1 mean the IP connection is muxed out + * Altera SoCFPGA PinMux configuration + * + * SPDX-License-Identifier: BSD-3-Clause */ -#define CONFIG_HPS_EMAC0 (1) -#define CONFIG_HPS_EMAC1 (0) -#define CONFIG_HPS_USB0 (0) -#define CONFIG_HPS_USB1 (1) -#define CONFIG_HPS_NAND (0) -#define CONFIG_HPS_SDMMC (1) -#define CONFIG_HPS_QSPI (0) -#define CONFIG_HPS_UART0 (1) -#define CONFIG_HPS_UART1 (0) -#define CONFIG_HPS_TRACE (0) -#define CONFIG_HPS_I2C0 (1) -#define CONFIG_HPS_I2C1 (0) -#define CONFIG_HPS_I2C2 (0) -#define CONFIG_HPS_I2C3 (0) -#define CONFIG_HPS_SPIM0 (0) -#define CONFIG_HPS_SPIM1 (0) -#define CONFIG_HPS_SPIS0 (0) -#define CONFIG_HPS_SPIS1 (0) -#define CONFIG_HPS_CAN0 (1) -#define CONFIG_HPS_CAN1 (0) - -/* IP attribute value (which affected by pin muxing configuration) */ -#define CONFIG_HPS_SDMMC_BUSWIDTH (8) - -/* 1 if the pins are connected out */ -#define CONFIG_HPS_QSPI_CS0 (0) -#define CONFIG_HPS_QSPI_CS1 (0) -#define CONFIG_HPS_QSPI_CS2 (0) -#define CONFIG_HPS_QSPI_CS3 (0) - -/* UART */ -/* 1 means the pin is mux out or available */ -#define CONFIG_HPS_UART0_TX (1) -#define CONFIG_HPS_UART0_RX (1) -#define CONFIG_HPS_UART0_CTS (0) -#define CONFIG_HPS_UART0_RTS (0) -#define CONFIG_HPS_UART1_TX (0) -#define CONFIG_HPS_UART1_RX (0) -#define CONFIG_HPS_UART1_CTS (0) -#define CONFIG_HPS_UART1_RTS (0)
-#endif /* _PRELOADER_PINMUX_CONFIG_H_ */ +unsigned long sys_mgr_init_table[] = { + 3, /* EMACIO0 */ + 3, /* EMACIO1 */ + 3, /* EMACIO2 */ + 3, /* EMACIO3 */ + 3, /* EMACIO4 */ + 3, /* EMACIO5 */ + 3, /* EMACIO6 */ + 3, /* EMACIO7 */ + 3, /* EMACIO8 */ + 3, /* EMACIO9 */ + 3, /* EMACIO10 */ + 3, /* EMACIO11 */ + 3, /* EMACIO12 */ + 3, /* EMACIO13 */ + 0, /* EMACIO14 */ + 0, /* EMACIO15 */ + 0, /* EMACIO16 */ + 0, /* EMACIO17 */ + 0, /* EMACIO18 */ + 0, /* EMACIO19 */ + 3, /* FLASHIO0 */ + 0, /* FLASHIO1 */ + 3, /* FLASHIO2 */ + 3, /* FLASHIO3 */ + 3, /* FLASHIO4 */ + 3, /* FLASHIO5 */ + 3, /* FLASHIO6 */ + 3, /* FLASHIO7 */ + 0, /* FLASHIO8 */ + 3, /* FLASHIO9 */ + 3, /* FLASHIO10 */ + 3, /* FLASHIO11 */ + 0, /* GENERALIO0 */ + 1, /* GENERALIO1 */ + 1, /* GENERALIO2 */ + 0, /* GENERALIO3 */ + 0, /* GENERALIO4 */ + 1, /* GENERALIO5 */ + 1, /* GENERALIO6 */ + 1, /* GENERALIO7 */ + 1, /* GENERALIO8 */ + 0, /* GENERALIO9 */ + 0, /* GENERALIO10 */ + 0, /* GENERALIO11 */ + 0, /* GENERALIO12 */ + 2, /* GENERALIO13 */ + 2, /* GENERALIO14 */ + 0, /* GENERALIO15 */ + 0, /* GENERALIO16 */ + 2, /* GENERALIO17 */ + 2, /* GENERALIO18 */ + 0, /* GENERALIO19 */ + 0, /* GENERALIO20 */ + 0, /* GENERALIO21 */ + 0, /* GENERALIO22 */ + 0, /* GENERALIO23 */ + 0, /* GENERALIO24 */ + 0, /* GENERALIO25 */ + 0, /* GENERALIO26 */ + 0, /* GENERALIO27 */ + 0, /* GENERALIO28 */ + 0, /* GENERALIO29 */ + 0, /* GENERALIO30 */ + 0, /* GENERALIO31 */ + 0, /* MIXED1IO0 */ + 1, /* MIXED1IO1 */ + 1, /* MIXED1IO2 */ + 1, /* MIXED1IO3 */ + 1, /* MIXED1IO4 */ + 0, /* MIXED1IO5 */ + 0, /* MIXED1IO6 */ + 0, /* MIXED1IO7 */ + 1, /* MIXED1IO8 */ + 1, /* MIXED1IO9 */ + 1, /* MIXED1IO10 */ + 1, /* MIXED1IO11 */ + 0, /* MIXED1IO12 */ + 0, /* MIXED1IO13 */ + 0, /* MIXED1IO14 */ + 1, /* MIXED1IO15 */ + 1, /* MIXED1IO16 */ + 1, /* MIXED1IO17 */ + 1, /* MIXED1IO18 */ + 0, /* MIXED1IO19 */ + 0, /* MIXED1IO20 */ + 0, /* MIXED1IO21 */ + 0, /* MIXED2IO0 */ + 0, /* MIXED2IO1 */ + 0, /* MIXED2IO2 */ + 0, /* MIXED2IO3 */ + 0, /* MIXED2IO4 */ + 0, /* MIXED2IO5 */ + 0, /* MIXED2IO6 */ + 0, /* MIXED2IO7 */ + 0, /* GPLINMUX48 */ + 0, /* GPLINMUX49 */ + 0, /* GPLINMUX50 */ + 0, /* GPLINMUX51 */ + 0, /* GPLINMUX52 */ + 0, /* GPLINMUX53 */ + 0, /* GPLINMUX54 */ + 0, /* GPLINMUX55 */ + 0, /* GPLINMUX56 */ + 0, /* GPLINMUX57 */ + 0, /* GPLINMUX58 */ + 0, /* GPLINMUX59 */ + 0, /* GPLINMUX60 */ + 0, /* GPLINMUX61 */ + 0, /* GPLINMUX62 */ + 0, /* GPLINMUX63 */ + 0, /* GPLINMUX64 */ + 0, /* GPLINMUX65 */ + 0, /* GPLINMUX66 */ + 0, /* GPLINMUX67 */ + 0, /* GPLINMUX68 */ + 0, /* GPLINMUX69 */ + 0, /* GPLINMUX70 */ + 1, /* GPLMUX0 */ + 1, /* GPLMUX1 */ + 1, /* GPLMUX2 */ + 1, /* GPLMUX3 */ + 1, /* GPLMUX4 */ + 1, /* GPLMUX5 */ + 1, /* GPLMUX6 */ + 1, /* GPLMUX7 */ + 1, /* GPLMUX8 */ + 1, /* GPLMUX9 */ + 1, /* GPLMUX10 */ + 1, /* GPLMUX11 */ + 1, /* GPLMUX12 */ + 1, /* GPLMUX13 */ + 1, /* GPLMUX14 */ + 1, /* GPLMUX15 */ + 1, /* GPLMUX16 */ + 1, /* GPLMUX17 */ + 1, /* GPLMUX18 */ + 1, /* GPLMUX19 */ + 1, /* GPLMUX20 */ + 1, /* GPLMUX21 */ + 1, /* GPLMUX22 */ + 1, /* GPLMUX23 */ + 1, /* GPLMUX24 */ + 1, /* GPLMUX25 */ + 1, /* GPLMUX26 */ + 1, /* GPLMUX27 */ + 1, /* GPLMUX28 */ + 1, /* GPLMUX29 */ + 1, /* GPLMUX30 */ + 1, /* GPLMUX31 */ + 1, /* GPLMUX32 */ + 1, /* GPLMUX33 */ + 1, /* GPLMUX34 */ + 1, /* GPLMUX35 */ + 1, /* GPLMUX36 */ + 1, /* GPLMUX37 */ + 1, /* GPLMUX38 */ + 1, /* GPLMUX39 */ + 1, /* GPLMUX40 */ + 1, /* GPLMUX41 */ + 1, /* GPLMUX42 */ + 1, /* GPLMUX43 */ + 1, /* GPLMUX44 */ + 1, /* GPLMUX45 */ + 1, /* GPLMUX46 */ + 1, /* GPLMUX47 */ + 1, /* GPLMUX48 */ + 1, /* GPLMUX49 */ + 1, /* GPLMUX50 */ + 1, /* GPLMUX51 */ + 1, /* GPLMUX52 */ + 1, /* GPLMUX53 */ + 1, /* GPLMUX54 */ + 1, /* GPLMUX55 */ + 1, /* GPLMUX56 */ + 1, /* GPLMUX57 */ + 1, /* GPLMUX58 */ + 1, /* GPLMUX59 */ + 1, /* GPLMUX60 */ + 1, /* GPLMUX61 */ + 1, /* GPLMUX62 */ + 1, /* GPLMUX63 */ + 1, /* GPLMUX64 */ + 1, /* GPLMUX65 */ + 1, /* GPLMUX66 */ + 1, /* GPLMUX67 */ + 1, /* GPLMUX68 */ + 1, /* GPLMUX69 */ + 1, /* GPLMUX70 */ + 0, /* NANDUSEFPGA */ + 0, /* UART0USEFPGA */ + 0, /* RGMII1USEFPGA */ + 0, /* SPIS0USEFPGA */ + 0, /* CAN0USEFPGA */ + 0, /* I2C0USEFPGA */ + 0, /* SDMMCUSEFPGA */ + 0, /* QSPIUSEFPGA */ + 0, /* SPIS1USEFPGA */ + 0, /* RGMII0USEFPGA */ + 0, /* UART1USEFPGA */ + 0, /* CAN1USEFPGA */ + 0, /* USB1USEFPGA */ + 0, /* I2C3USEFPGA */ + 0, /* I2C2USEFPGA */ + 0, /* I2C1USEFPGA */ + 0, /* SPIM1USEFPGA */ + 0, /* USB0USEFPGA */ + 0 /* SPIM0USEFPGA */ +}; +#endif /* __SOCFPGA_PINMUX_CONFIG_H__ */ diff --git a/board/altera/cyclone5-socdk/qts/pll_config.h b/board/altera/cyclone5-socdk/qts/pll_config.h index 7cd25df..3d621ed 100644 --- a/board/altera/cyclone5-socdk/qts/pll_config.h +++ b/board/altera/cyclone5-socdk/qts/pll_config.h @@ -1,109 +1,85 @@ /* - * Copyright Altera Corporation (C) 2012-2014. All rights reserved + * Altera SoCFPGA Clock and PLL configuration * - * SPDX-License-Identifier: BSD-3-Clause + * SPDX-License-Identifier: BSD-3-Clause */
-#endif /* _PRELOADER_PLL_CONFIG_H_ */ +#endif /* __SOCFPGA_PLL_CONFIG_H__ */ diff --git a/board/altera/cyclone5-socdk/qts/sdram_config.h b/board/altera/cyclone5-socdk/qts/sdram_config.h index 15df808..37c1476 100644 --- a/board/altera/cyclone5-socdk/qts/sdram_config.h +++ b/board/altera/cyclone5-socdk/qts/sdram_config.h @@ -1,86 +1,342 @@ /* - * Copyright Altera Corporation (C) 2012-2015 + * Altera SoCFPGA SDRAM configuration * - * SPDX-License-Identifier: BSD-3-Clause + * SPDX-License-Identifier: BSD-3-Clause */
-#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMTYPE 2 -#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMBL 8 +/* SDRAM configuration */ +#define CONFIG_HPS_SDR_CTRLCFG_CPORTRDWR_CPORTRDWR 0x5A56A +#define CONFIG_HPS_SDR_CTRLCFG_CPORTRMAP_CPORTRMAP 0xB00088 +#define CONFIG_HPS_SDR_CTRLCFG_CPORTWIDTH_CPORTWIDTH 0x44555 +#define CONFIG_HPS_SDR_CTRLCFG_CPORTWMAP_CPORTWMAP 0x2C011000 #define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ADDRORDER 0 -#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ECCEN 1 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_DQSTRKEN 0 #define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ECCCORREN 1 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ECCEN 1 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMBL 8 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMTYPE 2 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_NODMPINS 0 #define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_REORDEREN 1 #define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_STARVELIMIT 10 -#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_DQSTRKEN 0 -#define CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_NODMPINS 0 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCWL 6 +#define CONFIG_HPS_SDR_CTRLCFG_CTRLWIDTH_CTRLWIDTH 2 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_BANKBITS 3 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_COLBITS 10 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_CSBITS 1 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_ROWBITS 15 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMDEVWIDTH_DEVWIDTH 8 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMIFWIDTH_IFWIDTH 40 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMINTR_INTREN 0 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMODT_READ 0 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMODT_WRITE 1 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_AL 0 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCL 7 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRRD 3 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCWL 6 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TFAW 14 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRFC 104 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TREFI 3120 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRRD 3 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRCD 6 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TREFI 3120 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRP 6 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWR 6 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWTR 4 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRTP 3 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TCCD 4 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TMRD 4 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRAS 14 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRC 20 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TMRD 4 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TCCD 4 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_SELFRFSHEXIT 512 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRTP 3 #define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_PWRDOWNEXIT 3 +#define CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_SELFRFSHEXIT 512 +#define CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_INCSYNC 0 +#define CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_SYNCMODE 0 +#define CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST 0 +#define CONFIG_HPS_SDR_CTRLCFG_LOWPWREQ_SELFRFSHMASK 3 #define CONFIG_HPS_SDR_CTRLCFG_LOWPWRTIMING_AUTOPDCYCLES 0 #define CONFIG_HPS_SDR_CTRLCFG_LOWPWRTIMING_CLKDISABLECYCLES 8 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_COLBITS 10 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_ROWBITS 15 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_BANKBITS 3 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_CSBITS 1 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMIFWIDTH_IFWIDTH 40 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMDEVWIDTH_DEVWIDTH 8 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMINTR_INTREN 0 -#define CONFIG_HPS_SDR_CTRLCFG_LOWPWREQ_SELFRFSHMASK 3 -#define CONFIG_HPS_SDR_CTRLCFG_STATICCFG_MEMBL 2 -#define CONFIG_HPS_SDR_CTRLCFG_STATICCFG_USEECCASDATA 0 -#define CONFIG_HPS_SDR_CTRLCFG_CTRLWIDTH_CTRLWIDTH 2 -#define CONFIG_HPS_SDR_CTRLCFG_PORTCFG_AUTOPCHEN 0 -#define CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_SYNCMODE 0 -#define CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_INCSYNC 0 +#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_0_THRESHOLD1_31_0 0x20820820 +#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD1_59_32 0x8208208 +#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD2_3_0 0 +#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_2_THRESHOLD2_35_4 0x41041041 +#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_3_THRESHOLD2_59_36 0x410410 #define CONFIG_HPS_SDR_CTRLCFG_MPPRIORITY_USERPRIORITY 0x3FFD1088 +#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_0_THRESHOLDRSTCYCLES_31_0 0x01010101 +#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_1_THRESHOLDRSTCYCLES_63_32 0x01010101 +#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_2_THRESHOLDRSTCYCLES_79_64 0x0101 #define CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_0_STATICWEIGHT_31_0 0x21084210 #define CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_1_STATICWEIGHT_49_32 0x1EF84 #define CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_1_SUMOFWEIGHT_13_0 0x2020 #define CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_2_SUMOFWEIGHT_45_14 0x0 #define CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_3_SUMOFWEIGHT_63_46 0xF800 #define CONFIG_HPS_SDR_CTRLCFG_PHYCTRL_PHYCTRL_0 0x200 - -#define CONFIG_HPS_SDR_CTRLCFG_CPORTWIDTH_CPORTWIDTH 0x44555 -#define CONFIG_HPS_SDR_CTRLCFG_CPORTWMAP_CPORTWMAP 0x2C011000 -#define CONFIG_HPS_SDR_CTRLCFG_CPORTRMAP_CPORTRMAP 0xB00088 +#define CONFIG_HPS_SDR_CTRLCFG_PORTCFG_AUTOPCHEN 0 #define CONFIG_HPS_SDR_CTRLCFG_RFIFOCMAP_RFIFOCMAP 0x760210 +#define CONFIG_HPS_SDR_CTRLCFG_STATICCFG_MEMBL 2 +#define CONFIG_HPS_SDR_CTRLCFG_STATICCFG_USEECCASDATA 0 #define CONFIG_HPS_SDR_CTRLCFG_WFIFOCMAP_WFIFOCMAP 0x980543 -#define CONFIG_HPS_SDR_CTRLCFG_CPORTRDWR_CPORTRDWR 0x5A56A -#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_0_THRESHOLD1_31_0 0x20820820 -#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD1_59_32 0x8208208 -#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD2_3_0 0 -#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_2_THRESHOLD2_35_4 0x41041041 -#define CONFIG_HPS_SDR_CTRLCFG_MPPACING_3_THRESHOLD2_59_36 0x410410 -#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_0_THRESHOLDRSTCYCLES_31_0 \ -0x01010101 -#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_1_THRESHOLDRSTCYCLES_63_32 \ -0x01010101 -#define CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_2_THRESHOLDRSTCYCLES_79_64 \ -0x0101 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMODT_READ 0 -#define CONFIG_HPS_SDR_CTRLCFG_DRAMODT_WRITE 1 -#define CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST_READ_PORT_USED 0 -#define CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST_WRITE_PORT_USED 0 -#define CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST_COMMAND_PORT_USED 0 -#define CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST 0
-#endif /*#ifndef__SDRAM_CONFIG_H*/ +/* Sequencer auto configuration */ +#define RW_MGR_ACTIVATE_0_AND_1 0x0D +#define RW_MGR_ACTIVATE_0_AND_1_WAIT1 0x0E +#define RW_MGR_ACTIVATE_0_AND_1_WAIT2 0x10 +#define RW_MGR_ACTIVATE_1 0x0F +#define RW_MGR_CLEAR_DQS_ENABLE 0x48 +#define RW_MGR_GUARANTEED_READ 0x4B +#define RW_MGR_GUARANTEED_READ_CONT 0x53 +#define RW_MGR_GUARANTEED_WRITE 0x17 +#define RW_MGR_GUARANTEED_WRITE_WAIT0 0x1A +#define RW_MGR_GUARANTEED_WRITE_WAIT1 0x1E +#define RW_MGR_GUARANTEED_WRITE_WAIT2 0x18 +#define RW_MGR_GUARANTEED_WRITE_WAIT3 0x1C +#define RW_MGR_IDLE 0x00 +#define RW_MGR_IDLE_LOOP1 0x7C +#define RW_MGR_IDLE_LOOP2 0x7B +#define RW_MGR_INIT_RESET_0_CKE_0 0x6E +#define RW_MGR_INIT_RESET_1_CKE_0 0x73 +#define RW_MGR_LFSR_WR_RD_BANK_0 0x21 +#define RW_MGR_LFSR_WR_RD_BANK_0_DATA 0x24 +#define RW_MGR_LFSR_WR_RD_BANK_0_DQS 0x23 +#define RW_MGR_LFSR_WR_RD_BANK_0_NOP 0x22 +#define RW_MGR_LFSR_WR_RD_BANK_0_WAIT 0x31 +#define RW_MGR_LFSR_WR_RD_BANK_0_WL_1 0x20 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0 0x35 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0_DATA 0x38 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0_DQS 0x37 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0_NOP 0x36 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0_WAIT 0x45 +#define RW_MGR_LFSR_WR_RD_DM_BANK_0_WL_1 0x34 +#define RW_MGR_MRS0_DLL_RESET 0x02 +#define RW_MGR_MRS0_DLL_RESET_MIRR 0x08 +#define RW_MGR_MRS0_USER 0x07 +#define RW_MGR_MRS0_USER_MIRR 0x0C +#define RW_MGR_MRS1 0x03 +#define RW_MGR_MRS1_MIRR 0x09 +#define RW_MGR_MRS2 0x04 +#define RW_MGR_MRS2_MIRR 0x0A +#define RW_MGR_MRS3 0x05 +#define RW_MGR_MRS3_MIRR 0x0B +#define RW_MGR_PRECHARGE_ALL 0x12 +#define RW_MGR_READ_B2B 0x58 +#define RW_MGR_READ_B2B_WAIT1 0x60 +#define RW_MGR_READ_B2B_WAIT2 0x6A +#define RW_MGR_REFRESH_ALL 0x14 +#define RW_MGR_RETURN 0x01 +#define RW_MGR_SGLE_READ 0x7E +#define RW_MGR_ZQCL 0x06 + +/* Sequencer defines configuration */ +#define AFI_RATE_RATIO 1 +#define CALIB_LFIFO_OFFSET 7 +#define CALIB_VFIFO_OFFSET 5 +#define ENABLE_SUPER_QUICK_CALIBRATION 0 +#define IO_DELAY_PER_DCHAIN_TAP 25 +#define IO_DELAY_PER_DQS_EN_DCHAIN_TAP 25 +#define IO_DELAY_PER_OPA_TAP 312 +#define IO_DLL_CHAIN_LENGTH 8 +#define IO_DQDQS_OUT_PHASE_MAX 0 +#define IO_DQS_EN_DELAY_MAX 31 +#define IO_DQS_EN_DELAY_OFFSET 0 +#define IO_DQS_EN_PHASE_MAX 7 +#define IO_DQS_IN_DELAY_MAX 31 +#define IO_DQS_IN_RESERVE 4 +#define IO_DQS_OUT_RESERVE 6 +#define IO_IO_IN_DELAY_MAX 31 +#define IO_IO_OUT1_DELAY_MAX 31 +#define IO_IO_OUT2_DELAY_MAX 0 +#define IO_SHIFT_DQS_EN_WHEN_SHIFT_DQS 0 +#define MAX_LATENCY_COUNT_WIDTH 5 +#define READ_VALID_FIFO_SIZE 16 +#define REG_FILE_INIT_SEQ_SIGNATURE 0x55550483 +#define RW_MGR_MEM_ADDRESS_MIRRORING 0 +#define RW_MGR_MEM_DATA_MASK_WIDTH 5 +#define RW_MGR_MEM_DATA_WIDTH 40 +#define RW_MGR_MEM_DQ_PER_READ_DQS 8 +#define RW_MGR_MEM_DQ_PER_WRITE_DQS 8 +#define RW_MGR_MEM_IF_READ_DQS_WIDTH 5 +#define RW_MGR_MEM_IF_WRITE_DQS_WIDTH 5 +#define RW_MGR_MEM_NUMBER_OF_CS_PER_DIMM 1 +#define RW_MGR_MEM_NUMBER_OF_RANKS 1 +#define RW_MGR_MEM_VIRTUAL_GROUPS_PER_READ_DQS 1 +#define RW_MGR_MEM_VIRTUAL_GROUPS_PER_WRITE_DQS 1 +#define RW_MGR_TRUE_MEM_DATA_MASK_WIDTH 5 +#define TINIT_CNTR0_VAL 132 +#define TINIT_CNTR1_VAL 32 +#define TINIT_CNTR2_VAL 32 +#define TRESET_CNTR0_VAL 132 +#define TRESET_CNTR1_VAL 99 +#define TRESET_CNTR2_VAL 10 + +/* Sequencer ac_rom_init configuration */ +const u32 ac_rom_init[] ={ + 0x20700000, + 0x20780000, + 0x10080431, + 0x10080530, + 0x10090004, + 0x100a0008, + 0x100b0000, + 0x10380400, + 0x10080449, + 0x100804c8, + 0x100a0004, + 0x10090010, + 0x100b0000, + 0x30780000, + 0x38780000, + 0x30780000, + 0x10680000, + 0x106b0000, + 0x10280400, + 0x10480000, + 0x1c980000, + 0x1c9b0000, + 0x1c980008, + 0x1c9b0008, + 0x38f80000, + 0x3cf80000, + 0x38780000, + 0x18180000, + 0x18980000, + 0x13580000, + 0x135b0000, + 0x13580008, + 0x135b0008, + 0x33780000, + 0x10580008, + 0x10780000 +}; + +/* Sequencer inst_rom_init configuration */ +const u32 inst_rom_init[] ={ + 0x80000, + 0x80680, + 0x8180, + 0x8200, + 0x8280, + 0x8300, + 0x8380, + 0x8100, + 0x8480, + 0x8500, + 0x8580, + 0x8600, + 0x8400, + 0x800, + 0x8680, + 0x880, + 0xa680, + 0x80680, + 0x900, + 0x80680, + 0x980, + 0x8680, + 0x80680, + 0xb68, + 0xcce8, + 0xae8, + 0x8ce8, + 0xb88, + 0xec88, + 0xa08, + 0xac88, + 0x80680, + 0xce00, + 0xcd80, + 0xe700, + 0xc00, + 0x20ce0, + 0x20ce0, + 0x20ce0, + 0x20ce0, + 0xd00, + 0x680, + 0x680, + 0x680, + 0x680, + 0x60e80, + 0x61080, + 0x61080, + 0x61080, + 0xa680, + 0x8680, + 0x80680, + 0xce00, + 0xcd80, + 0xe700, + 0xc00, + 0x30ce0, + 0x30ce0, + 0x30ce0, + 0x30ce0, + 0xd00, + 0x680, + 0x680, + 0x680, + 0x680, + 0x70e80, + 0x71080, + 0x71080, + 0x71080, + 0xa680, + 0x8680, + 0x80680, + 0x1158, + 0x6d8, + 0x80680, + 0x1168, + 0x7e8, + 0x7e8, + 0x87e8, + 0x40fe8, + 0x410e8, + 0x410e8, + 0x410e8, + 0x1168, + 0x7e8, + 0x7e8, + 0xa7e8, + 0x80680, + 0x40e88, + 0x41088, + 0x41088, + 0x41088, + 0x40f68, + 0x410e8, + 0x410e8, + 0x410e8, + 0xa680, + 0x40fe8, + 0x410e8, + 0x410e8, + 0x410e8, + 0x41008, + 0x41088, + 0x41088, + 0x41088, + 0x1100, + 0xc680, + 0x8680, + 0xe680, + 0x80680, + 0x0, + 0x0, + 0xa000, + 0x8000, + 0x80000, + 0x80, + 0x80, + 0x80, + 0x80, + 0xa080, + 0x8080, + 0x80080, + 0x9180, + 0x8680, + 0xa680, + 0x80680, + 0x40f08, + 0x80680 +}; + +#endif /* __SOCFPGA_SDRAM_CONFIG_H__ */ diff --git a/board/altera/cyclone5-socdk/qts/sequencer_auto.h b/board/altera/cyclone5-socdk/qts/sequencer_auto.h deleted file mode 100644 index d3c2251..0000000 diff --git a/board/altera/cyclone5-socdk/qts/sequencer_auto_ac_init.h b/board/altera/cyclone5-socdk/qts/sequencer_auto_ac_init.h deleted file mode 100644 index 0d26281..0000000 diff --git a/board/altera/cyclone5-socdk/qts/sequencer_auto_inst_init.h b/board/altera/cyclone5-socdk/qts/sequencer_auto_inst_init.h deleted file mode 100644 index 2b4c78f..0000000 diff --git a/board/altera/cyclone5-socdk/qts/sequencer_defines.h b/board/altera/cyclone5-socdk/qts/sequencer_defines.h deleted file mode 100644 index 27ace02..0000000
Now that we're actually converting the QTS-generated header files, we can even adjust their data types. A good candidate for this is the pinmux table, where each entry can have value in the range of 0..3, but each element is declared as unsigned long. By changing the type to u8, we can save over 600 Bytes from the SPL, so do it. This patch also constifies the array.
Signed-off-by: Marek Vasut marex@denx.de --- arch/arm/mach-socfpga/include/mach/system_manager.h | 3 +-- arch/arm/mach-socfpga/qts-filter.sh | 2 +- arch/arm/mach-socfpga/system_manager.c | 2 +- arch/arm/mach-socfpga/wrap_pinmux_config.c | 3 +-- board/altera/arria5-socdk/qts/pinmux_config.h | 2 +- board/altera/cyclone5-socdk/qts/pinmux_config.h | 2 +- 6 files changed, 6 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index 46af30b..8712f8e 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -12,8 +12,7 @@ void sysmgr_pinmux_init(void); void sysmgr_config_warmrstcfgio(int enable);
-void sysmgr_get_pinmux_table(const unsigned long **table, - unsigned int *table_len); +void sysmgr_get_pinmux_table(const u8 **table, unsigned int *table_len); #endif
struct socfpga_system_manager { diff --git a/arch/arm/mach-socfpga/qts-filter.sh b/arch/arm/mach-socfpga/qts-filter.sh index 16d3a2a..fc41d99 100755 --- a/arch/arm/mach-socfpga/qts-filter.sh +++ b/arch/arm/mach-socfpga/qts-filter.sh @@ -66,7 +66,7 @@ process_pinmux_config() { EOF
# Retrieve the pinmux config and zap the ad-hoc length encoding - sed -n '/^unsigned/ !b; :next {/^unsigned/ s/[.*]/[]/;p;n;b next}' \ + sed -n '/^unsigned/ !b; :next {/^unsigned/ {s/[.*]/[]/s/unsigned long/const u8/};p;n;b next}' \ ${in_dir}/generated/pinmux_config_${soc}.c
cat << EOF diff --git a/arch/arm/mach-socfpga/system_manager.c b/arch/arm/mach-socfpga/system_manager.c index 744ec32..75a65f3 100644 --- a/arch/arm/mach-socfpga/system_manager.c +++ b/arch/arm/mach-socfpga/system_manager.c @@ -57,7 +57,7 @@ static void populate_sysmgr_fpgaintf_module(void) void sysmgr_pinmux_init(void) { uint32_t regs = (uint32_t)&sysmgr_regs->emacio[0]; - const unsigned long *sys_mgr_init_table; + const u8 *sys_mgr_init_table; unsigned int len; int i;
diff --git a/arch/arm/mach-socfpga/wrap_pinmux_config.c b/arch/arm/mach-socfpga/wrap_pinmux_config.c index bcb7781..a12f0b3 100644 --- a/arch/arm/mach-socfpga/wrap_pinmux_config.c +++ b/arch/arm/mach-socfpga/wrap_pinmux_config.c @@ -10,8 +10,7 @@ /* Board-specific header. */ #include <qts/pinmux_config.h>
-void sysmgr_get_pinmux_table(const unsigned long **table, - unsigned int *table_len) +void sysmgr_get_pinmux_table(const u8 **table, unsigned int *table_len) { *table = sys_mgr_init_table; *table_len = ARRAY_SIZE(sys_mgr_init_table); diff --git a/board/altera/arria5-socdk/qts/pinmux_config.h b/board/altera/arria5-socdk/qts/pinmux_config.h index 5a714a3..069d492 100644 --- a/board/altera/arria5-socdk/qts/pinmux_config.h +++ b/board/altera/arria5-socdk/qts/pinmux_config.h @@ -7,7 +7,7 @@ #ifndef __SOCFPGA_PINMUX_CONFIG_H__ #define __SOCFPGA_PINMUX_CONFIG_H__
-unsigned long sys_mgr_init_table[] = { +const u8 sys_mgr_init_table[] = { 0, /* EMACIO0 */ 2, /* EMACIO1 */ 2, /* EMACIO2 */ diff --git a/board/altera/cyclone5-socdk/qts/pinmux_config.h b/board/altera/cyclone5-socdk/qts/pinmux_config.h index aa282e1..33cf1fd 100644 --- a/board/altera/cyclone5-socdk/qts/pinmux_config.h +++ b/board/altera/cyclone5-socdk/qts/pinmux_config.h @@ -7,7 +7,7 @@ #ifndef __SOCFPGA_PINMUX_CONFIG_H__ #define __SOCFPGA_PINMUX_CONFIG_H__
-unsigned long sys_mgr_init_table[] = { +const u8 sys_mgr_init_table[] = { 3, /* EMACIO0 */ 3, /* EMACIO1 */ 3, /* EMACIO2 */
- sed -n '/^unsigned/ !b; :next {/^unsigned/ {s/[.*]/[]/s/unsigned long/const u8/};p;n;b next}' \ ${in_dir}/generated/pinmux_config_${soc}.c
Should this change be in it's own patch?
Thanks, Dinh
#endif
EOF
Not really, I think you want to change all the places atomically.
Best regards, Marek Vasut
Hi Marek,
the last sed line is invalid for my GNU sed 4.2.2. Maybe missed a semicolon?
sed -n '/^unsigned/ !b; :next {/^unsigned/ {s/[.*]/[]/;s/unsigned long/const u8/};p;n;b next}' \ # ^here
*Jian Luo DC-IA/EAH2*
Tel. +49(9352)18-4266
*Be**QIK *
#endif
EOF
Best regards, Marek Vasut _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Wednesday, August 19, 2015 at 12:14:21 PM, Jian.Luo4 wrote:
Hi Marek,
Nice catch, fixed before applying, thanks :)
On Tuesday, August 11, 2015 at 01:10:38 AM, Marek Vasut wrote:
This series cleans up the QTS-generated header files and cleans up the SoCDK support such that they fit into the framework just like any other SoCFPGA boards.
Marek Vasut (8): arm: socfpga: Move wrappers into platform directory arm: socfpga: Unbind CPU type from board type arm: socfpga: Split Altera socfpga into AV and CV SoCDK arm: socfpga: Remove CV-specific parts from AV-SoCDK arm: socfpga: Remove AV-specific parts from CV-SoCDK arm: socfpga: Add qts-filter.sh script arm: socfpga: Switch to filtered QTS files arm: socfpga: Make the pinmux table const u8
Hi Dinh,
could it be that Altera is now filtering me as a spammer, so you're not getting my patches (wouldn't be all that surprising :-) ) ?
Hi Dinh,
I didn't see these patches because my filter was looking for [U-Boot][PATCH]
Anyways...I see them now...
Dinh
Hi Dinh,
Whew, that's a relief :-)
Only comment was in patch 8/8.
For the series:
Acked-by: Dinh Nguyen dinguyen@opensource.altera.com
Thanks, Dinh
Dinh Nguyen
Jian.Luo4
