Please pull u-boot-x86
Hi Tom,
This PR includes the following x86 changes for v2020.07 release:
- Use device tree for FSP-M and FSP-S configuration on Intel Apollo Lake - Add SMBIOS cbmem entry parsing for coreboot - Various clean-ups to CBFS implementation
The following changes since commit 0ab24c37f03a3a23982edb63d88c4f22bb8bc2c5:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-riscv (2020-05-26 15:27:04 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-x86
for you to fetch changes up to 0621b5e1eeb6bcf08b220136f09d433d880f65a5:
cbfs: Don't require the CBFS size with cbfs_init_mem() (2020-05-27 14:40:09 +0800)
---------------------------------------------------------------- Bernhard Messerklinger (3): x86: apl: Only load VBT if CONFIG_HAVE_VBT is enabled x86: apl: Use devicetree for FSP-M configuration x86: apl: Use devicetree for FSP-S configuration
Christian Gmeiner (2): x86: coreboot: add SMBIOS cbmem entry parsing cbfs: drop file_cbfs_result declaration
Simon Glass (14): x86: mtrr: Drop the mask display when changing an mtrr cbfs: Rename the result variable cbfs: Use ulong consistently cbfs: Use bool type for whether initialised cbfs: Adjust return value of file_cbfs_next_file() cbfs: Adjust file_cbfs_load_header() to use cbfs_priv cbfs: Adjust cbfs_load_header_ptr() to use cbfs_priv cbfs: Unify the two header loaders cbfs: Use void * for the position pointers cbfs: Record the start address in cbfs_priv cbfs: Return the error code from file_cbfs_init() cbfs: Change file_cbfs_find_uncached() to return an error cbfs: Allow reading a file from a CBFS given its base addr cbfs: Don't require the CBFS size with cbfs_init_mem()
arch/x86/cpu/apollolake/Makefile | 1 + arch/x86/cpu/apollolake/fsp_bindings.c | 1805 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/cpu/apollolake/fsp_m.c | 169 +--------- arch/x86/cpu/apollolake/fsp_s.c | 430 ++------------------------ arch/x86/cpu/coreboot/tables.c | 14 + arch/x86/dts/chromebook_coral.dts | 73 ++++- arch/x86/include/asm/arch-apollolake/fsp/fsp_m_upd.h | 168 ++++++++++ arch/x86/include/asm/arch-apollolake/fsp/fsp_s_upd.h | 202 ++++++++++++ arch/x86/include/asm/arch-apollolake/fsp_bindings.h | 110 +++++++ arch/x86/include/asm/arch-coreboot/sysinfo.h | 2 + arch/x86/include/asm/coreboot_tables.h | 11 + arch/x86/lib/fsp2/fsp_init.c | 3 +- cmd/cbfs.c | 3 +- cmd/x86/mtrr.c | 1 - doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-m.txt | 320 +++++++++++++++++++ doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-s.txt | 483 +++++++++++++++++++++++++++++ fs/cbfs/cbfs.c | 240 +++++++++------ include/cbfs.h | 42 ++- 18 files changed, 3399 insertions(+), 678 deletions(-) create mode 100644 arch/x86/cpu/apollolake/fsp_bindings.c create mode 100644 arch/x86/include/asm/arch-apollolake/fsp_bindings.h create mode 100644 doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-m.txt create mode 100644 doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-s.txt
Regards, Bin
On Wed, May 27, 2020 at 02:45:19PM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
