[U-Boot] sf: Fix to compute proper sector_size
Upto now flash sector_size is assigned from params which isn't necessarily a sector size from vendor, so based on the SECT_* flags from flash_params the erase_size will compute and it will become the sector_size finally.
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Reported-by: Bin Meng bmeng.cn@gmail.com --- drivers/mtd/spi/sf_internal.h | 3 ++- drivers/mtd/spi/sf_probe.c | 10 +++++++--- 2 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index d273d30..6c73992 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -123,7 +123,8 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, * @name: Device name ([MANUFLETTER][DEVTYPE][DENSITY][EXTRAINFO]) * @jedec: Device jedec ID (0x[1byte_manuf_id][2byte_dev_id]) * @ext_jedec: Device ext_jedec ID - * @sector_size: Sector size of this device + * @sector_size: Isn't necessarily a sector size from vendor, the size here + * is what works with Sector erase (64KB) * @nr_sectors: No.of sectors on this device * @e_rd_cmd: Enum list for read commands * @flags: Important param, for flash specific behaviour diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index d19138d..68ec583 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -165,8 +165,9 @@ static int spi_flash_validate_params(struct spi_slave *spi, u8 *idcode, flash->page_size = 256; } flash->page_size <<= flash->shift; - flash->sector_size = params->sector_size << flash->shift; - flash->size = flash->sector_size * params->nr_sectors << flash->shift; + params->nr_sectors <<= flash->shift; + params->sector_size <<= flash->shift; + flash->size = params->sector_size * params->nr_sectors; #ifdef CONFIG_SF_DUAL_FLASH if (flash->dual_flash & SF_DUAL_STACKED_FLASH) flash->size <<= 1; @@ -181,9 +182,12 @@ static int spi_flash_validate_params(struct spi_slave *spi, u8 *idcode, flash->erase_size = 32768 << flash->shift; } else { flash->erase_cmd = CMD_ERASE_64K; - flash->erase_size = flash->sector_size; + flash->erase_size = info->sector_size; }
+ /* Now erase size becomes valid sector size */ + flash->sector_size = flash->erase_size; + /* Look for the fastest read cmd */ cmd = fls(params->e_rd_cmd & flash->spi->op_mode_rx); if (cmd) {
Some catches on this!
On 22 April 2015 at 15:29, Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com wrote:
- @name: Device name ([MANUFLETTER][DEVTYPE][DENSITY][EXTRAINFO])
- @jedec: Device jedec ID (0x[1byte_manuf_id][2byte_dev_id])
- @ext_jedec: Device ext_jedec ID
- @sector_size: Sector size of this device
- @sector_size: Isn't necessarily a sector size from vendor, the size here
- @nr_sectors: No.of sectors on this device
- @e_rd_cmd: Enum list for read commands
- @flags: Important param, for flash specific behaviour
These are read-only object.
Typo it should params->
-- 1.9.1
Will update on next version.
thanks!
Jagan Teki
