[U-Boot] [PATCH v3 1/5] net: fec_mxc: add 1000 Mbps selection
Define CONFIG_FEC_QUIRK_ENET_MAC and add to board files mx6qarm2 and mx6qsabrelite.
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com --- drivers/net/fec_mxc.c | 21 +++++++++++++++++++-- drivers/net/fec_mxc.h | 2 ++ include/configs/mx6qarm2.h | 1 + include/configs/mx6qsabrelite.h | 1 + 4 files changed, 23 insertions(+), 2 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index ed73353..7c42b87 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -379,13 +379,14 @@ static int fec_set_hwaddr(struct eth_device *dev) static int fec_open(struct eth_device *edev) { struct fec_priv *fec = (struct fec_priv *)edev->priv; + int speed;
debug("fec_open: fec_open(dev)\n"); /* full-duplex, heartbeat disabled */ writel(1 << 2, &fec->eth->x_cntrl); fec->rbd_index = 0;
-#if defined(CONFIG_MX6Q) +#ifdef CONFIG_FEC_QUIRK_ENET_MAC /* Enable ENET HW endian SWAP */ writel(readl(&fec->eth->ecntrl) | FEC_ECNTRL_DBSWAP, &fec->eth->ecntrl); @@ -428,9 +429,25 @@ static int fec_open(struct eth_device *edev) #endif
miiphy_wait_aneg(edev); - miiphy_speed(edev->name, fec->phy_id); + speed = miiphy_speed(edev->name, fec->phy_id); miiphy_duplex(edev->name, fec->phy_id);
+#ifdef CONFIG_FEC_QUIRK_ENET_MAC + { + u32 ecr = readl(&fec->eth->ecntrl) & ~FEC_ECNTRL_SPEED; + u32 rcr = (readl(&fec->eth->r_cntrl) & + ~(FEC_RCNTRL_RMII | FEC_RCNTRL_RMII_10T)) | + FEC_RCNTRL_RGMII | FEC_RCNTRL_MII_MODE; + if (speed == _1000BASET) + ecr |= FEC_ECNTRL_SPEED; + else if (speed != _100BASET) + rcr |= FEC_RCNTRL_RMII_10T; + writel(ecr, &fec->eth->ecntrl); + writel(rcr, &fec->eth->r_cntrl); + } +#endif + debug("%s:Speed=%i\n", __func__, speed); + /* * Enable SmartDMA receive task */ diff --git a/drivers/net/fec_mxc.h b/drivers/net/fec_mxc.h index 9825eab..af33d21 100644 --- a/drivers/net/fec_mxc.h +++ b/drivers/net/fec_mxc.h @@ -198,6 +198,7 @@ struct ethernet_regs { #define FEC_RCNTRL_FCE 0x00000020 #define FEC_RCNTRL_RGMII 0x00000040 #define FEC_RCNTRL_RMII 0x00000100 +#define FEC_RCNTRL_RMII_10T 0x00000200
#define FEC_TCNTRL_GTS 0x00000001 #define FEC_TCNTRL_HBC 0x00000002 @@ -207,6 +208,7 @@ struct ethernet_regs {
#define FEC_ECNTRL_RESET 0x00000001 /* reset the FEC */ #define FEC_ECNTRL_ETHER_EN 0x00000002 /* enable the FEC */ +#define FEC_ECNTRL_SPEED 0x00000020 #define FEC_ECNTRL_DBSWAP 0x00000100
#define FEC_X_WMRK_STRFWD 0x00000100 diff --git a/include/configs/mx6qarm2.h b/include/configs/mx6qarm2.h index 0962d3c..495a32a 100644 --- a/include/configs/mx6qarm2.h +++ b/include/configs/mx6qarm2.h @@ -61,6 +61,7 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_NET #define CONFIG_FEC_MXC +#define CONFIG_FEC_QUIRK_ENET_MAC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_XCV_TYPE RGMII diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index d650ee3..2e9775a 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -61,6 +61,7 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_NET #define CONFIG_FEC_MXC +#define CONFIG_FEC_QUIRK_ENET_MAC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_XCV_TYPE RGMII
Also, surround non PHYLIB routines miiphy_restart_aneg and miiphy_wait_aneg with ifndef CONFIG_PHYLIB.
Make fec_miiphy_read, and fec_miiphy_write call a routine common with PHYLIB version so that when later PHYLIB is required it is easy to delete the non-PHYLIB code. This separation idea came from Andy Fleming.
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com --- drivers/net/fec_mxc.c | 122 +++++++++++++++++++++++++++++++++++++++++------- drivers/net/fec_mxc.h | 5 ++ 2 files changed, 109 insertions(+), 18 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 7c42b87..e935426 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -88,16 +88,13 @@ static inline struct ethernet_regs *fec_miiphy_fec_to_eth(struct fec_priv *fec) /* * MII-interface related functions */ -static int fec_miiphy_read(const char *dev, uint8_t phyAddr, uint8_t regAddr, - uint16_t *retVal) +static int fec_mdio_read(struct ethernet_regs *eth, uint8_t phyAddr, + uint8_t regAddr) { - struct eth_device *edev = eth_get_dev_by_name(dev); - struct fec_priv *fec = (struct fec_priv *)edev->priv; - struct ethernet_regs *eth = fec_miiphy_fec_to_eth(fec); - uint32_t reg; /* convenient holder for the PHY register */ uint32_t phy; /* convenient holder for the PHY */ uint32_t start; + int val;
/* * reading from any PHY's register is done by properly @@ -129,10 +126,10 @@ static int fec_miiphy_read(const char *dev, uint8_t phyAddr, uint8_t regAddr, /* * it's now safe to read the PHY's register */ - *retVal = readl(ð->mii_data); + val = (unsigned short)readl(ð->mii_data); debug("fec_miiphy_read: phy: %02x reg:%02x val:%#x\n", phyAddr, - regAddr, *retVal); - return 0; + regAddr, val); + return val; }
static void fec_mii_setspeed(struct fec_priv *fec) @@ -146,13 +143,10 @@ static void fec_mii_setspeed(struct fec_priv *fec) debug("fec_init: mii_speed %08x\n", readl(&fec->eth->mii_speed)); } -static int fec_miiphy_write(const char *dev, uint8_t phyAddr, uint8_t regAddr, - uint16_t data) -{ - struct eth_device *edev = eth_get_dev_by_name(dev); - struct fec_priv *fec = (struct fec_priv *)edev->priv; - struct ethernet_regs *eth = fec_miiphy_fec_to_eth(fec);
+static int fec_mdio_write(struct ethernet_regs *eth, uint8_t phyAddr, + uint8_t regAddr, uint16_t data) +{ uint32_t reg; /* convenient holder for the PHY register */ uint32_t phy; /* convenient holder for the PHY */ uint32_t start; @@ -184,6 +178,43 @@ static int fec_miiphy_write(const char *dev, uint8_t phyAddr, uint8_t regAddr, return 0; }
+#ifdef CONFIG_PHYLIB +int fec_phy_read(struct mii_dev *bus, int phyAddr, int dev_addr, int regAddr) +{ + return fec_mdio_read(bus->priv, phyAddr, regAddr); +} + +int fec_phy_write(struct mii_dev *bus, int phyAddr, int dev_addr, int regAddr, + u16 data) +{ + return fec_mdio_write(bus->priv, phyAddr, regAddr, data); +} +#else + +static int fec_miiphy_read(const char *dev, uint8_t phyAddr, uint8_t regAddr, + uint16_t *retVal) +{ + struct eth_device *edev = eth_get_dev_by_name(dev); + struct fec_priv *fec = (struct fec_priv *)edev->priv; + struct ethernet_regs *eth = fec_miiphy_fec_to_eth(fec); + int val = fec_mdio_read(eth, phyAddr, regAddr); + if (val < 0) + return val; + *retVal = (uint16_t)val; + return 0; +} + +static int fec_miiphy_write(const char *dev, uint8_t phyAddr, uint8_t regAddr, + uint16_t data) +{ + struct eth_device *edev = eth_get_dev_by_name(dev); + struct fec_priv *fec = (struct fec_priv *)edev->priv; + struct ethernet_regs *eth = fec_miiphy_fec_to_eth(fec); + return fec_mdio_write(eth, phyAddr, regAddr, data); +} +#endif + +#ifndef CONFIG_PHYLIB static int miiphy_restart_aneg(struct eth_device *dev) { struct fec_priv *fec = (struct fec_priv *)dev->priv; @@ -241,6 +272,8 @@ static int miiphy_wait_aneg(struct eth_device *dev)
return 0; } +#endif + static int fec_rx_task_enable(struct fec_priv *fec) { writel(1 << 24, &fec->eth->r_des_active); @@ -372,6 +405,21 @@ static int fec_set_hwaddr(struct eth_device *dev) return 0; }
+static void fec_eth_phy_config(struct eth_device *dev) +{ +#ifdef CONFIG_PHYLIB + struct fec_priv *fec = (struct fec_priv *)dev->priv; + struct phy_device *phydev; + + phydev = phy_connect(fec->bus, fec->phy_id, dev, + PHY_INTERFACE_MODE_RGMII); + if (phydev) { + fec->phydev = phydev; + phy_config(phydev); + } +#endif +} + /** * Start the FEC engine * @param[in] dev Our device to handle @@ -428,9 +476,21 @@ static int fec_open(struct eth_device *edev) } #endif
+#ifdef CONFIG_PHYLIB + if (!fec->phydev) + fec_eth_phy_config(edev); + if (fec->phydev) { + /* Start up the PHY */ + phy_startup(fec->phydev); + speed = fec->phydev->speed; + } else { + speed = _100BASET; + } +#else miiphy_wait_aneg(edev); speed = miiphy_speed(edev->name, fec->phy_id); miiphy_duplex(edev->name, fec->phy_id); +#endif
#ifdef CONFIG_FEC_QUIRK_ENET_MAC { @@ -558,9 +618,10 @@ static int fec_init(struct eth_device *dev, bd_t* bd) fec_tbd_init(fec);
+#ifndef CONFIG_PHYLIB if (fec->xcv_type != SEVENWIRE) miiphy_restart_aneg(dev); - +#endif fec_open(dev); return 0; } @@ -836,15 +897,38 @@ static int fec_probe(bd_t *bd, int dev_id, int phy_id, uint32_t base_addr) } fec->phy_id = phy_id;
+#ifdef CONFIG_PHYLIB + { + struct mii_dev *bus = mdio_alloc(); + if (!bus) { + printf("mdio_alloc failed\n"); + ret = -ENOMEM; + goto err3; + } + bus->read = fec_phy_read; + bus->write = fec_phy_write; + sprintf(bus->name, edev->name); + bus->priv = fec->eth; + ret = mdio_register(bus); + if (ret) { + printf("mdio_register failed\n"); + free(bus); + ret = -ENOMEM; + goto err3; + } + fec->bus = bus; + } +#else miiphy_register(edev->name, fec_miiphy_read, fec_miiphy_write); - +#endif eth_register(edev);
if (fec_get_hwaddr(edev, dev_id, ethaddr) == 0) { debug("got MAC%d address from fuse: %pM\n", dev_id, ethaddr); memcpy(edev->enetaddr, ethaddr, 6); } - + /* Configure phy */ + fec_eth_phy_config(edev); return ret;
err3: @@ -877,9 +961,11 @@ int fecmxc_initialize_multi(bd_t *bd, int dev_id, int phy_id, uint32_t addr) return lout; }
+#ifndef CONFIG_PHYLIB int fecmxc_register_mii_postcall(struct eth_device *dev, int (*cb)(int)) { struct fec_priv *fec = (struct fec_priv *)dev->priv; fec->mii_postcall = cb; return 0; } +#endif diff --git a/drivers/net/fec_mxc.h b/drivers/net/fec_mxc.h index af33d21..5fd99b7 100644 --- a/drivers/net/fec_mxc.h +++ b/drivers/net/fec_mxc.h @@ -286,7 +286,12 @@ struct fec_priv { void *base_ptr; int dev_id; int phy_id; +#ifdef CONFIG_PHYLIB + struct mii_dev *bus; + struct phy_device *phydev; +#else int (*mii_postcall)(int); +#endif };
Add the gigabit phy KSZ9021. Also, add function ksz9021_phy_write for access to the phys extended registers. The environment variable "disable_giga" can be used to disable 1000baseTx.
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com --- drivers/net/phy/micrel.c | 82 ++++++++++++++++++++++++++++++++++++++++++++++ include/phy.h | 1 + 2 files changed, 83 insertions(+), 0 deletions(-)
diff --git a/drivers/net/phy/micrel.c b/drivers/net/phy/micrel.c index d4e64f2..d57896f 100644 --- a/drivers/net/phy/micrel.c +++ b/drivers/net/phy/micrel.c @@ -20,6 +20,8 @@ * author Andy Fleming * */ +#include <config.h> +#include <common.h> #include <phy.h>
static struct phy_driver KSZ804_driver = { @@ -42,10 +44,90 @@ static struct phy_driver KS8721_driver = { .shutdown = &genphy_shutdown, };
+/* ksz9021 PHY Registers */ +#define MII_KSZ9021_EXTENDED_CTRL 0x0b +#define MII_KSZ9021_EXTENDED_DATAW 0x0c +#define MII_KSZ9021_PHY_CTL 0x1f +#define MIIM_KSZ9021_PHYCTL_1000 (1 << 6) +#define MIIM_KSZ9021_PHYCTL_100 (1 << 5) +#define MIIM_KSZ9021_PHYCTL_10 (1 << 4) +#define MIIM_KSZ9021_PHYCTL_DUPLEX (1 << 3) + +#define CTRL1000_PREFER_MASTER (1 << 10) +#define CTRL1000_CONFIG_MASTER (1 << 11) +#define CTRL1000_MANUAL_CONFIG (1 << 12) + +int ksz9021_phy_write(struct phy_device *phydev, int devad, int regnum, u16 val) +{ + if (devad == MDIO_DEVAD_NONE) { + return phy_write(phydev, devad, regnum, val); + } else { + /* extended registers */ + phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9021_EXTENDED_CTRL, regnum | 0x8000); + return phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9021_EXTENDED_DATAW, val); + } +} + +/* Micrel ksz9021 */ +static int ksz9021_config(struct phy_device *phydev) +{ + unsigned ctrl1000 = 0; + const unsigned master = CTRL1000_PREFER_MASTER | + CTRL1000_CONFIG_MASTER | CTRL1000_MANUAL_CONFIG; + unsigned features = phydev->drv->features; + + if (getenv("disable_giga")) + features &= ~(SUPPORTED_1000baseT_Half | + SUPPORTED_1000baseT_Full); + /* force master mode for 1000BaseT due to chip errata */ + if (features & SUPPORTED_1000baseT_Half) + ctrl1000 |= ADVERTISE_1000HALF | master; + if (features & SUPPORTED_1000baseT_Full) + ctrl1000 |= ADVERTISE_1000FULL | master; + phydev->advertising = phydev->supported = features; + phy_write(phydev, MDIO_DEVAD_NONE, MII_CTRL1000, ctrl1000); + genphy_config_aneg(phydev); + genphy_restart_aneg(phydev); + return 0; +} + +static int ksz9021_startup(struct phy_device *phydev) +{ + unsigned phy_ctl; + genphy_update_link(phydev); + phy_ctl = phy_read(phydev, MDIO_DEVAD_NONE, MII_KSZ9021_PHY_CTL); + + if (phy_ctl & MIIM_KSZ9021_PHYCTL_DUPLEX) + phydev->duplex = DUPLEX_FULL; + else + phydev->duplex = DUPLEX_HALF; + + if (phy_ctl & MIIM_KSZ9021_PHYCTL_1000) + phydev->speed = SPEED_1000; + else if (phy_ctl & MIIM_KSZ9021_PHYCTL_100) + phydev->speed = SPEED_100; + else if (phy_ctl & MIIM_KSZ9021_PHYCTL_10) + phydev->speed = SPEED_10; + return 0; +} + +static struct phy_driver ksz9021_driver = { + .name = "Micrel ksz9021", + .uid = 0x221610, + .mask = 0xfffff0, + .features = PHY_GBIT_FEATURES, + .config = &ksz9021_config, + .startup = &ksz9021_startup, + .shutdown = &genphy_shutdown, +}; + int phy_micrel_init(void) { phy_register(&KSZ804_driver); phy_register(&KS8721_driver); + phy_register(&ksz9021_driver);
return 0; } diff --git a/include/phy.h b/include/phy.h index bc522d5..3c30f11 100644 --- a/include/phy.h +++ b/include/phy.h @@ -207,6 +207,7 @@ int phy_config(struct phy_device *phydev); int phy_shutdown(struct phy_device *phydev); int phy_register(struct phy_driver *drv); int genphy_config_aneg(struct phy_device *phydev); +int genphy_restart_aneg(struct phy_device *phydev); int genphy_update_link(struct phy_device *phydev); int genphy_config(struct phy_device *phydev); int genphy_startup(struct phy_device *phydev);
Boards may have things they want done before or after normal phy config. Letting the boards call drv->config allows them more flexibilty. Boards affected by this change are corenet_ds and mpc8544ds.
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com --- board/freescale/corenet_ds/eth_p4080.c | 2 ++ board/freescale/mpc8544ds/mpc8544ds.c | 2 ++ drivers/net/phy/phy.c | 5 ++--- 3 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/board/freescale/corenet_ds/eth_p4080.c b/board/freescale/corenet_ds/eth_p4080.c index 1f00c14..b87b092 100644 --- a/board/freescale/corenet_ds/eth_p4080.c +++ b/board/freescale/corenet_ds/eth_p4080.c @@ -96,6 +96,8 @@ struct mii_dev *mii_dev_for_muxval(u32 muxval) #if defined(CONFIG_SYS_P4080_ERRATUM_SERDES9) && defined(CONFIG_PHY_TERANETICS) int board_phy_config(struct phy_device *phydev) { + if (phydev->drv->config) + phydev->drv->config(phydev); if (phydev->drv->uid == PHY_UID_TN2020) { unsigned long timeout = 1 * 1000; /* 1 seconds */ enum srds_prtcl device; diff --git a/board/freescale/mpc8544ds/mpc8544ds.c b/board/freescale/mpc8544ds/mpc8544ds.c index 6fe8d39..24a1715 100644 --- a/board/freescale/mpc8544ds/mpc8544ds.c +++ b/board/freescale/mpc8544ds/mpc8544ds.c @@ -261,6 +261,8 @@ int board_phy_config(struct phy_device *phydev) uint phyid; struct mii_dev *bus = phydev->bus;
+ if (phydev->drv->config) + phydev->drv->config(phydev); if (do_once) return 0;
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index eb55180..7d327f7 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -733,6 +733,8 @@ int phy_startup(struct phy_device *phydev)
static int __board_phy_config(struct phy_device *phydev) { + if (phydev->drv->config) + return phydev->drv->config(phydev); return 0; }
@@ -741,9 +743,6 @@ int board_phy_config(struct phy_device *phydev)
int phy_config(struct phy_device *phydev) { - if (phydev->drv->config) - phydev->drv->config(phydev); - /* Invoke an optional board-specific helper */ board_phy_config(phydev);
Define CONFIG_PHY_MICREL, and minimize the tx clock delay.
There is an issue with 1000 baseTx mode on early revs of the SabreLite boards. The center tap pin 9 of the mag RJ45 USB combo was connected to the 3.3 filtered supply. Letting this pin float solved the problem. Symptoms of the problem were packets with many extra zeroes tacked on the end, and random bit flips causing a high rate of CRC errors. 10/100 baseTx worked fine on all revs. To disable 1000 baseTx for these boards, simply define the environment variable disable_giga. ie.
setenv disable_giga 1
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com Acked-by: Dirk Behme dirk.behme@de.bosch.com --- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 46 +++++-------------------- include/configs/mx6qsabrelite.h | 2 + 2 files changed, 11 insertions(+), 37 deletions(-)
diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index a53b01f..6c11660 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -193,53 +193,25 @@ int board_mmc_init(bd_t *bis) } #endif
-#define MII_1000BASET_CTRL 0x9 -#define MII_EXTENDED_CTRL 0xb -#define MII_EXTENDED_DATAW 0xc - -int fecmxc_mii_postcall(int phy) +int board_phy_config(struct phy_device *phydev) { - /* prefer master mode */ - miiphy_write("FEC", phy, MII_1000BASET_CTRL, 0x0f00); - - /* min rx data delay */ - miiphy_write("FEC", phy, MII_EXTENDED_CTRL, 0x8105); - miiphy_write("FEC", phy, MII_EXTENDED_DATAW, 0x0000); - - /* max rx/tx clock delay, min rx/tx control delay */ - miiphy_write("FEC", phy, MII_EXTENDED_CTRL, 0x8104); - miiphy_write("FEC", phy, MII_EXTENDED_DATAW, 0xf0f0); - miiphy_write("FEC", phy, MII_EXTENDED_CTRL, 0x104); - + ksz9021_phy_write(phydev, 0, 0x105, 0x0); /* min rx data delay */ + ksz9021_phy_write(phydev, 0, 0x106, 0x0); /* min tx data delay */ + /* max rx/tx clock delay, min rx/tx control */ + ksz9021_phy_write(phydev, 0, 0x104, 0xf0f0); + if (phydev->drv->config) + phydev->drv->config(phydev); return 0; }
int board_eth_init(bd_t *bis) { - struct eth_device *dev; int ret; - setup_iomux_enet(); - ret = cpu_eth_init(bis); - if (ret) { + if (ret) printf("FEC MXC: %s:failed\n", __func__); - return ret; - } - - dev = eth_get_dev_by_name("FEC"); - if (!dev) { - printf("FEC MXC: Unable to get FEC device entry\n"); - return -EINVAL; - } - - ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); - if (ret) { - printf("FEC MXC: Unable to register FEC mii postcall\n"); - return ret; - } - - return 0; + return ret; }
int board_early_init_f(void) diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index 2e9775a..47a1832 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -67,6 +67,8 @@ #define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_ETHPRIME "FEC" #define CONFIG_FEC_MXC_PHYADDR 6 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
On 2/1/2012 6:14 PM, Troy Kisky wrote:
- ksz9021_phy_write(phydev, 0, 0x105, 0x0); /* min rx data delay */
- ksz9021_phy_write(phydev, 0, 0x106, 0x0); /* min tx data delay */
- /* max rx/tx clock delay, min rx/tx control */
- ksz9021_phy_write(phydev, 0, 0x104, 0xf0f0);
I didn't notice this warning before
mx6qsabrelite.c:244: warning: implicit declaration of function 'ksz9021_phy_write'
Can I add this definition to mx6qsabrelite.c?
checkpatch says it should be in a .h file.
I'll resend just 5/5 if nobody spots other issues.
Troy
Troy,
On Thu, Feb 2, 2012 at 9:37 AM, Troy Kisky troy.kisky@boundarydevices.com wrote:
delay */
delay */
Definition or declaration? If the function only used by sabrelite board, you can move the definition to mx6qsabrelite.c. If it has more users, you need add it to one head file and include this head file in mx6qsabrelite.c.
I searched u-boot and find only sabrelite board use ksz9021_phy_write, so you can move the definition here.
Please had better re-post the whole patch-set to facilitate the user(at least me) to apply the patch and test. And please make sure you don't break i.mx6qarm2 board. Thanks,
Troy
Signed-off-by: Troy Kiskytroy.kisky@boundarydevices.com Acked-by: Dirk Behmedirk.behme@de.bosch.com
This patch series is against Stefano's u-boot-imx
WBR
Troy
Jason Hui
Troy Kisky
