[U-Boot] [GIT PULL] Please pull u-boot-mmc master
Dear Tom,
Could you pull these patches into u-boot/master? If there is a problem, let me know, plz.
The following changes since commit 08546df976b79b1694af3ff12b26baf2931f371a:
Merge git://git.denx.de/u-boot-x86 (2017-06-27 09:33:10 -0400)
git://git.denx.de/u-boot-mmc.git master
for you to fetch changes up to 34c529a6267a784dc92466909616cd4e03e3f205:
mmc: cadence: use fdt32_t for DT property value to fix sparse warning (2017-06-30 12:22:06 +0900)
---------------------------------------------------------------- Keerthy (12): regulator: Change get_enable return type to integer from bool power: regulator: fixed: get_enable should return integer power: regulator: act8846: get_enable should return integer power: regulator: max77686: get_enable should return integer power: regulator: palmas: get_enable should return integer power: regulator: pfuze100: get_enable should return integer power: regulator: tps65090: get_enable should return integer power: regulator: rk8xx: get_enable should return integer power: sandbox: fixed: get_enable should return integer power: regulator: s5m8767: get_enable should return integer power: regulator: lp873x: get_enable should return integer power: regulator: lp87565: get_enable should return integer
Kever Yang (2): mmc: use new hwpart API when CONFIG_BLK enabled mmc: rpmb: update size format for write_counter
Masahiro Yamada (2): mmc: add static to spl_mmc_get_device_index() mmc: cadence: use fdt32_t for DT property value to fix sparse warning
cmd/mmc.c | 4 ++++ common/spl/spl_mmc.c | 2 +- drivers/mmc/rpmb.c | 2 +- drivers/mmc/sdhci-cadence.c | 2 +- drivers/power/regulator/act8846.c | 2 +- drivers/power/regulator/fixed.c | 2 +- drivers/power/regulator/lp873x_regulator.c | 4 ++-- drivers/power/regulator/lp87565_regulator.c | 2 +- drivers/power/regulator/max77686.c | 4 ++-- drivers/power/regulator/palmas_regulator.c | 4 ++-- drivers/power/regulator/pfuze100.c | 2 +- drivers/power/regulator/regulator-uclass.c | 2 +- drivers/power/regulator/rk8xx.c | 6 +++--- drivers/power/regulator/s5m8767.c | 4 ++-- drivers/power/regulator/sandbox.c | 4 ++-- drivers/power/regulator/tps65090_regulator.c | 2 +- include/power/regulator.h | 8 ++++---- 17 files changed, 30 insertions(+), 26 deletions(-)
Best Regards, Jaehoon Chung
On Fri, Jun 30, 2017 at 12:48:20PM +0900, Jaehoon Chung wrote:
Dear Tom,
Since -rc3 is coming Monday, is there anything here that's just a bugfix? Thanks!
Hi Tom,
Dear Tom,
There is no bugfix..then i will keep these patches in my repository until opening the next merge window.
Jaehoon Chung
